  4. Update von Adaptern funktioniert nicht mehr
    1.7k
jscontroller adapterupdate
65 Beiträge 6 Kommentatoren 6.9k Aufrufe 5 Beobachtet
  • Mrs-BM Mrs-B
    @Mrs-B
    Jetzt werden allerdings nur noch 11 zu aktualisierende Adapter angezeigt.. (auch im 1. Browser)
    Ich versuche jetzt mal die anderen Adapter...
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    #41
    @Mrs-B
    Stopp
    erst dass:
    sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0 libpixman-1-dev
    cd /opt/iobroker
    npm install canvas
    Mrs-BM 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @Mrs-B
      Stopp
      erst dass:
      cd /opt/iobroker
      npm install canvas
      Mrs-BM Offline
      Mrs-BM Offline
      Mrs-B
      #42
      @Glasfaser said in Update von Adaptern funktioniert nicht mehr:
      npm install canvas
      Hab ich so gemacht.
      Jetzt werden mir aber wieder 12 Adapter zur Aktualisierung angezeigt :(
      npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 100
      npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
      npm ERR! Exit status 100
      npm ERR!
      npm ERR! Failed at the iobroker@2.0.3 postinstall script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2020-10-07T15_45_41_794Z-debug.log
      • Mrs-BM Mrs-B
        npm install canvas
        Hab ich so gemacht.
        npm ERR! errno 100
        npm ERR!
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #43
        @Mrs-B
        sudo reboot
          @Mrs-B
          sudo reboot
          Mrs-BM Offline
          Mrs-BM Offline
          Mrs-B
          #44
          @Glasfaser
          Hab ich gemacht. Wieder alle Adapter zur Aktualisierung... Dann nochmal versucht den Alexa Adapter zu aktualisieren..
          Wieder Error ..
          $ ./iobroker upgrade alexa2
          Update alexa2 from @3.3.0 to @3.3.1
          NPM version: 6.14.8
          npm install iobroker.alexa2@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
          ╭─────────────────────────────────────────────────────────╮│                                                         ││ Manual installation of ioBroker is no longer supported  ││ on Linux, OSX and FreeBSD!                              ││ Please refer to the documentation on how to install it! ││ https://github.com/ioBroker/ioBroker/wiki/Installation  ││                                                         │╰─────────────────────────────────────────────────────────╯
          npm ERR! code ELIFECYCLEnpm ERR! errno 100
          npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`npm ERR! Exit status 100npm ERR! npm ERR! Failed at the iobroker@2.0.3 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR!
               /home/iobroker/.npm/_logs/2020-10-07T15_50_44_829Z-debug.log
          ERROR: host.Mrs-Biesly-Pi Cannot install iobroker.alexa2@3.3.1: 100
          Mrs-BM HomoranH 2 Antworten Letzte Antwort
          • Mrs-BM Mrs-B
            @Glasfaser
            Wieder Error ..
            NPM version: 6.14.8
            Mrs-BM Offline
            Mrs-BM Offline
            Mrs-B
            schrieb am zuletzt editiert von Mrs-B
            #45
            @Mrs-B
            Oder ist es am Ende das Beste wenn ich den Rasperry komplett neu mit iobroker aufsetze??
            Ich habe den Backup-Adapter im Einsatz ... Dieser sichert auf nen USB-Stick im PI
            • Mrs-BM Mrs-B
              @Glasfaser
              Wieder Error ..
              NPM version: 6.14.8
              #46
              @Glasfaser
              @Mrs-B sagte in Update von Adaptern funktioniert nicht mehr:
              das hatten wir doch zuletzt erst, dass irgendwo eine dependency auf ioBroker drin stand
              Mrs-BM AlCalzoneA 2 Antworten Letzte Antwort
                @Glasfaser
                Mrs-BM Offline
                Mrs-BM Offline
                Mrs-B
                #47
                @Homoran
                Ähmmmm. Bahnhof ... ????
                • Mrs-BM Mrs-B
                  @Mrs-B
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #48
                  @Mrs-B
                  ioBroker blockt jetzt .
                  Zeige mal :
                  which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  @Homoran
                  Ich komme gerade nicht drauf , was es letztens mal war ....
                    @Mrs-B
                    Zeige mal :
                    @Homoran
                    Mrs-BM Offline
                    Mrs-BM Offline
                    Mrs-B
                    #49
                    @Glasfaser
                    Wie gewünscht...
                    pi@Mrs-Biesly-Pi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v12.19.0
                    /usr/bin/node
                    v12.19.0
                    /usr/bin/npm
                    6.14.8
                    nodejs:
                      Installiert:           12.19.0-1nodesource1
                      Installationskandidat: 12.19.0-1nodesource1
                      Versionstabelle:
                     *** 12.19.0-1nodesource1 100
                            100 /var/lib/dpkg/status
                         10.22.1-1nodesource1 500
                            500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                         10.21.0~dfsg-1~deb10u1+rpi1 500
                    • Mrs-BM Mrs-B
                      @Glasfaser
                      Wie gewünscht...
                      /usr/bin/nodejs
                      v12.19.0
                      /usr/bin/node
                      v12.19.0
                      /usr/bin/npm
                      6.14.8
                      nodejs:
                        Versionstabelle:
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #50
                      @Mrs-B @Homoran
                      das war es :
                      https://forum.iobroker.net/topic/37142/merkwürdige-fehler-bei-adapterupdate/26?lang=en-GB&page=2
                      @Mrs-B
                      Das mußt du jetzt wissen , ob noch mehr an deinem System rumgeschraubt wird !
                      Wenn nicht dann nimm das Backup und setzte dein Rasperry und dann ioBroker neu auf
                      Mrs-BM GlasfaserG 2 Antworten Letzte Antwort
                        @Mrs-B @Homoran
                        das war es :
                        @Mrs-B
                        Mrs-BM Offline
                        Mrs-BM Offline
                        Mrs-B
                        #51
                        @Glasfaser
                        Danke für deine Hilfe!!
                        Tendiere ja fast schon dazu den PI neu aufzusetzten...
                        Welches Image soll ich denn dann dafür nehmen? Finde das alles sehr unübersichtlich...
                        Der verlinkte Thread hat mich jetzt so auf die schnelle nicht weiter gebracht.. Geht schon los mit "Zunächst mal den root abmelden. Dann den Server in Runlevel 3 laufen lassen. Dann den fixer ausführen."
                        Wie gesagt, bin ein absoluter Windows-Mensch (MCSE) ... Mit Linux & Co hab ich sonst nix am Hut und finde es auch nicht gerade übersichtlich beschrieben wie das ganze hier so funktioniert...
                        Hab meinem PI vor Monaten über ein Image hier von iobroker aufgesetzt...
                        • Mrs-BM Mrs-B
                          @Glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          #52
                          Welches Image
                          Mache es händlisch .....
                          passendes Raspberry OS auf Karte
                          sudo raspi-config
                          ... allgemeine Einstellungen durchführen ....
                          und dann das ... siehe oben links
                          https://www.iobroker.net/#de/download
                            Welches Image
                            sudo raspi-config
                            Mrs-BM Offline
                            Mrs-BM Offline
                            Mrs-B
                            #53
                            @Glasfaser
                            Da weiss ich mit meinem Urlaub morgen ja was anzufangen...
                            Noch ne blöde Frage .. Woher weiss ich welches Raspberry OS ich benötige? Da gibt es gefühlt 100....
                            HomoranH Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                            • Mrs-BM Mrs-B
                              @Glasfaser
                              #54
                              nee, nur eins
                              raspberry os lite
                              • Mrs-BM Mrs-B
                                @Glasfaser
                                #55
                                Raspberry
                                Es gibt eigentlich nur eins.
                                Raspberry Pi OS (32-bit) Lite
                                • Mrs-BM Mrs-B
                                  @Glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #56
                                  @Mrs-B
                                  https://www.raspberrypi.org/downloads/raspberry-pi-os/
                                    Welches Image
                                    sudo raspi-config
                                    #57
                                    @Glasfaser sagte in Update von Adaptern funktioniert nicht mehr:
                                    sudo raspi-config
                                    und dann das ...
                                    curl -sLf https://iobroker.net/install.sh | bash -
                                    der Befehl erschlägt auf einem neuen System alles
                                      sudo raspi-config
                                      und dann das ...
                                      Mrs-BM Offline
                                      Mrs-BM Offline
                                      Mrs-B
                                      #58
                                      Ganz lieben Dank euch :) :)
                                      Ich werde mich dann wohl morgen gleich mal dran setzten. In der Hoffnung das mein Backup auch funzt...
                                      Ich werde kurz berichten...
                                        @Glasfaser
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #59
                                        @Homoran sagte in Update von Adaptern funktioniert nicht mehr:
                                        oder package-lock.json korrupt, wonach mir obige Screenshots und Logs aussehen.
                                          @Mrs-B @Homoran
                                          das war es :
                                          @Mrs-B
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          #60
                                          @Mrs-B
                                          @Mrs-B @Homoran
                                          das war es :
                                          Wenn du noch nichts gemacht hast , dann versuche es so wie im oben genannten Thread die Zeile :
                                          "iobroker": "^2.0.3",
                                          aus dem /opt/iobroker/package.json zu löschen .
