  4. Update von Adaptern funktioniert nicht mehr
jscontroller adapterupdate
65 Beiträge 6 Kommentatoren 8.0k Aufrufe 5 Beobachtet
  • Mrs-BM Mrs-B
    @Glasfaser
    Habe jetzt den iobroker mit nem anderen Browser auf meinem Windows geöffnet und auch hier versucht den Alexa Adapter zu aktualisieren...
    $ ./iobroker upgrade alexa2
    Update alexa2 from @3.3.0 to @3.3.1
    NPM version: 6.14.8
    npm install iobroker.alexa2@3.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 5.4.51-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR!
     node -v v12.19.0gyp
     ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp
     ERR! build error node-pre-gyp
     ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)node-pre-gyp
    ERR! System Linux 5.4.51-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    ╭─────────────────────────────────────────────────────────╮│                                                         ││ Manual installation of ioBroker is no longer supported  ││ on Linux, OSX and FreeBSD!                              ││ Please refer to the documentation on how to install it! ││ https://github.com/ioBroker/ioBroker/wiki/Installation  ││                                                         │╰─────────────────────────────────────────────────────────╯
    npm
     ERR! code ELIFECYCLEnpm
     ERR! errno 100
    npm
     ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
    npm ERR! Exit status 100npm ERR! npm
     ERR! Failed at the iobroker@2.0.3 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-10-07T15_37_44_009Z-debug.log
    ERROR: host.Mrs-Biesly-Pi Cannot install iobroker.alexa2@3.3.1: 100
    GlasfaserG Offline
    GlasfaserG Offline
    @Mrs-B
    Jipp ... sehr gut .
    1 Fehler schonmal weg :
    ERR! Unexpected end of JSON input while parsing near '...mGYCbgkC/010kVXLGoixn'
    • Mrs-BM Mrs-B
      @Glasfaser
      NPM version: 6.14.8
      gyp ERR!
       node -v v12.19.0gyp
      node-pre-gyp
      npm
       ERR! errno 100
      npm
      Mrs-BM Offline
      Mrs-BM Offline
      Mrs-B
      schrieb am zuletzt editiert von Mrs-B
      @Mrs-B
      Jetzt werden allerdings nur noch 11 zu aktualisierende Adapter angezeigt.. (auch im 1. Browser)
      Ich versuche jetzt mal die anderen Adapter...
      • Mrs-BM Mrs-B
        @Mrs-B
        GlasfaserG Offline
        GlasfaserG Offline
        @Mrs-B
        Stopp
        erst dass:
        sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0 libpixman-1-dev
        cd /opt/iobroker
        npm install canvas
        Mrs-BM 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          @Mrs-B
          Stopp
          erst dass:
          cd /opt/iobroker
          npm install canvas
          Mrs-BM Offline
          Mrs-BM Offline
          Mrs-B
          @Glasfaser said in Update von Adaptern funktioniert nicht mehr:
          npm install canvas
          Hab ich so gemacht.
          Jetzt werden mir aber wieder 12 Adapter zur Aktualisierung angezeigt :(
          npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm ERR! code ELIFECYCLE
          npm ERR! errno 100
          npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
          npm ERR!
          npm ERR! Failed at the iobroker@2.0.3 postinstall script.
          npm ERR!     /home/iobroker/.npm/_logs/2020-10-07T15_45_41_794Z-debug.log
          • Mrs-BM Mrs-B
            npm install canvas
            Hab ich so gemacht.
            npm ERR! errno 100
            npm ERR!
            GlasfaserG Offline
            GlasfaserG Offline
            @Mrs-B
            sudo reboot
              @Mrs-B
              sudo reboot
              Mrs-BM Offline
              Mrs-BM Offline
              Mrs-B
              @Glasfaser
              Hab ich gemacht. Wieder alle Adapter zur Aktualisierung... Dann nochmal versucht den Alexa Adapter zu aktualisieren..
              Wieder Error ..
              NPM version: 6.14.8
              npm ERR! code ELIFECYCLEnpm ERR! errno 100
              npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`npm ERR! Exit status 100npm ERR! npm ERR! Failed at the iobroker@2.0.3 postinstall script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                   /home/iobroker/.npm/_logs/2020-10-07T15_50_44_829Z-debug.log
              Mrs-BM HomoranH 2 Antworten Letzte Antwort
              • Mrs-BM Mrs-B
                @Glasfaser
                Wieder Error ..
                NPM version: 6.14.8
                Mrs-BM Offline
                Mrs-BM Offline
                Mrs-B
                @Mrs-B
                Oder ist es am Ende das Beste wenn ich den Rasperry komplett neu mit iobroker aufsetze??
                Ich habe den Backup-Adapter im Einsatz ... Dieser sichert auf nen USB-Stick im PI
                • Mrs-BM Mrs-B
                  @Glasfaser
                  Wieder Error ..
                  NPM version: 6.14.8
                  @Glasfaser
                  @Mrs-B sagte in Update von Adaptern funktioniert nicht mehr:
                  das hatten wir doch zuletzt erst, dass irgendwo eine dependency auf ioBroker drin stand
                  Mrs-BM AlCalzoneA 2 Antworten Letzte Antwort
                    @Glasfaser
                    Mrs-BM Offline
                    Mrs-BM Offline
                    Mrs-B
                    @Homoran
                    Ähmmmm. Bahnhof ... ????
                    • Mrs-BM Mrs-B
                      @Mrs-B
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Mrs-B
                      ioBroker blockt jetzt .
                      Zeige mal :
                      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      @Homoran
                      Ich komme gerade nicht drauf , was es letztens mal war ....
                        @Mrs-B
                        Zeige mal :
                        @Homoran
                        Mrs-BM Offline
                        Mrs-BM Offline
                        Mrs-B
                        @Glasfaser
                        Wie gewünscht...
                        pi@Mrs-Biesly-Pi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        /usr/bin/nodejs
                        v12.19.0
                        /usr/bin/node
                        v12.19.0
                        /usr/bin/npm
                        6.14.8
                        nodejs:
                          Installiert:           12.19.0-1nodesource1
                          Installationskandidat: 12.19.0-1nodesource1
                          Versionstabelle:
                         *** 12.19.0-1nodesource1 100
                             10.22.1-1nodesource1 500
                                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                             10.21.0~dfsg-1~deb10u1+rpi1 500
                        • Mrs-BM Mrs-B
                          @Glasfaser
                          Wie gewünscht...
                          /usr/bin/nodejs
                          v12.19.0
                          /usr/bin/node
                          v12.19.0
                          /usr/bin/npm
                          6.14.8
                          nodejs:
                            Versionstabelle:
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @Mrs-B @Homoran
                          das war es :
                          https://forum.iobroker.net/topic/37142/merkwürdige-fehler-bei-adapterupdate/26?lang=en-GB&page=2
                          @Mrs-B
                          Das mußt du jetzt wissen , ob noch mehr an deinem System rumgeschraubt wird !
                          Wenn nicht dann nimm das Backup und setzte dein Rasperry und dann ioBroker neu auf
                          Mrs-BM GlasfaserG 2 Antworten Letzte Antwort
                            @Mrs-B @Homoran
                            das war es :
                            @Mrs-B
                            Mrs-BM Offline
                            Mrs-BM Offline
                            Mrs-B
                            @Glasfaser
                            Danke für deine Hilfe!!
                            Tendiere ja fast schon dazu den PI neu aufzusetzten...
                            Welches Image soll ich denn dann dafür nehmen? Finde das alles sehr unübersichtlich...
                            Der verlinkte Thread hat mich jetzt so auf die schnelle nicht weiter gebracht.. Geht schon los mit "Zunächst mal den root abmelden. Dann den Server in Runlevel 3 laufen lassen. Dann den fixer ausführen."
                            Wie gesagt, bin ein absoluter Windows-Mensch (MCSE) ... Mit Linux & Co hab ich sonst nix am Hut und finde es auch nicht gerade übersichtlich beschrieben wie das ganze hier so funktioniert...
                            Hab meinem PI vor Monaten über ein Image hier von iobroker aufgesetzt...
                            • Mrs-BM Mrs-B
                              @Glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Welches Image
                              Mache es händlisch .....
                              passendes Raspberry OS auf Karte
                              sudo raspi-config
                              ... allgemeine Einstellungen durchführen ....
                              und dann das ... siehe oben links
                              https://www.iobroker.net/#de/download
                                Welches Image
                                sudo raspi-config
                                Mrs-BM Offline
                                Mrs-BM Offline
                                Mrs-B
                                @Glasfaser
                                Da weiss ich mit meinem Urlaub morgen ja was anzufangen...
                                Noch ne blöde Frage .. Woher weiss ich welches Raspberry OS ich benötige? Da gibt es gefühlt 100....
                                HomoranH Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
                                • Mrs-BM Mrs-B
                                  @Glasfaser
                                  nee, nur eins
                                  raspberry os lite
                                  • Mrs-BM Mrs-B
                                    @Glasfaser
                                    Raspberry
                                    Es gibt eigentlich nur eins.
                                    Raspberry Pi OS (32-bit) Lite
                                    • Mrs-BM Mrs-B
                                      @Glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @Mrs-B
                                      https://www.raspberrypi.org/downloads/raspberry-pi-os/
                                        Welches Image
                                        sudo raspi-config
                                        @Glasfaser sagte in Update von Adaptern funktioniert nicht mehr:
                                        sudo raspi-config
                                        und dann das ...
                                        curl -sLf https://iobroker.net/install.sh | bash -
                                        der Befehl erschlägt auf einem neuen System alles
                                          sudo raspi-config
                                          und dann das ...
                                          Mrs-BM Offline
                                          Mrs-BM Offline
                                          Mrs-B
                                          Ganz lieben Dank euch :) :)
                                          Ich werde mich dann wohl morgen gleich mal dran setzten. In der Hoffnung das mein Backup auch funzt...
                                          Ich werde kurz berichten...
