  4. SyntaxError: Unexpected Tokken
syntaxerror
71 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • F Finnimeister
    code_text/usr/bin/nodejs
    v12.18.1
    /usr/bin/node
    v12.18.1
    /usr/bin/npm
    6.14.5
    nodejs:
      Installiert:           12.18.1-1nodesource1
      Installationskandidat: 12.18.1-1nodesource1
      Versionstabelle:
     *** 12.18.1-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
            100 /var/lib/dpkg/status
         8.11.1~dfsg-2~bpo9+1 500
            500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
         4.8.2~dfsg-1 500
            500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
    pi@All-In-One_RasPi:~ $
    @Finnimeister
    iobroker stop
    iobroker fix
    iobroker start
    Und dann sollte das Ding wieder laufen.
    • F Offline
      Finnimeister
      code_textpi@All-In-One_RasPi:~ $ iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
      An unknown error occurred: Error: Failed to write pidfile (EACCES)
      • F Finnimeister
        @Finnimeister Was passierte bei
        iobroker fix
        denn? Ich kann nicht hellsehen...
        • F Offline
          Finnimeister
          sorry...
          code_textCommands:
          iobroker setup [--objects <host>] [--states <host>] [custom]
          iobroker start - starts the js-controller
          iobroker stop - stops the js-controller
          iobroker start <adapter>[.instance] - starts a specified adapter instance
          iobroker stop <adapter>.[instance] - stops a specified adapter instance
          iobroker start all - starts js-controller and all adapters
          iobroker restart - restarts the js-controller
          iobroker restart <adapter>[.instance] - restarts a specified adapter
          iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
              --wait stops the execution until the debugger is attached.
              --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
          iobroker info - shows the host info
          iobroker logs [adapter] [--watch] [--lines=1000]
          iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
          iobroker install <adapter> - installs a specified adapter
          iobroker rebuild <adapter>|self [--install]
          iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
          iobroker del <adapter> - remove adapter from system
          iobroker del <adapter>.<instance> - remove adapter instance
          iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
          iobroker upgrade [repository url]
          iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
          iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
          iobroker upload <pathToLocalFile> <pathIniobroker>
          iobroker upload all - upload all adapter files to make them available for instances
          iobroker upload <adapter> - upload specified adapter files to make them available for instances
          iobroker object get <id> - get object specified by id
          iobroker object set <id> <json-value> - set object with the given id by providing a new json object
          iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
          iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
          iobroker object del <id|pattern> [--yes]
          iobroker object chmod <object-mode> [state-mode] <id>
          iobroker object chown <user> <group> <id>
          iobroker object list <id>
          iobroker state get <id> - get state, specified by id
          iobroker state getplain <id> [--pretty]
          iobroker state getvalue <id>
          iobroker state set <id> <value> [ack]
          iobroker state del <id>
          iobroker message <adapter>[.instance] <command> [<message>]
          iobroker list <type> [filter]
          iobroker chmod <mode> <file>
          iobroker chown <user> <group> <file>
          iobroker touch <file>
          iobroker rm <file>
          iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
          iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
          iobroker file rm <iobroker-path-to-delete>
          iobroker file sync
          iobroker user add <user> [--ingroup group] [--password pass]
          iobroker user del <user>
          iobroker user passwd <user> [--password pass]
          iobroker user enable <user>
          iobroker user disable <user>
          iobroker user get <user>
          iobroker user check <user> [--password pass]
          iobroker group add <group>
          iobroker group del <group>
          iobroker group list <group>
          iobroker group enable <group>
          iobroker group disable <group>
          iobroker group get <group>
          iobroker group adduser <group> <user>
          iobroker group deluser <group> <user>
          iobroker host this
          iobroker host <hostname>
          iobroker host set <hostname>
          iobroker host remove <hostname>
          iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
          iobroker license <license.file or license.text>
          iobroker cert create
          iobroker cert view [<certificate name>]
          iobroker clean
          iobroker backup
          iobroker restore <backup name or path> - restore a specified backup
          iobroker validate <backup name or path> - validate a specified backup
          iobroker <command> --timeout 5000
          iobroker status [all|<adapter>.<instance>]
          iobroker repo [name]
          iobroker repo add <name> <path or url>
          iobroker repo set <name>
          iobroker repo del <name>
          iobroker uuid
          iobroker unsetup
          iobroker fix - execute the installation fixer script, this updates your ioBroker installation
          iobroker multihost <enable|disable> [--secure true|false]
          iobroker multihost browse
          iobroker multihost connect
          iobroker compact status - show if compact mode is enabled in general
          iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
          iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
          iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
          iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
          iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
          iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
          iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
          iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
          iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
          iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
          iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
          iobroker version [adapter] - show version of js-controller or specified adapter
          iobroker [adapter] -v - show version of js-controller or specified adapter
          Options:
            --help     Hilfe anzeigen  [boolean]
            --version  Version anzeigen  [boolean]
          • F Finnimeister
            sorry...
            code_textCommands:
            iobroker rm <file>
            iobroker file sync
            iobroker host this
            iobroker clean
            iobroker backup
            iobroker uuid
            iobroker unsetup
            Options:
            @Finnimeister
            curl -sL https://iobroker.net/fix.sh | bash –
            Und bitte poste deine Eingabe mit. Dann kann man besser sehen, was du da so treibst.
            • F Offline
              Finnimeister
              Hallo hatte leider gestern kein netz mehr...
              es hat erst gelaufen und dan habe ich was aktualiesiert und dan gin wieder nix mehr...
              code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker start
              internal/modules/cjs/loader.js:969
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
                  at internal/main/run_main_module.js:17:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              • F Finnimeister
                  throw err;
                  requireStack: []
                @Finnimeister Was hast du denn wie aktualisiert?
                Fixer nochmal drüber jagen:
                F 1 Antwort Letzte Antwort
                  Finnimeister
                  @Thomas-Braun
                  hab auf den kreis geklickt zu aktualiesieren
                  • F Finnimeister
                    @Thomas-Braun
                    @Finnimeister
                    Fixer laufen lassen.
                    Dann
                    iobroker update
                    iobroker upgrade
                    • F Offline
                      Finnimeister
                      geht leider nicht....
                      code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker update
                        throw err;
                        requireStack: []
                      • F Finnimeister
                          throw err;
                          requireStack: []
                        @Finnimeister Und der Fixer?
                        • F Offline
                          Finnimeister
                          geht auch nicht...
                          code_textpi@All-In-One_RasPi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash –
                          bash: –: Datei oder Verzeichnis nicht gefunden
                          • F Finnimeister
                            geht auch nicht...
                            @Finnimeister
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install iobroker.js-controller
                            • F Offline
                              Finnimeister
                              code_textpi@All-In-One_RasPi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                              sudo: Unbekannter Benutzer: iobroker
                              sudo: Regelwerks-Plugin konnte nicht initialisiert werden
                              • F Finnimeister
                                @Finnimeister
                                Warum hast du denn keinen user iobroker?
                                So eine alte Installation?
                                cd /opt/iobroker
                                • F Offline
                                  Finnimeister
                                  Danke !!! bist der beste....es läuft wieder....
                                  • F Finnimeister
                                    @Finnimeister
                                    Dann jetzt den Fixer hinterher!
                                    • F Offline
                                      Finnimeister
                                      Meinst du das...
                                      code_textcurl -sL https://iobroker.net/fix.sh | bash –
                                      • F Finnimeister
                                        Meinst du das...
                                        @Finnimeister
                                        Ja. Oder
                                        iobroker stop
                                        iobroker fix
                                        • F Offline
                                          Finnimeister
                                          code_textpi@All-In-One_RasPi:/opt/iobroker $ iobroker fix
                                          Commands:
                                          iobroker rm <file>
                                          iobroker file sync
                                          iobroker host this
                                          iobroker clean
                                          iobroker backup
                                          iobroker uuid
                                          iobroker unsetup
                                          Options:
