  4. Update tr-064 Adapter
adapter
28 Beiträge 4 Kommentatoren 3.3k Aufrufe 4 Beobachtet
    Ralf
    seit einiger Zeit wird im iobroker ein Update angeboten, welches aber nicht installiert werden kann. Im Log steht Folgendes :
    tr-064.0 2020-06-01 09:18:46.824 info (4526) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:18:46.822 info (4526) terminating
    tr-064.0 2020-06-01 09:18:46.785 error (4526) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
    tr-064.0 2020-06-01 09:18:46.782 error (4526) unhandled promise rejection: Cannot read property 'getState' of undefined
    tr-064.0 2020-06-01 09:18:46.781 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tr-064.0 2020-06-01 09:18:46.724 info (4526) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
    tr-064.0 2020-06-01 09:18:13.493 info (3556) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:18:13.492 info (3556) terminating
    tr-064.0 2020-06-01 09:18:13.459 error (3556) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
    tr-064.0 2020-06-01 09:18:13.455 error (3556) unhandled promise rejection: Cannot read property 'getState' of undefined
    tr-064.0 2020-06-01 09:18:13.454 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tr-064.0 2020-06-01 09:18:13.394 info (3556) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
    tr-064.0 2020-06-01 09:17:40.102 info (2500) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:17:40.101 info (2500) terminating
    tr-064.0 2020-06-01 09:17:40.067 error (2500) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/io
    tr-064.0 2020-06-01 09:17:40.064 error (2500) unhandled promise rejection: Cannot read property 'getState' of undefined
    tr-064.0 2020-06-01 09:17:40.062 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    tr-064.0 2020-06-01 09:17:39.999 info (2500) starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.1.4
    tr-064.0 2020-06-01 09:17:06.757 info (1576) Terminated (NO_ERROR): Without reason
    tr-064.0 2020-06-01 09:17:06.756 info (1576) terminating
    Der Adapter ist rot und lässt sich auch nicht mehr starten.
    Kann da vielleicht jemand helfen ?
    Thomas BraunT sigi234S 2 Antworten Letzte Antwort
    • R Ralf
      @Ralf EInmal den Adapter deinstallieren und dann neuinstallieren.
      BTW: Fehlermeldungen bitte in </> CodeTags setzen.
      R 1 Antwort Letzte Antwort
        Ralf
        @Thomas-Braun Nach der Deinstallation und Restart von iobroker wird immer noch das Update angeboten obwohl der Adapter in den Instanzen nicht mehr vorhanden ist. Blicke im Moment leider nicht durch.
        J Thomas BraunT 2 Antworten Letzte Antwort
        • R Ralf
          Jan1
          @Ralf
          Du hast wohl nur die Instanz deinstalliert und nicht den ganzen Adapter
          • R Ralf
            @Ralf
            iobroker list adapters
            iobroker update
            iobroker del tr-064
            iobroker add tr-064
              @Ralf
              iobroker update
              iobroker del tr-064
              iobroker add tr-064
              Ralf
              @Thomas-Braun sagte in Update tr-064 Adapter:
              iobroker del tr-064
              Adapter lässt sich nicht deinstallieren :
              <Delete adapter "tr-064"
              npm uninstall iobroker.tr-064 --error --prefix "/opt/iobroker" (System call)
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dgram
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/ip
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/safe-buffer
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/dns-packet
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/sprintf-js
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.tr-064/node_modules/soef
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm ERR! code EACCES
              npm ERR! syscall access
              npm ERR! path /opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'
              npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext']
              npm ERR! stack:
              npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext'',
              npm ERR! errno: -13,
              npm ERR! code: 'EACCES',
              npm ERR! syscall: 'access',
              npm ERR! path:
              npm ERR! '/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext' }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR! /home/iobroker/.npm/_logs/2020-06-01T08_05_12_110Z-debug.log
              Error deleting adapter tr-064 from disk: Error: host.debian-iobroker: Cannot uninstall iobroker.tr-064: 243
              You might have to delete it yourself!
              root@debian-iobroker:~#
              • R Ralf
                iobroker del tr-064
                npm ERR! errno -13
                npm ERR! stack:
                npm ERR! path:
                npm ERR!
                npm ERR!
                @Ralf
                Nicht als root rumhampeln und Konsolenausgaben in CodeTags setzen.
                • R Ralf
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  @Ralf
                  Bitte benutzt die Code Tags Funktion -> </>
                  Hier gehts zur Hilfe.
                  Immer Daten sichern!
                    @Ralf
                    Ralf
                    @Thomas-Braun Meldung in der Konsole :
                    Leider darf der Benutzer ralf »/usr/bin/iobroker update« als root auf debian-iobroker nicht ausführen.
                    • sigi234S sigi234
                      @Ralf
                      Ralf
                      @sigi234 sagte in Update tr-064 Adapter:
                      Finde leider nichts dazu wie man´s macht.
                      J 1 Antwort Letzte Antwort
                      • R Ralf
                        Jan1
                        @Ralf
                        Wie man mit der Maus scrollt ist aber bekannt, oder? Also scroll mal im Link von sigi234 bis Editor runter.
                        • J Jan1
                          @Ralf
                          Ralf
                          @Jan1 ```
                          manchmal dauert´s halt etwas länger
                          • R Ralf
                            @Jan1 ```
                            Jan1
                            @Ralf
                            ist egal, wenn es dann doch irgendwann mal klappt ;-)
                            • J Jan1
                              @Ralf
                              Ralf
                              @Jan1 noch eine Idee wie ich den Adapter los werde und neu installieren kann ?
                              • R Ralf
                                @Ralf
                                adduser ralf sudo
                                Ggf. das nochmal als root und dann den root-login künftig vermeiden.
                                  @Ralf
                                  adduser ralf sudo
                                  Ralf
                                  @Ralf
                                  adduser ralf sudo
                                  ...und dann als "Ralf" einloggen ?
                                  Ist das ein Problem, wenn ich mich als root einlogge ?
                                  • R Ralf
                                    @Ralf
                                    adduser ralf sudo
                                    @Ralf
                                    Ja, dann als Ralf einloggen.
                                    root-login sollte tabu sein.
                                    Als ralf dann
                                    sudo whoami
                                      @Ralf
                                      Als ralf dann
                                      sudo whoami
                                      Ralf
                                      warum ??
                                      • R Ralf
                                        warum ??
                                        @Ralf
                                        Why sudo?
                                        Using sudo is better (safer) than opening a session as root for a number of reasons, including:
                                        Nobody needs to know the root password (sudo prompts for the current user's password). Extra privileges can be granted to individual users temporarily, and then taken away without the need for a password change.
                                        It's easy to run only the commands that require special privileges via sudo; the rest of the time, you work as an unprivileged user, which reduces the damage that mistakes can cause.
                                        Auditing/logging: when a sudo command is executed, the original username and the command are logged.
                                        For the reasons above, switching to root using sudo -i (or sudo su) is usually deprecated because it cancels the above features.
                                        Und das ganze System inkl. des Rechtemanagement ist darauf ausgelegt mit sudo zu agieren.
                                          @Ralf
                                          Why sudo?
                                          Ralf
                                          @Thomas-Braun Adapter lässt sich nach wie vor nicht deinstallieren :
                                          ralf@debian-iobroker:~$ sudo whoami
                                          root
                                          ralf@debian-iobroker:~$ iobroker del tr-064
                                          npm ERR! errno -13
                                          npm ERR!   stack:
                                          npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.tr-064/node_modules/array-ext\'',
                                          npm ERR!   path:
                                          npm ERR!
                                          npm ERR!
                                          npm ERR!     /home/iobroker/.npm/_logs/2020-06-01T09_12_12_551Z-debug.log
