  4. js-controller 3.0/3.1 jetzt im Latest!
    1.0k
    6.1k
js-controller
1.3k Beiträge 127 Kommentatoren 593.2k Aufrufe 89 Beobachtet
    @dslraser Nicht als root!
    dslraserD Offline
    dslraserD Offline
    dslraser
    #681
    @Thomas-Braun
    sondern ? (Portainer---Docker)
    • dslraserD dslraser
      @Thomas-Braun
      #682
      @dslraser Ach, der blöde Docker...
      npm rebuild canvas --build-from-source
        dslraserD Offline
        dslraserD Offline
        dslraser
        #683
        @Thomas-Braun sagte in js-controller 3.0 jetzt im Latest!:
        root@iobroker:/opt/iobroker# npm rebuild canvas --build-from-source
        > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        Package pixman-1 was not found in the pkg-config search path.
        Perhaps you should add the directory containing `pixman-1.pc'
        to the PKG_CONFIG_PATH environment variable
        No package 'pixman-1' found
        gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        gyp ERR! configure error
        gyp ERR! stack Error: `gyp` failed with exit code: 1
        gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
        gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
        gyp ERR! System Linux 4.4.59+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v12.16.3
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
        node-pre-gyp ERR! System Linux 4.4.59+
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v12.16.3
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
        node-pre-gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.6.1 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /opt/iobroker/.npm/_logs/2020-05-02T11_26_33_480Z-debug.log
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          #684
          @dslraser Da fehlen jetzt die -dev-Pakete aus dem graphic stack. Ich weiß aber nicht wo man die bei deinem System her bekommt.
            dslraserD Offline
            dslraserD Offline
            dslraser
            #685
            @Thomas-Braun
            ich bin jetzt mal ne Stunde wech, nachher gets weiter.
            • liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              #686
              was sind das für warnungen ? weiß jmd, wie man die die wegbekommen kann
              web.1	2020-05-02 13:43:02.580	warn	(22881) readFile will not read this file (uploads/files/1588419094081-xxxxxxxxxxxxxx6f-0378895cb788-grafik.png) in future versions: assets is not an object of type "meta"
              kommt so alle 20-30 sekunden - die
                dslraserD Offline
                dslraserD Offline
                dslraser
                #687
                Was für Infos brauchst Du dafür ?
                  @dirk1962 sagte in js-controller 3.0 jetzt im Latest!:
                  @dslraser
                  Ich habe den Befehl nach "iobroker stop" im Verzeichnis "opt/iobroker" ausgeführt.
                  Mache ich da was falsch?
                  @apollon77
                  Beim heutigen Update (iot 1.4.14) ist es wieder da...
                  2020-05-02 13:05:48.477 - warn: iot.0 (1102) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                  was compiled against a different Node.js version using
                  NODE_MODULE_VERSION 64. This version of Node.js requires
                  NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                  the module (for instance, using `npm rebuild` or `npm install`).
                  #688
                  @dslraser Poste mal das install log von dem update
                    @dslraser
                    npm rebuild canvas
                    In /opt/iobroker
                    #689
                    @Thomas-Braun Das iobroker rebuild iot --install ist der preferred way mit controller 3.0!
                    dirk1962D 1 Antwort Letzte Antwort
                      #690
                      @Thomas-Braun Und genau aus dem grund haben wir das eigene Kommando! @Thomas-Braun Bitte empfehle das in Zukunft. Danke!
                      • apollon77A apollon77
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #691
                        @apollon77 sagte in js-controller 3.0 jetzt im Latest!:
                        vom iot Update, oder welches meinst Du ?
                        • liv-in-skyL liv-in-sky
                          #692
                          @liv-in-sky eigene Files die du irgendwie aus nem eigenen Folder lesen willst oder so? Der Name ist "assets" ... klingelt da was vllt?
                            #693
                            @dslraser Die sollte der Adapter an sich installieren ... mach mal ein apt installmit der Liste die da angegeben ist https://github.com/ioBroker/ioBroker.iot/blob/master/io-package.json#L243
                            Deswegen wäre ich mal über ein Install Log vom Adapter echt erfreut
                            Bzw bitte führe mal im container das hier aus
                            node -e 'console.log(process.platform);'
                            Was ist das Ergebnis?
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #694
                              root@iobroker:/opt/iobroker# node -e 'console.log(process.platform);'
                              linux
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #695
                                das Log von heute habe ich vorhin gelöscht, da ich noch was anderes gemacht habe, da ist jetzt fast nichts drinn, jedenfalls nichts mehr von den Updates...😕
                                  #696
                                  @dslraser Dann versuch mal manuell die genannten Pakete zu installieren, an sich würde ich aber erwarten das er sagt das die alle da sind
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #697
                                    @apollon77
                                    meinst Du so ? (dann wäre das erste schon nicht da, oder ?)
                                    root@iobroker:/opt/iobroker# apt install libcairo2-dev
                                    E: Paket libcairo2-dev kann nicht gefunden werden.
                                      @apollon77
                                      #698
                                      @dslraser Was hast denn du für ein System in deinem Container? Also Debian hat das seit ewig (https://packages.debian.org/search?keywords=libcairo2-dev), Ubuntu an such auch ...
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #699
                                        @apollon77
                                        das ist das "Buanet Image 4.2=latest"
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          #700
                                          Das hier: Buanet
