  4. Installation klappt nicht
gyp error
15 Beiträge 5 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • ? Offline
    Hallo Community,
    Ich möchte mit iobroker auf eine Proxmox vm wechseln.
    Leider erhalte ich immer Fehlermeldungen beim Installieren. Dabei habe ich mehrere Varianten ausprobiert:
    Iobroker auf Kvm vm installiert.
    Iobroker auf Lxc Container installiert.
    Beide Varianten mit sudo und root probiert.
    System:
    Debian 10 Buster
    Proxmox 6.1
    Fehlermeldungen:
    Linux iobroker-vm 4.19.0-8-amd64 #1 SMP Debian 4.19.98-1 (2020-01-26) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Thu Apr  9 09:03:24 2020 from 192.168.178.33
    root@iobroker-vm:~# su iobrokeruser
    iobrokeruser@iobroker-vm:/root$ curl -sL https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2020-01-30
        Welcome to the ioBroker installer!
        Installer version: 2020-01-25
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    [sudo] Passwort für iobrokeruser:
    OK:1 http://debian.inf.tu-dresden.de/debian buster InRelease
    OK:2 http://debian.inf.tu-dresden.de/debian buster-updates InRelease
    OK:3 http://security.debian.org/debian-security buster/updates InRelease
    OK:4 https://deb.nodesource.com/node_13.x buster InRelease
    Error: EACCES: permission denied, scandir '/root'
    bash: Zeile 71: [: !=: Einstelliger (unärer) Operator erwartet.
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
       v8::String::Utf8Value path(info[0]->ToString());
    In file included from /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/node.h:67,
                     from ../../nan/nan.h:54,
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:2750:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’
       V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:2750:44: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
       v8::Local<v8::Object> options = info[1]->ToObject();
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:2754:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’
       V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:2754:44: note:   candidate expects 1 argument, 0 provided
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    ../../nan/nan.h:1740:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
         results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:3547:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
       V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:3547:37: note:   candidate expects 3 arguments, 2 provided
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:3550:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
       V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/v8.h:3550:37: note:   candidate expects 3 arguments, 2 provided
    ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
         results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
    ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
         results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
         results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
       void init(v8::Handle<v8::Object> target) {
    ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
    ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
    ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
    ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
                                        tzset
    In file included from ../../nan/nan.h:54,
    ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
     NODE_MODULE(serialport, init);
    /home/iobrokeruser/.cache/node-gyp/13.12.0/include/node/node.h:618:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
    ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
    make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.0-8-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/serialport
    gyp ERR! node -v v13.12.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
                                        tzset
    gyp ERR! not ok
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.178.45:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
      Hallo Community,
      System:
      Debian 10 Buster
      Proxmox 6.1
      Fehlermeldungen:
      library: loaded
      Installed gcc-c++
                                          tzset
      gyp ERR! not ok
                                          tzset
      gyp ERR! not ok
      Autostart enabled!
      simatecS Offline
      simatecS Offline
      simatec
      @david83
      Nach welcher Anleitung hast du iobroker installiert?
      Welche node Version nutzt du?
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • ? Offline
        root@iobroker-vm:~# node -v
        v13.12.0
        root@iobroker-vm:~# npm -v
        6.14.4
        So habe ich installiert:
        Installation guide
        This page contains a short description on how to install ioBroker. See below for more detailed and localized version of the installation steps.
        Linux based systems and MacOS
        Preparation
            Install nodejs: New installations of ioBroker need at least nodejs 8.12. ioBroker basically also supports the other LTS versions (even version number!!) of nodejs. See https://github.com/nodesource/distributions#debinstall for detailed instructions
            Verify nodejs installation: the commands node -v and nodejs -v should output the same version number
            verify npm installation: the command npm -v should return a version number > 6.4.1. If not use sudo npm install -g npm@6 to update
            Install needed build tools: Make sure to also install additional libraries: sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev
        Installing ioBroker
        Please open a SSH shell. You do not need to use a root shell to install ioBroker. If a normal unprivilidged user exists you should start the installation with this user.
        Then execute
        This will install ioBroker in 4 steps and show its progress:
            Creating ioBroker directory (1/4)
            Downloading installation files (2/4)
        At the end you should see
        ioBroker was installed successfully Open http://localhost:8081 in a browser and start configuring!
        J 1 Antwort Letzte Antwort
          v13.12.0
          6.14.4
          Installation guide
          Preparation
          Installing ioBroker
          Then execute
          Jan1
          @david83
          Node 13 ist eine ungerade und somit ne Entwickler Version. Ich denke das steht auch so recht deutlich in der offiziellen IOBroker Doku.
          Gerade geschaut, steht sogar in rot drin, somit hast schon nicht die richtige Doku zur Installation.
          • ? Offline
            OK, jetzt habe ich die VM neu aufgesetzt und die offizielle Installationsanleitung von iobroker.net genommen:
            Images werden nur benötigt, wenn Probleme mit Installationsskripten auftreten.
            Die Installation kann einfach mit 1 bis 3 Zeilen Code erfolgen.
            1. Erst Node.js installieren (wenn noch nicht vorhanden):
            curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
            sudo apt-get install -y nodejs
            2. Anschließend ioBroker installieren:
            Nun bekomme ich folgende Warnungen und Fehler:
            OK:1 http://security.debian.org/debian-security buster/updates InRelease
            OK:2 http://debian.inf.tu-dresden.de/debian buster InRelease
            Holen:3 http://debian.inf.tu-dresden.de/debian buster-updates InRelease [49,3 kB]
            E: Release file for http://debian.inf.tu-dresden.de/debian/dists/buster-updates/InRelease is not valid yet (invalid for another 14 h 8 min 12 s). Updates for this repository will not be applied.
            Installed npm
            npm WARN npm npm does not support Node.js v10.15.2
            npm WARN npm You should probably upgrade to a newer version of node as we
            npm WARN npm can't make any promises that npm will work with this version.
            npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.npm WARN npm You can find the latest version at https://nodejs.org/
            Changing npm registry to https://registry.npmjs.org
            Installed acl
            Installed build-essential
            Installed gcc-c++
            Installed libavahi-compat-libdnssd-dev
            Installed libudev-dev
            Installed libpam0g-dev
            Installed git
            Installed unzip
            Installed python-dev
            User iobroker created
            You are using npm 5.8.0, but ioBroker needs at least using 6.0.0.
            Please use "npm install -g npm" to install a supported version!
            You need to make sure to repeat this step after installing an update to NodeJS and/or npm.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 4
            npm ERR! iobroker@2.0.3 install: `node lib/checkVersions.js`
            npm ERR! Exit status 4
            npm ERR!
            npm ERR! Failed at the iobroker@2.0.3 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /root/.npm/_logs/2020-04-09T09_06_45_748Z-debug.log
            Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
            Autostart enabled!
            root@iobroker-vm:~#
            J wendy2702W HomoranH 4 Antworten Letzte Antwort
              Installed npm
              Installed acl
              Installed gcc-c++
              Installed git
              Installed unzip
              npm ERR! errno 4
              npm ERR!
              Autostart enabled!
              root@iobroker-vm:~#
              Jan1
              @david83
              IOBroker scheint ja nun drauf zu sein, bleibt noch die Frage was bringt den nun
              node -v
              nodejs -v
              npm -v
              • ? Offline
                v10.20.0
                root@iobroker-vm:~# nodejs -v
                v10.20.0
                6.14.4
                root@iobroker-vm:~#
                  Installed npm
                  Installed acl
                  Installed gcc-c++
                  Installed git
                  Installed unzip
                  npm ERR! errno 4
                  npm ERR!
                  Autostart enabled!
                  root@iobroker-vm:~#
                  wendy2702W Online
                  wendy2702W Online
                  wendy2702
                  @david83 sagte in Installation klappt nicht:
                  Und was passiert wenn du das in den Browser einfügst?
                    v10.20.0
                    v10.20.0
                    6.14.4
                    root@iobroker-vm:~#
                    Jan1
                    @david83
                    Das sieht doch ganz gut aus, wobei auch gleich die Node 12 hättest nehmen können.
                    Kommst auf den IOBroker nun drauf?
                    • ? Offline
                      Also ich habe Node,npm und iobroker nochmals als root installiert. Jetzt läuft es ohne Probleme! Danke an alle Mitwirkenden . Danke Danke Dankr
                      wendy2702W J 2 Antworten Letzte Antwort
                        Installed npm
                        Installed acl
                        Installed gcc-c++
                        Installed git
                        Installed unzip
                        npm ERR! errno 4
                        npm ERR!
                        Autostart enabled!
                        root@iobroker-vm:~#
                        wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        Kann nicht sein.
                        Sonst wäre das nicht passiert:
                        Weil das in der Anleitung steht:
                        Als letzte Überprüfung bitte noch die Version von npm mittels npm -v überprüfen.
                        Ergibt dies eine Version < 6, bitte noch mit sudo -H npm install -g npm@6 ein npm-Update durchführen
                        ? 1 Antwort Letzte Antwort
                          wendy2702W Online
                          wendy2702W Online
                          wendy2702
                            Jan1
                            @david83
                            Dann passt ja alles und für die Zukunft, oben einfach auf Docu klicken und nach dem was dort steht vorgehen, alles andere ist nix offizielles .
                            • wendy2702W wendy2702
                              Kann nicht sein.
                              @wendy2702
                              Keine Ahnung wie das passieren konnte...
                                Installed npm
                                Installed acl
                                Installed gcc-c++
                                Installed git
                                Installed unzip
                                npm ERR! errno 4
                                npm ERR!
                                Autostart enabled!
                                root@iobroker-vm:~#
                                das ist nur die Ultrakurzfassung.
                                die korrekte Doku ist hier:
                                https://www.iobroker.net/#de/documentation/install/linux.md
