  4. Installation klappt nicht
gyp error
15 Beiträge 5 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • ? Offline
    root@iobroker-vm:~# node -v
    v13.12.0
    root@iobroker-vm:~# npm -v
    6.14.4
    So habe ich installiert:
    Installation guide
    This page contains a short description on how to install ioBroker. See below for more detailed and localized version of the installation steps.
    Linux based systems and MacOS
    Preparation
        Install nodejs: New installations of ioBroker need at least nodejs 8.12. ioBroker basically also supports the other LTS versions (even version number!!) of nodejs. See https://github.com/nodesource/distributions#debinstall for detailed instructions
        Verify nodejs installation: the commands node -v and nodejs -v should output the same version number
        verify npm installation: the command npm -v should return a version number > 6.4.1. If not use sudo npm install -g npm@6 to update
        Install needed build tools: Make sure to also install additional libraries: sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev
    Installing ioBroker
    Please open a SSH shell. You do not need to use a root shell to install ioBroker. If a normal unprivilidged user exists you should start the installation with this user.
    Then execute
    curl -sL https://iobroker.net/install.sh | bash -
    This will install ioBroker in 4 steps and show its progress:
        Creating ioBroker directory (1/4)
        Downloading installation files (2/4)
        Installing ioBroker (3/4)
        Finalizing installation (4/4)
    At the end you should see
    ioBroker was installed successfully Open http://localhost:8081 in a browser and start configuring!
      v13.12.0
      6.14.4
      Installation guide
      Preparation
      Installing ioBroker
      Then execute
      Jan1
      @david83
      Node 13 ist eine ungerade und somit ne Entwickler Version. Ich denke das steht auch so recht deutlich in der offiziellen IOBroker Doku.
      Gerade geschaut, steht sogar in rot drin, somit hast schon nicht die richtige Doku zur Installation.
      • ? Offline
        OK, jetzt habe ich die VM neu aufgesetzt und die offizielle Installationsanleitung von iobroker.net genommen:
        Images werden nur benötigt, wenn Probleme mit Installationsskripten auftreten.
        Die Installation kann einfach mit 1 bis 3 Zeilen Code erfolgen.
        1. Erst Node.js installieren (wenn noch nicht vorhanden):
        curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
        sudo apt-get install -y nodejs
        2. Anschließend ioBroker installieren:
        Nun bekomme ich folgende Warnungen und Fehler:
            Welcome to the ioBroker installer!
            Installer version: 2020-01-25
            Installing prerequisites (1/4)
        OK:1 http://security.debian.org/debian-security buster/updates InRelease
        OK:2 http://debian.inf.tu-dresden.de/debian buster InRelease
        Holen:3 http://debian.inf.tu-dresden.de/debian buster-updates InRelease [49,3 kB]
        E: Release file for http://debian.inf.tu-dresden.de/debian/dists/buster-updates/InRelease is not valid yet (invalid for another 14 h 8 min 12 s). Updates for this repository will not be applied.
        Installed npm
        npm WARN npm npm does not support Node.js v10.15.2
        npm WARN npm You should probably upgrade to a newer version of node as we
        npm WARN npm can't make any promises that npm will work with this version.
        npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.npm WARN npm You can find the latest version at https://nodejs.org/
        Changing npm registry to https://registry.npmjs.org
        Installed acl
        Installed build-essential
        Installed gcc-c++
        Installed libavahi-compat-libdnssd-dev
        Installed libudev-dev
        Installed libpam0g-dev
        Installed git
        Installed unzip
        Installed python-dev
            Creating ioBroker user and directory (2/4)
        User iobroker created
        Directory /opt/iobroker created
        You are using npm 5.8.0, but ioBroker needs at least using 6.0.0.
        Please use "npm install -g npm" to install a supported version!
        You need to make sure to repeat this step after installing an update to NodeJS and/or npm.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 4
        npm ERR! iobroker@2.0.3 install: `node lib/checkVersions.js`
        npm ERR! Exit status 4
        npm ERR!
        npm ERR! Failed at the iobroker@2.0.3 install script.
        npm ERR!     /root/.npm/_logs/2020-04-09T09_06_45_748Z-debug.log
        Enabling autostart...
        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
        Autostart enabled!
            Open http://192.168.178.45:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        root@iobroker-vm:~#
        J wendy2702W HomoranH 4 Antworten Letzte Antwort
          Installed npm
          Installed acl
          Installed gcc-c++
          Installed git
          Installed unzip
          npm ERR! errno 4
          npm ERR!
          Autostart enabled!
          root@iobroker-vm:~#
          Jan1
          @david83
          IOBroker scheint ja nun drauf zu sein, bleibt noch die Frage was bringt den nun
          node -v
          nodejs -v
          npm -v
          • ? Offline
            v10.20.0
            root@iobroker-vm:~# nodejs -v
            v10.20.0
            6.14.4
            root@iobroker-vm:~#
              Installed npm
              Installed acl
              Installed gcc-c++
              Installed git
              Installed unzip
              npm ERR! errno 4
              npm ERR!
              Autostart enabled!
              root@iobroker-vm:~#
              wendy2702W Online
              wendy2702W Online
              @david83 sagte in Installation klappt nicht:
              Und was passiert wenn du das in den Browser einfügst?
                v10.20.0
                v10.20.0
                6.14.4
                root@iobroker-vm:~#
                Jan1
                @david83
                Das sieht doch ganz gut aus, wobei auch gleich die Node 12 hättest nehmen können.
                Kommst auf den IOBroker nun drauf?
                • ? Offline
                  Also ich habe Node,npm und iobroker nochmals als root installiert. Jetzt läuft es ohne Probleme! Danke an alle Mitwirkenden . Danke Danke Dankr
                  wendy2702W J 2 Antworten Letzte Antwort
                    Installed npm
                    Installed acl
                    Installed gcc-c++
                    Installed git
                    Installed unzip
                    npm ERR! errno 4
                    npm ERR!
                    Autostart enabled!
                    root@iobroker-vm:~#
                    wendy2702W Online
                    wendy2702W Online
                    Kann nicht sein.
                    Sonst wäre das nicht passiert:
                    Weil das in der Anleitung steht:
                    Als letzte Überprüfung bitte noch die Version von npm mittels npm -v überprüfen.
                    Ergibt dies eine Version < 6, bitte noch mit sudo -H npm install -g npm@6 ein npm-Update durchführen
                      wendy2702W Online
                      wendy2702W Online
                        Jan1
                        @david83
                        Dann passt ja alles und für die Zukunft, oben einfach auf Docu klicken und nach dem was dort steht vorgehen, alles andere ist nix offizielles .
                        • wendy2702W wendy2702
                          Kann nicht sein.
                          @wendy2702
                          Keine Ahnung wie das passieren konnte...
                            Installed npm
                            Installed acl
                            Installed gcc-c++
                            Installed git
                            Installed unzip
                            npm ERR! errno 4
                            npm ERR!
                            Autostart enabled!
                            root@iobroker-vm:~#
                            das ist nur die Ultrakurzfassung.
                            die korrekte Doku ist hier:
                            https://www.iobroker.net/#de/documentation/install/linux.md
