  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 109 Kommentatoren 447.0k Aufrufe 102 Beobachtet
  • C Offline
    ChrisChros
    #941
    Hier mal ein Log-Auszug als die Error Message 429 aufgetreten ist, eventuell hilft das weiter:
    2022-07-21 03:22:47.978 - info: smartgarden.0 (3366) 2/ on_close: ### closed ### close.code=1006 close.reason=
    2022-07-21 03:22:47.980 - info: smartgarden.0 (3366) 2/ on_close: trying to reconnect
    2022-07-21 03:22:47.980 - info: smartgarden.0 (3366) 2/ reconnect!
    2022-07-21 03:22:47.981 - info: smartgarden.0 (3366) 2/ getConnection...
    2022-07-21 03:22:47.981 - info: smartgarden.0 (3366) 2/ connectToGardena...
    2022-07-21 03:22:47.982 - info: smartgarden.0 (3366) 2/ connecting to Gardena Smart System Service ...
    2022-07-21 03:22:47.983 - info: smartgarden.0 (3366) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    2022-07-21 03:22:47.983 - info: smartgarden.0 (3366) 2/ connect ... empty username
    2022-07-21 03:22:47.984 - info: smartgarden.0 (3366) 2/ connect ... empty password
    2022-07-21 03:22:47.988 - info: smartgarden.0 (3366) 2/ connect ... using client credentials grant
    2022-07-21 03:22:48.296 - info: smartgarden.0 (3366) 2/ Connection: successful: response.statusCode / statusMessage=200 / OK
    2022-07-21 03:22:48.297 - info: smartgarden.0 (3366) 2/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
    2022-07-21 03:22:48.297 - info: smartgarden.0 (3366) 2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    2022-07-21 03:22:48.298 - info: smartgarden.0 (3366) 2/ get_locations ...
    2022-07-21 03:22:48.539 - info: smartgarden.0 (3366) 2/ get_locations failure: response.statusCode/Message=429/
    2022-07-21 03:22:48.540 - info: smartgarden.0 (3366) 2/ get_locations failure:..return with error
    2022-07-21 03:22:48.540 - error: smartgarden.0 (3366) Error: request returned 429
    2022-07-21 03:22:48.541 - info: smartgarden.0 (3366) 2/ getConnection: returned connection error: request returned 429
    2022-07-21 03:22:48.541 - info: smartgarden.0 (3366) 2/ getConnection: trying to connect again in 300 seconds
    • JohGreJ Offline
      JohGreJ Offline
      JohGre
      #942
      @jpgorganizer Habe heute festgestellt, dass eine Bedienung über den Adapter mit Fehler 429 resultiert, aber die Bedienung mit der App problemlos funktioniert.
      Gibts schon Info von Gardena?
      nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
      • FenriswolfF Fenriswolf
        Moin,
        ich hänge mich da einfach mal mit ran, da auch bei mir der Fehler 429 auftritt. Meistens im Zusammenhang mit der Bewässerung über den "gartenbewaesserung"-Adapter.
        Es werden dann einfach die Ventile nicht geöffnet. Ist ärgerlich, wenn man um 04:30 Uhr bewässern will und dann morgens feststellt, das die Zisterne immer noch genauso voll ist wie am Abend vorher. Im Logfile tauchen dann immer die 429 auf, wenn der Bewässerungsadapter eines der Ventile einschalten will.
        Hoffen wir mal auf eine schnelle Antwort von Gardena.
        bis denne
        Marc
        SaschaS
        #943
        @fenriswolf Auch bei mir tritt Fehler 429 auf. Ich betreibe den Adapter zusammen mit dem Adapter sprinklecontrol. Fun-Fact: Die Bewässerung hat um 3:00 Uhr gestartet. Allerdings wurde das Stopp-Signal nach 36 Minuten mit Fehler 429 quittiert. So hat der Rasen heute (bis zur maximalen Zeit 60min) etwas mehr Wasser abbekommen.
        • S SaschaS
          mameier1234
          #944
          Hier auch Fehler 429.. Ich habe mir eingebildet, dass der Fehler erst mit dem Upgrade auf die 2.0 gekommen ist.. Deshalb hatte ich ein Downgrade auf die letzte 1.xx Version gemacht.. Erstmal hat es wieder funktioniert, dann kam aber der 429er wieder..
          Nun habe ich wieder auf die 2.0 aktualisiert.. gleiches Thema : 429.. Dann habe ich die Auth auf Key und Secret , anstatt Benutzername und PW umgestellt.. gleiches Thema...
          Dann habe ich im DevPortal von Husquarna eine neue Application erstellt.. gleiches Thema..
          Jetzt heist es wohl leider warten..
          Der Garten benötigt in der Zwischenzeit aber leider Wasser.. ich habe die Irrigation Control... und 3x Watercontrol, die ich vor die Bewässerungskreise geschaltet habe, da leider nicht alles ganz dicht ist... Ich wundere mich echt, warum das nicht in der App geht.. Dass ich dort einstellen kann, z.B. wenn Ventil 1 der Irrigation Control auf ist, auch die zugehörige Watercontrol öffnen... (und schließen) .. das habe ich jetzt alles im IOBroker abgebildet und nun ist so ein Mist...
          Wieder mal ein Punkt, wo Cloudzwang echt sch.. Blöd ist.....
          Grüße,
          Martin
          • J Offline
            jupzup
            schrieb am zuletzt editiert von jupzup
            #945
            Habe seit eben auch Fehler 429. Über den Tag hinweg hat noch alles funktioniert ich steuere ebenfalls ein Bewässerungsventil.
            APP Secret habe ich eben auch mal erneuert hat aber leider nichts gebracht.
            Auf der Gardena Web Seite gibt es ja ein Test Script für zb. eine Terminal Session basierend auf den persönlichen APP Key und App Server und dies funktioniert ohne Fehler ich bekomme einen gültigen Token in der Terminal Session zurück.
            Sehr merkwürdig.....
            curl -X POST -d "grant_type=client_credentials&client_id=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX&client_secret=XXXXXXXXXXXXXXXXXXXXXX"
             https://api.authentication.husqvarnagroup.dev/v1/oauth2/token
            • jpgorganizerJ jpgorganizer
              @netfriend
              ich habe heute bei mir im Log auch error 429 gefunden - habe Gardena mal angefragt, ob sie sich das erklären können. Mal sehen ob ich eine Antwort erhalte.
              @all: bitte mal beobachten ob ihr auch unmotivierte error 429 erhaltet
              dougstar
              #946
              @jpgorganizer Ja, ich habe in den letzten Tagen auf viele 429 Fehler.
              • D dougstar
                Denis103
                #947
                @dougstar Das ist bei mir leider auch so. Mein Log ist voller 429er... Dazwischen geht es mal und dann wieder nicht -> 429er...
                Bis vor 1-2 Wochen hatte ich keine Probleme. Ob das mit dem Wechsel auf den 2.0er Adapter bzw. mit dem Wechsel des Authentisierungsverfahren zuusammenhängt kann ich nicht genau sagen, da meine Bewässerung gewöhnlich Nachts läuft und ich das Problem jetzt erst bewusst bemerkt habe, als mein Rasen trotz vermeintlicher Bewässerung anfing gelb zu werden.
                  @All
                  Zum Error 429: aus meiner Sicht hat hier Gardena ein Todo. Seitens Adapter kann man das nicht lösen. Man kann sich zwar Dinge vorstellen, die man machen könnte, aber es bleibt dann immer noch Flickwerk mit Lücken. Gardena sollte das Problem kennen und meine Erwartung ist, dass Gardena das löst.
                  Denis103
                  #948
                  @jpgorganizer said in [neuer Adapter] smartgarden adapter for Gardena smart system:
                  @All
                  Danke für deine Analyse. Hast du das Problem bei Gardena aktiv gemeldet? Gibt es da ein Ticket zu? Oder hoffen wir alle, dass Gardena dies in den Logs auf ihren Server selber bemerkt?
                  • J Offline
                    jupzup
                    #949
                    Hallo, also ich glaube mittlerweile dass es evtl. doch an dem Adapter liegt.
                    Wenn ich über den Adapter Error 429 bekomme zb. wenn ich einen Befehl absetze und dann sofort über meinen Mac im Terminal einen Token hole, welcher übrigens immer ohne Fehler kommt, dann funktioniert auch der Adapter sofort wieder für eine gewisse Zeit.
                    Hiermit hole ich den Token:
                    % curl --location --request POST 'https://api.authentication.husqvarnagroup.dev/v1/oauth2/token' \
                    --header 'Content-Type: application/x-www-form-urlencoded' \
                    --data-urlencode 'client_id=xxxxxxxxxxxxxxxxxxxxxxxxx' \
                    --data-urlencode 'client_secret=xxxxxxxxxxxxxxxxxxxxxxxx' \
                    --data-urlencode 'grant_type=client_credentials'
                    @jpgorganizer
                    Kannst du das evtl. nachvollziehen ?
                    VG
                      @All
                      jpgorganizerJ Online
                      jpgorganizer
                      #950
                      @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                      @All
                      ich will mich ja nicht zu früh freuen, aber der letzte Error 429 war bei mir heute (29.07.22) um 13:19 Uhr. Sieht aus, als ob Gardena den Bug gefixed hat. Ich hoffe mal, das bleibt stabil.
                      Wie sieht's bei euch aus?
                      VG jpgorganizer
                      smartgarden Adapter für GARDENA smart system
                      J C 2 Antworten Letzte Antwort
                        @All
                        VG jpgorganizer
                        jupzup
                        #951
                        @jpgorganizer
                        Kann ich bestätigen bei mir sieht es seit heute ähnlich gut aus.
                          @All
                          VG jpgorganizer
                          ChrisChros
                          #952
                          @jpgorganizer der letzte Error 429 war bei mir am 29.07. um 14:52. Seit dem ist es ruhig geworden.
                            Denis103
                            #953
                            @jpgorganizer Ich habe den Error 429 nun auch nicht mehr im Log 👍
                            N 1 Antwort Letzte Antwort
                            • D Denis103
                              N Offline
                              N Offline
                              netfriend
                              #954
                              Ich hatte mich vor ein paar Tagen an den Gardena Support gewandt, vielleicht hat es ja geholfen?
                              Auch bei mir war die letzte Unterbrechung am 29.07. gegen 15h. Hoffen wir mal 👍
                              jpgorganizerJ 1 Antwort Letzte Antwort
                              • N netfriend
                                jpgorganizer
                                #955
                                @netfriend sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                da wirst du nicht der Einzige gewesen sein. :-)
                                Hast du von dort eine Antwort erhalten?
                                  N Offline
                                  N Offline
                                  netfriend
                                  #956
                                  @jpgorganizer Ja, ich habe eine freundliche Antwort erhalten. Ist ja gut, wenn sich mehrere Leute dort melden. Dann erweckt es nicht Eindruck, das Problem liegt beim Einzelnen sondern doch eher auf Seiten des Herstellers.
                                    SaschaS
                                    #957
                                    Seit gestern 15:17 Uhr auch kein Error 429 im Log mehr. Auf ein entspanntes Bewässern. 👍
                                    • S SaschaS
                                      mameier1234
                                      #958
                                      Bei mir ist der Error 429 jetzt eigentlich auch wieder weg..
                                      Dafür bekomme ich immer mal wieder einen errer 400
                                      smartgarden.0
                                      2022-08-03 11:01:29.579 error Error: request returned 400 Bad Request
                                      Wenn ich dann die Instanz neu starte, ist alles wieder ok...
                                      Grüße,
                                      Martin
                                      • M mameier1234
                                        smartgarden.0
                                        jpgorganizer
                                        #959
                                        @mameier1234 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                        das ist ein allgemeiner Fehler den Gardena ausgibt. Der Adapter kann da nichts machen. Versuch mal den Befehl neu zu senden statt den Adapter zu stoppen und wieder zu starten.
                                          mameier1234
                                          #960
                                          @jpgorganizer wie könnte ich denn abfangen, dass der Befehl nicht kam ? damit ich nur bei Bedarf neu sende ?
                                          Grüße,
                                          Martin
