  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 649.9k Aufrufe 118 Beobachtet
  • KevinK Kevin
    @Thomas-Braun
    Also ich hab es nun gefixed bekommen.
    Node12 installieren
    IoBroker fix
    npm rebuild im IoBroker Verzeichnis
    npm rebuild --build-from-source canvas
    Iobroker fix
    Seitdem funktioniert es auch mit node 12
    X Offline
    X Offline
    xADDRx
    #1041
    @Kevin verändert es irgendwas am System?
    Nicht das dann gar nichts mehr geht.
    Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
    KevinK 1 Antwort Letzte Antwort
    • X xADDRx
      KevinK Offline
      KevinK Offline
      Kevin
      #1042
      @xADDRx kann nur von meiner Erfahrung sprechen. Bei mir lief dannach immer noch alles wie davor.
      • KevinK Kevin
        @Thomas-Braun
        Node12 installieren
        IoBroker fix
        Iobroker fix
        X Offline
        X Offline
        xADDRx
        #1043
        @Kevin IObroker fix ging durch..
        beim npm Fehler:
        root@debian:/opt/iobroker# npm rebuild
        > iobroker@1.0.6 install /opt/iobroker/node_modules/iobroker
        > node lib/setup.js
        NPM version: 6.13.4
        NPM 5 is currently NOT supported!
        Please use "npm install -g npm@4" to downgrade npm to 4.x and try again.
        You need to make sure to downgrade again with the above command after you
        installed an update to nodejs/npm!
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! iobroker@1.0.6 install: `node lib/setup.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the iobroker@1.0.6 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_32_00_912Z-debug.log
        root@debian:/opt/iobroker# npm rebuild --build-from-source canvas
        > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        Package pixman-1 was not found in the pkg-config search path.
        Perhaps you should add the directory containing `pixman-1.pc'
        to the PKG_CONFIG_PATH environment variable
        No package 'pixman-1' found
        gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        gyp ERR! configure error
        gyp ERR! stack Error: `gyp` failed with exit code: 1
        gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
        gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
        gyp ERR! System Linux 4.9.0-4-amd64
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v12.16.3
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
        node-pre-gyp ERR! System Linux 4.9.0-4-amd64
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v12.16.3
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
        node-pre-gyp ERR! not ok
        npm ERR! errno 1
        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR!
        npm ERR! Failed at the canvas@2.6.1 install script.
        npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_32_42_894Z-debug.log
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_36_07_361Z-debug.log
        KevinK Thomas BraunT 2 Antworten Letzte Antwort
        • X xADDRx
          beim npm Fehler:
          > node lib/setup.js
          NPM version: 6.13.4
          npm ERR! errno 1
          npm ERR!
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          KevinK Offline
          KevinK Offline
          Kevin
          #1044
          @xADDRx
          ist deine npm version aktuell?
          X 1 Antwort Letzte Antwort
          • KevinK Kevin
            @xADDRx
            X Offline
            X Offline
            xADDRx
            #1045
            @Kevin Wenn ich das richtig sehe habe ich Version : NPM version: 6.13.4 drauf...
            • X xADDRx
              beim npm Fehler:
              > node lib/setup.js
              NPM version: 6.13.4
              npm ERR! errno 1
              npm ERR!
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              #1046
              @xADDRx Docker auf einer Synology? Ansonsten: Meld dich nicht als root an!
              Da scheint mir die Installation von node mal wieder in die Hose gegangen zu sein.
              Schau hier rein:
                Schau hier rein:
                X Offline
                X Offline
                xADDRx
                #1047
                @Thomas-Braun Keine Synology! Node habe ich nach der Anleitung damals ohne Fehler installiert gehabt.
                • X xADDRx
                  #1048
                  @xADDRx
                  Dann ist da wohl alles mögliche verfummelt. Deine Version vom js-controller ist auch uralt. Jedenfalls lt. Log.
                  root-Login ist jedenfalls absoluter Quark. Kannste Mal den @Freaknet fragen. Nur ein paar Postings zuvor.
                  Wenn du Hilfe beim glattziehen möchtest mach am besten einen neuen, eigenen Thread dafür auf. Hier führt das zu weit.
                    @xADDRx
                    X Offline
                    X Offline
                    xADDRx
                    schrieb am zuletzt editiert von xADDRx
                    #1049
                    @Thomas-Braun Hmmm. Also JS Controller ist aug 3.1.6. Auch habe ich sonst keine Porbleme. Sowohl die Karte als auch die Räume haben ja vorm Adapter Update funktionert und wurden geladen sobald man auf dem Button geklickt hat...
                    Thomas BraunT X 2 Antworten Letzte Antwort
                    • X xADDRx
                      #1050
                      @xADDRx Das Install-Log zeigt was anderes an.
                        X Offline
                        X Offline
                        xADDRx
                        #1051
                        @Thomas-Braun Was sollte ich am besten tun??
                        • X xADDRx
                          KevinK Offline
                          KevinK Offline
                          Kevin
                          schrieb am zuletzt editiert von Kevin
                          #1052
                          @xADDRx
                          Versuch mal das:
                          iobroker stop
                          sudo apt-get update
                          sudo apt-get upgrade
                          sudo apt-get --purge remove nodejs -y
                          sudo apt-get autoremove -y
                          sudo reboot
                          curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                          sudo sh -c "echo deb https://deb.nodesource.com/node_12.x disco main \> /etc/apt/sources.list.d/nodesource.list"
                          sudo apt-get update
                          sudo apt-get install nodejs -y
                          npm install -g npm@6
                          sudo reboot
                          iobroker update
                          iobroker upgrade self
                          iobroker fix
                          cd /opt/iobroker/
                          npm rebuild
                          • KevinK Kevin
                            @xADDRx
                            Versuch mal das:
                            iobroker stop
                            sudo apt-get update
                            sudo reboot
                            sudo apt-get update
                            sudo reboot
                            iobroker update
                            iobroker fix
                            cd /opt/iobroker/
                            npm rebuild
                            #1053
                            @Kevin Woher weißt du dass da Disco läuft?
                            So wird das mutmaßliche Installationschaos doch nur noch größer...
                            Da dürfte eher ein Debian laufen, kein Ubuntu.
                              KevinK Offline
                              KevinK Offline
                              Kevin
                              #1054
                              @Thomas-Braun so habe ich es bei mir zum laufen gebracht. Auf raspbian
                              • KevinK Kevin
                                #1055
                                @Kevin Dann hast du jetzt ein falsches Repo drin. Disco Dingo ist nicht für Raspian gedacht.
                                Vermutlich bist Du auch auf einem hervorragenden Weg dein System zu zerballern.
                                • X xADDRx
                                  #1056
                                  @xADDRx Mach einen neuen Thread auf und poste da die Ausgabe von
                                  lsb_release -a
                                  sowie von
                                  which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                  Komplette Eingaben und auch Ausgaben posten, nichts kürzen oder abändern...
                                  Das gleiche würde ich @Kevin auch empfehlen...
                                  • K K_o_bold
                                    @Sweatchuck ,
                                    falls du den Container von Buanet nutzt, dann nimm die neue Version 5 davon. Das ist eine saubere Installation mit node 12 und der aktuellste js-controller..
                                    Ich empfehle ich dir folgende Vorgehensweise:
                                    1. Backup von Iobroker mit z.B. backitup.
                                    2. neues leeres Volume anlegen.
                                    3. Container Image V 5 stable laden und starten
                                    4. In den container wechseln und das backup einspielen.
                                    Dann sollte alles laufen
                                    Sweatchuck
                                    #1057
                                    @K_o_bold
                                    Habe die Version 5 drauf und bisher ausschließlich den Container von Buanet genutz. Funktioniert trotzdem nicht.
                                    Entsprechend der Anleitung von Buanet habe ich über portainer den ioBroker Container über Recreate neu erstellt und das neueste Image eingespielt. (siehe Bild)
                                      lsb_release -a
                                      sowie von
                                      X Offline
                                      X Offline
                                      xADDRx
                                      #1058
                                      @Thomas-Braun https://forum.iobroker.net/topic/35767/node-fehlerbehebung
                                      • haselchenH haselchen
                                        @blackeagle998
                                        MIHOME App öffnen , dann geht es
                                        EckartS
                                        #1059
                                        ich habe das gleiche Problem. Ich habe zwei Roborock der ersten Generation, und der Adapter lief immer korrekt. Seit Update auf 2.x aber bleibt die Instanze des ersten Saugers auf "gelb" stehen, nur die des zweiten Saugers bekommt eine Verbindung.
                                        Log des ersten Saugers:
                                        {der Hinweis auf die 10 Minuten wiederholt sich dann endlos}
                                        mihome-vacuum.0	2020-08-10 17:10:56.044	info	(11238) connecting, this can take up to 10 minutes ...
                                        mihome-vacuum.0	2020-08-10 17:10:36.040	info	(11238) connecting, this can take up to 10 minutes ...
                                        mihome-vacuum.0	2020-08-10 17:10:16.571	info	(11238) set nächster Timer: Nicht verfügbar
                                        mihome-vacuum.0	2020-08-10 17:10:16.080	info	(11238) connecting, this can take up to 10 minutes ...
                                        mihome-vacuum.0	2020-08-10 17:10:16.063	info	(11238) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
                                        mihome-vacuum.0	2020-08-10 17:10:16.017	info	(11238) Create state clean_home for controlling by cloud adapter
                                        mihome-vacuum.0	2020-08-10 17:10:16.014	info	(11238) Expert mode disabled, states deleted
                                        mihome-vacuum.0	2020-08-10 17:10:15.972	info	(11238) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.20.1, js-controller: 3.1.4
                                        host.iobroker	2020-08-10 17:10:10.405	info	instance system.adapter.mihome-vacuum.0 started with pid 11238
                                        Konfiguration:
                                        Adapter Mihome-vaccuum 2.1.1
                                        Erster Sauger (der ohne Verbindung):: Port des Robot: 54321; eigener Port: 54321
                                        Zweiter Sauger (der mit Verbindung): Port des Robot: 54321; eigener Port: 54322
                                        Aktuelle Firmware auf beiden Saugern: 3.5.8_004018
                                        Der Tipp, die Mihome-App bei der Anmeldung geöffnet zu halten, hat nicht genutzt.
                                        Weiß da jemand Abhilfe?
                                        Grüße, EckartS
                                        • E EckartS
                                          Konfiguration:
                                          Grüße, EckartS
                                          dirkhe
                                          #1060
                                          @EckartS mach bitte ein debug Log, da kann man mehr sehen
