  4. Test Adapter mihome-vacuum v2.0.x
    1.0k
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 665.6k Aufrufe 118 Beobachtet
  • KevinK Kevin
    @xADDRx
    ist deine npm version aktuell?
    X Offline
    X Offline
    xADDRx
    #1045
    @Kevin Wenn ich das richtig sehe habe ich Version : NPM version: 6.13.4 drauf...
    Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
    • X xADDRx
      @Kevin IObroker fix ging durch..
      beim npm Fehler:
      root@debian:/opt/iobroker# npm rebuild
      > iobroker@1.0.6 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      NPM version: 6.13.4
      NPM 5 is currently NOT supported!
      Please use "npm install -g npm@4" to downgrade npm to 4.x and try again.
      You need to make sure to downgrade again with the above command after you
      installed an update to nodejs/npm!
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker@1.0.6 install: `node lib/setup.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker@1.0.6 install script.
      npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_32_00_912Z-debug.log
      root@debian:/opt/iobroker# npm rebuild --build-from-source canvas
      > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp WARN Using request for node-pre-gyp https download
      Package pixman-1 was not found in the pkg-config search path.
      Perhaps you should add the directory containing `pixman-1.pc'
      to the PKG_CONFIG_PATH environment variable
      No package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 4.9.0-4-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v12.16.3
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
      node-pre-gyp ERR! System Linux 4.9.0-4-amd64
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v12.16.3
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      npm ERR! errno 1
      npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
      npm ERR!
      npm ERR! Failed at the canvas@2.6.1 install script.
      npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_32_42_894Z-debug.log
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR!     /home/iobroker/.npm/_logs/2020-08-07T09_36_07_361Z-debug.log
      #1046
      @xADDRx Docker auf einer Synology? Ansonsten: Meld dich nicht als root an!
      Da scheint mir die Installation von node mal wieder in die Hose gegangen zu sein.
      Schau hier rein:
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      X 1 Antwort Letzte Antwort
        Schau hier rein:
        X Offline
        X Offline
        xADDRx
        #1047
        @Thomas-Braun Keine Synology! Node habe ich nach der Anleitung damals ohne Fehler installiert gehabt.
        • X xADDRx
          #1048
          @xADDRx
          Dann ist da wohl alles mögliche verfummelt. Deine Version vom js-controller ist auch uralt. Jedenfalls lt. Log.
          root-Login ist jedenfalls absoluter Quark. Kannste Mal den @Freaknet fragen. Nur ein paar Postings zuvor.
          Wenn du Hilfe beim glattziehen möchtest mach am besten einen neuen, eigenen Thread dafür auf. Hier führt das zu weit.
            @xADDRx
            X Offline
            X Offline
            xADDRx
            schrieb am zuletzt editiert von xADDRx
            #1049
            @Thomas-Braun Hmmm. Also JS Controller ist aug 3.1.6. Auch habe ich sonst keine Porbleme. Sowohl die Karte als auch die Räume haben ja vorm Adapter Update funktionert und wurden geladen sobald man auf dem Button geklickt hat...
            Thomas BraunT X 2 Antworten Letzte Antwort
            • X xADDRx
              #1050
              @xADDRx Das Install-Log zeigt was anderes an.
                X Offline
                X Offline
                xADDRx
                #1051
                @Thomas-Braun Was sollte ich am besten tun??
                KevinK Thomas BraunT 2 Antworten Letzte Antwort
                • X xADDRx
                  KevinK Offline
                  KevinK Offline
                  Kevin
                  schrieb am zuletzt editiert von Kevin
                  #1052
                  @xADDRx
                  Versuch mal das:
                  iobroker stop
                  sudo apt-get update
                  sudo apt-get upgrade
                  sudo apt-get --purge remove nodejs -y
                  sudo apt-get autoremove -y
                  sudo reboot
                  curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                  sudo sh -c "echo deb https://deb.nodesource.com/node_12.x disco main \> /etc/apt/sources.list.d/nodesource.list"
                  sudo apt-get update
                  sudo apt-get install nodejs -y
                  npm install -g npm@6
                  sudo reboot
                  iobroker update
                  iobroker upgrade self
                  iobroker fix
                  cd /opt/iobroker/
                  npm rebuild
                  • KevinK Kevin
                    @xADDRx
                    Versuch mal das:
                    iobroker stop
                    sudo apt-get update
                    sudo reboot
                    sudo apt-get update
                    sudo reboot
                    iobroker update
                    iobroker fix
                    cd /opt/iobroker/
                    npm rebuild
                    #1053
                    @Kevin Woher weißt du dass da Disco läuft?
                    So wird das mutmaßliche Installationschaos doch nur noch größer...
                    Da dürfte eher ein Debian laufen, kein Ubuntu.
                    KevinK 1 Antwort Letzte Antwort
                      KevinK Offline
                      KevinK Offline
                      Kevin
                      #1054
                      @Thomas-Braun so habe ich es bei mir zum laufen gebracht. Auf raspbian
                      • KevinK Kevin
                        #1055
                        @Kevin Dann hast du jetzt ein falsches Repo drin. Disco Dingo ist nicht für Raspian gedacht.
                        Vermutlich bist Du auch auf einem hervorragenden Weg dein System zu zerballern.
                        • X xADDRx
                          #1056
                          @xADDRx Mach einen neuen Thread auf und poste da die Ausgabe von
                          lsb_release -a
                          sowie von
                          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                          Komplette Eingaben und auch Ausgaben posten, nichts kürzen oder abändern...
                          Das gleiche würde ich @Kevin auch empfehlen...
                          • K K_o_bold
                            @Sweatchuck ,
                            falls du den Container von Buanet nutzt, dann nimm die neue Version 5 davon. Das ist eine saubere Installation mit node 12 und der aktuellste js-controller..
                            Ich empfehle ich dir folgende Vorgehensweise:
                            1. Backup von Iobroker mit z.B. backitup.
                            2. neues leeres Volume anlegen.
                            3. Container Image V 5 stable laden und starten
                            4. In den container wechseln und das backup einspielen.
                            Dann sollte alles laufen
                            Sweatchuck
                            #1057
                            @K_o_bold
                            Habe die Version 5 drauf und bisher ausschließlich den Container von Buanet genutz. Funktioniert trotzdem nicht.
                            Entsprechend der Anleitung von Buanet habe ich über portainer den ioBroker Container über Recreate neu erstellt und das neueste Image eingespielt. (siehe Bild)
                              lsb_release -a
                              sowie von
                              X Offline
                              X Offline
                              xADDRx
                              #1058
                              @Thomas-Braun https://forum.iobroker.net/topic/35767/node-fehlerbehebung
                              • haselchenH haselchen
                                @blackeagle998
                                MIHOME App öffnen , dann geht es
                                EckartS
                                #1059
                                ich habe das gleiche Problem. Ich habe zwei Roborock der ersten Generation, und der Adapter lief immer korrekt. Seit Update auf 2.x aber bleibt die Instanze des ersten Saugers auf "gelb" stehen, nur die des zweiten Saugers bekommt eine Verbindung.
                                Log des ersten Saugers:
                                {der Hinweis auf die 10 Minuten wiederholt sich dann endlos}
                                mihome-vacuum.0	2020-08-10 17:10:56.044	info	(11238) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-08-10 17:10:36.040	info	(11238) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-08-10 17:10:16.571	info	(11238) set nächster Timer: Nicht verfügbar
                                mihome-vacuum.0	2020-08-10 17:10:16.080	info	(11238) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-08-10 17:10:16.063	info	(11238) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
                                mihome-vacuum.0	2020-08-10 17:10:16.017	info	(11238) Create state clean_home for controlling by cloud adapter
                                mihome-vacuum.0	2020-08-10 17:10:16.014	info	(11238) Expert mode disabled, states deleted
                                mihome-vacuum.0	2020-08-10 17:10:15.972	info	(11238) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.20.1, js-controller: 3.1.4
                                host.iobroker	2020-08-10 17:10:10.405	info	instance system.adapter.mihome-vacuum.0 started with pid 11238
                                Konfiguration:
                                Adapter Mihome-vaccuum 2.1.1
                                Erster Sauger (der ohne Verbindung):: Port des Robot: 54321; eigener Port: 54321
                                Zweiter Sauger (der mit Verbindung): Port des Robot: 54321; eigener Port: 54322
                                Aktuelle Firmware auf beiden Saugern: 3.5.8_004018
                                Der Tipp, die Mihome-App bei der Anmeldung geöffnet zu halten, hat nicht genutzt.
                                Weiß da jemand Abhilfe?
                                Grüße, EckartS
                                • E EckartS
                                  Konfiguration:
                                  Grüße, EckartS
                                  dirkhe
                                  #1060
                                  @EckartS mach bitte ein debug Log, da kann man mehr sehen
                                  • X xADDRx
                                    X Offline
                                    X Offline
                                    xADDRx
                                    #1061
                                    @xADDRx folgendes hat mir geholfen:
                                    sudo iobroker stop
                                    cd /opt/iobroker
                                    sudo apt update
                                    sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                    sudo npm install canvas --unsafe-perm=true
                                    Katrte geht wieder und Räume wurden geladen
                                    S Thomas BraunT 2 Antworten Letzte Antwort
                                    • R Offline
                                      Rushmed
                                      schrieb am zuletzt editiert von Rushmed
                                      #1062
                                      ich habe erfolgreich meinen S6 maxv im ioBroker installiert, für meine beiden Etagen jeweils eine Karte erstellt, Räume abgetrennt, umbenannt und Moduseinstellungen gesetzt.
                                      Wenn ich nun ein "roomClean" Objekt auslose passiert im Log das Folgende:
                                      mihome-vacuum.0	2020-08-13 20:39:22.260	info	(14105) set nächster Timer: Nicht verfügbar
                                      mihome-vacuum.0	2020-08-13 20:39:21.858	info	(14105) connecting, this can take up to 10 minutes ...
                                      mihome-vacuum.0	2020-08-13 20:39:21.801	info	(14105) New generation or new fw(3.5.8,4436) detected, create new states goto and zoneclean
                                      mihome-vacuum.0	2020-08-13 20:39:21.714	info	(14105) Create state clean_home for controlling by cloud adapter
                                      mihome-vacuum.0	2020-08-13 20:39:21.711	info	(14105) Expert mode disabled, states deleted
                                      mihome-vacuum.0	2020-08-13 20:39:21.607	info	(14105) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                                      mihome-vacuum.0	2020-08-13 20:38:49.057	info	(12745) Terminated (NO_ERROR): Without reason
                                      mihome-vacuum.0	2020-08-13 20:38:49.055	info	(12745) terminating
                                      mihome-vacuum.0	2020-08-13 20:38:49.044	error	(12745) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:144:51 at /opt/iobroker/node_modules/iobroker.js-controller/lib/ad
                                      mihome-vacuum.0	2020-08-13 20:38:49.040	error	(12745) uncaught exception: Cannot read property 'val' of null
                                      mihome-vacuum.0	2020-08-13 20:37:33.316	info	(12745) create states for water box filter
                                      mihome-vacuum.0	2020-08-13 20:37:33.313	info	(12745) create states for water box
                                      mihome-vacuum.0	2020-08-13 20:37:14.454	info	(12745) create state for carpet_mode
                                      mihome-vacuum.0	2020-08-13 20:37:13.819	info	(12745) set nächster Timer: Nicht verfügbar
                                      mihome-vacuum.0	2020-08-13 20:37:13.441	info	(12745) Connected
                                      mihome-vacuum.0	2020-08-13 20:37:13.381	info	(12745) connecting, this can take up to 10 minutes ...
                                      mihome-vacuum.0	2020-08-13 20:37:13.369	info	(12745) New generation or new fw(3.5.8,4436) detected, create new states goto and zoneclean
                                      mihome-vacuum.0	2020-08-13 20:37:13.290	info	(12745) Create state clean_home for controlling by cloud adapter
                                      mihome-vacuum.0	2020-08-13 20:37:13.288	info	(12745) Expert mode disabled, states deleted
                                      mihome-vacuum.0	2020-08-13 20:37:13.188	info	(12745) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                                      mihome-vacuum.0	2020-08-13 20:36:40.744	info	(9488) Terminated (NO_ERROR): Without reason
                                      mihome-vacuum.0	2020-08-13 20:36:40.742	info	(9488) terminating
                                      mihome-vacuum.0	2020-08-13 20:36:40.724	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                      mihome-vacuum.0	2020-08-13 20:36:40.724	error	at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                                      mihome-vacuum.0	2020-08-13 20:36:40.724	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                      mihome-vacuum.0	2020-08-13 20:36:40.724	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:673:13
                                      mihome-vacuum.0	2020-08-13 20:36:40.724	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6757:17
                                      mihome-vacuum.0	2020-08-13 20:36:40.724	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:144:51
                                      mihome-vacuum.0	2020-08-13 20:36:40.724	error	(9488) TypeError: Cannot read property 'val' of null
                                      mihome-vacuum.0	2020-08-13 20:36:40.717	error	(9488) uncaught exception: Cannot read property 'val' of null
                                      mihome-vacuum.0	2020-08-13 20:35:27.231	info	(9488) create states for water box filter
                                      mihome-vacuum.0	2020-08-13 20:35:27.230	info	(9488) create states for water box
                                      mihome-vacuum.0	2020-08-13 20:35:18.347	info	(9488) create state for carpet_mode
                                      mihome-vacuum.0	2020-08-13 20:35:17.329	info	(9488) Connected
                                      mihome-vacuum.0	2020-08-13 20:35:07.224	info	(9488) connecting, this can take up to 10 minutes ...
                                      Der Robi mach garnichts und der Adapter startet neu.
                                      Kann mir jemand sagen was das Problem ist?
                                      Habe gerade noch diesen Post entdeckt und es mit "roomFanPower" auf BALANCED60 nochmal probiert.
                                      mihome-vacuum.0	2020-08-13 20:47:57.910	error	(14105) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/roomManager.js:144:51 at /opt/iobroker/node_modules/iobroker.js-controller/lib/ad
                                      mihome-vacuum.0	2020-08-13 20:47:57.903	error	(14105) uncaught exception: Cannot read property 'val' of null
                                      Gleiches Ergebnis.
                                      R 1 Antwort Letzte Antwort
                                      • X xADDRx
                                        sudo iobroker stop
                                        cd /opt/iobroker
                                        sudo apt update
                                        seppel786
                                        schrieb am zuletzt editiert von seppel786
                                        #1063
                                        Hi zusammen,
                                        @Alle Valetudo-Nutzer:
                                        Mit welcher Konstellation/Versionen (JS-Controller, Node, Valetudo, mihome-vacuum Adapter etc. ) funktioniert bei Euch die MAP-Funktion?
                                        Gruß Daniel
                                        • X xADDRx
                                          sudo iobroker stop
                                          cd /opt/iobroker
                                          sudo apt update
                                          #1064
                                          @xADDRx npm nicht mit sudo zusammen verwenden.
