  4. js-controller 2.2 jetzt für Alle im Stable
js-controller
142 Beiträge 28 Kommentatoren 30.2k Aufrufe 27 Beobachtet
  • apollon77A apollon77
    @saeft_2003 tr-064 sind wir inzwischen bei 3.x ... update mal
    saeft_2003
    #101
    @apollon77
    hab ich gerade über github auf 3.2.0. Jetzt hab ich den Fehler...
    host.iobroker	2020-02-09 22:20:36.175	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.iobroker	2020-02-09 22:20:36.175	info	instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
    host.iobroker	2020-02-09 22:20:36.174	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
    host.iobroker	2020-02-09 22:20:36.174	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    host.iobroker	2020-02-09 22:20:36.174	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.iobroker	2020-02-09 22:20:36.173	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
    host.iobroker	2020-02-09 22:20:36.173	error	Caught by controller[0]: at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2491:65)
    host.iobroker	2020-02-09 22:20:36.173	error	Caught by controller[0]: at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
    host.iobroker	2020-02-09 22:20:36.172	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
    host.iobroker	2020-02-09 22:20:36.172	error	Caught by controller[0]: ReferenceError: secret is not defined
    tr-064.0	2020-02-09 22:20:35.626	info	(11818) Terminated (NO_ERROR): Without reason
    tr-064.0	2020-02-09 22:20:35.624	info	(11818) terminating
    tr-064.0	2020-02-09 22:20:35.564	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    tr-064.0	2020-02-09 22:20:35.564	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    tr-064.0	2020-02-09 22:20:35.564	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    tr-064.0	2020-02-09 22:20:35.564	error	at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
    tr-064.0	2020-02-09 22:20:35.564	error	at objects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2491:65)
    tr-064.0	2020-02-09 22:20:35.564	error	at adapter.getForeignObject (/opt/iobroker/node_modules/iobroker.tr-064/main.js:115:13)
    tr-064.0	2020-02-09 22:20:35.564	error	at main (/opt/iobroker/node_modules/iobroker.tr-064/main.js:1119:49)
    tr-064.0	2020-02-09 22:20:35.564	error	(11818) ReferenceError: secret is not defined
    tr-064.0	2020-02-09 22:20:35.562	error	(11818) uncaught exception: secret is not defined
    tr-064.0	2020-02-09 22:20:35.431	info	(11818) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.19.0
    host.iobroker	2020-02-09 22:20:32.564	info	instance system.adapter.tr-064.0 started with pid 11818
    host.iobroker	2020-02-09 22:20:32.526	info	"system.adapter.tr-064.0" enabled
    • S saeft_2003
      @apollon77
      #102
      @saeft_2003 Ich hab ja auch nicht gesagt du sollst auf die GitHub Version updaten ... Ja ok im Stable ist die 3.xer noch nicht ... hm ... stell mal auf "Latest" um und nimm die 3.1.4 von da
      S 2 Antworten Letzte Antwort
        saeft_2003
        #103
        @apollon77
        Ok mach ich
          saeft_2003
          #104
          @apollon77
          Noch was ich würde gerne javascript updaten auf 4.3.4. Geht aber nicht da falsche version von admin. Installiert ist aber 3.7.8
          • S saeft_2003
            @apollon77
            #105
            @saeft_2003 Hm ... JS 4.3.4 geht mit Admin 3.7.x ... das sollte kein problem sein ... nur für js 4.4 brauchst Du Admin 4..0.1
              saeft_2003
              schrieb am zuletzt editiert von saeft_2003
              #106
              @apollon77
              ist das jetzt ein problem für mich? weil im protokoll steht das erst die 4.3.7 den js-controller 2.2.x unterstüzt.
              • S saeft_2003
                @apollon77
                #107
                @saeft_2003 Ok, nochmal ... was hast DU installiert und welche meldung kommt wo?
                  saeft_2003
                  #108
                  @apollon77
                  ich kann js nicht updaten deswegen...
                  • S saeft_2003
                    @apollon77
                    #109
                    @saeft_2003 Komisch. Das sollte an sich ok sein ... Starte mal neu ... den ganzen iobroker
                      saeft_2003
                      #110
                      @apollon77
                      habe grad eh neugestartet nach dem downgrad von tr-064 auf 3.1.4. der läuft jetzt aber js kann ich immer noch nicht aktualisieren :-(
                      • S saeft_2003
                        @apollon77
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #111
                        @saeft_2003
                        @apollon77
                        habe ich heute schon mal gelesen (mit Lösung über console und npm)
                        @apollon77
                        Sollte man das nicht ohne sudo machen ?
                        also nur
                         npm install iobroker.javascript@4.3.4
                        https://forum.iobroker.net/topic/29893/js-script-engine-update-nicht-möglich-trotz-admin-3-7-8
                        • dslraserD dslraser
                          @saeft_2003
                          @apollon77
                          @apollon77
                          also nur
                          saeft_2003
                          #112
                          @dslraser @apollon77
                          Danke für die Info! Ich habs über die Konsole gemacht und hat funktioniert. Trotzdem müsste jemand von euch mal klären warum das so ist...
                          • smartmoodS Offline
                            smartmoodS Offline
                            smartmood
                            schrieb am zuletzt editiert von smartmood
                            #113
                            ich muss zugeben ich habe mich vor dem Update des js-controller gedrückt, aus Angst dass danach nichts mehr läuft...
                            da ich gestern einige Adapteraktualisierungen vorgenommen hatte:
                            • u.a. auch socket.io - spuckt dieser im Log jetzt ununterbrochen: Server detected. Please update to js-controller 2.0 or higher !
                            Also werde ich jetzt das Update machen...
                            Hier im Thema steht ja unter VOR der Installation/ Nötige Adapter-Aktualisierungen:
                            @apollon77 sagte in js-controller 2.2 jetzt für Alle im Stable:
                            admin 3.7.8 oder höher! Sonst können Custom-Objektdaten - das unter dem Schraubenschlüssel - nicht mehr deaktiviert werden!
                            Mein admin ist zur Zeit auf 3.6.2 - eine Aktualisierung auf 3.7.8 wird mir angeboten, jedoch kann ich diese nicht durchführen weil dafür der js-controller auf 2 sein muss...
                            (iobroker läuft auf einem Raspberry Pi 4 - wenn weitere Infos nötig sind, reiche ich diese natürlich nach =))
                            Wie muss ich jetzt vorgehen?
                            Mein Youtubekanal: https://www.youtube.com/channel/UCCHBGD-bByzOnCGW0YOL0Ww Technik - Smarthome - Automatisierung
                            • smartmoodS smartmood
                              #114
                              @smartmood
                              1.) Wenn die oben gennannte Meldung von Adaptern kommt dann hast Du schoneinen 2.2.xer controller, weildie Meldung sonst nicht kommen würde
                              2.) Dann am besten js.cotnroller zuerst updaten und VOR dem "iobroker start" noch den Admin über Komandozeile "iobroker upgrade admin" updaten.
                              Habe ds jetzt auch in die FAQ eingefügt
                                smartmoodS Offline
                                smartmood
                                #115
                                @apollon77
                                Danke für die schnelle Antwort also folgende Reihenfolge:
                                1. iobroker stop
                                2. ps auxww|grep io und ps auxww|grep backup
                                3. iobroker upgrade self
                                4. iobroker upgrade admin
                                5. iobroker start
                                ... richtig?
                                apollon77A ostseereiterO 2 Antworten Letzte Antwort
                                  @apollon77
                                  1. iobroker stop
                                  5. iobroker start
                                  ... richtig?
                                  #116
                                  @smartmood das wäre die idee
                                    smartmoodS Offline
                                    smartmood
                                    #117
                                    @apollon77
                                    soeben durchgeführt - hat alles geklappt wie es soll! 👍
                                      @apollon77
                                      1. iobroker stop
                                      5. iobroker start
                                      ... richtig?
                                      ostseereiterO Offline
                                      ostseereiter
                                      #118
                                      @smartmood sagte in js-controller 2.2 jetzt für Alle im Stable:
                                      Was ist das für ein Befehl?
                                      Gruß OSR
                                      Plattform
                                      Linux x64 CPUs2 AMD G-T56N Processor 1646 MHz 8GB RAM
                                      • ostseereiterO ostseereiter
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        #119
                                        @ostseereiter
                                        ostseereiterO 1 Antwort Letzte Antwort
                                        • GlasfaserG Glasfaser
                                          @ostseereiter
                                          ostseereiter
                                          schrieb am zuletzt editiert von ostseereiter
                                          #120
                                          @Glasfaser
                                          alles klar super werde ich beachten.
                                          dann sehen meine Befehle die ich abarbeite so aus:
                                          update js controller
                                          apt-get update && apt-get upgrade -y
                                          cd /opt/iobroker
                                          sudo iobroker stop
                                          ps auxww|grep io
                                          sudo iobroker update
                                          sudo iobroker upgrade self
                                          sudo iobroker start
                                          Gruß OSR
                                          Plattform
