  4. Test Adapter ioBroker.backitup v3.1.x
    6.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • simatecS simatec
    @maximal1981 Die Instanz von Backitup auf Debug stellen.
    Sollte dies bereits so sein, kannst du dir die Logs der letzten Tage im Tab "Protokolle" über den Button oben "Logs herunterladen" ansehen
    maximal1981M Offline
    maximal1981
    #2341
    @simatec
    manuell geht es, wie oben geschrieben.
    Backitup
    System sichern…
    Backup Informationen
    info
    Letzte ioBroker Sicherung:
    08. April 2023 um 13:34 Uhr
    Nächste ioBroker Sicherung:
    09. April 2023 um 02:40 Uhr
    storage
    aktive Speicher-Optionen
    Google Drive
    backup
    aktive Backup-Optionen
    Javascript
    Systemsicherung
    Wiederherstellen
    Lokal
    Sicherungsquelle
    Alle Sicherungs Einstellungen können in der Adapterkonfiguration von Backitup geändert werden.
    Backitup-Ausführung:
    Started iobroker ...
    [DEBUG] [iobroker] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups"}
    [DEBUG] [iobroker] - host.iobroker 19416 states saved
    [DEBUG] [iobroker] - host.iobroker 22426 objects saved
    [DEBUG] [iobroker] - Backup created: C:\ioBroker\backups\iobroker_2023_04_08-13_33_34_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "C:/ioBroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: Weihnachten
    [DEBUG] [javascripts] - found Script: Sonos_Esszimmer
    [DEBUG] [javascripts] - found Script: Halbkeller
    [DEBUG] [javascripts] - found Script: Ansagen
    [DEBUG] [javascripts] - found Script: Shelly_update
    [DEBUG] [javascripts] - found Script: Strom
    [DEBUG] [javascripts] - found Script: Sonos_Kinderzimmer
    [DEBUG] [javascripts] - found Script: Fenster-Schlafzimmer
    [DEBUG] [javascripts] - found Script: Spritpreis_mit_Logo
    [DEBUG] [javascripts] - found Script: Spritpreisrechner
    [DEBUG] [javascripts] - found Script: Test
    [DEBUG] [javascripts] - found Script: Objekte_anlegen_Mäx
    [DEBUG] [javascripts] - found Script: UWZ
    [DEBUG] [javascripts] - found Script: adapter_infos
    [DEBUG] [javascripts] - found Script: adapter_vis
    [DEBUG] [javascripts] - found Script: adapter_widget
    [DEBUG] [javascripts] - found Script: hm_meldungen
    [DEBUG] [javascripts] - found Script: alexa_log_skript
    [DEBUG] [javascripts] - found Script: receiver_aufnahmen
    [DEBUG] [javascripts] - found Script: receiver_timer
    [DEBUG] [javascripts] - found Script: sonoff_infos
    [DEBUG] [javascripts] - found Script: objekte_erstellen
    [DEBUG] [javascripts] - found Script: reboot_qnap-b
    [DEBUG] [javascripts] - found Script: shutdown_esxp01
    [DEBUG] [javascripts] - found Script: shutdown_esxp02
    [DEBUG] [javascripts] - found Script: shutdown_qnap-archiv_v0_1
    [DEBUG] [javascripts] - found Script: shutdown_synology_v0_1
    [DEBUG] [javascripts] - found Script: alias_erzeugen
    [DEBUG] [javascripts] - found Script: kodi_fanart
    [DEBUG] [javascripts] - found Script: onlinezeit
    [DEBUG] [javascripts] - found Script: regenradar
    [DEBUG] [javascripts] - found Script: abfall_tage
    [DEBUG] [javascripts] - found Script: staumeldung
    [DEBUG] [javascripts] - found Script: test
    [DEBUG] [javascripts] - found Script: wol_daniel
    [DEBUG] [javascripts] - found Script: wol_esxp01
    [DEBUG] [javascripts] - found Script: wol_esxp02
    [DEBUG] [javascripts] - found Script: wol_qnap_archiv
    [DEBUG] [javascripts] - found Script: wol_synology
    [DEBUG] [javascripts] - found Script: wol_winnas
    [DEBUG] [javascripts] - found Script: wol_xmg
    [DEBUG] [javascripts] - found Script: Heizungsanforderung
    [DEBUG] [javascripts] - found Script: wohnzimmer_v0_3
    [DEBUG] [javascripts] - found Script: pv_ost_west
    [DEBUG] [javascripts] - found Script: #no-need_temperaturen
    [DEBUG] [javascripts] - found Script: bewegungsmelder
    [DEBUG] [javascripts] - found Script: iobroker-pi_api_sync
    [DEBUG] [javascripts] - found Script: DPs_kopieren
    [DEBUG] [javascripts] - found Script: Sternzeichen
    [DEBUG] [javascripts] - found Script: unifi_auto_alive
    [DEBUG] [javascripts] - found Script: Beleuchtung
    [DEBUG] [javascripts] - found Script: PC-Steckdose
    [DEBUG] [javascripts] - found Script: 3D_Drucker
    [DEBUG] [javascripts] - found Script: Geschirrspueler
    [DEBUG] [javascripts] - found Script: Geraeteueberwachung
    [DEBUG] [javascripts] - found Script: Fernseher
    [DEBUG] [javascripts] - found Script: Lichtueberwachung
    [DEBUG] [javascripts] - found Script: ankleide_v0_1
    [DEBUG] [javascripts] - found Script: kueche_v0_1
    [DEBUG] [javascripts] - found Script: schlafzimmer_v0_1
    [DEBUG] [javascripts] - found Script: aussenbeleuchtung
    [DEBUG] [javascripts] - found Script: kueche_v0_2
    [DEBUG] [javascripts] - found Script: schlafzimmer_v0_3
    [DEBUG] [javascripts] - found Script: weckzeit_jenny
    [DEBUG] [javascripts] - found Script: weihnachten
    [DEBUG] [javascripts] - found Script: #no-need_lueftung_rolladen_v0_2
    [DEBUG] [javascripts] - found Script: #test_Wecker
    [DEBUG] [javascripts] - found Script: aussentemperatur
    [DEBUG] [javascripts] - found Script: kalender
    [DEBUG] [javascripts] - found Script: kamera_auf_TV
    [DEBUG] [javascripts] - found Script: tuerklingel
    [DEBUG] [javascripts] - found Script: weckradio
    [DEBUG] [javascripts] - found Script: buero_monitore_v0_1
    [DEBUG] [javascripts] - found Script: trockner_v0_1
    [DEBUG] [javascripts] - found Script: waschmaschine_v0_1
    [DEBUG] [javascripts] - found Script: kodi_steckdose_v0_3
    [DEBUG] [javascripts] - found Script: ps4_lueftung_v0_2
    [DEBUG] [javascripts] - found Script: schlafzimmer_tv_v0_1
    [DEBUG] [javascripts] - found Script: vu_receiver
    [DEBUG] [javascripts] - found Script: backup_erstellen
    [DEBUG] [javascripts] - found Script: fritzbox
    [DEBUG] [javascripts] - found Script: ressourcen_berechnungen
    [DEBUG] [javascripts] - found Script: iobroker_instanz
    [DEBUG] [javascripts] - found Script: iobroker_pi_instanz
    [DEBUG] [javascripts] - found Script: qnap_archiv
    [DEBUG] [javascripts] - found Script: qnap_b
    [DEBUG] [javascripts] - found Script: sonoff_bewaesserung
    [DEBUG] [javascripts] - found Script: synology
    [DEBUG] [javascripts] - found Script: unifi_ap_eg
    [DEBUG] [javascripts] - found Script: unifi_ap_og
    [DEBUG] [javascripts] - found Script: unifi_ap_pavillon
    [DEBUG] [javascripts] - found Script: unifi_controller
    [DEBUG] [javascripts] - found Script: unifi_switch_rack
    [DEBUG] [javascripts] - found Script: unifi_switch_wohnzimmer
    [DEBUG] [javascripts] - found Script: win10
    [DEBUG] [javascripts] - found Script: winnas
    [DEBUG] [javascripts] - found Script: wlan_failover
    [DEBUG] [javascripts] - found Script: Kuddel_vis_var
    [DEBUG] [javascripts] - found Script: WebSpeedy
    [DEBUG] [javascripts] - found Script: indirektes_Licht
    [DEBUG] [javascripts] - found Script: Nachlegen
    [DEBUG] [javascripts] - found Script: Klima-Kinderzimmer
    [DEBUG] [javascripts] - found Script: Klima-Schlafzimmer
    [DEBUG] [javascripts] - found Script: Mini_Clubman
    [DEBUG] [javascripts] - found Script: objekte_anlegen_v0_1
    [DEBUG] [javascripts] - found Script: kodi_licht_v0_1
    [DEBUG] [javascripts] - found Script: schriftleuchte_v0_2
    [DEBUG] [javascripts] - found Script: weckzeit_daniel
    [DEBUG] [javascripts] - found Script: kamera_ueberwachung
    [DEBUG] [javascripts] - found Script: reboot_skript
    [DEBUG] [javascripts] - found Script: system_ctr_vis
    [DEBUG] [javascripts] - found Script: esx_nuc
    [DEBUG] [javascripts] - found Script: PV
    [DEBUG] [javascripts] - found Script: PV_new
    [DEBUG] [javascripts] - found Script: #no-need_rolladen_beamer_v0_3
    [DEBUG] [javascripts] - found Script: rolladen_verdunkelung_v0_1
    [DEBUG] [javascripts] - found Script: briefkasten_tuerklingel_v0_1
    [DEBUG] [javascripts] - found Script: echo_stati
    [DEBUG] [javascripts] - found Script: ccu
    [DEBUG] [javascripts] - found Script: motioneye
    [DEBUG] [javascripts] - found Script: nut-server
    [DEBUG] [javascripts] - found Script: omv
    [DEBUG] [javascripts] - found Script: pihole
    [DEBUG] [javascripts] - found Script: raspberry-matic
    [DEBUG] [javascripts] - found Script: sophos
    [DEBUG] [javascripts] - found Script: vu_wohnzimmer
    [DEBUG] [javascripts] - found Script: Klima-Wohnzimmer
    [DEBUG] [javascripts] - found Script: RGB
    [DEBUG] [javascripts] - found Script: shutdown_WinNAS_v01
    [DEBUG] [javascripts] - found Script: lichterkette_flur_v0_3
    [DEBUG] [javascripts] - found Script: lichtkugeln_v0_2
    [DEBUG] [javascripts] - found Script: usv_shutdown
    [DEBUG] [javascripts] - found Script: hm_meldungen_neu
    [DEBUG] [javascripts] - found Script: logs_vis_neu
    [DEBUG] [javascripts] - found Script: sonoff_tabelle_6_spalten
    [DEBUG] [javascripts] - found Script: sonoff_tabelle_8_spalten
    [DEBUG] [javascripts] - found Script: bahn_verspaetungen
    [DEBUG] [javascripts] - found Script: anwesenheit
    [DEBUG] [javascripts] - found Script: remote_abfragen
    [DEBUG] [javascripts] - found Script: Rolladen
    [DEBUG] [javascripts] - found Script: harmony_schaltung_v0_4
    [DEBUG] [javascripts] - found Script: vis_status
    [DEBUG] [javascripts] - found Script: alexa_benachrichtigungen
    [DEBUG] [javascripts] - found Script: #zeiten_v01
    [DEBUG] [javascripts] - found Script: solarweb_abfrage
    [DEBUG] [javascripts] - found Script: adapter_starten_stoppen
    [DEBUG] [javascripts] - found Script: staubsauger_v0_3
    [DEBUG] [javascripts] - found Script: benachrichtigungen_v0_2
    [DEBUG] [javascripts] - found Script: bewasserung_sonoff
    [DEBUG] [javascripts] - found Script: bewaesserung
    [DEBUG] [javascripts] - found Script: rolladen_tag_nacht
    [DEBUG] [javascripts] - found Script: bewaesserung_neu_1
    [DEBUG] [javascripts] - found Script: battery
    [DEBUG] [javascripts] - found Script: userdata_wrong
    [DEBUG] [javascripts] - found Script: DWD-UWZ-NINA-Pushwarnungen
    [DEBUG] [javascripts] - found Script: tablet
    [DEBUG] [javascripts] - found Script: wer_schaltet_DP
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "C:/ioBroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "C:/ioBroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: C:\ioBroker\backups\javascripts_2023_04_08-13_33_46_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2023_04_08-13_33_34_backupiobroker.tar.gz...
    [DEBUG] [drive] start with {"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"deleteBackupAfter":0}
    [DEBUG] [googledrive] - Google Drive: Copy javascripts_2023_04_08-13_33_46_backupiobroker.tar.gz...
    [DEBUG] [googledrive] - done
    [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
    [DEBUG] [clean] - done
    [DEBUG] [email] - [iobroker] used E-Mail-Instance: email.0
    [DEBUG] [email] - done
    [DEBUG] [email] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [DEBUG] [historyJSON] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
    [EXIT] 0
    simatecS 2 Antworten Letzte Antwort
    • maximal1981M maximal1981
      @simatec
      Backitup
      System sichern…
      info
      storage
      Google Drive
      backup
      Javascript
      Systemsicherung
      Wiederherstellen
      Lokal
      Sicherungsquelle
      [EXIT] 0
      simatecS Offline
      simatecS Offline
      simatec
      #2342
      @maximal1981 sagte in Test Adapter ioBroker.backitup v2.6.x:
      Nächste ioBroker Sicherung: 09. April 2023 um 02:40 Uhr
      Ändere die Zeit auf was krummes wie 2:17 Uhr.
      Google ist immer zu den Standardzeit gut ausgelastet, was zu Problemen führen kann
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
        @simatec
        Backitup
        System sichern…
        info
        storage
        Google Drive
        backup
        Javascript
        Systemsicherung
        Wiederherstellen
        Lokal
        Sicherungsquelle
        [EXIT] 0
        simatecS Offline
        simatecS Offline
        simatec
        #2343
        @maximal1981 Alternativ nimm ne andere Cloud wie Dropbox oder Onedrive
        maximal1981M 1 Antwort Letzte Antwort
        • C Offline
          cbrocker
          #2344
          ich bin gerade auch mit einem Problem bei Backup bzw. Restore auf ein neues System beschäftigt.
          Darf ich mich hier anhängen oder soll ich einen neuen Thread aufmachen?
          Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
          • C cbrocker
            #2345
            @cbrocker sagte in Test Adapter ioBroker.backitup v2.6.x:
            Vermutlich die ubersichtlichere Variante.
            C 1 Antwort Letzte Antwort
              cbrocker
              #2346
              @thomas-braun ja, wenn ich sehe, hier schon 2345 Einträge...
              mache ich. danke
              • simatecS simatec
                maximal1981
                #2347
                @simatec
                habe Zeit abgeändert, zusätzlich mal onedrive aktiviert und werde es weiter verfolgen.
                aber trotzdem dürfte das backup nicht anhalten/einfrieren oder was auch immer, sondern einen Fehler bringen, da bei mir nach dem nicht abgelegten backup 05. April nicht mehr lief, jedoch nächste Sicherung immer korrekt angezeigt wird.
                  @simatec
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #2348
                  @maximal1981 Das Backup wurde erstellt und konnte halt nicht in Google Drive abgelegt werden, da Google nicht erreichbar war
                  • simatecS simatec
                    maximal1981
                    #2349
                    @simatec aber die nächsten Tage nicht mehr.
                    wenn zumindest lokale Sicherungen erstellt worden wären die nächsten Tage, und Fehler im Log vorhanden wären.
                    Kann es sein, dass das backup dann mit dem Upload auf "ewig" hochladet und kein neues gestartet wird?
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #2350
                      @maximal1981 Dafür benötige ich den vollständigen debuglog vom Backupprozess.
                      Ansonsten ist es in die Glaskugel schauen
                      • simatecS simatec
                        @david-g Was kommt jetzt in der Ausgabe über CLI
                        iob backup
                        David G.D Online
                        David G.D Online
                        David G.
                        #2351
                        @simatec sagte in Test Adapter ioBroker.backitup v2.6.x:
                        iob backup
                        Jetzt läuft er wieder nicht
                        pi@pi:~ $ iob backup
                        host.pi 24211 states saved
                        host.pi 26491 objects saved
                        /usr/bin/iob: line 10: 10346 Killed                  sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                        pi@pi:~ $
                        Die "10346" ändert sich bei jeden Versuch. Aber immer etwas nach oben.
                        Mache jetzt grade erstmal nichts. Kein fix, reboot etc.
                        • David G.D David G.
                          iob backup
                          pi@pi:~ $
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #2352
                          @david-g So jetzt gehen wir mal in eine andere Richtung.
                          So wie ich vermute, könnte dir beim Backup der RAM ausgehen.
                          Wie groß sind deine iobroker Backups?
                          • simatecS simatec
                            David G.D Online
                            David G.D Online
                            David G.
                            #2353
                            @simatec
                            32mb
                            So alle 2 Tage startet der iob willkürlich von selber neu.
                            Hab noch nicht rausgefunden warum. Das siehst man da, wo der RAM einmal runter geht.
                            Testhalber ein paar Instanzen deaktivieren und nochmal testen?
                            Grad eben ist es nochmal gelaufen.
                              @simatec
                              32mb
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #2354
                              @david-g
                              Da musst du mal schauen, was da soviel RAM frisst.
                              Wenn du wieder den Fehler bekommst beim Backup über cli, fahre mal dein iobroker runter bzw. Stoppe ihn und versuche das Backup erneut.
                              Des Weiteren würde ich dich bitten zu dem Thema mal ein separaten Thread aufzumachen.
                              Hier geht es um Tests des Adapters und nicht um spezifische Probleme, die nicht in Verbindung mit dem Adapter stehen
                              • simatecS simatec
                                @david-g
                                David G.D Online
                                David G.D Online
                                David G.
                                #2355
                                @simatec
                                Okay 👌
                                Okay 👌
                                Okay 👌
                                Werde berichten.
                                  Sushibomba
                                  schrieb am zuletzt editiert von Sushibomba
                                  #2356
                                  Hey... weiß nicht ob ich dafür jetzt nen neuen Thread aufmachen soll oder nicht aber mein Backup läuft seit kurzem nicht mehr durch.
                                  [DEBUG] [iobroker] - host.Pi4ioBroker128GB 21396 states saved
                                  [DEBUG] [iobroker] - host.Pi4ioBroker128GB 25489 objects saved
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_05_02-22_19_31_backupiobroker.tar.gz
                                  [DEBUG] [influxDB] - InfluxDB-Backup started ...
                                  [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                  [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                  [DEBUG] [influxDB] - Packed 26MB so far...
                                  [DEBUG] [influxDB] - Packed 59MB so far...
                                  [DEBUG] [influxDB] - Packed 93MB so far...
                                  [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_05_02-22_20_28_backupiobroker.tar.gz
                                  [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_05_02-22_20_28_backupiobroker"
                                  [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_05_02-22_20_28_backupiobroker" successfully deleted
                                  [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                                  [DEBUG] [influxDB] - done
                                  [DEBUG] [mysql] - MySql-Backup started ...
                                  Er bleibt bei MySql-Backup started stehen. Nach ner Weil hängt sich dann auch der komplette Pi4 auf und ist vorerst nicht mehr erreichbar.
                                  Jemand eine Idee woran das liegen kann? Habe keine Einstellungen geändert und sichere auf meiner Fritzbox per FTP.
                                  Nach einem manuellen Neustart des Pi`s kommt dann folgendes debug:
                                  backitup.0
                                  2023-05-02 22:59:34.880	debug	Plugin sentry destroyed because not initialized correctly
                                  backitup.0
                                  2023-05-02 22:59:34.793	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                                  backitup.0
                                  2023-05-02 22:59:32.406	debug	States connected to redis: 127.0.0.1:9000
                                  backitup.0
                                  2023-05-02 22:59:30.830	debug	States create User PubSub Client
                                  backitup.0
                                  2023-05-02 22:59:30.828	debug	States create System PubSub Client
                                  backitup.0
                                  2023-05-02 22:59:30.617	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                  backitup.0
                                  2023-05-02 22:59:30.039	debug	Objects connected to redis: 127.0.0.1:9001
                                  backitup.0
                                  2023-05-02 22:59:29.726	debug	Objects client initialize lua scripts
                                  backitup.0
                                  2023-05-02 22:59:28.922	debug	Objects create User PubSub Client
                                  backitup.0
                                  2023-05-02 22:59:28.920	debug	Objects create System PubSub Client
                                  backitup.0
                                  2023-05-02 22:59:28.323	debug	Objects client ready ... initialize now
                                  backitup.0
                                  2023-05-02 22:59:27.775	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  backitup.0
                                  2023-05-02 22:58:51.542	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                  backitup.0
                                  2023-05-02 22:58:51.538	debug	Plugin sentry destroyed
                                  backitup.0
                                  2023-05-02 22:58:51.535	error	backitup.0 already running
                                  backitup.0
                                  2023-05-02 22:58:51.414	debug	States connected to redis: 127.0.0.1:9000
                                  • S Sushibomba
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    backitup.0
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #2357
                                    @sushibomba Wie groß ist der mysql db denn?
                                    Denke dir geht der RAM aus?
                                    • simatecS simatec
                                      Sushibomba
                                      #2358
                                      @simatec
                                      Wie finde ich das denn raus wie groß die MySql Datenbank ist? Was mich wundert, die Backup nachts scheinen problemlos zu laufen. Nur wenn ich es manuell anstoße passiert das.
                                      Habe nen pi4 mit 4GB Ram
                                      • simatecS Offline
                                        simatecS Offline
                                        simatec
                                        schrieb am zuletzt editiert von simatec
                                        #2359
                                        @sushibomba Zeige mal folgende Ausgaben
                                        ls -lah /opt/iobroker/backups
                                        df -h
                                        iob diag
                                        • simatecS simatec
                                          df -h
                                          iob diag
                                          Sushibomba
                                          #2360
                                          pi@Pi4ioBroker128GB:~ $ ls -lah /opt/iobroker/backups
                                          total 3.2G
                                          drwxrwxr-x+ 2 iobroker iobroker  12K May  3 08:27 .
                                          drwxrwxr-x+ 6 iobroker iobroker 4.0K Aug  6  2022 ..
                                          -rw-rwxr--+ 1 iobroker iobroker 2.6M Apr 25  2022 2022_04_25-20_23_29_backupiobr                                    oker.tar.gz
                                          -rw-rwxr--+ 1 iobroker iobroker 5.7M Jun 27  2022 2022_06_27-15_47_53_backupiobr                                    oker.tar.gz
                                          -rw-rwxr--+ 1 iobroker iobroker 5.7M Jun 27  2022 2022_06_27-16_41_28_backupiobr                                    oker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  11K Apr 19 08:24 grafana_2023_04_19-08_23_57_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  11K Apr 20 08:24 grafana_2023_04_20-08_24_25_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  11K Apr 21 08:24 grafana_2023_04_21-08_24_30_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  11K Apr 22 08:24 grafana_2023_04_22-08_24_30_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  11K Apr 23 08:24 grafana_2023_04_23-08_24_33_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  12K Apr 24 08:27 grafana_2023_04_24-08_27_46_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  12K Apr 25 08:27 grafana_2023_04_25-08_27_49_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  12K Apr 26 08:30 grafana_2023_04_26-08_30_25_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  12K Apr 27 08:28 grafana_2023_04_27-08_28_02_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  12K Apr 28 08:27 grafana_2023_04_28-08_27_32_ba                                    ckupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 109M Apr 19 02:02 influxDB_2023_04_19-02_01_03_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 109M Apr 20 02:01 influxDB_2023_04_20-02_01_03_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 109M Apr 21 02:02 influxDB_2023_04_21-02_01_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 110M Apr 22 02:02 influxDB_2023_04_22-02_01_08_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 110M Apr 23 02:02 influxDB_2023_04_23-02_01_08_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 110M Apr 24 02:02 influxDB_2023_04_24-02_01_09_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 111M Apr 25 02:02 influxDB_2023_04_25-02_01_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 110M Apr 26 02:02 influxDB_2023_04_26-02_01_07_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 110M Apr 27 02:02 influxDB_2023_04_27-02_01_07_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 110M Apr 28 02:01 influxDB_2023_04_28-02_01_03_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 111M Apr 28 13:32 influxDB_2023_04_28-13_31_51_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 111M Apr 28 15:15 influxDB_2023_04_28-15_14_39_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 111M Apr 29 02:01 influxDB_2023_04_29-02_01_03_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 112M Apr 30 02:02 influxDB_2023_04_30-02_01_06_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 112M May  1 02:01 influxDB_2023_05_01-02_01_03_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 113M May  2 02:01 influxDB_2023_05_02-02_01_05_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 111M May  2 22:10 influxDB_2023_05_02-22_09_19_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 112M May  2 22:21 influxDB_2023_05_02-22_20_28_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 112M May  3 02:19 influxDB_2023_05_03-02_18_56_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 19 02:01 iobroker_2023_04_19-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 20 02:01 iobroker_2023_04_20-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 21 02:01 iobroker_2023_04_21-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 22 02:01 iobroker_2023_04_22-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 23 02:01 iobroker_2023_04_23-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 24 02:01 iobroker_2023_04_24-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 25 02:01 iobroker_2023_04_25-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 26 02:01 iobroker_2023_04_26-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 27 02:01 iobroker_2023_04_27-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 28 02:01 iobroker_2023_04_28-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 28 13:31 iobroker_2023_04_28-13_31_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 28 15:14 iobroker_2023_04_28-15_13_58_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 29 02:01 iobroker_2023_04_29-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  38M Apr 30 02:01 iobroker_2023_04_30-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  40M May  1 02:01 iobroker_2023_05_01-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  41M May  2 02:01 iobroker_2023_05_02-02_00_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  41M May  2 22:09 iobroker_2023_05_02-22_08_29_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  41M May  2 22:20 iobroker_2023_05_02-22_19_31_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  41M May  3 02:18 iobroker_2023_05_03-02_18_10_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 178K Apr 19 08:24 javascripts_2023_04_19-08_24_0                                    2_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 178K Apr 20 08:24 javascripts_2023_04_20-08_24_3                                    1_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 190K Apr 21 08:24 javascripts_2023_04_21-08_24_3                                    6_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 197K Apr 22 08:24 javascripts_2023_04_22-08_24_3                                    5_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 193K Apr 23 08:24 javascripts_2023_04_23-08_24_3                                    9_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 194K Apr 24 08:27 javascripts_2023_04_24-08_27_5                                    2_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 194K Apr 25 08:27 javascripts_2023_04_25-08_27_5                                    4_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 305K Apr 26 08:30 javascripts_2023_04_26-08_30_3                                    1_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 298K Apr 27 08:28 javascripts_2023_04_27-08_28_0                                    8_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 301K Apr 28 08:27 javascripts_2023_04_28-08_27_3                                    7_backupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 19 08:23 mysql_2023_04_19-02_02_00_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 20 08:24 mysql_2023_04_20-02_01_59_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 21 08:24 mysql_2023_04_21-02_02_10_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 22 08:24 mysql_2023_04_22-02_02_09_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 23 08:24 mysql_2023_04_23-02_02_08_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 24 08:27 mysql_2023_04_24-02_02_07_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 25 08:27 mysql_2023_04_25-02_02_08_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 26 08:30 mysql_2023_04_26-02_02_05_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  13M Apr 27 08:27 mysql_2023_04_27-02_02_07_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  14M Apr 28 08:27 mysql_2023_04_28-02_01_57_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 179M Apr 28 21:02 mysql_2023_04_28-13_32_44_back                                    upiobroker.sql
                                          -rw-rw-r--+ 1 iobroker iobroker  14M Apr 28 21:03 mysql_2023_04_28-15_15_38_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  14M Apr 29 08:27 mysql_2023_04_29-02_01_57_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  14M Apr 30 08:29 mysql_2023_04_30-02_02_00_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  14M May  1 08:28 mysql_2023_05_01-02_01_58_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker  14M May  2 08:27 mysql_2023_05_02-02_02_00_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker    0 May  2 22:10 mysql_2023_05_02-22_10_30_back                                    upiobroker.sql
                                          -rw-rw-r--+ 1 iobroker iobroker    0 May  2 22:21 mysql_2023_05_02-22_21_32_back                                    upiobroker.sql
                                          -rw-rw-r--+ 1 iobroker iobroker  14M May  3 08:27 mysql_2023_05_03-02_19_52_back                                    upiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 19 08:23 zigbee.0_2023_04_19-08_23_55_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 20 08:24 zigbee.0_2023_04_20-08_24_23_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 21 08:24 zigbee.0_2023_04_21-08_24_28_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 22 08:24 zigbee.0_2023_04_22-08_24_28_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 23 08:24 zigbee.0_2023_04_23-08_24_32_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 24 08:27 zigbee.0_2023_04_24-08_27_44_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 25 08:27 zigbee.0_2023_04_25-08_27_47_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 26 08:30 zigbee.0_2023_04_26-08_30_23_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 27 08:28 zigbee.0_2023_04_27-08_28_00_b                                    ackupiobroker.tar.gz
                                          -rw-rw-r--+ 1 iobroker iobroker 3.0K Apr 28 08:27 zigbee.0_2023_04_28-08_27_30_b                                    ackupiobroker.tar.gz
                                          df -h
                                          pi@Pi4ioBroker128GB:~ $ df -h
                                          Filesystem      Size  Used Avail Use% Mounted on
                                          /dev/root       117G   18G   95G  16% /
                                          devtmpfs        1.7G     0  1.7G   0% /dev
                                          tmpfs           1.9G   16K  1.9G   1% /dev/shm
                                          tmpfs           759M  852K  758M   1% /run
                                          tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                                          /dev/sda1       253M   51M  202M  20% /boot
                                          tmpfs           380M     0  380M   0% /run/user/1000
                                          iob diag
                                          pi@Pi4ioBroker128GB:~ $ iob diag
                                          iobroker [command]
                                          Commands:
                                            iobroker setup                                               Setup ioBroker
                                            iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                                            iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                                            iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                                            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                                            iobroker info                                                Shows the host info
                                            iobroker logs [<adapter>]                                    Monitor log
                                            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                                            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                                            iobroker rebuild [<module>]                                  Rebuild all native modules or path
                                            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                                            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                                            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                                            iobroker update [<repositoryUrl>]                            Update repository and list adapters
                                            iobroker upgrade                                             Upgrade management
                                            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                                            iobroker object                                              Object management  [aliases: o]
                                            iobroker state                                               State management  [aliases: s]
                                            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                                            iobroker list <type> [<filter>]                              List all entries, like objects
                                            iobroker chmod <mode> <file>                                 Change file rights
                                            iobroker chown <user> <group> <file>                         Change file ownership
                                            iobroker touch <file>                                        Touch file
                                            iobroker rm <file>                                           Remove file
                                            iobroker file                                                File management
                                            iobroker user                                                User commands
                                            iobroker group                                               group management
                                            iobroker host <hostname>                                     Set host to given hostname
                                            iobroker set <adapter>.<instance>                            Change settings of adapter config
                                            iobroker license <license.file or license.text>              Update license by given file
                                            iobroker cert                                                Certificate management
                                            iobroker clean <yes>                                         Clears all objects and states
                                            iobroker backup                                              Create backup
                                            iobroker restore <backup name or path>                       Restore a specified backup
                                            iobroker validate <backup name or path>                      Validate a specified backup
                                            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                                            iobroker repo [<name>]                                       Show repo information
                                            iobroker uuid                                                Show uuid of the installation  [aliases: id]
                                            iobroker unsetup                                             Reset license, installation secret and language
                                            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                                            iobroker multihost                                           Multihost management
                                            iobroker compact                                             compact group management
                                            iobroker plugin                                              Plugin management
                                            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                                          Options:
                                            --help  Show help  [boolean]
