  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • David G.D David G.
    @simatec
    Ja, der fix ist gestern 2x durch.
    Dadurch ging es ja immer auch kurz.
    Auch mehrere Neustarts ob zu prüfen ob es mit zu tun hat.
    Hier nochmal ein aktuelles iob diag:
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v8+                                 Installation:           Native                                     Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000                                       X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0                                          Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                            /usr/bin/node           v18.15.0
                            /usr/bin/npm            9.5.0
                            /usr/bin/npx            9.5.0
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        2.4G        912M        0.0K        519M        1.3G
    Swap:            99M         12M         87M
    Total:          3.9G        2.4G        999M
    Active iob-Instances:   52
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.7
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : pi                                       -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    Objects:                26473
    States:                 24308
    Size of iob-Database:
    55M     /opt/iobroker/iobroker-data/objects.jsonl
    67M     /opt/iobroker/iobroker-data/states.jsonl
    Und komplett
    *** BASE SYSTEM ***                                                Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian                                           Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     12:40:42 up 15:30,  2 users,  load average: 3.80, 3.15, 2.18
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sat 2023-04-08 12:40:42 CEST
               Universal time: Sat 2023-04-08 10:40:42 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        2.8G        716M        0.0K        266M        876M
    Swap:            99M         12M         87M
    Total:          3.9G        2.8G        804M
             3793 M total memory
             2809 M used memory
             2744 M active memory
              155 M inactive memory
              716 M free memory
                9 M buffer memory
              256 M swap cache
               99 M total swap
               12 M used swap
               87 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4      229G   18G  202G   9% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  880K  758M   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Apr  7 21:09:51 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:AC:7B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7faabd4d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Apr  7 21:09:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Apr  7 21:09:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Apr  7 21:09:55 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    8.5G    /var/
    7.9G    /var/log
    3.0G    /var/log/journal/bd463378997f44f088b185e90db76a13
    406M    /var/lib
    /opt/iobroker/backups:
    2.4G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    776M    /opt/iobroker/iobroker-data/
    528M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
    111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
    64M     /opt/iobroker/iobroker-data/states.jsonl
    53M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    22M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.b7f9d93f.js.map
    *** NodeJS-Installation ***
    /usr/bin/npm            9.5.0
    /usr/bin/npx            9.5.0
    nodejs:
      Installed: 18.15.0-deb-1nodesource1
      Candidate: 18.15.0-deb-1nodesource1
      Version table:
     *** 18.15.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.7
    javascript:     6.1.4
    Adapters from github:   10
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : pi                                       -  enabled
    + system.adapter.adb.0                    : adb                   : pi                                       -  enabled
      system.adapter.alexa2.0                 : alexa2                : pi                                       - disabled
      system.adapter.alias-manager.0          : alias-manager         : pi                                       - disabled
    + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
      system.adapter.birthdays.0              : birthdays             : pi                                       -  enabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : pi                                       -  enabled
    + system.adapter.cloud.0                  : cloud                 : pi                                       -  enabled
      system.adapter.daswetter.0              : daswetter             : pi                                       -  enabled
      system.adapter.daswetter.1              : daswetter             : pi                                       -  enabled
      system.adapter.device-reminder.0        : device-reminder       : pi                                       - disabled
    + system.adapter.device-watcher.0         : device-watcher        : pi                                       -  enabled
      system.adapter.devices.0                : devices               : pi                                       - disabled
      system.adapter.discovery.0              : discovery             : pi                                       - disabled
    + system.adapter.echarts.0                : echarts               : pi                                       -  enabled
    + system.adapter.email.0                  : email                 : pi                                       -  enabled
      system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
      system.adapter.flot.0                   : flot                  : pi                                       -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : pi                                       - disabled
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: pi                                       -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : pi                                       -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : pi                                       -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : pi                                       -  enabled, port: 0
    + system.adapter.hmip.0                   : hmip                  : pi                                       -  enabled
      system.adapter.ical.0                   : ical                  : pi                                       -  enabled
      system.adapter.ical.1                   : ical                  : pi                                       -  enabled
      system.adapter.iceroad.0                : iceroad               : pi                                       -  enabled
    + system.adapter.imap.0                   : imap                  : pi                                       -  enabled
    + system.adapter.info.0                   : info                  : pi                                       -  enabled
    + system.adapter.iot.0                    : iot                   : pi                                       -  enabled
    + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
    + system.adapter.linux-control.0          : linux-control         : pi                                       -  enabled
    + system.adapter.logparser.0              : logparser             : pi                                       -  enabled
    + system.adapter.lovelace.0               : lovelace              : pi                                       -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.lovelace.1               : lovelace              : pi                                       -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : pi                                       -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.nctalk.0                 : nctalk                : pi                                       - disabled, port: 443
      system.adapter.net-tools.0              : net-tools             : pi                                       - disabled
    + system.adapter.nina.0                   : nina                  : pi                                       -  enabled
    + system.adapter.nut.0                    : nut                   : pi                                       -  enabled
    + system.adapter.parcel.0                 : parcel                : pi                                       -  enabled
    + system.adapter.parcel.1                 : parcel                : pi                                       -  enabled
      system.adapter.parser.0                 : parser                : pi                                       - disabled
    + system.adapter.ping.0                   : ping                  : pi                                       -  enabled
    + system.adapter.places.0                 : places                : pi                                       -  enabled
      system.adapter.proxy.0                  : proxy                 : pi                                       -  enabled
    + system.adapter.pushover.0               : pushover              : pi                                       -  enabled
    + system.adapter.rest-api.0               : rest-api              : pi                                       -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.roborock.0               : roborock              : pi                                       -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : pi                                       -  enabled
    + system.adapter.sayit.0                  : sayit                 : pi                                       -  enabled, port: 0
    + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1888, bind: 192.168.99.33
    + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : pi                                       -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : pi                                       -  enabled
    + system.adapter.sql.0                    : sql                   : pi                                       -  enabled, port: 0
    + system.adapter.tankerkoenig.0           : tankerkoenig          : pi                                       -  enabled
    + system.adapter.telegram.0               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : pi                                       -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : pi                                       -  enabled
    + system.adapter.upnp.0                   : upnp                  : pi                                       -  enabled
      system.adapter.vis.0                    : vis                   : pi                                       -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : pi                                       -  enabled
      system.adapter.windows-control.0        : windows-control       : pi                                       - disabled
    + system.adapter.wireguard.0              : wireguard             : pi                                       -  enabled
    + system.adapter.zigbee.0                 : zigbee                : pi                                       -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 6.3.5    , installed 6.3.7
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "device-watcher": 2.6.1   , installed 2.6.1
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "echarts"      : 1.0.12   , installed 1.4.13
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "iceroad"      : 1.2.0    , installed 1.2.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "linux-control": 1.1.3    , installed 1.1.5
    Adapter    "logparser"    : 2.1.1    , installed 2.1.1
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "operating-hours": 0.0.19 , installed 0.0.19
    Adapter    "parcel"       : 0.0.25   , installed 0.0.25
    Adapter    "parser"       : 1.1.8    , installed 1.1.8
    Adapter    "places"       : 1.1.2    , installed 1.1.2
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
    Adapter    "sayit"        : 1.12.3   , installed 1.12.6
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vw-connect"   : 0.0.62   , installed 0.0.62
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wireguard"    : 1.3.1    , installed 1.4.1
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        26473
    States:         24308
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       2475127    32245/io.sonoff.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       2477175    32333/io.mqtt.0
    tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1001       2473036    31798/io.hm-rpc.0
    tcp        0      0 192.168.99.33:3493      0.0.0.0:*               LISTEN      0          14167      983/upsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2470210    31410/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2470203    31410/iobroker.js-c
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       2476081    462/adb
    tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1001       2476128    32239/io.shelly.0
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          14168      983/upsd
    tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1001       2470901    31819/io.hm-rpc.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15680      567/sshd: /usr/sbin
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       2483547    867/io.upnp.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2470368    31528/io.admin.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       2479099    659/io.web.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2479409    650/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2476485    477/io.simple-api.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       2476487    32596/io.lovelace.0
    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       2480184    491/io.rest-api.0
    tcp6       0      0 :::8092                 :::*                    LISTEN      1001       2478080    32706/io.lovelace.1
    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       2484408    1283/go2rtc_linux_a
    tcp6       0      0 :::3306                 :::*                    LISTEN      109        11930      632/mariadbd
    tcp6       0      0 :::8555                 :::*                    LISTEN      1001       2484415    1283/go2rtc_linux_a
    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       2484412    1283/go2rtc_linux_a
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15682      567/sshd: /usr/sbin
    udp        0      0 0.0.0.0:33186           0.0.0.0:*                           1001       2479097    867/io.upnp.0
    udp        0      0 0.0.0.0:39367           0.0.0.0:*                           108        13590      400/avahi-daemon: r
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          12955      -
    udp        0      0 0.0.0.0:49986           0.0.0.0:*                           1001       2479098    867/io.upnp.0
    udp        0      0 10.137.192.1:5353       0.0.0.0:*                           1001       2473955    32259/io.tr-064.0
    udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1001       2473954    32259/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13588      400/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2480413    867/io.upnp.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2480412    867/io.upnp.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15788      802/dhcpcd
    udp6       0      0 :::8443                 :::*                                1001       2484413    1283/go2rtc_linux_a
    udp6       0      0 :::51820                :::*                                0          12956      -
    udp6       0      0 :::5353                 :::*                                108        13589      400/avahi-daemon: r
    udp6       0      0 :::56911                :::*                                108        13591      400/avahi-daemon: r
    2023-04-08 12:40:41.377  - info: hm-rega.0 (31775) deleted 0 variables
    2023-04-08 12:40:41.434  - info: hm-rega.0 (31775) update functions to enum.functions
    2023-04-08 12:40:45.213  - info: tankerkoenig.0 (524) Start first request
    2023-04-08 12:40:47.156  - info: info.0 (1149) Reading network data every 60 seconds.
    2023-04-08 12:40:48.307  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Amazon.Amazon_h successfully
    2023-04-08 12:40:48.308  - info: sourceanalytix.0 (513) Initialising (4 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Disney.Disney_h"
    2023-04-08 12:41:00.689  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Disney.Disney_h successfully
    2023-04-08 12:41:00.690  - info: sourceanalytix.0 (513) Initialising (5 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Gesamt.Gesamt_h"
    2023-04-08 12:41:08.804  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Gesamt.Gesamt_h successfully
    2023-04-08 12:41:08.805  - info: sourceanalytix.0 (513) Initialising (6 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Homescreen.Homescreen_h"
    2023-04-08 12:41:17.667  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Homescreen.Homescreen_h successfully
    2023-04-08 12:41:17.668  - info: sourceanalytix.0 (513) Initialising (7 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Netflix.Netflix_h"
    2023-04-08 12:41:26.616  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Netflix.Netflix_h successfully
    2023-04-08 12:41:26.617  - info: sourceanalytix.0 (513) Initialising (8 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Sonstige.Sonstige_h"
    2023-04-08 12:41:36.931  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Sonstige.Sonstige_h successfully
    2023-04-08 12:41:36.932  - info: sourceanalytix.0 (513) Initialising (9 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TOGGO.Toggo_h"
    2023-04-08 12:41:45.231  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TOGGO.Toggo_h successfully
    2023-04-08 12:41:45.232  - info: sourceanalytix.0 (513) InitialisinCopy text starting here:
    simatecS Offline
    simatecS Offline
    simatec
    #2335
    @david-g Was kommt jetzt in der Ausgabe über CLI
    iob backup
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • maximal1981M maximal1981
      ich schalte mich mal hier mit ein.
      Bei mir gibt es auch Probleme, habe aber ein Win10 System am laufen.
      Bin draufgekommen weil ich erst eines gebraucht hätte und es das letzte Mal vor 10 Tagen lief.
      Dann habe ich es manuell gestartet, dann lief es am nächsten Tag wie geplant 1 x und seither wieder nicht.
      Ich sichere auf google, falls dies relevant ist.
      Anbei ein Bild wann es lief.
      simatecS Offline
      simatecS Offline
      simatec
      #2336
      @maximal1981 Bitte poste den Debuglog vom Backupprozess und zusätzlich auch noch die Ausgabe, wenn du ein Backup über die CLI erstellst
      iob backup
      maximal1981M 1 Antwort Letzte Antwort
      • simatecS simatec
        @Thomas-Braun Kannst mal drüberschauen, ob dir etwas auffällt?
        #2337
        @simatec
        Nein, ist fast mustergültig aufgesetzt.
        Ich vermute da 'irgendwas' mit den entfernten Dateisystemen. Wie ist der FTP-Server angebunden?
        • simatecS simatec
          iob backup
          maximal1981M Offline
          maximal1981
          #2338
          @simatec said in Test Adapter ioBroker.backitup v2.6.x:
          iob backup
          lokal habe ich ein erstelltes Backup gefunden, google fehlt es, und im log war keine Fehlermeldung am 2023-04-05 zu finden.
          C:\iobroker>iob backup
          host.iobroker 19416 states saved
          host.iobroker 22426 objects saved
          Backup created: C:\iobroker\backups\2023_04_08-13_12_07_backupiobroker.tar.gz
          C:\iobroker>
          das manuell erstellte hat eine andere Formatierung im Dateinamen.
          Wo finde ich das debug, aktiviert habe ich es, oder muss ich jetzt auf den nächsten automatischen Lauf warten?
          • David G.D Online
            David G.D Online
            David G.
            #2339
            @simatec
            Hatte beim ersten Ablauf von iob diag als er die states auflisten wollte den inmem 9009 Fehler. Vermutlich weil der ioborker noch nicht ganz hochgefahren war. Versuche das irgendwie zu reproduzieren wann es kommt. Beim zweiten Anlauf ist das diag dann durchgelaufen.
            Jetzt ist das Backup über die gui und cli durchgelaufen.
            Es scheint nach dem fixer oder einem reboot des iobroker immer eine Zeit zu klappen.
            Poster nachher nochmal das cli eines fehlerhaften Backups. Stoße jetzt mal regelmäßig eins an.
              iob backup
              C:\iobroker>
              simatecS Offline
              simatecS Offline
              simatec
              #2340
              @maximal1981 Die Instanz von Backitup auf Debug stellen.
              Sollte dies bereits so sein, kannst du dir die Logs der letzten Tage im Tab "Protokolle" über den Button oben "Logs herunterladen" ansehen
              • simatecS simatec
                maximal1981
                #2341
                @simatec
                manuell geht es, wie oben geschrieben.
                Backitup
                System sichern…
                Backup Informationen
                info
                Letzte ioBroker Sicherung:
                08. April 2023 um 13:34 Uhr
                Nächste ioBroker Sicherung:
                09. April 2023 um 02:40 Uhr
                storage
                aktive Speicher-Optionen
                Google Drive
                backup
                aktive Backup-Optionen
                Javascript
                Systemsicherung
                Wiederherstellen
                Lokal
                Sicherungsquelle
                Alle Sicherungs Einstellungen können in der Adapterkonfiguration von Backitup geändert werden.
                Backitup-Ausführung:
                Started iobroker ...
                [DEBUG] [iobroker] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups"}
                [DEBUG] [iobroker] - host.iobroker 19416 states saved
                [DEBUG] [iobroker] - host.iobroker 22426 objects saved
                [DEBUG] [iobroker] - Backup created: C:\ioBroker\backups\iobroker_2023_04_08-13_33_34_backupiobroker.tar.gz
                [DEBUG] [iobroker] - done
                [DEBUG] [javascripts] - Created javascript_tmp directory: "C:/ioBroker/backups/tmpScripts"
                [DEBUG] [javascripts] - found Script: Weihnachten
                [DEBUG] [javascripts] - found Script: Sonos_Esszimmer
                [DEBUG] [javascripts] - found Script: Halbkeller
                [DEBUG] [javascripts] - found Script: Ansagen
                [DEBUG] [javascripts] - found Script: Shelly_update
                [DEBUG] [javascripts] - found Script: Strom
                [DEBUG] [javascripts] - found Script: Sonos_Kinderzimmer
                [DEBUG] [javascripts] - found Script: Fenster-Schlafzimmer
                [DEBUG] [javascripts] - found Script: Spritpreis_mit_Logo
                [DEBUG] [javascripts] - found Script: Spritpreisrechner
                [DEBUG] [javascripts] - found Script: Test
                [DEBUG] [javascripts] - found Script: Objekte_anlegen_Mäx
                [DEBUG] [javascripts] - found Script: UWZ
                [DEBUG] [javascripts] - found Script: adapter_infos
                [DEBUG] [javascripts] - found Script: adapter_vis
                [DEBUG] [javascripts] - found Script: adapter_widget
                [DEBUG] [javascripts] - found Script: hm_meldungen
                [DEBUG] [javascripts] - found Script: alexa_log_skript
                [DEBUG] [javascripts] - found Script: receiver_aufnahmen
                [DEBUG] [javascripts] - found Script: receiver_timer
                [DEBUG] [javascripts] - found Script: sonoff_infos
                [DEBUG] [javascripts] - found Script: objekte_erstellen
                [DEBUG] [javascripts] - found Script: reboot_qnap-b
                [DEBUG] [javascripts] - found Script: shutdown_esxp01
                [DEBUG] [javascripts] - found Script: shutdown_esxp02
                [DEBUG] [javascripts] - found Script: shutdown_qnap-archiv_v0_1
                [DEBUG] [javascripts] - found Script: shutdown_synology_v0_1
                [DEBUG] [javascripts] - found Script: alias_erzeugen
                [DEBUG] [javascripts] - found Script: kodi_fanart
                [DEBUG] [javascripts] - found Script: onlinezeit
                [DEBUG] [javascripts] - found Script: regenradar
                [DEBUG] [javascripts] - found Script: abfall_tage
                [DEBUG] [javascripts] - found Script: staumeldung
                [DEBUG] [javascripts] - found Script: test
                [DEBUG] [javascripts] - found Script: wol_daniel
                [DEBUG] [javascripts] - found Script: wol_esxp01
                [DEBUG] [javascripts] - found Script: wol_esxp02
                [DEBUG] [javascripts] - found Script: wol_qnap_archiv
                [DEBUG] [javascripts] - found Script: wol_synology
                [DEBUG] [javascripts] - found Script: wol_winnas
                [DEBUG] [javascripts] - found Script: wol_xmg
                [DEBUG] [javascripts] - found Script: Heizungsanforderung
                [DEBUG] [javascripts] - found Script: wohnzimmer_v0_3
                [DEBUG] [javascripts] - found Script: pv_ost_west
                [DEBUG] [javascripts] - found Script: #no-need_temperaturen
                [DEBUG] [javascripts] - found Script: bewegungsmelder
                [DEBUG] [javascripts] - found Script: iobroker-pi_api_sync
                [DEBUG] [javascripts] - found Script: DPs_kopieren
                [DEBUG] [javascripts] - found Script: Sternzeichen
                [DEBUG] [javascripts] - found Script: unifi_auto_alive
                [DEBUG] [javascripts] - found Script: Beleuchtung
                [DEBUG] [javascripts] - found Script: PC-Steckdose
                [DEBUG] [javascripts] - found Script: 3D_Drucker
                [DEBUG] [javascripts] - found Script: Geschirrspueler
                [DEBUG] [javascripts] - found Script: Geraeteueberwachung
                [DEBUG] [javascripts] - found Script: Fernseher
                [DEBUG] [javascripts] - found Script: Lichtueberwachung
                [DEBUG] [javascripts] - found Script: ankleide_v0_1
                [DEBUG] [javascripts] - found Script: kueche_v0_1
                [DEBUG] [javascripts] - found Script: schlafzimmer_v0_1
                [DEBUG] [javascripts] - found Script: aussenbeleuchtung
                [DEBUG] [javascripts] - found Script: kueche_v0_2
                [DEBUG] [javascripts] - found Script: schlafzimmer_v0_3
                [DEBUG] [javascripts] - found Script: weckzeit_jenny
                [DEBUG] [javascripts] - found Script: weihnachten
                [DEBUG] [javascripts] - found Script: #no-need_lueftung_rolladen_v0_2
                [DEBUG] [javascripts] - found Script: #test_Wecker
                [DEBUG] [javascripts] - found Script: aussentemperatur
                [DEBUG] [javascripts] - found Script: kalender
                [DEBUG] [javascripts] - found Script: kamera_auf_TV
                [DEBUG] [javascripts] - found Script: tuerklingel
                [DEBUG] [javascripts] - found Script: weckradio
                [DEBUG] [javascripts] - found Script: buero_monitore_v0_1
                [DEBUG] [javascripts] - found Script: trockner_v0_1
                [DEBUG] [javascripts] - found Script: waschmaschine_v0_1
                [DEBUG] [javascripts] - found Script: kodi_steckdose_v0_3
                [DEBUG] [javascripts] - found Script: ps4_lueftung_v0_2
                [DEBUG] [javascripts] - found Script: schlafzimmer_tv_v0_1
                [DEBUG] [javascripts] - found Script: vu_receiver
                [DEBUG] [javascripts] - found Script: backup_erstellen
                [DEBUG] [javascripts] - found Script: fritzbox
                [DEBUG] [javascripts] - found Script: ressourcen_berechnungen
                [DEBUG] [javascripts] - found Script: iobroker_instanz
                [DEBUG] [javascripts] - found Script: iobroker_pi_instanz
                [DEBUG] [javascripts] - found Script: qnap_archiv
                [DEBUG] [javascripts] - found Script: qnap_b
                [DEBUG] [javascripts] - found Script: sonoff_bewaesserung
                [DEBUG] [javascripts] - found Script: synology
                [DEBUG] [javascripts] - found Script: unifi_ap_eg
                [DEBUG] [javascripts] - found Script: unifi_ap_og
                [DEBUG] [javascripts] - found Script: unifi_ap_pavillon
                [DEBUG] [javascripts] - found Script: unifi_controller
                [DEBUG] [javascripts] - found Script: unifi_switch_rack
                [DEBUG] [javascripts] - found Script: unifi_switch_wohnzimmer
                [DEBUG] [javascripts] - found Script: win10
                [DEBUG] [javascripts] - found Script: winnas
                [DEBUG] [javascripts] - found Script: wlan_failover
                [DEBUG] [javascripts] - found Script: Kuddel_vis_var
                [DEBUG] [javascripts] - found Script: WebSpeedy
                [DEBUG] [javascripts] - found Script: indirektes_Licht
                [DEBUG] [javascripts] - found Script: Nachlegen
                [DEBUG] [javascripts] - found Script: Klima-Kinderzimmer
                [DEBUG] [javascripts] - found Script: Klima-Schlafzimmer
                [DEBUG] [javascripts] - found Script: Mini_Clubman
                [DEBUG] [javascripts] - found Script: objekte_anlegen_v0_1
                [DEBUG] [javascripts] - found Script: kodi_licht_v0_1
                [DEBUG] [javascripts] - found Script: schriftleuchte_v0_2
                [DEBUG] [javascripts] - found Script: weckzeit_daniel
                [DEBUG] [javascripts] - found Script: kamera_ueberwachung
                [DEBUG] [javascripts] - found Script: reboot_skript
                [DEBUG] [javascripts] - found Script: system_ctr_vis
                [DEBUG] [javascripts] - found Script: esx_nuc
                [DEBUG] [javascripts] - found Script: PV
                [DEBUG] [javascripts] - found Script: PV_new
                [DEBUG] [javascripts] - found Script: #no-need_rolladen_beamer_v0_3
                [DEBUG] [javascripts] - found Script: rolladen_verdunkelung_v0_1
                [DEBUG] [javascripts] - found Script: briefkasten_tuerklingel_v0_1
                [DEBUG] [javascripts] - found Script: echo_stati
                [DEBUG] [javascripts] - found Script: ccu
                [DEBUG] [javascripts] - found Script: motioneye
                [DEBUG] [javascripts] - found Script: nut-server
                [DEBUG] [javascripts] - found Script: omv
                [DEBUG] [javascripts] - found Script: pihole
                [DEBUG] [javascripts] - found Script: raspberry-matic
                [DEBUG] [javascripts] - found Script: sophos
                [DEBUG] [javascripts] - found Script: vu_wohnzimmer
                [DEBUG] [javascripts] - found Script: Klima-Wohnzimmer
                [DEBUG] [javascripts] - found Script: RGB
                [DEBUG] [javascripts] - found Script: shutdown_WinNAS_v01
                [DEBUG] [javascripts] - found Script: lichterkette_flur_v0_3
                [DEBUG] [javascripts] - found Script: lichtkugeln_v0_2
                [DEBUG] [javascripts] - found Script: usv_shutdown
                [DEBUG] [javascripts] - found Script: hm_meldungen_neu
                [DEBUG] [javascripts] - found Script: logs_vis_neu
                [DEBUG] [javascripts] - found Script: sonoff_tabelle_6_spalten
                [DEBUG] [javascripts] - found Script: sonoff_tabelle_8_spalten
                [DEBUG] [javascripts] - found Script: bahn_verspaetungen
                [DEBUG] [javascripts] - found Script: anwesenheit
                [DEBUG] [javascripts] - found Script: remote_abfragen
                [DEBUG] [javascripts] - found Script: Rolladen
                [DEBUG] [javascripts] - found Script: harmony_schaltung_v0_4
                [DEBUG] [javascripts] - found Script: vis_status
                [DEBUG] [javascripts] - found Script: alexa_benachrichtigungen
                [DEBUG] [javascripts] - found Script: #zeiten_v01
                [DEBUG] [javascripts] - found Script: solarweb_abfrage
                [DEBUG] [javascripts] - found Script: adapter_starten_stoppen
                [DEBUG] [javascripts] - found Script: staubsauger_v0_3
                [DEBUG] [javascripts] - found Script: benachrichtigungen_v0_2
                [DEBUG] [javascripts] - found Script: bewasserung_sonoff
                [DEBUG] [javascripts] - found Script: bewaesserung
                [DEBUG] [javascripts] - found Script: rolladen_tag_nacht
                [DEBUG] [javascripts] - found Script: bewaesserung_neu_1
                [DEBUG] [javascripts] - found Script: battery
                [DEBUG] [javascripts] - found Script: userdata_wrong
                [DEBUG] [javascripts] - found Script: DWD-UWZ-NINA-Pushwarnungen
                [DEBUG] [javascripts] - found Script: tablet
                [DEBUG] [javascripts] - found Script: wer_schaltet_DP
                [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "C:/ioBroker/backups/tmpScripts"
                [DEBUG] [javascripts] - Javascript tmp directory "C:/ioBroker/backups/tmpScripts" successfully deleted
                [DEBUG] [javascripts] - Backup created: C:\ioBroker\backups\javascripts_2023_04_08-13_33_46_backupiobroker.tar.gz
                [DEBUG] [javascripts] - done
                [DEBUG] [googledrive] - Google Drive: Copy iobroker_2023_04_08-13_33_34_backupiobroker.tar.gz...
                [DEBUG] [drive] start with {"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"deleteBackupAfter":0}
                [DEBUG] [googledrive] - Google Drive: Copy javascripts_2023_04_08-13_33_46_backupiobroker.tar.gz...
                [DEBUG] [googledrive] - done
                [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                [DEBUG] [clean] - done
                [DEBUG] [email] - [iobroker] used E-Mail-Instance: email.0
                [DEBUG] [email] - done
                [DEBUG] [email] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                [DEBUG] [historyHTML] - new history html values created
                [DEBUG] [historyHTML] - done
                [DEBUG] [historyJSON] - new history json values created
                [DEBUG] [historyJSON] - done
                [DEBUG] [historyHTML] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                [DEBUG] [historyJSON] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                [EXIT] 0
                simatecS 2 Antworten Letzte Antwort
                  @simatec
                  Backitup
                  System sichern…
                  info
                  storage
                  Google Drive
                  backup
                  Javascript
                  Systemsicherung
                  Wiederherstellen
                  Lokal
                  Sicherungsquelle
                  [EXIT] 0
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #2342
                  @maximal1981 sagte in Test Adapter ioBroker.backitup v2.6.x:
                  Nächste ioBroker Sicherung: 09. April 2023 um 02:40 Uhr
                  Ändere die Zeit auf was krummes wie 2:17 Uhr.
                  Google ist immer zu den Standardzeit gut ausgelastet, was zu Problemen führen kann
                    @simatec
                    Backitup
                    System sichern…
                    info
                    storage
                    Google Drive
                    backup
                    Javascript
                    Systemsicherung
                    Wiederherstellen
                    Lokal
                    Sicherungsquelle
                    [EXIT] 0
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #2343
                    @maximal1981 Alternativ nimm ne andere Cloud wie Dropbox oder Onedrive
                    • C Offline
                      cbrocker
                      #2344
                      ich bin gerade auch mit einem Problem bei Backup bzw. Restore auf ein neues System beschäftigt.
                      Darf ich mich hier anhängen oder soll ich einen neuen Thread aufmachen?
                      Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
                      • C cbrocker
                        #2345
                        @cbrocker sagte in Test Adapter ioBroker.backitup v2.6.x:
                        Vermutlich die ubersichtlichere Variante.
                        C 1 Antwort Letzte Antwort
                          cbrocker
                          #2346
                          @thomas-braun ja, wenn ich sehe, hier schon 2345 Einträge...
                          mache ich. danke
                          • simatecS simatec
                            maximal1981
                            #2347
                            @simatec
                            habe Zeit abgeändert, zusätzlich mal onedrive aktiviert und werde es weiter verfolgen.
                            aber trotzdem dürfte das backup nicht anhalten/einfrieren oder was auch immer, sondern einen Fehler bringen, da bei mir nach dem nicht abgelegten backup 05. April nicht mehr lief, jedoch nächste Sicherung immer korrekt angezeigt wird.
                              @simatec
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #2348
                              @maximal1981 Das Backup wurde erstellt und konnte halt nicht in Google Drive abgelegt werden, da Google nicht erreichbar war
                              • simatecS simatec
                                maximal1981
                                #2349
                                @simatec aber die nächsten Tage nicht mehr.
                                wenn zumindest lokale Sicherungen erstellt worden wären die nächsten Tage, und Fehler im Log vorhanden wären.
                                Kann es sein, dass das backup dann mit dem Upload auf "ewig" hochladet und kein neues gestartet wird?
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #2350
                                  @maximal1981 Dafür benötige ich den vollständigen debuglog vom Backupprozess.
                                  Ansonsten ist es in die Glaskugel schauen
                                  • simatecS simatec
                                    iob backup
                                    David G.D Online
                                    David G.D Online
                                    David G.
                                    #2351
                                    @simatec sagte in Test Adapter ioBroker.backitup v2.6.x:
                                    iob backup
                                    Jetzt läuft er wieder nicht
                                    pi@pi:~ $ iob backup
                                    host.pi 24211 states saved
                                    host.pi 26491 objects saved
                                    /usr/bin/iob: line 10: 10346 Killed                  sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                    pi@pi:~ $
                                    Die "10346" ändert sich bei jeden Versuch. Aber immer etwas nach oben.
                                    Mache jetzt grade erstmal nichts. Kein fix, reboot etc.
                                      iob backup
                                      pi@pi:~ $
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #2352
                                      @david-g So jetzt gehen wir mal in eine andere Richtung.
                                      So wie ich vermute, könnte dir beim Backup der RAM ausgehen.
                                      Wie groß sind deine iobroker Backups?
                                      • simatecS simatec
                                        David G.D Online
                                        David G.D Online
                                        David G.
                                        #2353
                                        @simatec
                                        32mb
                                        So alle 2 Tage startet der iob willkürlich von selber neu.
                                        Hab noch nicht rausgefunden warum. Das siehst man da, wo der RAM einmal runter geht.
                                        Testhalber ein paar Instanzen deaktivieren und nochmal testen?
                                        Grad eben ist es nochmal gelaufen.
                                          @simatec
                                          32mb
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #2354
                                          @david-g
                                          Da musst du mal schauen, was da soviel RAM frisst.
                                          Wenn du wieder den Fehler bekommst beim Backup über cli, fahre mal dein iobroker runter bzw. Stoppe ihn und versuche das Backup erneut.
                                          Des Weiteren würde ich dich bitten zu dem Thema mal ein separaten Thread aufzumachen.
                                          Hier geht es um Tests des Adapters und nicht um spezifische Probleme, die nicht in Verbindung mit dem Adapter stehen
