  4. Test Adapter radar2 v1.2.x GitHub
radar2 adapter
244 Beiträge 49 Kommentatoren 54.8k Aufrufe 42 Beobachtet
  • lobomauL lobomau
    @a1development I don`t understand how it works. BT has not such a long range!? Does it only work together with Samsung and the SmartThings-App?
    a1development
    #141
    @lobomau i know.
    I was surprised when it showed up in ioBroker under radar2.0_uBTs List of unknown BT devices.
    I tested it in my house and placed it as far apart as possible ( one level down into the basement in the farest corner that i can think of ) and it still picks it up.
    The Gigaset Keeper Tag does lose its connection on the same level about 10-12m away from the BT dongle that is used for radar2.
    Not sure what Samsung is doing there, but to me this looks very promising. BUT with the rolling BT addresses, it s no use for radar2.
      a1development
      #142
      OK. I switched to "Tile Pro" BT Beacons. I did some tests and compared to the Gigaset Gatekeeper, they are working alot further.
      Axel KoenekeA 1 Antwort Letzte Antwort
      • A a1development
        Axel KoenekeA Offline
        Axel Koeneke
        #143
        Moin, ich habe den Adapter neu installiert nachdem ich von Pi4 auf Proxmox umgestiegen bin.
        Er hat auch schon mal gelaufen aber seit dem letzten reboot ist der Adapter nur noch rot.
        FYI: Es läuft ein Pihole auf einer anderen VM.
        Ich habe mal gelesen das es Probleme mit DNS gäbe, diese sollte aber doch inzwischen behoben sein, oder?
        radar2.0	2021-03-08 08:39:13.440	info	(18723) Adapter disconnected and stopped with dostop(null) and callback(true)
        radar2.0	2021-03-08 08:39:13.439	info	(18723) Unload adapter now with null
        radar2.0	2021-03-08 08:39:13.394	warn	(18723) Uncaught Exception: bind EACCES 0.0.0.0:67
        radar2.0	2021-03-08 08:39:13.390	error	(18723) Exception-Code: EACCES: bind EACCES 0.0.0.0:67
        radar2.0	2021-03-08 08:39:13.390	error	at processTicksAndRejections (internal/process/task_queues.js:85:21)
        radar2.0	2021-03-08 08:39:13.390	error	at dgram.js:338:20
        radar2.0	2021-03-08 08:39:13.390	error	(18723) Error: bind EACCES 0.0.0.0:67
        radar2.0	2021-03-08 08:39:13.388	error	(18723) uncaught exception: bind EACCES 0.0.0.0:67
        VG
        Axel
        • Axel KoenekeA Axel Koeneke
          VG
          Axel
          crunchipC Abwesend
          crunchipC Abwesend
          #144
          @axel-koeneke sagte in Test Adapter radar2 v1.2.x GitHub:
          Was war der Grund für einen reboot? Update?
          Dann wurde wahrscheinlich node oder bluetooth upgedatet, daher sind danach die setcup Befehle oder iobroker fix auszuführen.
          Axel KoenekeA 2 Antworten Letzte Antwort
            Axel Koeneke
            #145
            @crunchip Danke für die schnelle Antwort. Ich werde es heute Abend testen.
            VG
            Axel
              Axel Koeneke
              #146
              @crunchip sagte in Test Adapter radar2 v1.2.x GitHub:
              Fix hat es gefixt !
                Megawaldi
                #147
                Hallo Leute,
                der Adapter funktioniert soweit gut, aber ich habe noch das Problem das arp-scan nicht läuft.
                Im log:
                Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
                Ich denke ich habe alle probiert:
                sudors von iobroker passt,
                iobroker fix gemacht,
                als iobroker angemeldet -> arp-scan geht ohne passwort
                Nur in iobroker kommt die warning von oben und doArp(false)...
                Vielleicht fällt euch ja noch was ein, was ich probieren kann...
                Grüße
                Megawaldi
                • M Megawaldi
                  Hallo Leute,
                  Im log:
                  Grüße
                  Megawaldi
                  #148
                  @megawaldi
                  apr-scan
                  sudo -u iobroker arp-scan
                  sudo arp-scan
                    @megawaldi
                    apr-scan
                    sudo arp-scan
                    Megawaldi
                    #149
                    Hab ich schon probiert:
                    Auf alle drei Befehle kommt die normale help info von arp-scan.
                    Sollte also ansich laufen? Bin ein bischen ratlos...
                    • M Megawaldi
                      #150
                      @megawaldi
                      Bitte Ein- und Ausgaben vollständig posten und nicht nacherzählen.
                      Der Adapterstart sieht im log file genau wie aus?
                        Megawaldi
                        #151
                        [17:59][martin@xxx:~]$ arp-scan -interface=wlan0
                        Interface: wlan0, type: EN10MB, MAC: e4:5f:01:03:XX:XX, IPv4: 192.168.0.XXX
                        Usage: arp-scan [options] [hosts...]
                        Target hosts must be specified on the command line unless the --file option is
                        given, in which case the targets are read from the specified file instead, or
                        the --localnet option is used, in which case the targets are generated from
                        the network interface IP address and netmask.
                        You will need to be root, or arp-scan must be SUID root, in order to run
                        arp-scan, because the functions that it uses to read and write packets
                        require root privilege.
                        The target hosts can be specified as IP addresses or hostnames. You can also
                        specify the target as IPnetwork/bits (e.g. 192.168.1.0/24) to specify all hosts
                        in the given network (network and broadcast addresses included), or
                        IPstart-IPend (e.g. 192.168.1.3-192.168.1.27) to specify all hosts in the
                        inclusive range, or IPnetwork:NetMask (e.g. 192.168.1.0:255.255.255.0) to
                        specify all hosts in the given network and mask.
                        These different options for specifying target hosts may be used both on the
                        command line, and also in the file specified with the --file option.
                        use "arp-scan --help" for detailed information on the available options.
                        Report bugs or send suggestions at https://github.com/royhills/arp-scan
                        See the arp-scan homepage at https://github.com/royhills/arp-scan
                        [17:59][martin@xxx:~]$ sudo -u iobroker arp-scan -interface=wlan0
                        [sudo] password for martin:
                        [17:59][martin@xxx:~]$ sudo arp-scan -interface=wlan0
                        radar2.0	2021-03-12 16:34:33.724	warn	(2036) Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
                        radar2.0	2021-03-12 16:34:33.541	info	(2036) Connected with '0.0.0.0' for DHCP Scan
                        radar2.0	2021-03-12 16:34:33.043	info	(2036) Will run hcitool-mode and not noble on device [ [Object] ]!
                        radar2.0	2021-03-12 16:34:32.933	info	(2036) Will use l2Ping for BT scans.
                        radar2.0	2021-03-12 16:34:32.916	info	(2036) radar2 initialization started...
                        radar2.0	2021-03-12 16:34:32.494	info	(2036) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.radar2, node: v12.21.0, js-controller: 3.2.16
                        Danach läuft er ohne Fehler und Warnungen bis zum:
                        radar2.0	2021-03-12 16:35:40.088	info	(2036) Adapter initialization finished!
                        Durch.
                        Ich denke das ich das dazwischen aus Datenschutzgründen hier nicht posten will. Ist aber nichts komisches dabei.
                        Danke dir für deine Hilfe Thomas
                        • M Megawaldi
                          Durch.
                          #152
                          @megawaldi sagte in Test Adapter radar2 v1.2.x GitHub:
                          Auf was für Hardware und OS läuft die Geschichte?
                            Megawaldi
                            #153
                            Ist ein raspi 4 mit Ubuntu LTS
                            • M Megawaldi
                              #154
                              @megawaldi
                              Mit Raspberry OS funktioniert das einwandfrei hier.
                              Warum setzt man Ubuntu LTS (Welches Release?) ein und nicht das viel besser an den Pi 4 angepasste Raspberry OS? (Ich hoffe nicht wegen 'des schöneren Desktops')
                                @megawaldi
                                Megawaldi
                                #155
                                Das hat sich so ergeben. Nutze das ganze nur headless und bei raspian ist mir ehrlichgesagt zu viel "müll" dabei für ein server linux.
                                • M Megawaldi
                                  #156
                                  @megawaldi
                                  Der Müll funktioniert aber.
                                    @megawaldi
                                    Megawaldi
                                    #157
                                    Wenn du mir dann bitte mal erzälen kannst, was für einen Einfluss jetzt nen xserver desktop oder nen office auf mein Problem mit arp-scan hat bin ich beeindruckt. Übrigens ist Ubuntu arm auch ein auf nen raspi optimiertes Linux. Das beide also Ubuntu und rasperian nen debian port sind muss ich dir ja ned erklären.
                                    crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                                    • M Megawaldi
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #158
                                      @megawaldi was passiert denn, wenn du setcap einzeln absetzt
                                      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                                      • M Megawaldi
                                        #159
                                        Keinen. Weil ja keines von beidem auf einem Server läuft.
                                        Nee, brauchst du nicht. Das weiß ich. Trotzdem gibt es Unterschiede.
                                          Megawaldi
                                          #160
                                          @crunchip
                                          Geht ohne Probleme ändert aber nix..
                                          [18:39][martin@xxx:~]$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                                          [18:40][martin@xxx:~]$
                                          @Thomas-Braun
                                          Als user iobroker gehts ohne sudo oder Passwort, also wie es sein sollte...
                                          iobroker@xxx:~$ arp-scan -lgq --interface=wlan0
                                          Interface: wlan0, type: EN10MB, MAC: e4:5f:01:03:54:4f, IPv4: 192.168.0.206
                                          Starting arp-scan 1.9.7 with 256 hosts (https://github.com/royhills/arp-scan)
                                          192.168.0.1     2c:3a:fd:9e:xx:xx
                                          192.168.0.2     44:4e:6d:36:xx:xx
                                          192.168.0.100   c4:9d:ed:1a:xx:xx
                                          24 packets received by filter, 0 packets dropped by kernel
                                          Ending arp-scan 1.9.7: 256 hosts scanned in 1.884 seconds (135.88 hosts/sec). 17 responded
