  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
audiid.3myaudiseatskodaskoda connectvolkswagenvw idwe connectwecharge
3.8k Beiträge 463 Kommentatoren 2.3m Aufrufe 409 Beobachtet
  • M Momo1982
    @tombox
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.879 info Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.879 error instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.878 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.878 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.876 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.876 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.876 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.875 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.875 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.874 error Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.874 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.874 error Caught by controller[0]: was compiled against a different Node.js version using
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.873 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.873 error Caught by controller[0]: ^
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.872 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.871 error Caught by controller[0]: internal/modules/cjs/loader.js:1057
    host.RaspberryPi4-IOB 2021-01-25 10:16:01.605 info instance system.adapter.vw-connect.0 started with pid 4741
    tombox
    #641
    @momo1982
    cd /opt/iobroker
    npm install canvas
    M 2 Antworten Letzte Antwort
    • T tombox
      @momo1982
      cd /opt/iobroker
      npm install canvas
      Momo1982
      schrieb am zuletzt editiert von Momo1982
      #642
      @tombox
      Leider hat das nicht wirklich geklappt... Es sind eine Menge Fehlermeldungen aufgetaucht.
      > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.6.1 and node@12.20.1 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
      gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/12.20.1"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
      gyp ERR! System Linux 5.4.51-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v12.20.1
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
      node-pre-gyp ERR! System Linux 5.4.51-v7l+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v12.20.1
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the canvas@2.6.1 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2021-01-25T11_25_55_978Z-debug.log
      Versuche ich, in das Verzeichnis zu kommen, habe ich (auch mit sudo) keine Berechtigung dazu.
      • T tombox
        @momo1982
        cd /opt/iobroker
        npm install canvas
        Momo1982
        #643
        @tombox
        Aber... aus welchen Gründen auch immer, läuft der Adapter jetzt und liefert mir auch Daten... WTF!?
        Vielen Dank also trotzdem für deine Hilfe!
        • M Momo1982
          @tombox
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #644
          @momo1982
          Hinweis , dein ioBroker ist nicht in Ordnung !!
          • GlasfaserG Glasfaser
            @momo1982
            Momo1982
            #645
            @glasfaser
            Was meinst du?
            • D Datensammler
              @tombox
              vielen Dank für die Integration des SEAT-Portals!
              Ich habe den Adapter von guthub installiert, Version 0.0.23
              Funktioniert auch prinzipiell (für SEAT Mii electric) aber ich bekomme nach einger Zeit folgende Fehler:
              vw-connect.1	2021-01-15 10:10:10.095	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.brand:{"val":"Seat","ack":true,"ts":1610701810074,"q":0,"from":"system.adapter.vw-connect.1","user":"system.use
              vw-connect.1	2021-01-15 10:10:10.089	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.requestId:{"val":"MSG-IVWB2193-1610701808811-71805-SES","ack":true,"ts":1610701810071,"q":0,"from":"system.adap
              vw-connect.1	2021-01-15 10:10:10.078	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.systemId:{"val":"XID_APP_SEAT","ack":true,"ts":1610701810069,"q":0,"from":"system.adapter.vw-connect.1","user":
              vw-connect.1	2021-01-15 10:10:10.050	debug	(24236) {"vehicleDataDetail":{"systemId":"XID_APP_SEAT","requestId":"MSG-IVWB2193-1610701808811-71805-SES","brand":"Seat","country":"DE","vin":"XXXXXXXXXXXXXXXXXX","isConnect":true,"isConnectSorglosRea
              vw-connect.1	2021-01-15 10:10:09.565	error	(24236) status update Failed
              vw-connect.1	2021-01-15 10:10:09.564	error	(24236) 429
              vw-connect.1	2021-01-15 10:10:08.945	debug	(24236) {"homeRegion":{"baseUri":{"systemId":"ICTO-10487","content":"https://mal-1a.prd.ece.vwg-connect.com/api"}}}
              vw-connect.1	2021-01-15 10:10:08.892	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.preferredLanguage:{"val":"de","ack":true,"ts":1610701808428,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
              vw-connect.1	2021-01-15 10:10:08.889	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.phoneNumbers:{"val":[{"uuid":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","type":"PHONE_CONTACT_TYPE:MOBILE_GENERAL","number":"+000000
              vw-connect.1	2021-01-15 10:10:08.886	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierValue:{"val":"0ibPp05UQA6sC7pPflbY5MHnz8B","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-conne
              vw-connect.1	2021-01-15 10:10:08.883	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierType:{"val":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-co
              vw-connect.1	2021-01-15 10:10:08.880	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.nickname:{"val":"Muckii","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc
              vw-connect.1	2021-01-15 10:10:08.878	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.salutation:{"val":"SALUTATION:MRS","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.
              vw-connect.1	2021-01-15 10:10:08.875	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.lastName:{"val":"XXXXXXXXXXX","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
              vw-connect.1	2021-01-15 10:10:08.872	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.firstName:{"val":"XXXXXX","ack":true,"ts":1610701808426,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","l
              vw-connect.1	2021-01-15 10:10:08.605	debug	(24236) getHomeRegion
              vw-connect.1	2021-01-15 10:10:08.601	debug	(24236) {"userVehicles":{"vehicle":["XXXXXXXXXXXXXXXXXX"]}}
              vw-connect.1	2021-01-15 10:10:08.301	debug	(24236) "{\"firstName\":\"XXXXXX\",\"lastName\":\"XXXXXXXXXXX\",\"salutation\":\"SALUTATION:MRS\",\"nickname\":\"Muckii\",\"businessIdentifierType\":\"BUSINESS_IDENTIFIER_TYPE:MBB_ID\",\"businessIdent
              vw-connect.1	2021-01-15 10:10:07.870	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":true,"ack":true,"ts":1610701807866,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":1610
              vw-connect.1	2021-01-15 10:10:07.858	debug	(24236) getData
              vw-connect.1	2021-01-15 10:10:07.856	debug	(24236) Login successful
              vw-connect.1	2021-01-15 10:10:07.254	debug	(24236) Error: Invalid protocol: seatconnect:
              vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) {"date":"Fri, 15 Jan 2021 09:10:06 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en-US","expires":"0","loc
              vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) ""
              vw-connect.1	2021-01-15 10:10:06.069	debug	(24236) parsePasswordForm
              vw-connect.1	2021-01-15 10:10:05.562	debug	(24236) parseEmailForm
              vw-connect.1	2021-01-15 10:10:04.606	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":false,"ack":true,"ts":1610701804595,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":161
              vw-connect.1	2021-01-15 10:10:04.603	silly	(24236) States system redis pmessage system.adapter.vw-connect.1.logLevel/system.adapter.vw-connect.1.logLevel:{"val":"silly","ack":true,"ts":1610701804577,"q":0,"from":"system.adapter.vw-connect.1","
              Es sind auch noch andere Meldungen, an die komme ich gerade aber nicht und werde diese posten, wenn diese nochmal auftauchen.
              Die Daten werden dann auch scheinbar nicht aktualisiert.
              Hast Du da einen Tip für mich?
              @fuchs1978: läuft es bei Dir ohne Probleme?
              tombox
              #646
              @datensammler Hast du mit der aktuellen github Version immer noch die probleme?
              • M Momo1982
                @tombox
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR!
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #647
                @momo1982 sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                current user ("pi") does not have ....
                EACCES: permission denied,....
                Einmal schreibst du selber das du Rechteprobleme hast ...
                und ich weiß nicht was du gemacht hast , aber der Fehler " was compiled against a different Node.js version using " geht nicht von alleine weg !
                Einmal den iobroker fix drüberlaufen lassen
                und hiernach würde mal Prüfen :
                Wenn du Probleme hast ,dann schreibe in diesem Thread weiter
                https://forum.iobroker.net/topic/39780/diskussion-zum-howto-nodejs-installation-und-upgrade
                und bitte den LOG in Code-Tags </> setzen !!!!
                  Momo1982
                  #648
                  @glasfaser
                  NodeJS habe ich erst vor kurzem installiert bzw. aktualisiert. Da lieft auch alles problemlos.
                  PI st kein Admin, daher kann ich die Fehlermeldung noch verstehen.
                  Werde nachher mal dex Fix drüber laufen lassen.
                  Danke für den Hinweis mit dem Code-Tag, da wusste ich ned, wie ich des mache. Danke!
                  F 1 Antwort Letzte Antwort
                  • M Momo1982
                    @glasfaser
                    fuchs1978
                    #649
                    Kann man eigentlich irgendwo im Adapter den aktuellen Kilometerstand auslesen?
                    • F fuchs1978
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #650
                      @fuchs1978
                      "53KILOMETER_STATUS",                          52, "0x0101010002"); // 0x0101010002.0x0101010002, distanceCovered
                      • WszeneW Offline
                        WszeneW Offline
                        Wszene
                        #651
                        @tombox
                        Ich wollte mich nochmal bei dir bedanken
                        Du hast hier einen Adapter erschaffen der einfach funktioniert
                        Du solltest für Skoda die App bauen dann würde diese dann auch funktionieren
                        momentan ist es so das die App mich einfach nur noch nervt
                        Aber dank dir brauche ich die App auch nicht mehr
                        Ich kann mir alles was ich benötige in der VIS anzeigen und schalten was ich benötige
                        Und das Schöne ist es funktioniert
                        Nochmal 1000 Dank dafür
                        Meine Hard- & Software:
                        • MSI Cubi 5 10M-049DE mit Proxmox
                        • CC2652P Zigbee Stick
                        • Steckdosen mit Tasmota und Zigbee
                        • Lichtschalter mit Tasmota
                        • IKEA TRÅDFRI Glühbirnen
                        • Aqara Sensoren
                          @fuchs1978
                          fuchs1978
                          #652
                          @glasfaser said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                          @fuchs1978
                          Vielen Dank
                          • WszeneW Wszene
                            Hat vielleicht jemand eine Idee welches Widget ich für folgendes nutzen kann
                            Ich habe mir einen Datenpunkt er stellt welcher bei true ein Blockly auslöst
                            Dieses Blockly startet die Standheizung und sendet mir den Status via Telegram
                            Also Standheizung gestartet / beendet
                            das heist ich möchte mit dem Widget den Datenpunkt schalten
                            Die Anzeige der Icons ob Standheizung an oder aus soll dann aber über einen anderen Datenpunkt gehen
                            Das ist dieser DP "vw-connect.0.XXXXXXXXXXX.remoteStandheizung.climatisationStateReport.remainingClimateTime"
                            Dieser DP zeigt mir die Dauer der Standheizung an
                            Also in meinem Fall läuft er von 30min auf 0
                            Also möchte ich gern bei >=1 mein Icon in grün
                            und bei
                            <1 in rot
                            Hat da zufällig jemand eine Idee?
                            Ich weiss ich könnte der Bilder übereinander legen und bei Sichtbarkeit die Bedingung eingeben aber vieleicht geht es auch mit einem Widget
                            Momo1982
                            #653
                            @wszene
                            wie schaffst du es denn, mit einem Script (Button), die Standheizung zu starten? Ich kann bei mir leider nur die Werte auslesen, aber nicht setzen.
                            Kannst du hier vllt unterstützen?
                            M WszeneW 2 Antworten Letzte Antwort
                            • M Momo1982
                              @wszene
                              Momo1982
                              #654
                              @momo1982 said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                              @wszene
                              Okay, den Button (im Ordner "Remote") habe ich jetzt auch gefunden, jedoch reagiert meine Standheizung darauf leider gar nicht. Jemand eine Idee?
                              • M Momo1982
                                @wszene
                                tombox
                                #655
                                @momo1982 debug log anmachen und mir schicken
                                • T tombox
                                  Momo1982
                                  #656
                                  @tombox anbei das Log via PN.
                                  • M Momo1982
                                    @wszene
                                    WszeneW Offline
                                    WszeneW Offline
                                    Wszene
                                    schrieb am zuletzt editiert von Wszene
                                    #657
                                    @momo1982
                                    Aber sicher doch
                                    Ich habe mir folgende Datenpunkte erstellt
                                    Das ganze habe ich mit diesem Blockly gemacht
                                    bkockly_datenpunkte.txt
                                    Dann schalte ich mir diesem Blockly die Standheizung
                                    blockly_standheizung.txt
                                    Und so sieht das Ganze dann in der VIS aus
                                    Die Belüftung ist nicht an da habe ich noch nichts gemacht aber das sollte genauso funktionieren wie die Standheizung
                                    vis_standheizung.txt
                                    Ich hoffe ich konnte dir und anderen Interessenten damit helfen
                                    • Aqara Sensoren
                                    • M Momo1982
                                      tombox
                                      #658
                                      @momo1982 löschen mal den log und installier via GitHub
                                      • S Sneak-L8
                                        @tombox Die Kommandos (URL) zum Abruf der Fahrdaten. Ich vermute, dass der Abruf funktioniert, wenn man Lang- und Kurzzeitdaten separat abruft, aber der Aufruf "gib mir alles" wohl etwas anderes ("cycle") liefert.
                                        Du gibst in der URL ja den TripType mit (shortTerm, longTerm, cyclic). Ich vermute, dass "cyclic" eben nicht (mehr?) bedeutet, dass alle Daten abgerufen werden sollen, sondern dies ein eigener Typ von Trip-Daten ist. Dann müsste man im Admin einen zusätzlichen Punkt "Zyklisch" mit dem bestehenden Wert "cyclic" und "Alle" mit einem neuen Wert versehen.
                                        Im Adapter müssen dann bei "alle" drei Aufrufe (shortTerm, longTerm und cyclic) ausgeführt werden.
                                        Jetzt wo ich es beschreiben kann, kann ich mir auch vorstellen es zu ändern. Aber frühestens nach Weihnachten. Davor komme ich nicht dazu.
                                        aba320
                                        schrieb am zuletzt editiert von aba320
                                        #659
                                        @sneak-l8 sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                                        Hallo @tombox ich hatte im Dezember schon mal auf die skoda tripfehler hingewiesen.
                                        jetzt hatte skoda mal wieder Wartungsarbeiten und ich möchte danach noch mal auf die Probleme hinweisen.
                                        wenn im adapter "alle" Fahrdaten gewählt wird kommen nur die cyclic
                                        Wie man sieht ist auch die Sortierung nicht nach Datum, das gilt für alle Varianten.
                                        bei long kommen wie erwartet nur long
                                        bei kurz kommen nur die Kurzen aber auch hier ist die Reihenfolge nicht richtig. ich hab den Wagen seit dem 21.jan nicht genutzt . aber dieser Wert liegt auf datensatz 25.
                                        für die screenshots hab ich immer vor der Adapterumstellung alle Tripdata gelöscht. um alle zu haben habe ich am ende aber alle drin gelassen. wie bis vorgestern ändere ich alle paar tage den Adapter und speichere alle daten neu aber das bringst natürlich in den tripdata keine vernünfitge synchrone Struktur...
                                        vielleicht findet Jemand Zeit das mal etwas zu sortieren.
                                        Ansonsten aber bin ich schon mit der Adabpterentwicklung zufrieden und möchte mich dafür bedanken.
                                        HW: Raspimatic 3B+ ;3.69.7.20230506; RPI-RF-MOD
                                        ioBrokermaster auf Raspi 4 8 GB; ioBrokerslave auf Raspi 4 4 GB
                                        • T tombox
                                          Momo1982
                                          #660
                                          @tombox kann ich das problemlos machen? Ich meine, ich habe meine VIS dementsprechend aufgebaut. Bleiben die Datenpunkte die selbe? Oder muss ich da wieder alles mögliche anpassen (VIS und Blockly)?
                                          Wenn das alles problemlos möglich ist, komme ich gerne deinem Vorschlag nach. :)
                                          Vielen Dank schon mal!
