  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • M Momo1982
    @tombox
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.879 info Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.879 error instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.878 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.878 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.877 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.876 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.876 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.876 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.875 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.875 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.874 error Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.874 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.874 error Caught by controller[0]: was compiled against a different Node.js version using
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.873 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.873 error Caught by controller[0]: ^
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.872 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.RaspberryPi4-IOB 2021-01-25 10:16:02.871 error Caught by controller[0]: internal/modules/cjs/loader.js:1057
    host.RaspberryPi4-IOB 2021-01-25 10:16:01.605 info instance system.adapter.vw-connect.0 started with pid 4741
    GlasfaserG Offline
    GlasfaserG Offline
    #640
    @momo1982 sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
    Du hast wohl ein Update von Node gemacht !
    cd /opt/iobroker
    iobroker stop
    npm rebuild
    iobroker start
    EDIT:
    Bitte dein Log in Code-Tags setzten </>
    • M Momo1982
      @tombox
      tombox
      #641
      @momo1982
      cd /opt/iobroker
      npm install canvas
      M 2 Antworten Letzte Antwort
      • T tombox
        @momo1982
        cd /opt/iobroker
        npm install canvas
        Momo1982
        schrieb am zuletzt editiert von Momo1982
        #642
        @tombox
        Leider hat das nicht wirklich geklappt... Es sind eine Menge Fehlermeldungen aufgetaucht.
        > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        node-pre-gyp WARN Pre-built binaries not installable for canvas@2.6.1 and node@12.20.1 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
        node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
        gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/12.20.1"
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
        gyp ERR! configure error
        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
        gyp ERR! System Linux 5.4.51-v7l+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v12.20.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
        node-pre-gyp ERR! System Linux 5.4.51-v7l+
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v12.20.1
        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
        node-pre-gyp ERR! not ok
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.6.1 install script.
        npm ERR!     /root/.npm/_logs/2021-01-25T11_25_55_978Z-debug.log
        Versuche ich, in das Verzeichnis zu kommen, habe ich (auch mit sudo) keine Berechtigung dazu.
        • T tombox
          @momo1982
          cd /opt/iobroker
          npm install canvas
          Momo1982
          #643
          @tombox
          Aber... aus welchen Gründen auch immer, läuft der Adapter jetzt und liefert mir auch Daten... WTF!?
          Vielen Dank also trotzdem für deine Hilfe!
          • M Momo1982
            @tombox
            GlasfaserG Offline
            GlasfaserG Offline
            #644
            @momo1982
            Hinweis , dein ioBroker ist nicht in Ordnung !!
            • GlasfaserG Glasfaser
              @momo1982
              Momo1982
              #645
              @glasfaser
              Was meinst du?
              • D Datensammler
                @tombox
                vielen Dank für die Integration des SEAT-Portals!
                Ich habe den Adapter von guthub installiert, Version 0.0.23
                Funktioniert auch prinzipiell (für SEAT Mii electric) aber ich bekomme nach einger Zeit folgende Fehler:
                vw-connect.1	2021-01-15 10:10:10.095	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.brand:{"val":"Seat","ack":true,"ts":1610701810074,"q":0,"from":"system.adapter.vw-connect.1","user":"system.use
                vw-connect.1	2021-01-15 10:10:10.089	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.requestId:{"val":"MSG-IVWB2193-1610701808811-71805-SES","ack":true,"ts":1610701810071,"q":0,"from":"system.adap
                vw-connect.1	2021-01-15 10:10:10.078	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.systemId:{"val":"XID_APP_SEAT","ack":true,"ts":1610701810069,"q":0,"from":"system.adapter.vw-connect.1","user":
                vw-connect.1	2021-01-15 10:10:10.050	debug	(24236) {"vehicleDataDetail":{"systemId":"XID_APP_SEAT","requestId":"MSG-IVWB2193-1610701808811-71805-SES","brand":"Seat","country":"DE","vin":"XXXXXXXXXXXXXXXXXX","isConnect":true,"isConnectSorglosRea
                vw-connect.1	2021-01-15 10:10:09.565	error	(24236) status update Failed
                vw-connect.1	2021-01-15 10:10:09.564	error	(24236) 429
                vw-connect.1	2021-01-15 10:10:08.945	debug	(24236) {"homeRegion":{"baseUri":{"systemId":"ICTO-10487","content":"https://mal-1a.prd.ece.vwg-connect.com/api"}}}
                vw-connect.1	2021-01-15 10:10:08.892	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.preferredLanguage:{"val":"de","ack":true,"ts":1610701808428,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
                vw-connect.1	2021-01-15 10:10:08.889	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.phoneNumbers:{"val":[{"uuid":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","type":"PHONE_CONTACT_TYPE:MOBILE_GENERAL","number":"+000000
                vw-connect.1	2021-01-15 10:10:08.886	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierValue:{"val":"0ibPp05UQA6sC7pPflbY5MHnz8B","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-conne
                vw-connect.1	2021-01-15 10:10:08.883	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierType:{"val":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-co
                vw-connect.1	2021-01-15 10:10:08.880	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.nickname:{"val":"Muckii","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc
                vw-connect.1	2021-01-15 10:10:08.878	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.salutation:{"val":"SALUTATION:MRS","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.
                vw-connect.1	2021-01-15 10:10:08.875	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.lastName:{"val":"XXXXXXXXXXX","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
                vw-connect.1	2021-01-15 10:10:08.872	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.firstName:{"val":"XXXXXX","ack":true,"ts":1610701808426,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","l
                vw-connect.1	2021-01-15 10:10:08.605	debug	(24236) getHomeRegion
                vw-connect.1	2021-01-15 10:10:08.601	debug	(24236) {"userVehicles":{"vehicle":["XXXXXXXXXXXXXXXXXX"]}}
                vw-connect.1	2021-01-15 10:10:08.301	debug	(24236) "{\"firstName\":\"XXXXXX\",\"lastName\":\"XXXXXXXXXXX\",\"salutation\":\"SALUTATION:MRS\",\"nickname\":\"Muckii\",\"businessIdentifierType\":\"BUSINESS_IDENTIFIER_TYPE:MBB_ID\",\"businessIdent
                vw-connect.1	2021-01-15 10:10:07.870	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":true,"ack":true,"ts":1610701807866,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":1610
                vw-connect.1	2021-01-15 10:10:07.858	debug	(24236) getData
                vw-connect.1	2021-01-15 10:10:07.856	debug	(24236) Login successful
                vw-connect.1	2021-01-15 10:10:07.254	debug	(24236) Error: Invalid protocol: seatconnect:
                vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) {"date":"Fri, 15 Jan 2021 09:10:06 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en-US","expires":"0","loc
                vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) ""
                vw-connect.1	2021-01-15 10:10:06.069	debug	(24236) parsePasswordForm
                vw-connect.1	2021-01-15 10:10:05.562	debug	(24236) parseEmailForm
                vw-connect.1	2021-01-15 10:10:04.606	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":false,"ack":true,"ts":1610701804595,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":161
                vw-connect.1	2021-01-15 10:10:04.603	silly	(24236) States system redis pmessage system.adapter.vw-connect.1.logLevel/system.adapter.vw-connect.1.logLevel:{"val":"silly","ack":true,"ts":1610701804577,"q":0,"from":"system.adapter.vw-connect.1","
                Es sind auch noch andere Meldungen, an die komme ich gerade aber nicht und werde diese posten, wenn diese nochmal auftauchen.
                Die Daten werden dann auch scheinbar nicht aktualisiert.
                Hast Du da einen Tip für mich?
                @fuchs1978: läuft es bei Dir ohne Probleme?
                tombox
                #646
                @datensammler Hast du mit der aktuellen github Version immer noch die probleme?
                • M Momo1982
                  @tombox
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #647
                  current user ("pi") does not have ....
                  EACCES: permission denied,....
                  Einmal schreibst du selber das du Rechteprobleme hast ...
                  und ich weiß nicht was du gemacht hast , aber der Fehler " was compiled against a different Node.js version using " geht nicht von alleine weg !
                  Einmal den iobroker fix drüberlaufen lassen
                  und hiernach würde mal Prüfen :
                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                  Wenn du Probleme hast ,dann schreibe in diesem Thread weiter
                  https://forum.iobroker.net/topic/39780/diskussion-zum-howto-nodejs-installation-und-upgrade
                  und bitte den LOG in Code-Tags </> setzen !!!!
                    Momo1982
                    #648
                    @glasfaser
                    NodeJS habe ich erst vor kurzem installiert bzw. aktualisiert. Da lieft auch alles problemlos.
                    PI st kein Admin, daher kann ich die Fehlermeldung noch verstehen.
                    Werde nachher mal dex Fix drüber laufen lassen.
                    Danke für den Hinweis mit dem Code-Tag, da wusste ich ned, wie ich des mache. Danke!
                    F 1 Antwort Letzte Antwort
                    • M Momo1982
                      @glasfaser
                      fuchs1978
                      #649
                      Kann man eigentlich irgendwo im Adapter den aktuellen Kilometerstand auslesen?
                      • F fuchs1978
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #650
                        @fuchs1978
                        "53KILOMETER_STATUS",                          52, "0x0101010002"); // 0x0101010002.0x0101010002, distanceCovered
                        • WszeneW Offline
                          WszeneW Offline
                          Wszene
                          #651
                          @tombox
                          Ich wollte mich nochmal bei dir bedanken
                          Du hast hier einen Adapter erschaffen der einfach funktioniert
                          Du solltest für Skoda die App bauen dann würde diese dann auch funktionieren
                          momentan ist es so das die App mich einfach nur noch nervt
                          Aber dank dir brauche ich die App auch nicht mehr
                          Ich kann mir alles was ich benötige in der VIS anzeigen und schalten was ich benötige
                          Und das Schöne ist es funktioniert
                          Nochmal 1000 Dank dafür
                          Meine Hard- & Software:
                          • CC2652P Zigbee Stick
                          • Lichtschalter mit Tasmota
                          • IKEA TRÅDFRI Glühbirnen
                          • Aqara Sensoren
                            @fuchs1978
                            fuchs1978
                            #652
                            @glasfaser said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                            @fuchs1978
                            Vielen Dank
                            • WszeneW Wszene
                              Hat vielleicht jemand eine Idee welches Widget ich für folgendes nutzen kann
                              Ich habe mir einen Datenpunkt er stellt welcher bei true ein Blockly auslöst
                              Dieses Blockly startet die Standheizung und sendet mir den Status via Telegram
                              Also Standheizung gestartet / beendet
                              das heist ich möchte mit dem Widget den Datenpunkt schalten
                              Die Anzeige der Icons ob Standheizung an oder aus soll dann aber über einen anderen Datenpunkt gehen
                              Das ist dieser DP "vw-connect.0.XXXXXXXXXXX.remoteStandheizung.climatisationStateReport.remainingClimateTime"
                              Dieser DP zeigt mir die Dauer der Standheizung an
                              Also in meinem Fall läuft er von 30min auf 0
                              Also möchte ich gern bei >=1 mein Icon in grün
                              und bei
                              <1 in rot
                              Hat da zufällig jemand eine Idee?
                              Ich weiss ich könnte der Bilder übereinander legen und bei Sichtbarkeit die Bedingung eingeben aber vieleicht geht es auch mit einem Widget
                              Momo1982
                              #653
                              @wszene
                              wie schaffst du es denn, mit einem Script (Button), die Standheizung zu starten? Ich kann bei mir leider nur die Werte auslesen, aber nicht setzen.
                              Kannst du hier vllt unterstützen?
                              M WszeneW 2 Antworten Letzte Antwort
                              • M Momo1982
                                @wszene
                                Momo1982
                                #654
                                @momo1982 said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                                @wszene
                                Okay, den Button (im Ordner "Remote") habe ich jetzt auch gefunden, jedoch reagiert meine Standheizung darauf leider gar nicht. Jemand eine Idee?
                                • M Momo1982
                                  @wszene
                                  tombox
                                  #655
                                  @momo1982 debug log anmachen und mir schicken
                                  • T tombox
                                    Momo1982
                                    #656
                                    @tombox anbei das Log via PN.
                                    • M Momo1982
                                      @wszene
                                      WszeneW Offline
                                      WszeneW Offline
                                      Wszene
                                      schrieb am zuletzt editiert von Wszene
                                      #657
                                      @momo1982
                                      Aber sicher doch
                                      Ich habe mir folgende Datenpunkte erstellt
                                      Das ganze habe ich mit diesem Blockly gemacht
                                      bkockly_datenpunkte.txt
                                      Dann schalte ich mir diesem Blockly die Standheizung
                                      blockly_standheizung.txt
                                      Und so sieht das Ganze dann in der VIS aus
                                      Die Belüftung ist nicht an da habe ich noch nichts gemacht aber das sollte genauso funktionieren wie die Standheizung
                                      vis_standheizung.txt
                                      Ich hoffe ich konnte dir und anderen Interessenten damit helfen
                                      • Aqara Sensoren
                                      • M Momo1982
                                        tombox
                                        #658
                                        @momo1982 löschen mal den log und installier via GitHub
                                        • S Sneak-L8
                                          @tombox Die Kommandos (URL) zum Abruf der Fahrdaten. Ich vermute, dass der Abruf funktioniert, wenn man Lang- und Kurzzeitdaten separat abruft, aber der Aufruf "gib mir alles" wohl etwas anderes ("cycle") liefert.
                                          Du gibst in der URL ja den TripType mit (shortTerm, longTerm, cyclic). Ich vermute, dass "cyclic" eben nicht (mehr?) bedeutet, dass alle Daten abgerufen werden sollen, sondern dies ein eigener Typ von Trip-Daten ist. Dann müsste man im Admin einen zusätzlichen Punkt "Zyklisch" mit dem bestehenden Wert "cyclic" und "Alle" mit einem neuen Wert versehen.
                                          Im Adapter müssen dann bei "alle" drei Aufrufe (shortTerm, longTerm und cyclic) ausgeführt werden.
                                          Jetzt wo ich es beschreiben kann, kann ich mir auch vorstellen es zu ändern. Aber frühestens nach Weihnachten. Davor komme ich nicht dazu.
                                          aba320
                                          schrieb am zuletzt editiert von aba320
                                          #659
                                          @sneak-l8 sagte in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                                          Hallo @tombox ich hatte im Dezember schon mal auf die skoda tripfehler hingewiesen.
                                          jetzt hatte skoda mal wieder Wartungsarbeiten und ich möchte danach noch mal auf die Probleme hinweisen.
                                          wenn im adapter "alle" Fahrdaten gewählt wird kommen nur die cyclic
                                          Wie man sieht ist auch die Sortierung nicht nach Datum, das gilt für alle Varianten.
                                          bei long kommen wie erwartet nur long
                                          bei kurz kommen nur die Kurzen aber auch hier ist die Reihenfolge nicht richtig. ich hab den Wagen seit dem 21.jan nicht genutzt . aber dieser Wert liegt auf datensatz 25.
                                          für die screenshots hab ich immer vor der Adapterumstellung alle Tripdata gelöscht. um alle zu haben habe ich am ende aber alle drin gelassen. wie bis vorgestern ändere ich alle paar tage den Adapter und speichere alle daten neu aber das bringst natürlich in den tripdata keine vernünfitge synchrone Struktur...
                                          vielleicht findet Jemand Zeit das mal etwas zu sortieren.
                                          Ansonsten aber bin ich schon mit der Adabpterentwicklung zufrieden und möchte mich dafür bedanken.
                                          HW: Raspimatic 3B+ ;3.69.7.20230506; RPI-RF-MOD
                                          ioBrokermaster auf Raspi 4 8 GB; ioBrokerslave auf Raspi 4 4 GB
