  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
    mtbsteve
    #613
    @tombox ich bekomme beim ändern von parametern (egal welche) in der Version 0.23 ständig Fehler:
    vw-connect.0	2021-01-14 14:23:51.378	error	(25033) failed set state targetSOC_pct
    vw-connect.0	2021-01-14 14:23:51.378	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:51.377	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:48.086	error	(25033) failed set state windowHeatingEnabled
    vw-connect.0	2021-01-14 14:23:48.086	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:48.086	error	(25033) 401
    web.0	2021-01-14 14:23:45.349	info	(2015) ==>Connected system.user.admin from ::1
    web.0	2021-01-14 14:23:44.831	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
    vw-connect.0	2021-01-14 14:23:43.411	error	(25033) failed set state targetTemperature_C
    vw-connect.0	2021-01-14 14:23:43.411	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:43.410	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:42.418	error	(25033) failed set state targetTemperature_C
    vw-connect.0	2021-01-14 14:23:42.418	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:42.417	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:42.397	error	(25033) failed set state targetTemperature_C
    vw-connect.0	2021-01-14 14:23:42.397	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:42.396	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:41.381	error	(25033) failed set state targetTemperature_C
    vw-connect.0	2021-01-14 14:23:41.380	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:41.380	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:41.306	error	(25033) failed set state targetTemperature_C
    vw-connect.0	2021-01-14 14:23:41.306	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:41.305	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:40.295	error	(25033) failed set state targetTemperature_C
    vw-connect.0	2021-01-14 14:23:40.295	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:40.294	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:37.954	error	(25033) failed set state targetTemperature_C
    vw-connect.0	2021-01-14 14:23:37.953	error	(25033) "code=401, message=Unauthorized"
    vw-connect.0	2021-01-14 14:23:37.952	error	(25033) 401
    vw-connect.0	2021-01-14 14:23:16.190	info	(25033) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.0, js-controller: 3.1.6
    In der VW ID app funktioniert es einwandfrei. In der Version 0.21 des Adapters konnte ich zumindest die Charging Parameter setzen. Any idea?
    Fahrzeug: ID3, Software 0564
    Danke!
    • M mtbsteve
      Danke!
      tombox
      #614
      @mtbsteve Hast du via github oder normal iobroker 0.23 installiert?
      • T tombox
        mtbsteve
        #615
        @tombox via github
        • M mtbsteve
          @tombox via github
          tombox
          #616
          @mtbsteve Bitte nochmal probieren
          • T tombox
            mtbsteve
            #617
            @tombox gerade die V0.23 neu über github installiert. Die Fehlermeldungen sind anders, das setzen von Parametern geht immer noch nicht:
            vw-connect.0	2021-01-14 16:12:26.437	info	(27115) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.0, js-controller: 3.1.6
            host.stephan-Aspire-A315-53	2021-01-14 16:12:25.186	info	instance system.adapter.vw-connect.0 started with pid 27115
            host.stephan-Aspire-A315-53	2021-01-14 16:11:55.176	info	Restart adapter system.adapter.vw-connect.0 because enabled
            host.stephan-Aspire-A315-53	2021-01-14 16:11:55.176	info	instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
            host.stephan-Aspire-A315-53	2021-01-14 16:11:55.176	error	Caught by controller[1]: undefined
            host.stephan-Aspire-A315-53	2021-01-14 16:11:55.175	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
            vw-connect.0	2021-01-14 16:11:54.666	info	(27070) Terminated (NO_ERROR): Without reason
            vw-connect.0	2021-01-14 16:11:54.666	info	(27070) terminating
            vw-connect.0	2021-01-14 16:11:54.571	info	(27070) cleaned everything up...
            vw-connect.0	2021-01-14 16:11:54.571	error	(27070) unhandled promise rejection: undefined
            vw-connect.0	2021-01-14 16:11:54.571	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            vw-connect.0	2021-01-14 16:11:54.570	error	(27070) 400
            vw-connect.0	2021-01-14 16:11:54.341	error	(27070) failed set state targetTemperature_C
            vw-connect.0	2021-01-14 16:11:54.340	error	(27070) Refresh Token
            vw-connect.0	2021-01-14 16:11:54.340	error	(27070) "code=401, message=Unauthorized"
            vw-connect.0	2021-01-14 16:11:54.339	error	(27070) 401
            web.0	2021-01-14 16:11:34.654	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
            web.0	2021-01-14 16:11:30.757	info	(2015) ==>Connected system.user.admin from ::1
            web.0	2021-01-14 16:11:30.318	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
            web.0	2021-01-14 16:11:24.563	info	(2015) ==>Connected system.user.admin from ::1
            web.0	2021-01-14 16:11:23.744	info	(2015) <==Disconnect system.user.admin from ::1 vis.0
            vw-connect.0	2021-01-14 16:09:23.257	info	(27070) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.0, js-controller: 3.1.6
            host.stephan-Aspire-A315-53	2021-01-14 16:09:21.938	info	instance system.adapter.vw-connect.0 started with pid 27070
            host.stephan-Aspire-A315-53	2021-01-14 16:08:51.931	info	Restart adapter system.adapter.vw-connect.0 because enabled
            • M mtbsteve
              @tombox ja super!! Folgendes ist mir gerade aufgefallen:
              1. der jeweils letzte Ladevorgang unter wecharge/homecharging/records ist leer.
              2. unter wecharge/chargeandpay sehe ich keine Einträge - hier hätte ich meine Ladevorgänge an öffentlichen Ladestationen erwartet (?)
              tombox
              #618
              @mtbsteve die chargeandpay einträge sind jetzt drin. Aktuelle session sollte unter:
              vw-connect.0.wecharge.homecharging.stations.xxxx... sein
              • GlasfaserG Offline
                GlasfaserG Offline
                #619
                @wszene said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                Ich bekomme jetzt verdammt viele Telegrams
                Nimm das :
                 <variables>
                   <variable id="$ZBG[fEIeDUoMc{ekk0/">sperre</variable>
                 </variables>
                 <block type="variables_set" id="@r$S6|53Lf^0!A`830mY" x="38" y="38">
                   <field name="VAR" id="$ZBG[fEIeDUoMc{ekk0/">sperre</field>
                   <value name="VALUE">
                     <block type="logic_boolean" id="A(URtf8zPanx0N_tk}FI">
                     </block>
                   </value>
                   <next>
                     <block type="on" id="}ZWON=|p^MkmJ,t;Ap!s">
                       <field name="OID">0_userdata.0.1</field>
                       <statement name="STATEMENT">
                         <block type="controls_if" id="w=%`ceyfS!J-,|8wzey=">
                           <value name="IF0">
                             <block type="logic_operation" id="pY@4UwU%iWFRrT5*]o7G">
                               <field name="OP">AND</field>
                               <value name="A">
                                 <block type="logic_compare" id="GT{^i}l+r*[@AC~phuua">
                                   <field name="OP">GTE</field>
                                   <value name="A">
                                     <block type="on_source" id="2i}B._Ao**P{xtuc)0RI">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="8qi:NO(LFv@}rT%@j5%}">
                                       <field name="NUM">1</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id="E-jEsb@oM@h7Z^xhuIMi">
                                   <field name="OP">EQ</field>
                                   <value name="A">
                                     <block type="variables_get" id="n3ZbxZpr~uaaW]Gubt.W">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_boolean" id="zf)OZe*6~Oqnj^whmW;B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <statement name="DO0">
                             <block type="variables_set" id="8oR4HfM?9T{va4@4QKDS">
                                 <block type="logic_boolean" id="oW9;zQH2T2:[#m]T[kVa">
                                 </block>
                               </value>
                               <next>
                                 <block type="telegram" id="|){3Af,jNedzEwOJHER+">
                                   <field name="INSTANCE">.4</field>
                                   <field name="LOG"></field>
                                   <value name="MESSAGE">
                                     <shadow type="text" id="KKV2~AWrAtL]kgg*o(?$">
                                       <field name="TEXT">an</field>
                                     </shadow>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <value name="IF1">
                             <block type="logic_operation" id=":)HRy=h%s-pB=GQDdA{B">
                               <value name="A">
                                 <block type="logic_compare" id="*2=1[f8*{)J%mxg3Pzb|">
                                   <field name="OP">LT</field>
                                   <value name="A">
                                     <block type="on_source" id="RQ_auc-o-ZPNHl60k]^Y">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="6VM?nZ8jDgdtX~V@tBp=">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id="x0)Cj$@EHlj7w*(6h1mF">
                                   <value name="A">
                                     <block type="variables_get" id="cp{E)9ngNElflcok06V!">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_boolean" id=".P_eTp,k:VASHWHwX@!l">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <statement name="DO1">
                             <block type="variables_set" id="^9pP@/8Ws!Mpds3oa.Og">
                                 <block type="logic_boolean" id="Xrq9Ph8Q}S]]q_v54}4]">
                                 </block>
                               </value>
                               <next>
                                 <block type="telegram" id="`vI[nCh/lt{IX4p/fIYg">
                                     <shadow type="text" id="~fM,TqT#){`|eAhf+Iwk">
                                       <field name="TEXT">aus</field>
                                     </shadow>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
                </xml>
                WszeneW 1 Antwort Letzte Antwort
                • GlasfaserG Glasfaser
                  Nimm das :
                   <variables>
                   </variables>
                       </block>
                     </value>
                     <next>
                             <value name="IF0">
                                 <value name="A">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                                   </block>
                                 </value>
                                 <next>
                                       </shadow>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                             <value name="IF1">
                                 <value name="A">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                                   </block>
                                 </value>
                                 <next>
                                       </shadow>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                  </xml>
                  WszeneW Offline
                  WszeneW Offline
                  Wszene
                  #620
                  @glasfaser
                  Danke dir das sieht gut aus aber ich habe da mal noch eine Frage
                  Was ist Sperre?
                  Muss ich da noch etwas anlegen?
                  Meine Hard- & Software:
                  • CC2652P Zigbee Stick
                  • Lichtschalter mit Tasmota
                  • IKEA TRÅDFRI Glühbirnen
                  • Aqara Sensoren
                  • WszeneW Wszene
                    @glasfaser
                    Was ist Sperre?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #621
                    @wszene
                    Es wird eine Variable genutzt , Sie wird beim Triggern deines Datenpunktes bei true (Telegram Heizung an) einmalig gesetzt .
                    Bei dem wiederholten triggern was bei dir ist ,wird halt die Funktion nicht mehr ausgeführt (Telegram senden Heizung an) , da die Variable auf false gesetzt ist ......
                    du kannst es so importieren , es wird alles automatisch angelegt .
                    • T tombox
                      @fuchs1978 Ich habe Seat zum Adapter hinzugefügt
                      Datensammler
                      #622
                      @tombox
                      vielen Dank für die Integration des SEAT-Portals!
                      Ich habe den Adapter von guthub installiert, Version 0.0.23
                      Funktioniert auch prinzipiell (für SEAT Mii electric) aber ich bekomme nach einger Zeit folgende Fehler:
                      vw-connect.1	2021-01-15 10:10:10.095	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.brand:{"val":"Seat","ack":true,"ts":1610701810074,"q":0,"from":"system.adapter.vw-connect.1","user":"system.use
                      vw-connect.1	2021-01-15 10:10:10.089	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.requestId:{"val":"MSG-IVWB2193-1610701808811-71805-SES","ack":true,"ts":1610701810071,"q":0,"from":"system.adap
                      vw-connect.1	2021-01-15 10:10:10.078	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.XXXXXXXXXXXXXXXXXX.general.systemId:{"val":"XID_APP_SEAT","ack":true,"ts":1610701810069,"q":0,"from":"system.adapter.vw-connect.1","user":
                      vw-connect.1	2021-01-15 10:10:10.050	debug	(24236) {"vehicleDataDetail":{"systemId":"XID_APP_SEAT","requestId":"MSG-IVWB2193-1610701808811-71805-SES","brand":"Seat","country":"DE","vin":"XXXXXXXXXXXXXXXXXX","isConnect":true,"isConnectSorglosRea
                      vw-connect.1	2021-01-15 10:10:09.565	error	(24236) status update Failed
                      vw-connect.1	2021-01-15 10:10:09.564	error	(24236) 429
                      vw-connect.1	2021-01-15 10:10:08.945	debug	(24236) {"homeRegion":{"baseUri":{"systemId":"ICTO-10487","content":"https://mal-1a.prd.ece.vwg-connect.com/api"}}}
                      vw-connect.1	2021-01-15 10:10:08.892	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.preferredLanguage:{"val":"de","ack":true,"ts":1610701808428,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
                      vw-connect.1	2021-01-15 10:10:08.889	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.phoneNumbers:{"val":[{"uuid":"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx","type":"PHONE_CONTACT_TYPE:MOBILE_GENERAL","number":"+000000
                      vw-connect.1	2021-01-15 10:10:08.886	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierValue:{"val":"0ibPp05UQA6sC7pPflbY5MHnz8B","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-conne
                      vw-connect.1	2021-01-15 10:10:08.883	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.businessIdentifierType:{"val":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-co
                      vw-connect.1	2021-01-15 10:10:08.880	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.nickname:{"val":"Muckii","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc
                      vw-connect.1	2021-01-15 10:10:08.878	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.salutation:{"val":"SALUTATION:MRS","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.
                      vw-connect.1	2021-01-15 10:10:08.875	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.lastName:{"val":"XXXXXXXXXXX","ack":true,"ts":1610701808427,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin
                      vw-connect.1	2021-01-15 10:10:08.872	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.personal.firstName:{"val":"XXXXXX","ack":true,"ts":1610701808426,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","l
                      vw-connect.1	2021-01-15 10:10:08.605	debug	(24236) getHomeRegion
                      vw-connect.1	2021-01-15 10:10:08.601	debug	(24236) {"userVehicles":{"vehicle":["XXXXXXXXXXXXXXXXXX"]}}
                      vw-connect.1	2021-01-15 10:10:08.301	debug	(24236) "{\"firstName\":\"XXXXXX\",\"lastName\":\"XXXXXXXXXXX\",\"salutation\":\"SALUTATION:MRS\",\"nickname\":\"Muckii\",\"businessIdentifierType\":\"BUSINESS_IDENTIFIER_TYPE:MBB_ID\",\"businessIdent
                      vw-connect.1	2021-01-15 10:10:07.870	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":true,"ack":true,"ts":1610701807866,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":1610
                      vw-connect.1	2021-01-15 10:10:07.858	debug	(24236) getData
                      vw-connect.1	2021-01-15 10:10:07.856	debug	(24236) Login successful
                      vw-connect.1	2021-01-15 10:10:07.254	debug	(24236) Error: Invalid protocol: seatconnect:
                      vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) {"date":"Fri, 15 Jan 2021 09:10:06 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en-US","expires":"0","loc
                      vw-connect.1	2021-01-15 10:10:06.503	debug	(24236) ""
                      vw-connect.1	2021-01-15 10:10:06.069	debug	(24236) parsePasswordForm
                      vw-connect.1	2021-01-15 10:10:05.562	debug	(24236) parseEmailForm
                      vw-connect.1	2021-01-15 10:10:04.606	silly	(24236) States user redis pmessage vw-connect.1.*/vw-connect.1.info.connection:{"val":false,"ack":true,"ts":1610701804595,"q":0,"from":"system.adapter.vw-connect.1","user":"system.user.admin","lc":161
                      vw-connect.1	2021-01-15 10:10:04.603	silly	(24236) States system redis pmessage system.adapter.vw-connect.1.logLevel/system.adapter.vw-connect.1.logLevel:{"val":"silly","ack":true,"ts":1610701804577,"q":0,"from":"system.adapter.vw-connect.1","
                      Es sind auch noch andere Meldungen, an die komme ich gerade aber nicht und werde diese posten, wenn diese nochmal auftauchen.
                      Die Daten werden dann auch scheinbar nicht aktualisiert.
                      Hast Du da einen Tip für mich?
                      @fuchs1978: läuft es bei Dir ohne Probleme?
                      D T 2 Antworten Letzte Antwort
                      • T tombox
                        @aba320 Einfach mal nochmal via github installieren und nochmal testen
                        aba320
                        schrieb am zuletzt editiert von aba320
                        #623
                        @tombox Hallo hab gestern spät abend nochmal auf 23 via git update durchgeführt. es kommen alle 54 Minuten die Fehlermeldungen:
                        vw-connect.0	2021-01-15 10:33:07.091	info	(5958) starting. Version 0.0.23 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.20.1, js-controller: 3.1.6
                        host.raspberrypiiobroker	2021-01-15 10:33:03.199	info	instance system.adapter.vw-connect.0 started with pid 5958
                        host.raspberrypiiobroker	2021-01-15 10:33:00.681	info	instance system.adapter.vw-connect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        vw-connect.0	2021-01-15 10:33:00.092	info	(23070) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        vw-connect.0	2021-01-15 10:33:00.090	info	(23070) terminating
                        vw-connect.0	2021-01-15 10:33:00.089	info	(23070) cleaned everything up...
                        vw-connect.0	2021-01-15 10:33:00.088	info	(23070) Got terminate signal TERMINATE_YOURSELF
                        host.raspberrypiiobroker	2021-01-15 10:33:00.079	info	stopInstance system.adapter.vw-connect.0 send kill signal
                        host.raspberrypiiobroker	2021-01-15 10:33:00.073	info	stopInstance system.adapter.vw-connect.0 (force=false, process=true)
                        host.raspberrypiiobroker	2021-01-15 10:32:29.739	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                        host.raspberrypiiobroker	2021-01-15 10:30:20.788	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                        ical.1	2021-01-15 10:30:20.264	info	(3530) Terminated (NO_ERROR): Without reason
                        host.raspberrypiiobroker	2021-01-15 10:30:17.142	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.raspberrypiiobroker	2021-01-15 10:30:15.847	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        ical.1	2021-01-15 10:30:15.204	info	(3530) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                        ical.1	2021-01-15 10:30:14.690	info	(3530) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.1, js-controller: 3.1.6
                        host.raspberrypiiobroker	2021-01-15 10:30:12.334	info	instance system.adapter.ical.1 started with pid 3530
                        host.raspberrypiiobroker	2021-01-15 10:30:10.074	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                        host.raspberrypiiobroker	2021-01-15 10:30:08.091	info	instance system.adapter.dwd.1 started with pid 3514
                        host.raspberrypiiobroker	2021-01-15 10:30:04.066	info	instance system.adapter.dwd.0 started with pid 3353
                        host.raspberrypiiobroker	2021-01-15 10:30:00.041	info	instance system.adapter.daswetter.0 started with pid 3334
                        vw-connect.0	2021-01-15 10:29:34.142	error	(23070) Failed relogin
                        vw-connect.0	2021-01-15 10:29:34.141	error	(23070) Error: Invalid protocol: skodaconnect:
                        vw-connect.0	2021-01-15 10:29:34.139	error	(23070) Failed in first login step
                        vw-connect.0	2021-01-15 10:29:33.047	error	(23070) Relogin
                        vw-connect.0	2021-01-15 10:29:33.046	error	(23070) 400
                        vw-connect.0	2021-01-15 10:29:33.046	error	(23070) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
                        vw-connect.0	2021-01-15 10:29:33.035	error	(23070) VwToken
                        host.raspberrypiiobroker	2021-01-15 10:15:16.285	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                        host.raspberrypiiobroker	2021-01-15 10:15:12.761	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.raspberrypiiobroker	2021-01-15 10:15:09.351	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.raspberrypiiobroker	2021-01-15 10:15:08.135	info	instance system.adapter.daswetter.0 started with pid 22655
                        host.raspberrypiiobroker	2021-01-15 10:15:04.086	info	instance system.adapter.dwd.0 started with pid 22640
                        host.raspberrypiiobroker	2021-01-15 10:15:00.040	info	instance system.adapter.dwd.1 started with pid 22620
                        host.raspberrypiiobroker	2021-01-15 10:00:21.104	info	instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                        ical.1	2021-01-15 10:00:20.584	info	(10006) Terminated (NO_ERROR): Without reason
                        host.raspberrypiiobroker	2021-01-15 10:00:15.932	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        ical.1	2021-01-15 10:00:15.531	info	(10006) processing URL: termine https://calendar.google.com/calendar/ical/dqk5mocnel98rb8s49b8dbppns%40group.calendar.google.com/private-8619eac97e9958684b0dc5575e2bd118/basic.ics
                        ical.1	2021-01-15 10:00:15.084	info	(10006) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.20.1, js-controller: 3.1.6
                        host.raspberrypiiobroker	2021-01-15 10:00:14.986	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.raspberrypiiobroker	2021-01-15 10:00:12.462	info	instance system.adapter.ical.1 started with pid 10006
                        host.raspberrypiiobroker	2021-01-15 10:00:08.856	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                        host.raspberrypiiobroker	2021-01-15 10:00:08.091	info	instance system.adapter.dwd.1 started with pid 9844
                        host.raspberrypiiobroker	2021-01-15 10:00:04.067	info	instance system.adapter.dwd.0 started with pid 9825
                        host.raspberrypiiobroker	2021-01-15 10:00:00.043	info	instance system.adapter.daswetter.0 started with pid 9810
                        mqtt.0	2021-01-15 09:52:57.972	info	(1355) Client [MqttClient] connection closed: closed
                        mqtt.0	2021-01-15 09:52:57.788	info	(1355) Client [MqttClient] connected with secret 1610700777784_5720
                        host.raspberrypiiobroker	2021-01-15 09:45:15.974	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                        host.raspberrypiiobroker	2021-01-15 09:45:12.952	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.raspberrypiiobroker	2021-01-15 09:45:10.869	info	instance system.adapter.dwd.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.raspberrypiiobroker	2021-01-15 09:45:08.131	info	instance system.adapter.daswetter.0 started with pid 29210
                        host.raspberrypiiobroker	2021-01-15 09:45:04.078	info	instance system.adapter.dwd.0 started with pid 29191
                        host.raspberrypiiobroker	2021-01-15 09:45:00.038	info	instance system.adapter.dwd.1 started with pid 29029
                        vw-connect.0	2021-01-15 09:35:34.117	error	(23070) Failed relogin
                        vw-connect.0	2021-01-15 09:35:34.115	error	(23070) Error: Invalid protocol: skodaconnect:
                        vw-connect.0	2021-01-15 09:35:34.114	error	(23070) Failed in first login step
                        vw-connect.0	2021-01-15 09:35:33.055	error	(23070) Relogin
                        vw-connect.0	2021-01-15 09:35:33.054	error	(23070) 400
                        vw-connect.0	2021-01-15 09:35:33.054	error	(23070) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
                        vw-connect.0	2021-01-15 09:35:33.046	error	(23070) VwToken
                        adaptereinstellungen wurden nicht geändert und sind:
                        Typ Skoda
                        Update 7 Minuten
                        Spin eingegeben
                        Update erzwingen 0
                        Fahrdaten alle und alle
                        auch schon bei vorgängerversionen kamen alle 54 Minuten Fehler aber es waren nur 2 Zeilen.
                        in objekten werden neben destination, position, remote, status nur die cyclic tripdata erstellt ,
                        wenn der adapter umgestellt wird kommen auch entsprechen die Lang oder kurz Tripwerte.
                        HW: Raspimatic 3B+ ;3.69.7.20230506; RPI-RF-MOD
                        ioBrokermaster auf Raspi 4 8 GB; ioBrokerslave auf Raspi 4 4 GB
                        • D Datensammler
                          @tombox
                          Datensammler
                          #624
                          @datensammler said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                          Ich kann meinen vorherigen Beitrag leider nicht bearbeiten, daher hier die Ergänzung der Fehlermeldungen:
                          host.iobroker	2021-01-15 12:30:23.154	info	instance system.adapter.vw-connect.1 terminated with code 0 (NO_ERROR)
                          vw-connect.1	2021-01-15 12:30:22.604	error	(24696) unhandled promise rejection: undefined
                          vw-connect.1	2021-01-15 12:30:22.603	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          vw-connect.1	2021-01-15 12:30:22.601	error	(24696) Error: Invalid protocol: seatconnect:
                          vw-connect.1	2021-01-15 12:30:22.601	error	(24696) Failed in first login step
                          vw-connect.1	2021-01-15 12:30:21.444	error	(24696) Relogin
                          vw-connect.1	2021-01-15 12:30:21.443	error	(24696) 400
                          vw-connect.1	2021-01-15 12:30:21.443	error	(24696) {"errorCode":"REQUEST_DATA_INVALID","description":"invalid brand or token audience"}
                          vw-connect.1	2021-01-15 12:30:21.438	error	(24696) VwToken
                          vw-connect.1	2021-01-15 11:36:22.913	error	(24696) status update Failed
                          vw-connect.1	2021-01-15 11:36:22.911	error	(24696) 429
                          host.iobroker	2021-01-15 11:36:15.075	info	instance system.adapter.vw-connect.1 started with pid 24696
                          • D Datensammler
                            tombox
                            #625
                            @datensammler
                            Fehler 429 wurden zuviele Requests gesendet. Du musst das Auto einmal starten
                            • T tombox
                              mtbsteve
                              #626
                              @tombox funktioniert! Danke!!
                              • Tranquility76T Offline
                                Tranquility76
                                #627
                                vielleicht habe ich es bei der Länge des Threads überlesen - wurde schon mal was Richtung Wallbox VW ID Charger Connect/Pro versucht?
                                Das Ding ist auch über die We Connect ID App mit eingebunden, müsste also auch über den Adapter hier erreichbar sein.
                                • Tranquility76T Tranquility76
                                  tombox
                                  #628
                                  @tranquility76 probier mal die aktuellste version
                                  • T tombox
                                    jhg
                                    #629
                                    @tombox Welche Funktionalitäten wurden denn für WeCharge implementiert?
                                    Ist das nur für das Laden zuhause gedacht.
                                    Verstehe es gerade nicht.
                                    T M 2 Antworten Letzte Antwort
                                    • J jhg
                                      tombox
                                      #630
                                      @jhg Alles was in der App We connect ID zum we charge angezeigt wird. die stop funktionalität wurde noch nicht eingebaut
                                      • J jhg
                                        mtbsteve
                                        #631
                                        @jhg unter wecharge.chargeandpay findest du deine WeCharge Tarifdetails und die Ladehistorie an öffentlichen Stationen und unter wechagre.homecharging alle Elli Wallbox Parameter sowie die Ladehistorie an deiner Elli Box.
                                        • M mtbsteve
                                          jhg
                                          #632
                                          @mtbsteve @tombox Danke euch beiden. Da ich bisher noch nicht mit WeCharge geladen habe, ist nichts ersichtlich.
