  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    5.2k
audiid.3myaudiseatskodaskoda connectvolkswagenvw idwe connectwecharge
3.7k Beiträge 461 Kommentatoren 2.1m Aufrufe 413 Beobachtet
  • L lesiflo
    Hi, seit dem Update unseres ID.4 auf die SW Version 3.1 kommen jede Menge von diesen Warnings hier. Jemand eine Idee wie ich die weg bekomme.
    vw-connect.0
    2023-09-21 08:49:20.541	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleWakeUpTrigger" is missing the required property "common.type"
    vw-connect.0
    2023-09-21 08:49:20.493	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleLights" is missing the required property "common.type"
    vw-connect.0
    2023-09-21 08:49:20.445	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleHealthWarnings" is missing the required property "common.type"
    vw-connect.0
    2023-09-21 08:49:20.397	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleHealthInspection" is missing the required property "common.type"
    vw-connect.0
    2023-09-21 08:49:20.352	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.vehicleHealth" is missing the required property "common.type"
    vw-connect.0
    2023-09-21 08:49:20.277	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.state" is missing the required property "common.type"
    vw-connect.0
    2023-09-21 08:49:20.193	warn	Object of state "vw-connect.0.xxxxxxxxxxxxxxxxxxxxx.status.userCapabilities.capabilitiesStatus.value.poiSearch" is missing the required property "common.type"
    Sneak-L8
    #1981
    @lesiflo Das könnte das Problem sein, dass bei Werte-Paaren im JSON intern daraus Einzelwerte gemacht werden.
    Beispiel:
        "userCapabilities": {
            "capabilitiesStatus": {
                "value": [{
                        "id": "webApp",
                        "userDisablingAllowed": false
                        "id": "automation",
                        "userDisablingAllowed": true
    Hier wird de id (webApp, automation) als Key und übernommen und darunter der Wert abgelegt.
    Wenn im Array mehr als 2 Einträge vorkommen, dann werdne sie aber anders beahndelt:
            "value": [{
                    "id": "webApp",
                    "expirationDate": "2052-12-26T23:59:59Z",
                    "id": "automation",
                    "expirationDate": "2023-12-26T00:00:00Z",
    Bei VW kommen aber (meine Erfahrung meist kurz nach Mitternacht) mal zwei und mal drei Werte. Und dadurch kommt es dann zu Fehlern wie
    warn: vw-connect.0 (COMPACT) Object of state "vw-connect.0.WVWZZZE1ZMP035023.status.userCapabilities.capabilitiesStatus.value.webApp" is missing the required property "common.type"
    weil webApp bei 2 Werten als state ud nicht mehr als channel betrachtet wird.
    Das könnte hier auch so ein Problem sein. Wenn sich die Struktur aber "nur" aufgrund des Updates, also dauerhaft, geändert hat, dann könnte es wie von @tombox beschrieben reichen, die vorhandenen Objekte zu löschen.
    Aber ich glaube, es ist (da es bei Dir auch um die capabilities geht) eher das oben beschriebene Problem. Ist damit vermutlich in Kürze weg und tritt sporadisch auf, wenn VW gerade mal wieder nicht die Ablaufdaten der Services kennt.
    • T tombox
      @lesiflo Hast du mal alle objektgelöschte und adapter neugestartet
      lesiflo
      #1982
      @tombox Das hatte das Problem behoben. Danke fürs den Tip.
      • L lesiflo
        SolarMaxe
        schrieb am zuletzt editiert von SolarMaxe
        #1983
        ich habe vom GitHub die Version 0.1.2 installiert.
        Der Adapter funktioniert soweit auch Problemlos für meinen Audi Hybrid.
        Allerdings bekomme ich folgende Fehlermeldung:
        State "vw-connect.0.WAU1234567.remote.climatisationv2" has no existing object, this might lead to an error in future versions
        das Objekt climatisationv2 ist auch im Objekt Baum nicht vorhanden.
        Kennt einer von euch das Problem und kann mir helfen?
          mick70
          #1984
          Folgende Fehlermeldungen exakt alle 30 Minuten, seit heute morgen 7:40:
          vw-connect.0
          2023-09-24 17:40:10.758	error	Refresh Token in 10min
          vw-connect.0
          2023-09-24 17:40:10.758	error	{"error":{"errorCode":"gw.error.unknown","description":"Invalid backend error"}}
          vw-connect.0
          2023-09-24 17:40:10.757	error	401
          vw-connect.0
          2023-09-24 17:40:10.753	error	WVWZZZAUZL89xxxxx
          Der übliche Server-Schluckauf bei VW oder was anderes? Installiert ist 0.1.2 von Github.
          M G 2 Antworten Letzte Antwort
            Schtallone
            #1985
            @mick70
            Moin,
            ich schließe mich an. Habe die selben Meldungen seit ca. 2-3 Tagen...
            • M mick70
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              mick70
              schrieb am zuletzt editiert von mick70
              #1986
              @mick70 Ergänzung: jetzt kommen die Fehlermeldungen (wie angekündigt) im 10 Minuten Abstand alle 20 Minuten.
              Die Datenpunkte scheinen aktuell zu sein, also ist es wohl nicht das übliche Serverproblem. Remotefunktionen kann ich erst heute Nachmittag ausprobieren, bin dzt. zu weit weg vom Auto.
              Fzg.: e-Golf.
              • Hant0rH Offline
                Hant0rH Offline
                Hant0r
                #1987
                Habe das Problem nicht (Skoda) 🤷‍♂️
                • S Schtallone
                  @mick70
                  Moin,
                  SolarMaxe
                  #1988
                  Hab den Fehler seit heute:
                  2023-09-25 15:12:56.358 - error: vw-connect.0 (14492) [{"message":"network timeout at: ","locations":[{"line":10,"column":5}],"path":["userVehicles",0,"userRole"],"extensions":{"code":"INTERNAL_SERVER_ERROR","exception":{"message":"network timeout at: ","type":"request-timeout"}}}]
                  2023-09-25 15:12:56.359 - error: vw-connect.0 (14492) Get Vehicles Failed
                  • M mick70
                    vw-connect.0
                    vw-connect.0
                    vw-connect.0
                    vw-connect.0
                    guitardoc
                    #1989
                    @mick70 said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                    vw-connect.0
                    vw-connect.0
                    vw-connect.0
                    vw-connect.0
                    Ebenso. Bei mir VW Touareg. Das Log ist voll mit dem Fehler...
                    • G guitardoc
                      vw-connect.0
                      vw-connect.0
                      vw-connect.0
                      vw-connect.0
                      tombox
                      #1990
                      @guitardoc bitte v0.1.3 testen
                      G 1 Antwort Letzte Antwort
                      • T tombox
                        guitardoc
                        #1991
                        @tombox said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                        Wo finde ich die Version?
                        • G guitardoc
                          mick70
                          #1992
                          @guitardoc https://github.com/TA2k/ioBroker.vw-connect
                          @tombox Scheint zu funktionieren, bisher keine Meldungen mehr - vielen Dank!
                          • M mick70
                            guitardoc
                            #1993
                            Bei mir auch - funktioniert. Vielen Dank!
                            • G guitardoc
                              guitardoc
                              #1994
                              Es kommen seit heute neue Meldungen:
                              ? 1 Antwort Letzte Antwort
                              • G guitardoc
                                #1995
                                @guitardoc sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                Moin,
                                VW hatte eine IT Störung, es hieß zwar immer, die Produktion sei betroffen, aber hat vielleicht auch Auswirkungen auf andere Systeme.
                                Anscheinend läuft es wieder.
                                https://www.ndr.de/nachrichten/niedersachsen/braunschweig_harz_goettingen/IT-Stoerung-bei-VW-behoben-Produktion-laeuft-weltweit-wieder-an,vw6040.html
                                VG
                                Bernd
                                P.S.: Welche Version vom Adapter und Text bitte nicht als Bild, sondern als Text in Code Tags </>
                                  Moin,
                                  VG
                                  Bernd
                                  mick70
                                  #1996
                                  @dp20eic Den gleichen Fehler hatte ich - ohne backend timeout - mit v 0.1.3 auch, aber nur einmalig heute Nacht um 0:45.
                                  vw-connect.0
                                  2023-09-28 08:00:45.776	error	{"error":{"errorCode":"VSR.technical.9031","description":"Service [TSS] timed out"}}
                                  vw-connect.0
                                  2023-09-28 08:00:45.775	error	504
                                  Könnte dieses Mal tatsächlich serverbezogen sein.
                                  • S SolarMaxe
                                    SolarMaxe
                                    #1997
                                    @solarmaxe sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                    @tombox
                                    den Fehler bekomme ich auch leider mit der neusten Version (v0.1.3) noch
                                      reimai
                                      #1998
                                      Hallo, ich bekomme seit gestern keine Werte mehr von meinem E-Golf.
                                      Habe im Iobroker folgende Fehlermeldung:
                                      vw-connect.0
                                      	2023-09-28 17:22:32.899	error	get personal data Failed
                                      vw-connect.0
                                      	2023-09-28 17:22:32.896	error	Error: getaddrinfo ENOTFOUND customer-profile.apps.emea.vwapps.io
                                      vw-connect.0
                                      	2023-09-28 17:22:32.825	info	Login successful
                                      vw-connect.0
                                      	2023-09-28 17:22:28.450	info	Login in with vw
                                      vw-connect.0
                                      	2023-09-28 17:22:28.380	info	starting. Version 0.0.67 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v16.19.0, js-controller: 4.0.23
                                      Kann mir da jemand helfen?
                                      Danke schön
                                      • R reimai
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        vw-connect.0
                                        Danke schön
                                        tombox
                                        #1999
                                        @reimai beta repo nutzen
                                          reimai
                                          #2000
                                          @tombox
                                          Ich stehe auf dem Schlauch. Was ist das?
                                          Sorry, für mein Unwissen
                                          R 1 Antwort Letzte Antwort
