  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. MegaD 328
    6.3k
MegaD 328
430 Beiträge 28 Kommentatoren 174.5k Aufrufe 2 Beobachtet
  • V Offline
    V Offline
    vtec
    #101
    @Bluefox:
    А что говорит лог? И надеюсь, что драйвера мег, а не вообще все. `
    Как раз все. Но после перезагрузки все ОК. Исследую дальше.
    • V Offline
      V Offline
      vtec
      #102
      @Bluefox:
      А ты что нибудь в Сценарий порта 0 писал? `
      host-cubieboard2	2015-08-21 11:27:36	info	instance system.adapter.megad.0 started with pid 2370
      host-cubieboard2	2015-08-21 11:27:06	info	Restart adapter system.adapter.megad.0 because enabled
      host-cubieboard2	2015-08-21 11:27:06	error	instance system.adapter.megad.0 terminated with code 6 (uncaught exception)
      Error:	2015-08-21 11:27:05	error	at _stream_readable.js:944:16
      Error:	2015-08-21 11:27:05	error	at IncomingMessage.emit (events.js:117:20)
      Error:	2015-08-21 11:27:05	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.megad/main.js:193:13)
      Error:	2015-08-21 11:27:05	error	at writeConfigOne (/opt/iobroker/node_modules/iobroker.megad/main.js:141:16)
      Error:	2015-08-21 11:27:05	error	at /opt/iobroker/node_modules/iobroker.megad/main.js:393:21
      Error:	2015-08-21 11:27:05	error	at writeConfigDevice (/opt/iobroker/node_modules/iobroker.megad/main.js:339:19)
      Error:	2015-08-21 11:27:05	error	at findIp (/opt/iobroker/node_modules/iobroker.megad/main.js:310:21)
      Error:	2015-08-21 11:27:05	error	at ipMask (/opt/iobroker/node_modules/iobroker.megad/main.js:266:12)
      Error:	2015-08-21 11:27:05	error	at ipToBuffer (/opt/iobroker/node_modules/iobroker.megad/main.js:234:15)
      Error:	2015-08-21 11:27:05	error	at Error ()
      Error:	2015-08-21 11:27:05	error	Invalid ip address: undefined
      uncaught	2015-08-21 11:27:05	error	exception: Invalid ip address: undefined
      megad-0	2015-08-21 11:27:05	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:27:04	info	Write config for port 15: http://192.168.0.14/sec/?pn=15&pty=255
      megad-0	2015-08-21 11:27:04	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:27:03	info	Write config for port 14: http://192.168.0.14/sec/?pn=14&pty=255
      megad-0	2015-08-21 11:27:03	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:27:02	info	Write config for port 13: http://192.168.0.14/sec/?pn=13&pty=1&m=0&d=0&pwm=0
      megad-0	2015-08-21 11:27:02	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:27:01	info	Write config for port 12: http://192.168.0.14/sec/?pn=12&pty=1&m=0&d=0&pwm=0
      megad-0	2015-08-21 11:27:01	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:27:00	info	Write config for port 11: http://192.168.0.14/sec/?pn=11&pty=1&m=0&d=0&pwm=0
      megad-0	2015-08-21 11:27:00	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:59	info	Write config for port 10: http://192.168.0.14/sec/?pn=10&pty=1&m=0&d=0&pwm=0
      megad-0	2015-08-21 11:26:59	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:58	info	Write config for port 9: http://192.168.0.14/sec/?pn=9&pty=1&m=0&d=0&pwm=0
      megad-0	2015-08-21 11:26:58	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:57	info	Write config for port 8: http://192.168.0.14/sec/?pn=8&pty=1&m=0&d=0&pwm=0
      megad-0	2015-08-21 11:26:57	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:56	info	Write config for port 7: http://192.168.0.14/sec/?pn=7&pty=1&m=0&d=0&pwm=0
      megad-0	2015-08-21 11:26:56	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:55	info	Write config for port 6: http://192.168.0.14/sec/?pn=6&pty=0&m=0&ecmd=ð=
      megad-0	2015-08-21 11:26:55	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:54	info	Write config for port 5: http://192.168.0.14/sec/?pn=5&pty=0&m=0&ecmd=ð=
      megad-0	2015-08-21 11:26:54	debug	Response: Back
      Device is restared.
      inMem	2015-08-21 11:26:53	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1440134813, from=system.adapter.admin.0, lc=1440133173
      megad-0	2015-08-21 11:26:53	info	Write config for port 4: http://192.168.0.14/sec/?pn=4&pty=0&m=0&ecmd=ð=
      megad-0	2015-08-21 11:26:53	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:52	info	Write config for port 3: http://192.168.0.14/sec/?pn=3&pty=0&m=0&ecmd=ð=
      megad-0	2015-08-21 11:26:52	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:50	info	Write config for port 2: http://192.168.0.14/sec/?pn=2&pty=0&m=0&ecmd=ð=
      megad-0	2015-08-21 11:26:50	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:49	info	Write config for port 1: http://192.168.0.14/sec/?pn=1&pty=0&m=0&ecmd=ð=
      megad-0	2015-08-21 11:26:49	debug	Response: Back
      Device is restared.
      megad-0	2015-08-21 11:26:49	info	Write config for port 0: http://192.168.0.14/sec/?pn=0&pty=0&m=0&ecmd=ð=
      inMem	2015-08-21 11:26:49	debug	message messagebox.system.adapter.megad.0 messagebox.system.adapter.megad.0 command=writeConfig, ip=192.168.0.14, password=sec, ports=[pty=0, name=P0, m=0, pwm=0, role=state, room=, long=false, double=true, eth=, ecmd=, pty=0, name=P1, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P2, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P3, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P4, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P5, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P6, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=1, name=P7, m=0, role=state, room=, d=0, pty=1, name=P8, m=0, role=state, room=, d=0, pty=1, name=P9, m=0, role=state, room=, d=0, pty=1, name=P10, m=0, role=state, room=, d=0, pty=1, name=P11, m=0, role=state, room=, d=0, pty=1, name=P12, m=0, role=state, room=, d=0, pty=1, name=P13, m=0, role=state, room=, d=0, pty=255, name=P14, m=0, role=value, room=, pty=255, name=P15, m=0, role=value, room=], port=, from=system.adapter.admin.0, ip=192.168.0.14, password=sec, ports=[pty=0, name=P0, m=0, pwm=0, role=state, room=, long=false, double=true, eth=, ecmd=, pty=0, name=P1, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P2, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P3, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P4, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P5, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=0, name=P6, m=0, pwm=0, role=state, room=, long=false, double=false, eth=, ecmd=, pty=1, name=P7, m=0, role=state, room=, d=0, pty=1, name=P8, m=0, role=state, room=, d=0, pty=1, name=P9, m=0, role=state, room=, d=0, pty=1, name=P10, m=0, role=state, room=, d=0, pty=1, name=P11, m=0, role=state, room=, d=0, pty=1, name=P12, m=0, role=state, room=, d=0, pty=1, name=P13, m=0, role=state, room=, d=0, pty=255, name=P14, m=0, role=value, room=, pty=255, name=P15, m=0, role=value, room=], port=, id=51, ack=false, time=1440134809490, _id=130
      admin-0	2015-08-21 11:26:49	info	sendTo 'writeConfig' to system.adapter.megad.0 from system.adapter.admin.0: {'ip':'192.168.0.14','password':'sec','ports':[{'pty':'0','name':'P0','m':0,'pwm':0,'role':'state','room':'','long':false,'double':true,'eth':'','ecmd':''},{'pty':'0','name':'P1','m':0,'pwm':0,'role':'state','room':'','long':false,'double':false,'eth':'','ecmd':''},{'pty':'0','name':'P2','m':0,'pwm':0,'role':'state','room':'','long':false,'double':false,'eth':'','ecmd':''},{'pty':'0','name':'P3','m':0,'pwm':0,'role':'state','room':'','long':false,'double':false,'eth':'','ecmd':''},{'pty':'0','name':'P4','m':0,'pwm':0,'role':'state','room':'','long':false,'double':false,'eth':'','ecmd':''},{'pty':'0','name':'P5','m':0,'pwm':0,'role':'state','room':'','long':false,'double':false,'eth':'','ecmd':''},{'pty':'0','name':'P6','m':0,'pwm':0,'role':'state','room':'','long':false,'double':false,'eth':'','ecmd':''},{'pty':'1','name':'P7','m':0,'role':'state','room':'','d':0},{'pty':'1','name':'P8','m':0,'role':'state','room':'','d':0},{'pty':'1','name':'P9','m':0,'role':'state','room':'','d':0},{'pty':'1','name':'P10','m':0,'role':'state','room':'','d':0},{'pty':'1','name':'P11','m':0,'role':'state','room':'','d':0},{'pty':'1','name':'P12','m':0,'role':'state','room':'','d':0},{'pty':'1','name':'P13','m':0,'role':'state','room':'','d':0},{'pty':'255','name':'P14','m':0,'role':'value','room':''},{'pty':'255','name':'P15','m':0,'role':'value','room':''}],'config':{'port':''}}
      • V Offline
        V Offline
        vtec
        #103
        Похоже не работает считывание настроек или работает не корректно.
        Вот что в меге (все порты и конкретно P0):
        А вот что после нажатия кнопки считать (почему то входы и выходы наоборот и сценарии пустые):
        • BluefoxB Offline
          BluefoxB Offline
          #104
          @vtec:
          filename="mega_new.png" index="1">~~
          filename="mega_driver_new.png" index="0">~~ `
          Надо внести ясность.
          1. Вход - Это то откуда данные поступают в ioBroker, например кнопка
          Выход - Это выход из ioBroker и из меги в сторону лампы/реле
          2. Я пытался определить настройки по тому, как выглядит строка http://192.168.0.14/sec/?cmd=all
          Например ответ такой:
          OFF;OFF/0;OFF/0;25;temp:45.6;temp:45.6/hum:27
          Тогда я порт 0 (OFF) распознавал, как вход
          OFF/0 - выход
          25 - ACD вход
          temp:45.6 - digital sensor (mode 0)
          temp:45.6/hum:27 - digital sensor (mode 1)
          Поэтому такие настройки, как сценарии, не считывались.
          Теперь оказывается настройки можно считать с HTTP страницы.
          Вопрос/запрос.
          1. Как выглядит твоя конкретно конфигурация меги? По-портам:
          P0 - Dig Input, Mode P&R(Press&Release :?: ) 1, Action: "7:1", Net: "192xxx" ?
          P1 - Dig Input
          P2 - Dig Input
          P3 - Dig Input
          P4 - Dig Input
          P5 - Dig Input
          P6 - Dig Input
          P7 - Dig Output,
          P8 - Dig Output,
          P9 - Dig Output,
          P10 - Dig Output,
          P11 - Dig Output,
          P12 - Dig Output,
          P13 - Dig Output,
          P14- A6 - Analog Input
          P15- A7 - Analog Input
          2. Что выдаётся у тебя на "http://192.168.0.14/sec/?cmd=all" :?:
          OFF;OFF;OFF;OFF;OFF;OFF;OFF;ON/1;OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;25;67
          3. Что надо вызвать чтобы появилась страница с настройками для порта? "http://192.168.0.14/sec/?pt=0" ?
          А для P14 "http://192.168.0.14/sec/?pt=14" ?
          4. Как выглядит HTML source code такой страницы? Для входа, выхода, ADC, DHT, NC ?
          Без этого я не смогу написать нормальный симулятор, а без симулятора не смогу написать нормальный драйвер.
          • V Offline
            V Offline
            vtec
            #105
            @Bluefox:
            Да.
            • V Offline
              V Offline
              vtec
              #106
              @Bluefox:
              P1 - Dig Input
              P2 - Dig Input
              P3 - Dig Input
              P4 - Dig Input
              P5 - Dig Input
              P6 - Dig Input
              P7 - Dig Output,
              P8 - Dig Output,
              P9 - Dig Output,
              P10 - Dig Output,
              P11 - Dig Output,
              P12 - Dig Output,
              P13 - Dig Output,
              P15- A7 - Analog Input `
              Именно так сейчас и выглядит.
              • V Offline
                V Offline
                vtec
                #107
                @Bluefox:
                OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;OFF;OFF;OFF;OFF;OFF;OFF;OFF;39;23
                Как раз OFF/0 это вход, а просто OFF это выход
                У меня конфигурация меги 7I7O, то есть 7 входов (0-6) и 7 выходов (7-13)
                Вот так выглядит строка с включенным симистором/реле на седьмом порту
                OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;OFF/0;ON;OFF;OFF;OFF;OFF;OFF;OFF;35;22
                На конце цыфры (35;22), на этих двух портах у меня сейчас ничего нет, но это и нормально, там напряжение скачет, т.к. нет никаких датчиков. Эти два порта могут быть только ADC.
                • V Offline
                  V Offline
                  vtec
                  #108
                  @Bluefox:
                  А для P14 "http://192.168.0.14/sec/?pt=14" ? `
                  http://192.168.0.14/sec/?pt=7
                  • V Offline
                    V Offline
                    vtec
                    #109
                    @Bluefox:
                    Без этого я не смогу написать нормальный симулятор, а без симулятора не смогу написать нормальный драйвер. `
                    Надеюсь это только для симулятора :), не для парсинга %)
                    Bluefox, а почему бы не попросить у Андрея данное устройство для написания драйвера, я думаю что он будет согласен!
                    <u>Вход</u>
                    [Back](/sec)
                    P0/OFF/0
                    <form action="/sec/">Type In
                    Act
                    Net
                    Mode <select name="m"><option value="0">P</option><option value="1" selected="">P&R</option><option value="2">R</option></select>
                    Raw
                    </form>
                    <u>Выход</u>
                    [Back](/sec)
                    P7/OFF
                    [ON](/sec/?pt=7&cmd=7:1) [OFF](/sec/?pt=7&cmd=7:0)
                    <form action="/sec/">Type Out
                    Default: <select name="d"><option value="0" selected="">0</option><option value="1">1</option></select>
                    </form>
                    <u>ADC только 14 и 15 порты или А6 А7</u>
                    [Back](/sec)
                    A6/95
                    <form action="/sec/">Mode <select name="m"><option value="0" selected="">Norm</option><option value="1">></option><option value="2"><</option><option value="3"><></option></select>
                    Val
                    Act
                    Net
                    </form>
                    <u>NC</u>
                    [Back](/sec)
                    P0
                    <form action="/sec/">Type <select name="pty"><option value="255" selected="">NC</option><option value="0">In</option><option value="1">Out</option><option value="3">DSen</option><option value="2">ADC</option></select>
                    </form>
                    <u>Dsen</u>
                    [Back](/sec)
                    P0
                    temp:0
                    hum:0
                    <form action="/sec/">Type <select name="pty"><option value="255">NC</option><option value="0">In</option><option value="1">Out</option><option value="3" selected="">DSen</option><option value="2">ADC</option></select>
                    Sensor: <select name="m"><option value="1" selected="">DHT11</option><option value="2">DHT22</option></select>
                    </form>
                    • V Offline
                      V Offline
                      vtec
                      #110
                      На все ли я ответил?
                      • BluefoxB Offline
                        BluefoxB Offline
                        #111
                        @vtec:
                        @Bluefox:
                        filename="p0.png" index="2">~~
                        filename="p7.png" index="1">~~
                        filename="p14.png" index="0">~~ `
                        Вроде начинает проясняться. Спасибо!
                        Именно для парсинга. Я хочу считать все "…sec/?pt=Х" и извлечь настройки. А что есть какой то другой путь?
                        • V Offline
                          V Offline
                          vtec
                          #112
                          Если я не ошибаюсь, то есть, т.к. есть скрипт который все настройки экспортирует.
                          Работа с настройками
                          При использовании ключа –ee (стирание EEPROM), часто необходимого при обновлении прошивки, из памяти устройства удаляется вся текущая нстройка портов. Это очень неудобно после перепрошивки восстанавливать настройки устройства и портов. Поэтому начиная с версии 1.1 скрипта megad-cfg.php была предусмотрена функция считывания и записи текущих настроек.
                          Считывание конфигурации устройства и запись в файл megad.cfg
                          php megad-cfg.php --ip 192.168.0.14 --read-conf megad.cfg -p sec
                          Считывание конфигурации из файла и запись в устройство
                          php megad-cfg.php --ip 192.168.0.14 --write-conf megad.cfg -p sec
                          Сканирование всех устройств типа MegaD-328 в сети
                          php megad-cfg.php –scan
                          • V Offline
                            V Offline
                            vtec
                            #113
                            Сканирование (из php файла):
                            $sock = socket_create(AF_INET, SOCK_DGRAM, SOL_UDP);
                            socket_set_option($sock, SOL_SOCKET, SO_BROADCAST, 1);
                            $broadcast_ip = preg_replace("/(\d+)\.(\d+)\.(\d+)\.(\d+)/", "$1.$2.$3.255", $local_ip);
                            # Prepearing sockets
                            if ( !empty($options['local-ip']) )
                            $local_ip = $options['local-ip'];
                            else
                            	$local_ip = gethostbyname(gethostname());
                            	if ( empty($local_ip) || preg_match("/127\./", $local_ip) )
                            		if ( preg_match("/^WIN/", PHP_OS) )
                            		$local_ip = get_local_ip_win();
                            		else
                            			$find_ip = get_local_ip();
                            			foreach ( $find_ip as $iface => $iface_ip)
                            				if ( preg_match("/^192\.168/", $find_ip[$iface]) || preg_match("/^10\./", $find_ip[$iface]) )
                            				$local_ip = $find_ip[$iface];
                            	if ( !preg_match("/192\.168\./", $local_ip) && !preg_match("/10\.0\./", $local_ip) && !preg_match("/172\.16\./", $local_ip) )
                            		echo "Unable to detect local network\nPlase, specify local IP-address with --local-ip\n";
                            		exit;
                            # Scanning network for Mega-cool MegaD-devices ;)
                            if ( array_key_exists('scan', $options) || array_key_exists('s', $options) )
                            	$broadcast_string = chr(0xAA).chr(0).chr(12);
                            	socket_sendto($sock, $broadcast_string, strlen($broadcast_string), 0, $broadcast_ip, 52000);
                            	usleep(100);
                            	do
                            		$pkt = fread($socket, 10);
                            		if ( !empty($pkt) && ord($pkt[0]) == 0xAA )
                            		echo ord($pkt[1]).".".ord($pkt[2]).".".ord($pkt[3]).".".ord($pkt[4])."\n";
                            	while ( $pkt != false );
                            Чтение конфига
                            	if ( array_key_exists('read-conf', $options) )
                            		echo "Reading configuration... ";
                            		$pages = array("cf=1", "cf=2");
                            		//$pages = array();
                            		$page = file_get_contents("http://".$options['ip']."/".$options['p']);
                            		$ports = preg_replace("/.*\?pt=(\d+).*/", "$1", $page);
                            		for ( $i = 0; $i <= $ports; $i++ )
                            		$pages[] = "pt=$i";
                            		$fh = fopen($options['read-conf'], "w");
                            		$dom = new DOMDocument();
                            		$preset_flag = 0;
                            		for ( $i = 0; $i < count($pages); $i++ )
                            			if ( $preset_flag == 1 )
                            				//echo "Setting preset 0\n";
                            				$page = file_get_contents("http://".$options['ip']."/".$options['p']."/?cf=1&pr=0");
                            				sleep(1);
                            				$preset_flag = 2;
                            			$page = file_get_contents("http://".$options['ip']."/".$options['p']."/?".$pages[$i]);
                            			@$dom->loadHTML($page);
                            			//$url = "http://".$options['ip']."/".$options['p']."/?";
                            			$url = "";
                            			$els=$dom->getelementsbytagname('input');
                            			foreach($els as $inp)
                            				if ( $inp->getAttribute('type') != "submit" )
                            					$name=$inp->getAttribute('name');
                            					//$value=urlencode($inp->getAttribute('value'));
                            					if ( $inp->getAttribute('type') == "checkbox" )
                            						if ( $inp->hasAttribute('checked') )
                            						$value=1;
                            						else
                            						$value='';
                            					else
                            					$value=$inp->getAttribute('value');
                            					if ( $name != "pt" )
                            						if ( $name == "sl" && empty($value));
                            						else
                            						$url .= "$name=$value&";
                            			$select = $dom->getelementsbytagname('select');
                            			foreach($select as $elem)
                            				$name=$elem->getAttribute('name');
                            				$els=$elem->getelementsbytagname('option');
                            				$sel_flag = 0;
                            					if ( $inp->hasAttribute('selected') )
                            						//$name=$inp->getAttribute('name');
                            						$sel_flag = 1;
                            						if ( $pages[$i] == "cf=1" && $name == "pr" && !empty($value) )
                            							$preset_flag = 1;
                            							$stored_preset = $value;
                            				// Хак ввиду того, что PHP DOM почему-то не может распарсить значение <> поля "Mode"
                            				if ( $sel_flag == 0 && $name == "m" )
                            				$url .= "m=3&";
                            			$url = preg_replace("/&$/", "", $url);
                            			fwrite($fh, "$url\n");
                            		fclose($fh);
                            		if ( $preset_flag == 2 )
                            			//echo "Setting preset 1\n";
                            			$page = file_get_contents("http://".$options['ip']."/".$options['p']."/?cf=1&pr=$stored_preset");
                            			sleep(1);
                            		echo "OK\n";
                            • V Offline
                              V Offline
                              vtec
                              #114
                              Посмотрел чтение конфига, там тот же парсинг идет :lol:
                              А вот поиск устройств, всего две строки, отправка udp запроса бродкастом на порт 52000
                              • V Offline
                                V Offline
                                vtec
                                #115
                                Из мануала:
                                Если порт настроен как вход, то через слеш указывается значение счетчика входа. То есть там может быть не 0, а любая цифра.
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  #116
                                  Спасибо. Вот теперь я знаю, что я буду делать на выходных.
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #117
                                    Что возвращают?
                                    • http://192.168.0.14/sec
                                    • http://192.168.0.14/sec/
                                    • http://192.168.0.14/sec/?cf=1
                                    • http://192.168.0.14/sec/?cf=2
                                    Как HTML.
                                    • V Offline
                                      V Offline
                                      vtec
                                      #118
                                      MegaD-328 by [ab-log.ru](http://ab-log.ru) (fw: 3.30b5)
                                      [Config](/sec/?cf=1)
                                      -- Ports --
                                      [P0 - IN](/sec/?pt=0)
                                      [P1 - IN](/sec/?pt=1)
                                      [P2 - IN](/sec/?pt=2)
                                      [P3 - IN](/sec/?pt=3)
                                      [P4 - IN](/sec/?pt=4)
                                      [P5 - IN](/sec/?pt=5)
                                      [P6 - IN](/sec/?pt=6)
                                      [P7 - OUT](/sec/?pt=7)
                                      [P8 - OUT](/sec/?pt=8)
                                      [P9 - OUT](/sec/?pt=9)
                                      [P10 - OUT](/sec/?pt=10)
                                      [P11 - OUT](/sec/?pt=11)
                                      [P12 - OUT](/sec/?pt=12)
                                      [P13 - OUT](/sec/?pt=13)
                                      [A6 - ADC](/sec/?pt=14)
                                      [A7 - ADC](/sec/?pt=15)
                                      2. Тоже самое что и первое
                                      3.
                                      [Back](/sec) | [Megad-ID](/sec/?cf=2)
                                      <form action="/sec/">IP:
                                      Pwd:
                                      GW:
                                      SRV:
                                      Script:
                                      Preset: <select name="pr"><option value="0" selected="">Norm</option><option value="1">7I7O</option></select>
                                      T check:
                                      Alarm T:
                                      Cur T: 37
                                      </form>
                                      [Back](/sec) | [Config](/sec/?cf=1)
                                      <form action="/sec/">Megad-ID:
                                      srv loop:
                                      </form>
                                      • V Offline
                                        V Offline
                                        vtec
                                        #119
                                        Предложение, если я выставляю режим кнопки "изменение", то соответственно, я буду использовать доп. режимы, это либо долгое нажатие, либо двойное, либо в сумме. Так вот предлагаю эти галочки у этих двух параметров по умолчанию чтобы были выставлены. Возможно такое?
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          #120
                                          Дописал драйвер с твоей помощью. Можешь попробовать?
