  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.1k Aufrufe 51 Beobachtet
  • ZefauZ Zefau
    @miwe sagte in [Aufruf] Nuki-extended Adapter:
    Warum reagiert das Schloss erst beim 2ten mal? Beim ersten mal positive Rückmeldungen im Log, jedoch ohne Reaktion, beim 2ten mal ausösen funktioniert es. Verbindung zum Schloss ist gegeben und sehr gut.
    Kannst du das vollständige Log posten (ab Adapter-Start), sofern das noch auftritt?
    miwe
    #181
    @Zefau nuki-extended.0 2019-10-26 17:48:23.540 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
    nuki-extended.0 2019-10-26 17:48:22.954 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572104902950,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":1572104
    nuki-extended.0 2019-10-26 17:48:22.951 debug (9733) Action applied on Bridge API.
    nuki-extended.0 2019-10-26 17:48:22.951 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
    nuki-extended.0 2019-10-26 17:48:22.950 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104902949,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104902949
    admin.0 2019-10-26 17:48:16.872 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
    admin.0 2019-10-26 17:48:11.865 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
    nuki-extended.0 2019-10-26 17:47:51.836 info (9733) Listening for Nuki events on port 51989.
    nuki-extended.0 2019-10-26 17:47:51.830 debug (9733) Callback (with URL http://192.168.2.53:51989/nuki-api-bridge) already attached to Nuki Bridge with name Nuki .
    nuki-extended.0 2019-10-26 17:47:51.829 debug (9733) Retrieved current callbacks from Nuki Bridge with name Nuki .
    nuki-extended.0 2019-10-26 17:47:51.464 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572104871421,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":1572104
    nuki-extended.0 2019-10-26 17:47:51.454 debug (9733) Updating device smartlocks.wohnungstür with payload: {"deviceType":0,"nukiId":449894709,"name":"Wohnungstür","bridge":"1092735473","state":{"mode":2,"state":1,"batteryCritical":false,"timestam
    nuki-extended.0 2019-10-26 17:47:51.454 debug (9733) Updating device openers.haustür with payload: {"deviceType":2,"nukiId":455049994,"name":"Haustür","bridge":"1092735473","state":{"mode":3,"state":1,"batteryCritical":false,"timestamp":"2019-10
    nuki-extended.0 2019-10-26 17:47:51.453 debug (9733) getBridgeApi(): [{"deviceType":2,"nukiId":455049994,"name":"Haustür","lastKnownState":{"mode":3,"state":1,"stateName":"online","batteryCritical":false,"timestamp":"2019-10-26T14:36:44+00:00"},
    nuki-extended.0 2019-10-26 17:47:51.421 debug (9733) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lati
    nuki-extended.0 2019-10-26 17:47:51.417 debug (9733) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,
    nuki-extended.0 2019-10-26 17:47:51.416 debug (9733) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,"
    nuki-extended.0 2019-10-26 17:47:51.158 info (9733) Polling Nuki Web API deactivated.
    nuki-extended.0 2019-10-26 17:47:51.115 info (9733) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v10.17.0
    nuki-extended.0 2019-10-26 17:47:50.688 debug (9733) States connected to redis: 127.0.0.1:9000
    nuki-extended.0 2019-10-26 17:47:50.643 debug (9733) statesDB connected
    nuki-extended.0 2019-10-26 17:47:50.640 debug (9733) Objects connected to redis: 127.0.0.1:9001
    nuki-extended.0 2019-10-26 17:47:50.639 debug (9733) Redis States: Use Redis connection: 127.0.0.1:9000
    nuki-extended.0 2019-10-26 17:47:50.638 debug (9733) objectDB connected
    nuki-extended.0 2019-10-26 17:47:50.610 debug (9733) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.iobroker 2019-10-26 17:47:50.169 info instance system.adapter.nuki-extended.0 started with pid 9733
    ZefauZ 1 Antwort Letzte Antwort
    • M miwe
      ZefauZ Offline
      ZefauZ Offline
      Zefau
      #182
      @miwe das Log sieht gut aus. Ist in dem Log der Fehler enthalten, dass das Schloss erst beim zweiten Mal reagiert? Es erscheint ja richtigerweise nur eine Erfolgsmeldung.
      In dem Log wird _ACTION 1x mit Wert "1" getriggert (und 2x auf "0" resettet).
      Meine Adapter: https://zefau.github.io/iobroker/
      M 2 Antworten Letzte Antwort
      • ZefauZ Zefau
        miwe
        #183
        @Zefau Was sagt mir das? Ich kann damit nichts anfangen. Ich möchte das Schloss über die Szenen des IOBROKERS steuern. Was muss ich hier machen?
        • ZefauZ Zefau
          miwe
          #184
          @Zefau said in [Aufruf] Nuki-extended Adapter:
          nuki-extended.0 2019-10-26 17:52:36.348 debug (9733) system.adapter.admin.0: logging false
          nuki-extended.0 2019-10-26 17:52:18.545 debug (9733) system.adapter.admin.0: logging true
          nuki-extended.0 2019-10-26 17:52:14.647 debug (9733) system.adapter.admin.0: logging false
          admin.0 2019-10-26 17:51:21.169 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
          nuki-extended.0 2019-10-26 17:49:48.716 debug (9733) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lati
          nuki-extended.0 2019-10-26 17:49:48.710 debug (9733) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,
          nuki-extended.0 2019-10-26 17:49:48.710 debug (9733) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,"
          nuki-extended.0 2019-10-26 17:49:48.344 debug (9733) Updating device smartlocks.wohnungstür with payload: {"nukiId":449894709,"state":{"deviceType":0,"mode":2,"state":3,"batteryCritical":false,"timestamp":"2019-10-26T15:49:48+00:00","locked":3},
          nuki-extended.0 2019-10-26 17:49:48.343 debug (9733) Received payload via callback: {"nukiId":449894709,"state":{"deviceType":0,"mode":2,"state":3,"stateName":"unlocked","batteryCritical":false,"timestamp":"2019-10-26T15:49:48+00:00"}}
          nuki-extended.0 2019-10-26 17:49:24.417 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
          nuki-extended.0 2019-10-26 17:49:17.412 debug (9733) Action applied on Bridge API.
          nuki-extended.0 2019-10-26 17:49:17.412 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
          nuki-extended.0 2019-10-26 17:49:17.412 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104957410,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104953664
          nuki-extended.0 2019-10-26 17:49:14.079 info (9733) Successfully triggered action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
          nuki-extended.0 2019-10-26 17:49:13.666 debug (9733) Action applied on Bridge API.
          nuki-extended.0 2019-10-26 17:49:13.666 info (9733) Trigger action -UNLOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
          nuki-extended.0 2019-10-26 17:49:13.665 debug (9733) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":1,"ack":false,"ts":1572104953664,"q":0,"from":"system.adapter.scenes.0","user":"system.user.admin","lc":1572104953664
          admin.0 2019-10-26 17:49:08.829 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
          admin.0 2019-10-26 17:49:05.115 info (3355) successful connection to socket.io from ::ffff:192.168.2.45
          Hier das komplette Log mit insgesamt 3 Versuchen . Es hat erst beim 3ten mal diesmals funktioniert.
          • M miwe
            ZefauZ Offline
            ZefauZ Offline
            Zefau
            #185
            Kannst du mal versuchen in den Objekten beim State _ACTION manuell einen Wert (z.B. LOCK oder UNLOCK) zu wählen?
            • ZefauZ Zefau
              miwe
              #186
              @Zefau Wie geht das? Ich bin da leider nicht so bewandert wie Du und habe keine Lust mir den Broker durch mein gefummel zu zerschiessen :)
              • M miwe
                ZefauZ Offline
                ZefauZ Offline
                Zefau
                #187
                @miwe einfach in der Navigation Objekte wählen und dort zum State navigieren: nuki-extended.0.smartlocks.wohnungstür._ACTION. Dann rechts wo NO_ACTION(0) steht einen anderen Wert auswählen.
                • ZefauZ Zefau
                  miwe
                  schrieb am zuletzt editiert von miwe
                  #188
                  @Zefau
                  Das kommt dabei heraus - Schloss hat nicht reagiert,
                  nuki-extended.0 2019-10-26 18:02:28.341 debug (25155) system.adapter.admin.0: logging true
                  nuki-extended.0 2019-10-26 18:02:23.694 info (25155) Successfully triggered action -LOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                  nuki-extended.0 2019-10-26 18:02:23.006 debug (25155) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":0,"ack":true,"ts":1572105743002,"q":0,"from":"system.adapter.nuki-extended.0","user":"system.user.admin","lc":157210
                  nuki-extended.0 2019-10-26 18:02:23.003 debug (25155) Action applied on Bridge API.
                  nuki-extended.0 2019-10-26 18:02:23.003 info (25155) Trigger action -LOCK- on Nuki Smartlock Wohnungstür (via Bridge API).
                  nuki-extended.0 2019-10-26 18:02:23.002 debug (25155) State of nuki-extended.0.smartlocks.wohnungstür._ACTION has changed {"val":2,"ack":false,"ts":1572105743000,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1572105743000
                  nuki-extended.0 2019-10-26 18:01:08.527 info (25155) Listening for Nuki events on port 51989.
                  nuki-extended.0 2019-10-26 18:01:08.521 debug (25155) Callback (with URL http://192.168.2.53:51989/nuki-api-bridge) already attached to Nuki Bridge with name Nuki .
                  nuki-extended.0 2019-10-26 18:01:08.520 debug (25155) Retrieved current callbacks from Nuki Bridge with name Nuki .
                  nuki-extended.0 2019-10-26 18:01:08.312 debug (25155) Updating device smartlocks.wohnungstür with payload: {"smartlockId":449894709,"accountId":2145826587,"authId":3431686,"name":"Wohnungstür","favorite":false,"config":{"name":"Wohnungstür","lat
                  nuki-extended.0 2019-10-26 18:01:08.308 debug (25155) Updating device openers.haustür with payload: {"smartlockId":9044984586,"accountId":2145826587,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858
                  nuki-extended.0 2019-10-26 18:01:08.307 debug (25155) getWebApi(): [{"smartlockId":9044984586,"accountId":2145826587,"type":2,"authId":3431647,"name":"Haustür","favorite":false,"config":{"name":"Haustür","latitude":50.8858,"longitude":12.064853,
                  nuki-extended.0 2019-10-26 18:01:08.141 debug (25155) Updating device smartlocks.wohnungstür with payload: {"deviceType":0,"nukiId":449894709,"name":"Wohnungstür","bridge":"1092735473","state":{"mode":2,"state":3,"batteryCritical":false,"timesta
                  nuki-extended.0 2019-10-26 18:01:08.140 debug (25155) Updating device openers.haustür with payload: {"deviceType":2,"nukiId":455049994,"name":"Haustür","bridge":"1092735473","state":{"mode":3,"state":1,"batteryCritical":false,"timestamp":"2019-1
                  nuki-extended.0 2019-10-26 18:01:08.139 debug (25155) getBridgeApi(): [{"deviceType":2,"nukiId":455049994,"name":"Haustür","lastKnownState":{"mode":3,"state":1,"stateName":"online","batteryCritical":false,"timestamp":"2019-10-26T14:36:44+00:00"}
                  nuki-extended.0 2019-10-26 18:01:07.885 info (25155) Polling Nuki Web API deactivated.
                  nuki-extended.0 2019-10-26 18:01:07.853 debug (25155) States connected to redis: 127.0.0.1:9000
                  nuki-extended.0 2019-10-26 18:01:07.842 info (25155) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v10.17.0
                  nuki-extended.0 2019-10-26 18:01:07.763 debug (25155) statesDB connected
                  nuki-extended.0 2019-10-26 18:01:07.760 debug (25155) Objects connected to redis: 127.0.0.1:9001
                  nuki-extended.0 2019-10-26 18:01:07.759 debug (25155) Redis States: Use Redis connection: 127.0.0.1:9000
                  nuki-extended.0 2019-10-26 18:01:07.758 debug (25155) objectDB connected
                  nuki-extended.0 2019-10-26 18:01:07.732 debug (25155) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  host.iobroker 2019-10-26 18:01:07.312 info instance system.adapter.nuki-extended.0 started with pid 25155
                  • M miwe
                    @Zefau
                    ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    #189
                    @miwe Und ging es beim ersten Mal?
                    • ZefauZ Zefau
                      miwe
                      #190
                      @Zefau nein. Ich habe aber auch nur einmal probiert.
                      • ZefauZ Zefau
                        miwe
                        #191
                        @Zefau Jetzt eben nochmal probiert - geht. Seltsam.
                        • M miwe
                          miwe
                          #192
                          @miwe Bis jetzt funktioniert es plötzlich einwandfrei. Wunderheilung? Keine Ahnung. Ich beobachte mal weiter. Besten Dan für deine Mühen und gute Arbeit hier.
                          • cashC cash
                            @Zefau So es ist vollbracht. Habe den Adapter wieder längere Zeit ausgelassen und als ich dann per Browser den Satus abfragen konnte hatte ich gesehen Uptime der Bridge 112. Ich vermute Sekunden? Also wird die Bridge sich verabschiedet haben. Also Adapter gestartet und er ist wieder gelb ✌ Aber das ist ja ein gutes Zeichen. Im Log kam nach dem Polling auch sofort der richtige State für die Haustür und danach der Callback. Also einmal den Actions-State geändert und auch das passt nun:
                            javascript.0	2019-10-19 22:26:52.514	info	script.js.Flur.Nuki_Opener: Status von Haustür: RING_TO_OPEN_ACTIVE
                            nuki-extended.1	2019-10-19 22:26:49.014	info	Successfully triggered action -ACTIVE RTO- on Nuki Opener Haustür (via Bridge API).
                            nuki-extended.1	2019-10-19 22:26:47.517	info	Trigger action -ACTIVE RTO- on Nuki Opener Haustür.
                            nuki-extended.1	2019-10-19 22:23:40.822	info	Callback (with URL http://192.168.178.10:51989/nuki-api-bridge) attached to Nuki Bridge with name Nuki Bridge.
                            nuki-extended.1	2019-10-19 22:23:40.039	info	Listening for Nuki events on port 51989.
                            javascript.0	2019-10-19 22:22:09.789	info	script.js.Flur.Nuki_Opener: Status von Haustür: ONLINE
                            nuki-extended.1	2019-10-19 22:22:09.316	info	Polling Nuki Web API with a frequency of 60s.
                            Ich hoffe echt das Nuki Firmware der Bridge deutlich verbessern kann. So ist mir das ganze etwas instabil und wenig verlässlich...
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            #193
                            @cash sagte in [Aufruf] Nuki-extended Adapter:
                            Wie läuft das Update bisher bei dir?
                            Haste schon gesehen, dass es eine neue Beta Firmware für die Bridge gibt (https://developer.nuki.io/t/early-access-bridge-beta-2-4-0/3331?u=zefau) ?
                            cashC GrizzelbeeG 3 Antworten Letzte Antwort
                            • ZefauZ Zefau
                              cashC Offline
                              cashC Offline
                              cash
                              #194
                              @Zefau Ich bin noch bei der 2.0.1 weil die eigentlich relativ sauber läuft. Nach dem Update läuft es ja meist erstmal nicht :-( deshalb bin ich etwas zurückhaltend.
                              Beta hatte ich mitbekommen und auch das erste Kommtentar von einem User der erstmal zufrieden war. Das würde ich aber bei mir nicht riskieren. Das wäre mir zu heiß.
                              Insgesamt bin ich mit Nuki zwar zufrieden aber es würde halt soviel mehr gehen wenn die StatusUpdates zuverlässiger kämen.
                              Ich habe bei mir das Problem, dass meine Garage direkt neben der Haustür ist und sobald ich aussteige, wird die Wohnungstür geöffnet, nur bleibt die halt nicht offen. Eh ich dann mittels Ring to Open im Haus bin ist es viel zu spät. An sich sehr unlogisch programmiert. Ich wollte das per Adapter lösen. Einfach 3 Sekunden nach dem der Status der Haustür wieder Online ist soll er die Tür aufmachen (natürlich mit vielen Zusatzbedingungen wie Geofencing usw.)
                              Die Testpush kam auch eigentlich immer relativ passend nur das öffnen klappte bisher einmal. Und selbst dort stand im Log das es über die Bridge nicht gegangen ist und stattdessen die Webapi genommen wurde. Insgesamt für mich zu unzuverlässig als das ich das produktiv nutzen würden.
                              Die Probeschaltungen funktionieren zwar aber ich glaube wenn ich zu Nah nach einer Statusänderungen schalte ist die Bridge überfordert. Vielleicht wird das ja mit der Beta besser. Anderseits wenn Nuki nur die Hälfte der Requests umsetzt wäre das Produkt ohne eigene Scripte schon nahe zu perfekt....
                              • ZefauZ Zefau
                                cashC Offline
                                cashC Offline
                                cash
                                #195
                                @Zefau Habe jetzt das Update gemacht. Wie befürchtet funktioniert jetzt garnichts mehr.
                                Das Log ist komplett leer. Selbst beim Start stand in der Vorversion etwas von Polling Web-Api alle 60 Sekunden. Jetzt sehe ich nur das der Adapter gestartet ist. Er aktualisiert aber weder wenn ich versuche über den Adapter etwas zu machen noch wenn ich per App etwas ändere. Das heißt sowohl Bridge-Api als auch Web-Api liefern nichts? Sollte dann nicht warnings im log kommen?
                                Ich deaktiviere den Adapter jetzt erstmal wieder und werde heute Abend mal wieder den callback manuell löschen und mal gucken ob es danach wieder geht.
                                • cashC Offline
                                  cashC Offline
                                  cash
                                  #196
                                  Mit Version 2.03 scheint die Web-Api nicht mehr zu funktionieren? In der Datenpunkten steht bei WebApiLast die Uhrzeit von heute Morgen wo ich das Update eingespielt habe. Wie schon geschrieben das Log ist absolut leer.
                                  Selbst im Debug Modus ist es nicht sehr auskunftsfreudig:
                                  nuki-extended.1	2019-11-09 18:39:10.046	debug	system.adapter.admin.0: logging true
                                  nuki-extended.1	2019-11-09 18:39:08.995	info	starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v8.14.0
                                  nuki-extended.1	2019-11-09 18:39:08.975	debug	statesDB connected
                                  nuki-extended.1	2019-11-09 18:39:08.949	debug	objectDB connected
                                  host.iobroker_v2_19-05-19	2019-11-09 18:39:07.880	info	instance system.adapter.nuki-extended.1 started with pid 18667
                                  host.iobroker_v2_19-05-19	2019-11-09 18:39:05.397	info	instance system.adapter.nuki-extended.1 terminated with code 0 (OK)
                                  nuki-extended.1	2019-11-09 18:39:05.374	info	Adapter stopped und unloaded.
                                  nuki-extended.1	2019-11-09 18:39:05.367	info	Adapter stopped und unloaded.
                                  • ZefauZ Zefau
                                    GrizzelbeeG Offline
                                    GrizzelbeeG Offline
                                    Grizzelbee
                                    #197
                                    @Zefau
                                    Kann der Adapter eigentlich auch Firmware-Updates erkennen und ggf. ein Flag auf True setzen, wenn eins da ist?
                                    Die Updates sind bei Nuki so tief in der App versteckt, dass es jedesmal ein Wunder ist, wenn ich mitbekomme das eins da ist - und die basteln (gefühlt) gerade ordentlich an der F/W.
                                    Auf das Flag könnte ich dann wenigstens eine Alarmierung setzen und mich via telegram informieren lassen.
                                    Grizzelbee
                                    cashC ZefauZ 2 Antworten Letzte Antwort
                                    • GrizzelbeeG Grizzelbee
                                      @Zefau
                                      Grizzelbee
                                      cashC Offline
                                      cashC Offline
                                      cash
                                      #198
                                      @Grizzelbee wenn man die App startet hat man doch oben recht eine Glocke. Wenn es Updates liegt ist dort ein roter Badge. Nur bei der Bridge bekommt man es nicht mit, da das Update automatisch installiert wird.
                                        @Zefau
                                        Grizzelbee
                                        ZefauZ Offline
                                        ZefauZ Offline
                                        Zefau
                                        #199
                                        @Grizzelbee sagte in Test Adapter Nuki-extended v2.0.x:
                                        Der Adapter kann die auf dem Gerät befindliche Firmware laden bzw. anzeigen. Die API enthält aber keine Information über eine aktuellere API auf den Nuki Servern. Ich wüsste auch keine Quelle mit der die Firmware hinsichtlich einer aktuelleren Version abgeglichen werden kann.
                                        Insofern, leider nein.
                                        GrizzelbeeG 1 Antwort Letzte Antwort
                                        • cashC cash
                                          ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          #200
                                          @cash sagte in Test Adapter Nuki-extended v2.0.x:
                                          Hast du die Probleme noch? Kannst du mir nochmal zusammenschreiben, was für ein System du nutzt und welche Node.js Version du im Einsatz hast? Mich wundert, dass du so viele Probleme mit dem Adapter hast.
                                          Ich habe diesen bei mir nochmal frisch auf der Testumgebung installiert und habe keinerlei Probleme. Sehr komisch.
                                          cashC 1 Antwort Letzte Antwort
