  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.0k Aufrufe 51 Beobachtet
    @horst-böttcher
    Ich schon. Screenshot?
    Horst BöttcherH Offline
    Horst Böttcher
    #561
    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
    • Horst BöttcherH Horst Böttcher
      #562
      @horst-böttcher
      iobroker update -i
      zeigen.
      Horst BöttcherH 1 Antwort Letzte Antwort
        @horst-böttcher
        iobroker update -i
        zeigen.
        Horst Böttcher
        #563
        pi@raspberrypi:/opt/iobroker $ iobroker update -i
        Used repository: stable
        Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "alias-manager": 1.2.4    , installed 1.2.4
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "chromecast"   : 2.3.1    , installed 3.0.1
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "history"      : 1.11.1   , installed 1.11.1
        Adapter    "hmip"         : 1.17.0   , installed 1.17.0
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "ical"         : 1.12.1   , installed 1.12.1
        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
        Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.4   , installed 1.11.4
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
        Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "node-red"     : 3.3.1    , installed 3.3.0  [Updatable]
        Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
        Adapter    "nut"          : 1.5.1    , installed 1.5.1
        Adapter    "openweathermap": 0.2.4   , installed 0.2.4
        Adapter    "pushover"     : 2.1.0    , installed 2.1.0
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 4.2.0    , installed 4.2.0
        Adapter    "sql"          : 1.16.2   , installed 1.16.2
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "tuya"         : 3.6.15   , installed 3.6.15
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
        Adapter    "web"          : 4.3.0    , installed 4.3.0
        Adapter    "windows-control": 0.1.5  , installed 0.1.5
        Adapter    "ws"           : 1.3.0    , installed 1.3.0
          #564
          @horst-böttcher
          Hast du im Admin noch auf 'alte Oberfläche' gestellt?
            @horst-böttcher
            Horst Böttcher
            #565
            @thomas-braun ja habe gerade wieder zurück gestellt und ist immer noch so
              #566
              @horst-böttcher
              Browser Cache gelöscht?
                @horst-böttcher
                Horst Böttcher
                schrieb am zuletzt editiert von Horst Böttcher
                #567
                @thomas-braun Jo jetzt geht es dank
                • Boris HolowkaB Boris Holowka
                  Moin Leute
                  Schon lange wollte ich Aktionen steuern wenn jmd. via dem Keypad die Wohnung betritt. Nun kann dies in den Logs ausgelesen werden: nuki-extended.0.smartlocks.wohnungstür.logs
                  Problem: Ich würde gerne dort den Wert "name" auslesen und je nachdem was da drin steht via Blockly eine Aktion starten. Ich habe versucht den Text mit einem Blockly auszulesen. Jedoch reagiert er bei jedem neuen Logeintrag, da er natürlich das ganze Log durchcheckt und den Namen dann findet. Kann man das so steuern, dass er nur den letzten Eintrag checkt und nur diesen Wert von "name" auswertet?
                  Boris HolowkaB Offline
                  Boris Holowka
                  schrieb am zuletzt editiert von Boris Holowka
                  #568
                  Moin Leute
                    Matze89
                    schrieb am zuletzt editiert von Matze89
                    #569
                    im Datenpunkt Logs werden bei mir die zeiten um 2 Stunden falsch angezeigt?
                    laut logs 15:05 Uhr ist aber tatsächlich 17:05Uhr, ist bei allen einträgen um 2 Stunden Falsch.
                    Egal ob V.2.3.1 oder 2.6.5 ist überall das selbe, hat noch jemand das problem?
                    wie kann ich das ändern?
                    "autoUnlock": false,
                    "date": "2022-07-05T15:05:00.000Z"
                    danke schon mal :)
                    • M Matze89
                      danke schon mal :)
                      #570
                      @matze89
                      timedatectl
                      sagt dir?
                      Und 15Z sind 17Uhr lokal. Passt also.
                        @matze89
                        timedatectl
                        sagt dir?
                        Matze89
                        #571
                        Local time: Mi 2022-07-06 14:59:01 CEST
                        Universal time: Mi 2022-07-06 12:59:01 UTC
                        RTC time: Mi 2022-07-06 12:59:01
                        NTP service: active
                        RTC in local TZ: no
                        • M Matze89
                          NTP service: active
                          RTC in local TZ: no
                          #572
                          @matze89
                          Passt doch. Ich seh auch dein Problem nicht wirklich. Die Zeiten sind korrekt.
                            @matze89
                            Matze89
                            #573
                            @thomas-braun das problem ist immernoch diese Uhrzeit-angabe im wert “T15:05:00.000Z“
                            Diese Uhrzeit-Angabe ist einfach völliger quatsch um das ganze ordentlich zu visualisieren, wie soll man bitte da eine 17:05 Uhr daraus machen ohne alles auseinanderzu nehmen?
                            • M Matze89
                              #574
                              @matze89
                              Vermutlich gibt es da eine Möglichkeit, die Z-Zeit in die lokale Zeitzone zu konvertieren. Ich hab aber keine vis laufen, kann dir da also nicht weiterhelfen.
                                @matze89
                                Matze89
                                #575
                                @thomas-braun hab die json in brauchbare datenpunkte umgewandelt.
                                Sieht nun bisher so aus:
                                Horst BöttcherH H 2 Antworten Letzte Antwort
                                • M Matze89
                                  Horst Böttcher
                                  #576
                                  @matze89 sagte in Test Adapter Nuki-extended v2.0.x:
                                  kannst du das zur Verfügungstellung
                                    Horst Böttcher
                                    #577
                                    Ich hab immer wieder Probleme
                                    Adapter wir immer wieder gelb auch nach update auf Installierte Version:
                                    2.6.5
                                    api ist aktiviert
                                    Please activate Nuki Web API to retrieve log entries!
                                    L 1 Antwort Letzte Antwort
                                      2.6.5
                                      api ist aktiviert
                                      legro
                                      #578
                                      @horst-böttcher
                                      Ist bei mir seit über einem Jahr auch so. Adapter neu starten, danach funktioniert's wieder eine Weile. Ich hab's aufgegeben, dagegen etwas zu unternehmen, solange es denn funktioniert.😞
                                      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                                      • L legro
                                        @horst-böttcher
                                        Horst Böttcher
                                        #579
                                        @legro das ist echt schade
                                        • M Matze89
                                          helfi9999
                                          #580
                                          würdest du deine Vis zur Verfügung stellen suche schon die ganze Zeit nach etwas brauchbaren und dieses sieht super aus.
                                          Gruss
                                          helfi
                                          Intel NUC mit Iobroker
