  4. Test Adapter Nuki-extended v2.0.x
nuki-extended adapternuki
599 Beiträge 65 Kommentatoren 178.0k Aufrufe 51 Beobachtet
  • S Sandmanyz
    @Zefau sagte in [Neuer Adapter] Nuki:
    @Sandmanyz Auf was hast du die refresh Zeit eingestellt?
    15 Sekunden
    Ich habe den Adapter aktualisiert. Um 13:45 Uhr habe ich den Adapter, nach der Einrichtung, gestartet. Alle Werte wurden aktualisiert. Dann habe ich über die App die Tür abgeschlossen. Seit dem Zeitpunkt werden die Werte wieder nicht aktualisiert.
    • "nuki2.0.door__XXXXXX.status.lastAction" hat den Wert "LOCK(2)" weil ich ja abgeschlossen habe aber...
    • "nuki2.0.door__XXXXXX.status.lockState" hat noch "UNLOCKED(3)" und...
    • "nuki2.0.door__XXXXXX.status.locked" ist "false".
    Auszug aus dem Debug-Log....
    nuki2.0	2019-08-11 13:47:19.474	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:47:04.485	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:46:49.470	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:46:34.466	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:46:19.459	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:46:04.456	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:45:49.452	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:45:34.445	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:45:19.444	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3431648,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:45:06.044	info	Listening for Nuki events on port 51988.
    nuki2.0	2019-08-11 13:45:05.139	debug	getBridgeInfo(): {"deviceType":0,"nukiId":123456789,"name":"XXXXXX","lastKnownState":{"mode":2,"state":3,"stateName":"unlocked","batteryCritical":false,"timestamp":"2019-08-11T11:43:40+00:00"},"nuki"
    nuki2.0	2019-08-11 13:45:04.649	debug	State of nuki2.0.door__XXXXXX.action has changed {"val":0,"ack":true,"ts":1565443904532,"q":0,"from":"system.adapter.nuki2.0","lc":1565333305530}.
    nuki2.0	2019-08-11 13:45:04.537	debug	updateLocks(): {"smartlockId":123456789,"accountId":999999999,"type":0,"authId":3333333,"name":"XXXXXX","favorite":false,"config":{"name":"XXXXXX","latitude":xx.xxxxxx,"longitude":xx.xxxxxx,"capabil
    nuki2.0	2019-08-11 13:45:04.408	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.nuki2, node: v8.16.0
    nuki2.0	2019-08-11 13:45:00.425	info	Adapter stopped und unloaded.
    Seit dem nicht mehr aktualisiert wird, wird ins Log alle 15 Sekunden nur das geschrieben...
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    @Sandmanyz Bekomme es leider nicht reproduziert. Bei mir funktioniert es.
    Hast du in deinen Einstellungen den Callback aktiviert? Also in den Adapter-Einstellungen der linke der beiden Haken in der Tabelle.
    Dadurch erhältst du die Aktualisierungen vom Nuki. Dann sollte im Log etwas stehen wie Received payload via callback.
    Meine Adapter: https://zefau.github.io/iobroker/
      Sandmanyz
      Erst einmal vielen Dank für deine Unterstützung!
      Davon finde ich im Log gar nichts, trotz des gesetzten Häkchens bei "Callback nutzen".
      Ich bin von der Konfiguration über den Start des Adapters bis zum Test (öffnen/schließen) noch einmal alles durchgegangen (siehe PDF-Datei im Anhang). Das Problem besteht aber weiterhin.
      Die Log-Datei im Anhang ist ebenfalls vom Start bis Test.
      Screenshots.pdf
      Log.txt
      Vielleicht siehst du in dem Log oder meinen Screenshots einen Fehler?
      ZefauZ 2 Antworten Letzte Antwort
      • S Sandmanyz
        Screenshots.pdf
        Log.txt
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        schrieb am zuletzt editiert von Zefau
        @Sandmanyz Wirklich sehr ausführlich dokumentiert, vielen Dank!
        Kannst du mir per PN schicken, was du unter http://<bridgeIp>:8080/callback/list?token=deinToken bekommst?
        EDIT: Sieht alles soweit gut aus im Log. Das wichtige Listening for Nuki events on port 51988 ist drin, aber der Event wird wohl nicht empfangen.
        • S Sandmanyz
          Screenshots.pdf
          Log.txt
          ZefauZ Offline
          ZefauZ Offline
          Zefau
          @Sandmanyz kannst du die aktuelle v1.0.2 von Github installieren und mir das Log nochmal bereitstellen?
          iobroker url https://github.com/Zefau/ioBroker.nuki2
          • ZefauZ Zefau
            Sandmanyz
            @Zefau
            Die Installation ist, soweit ich das als Leihe bewerten kann, sauber durchgelaufen. Ich konnte allerdings nirgends einen Hinweis auf die Version 1.0.2 finden. D.h., ich weiß jetzt nicht ob tatsächlich die 1.0.2 installiert ist.
            In der Adapterübersicht steht beim Nuki Adapter "Installierte Version: 1.0.1". Das Verhalten ist derzeit noch unverändert.
            nuki2.0	2019-08-12 21:23:43.505	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:23:28.506	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:23:13.493	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:22:58.492	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:22:43.472	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:22:28.478	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:22:13.458	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:21:58.466	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:21:43.450	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:21:28.461	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:21:13.451	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:20:58.459	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:20:43.426	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:20:29.917	info	Listening for Nuki events on port 51988.
            nuki2.0	2019-08-12 21:20:29.917	debug	Adding callback with URL http://192.168.xxx.x:51988/nuki-api-bridge to Nuki Bridge with name XXXXXXX.
            nuki2.0	2019-08-12 21:20:29.915	debug	Retrieved current callbacks from Nuki Bridge with name XXXXXXX: [{"domain":null,"_events":{},"_eventsCount":0,"_maxListeners":100,"connection":{"ip":"192.168.102.20","port":8080,"token":"8HIh0A","dela
            nuki2.0	2019-08-12 21:20:29.004	debug	getBridgeInfo(): {"deviceType":0,"nukiId":222222222,"name":"XXXXXXX","lastKnownState":{"mode":2,"state":1,"stateName":"locked","batteryCritical":false,"timestamp":"2019-08-12T19:12:24+00:00"},"nuki":{
            nuki2.0	2019-08-12 21:20:28.660	debug	State of nuki2.0.door__XXXXXXX.action has changed {"val":0,"ack":true,"ts":1115622628593,"q":0,"from":"system.adapter.nuki2.0","lc":1115622495570}.
            nuki2.0	2019-08-12 21:20:28.554	debug	updateLocks(): {"smartlockId":222222222,"accountId":999999999,"type":0,"authId":1234567,"name":"XXXXXXX","favorite":false,"config":{"name":"XXXXXXX","latitude":11.111111,"longitude":11.111111,"capabil
            nuki2.0	2019-08-12 21:20:28.399	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.nuki2, node: v8.16.0
            ZefauZ 1 Antwort Letzte Antwort
            • S Sandmanyz
              @Zefau
              ZefauZ Offline
              ZefauZ Offline
              Zefau
              @Sandmanyz habe vergessen die Version anzupassen, insofern passt v1.0.1. Das Log erhält auch die zusätzlichen Einträge, die ich hinzugefügt habe, aber merkwürdigerweise nicht alle.
              Kommst du per SSH oder Samba auf dein ioBroker und könntest mal etwas nachprüfen?
              Und zwar die Datei /opt/iobroker/node_modules/iobroker.nuki2/node_modules/nuki-bridge-api/package.json (oder wenn diese nicht existiert, dann /opt/iobroker/node_modules/nuki-bridge-api/package.json) hat einen Eintrag namens "version". Was steht da bei dir?
              • ZefauZ Zefau
                Sandmanyz
                Der Pfad /opt/iobroker/node_modules/iobroker.nuki2/node_modules/nuki-bridge-api bzw. der Ordner nuki-bridge-api existiert nicht. Der Pfad /opt/iobroker/node_modules/nuki-bridge-api/ hingegen ist vorhanden und es liegt auch die Datei package.json drin.
                Ich habe mal einen Screenshot gemacht....
                • S Sandmanyz
                  ZefauZ Offline
                  ZefauZ Offline
                  Zefau
                  @Sandmanyz Ok. Mist, ist die richtige Version ;-) Langsam weiß ich leider nicht weiter.
                  Der Log-Eintrag aus Zeile #L316 ist bei dir vorhanden (https://github.com/Zefau/ioBroker.nuki2/blob/master/nuki2.js#L316).
                  Aber weder der Log-Eintrag in #L322 noch in #L329 bzw. #L333 wird bei dir angezeigt, obwohl mindestens einer von diesen im Log stehen müsste.
                  • S Sandmanyz
                    ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    @Sandmanyz Wir können es allerdings "manuell" beheben, allerdings weiß ich nicht, ob das von Dauer ist.
                    1. Wenn du http://<bridge_ip>:<bridge_port>/callback/list?token=<bridgeToken> aufrufst
                    2. alle Einträge dort löschen mittels http://<bridge_ip>:<bridge_port>/callback/remove?id=<callback_id>&token=<bridgeToken>
                    3. den korrekten Eintrag manuell anlegen mittels http://<bridge_ip>:<bridge_port>/callback/add?url=http%3A%2F%2F<ioBrokerIp>%3A51988%2Fnuki-api-bridge&token=<bridgeToken>
                    EDIT: Kannst mir dann gerne nochmal die Ausgabe aus #1 vorher und nachher schicken, dann prüfe ich das nochmal quer.
                    • ZefauZ Zefau
                      Sandmanyz
                      Verflucht, nicht gelesen. Habe also keinen vorher Screenshot. Ich weiß nur, dass der Broker mit zwei Ports (8080 und 51988) eingetragen war und die IDs 0, 1 und 2 belegt waren. D.h., ich weiß nicht mehr was bei der dritten ID hinterlegt war.
                      Jetzt gibt es genau einen Eintrag: {"callbacks": [{"id": 0, "url": "http://192.168.xxx.x:51988/nuki-api-bridge"}]} (192.168.xxx.x = mein Broker).
                      Wenn ich den Link http://192.168.xxx.x:51988/nuki-api-bridge aufrufe erscheint im Browser Cannot GET /nuki-api-bridge. Soll das so?
                      Es scheint erst einmal zu funktionieren. Die Werte werden nun aktualisiert. Wie zuverlässig das ist, wird sich zeigen.
                      Vielen Dank für deine Unterstützung 👍
                      • S Sandmanyz
                        ZefauZ Offline
                        ZefauZ Offline
                        Zefau
                        @Sandmanyz sagte in [Neuer Adapter] Nuki:
                        Das ist richtig, da kein direkter Aufruf (/GET) unterstützt wird.
                        Freut mich, dass es (endlich) funktioniert.
                        • ZefauZ Zefau
                          Sandmanyz
                          @Zefau
                          Es war nicht von langer Dauer. Die Werte werden wieder nicht aktualisiert.
                          Habe nun den Adapter von @smaragdschlange installiert, welcher für den Smart Lock 2.0 funktioniert und erst einmal meine Zwecke erfüllt.
                          • S Sandmanyz
                            @Zefau
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            @Sandmanyz alles klar, sehr schade
                              Mercator
                              schrieb am zuletzt editiert von Mercator
                              @Zefau
                              Bei mir wurde noch nie bisher ein Wert in nuki2.0.bridge__nuki.callbacks eingetragen.
                              Sollten hier eventuell die Ergebnisse von :8080/callback/list stehen?
                              Darüber hinaus würde es mich interessieren, wieviele Sekunden es normalerweise bei dir/euch dauert zwischen dem Öffnen der Tür (sprich Aufleuchten der LED am Schloss) und Update im ioBroker durch den Callback (z.B. nuki2.0.door__meinNukiSchloss.status.refreshed)?
                              Hintergrund ist, dass ich per Script einen den Summer der Haustür betätige, sowie das Nuki per BLE die Wohnungstür geöffnet hat. Leider kommt der Callback aber erst nach ca. 10 - 20 Sekunden an, was dann eine gefühlte Ewigkeit ist, bis die Haustür aufgeht.
                              Gerne würde ich das so haben, dass nach 1-2 Sekunden, nachdem das Schloß bei Ankunft aufschließt, den Callback sendet und somit die Haustür öffnet.
                              (Ich nutze die HW Bridge + Nuki 2.0)
                              bergjetB 1 Antwort Letzte Antwort
                                Brati
                                schrieb am zuletzt editiert von Brati
                                @Zefau
                                Ich bekomme den Adapter auch nicht zum Laufen. Also grün ist er, aber der State stimmt nicht.
                                In der Nuki App ist der Status richtig, im Adapter wird nix aktualisiert. Web API habe ich auch schon aktiviert, direkt die Bridge auslesen würde mir aber reichen.
                                Der Versuch über
                                http://<NukiBridgeURL>:8080/lockState?nukiId=<NukiID>&token=<NukiToken>
                                führt zu
                                HTTP 401 Unauthorized
                                ID habe ich aus dem Adapter genommen und den Token vorher aus der Bridge.
                                Nächster Versuch über
                                gibt
                                {"callbacks": [{"id": 0, "url": "http://1*******:51988/nuki-api-bridge"}]}
                                Müsste dort bei 0 nicht auch die ID stehen?
                                Das Schloss ist erst 2 Wochen alt und hat die aktuelle FW.
                                Update
                                Der andere Adapter funktioniert.
                                Grüße
                                Brati
                                CCU2 - 46 Geräte, ioBroker auf Intel NUC (DN2820FYKH) mit Tab als Frontend, Projekt Gartenhaus mit HM
                                • M Mercator
                                  @Zefau
                                  bergjetB Offline
                                  bergjetB Offline
                                  bergjet
                                  @Mercator said in [Neuer Adapter] Nuki:
                                  Leider liefert Nuki das nicht schneller. Mindestens dauert es 20sek. Habe schon einmal an Nuki geschrieben, aber da kam nichts zurück.
                                  homee, ioBroker, iMac, iPhone, Sonos, Alaxa
                                    Brati
                                    Ich muss mich noch mal melden, weil doch keiner der Adapter zuverlässig läuft. Hatte nur keine Zeit mich drum zu kümmern. Es wird nur beim Adapter Start der Status eingelesen und dann nie wieder aktualisiert.
                                    In der App und Web stimmt er.
                                    Ich hatte die Bridge noch mal zurück gesetzt und über:
                                    stimmt der Status.
                                    {"mode": 2, "state": 1, "stateName": "locked", "batteryCritical": false, "success": true}
                                    Mit Aufruf von
                                    http://<NukiBridgeURL>/list?token=<NukiToken>
                                    Stimmt der Status nicht (es ist gerade abgeschlossen):
                                    [{"deviceType": 0, "nukiId": #####, "name": "####", "lastKnownState": {"mode": 2, "state": 3, "stateName": "unlocked", "batteryCritical": false, "timestamp": "2019-09-09T08:34:16+00:00"}}]
                                    Ich kann das Schloss auch über die Adapter bedienen. Callback ist dektiviert.
                                    Woran könnte es liegen?
                                    Grüße
                                    Brati
                                    • B Brati
                                      stimmt der Status.
                                      Mit Aufruf von
                                      Grüße
                                      Brati
                                      ZefauZ Offline
                                      ZefauZ Offline
                                      Zefau
                                      @Brati sagte in [Neuer Adapter] Nuki:
                                      Unabhängig vom Adapter muss der callback aktiviert sein, um die Status Änderung vom Nuki zu empfangen.
                                      • ZefauZ Zefau
                                        Brati
                                        @Zefau es war vorher eingeschaltet und der Adapter steht auf alle 5min periodisch aktualisieren.
                                        • ZefauZ Offline
                                          ZefauZ Offline
                                          Zefau
                                          Hab mir gerade den Nuki Opener gekauft. Im Zuge dessen habe ich einen 30 EUR Gutschein erhalten, den ich weitergeben darf. Sofern dieser genutzt wird, erhalte ich einen Nuki Fob.
                                          Gerne PN an mich, wenn jemand den 30 EUR Gutschein haben möchte.
                                          Viele Grüße
                                          Zefau
