  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 435.6k Aufrufe 64 Beobachtet
    @apollon77 ab 11:42...
    hmm hab jetzt mal iobroker stop, und wieder gestartet, läuft.. hmm.. vielleicht hab ich nicht lange genug gewartet..
    2019-11-13 11:35:30.912  - warn: host.iobroker Multihost discovery server: service started on 0.0.0.0:50005
    2019-11-13 11:41:29.432  - info: host.iobroker iobroker.js-controller version 2.0.43 js-controller starting
    2019-11-13 11:41:29.435  - info: host.iobroker Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    2019-11-13 11:41:29.436  - info: host.iobroker hostname: iobroker, node: v10.17.0
    2019-11-13 11:41:29.436  - info: host.iobroker ip addresses: 192.168.178.41 2001:16b8:20a3:f500:b01e:c80:4af8:2b16 fe80::9e97:b87d:9152:5695
    2019-11-13 11:41:30.270  - info: host.iobroker connected to Objects and States
    2019-11-13 11:41:30.513  - info: host.iobroker 71 instances found
    2019-11-13 11:41:30.593  - info: host.iobroker starting 64 instances
    2019-11-13 11:41:30.601  - warn: host.iobroker Multihost discovery server: service started on 0.0.0.0:50005
    2019-11-13 11:41:30.619  - info: host.iobroker instance system.adapter.admin.0 started with pid 833
    2019-11-13 11:41:34.609  - info: host.iobroker instance system.adapter.mihome.0 started with pid 855
    2019-11-13 11:41:38.609  - info: host.iobroker instance system.adapter.wifilight.0 started with pid 871
    2019-11-13 11:41:42.606  - info: host.iobroker instance system.adapter.amazon-dash.0 started with pid 887
    2019-11-13 11:41:46.607  - info: host.iobroker instance system.adapter.cloud.0 started with pid 913
    2019-11-13 11:41:50.610  - info: host.iobroker instance system.adapter.email.0 started with pid 928
    2019-11-13 11:41:54.611  - info: host.iobroker instance system.adapter.email.1 started with pid 943
    2019-11-13 11:41:58.603  - info: host.iobroker instance scheduled system.adapter.feiertage.0 0 0 * * *
    2019-11-13 11:41:58.618  - info: host.iobroker instance system.adapter.feiertage.0 started with pid 959
    2019-11-13 11:42:02.291  - info: host.iobroker instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
    2019-11-13 11:42:02.613  - info: host.iobroker instance system.adapter.firetv.0 started with pid 974
    2019-11-13 11:42:04.105  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.107  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.110  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.111  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.114  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.117  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:06.609  - info: host.iobroker instance system.adapter.history.0 started with pid 1004
    2019-11-13 11:42:09.594  - warn: history.0 (1004) Alias * has no target 12
    2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.zweiberry" is offline
    2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.zeroberry" is offline
    2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.berrymotion" is offline
    2019-11-13 11:42:10.197  - warn: host.iobroker "system.host.meterberry" is offline
    2019-11-13 11:42:10.197  - warn: host.iobroker "system.host.gymberry" is offline
    2019-11-13 11:42:10.611  - info: host.iobroker instance system.adapter.info.0 started with pid 1019
    2019-11-13 11:42:14.608  - info: host.iobroker instance system.adapter.javascript.0 started with pid 1039
    2019-11-13 11:42:18.799  - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 1545
    2019-11-13 11:42:20.717  - info: host.iobroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2019-11-13 11:42:20.720  - warn: host.iobroker "system.host.zweiberry" is offline
    #841
    @ilovegym Strange ... müssen wir beobachten
    ? 1 Antwort Letzte Antwort
    • apollon77A apollon77
      #842
      @apollon77 ich hab das unter "kann mal vorkommen" eingestuft.. solange das nicht öfters ist.. bis jetzt sonst keine Fehler im Log und auch keine Auffälligkeiten.. von daher..
        schmid_no1
        #843
        Nabend Jungs
        Habe die Version 2.0.24 noch installiert und wollte auch auf die 2.0.43 gehen und bekomme es nicht installiert bei
        "iobroker upgrade self"
        Kommt nur
        "host is up to date"
        Iobroker update habe ich gemacht
        Kann mir jemand sagen was ich falsch mache
        • S schmid_no1
          Nabend Jungs
          Kommt nur
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #844
          @schmid_no1
          Verwahrungsort
          • GlasfaserG Glasfaser
            @schmid_no1
            Verwahrungsort
            dslraserD Offline
            dslraserD Offline
            dslraser
            #845
            @Glasfaser sagte in js-controller 2.0 ab sofort im Latest Repo:
            @schmid_no1
            Verwahrungsort
            wurde/wird mir auch im latest nicht angezeigt.
            Ich habe iobroker gestoppt (im Docker Container) mit
            pkill io
            das dürfte ja sonst
            iobroker stop
            sein
            und dann Update mit
            npm install ioBroker/ioBroker.js-controller
            danach ist so
            aber angeboten wird es trotzdem nicht, auch nach
            iobroker update
            nicht.
            Verwahrungsort
            apollon77A GlasfaserG 2 Antworten Letzte Antwort
              schmid_no1
              schrieb am zuletzt editiert von schmid_no1
              #846
              @Glasfaser die Installation ist durchgelaufen doch leider zeigt es mir immer noch die alte Version an
              • S schmid_no1
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #847
                @schmid_no1
                Was hast du gemacht ……..
                Was ist mit dem Verwahrungsort !?
                ……. gerade selber auf meiner Synology durchgeführt . Update wurde durchgeführt
                Version 2.0.43
                  @schmid_no1
                  Version 2.0.43
                  schmid_no1
                  #848
                  @Glasfaser am Verwarungsort habe ich nichts geändert, also auf lastest gelassen und dann so installiert wie du das beschrieben hast
                  Er hat mir auch im putty gesagt das die 2.0.43 installiert ist.
                  Doch wenn ich mit iobroker version frage bekomme ich 2.0.25
                  • S schmid_no1
                    #849
                    @schmid_no1 „iobroker update“ mal ausgeführt?
                    S 2 Antworten Letzte Antwort
                    • dslraserD dslraser
                      @schmid_no1
                      Verwahrungsort
                      pkill io
                      das dürfte ja sonst
                      iobroker stop
                      sein
                      und dann Update mit
                      danach ist so
                      iobroker update
                      nicht.
                      Verwahrungsort
                      #850
                      @dslraser dann cached irgendwas bei euch das Repo file
                        @schmid_no1
                        Verwahrungsort
                        pkill io
                        das dürfte ja sonst
                        iobroker stop
                        sein
                        und dann Update mit
                        danach ist so
                        iobroker update
                        nicht.
                        Verwahrungsort
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        #851
                        @dslraser
                        Schalte mal die Kachel um , was kommt dann ?
                          schmid_no1
                          #852
                          @apollon77 ja habe ich
                          Aber scheint doch nicht so sauber durchgelaufen zu sein
                            schmid_no1
                            #853
                            @apollon77 wenn ich den Verwarungsort auf latest habe zeigt er mir bei verfügbar nur die 2.0.25 an
                            • S schmid_no1
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              #854
                              @schmid_no1
                              Kontrolliere bei dir den Eintrag :
                                @schmid_no1
                                schmid_no1
                                #855
                                @Glasfaser das passt
                                • S schmid_no1
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #856
                                  @schmid_no1
                                  Zeige mal bitte
                                  iobroker version
                                    @schmid_no1
                                    Zeige mal bitte
                                    iobroker version
                                    schmid_no1
                                    #857
                                    @Glasfaser im putty auch auf 2.0.25
                                    • S schmid_no1
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      #858
                                      @schmid_no1
                                      Reboot mal durchgeführt !?
                                        @schmid_no1
                                        schmid_no1
                                        #859
                                        @Glasfaser reboot update und Upgrade durchgeführt...... Leider ohne erfolg
                                        • S schmid_no1
                                          #860
                                          @schmid_no1 sagte in js-controller 2.0 ab sofort im Latest Repo:
                                          sicher dass auch ne Verbindung nach draussen besteht? :-)
