  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 526.6k Aufrufe 64 Beobachtet
  • SBorgS SBorg
    @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
    • (Apollon77) increase object init timeout for adapter starts before complaining/stopping
    betraf/betrifft das auch den "no connection to objekts db"-Fehler (oder gerade eben diesen)?
    Nach Update und Start:
    2019-11-13 11:38:50.229 - warn: tr-064-community.0 (14931) no connection to objects DB
    2019-11-13 11:38:50.243 - warn: tankerkoenig.0 (14634) no connection to objects DB
    2019-11-13 11:38:53.070 - warn: terminal.0 (14825) no connection to objects DB
    2019-11-13 11:38:53.912 - warn: tuya.0 (15103) no connection to objects DB
    2019-11-13 11:38:54.282 - warn: tr-064-community.0 (14931) no connection to states DB
    2019-11-13 11:38:54.838 - warn: vis-google-fonts.0 (15350) no connection to objects DB
    2019-11-13 11:38:56.750 - warn: tankerkoenig.0 (14634) no connection to states DB
    2019-11-13 11:38:56.864 - warn: terminal.0 (14825) no connection to states DB
    2019-11-13 11:38:57.161 - info: host.Ubuntu instance scheduled system.adapter.yr.0 33 * * * *
    2019-11-13 11:38:57.201 - info: host.Ubuntu instance system.adapter.yr.0 started with pid 15851
    2019-11-13 11:38:57.437 - warn: vis.0 (15525) no connection to objects DB
    2019-11-13 11:38:57.577 - info: radar2.0 (14026) radar2 initialization started...
    2019-11-13 11:38:57.580 - info: radar2.0 (14026) radar2 starting main...
    2019-11-13 11:38:59.619 - info: host.Ubuntu instance system.adapter.fb-checkpresence.0 started with pid 16025
    2019-11-13 11:39:01.789 - warn: tuya.0 (15103) no connection to states DB
    2019-11-13 11:39:01.792 - warn: vis.0 (15525) no connection to states DB
    2019-11-13 11:39:21.444 - info: radar2.0 (14026) Connected with '0.0.0.0' for DHCP Scan
    2019-11-13 11:39:21.940 - info: radar2.0 (14026) Will try to scan BT devices: true
    2019-11-13 11:39:23.830 - info: statistics.0 (14498) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.statistics, node: v8.16.2
    2019-11-13 11:39:30.503 - info: statistics.0 (14498) [INFO] statistics observes 1 values after startup
    2019-11-13 11:39:30.503 - info: statistics.0 (14498) [INFO] monitor "MyOwnData.0.Wetter.Ozon.Ozonwert" as avg
    2019-11-13 11:39:30.505 - info: statistics.0 (14498) [INFO] monitor "MyOwnData.0.Wetter.Ozon.Ozonwert" as minmax
    2019-11-13 11:39:33.364 - info: sonoff.0 (14322) Starting MQTT authenticated server on port 1885
    2019-11-13 11:39:33.665 - warn: upnp.0 (15260) no connection to objects DB
    2019-11-13 11:39:33.875 - warn: web.0 (15839) no connection to objects DB
    2019-11-13 11:39:33.885 - warn: yr.0 (15851) no connection to objects DB
    ...und weitere Connect-Fehler
    Daraufhin habe ich nochmal in den Einstellungen geschaut, der Connection-Timeout stand da (noch) auf 2000ms.
    Dann habe ich den ioB gestoppt, den Timeout händisch mal auf 3 Sek. gestellt und seit ~ 2 h ist absolute Ruhe, kein einziger Fehler mehr. Muss ich aber noch mal über einen ganzen Tag beobachten :)
    apollon77A
    apollon77A
    #840
    @SBorg Das betrifft genau diesen. Kannst es auf 2000 in den Settings lassen. Im Code wird der verdoppelt :-) Htte also auch schon vorher ruhig gewesen sein sollen. SOnst ist dein system echt komisch und braucht lange zum "hochfahren" eines Adapter-prozesses
      @apollon77 ab 11:42...
      hmm hab jetzt mal iobroker stop, und wieder gestartet, läuft.. hmm.. vielleicht hab ich nicht lange genug gewartet..
      2019-11-13 11:35:30.912  - warn: host.iobroker Multihost discovery server: service started on 0.0.0.0:50005
      2019-11-13 11:41:29.432  - info: host.iobroker iobroker.js-controller version 2.0.43 js-controller starting
      2019-11-13 11:41:29.435  - info: host.iobroker Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
      2019-11-13 11:41:29.436  - info: host.iobroker hostname: iobroker, node: v10.17.0
      2019-11-13 11:41:29.436  - info: host.iobroker ip addresses: 192.168.178.41 2001:16b8:20a3:f500:b01e:c80:4af8:2b16 fe80::9e97:b87d:9152:5695
      2019-11-13 11:41:30.270  - info: host.iobroker connected to Objects and States
      2019-11-13 11:41:30.513  - info: host.iobroker 71 instances found
      2019-11-13 11:41:30.593  - info: host.iobroker starting 64 instances
      2019-11-13 11:41:30.601  - warn: host.iobroker Multihost discovery server: service started on 0.0.0.0:50005
      2019-11-13 11:41:30.619  - info: host.iobroker instance system.adapter.admin.0 started with pid 833
      2019-11-13 11:41:34.609  - info: host.iobroker instance system.adapter.mihome.0 started with pid 855
      2019-11-13 11:41:38.609  - info: host.iobroker instance system.adapter.wifilight.0 started with pid 871
      2019-11-13 11:41:42.606  - info: host.iobroker instance system.adapter.amazon-dash.0 started with pid 887
      2019-11-13 11:41:46.607  - info: host.iobroker instance system.adapter.cloud.0 started with pid 913
      2019-11-13 11:41:50.610  - info: host.iobroker instance system.adapter.email.0 started with pid 928
      2019-11-13 11:41:54.611  - info: host.iobroker instance system.adapter.email.1 started with pid 943
      2019-11-13 11:41:58.603  - info: host.iobroker instance scheduled system.adapter.feiertage.0 0 0 * * *
      2019-11-13 11:41:58.618  - info: host.iobroker instance system.adapter.feiertage.0 started with pid 959
      2019-11-13 11:42:02.291  - info: host.iobroker instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
      2019-11-13 11:42:02.613  - info: host.iobroker instance system.adapter.firetv.0 started with pid 974
      2019-11-13 11:42:04.105  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
      2019-11-13 11:42:04.107  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
      2019-11-13 11:42:04.110  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
      2019-11-13 11:42:04.111  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
      2019-11-13 11:42:04.114  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
      2019-11-13 11:42:04.117  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
      2019-11-13 11:42:06.609  - info: host.iobroker instance system.adapter.history.0 started with pid 1004
      2019-11-13 11:42:09.594  - warn: history.0 (1004) Alias * has no target 12
      2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.zweiberry" is offline
      2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.zeroberry" is offline
      2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.berrymotion" is offline
      2019-11-13 11:42:10.197  - warn: host.iobroker "system.host.meterberry" is offline
      2019-11-13 11:42:10.197  - warn: host.iobroker "system.host.gymberry" is offline
      2019-11-13 11:42:10.611  - info: host.iobroker instance system.adapter.info.0 started with pid 1019
      2019-11-13 11:42:14.608  - info: host.iobroker instance system.adapter.javascript.0 started with pid 1039
      2019-11-13 11:42:18.799  - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 1545
      2019-11-13 11:42:20.717  - info: host.iobroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      2019-11-13 11:42:20.720  - warn: host.iobroker "system.host.zweiberry" is offline
      apollon77A
      apollon77A
      #841
      @ilovegym Strange ... müssen wir beobachten
      • apollon77A apollon77
        #842
        @apollon77 ich hab das unter "kann mal vorkommen" eingestuft.. solange das nicht öfters ist.. bis jetzt sonst keine Fehler im Log und auch keine Auffälligkeiten.. von daher..
        • S
          S
          schmid_no1
          #843
          Nabend Jungs
          Habe die Version 2.0.24 noch installiert und wollte auch auf die 2.0.43 gehen und bekomme es nicht installiert bei
          "iobroker upgrade self"
          Kommt nur
          "host is up to date"
          Iobroker update habe ich gemacht
          Kann mir jemand sagen was ich falsch mache
          • S schmid_no1
            Nabend Jungs
            Kommt nur
            GlasfaserG
            GlasfaserG
            #844
            @schmid_no1
            Verwahrungsort
            • GlasfaserG Glasfaser
              @schmid_no1
              Verwahrungsort
              dslraserD
              dslraserD
              dslraser
              #845
              @Glasfaser sagte in js-controller 2.0 ab sofort im Latest Repo:
              @schmid_no1
              Verwahrungsort
              wurde/wird mir auch im latest nicht angezeigt.
              Ich habe iobroker gestoppt (im Docker Container) mit
              pkill io
              das dürfte ja sonst
              iobroker stop
              sein
              und dann Update mit
              npm install ioBroker/ioBroker.js-controller
              danach ist so
              aber angeboten wird es trotzdem nicht, auch nach
              iobroker update
              nicht.
              Verwahrungsort
              apollon77A GlasfaserG 2 Antworten Letzte Antwort
              • S
                S
                schmid_no1
                schrieb am zuletzt editiert von schmid_no1
                #846
                @Glasfaser die Installation ist durchgelaufen doch leider zeigt es mir immer noch die alte Version an
                • S schmid_no1
                  GlasfaserG
                  GlasfaserG
                  #847
                  @schmid_no1
                  Was hast du gemacht ……..
                  Was ist mit dem Verwahrungsort !?
                  ……. gerade selber auf meiner Synology durchgeführt . Update wurde durchgeführt
                  Version 2.0.43
                    @schmid_no1
                    Version 2.0.43
                    S
                    S
                    schmid_no1
                    #848
                    @Glasfaser am Verwarungsort habe ich nichts geändert, also auf lastest gelassen und dann so installiert wie du das beschrieben hast
                    Er hat mir auch im putty gesagt das die 2.0.43 installiert ist.
                    Doch wenn ich mit iobroker version frage bekomme ich 2.0.25
                    • S schmid_no1
                      apollon77A
                      apollon77A
                      #849
                      @schmid_no1 „iobroker update“ mal ausgeführt?
                      S 2 Antworten Letzte Antwort
                      • dslraserD dslraser
                        @schmid_no1
                        Verwahrungsort
                        pkill io
                        das dürfte ja sonst
                        iobroker stop
                        sein
                        und dann Update mit
                        danach ist so
                        iobroker update
                        nicht.
                        Verwahrungsort
                        apollon77A
                        apollon77A
                        #850
                        @dslraser dann cached irgendwas bei euch das Repo file
                          @schmid_no1
                          Verwahrungsort
                          pkill io
                          das dürfte ja sonst
                          iobroker stop
                          sein
                          und dann Update mit
                          danach ist so
                          iobroker update
                          nicht.
                          Verwahrungsort
                          GlasfaserG
                          GlasfaserG
                          #851
                          @dslraser
                          Schalte mal die Kachel um , was kommt dann ?
                            S
                            S
                            schmid_no1
                            #852
                            @apollon77 ja habe ich
                            Aber scheint doch nicht so sauber durchgelaufen zu sein
                              S
                              S
                              schmid_no1
                              #853
                              @apollon77 wenn ich den Verwarungsort auf latest habe zeigt er mir bei verfügbar nur die 2.0.25 an
                              • S schmid_no1
                                GlasfaserG
                                GlasfaserG
                                #854
                                @schmid_no1
                                Kontrolliere bei dir den Eintrag :
                                  @schmid_no1
                                  S
                                  S
                                  schmid_no1
                                  #855
                                  @Glasfaser das passt
                                  • S schmid_no1
                                    GlasfaserG
                                    GlasfaserG
                                    #856
                                    @schmid_no1
                                    Zeige mal bitte
                                    iobroker version
                                      @schmid_no1
                                      Zeige mal bitte
                                      iobroker version
                                      S
                                      S
                                      schmid_no1
                                      #857
                                      @Glasfaser im putty auch auf 2.0.25
                                      • S schmid_no1
                                        GlasfaserG
                                        GlasfaserG
                                        #858
                                        @schmid_no1
                                        Reboot mal durchgeführt !?
                                          @schmid_no1
                                          S
                                          S
                                          schmid_no1
                                          #859
                                          @Glasfaser reboot update und Upgrade durchgeführt...... Leider ohne erfolg
                                          33.2k
                                          84.3k
