  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 526.5k Aufrufe 64 Beobachtet
  • apollon77A apollon77
    @ilovegym sagte in js-controller 2.0 ab sofort im Latest Repo:
    ok ich checke bei mir nochmal, aber daran hab ich an sich nix gedreht ... mal schauen ...
    Wann war denn der Master wieder da genau?
    #839
    @apollon77 ab 11:42...
    hmm hab jetzt mal iobroker stop, und wieder gestartet, läuft.. hmm.. vielleicht hab ich nicht lange genug gewartet..
    2019-11-13 11:35:30.912  - warn: host.iobroker Multihost discovery server: service started on 0.0.0.0:50005
    2019-11-13 11:41:29.432  - info: host.iobroker iobroker.js-controller version 2.0.43 js-controller starting
    2019-11-13 11:41:29.435  - info: host.iobroker Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    2019-11-13 11:41:29.436  - info: host.iobroker hostname: iobroker, node: v10.17.0
    2019-11-13 11:41:29.436  - info: host.iobroker ip addresses: 192.168.178.41 2001:16b8:20a3:f500:b01e:c80:4af8:2b16 fe80::9e97:b87d:9152:5695
    2019-11-13 11:41:30.270  - info: host.iobroker connected to Objects and States
    2019-11-13 11:41:30.513  - info: host.iobroker 71 instances found
    2019-11-13 11:41:30.593  - info: host.iobroker starting 64 instances
    2019-11-13 11:41:30.601  - warn: host.iobroker Multihost discovery server: service started on 0.0.0.0:50005
    2019-11-13 11:41:30.619  - info: host.iobroker instance system.adapter.admin.0 started with pid 833
    2019-11-13 11:41:34.609  - info: host.iobroker instance system.adapter.mihome.0 started with pid 855
    2019-11-13 11:41:38.609  - info: host.iobroker instance system.adapter.wifilight.0 started with pid 871
    2019-11-13 11:41:42.606  - info: host.iobroker instance system.adapter.amazon-dash.0 started with pid 887
    2019-11-13 11:41:46.607  - info: host.iobroker instance system.adapter.cloud.0 started with pid 913
    2019-11-13 11:41:50.610  - info: host.iobroker instance system.adapter.email.0 started with pid 928
    2019-11-13 11:41:54.611  - info: host.iobroker instance system.adapter.email.1 started with pid 943
    2019-11-13 11:41:58.603  - info: host.iobroker instance scheduled system.adapter.feiertage.0 0 0 * * *
    2019-11-13 11:41:58.618  - info: host.iobroker instance system.adapter.feiertage.0 started with pid 959
    2019-11-13 11:42:02.291  - info: host.iobroker instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
    2019-11-13 11:42:02.613  - info: host.iobroker instance system.adapter.firetv.0 started with pid 974
    2019-11-13 11:42:04.105  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.107  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.110  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.111  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.114  - error: firetv.0 (974) ID: 192.168.178.83 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:04.117  - error: firetv.0 (974) ID: 192.168.178.85 Error=Failure: 'device unauthorized. Please check the confirmation dialog on your device.'
    2019-11-13 11:42:06.609  - info: host.iobroker instance system.adapter.history.0 started with pid 1004
    2019-11-13 11:42:09.594  - warn: history.0 (1004) Alias * has no target 12
    2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.zweiberry" is offline
    2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.zeroberry" is offline
    2019-11-13 11:42:10.196  - warn: host.iobroker "system.host.berrymotion" is offline
    2019-11-13 11:42:10.197  - warn: host.iobroker "system.host.meterberry" is offline
    2019-11-13 11:42:10.197  - warn: host.iobroker "system.host.gymberry" is offline
    2019-11-13 11:42:10.611  - info: host.iobroker instance system.adapter.info.0 started with pid 1019
    2019-11-13 11:42:14.608  - info: host.iobroker instance system.adapter.javascript.0 started with pid 1039
    2019-11-13 11:42:18.799  - info: host.iobroker instance system.adapter.mihome-vacuum.0 started with pid 1545
    2019-11-13 11:42:20.717  - info: host.iobroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2019-11-13 11:42:20.720  - warn: host.iobroker "system.host.zweiberry" is offline
    • SBorgS SBorg
      @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
      • (Apollon77) increase object init timeout for adapter starts before complaining/stopping
      betraf/betrifft das auch den "no connection to objekts db"-Fehler (oder gerade eben diesen)?
      Nach Update und Start:
      2019-11-13 11:38:50.229 - warn: tr-064-community.0 (14931) no connection to objects DB
      2019-11-13 11:38:50.243 - warn: tankerkoenig.0 (14634) no connection to objects DB
      2019-11-13 11:38:53.070 - warn: terminal.0 (14825) no connection to objects DB
      2019-11-13 11:38:53.912 - warn: tuya.0 (15103) no connection to objects DB
      2019-11-13 11:38:54.282 - warn: tr-064-community.0 (14931) no connection to states DB
      2019-11-13 11:38:54.838 - warn: vis-google-fonts.0 (15350) no connection to objects DB
      2019-11-13 11:38:56.750 - warn: tankerkoenig.0 (14634) no connection to states DB
      2019-11-13 11:38:56.864 - warn: terminal.0 (14825) no connection to states DB
      2019-11-13 11:38:57.161 - info: host.Ubuntu instance scheduled system.adapter.yr.0 33 * * * *
      2019-11-13 11:38:57.201 - info: host.Ubuntu instance system.adapter.yr.0 started with pid 15851
      2019-11-13 11:38:57.437 - warn: vis.0 (15525) no connection to objects DB
      2019-11-13 11:38:57.577 - info: radar2.0 (14026) radar2 initialization started...
      2019-11-13 11:38:57.580 - info: radar2.0 (14026) radar2 starting main...
      2019-11-13 11:38:59.619 - info: host.Ubuntu instance system.adapter.fb-checkpresence.0 started with pid 16025
      2019-11-13 11:39:01.789 - warn: tuya.0 (15103) no connection to states DB
      2019-11-13 11:39:01.792 - warn: vis.0 (15525) no connection to states DB
      2019-11-13 11:39:21.444 - info: radar2.0 (14026) Connected with '0.0.0.0' for DHCP Scan
      2019-11-13 11:39:21.940 - info: radar2.0 (14026) Will try to scan BT devices: true
      2019-11-13 11:39:23.830 - info: statistics.0 (14498) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.statistics, node: v8.16.2
      2019-11-13 11:39:30.503 - info: statistics.0 (14498) [INFO] statistics observes 1 values after startup
      2019-11-13 11:39:30.503 - info: statistics.0 (14498) [INFO] monitor "MyOwnData.0.Wetter.Ozon.Ozonwert" as avg
      2019-11-13 11:39:30.505 - info: statistics.0 (14498) [INFO] monitor "MyOwnData.0.Wetter.Ozon.Ozonwert" as minmax
      2019-11-13 11:39:33.364 - info: sonoff.0 (14322) Starting MQTT authenticated server on port 1885
      2019-11-13 11:39:33.665 - warn: upnp.0 (15260) no connection to objects DB
      2019-11-13 11:39:33.875 - warn: web.0 (15839) no connection to objects DB
      2019-11-13 11:39:33.885 - warn: yr.0 (15851) no connection to objects DB
      ...und weitere Connect-Fehler
      Daraufhin habe ich nochmal in den Einstellungen geschaut, der Connection-Timeout stand da (noch) auf 2000ms.
      Dann habe ich den ioB gestoppt, den Timeout händisch mal auf 3 Sek. gestellt und seit ~ 2 h ist absolute Ruhe, kein einziger Fehler mehr. Muss ich aber noch mal über einen ganzen Tag beobachten :)
      apollon77A
      apollon77A
      #840
      @SBorg Das betrifft genau diesen. Kannst es auf 2000 in den Settings lassen. Im Code wird der verdoppelt :-) Htte also auch schon vorher ruhig gewesen sein sollen. SOnst ist dein system echt komisch und braucht lange zum "hochfahren" eines Adapter-prozesses
        apollon77A
        apollon77A
        #841
        @ilovegym Strange ... müssen wir beobachten
          #842
          @apollon77 ich hab das unter "kann mal vorkommen" eingestuft.. solange das nicht öfters ist.. bis jetzt sonst keine Fehler im Log und auch keine Auffälligkeiten.. von daher..
          • S
            S
            schmid_no1
            #843
            Nabend Jungs
            Habe die Version 2.0.24 noch installiert und wollte auch auf die 2.0.43 gehen und bekomme es nicht installiert bei
            "iobroker upgrade self"
            Kommt nur
            "host is up to date"
            Iobroker update habe ich gemacht
            Kann mir jemand sagen was ich falsch mache
            • S schmid_no1
              Nabend Jungs
              Kommt nur
              GlasfaserG
              GlasfaserG
              #844
              @schmid_no1
              Verwahrungsort
              • GlasfaserG Glasfaser
                @schmid_no1
                Verwahrungsort
                dslraserD
                dslraserD
                dslraser
                #845
                @Glasfaser sagte in js-controller 2.0 ab sofort im Latest Repo:
                @schmid_no1
                Verwahrungsort
                wurde/wird mir auch im latest nicht angezeigt.
                Ich habe iobroker gestoppt (im Docker Container) mit
                pkill io
                das dürfte ja sonst
                iobroker stop
                sein
                und dann Update mit
                npm install ioBroker/ioBroker.js-controller
                danach ist so
                aber angeboten wird es trotzdem nicht, auch nach
                iobroker update
                nicht.
                Verwahrungsort
                apollon77A GlasfaserG 2 Antworten Letzte Antwort
                • S
                  S
                  schmid_no1
                  schrieb am zuletzt editiert von schmid_no1
                  #846
                  @Glasfaser die Installation ist durchgelaufen doch leider zeigt es mir immer noch die alte Version an
                  • S schmid_no1
                    GlasfaserG
                    GlasfaserG
                    #847
                    @schmid_no1
                    Was hast du gemacht ……..
                    Was ist mit dem Verwahrungsort !?
                    ……. gerade selber auf meiner Synology durchgeführt . Update wurde durchgeführt
                    Version 2.0.43
                      @schmid_no1
                      Version 2.0.43
                      S
                      S
                      schmid_no1
                      #848
                      @Glasfaser am Verwarungsort habe ich nichts geändert, also auf lastest gelassen und dann so installiert wie du das beschrieben hast
                      Er hat mir auch im putty gesagt das die 2.0.43 installiert ist.
                      Doch wenn ich mit iobroker version frage bekomme ich 2.0.25
                      • S schmid_no1
                        apollon77A
                        apollon77A
                        #849
                        @schmid_no1 „iobroker update“ mal ausgeführt?
                        S 2 Antworten Letzte Antwort
                        • dslraserD dslraser
                          @schmid_no1
                          Verwahrungsort
                          pkill io
                          das dürfte ja sonst
                          iobroker stop
                          sein
                          und dann Update mit
                          danach ist so
                          iobroker update
                          nicht.
                          Verwahrungsort
                          apollon77A
                          apollon77A
                          #850
                          @dslraser dann cached irgendwas bei euch das Repo file
                            @schmid_no1
                            Verwahrungsort
                            pkill io
                            das dürfte ja sonst
                            iobroker stop
                            sein
                            und dann Update mit
                            danach ist so
                            iobroker update
                            nicht.
                            Verwahrungsort
                            GlasfaserG
                            GlasfaserG
                            #851
                            @dslraser
                            Schalte mal die Kachel um , was kommt dann ?
                              S
                              S
                              schmid_no1
                              #852
                              @apollon77 ja habe ich
                              Aber scheint doch nicht so sauber durchgelaufen zu sein
                                S
                                S
                                schmid_no1
                                #853
                                @apollon77 wenn ich den Verwarungsort auf latest habe zeigt er mir bei verfügbar nur die 2.0.25 an
                                • S schmid_no1
                                  GlasfaserG
                                  GlasfaserG
                                  #854
                                  @schmid_no1
                                  Kontrolliere bei dir den Eintrag :
                                    @schmid_no1
                                    S
                                    S
                                    schmid_no1
                                    #855
                                    @Glasfaser das passt
                                    • S schmid_no1
                                      GlasfaserG
                                      GlasfaserG
                                      #856
                                      @schmid_no1
                                      Zeige mal bitte
                                      iobroker version
                                        @schmid_no1
                                        Zeige mal bitte
                                        iobroker version
                                        S
                                        S
                                        schmid_no1
                                        #857
                                        @Glasfaser im putty auch auf 2.0.25
                                        • S schmid_no1
                                          GlasfaserG
                                          GlasfaserG
                                          #858
                                          @schmid_no1
                                          Reboot mal durchgeführt !?
                                          33.2k
                                          84.3k
