  4. js-controller 2.0 ab sofort im Latest Repo
    6.5k
js-controller
1.1k Beiträge 89 Kommentatoren 437.6k Aufrufe 64 Beobachtet
  • NightlyN Nightly
    Hallo, beim Updaten auf js-controller 2.2.9 kommen diverse Fehlermeldungen. Nach dem Update funktioniert alles soweit, ausser dass beim Updaten von Adaptern der selbe Fehler ebenso kommt. Danke für Hinweise, was unternommen werden kann.
    root@ioBroker2:~# iobroker upgrade self
    Update js-controller from @1.5.3 to @2.2.9
    NPM version: 4.6.1
    npm install iobroker.js-controller@2.2.9 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
     #include <security/pam_appl.h>
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.9.0-8-amd64
    gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v8.11.3
    gyp ERR! node-gyp -v v3.6.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none was installed.
    npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none was installed.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    Host "ioBroker2" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    Update von Adapter:
    $ ./iobroker upgrade cloud
    Update cloud from @3.0.2 to @3.0.3
    NPM version: 4.6.1
    npm install iobroker.cloud@3.0.3 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security/pam_appl.h>                               ^compilation terminated.
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR!
     stack     at emitTwo (events.js:126:13)gyp ERR! stack     at ChildProcess.emit (events.js:214:7)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
     ERR! System Linux 4.9.0-8-amd64gyp ERR! command "/root/.nvm/versions/node/v8.11.3/bin/node" "/root/.nvm/versions/node/v8.11.3/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd
     /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v8.11.3gyp ERR! node-gyp -v v3.6.0gyp ERR! not ok
    upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
    Update "system.adapter.cloud.0"
    upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
    upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index.html index.html text/html
    upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
    upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
    upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
    upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
    Adapter "cloud" updated
    process exited with code 0
    #1041
    @Nightly sagte:
    NPM version: 4.6.1
    Die Version ist sehr alt.
      @Nightly sagte:
      NPM version: 4.6.1
      #1042
      @paul53 said in js-controller 2.0 ab sofort im Latest Repo:
      Nicht nur alt, sondern auch schief installiert.
        @Nightly node falsch installiert (und in einer zu niedrigen Version für iobroker 2.2.9, denke ich) .
        Und melde dich als root ab! Das wird als normaler user ausgeführt. (Es sei denn, das läuft im Docker ab...)
        NightlyN Offline
        NightlyN Offline
        Nightly
        #1043
        @Thomas-Braun Was meinst du mit "falsch"/"schief" installiert? Unterschiedliche Versionen von nodejs und node? Hatte da vor einiger Zeit Probleme mit yahka Adapter, als ich zu aktuell war, und musste da mühsam zurück. Seit dann habe ich's gelassen ;)
        Bezüglich root schaue ich mir an.
        • NightlyN Nightly
          #1044
          @Nightly said in js-controller 2.0 ab sofort im Latest Repo:
          Das sieht man. Die Baustelle ist zugemüllt.
          Was gibt es dann da 'anzuschauen?
          NightlyN 1 Antwort Letzte Antwort
            NightlyN Offline
            NightlyN Offline
            Nightly
            #1045
            @Thomas-Braun Willst du mir helfen, oder nur rummeckern? Die Frage was du mit falsch/schief meinst hast du nicht beantwortet. Das würde weiter helfen. Dankeschön.
            • NightlyN Nightly
              #1046
              @Nightly Du kannst Hilfe bekommen:
              Die Versionen von node und nodejs müssen übereinstimmen. Soweit zu falsch.
              Schief ist das, weil die abweichende Version 'irgendwie' händisch in das System geknüppelt wurde.
              Und dann ist die Version 8 zu alt für den js-controller 2.2.9.
              Wir können das Problem angehen, dann aber auf einem 'sauberen' Grundsystem. Mit korrektem user login und nicht als 'root' eingeloggt.
              Vermutlich kommt die schiefe Installation nämlich dadurch erst zustande.
                NightlyN Offline
                NightlyN Offline
                Nightly
                #1047
                @Thomas-Braun Vielen Dank für die Klärung. Wie erwähnt musste ich da mit nodejs und node Verseionen hin und her probieren, bis yahka wieder lief. Ich schaue mir das die nächsten Tage an, wie ich in meinem Clone vorgehe, um alles geordnet upzudaten, und dass dann alles noch funktioniert.
                Aber Version 8 ist nicht zu alt für js-controller 2x (siehe hier) :
                • Ab der Version 2.0 des js-controllers (das Freigabedatum ist noch nicht bekannt) sind die Anpassungen so tiefgreifend, dass die Node.js-Versionen 4 und 6 nicht mehr unterstützt werden können.
                • Ab Version 3.0 vom Controller, der gerade (Stand 24.4.2020) im Latest Repository ist, wird Nodejs 10.x Minimum sein.
                • NightlyN Nightly
                  #1048
                  @Nightly Nur ist node8 schon längst obsolet. Wird nicht mehr supportet.
                  Der Eintrag von Stabilostick ist auch vom 1 Jun 2019, 02:46
                  Also mindestens 10 ist da heute angesagt.
                  https://nodejs.org/en/about/releases/
                    NightlyN Offline
                    NightlyN Offline
                    Nightly
                    #1049
                    @Thomas-Braun So, habe ne aktuelle buster Disti installiert und den ioBroker migriert. Ein ganzes Stück Arbeit. Insbesondere musste das gesamte Homekit auf dem Phone neu verbunden und neu konfiguriert werden, da mit den bestehender Einstellung auf dem Phone nicht zu yahka verbunden werden konnte. Werde wohl oder übel wieder einige Zeit auf diesem Stand bleiben, bis das nächste grosse Update gezwungenermassen ansteht. Danke für den Hint bez. nodejs/node Versionen. Und läuft jetzt auch im Userkontext.
                    • NightlyN Nightly
                      #1050
                      @Nightly Das schaut doch schon mal ganz ordentlich aus.
                      Richtig schön wäre, wenn du dich auch nicht als iobroker einloggen würdest. Das ist ein system user.
                      • MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        schrieb am zuletzt editiert von MathiasJ
                        #1051
                        Ich dachte, diese Version wäre schon Asbach Uralt?
                        Es gibt doch schon die Version 3.x oder irre ich?
                        https://forum.iobroker.net/topic/32481/js-controller-3-0-jetzt-im-latest
                        IObroker auf dem NUC als VM.
                        • MathiasJM MathiasJ
                          #1052
                          @MathiasJ der controller 3.x ist erst im Latest, aber ich denke so in 1-2 Wochen sind wir damit im Stable
