  4. Test Adapter enigma2 v1.2.x
    6.5k
adapterenigma2
640 Beiträge 71 Kommentatoren 219.7k Aufrufe 60 Beobachtet
  • NegaleinN Negalein
    Ich bekomm seit JS-Controller 3.3.14 laufend solche Meldungen.
    enigma2.0 | 2021-07-08 16:04:56.849 | info | State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
    enigma2.0 | 2021-07-08 16:04:56.848 | info | State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
    enigma2.0 | 2021-07-08 16:04:56.844 | info | State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
    Matten MattenM Offline
    Matten Matten
    #441
    @negalein sagte in Test Adapter enigma2 v1.2.x:
    Bitte den Adapter neu installieren.
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
      @negalein
      Wird denn der Adapter überhaupt noch betreut?
      Matten Matten
      #442
      Nicht aktiv, nein
      • Matten MattenM Matten Matten
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #443
        @matten-matten sagte in Test Adapter enigma2 v1.2.x:
        Das wars.
        Nun kommt aber was neues.
        enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_FREE" has no existing object, this might lead to an error in future versions
        enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_CAPACITY" has no existing object, this might lead to an error in future versions
        enigma2.0 2021-07-08 16:57:47.334	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
        enigma2.0 2021-07-08 16:57:43.350	info	enigma2 Verbunden!
        enigma2.0 2021-07-08 16:57:38.304	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
        enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
        enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
        enigma2.0 2021-07-08 16:57:38.284	info	starting Polling every 5000 ms
        enigma2.0 2021-07-08 16:57:38.261	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.17.1, js-controller: 3.3.14
        ° Fixer ---> iob fix
        Matten MattenM J 2 Antworten Letzte Antwort
          Das wars.
          Matten Matten
          #444
          Das wars.
          Hast du die Instanzen vorher einmal gelöscht. Dann den Adapter neu installieren dann am besten ein Upload und die Instanzen neu anlegen.
          Gruß.
          NegaleinN oberfraggerO 2 Antworten Letzte Antwort
            Das wars.
            Jan1
            #445
            @negalein
            Greif mal auf die HDD zu, wenn die schläft bekommt der Adapter keine Daten ;)
              Das wars.
              Gruß.
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #446
              Nein.
              Hab den Adapter gelöscht, installiert und Instanz erzeugt.
              Hab nochmal einen Upload gemacht. Funktioniert! :)
              Wo kommt der leere Admin Ordner her? Ist der eventuell noch von vorher?
              Kann ich den löschen oder hat er eine Funktion?
              J 1 Antwort Letzte Antwort
                Nein.
                Jan1
                #447
                @negalein
                Einen leeren Admin Ordner habe ich bei jedem Adapter in den Objekten.
                • J Jan1
                  @negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #448
                  @jan1 sagte in Test Adapter enigma2 v1.2.x:
                  stimmt. Hab gerade nachgeschaut.
                  Wird wohl mit Admin 5 zusammenhängen.
                    Jan1
                    #449
                    @negalein
                    Seit dem Umstieg sind die zumindest mal da. Was das soll frage ich mich aber auch. Da es nicht wirklich stört, wird es aber auch ein Sinn haben.
                    Hatte übrigens die selben Meldungen wie Du im Log wegen der HDD und erst nach dem ich die aus dem Sleep geholt hatte und der Adapter die Werte lesen konnte war Ruhe.
                      Das wars.
                      Gruß.
                      oberfraggerO Offline
                      oberfragger
                      #450
                      @matten-matten said in Test Adapter enigma2 v1.2.x:
                      Moin,
                      ich habe das so gemacht wie beschrieben. Vor der Neuinstallation der Instanzen noch die Objekte gelöscht. Leider bekomme ich noch folgendes:
                      enigma2.0
                      2021-08-10 22:20:22.561	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
                      enigma2.0
                      2021-08-10 22:20:15.151	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
                      enigma2.0
                      2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
                      enigma2.0
                      2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
                        #451
                        Hat sich eigentlich inzwischen ein Maintainer für den enigma2 Adapter gefunden?
                        Für admin 5 müsste da was angepasst werden
                          TiDO
                          #452
                          bekomme aktuell folgende Fehler:
                          enigma2.0
                          	2021-09-02 21:52:58.817	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
                          enigma2.0
                          	2021-09-02 21:52:53.832	info	State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
                          enigma2.0
                          	2021-09-02 21:52:53.829	info	State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
                          enigma2.0
                          	2021-09-02 21:52:53.813	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
                          jemand eine Idee?
                          liegt das am js-controller 3.3.15?
                          • T TiDO
                            enigma2.0
                            enigma2.0
                            enigma2.0
                            enigma2.0
                            jemand eine Idee?
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #453
                            @tido
                            Alle Datenpunkte vom enigma löschen und den Adapter neu installieren
                            https://forum.iobroker.net/topic/25112/test-adapter-enigma2-v1-2-x/441
                            B 1 Antwort Letzte Antwort
                            • GlasfaserG Glasfaser
                              @tido
                              biker1602
                              #454
                              Ich habe mich jetzt auch mal, mit dem Adapter beschäftigt um mit einem Blockly zu arbeiten.
                              Ich habe eine VU+Duo2 mit Open ATV Image, und es wird mir unter Objekte alles angezeigt, aber mein Problem ist, zum einen, dass ich die Box zwar in den DeepStandby versetzen kann, aber nicht wieder eingeschaltet bekomme. Es stehen ja auch nur die Werte true und false zur Verfügung, die sich automatisch auch nicht ändern.
                              Das macht mich irgendwie stutzig. Kann mir da jemand helfen?
                              E B SBorgS 3 Antworten Letzte Antwort
                              • B biker1602
                                el_malto
                                #455
                                @biker1602 beim DeepStandby wird der Receiver komplett heruntergefahren. Sprich, es ist auch kein Netzwerk mehr verfügbar und somit kannst du den Receiver darüber nicht aus dem DeppStandby holen. Das geht dann nur noch mit der Fernbedienung. Wenn du den Receiver immer über ioBroker steuern willst, musst du den nur in den normalen Standby schicken.
                                Als abhilfe könnte hier vielleicht so eine Logitech Harmony sein? Weiß nicht ob man die quasi als "Brücke" nehmen kann.
                                • B biker1602
                                  B Online
                                  B Online
                                  bombaman
                                  #456
                                  @biker1602 Du kannst über eine schaltbare Steckdose den Strom wegnehmen. Wenn du die dann wieder einschaltest dann startet der Receiver.
                                  • B biker1602
                                    SBorgS Offline
                                    SBorgS Offline
                                    SBorg
                                    #457
                                    Hat die VU+Duo2 nicht WoL (was noch immer selbst bei der aktuellen DreamBox fehlt... :( ) ?
                                    @biker1602
                                    Hast du irgendwo was im Menü mit "Wake on LAN" (sorry, DreamBox-Nutzer ;) ) ? Dann kannst du sie darüber aufwecken (bspw. "Magic Paket" per Blockly oä.).
                                    LG SBorg ( SBorg auf GitHub)
                                    AtifanA 1 Antwort Letzte Antwort
                                    • SBorgS SBorg
                                      @biker1602
                                      AtifanA Offline
                                      AtifanA Offline
                                      Atifan
                                      #458
                                      Duo2 weiß ich nicht, ich hab ne UNO 4K SE, die hat kein WOL.
                                      Man kann den Receiver entweder wie schon geschrieben über ne schaltbare Steckdose Wecken über Strom aus/an, oder über HDMI-CEC wenn man das TV ansteuern kann und das angeht, dass dann der Receiver angeschaltet wird. Oder über nen IR-Sender.
                                      • AtifanA Atifan
                                        SBorgS Offline
                                        SBorgS Offline
                                        SBorg
                                        #459
                                        @atifan ...und ich dachte schon nur die "Dreamer" schauen da in die Röhre... ;)
                                        Hier ist aber sogar eine Anleitung zur Einrichtung.
                                          biker1602
                                          #460
                                          @sborg Danke das werde ich mal testen
