  4. Diagramm mehrerer Datenpunkte ohne History
    2.6k
    4.6k
    4.0k
visflot adapter
45 Beiträge 6 Kommentatoren 3.6k Aufrufe 5 Beobachtet
  • sigi234S sigi234
    @Negalein sagte in Diagramm mehrerer Datenpunkte ohne History:
    @sigi234 sagte in Diagramm mehrerer Datenpunkte ohne History:
    Übrigens Table geht auch:
    Wie funktioniert das mit der Tabelle?
    Ich kann da nur 1 DP auswählen.
    Könntest du mir den Export deiner Tabelle (Widget) schicken, damit ich mir das ansehen kann?
    [{"tpl":"tplTableBody","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","static_value":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"table_oid":"javascript.0.vis.dasWetterTable","max_rows":"8","colCount":"6","new_on_top":true,"colWidth1":"60px","colWidth2":"60px","colWidth3":"60px","colWidth4":"60px","colName2":"","colWidth5":"60px","colWidth6":"60px","class":""},"style":{"left":"32px","top":"320px","width":"571px","height":"204px","z-index":"5","text-align":"center","font-size":"medium","color":"","background-color":"","background":""},"widgetSet":"basic"}]
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    Funktioniert nicht bei mir.
    Ich hab keinen DP javascript.0.vis.dasWetterTable
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      sigi234S Online
      sigi234S Online
      sigi234
      Du brauchst das Skript von @paul53
      var path    = "daswetter.0.NextDaysDetailed.Location_1."; // Pfad der String-Datenpunkte aus "list"
      var idTable = "vis.dasWetterTable"; // Pfad des Datenpunkts für das vis-Json
      // Datenpunkte anlegen
      createState(idTable, "", {
        desc: 'Tabelle der Vorhersagewerte aus daswetter.com als Json-Objekt',
        type: 'string',
        unit: '',
        role: 'value'
      function wetter() {
         var list = [];
         for(let i = 0; i < 8; i++) {
            list[i] = {};
            list[i].Zeit = getState(path + 'Day_1.Hour_' + (i + 1) + '.hour_value').val;
            list[i].Heute = getState(path + 'Day_1.Hour_' + (i + 1) + '.temp_value').val;
            list[i].Morgen = getState(path + 'Day_2.Hour_' + (i + 1) + '.temp_value').val;
            list[i].Tag_2 = getState(path + 'Day_3.Hour_' + (i + 1) + '.temp_value').val;
            list[i].Tag_3 = getState(path + 'Day_4.Hour_' + (i + 1) + '.temp_value').val;
            list[i].Tag_4 = getState(path + 'Day_5.Hour_' + (i + 1) + '.temp_value').val;
         var json = JSON.stringify(list);
         // log(json);
         setState(idTable, json, true);
      // Trigger
      schedule('10 */15 * * * *', wetter);
      Immer Daten sichern!
      • sigi234S sigi234
          type: 'string',
          unit: '',
          role: 'value'
        function wetter() {
           var list = [];
              list[i] = {};
           // log(json);
        // Trigger
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @sigi234
        Danke!
        Ich hatte das von @dtp
        • NegaleinN Offline
          NegaleinN Offline
          Negalein
          @sigi234
          Hast du die Zeile für die Einheiten (°C, km/h, %, mm) schon eingefügt?
          Wo gehört das im Script von @paul53 eingetragen?
            @sigi234
            @Negalein sagte:
            Das Skript liefert nur die Temperaturwerte. Mit °C:
                  list[i].Heute = getState(path + 'Day_1.Hour_' + (i + 1) + '.temp_value').val + ' °C';
                  list[i].Morgen = getState(path + 'Day_2.Hour_' + (i + 1) + '.temp_value').val + ' °C';
                  list[i].Tag_2 = getState(path + 'Day_3.Hour_' + (i + 1) + '.temp_value').val + ' °C';
                  list[i].Tag_3 = getState(path + 'Day_4.Hour_' + (i + 1) + '.temp_value').val + ' °C';
                  list[i].Tag_4 = getState(path + 'Day_5.Hour_' + (i + 1) + '.temp_value').val + ' °C';
              @Negalein sagte:
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              @paul53 sagte in Diagramm mehrerer Datenpunkte ohne History:
              @Negalein sagte:
              Könnte man das auf die anderen Werte noch erweitern?
                @Negalein sagte:
                @Negalein sagte:
                Wie soll die Tabelle dann aussehen ? Oder mehrere Tabellen ?
                  @Negalein sagte:
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  @Negalein sagte:
                  So wie die Tabelle von @dtp ungefähr
                  Beispiel
                    @Negalein sagte:
                    Beispiel
                    @Negalein 40 Zeilen ?
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      So zB hätte ich gedacht
                        dtp
                        schrieb am zuletzt editiert von dtp
                        Hier gingen jetzt zwei Sachen durcheinander. Zum Einen das Skript von @paul53 zur Erstellung einer JSON-Tabelle und dann meine Version, die die Grundlage für charts.js bilden sollte. Das sollten wir vielleicht klarer trennen.
                        Mir ging es in erster Linie um eine grafische Darstellung der Vorhersagewerte. Eine JSON-Tabelle ist da ggf. nicht so zielführend, zumal man die Werte ja auch problemlos einzeln mit entsprechenden Widgets als Tabelle darstellen kann.
                        @paul53: hab die Units aus den Array-Datenpunkten ebenfalls entfernt. Danke für den Hinweis.
                        Hab mir nun mal charts.js mit
                        npm install chart.js --save
                        installiert. Unter node_modules befinden sich auch die entsprechenden charts.js-Verzeichnisse. Doch nun stocke ich bei der Erstellung des entsprechenden Skripts mit
                        require(['chart.js/dist/Chart.js'], function(Chart){
                          var myChart = new Chart(ctx, {...});
                        Wie und wo zeige ich die entsprechenden Daten an? Jemand eine Idee?
                        • D dtp
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          @dtp sagte in Diagramm mehrerer Datenpunkte ohne History:
                          Ja, das möchte ich auch!
                          Mit dem Script von @paul53 funktioniert das leider nicht.
                            @Negalein sagte:
                            Versuche es mal so (nicht getestet)
                            var path    = "daswetter.0.NextDaysDetailed.Location_1.Day_"; // Pfad der String-Datenpunkte aus "list"
                              type: 'string',
                              role: 'json'
                            function wetter() {
                               var list = [];
                               for(let i = 0; i < 20; i++) {
                                  var j = i % 4;
                                  var sensor = 'temp_value';
                                  var unit = '°C';
                                  if(j == 1) {
                            	     sensor = 'humidity_value';
                            	     unit = '%rH';
                                  else if(j == 2) {
                            	     sensor = 'rain_value';
                            	     unit = 'mm';
                                  else if(j == 3) {
                            	     sensor = 'wind_value';
                                         unit = 'km/h';
                                  var day = Math.floor(i / 4);
                                  var tage = ['Heute','Morgen','Tag 2','Tag 3','Tag 4']
                                  list[i] = {};
                                  if(j == 0) list[i].Tag = tage[day];
                                  list[i].Sensor = unit;
                                  day = day + 1;
                                  list[i]['02:00'] = getState(path + day + '.Hour_1.' + sensor).val;
                                  list[i]['05:00'] = getState(path + day + '.Hour_2.' + sensor).val;
                                  list[i]['08:00'] = getState(path + day + '.Hour_3.' + sensor).val;
                                  list[i]['11:00'] = getState(path + day + '.Hour_4.' + sensor).val;
                                  list[i]['14:00'] = getState(path + day + '.Hour_5.' + sensor).val;
                                  list[i]['17:00'] = getState(path + day + '.Hour_6.' + sensor).val;
                                  list[i]['20:00'] = getState(path + day + '.Hour_7.' + sensor).val;
                                  list[i]['23:00'] = getState(path + day + '.Hour_8.' + sensor).val;
                               // log(json);
                            // Trigger
                              @Negalein sagte:
                                type: 'string',
                                role: 'json'
                              function wetter() {
                                 var list = [];
                                    var j = i % 4;
                                    var unit = '°C';
                                    if(j == 1) {
                              	     unit = '%rH';
                                    else if(j == 2) {
                              	     unit = 'mm';
                                    else if(j == 3) {
                                           unit = 'km/h';
                                    list[i] = {};
                                    day = day + 1;
                                 // log(json);
                              // Trigger
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @Negalein sagte:
                              Funktioniert leider nicht.
                              Aber egal. Ich versuchs irgendwie grafisch umzusetzen.
                                @Negalein sagte:
                                @Negalein
                                Ändere mal
                                in
                                      else list[i].Tag = '';
                                  @Negalein
                                  Ändere mal
                                  in
                                  sigi234S Online
                                  sigi234S Online
                                  sigi234
                                  @Negalein
                                  Ändere mal
                                  in
                                  Schaut bei mir so aus:
                                  Edit:
                                    dtp
                                    Also das finde ich aber ehrlich gesagt alles andere, als übersichtlich. Da würde ich lieber bei der Ansicht aus meinem Ausgangsposting bleiben.
                                    Eigentlich schwebte mir eher sowas vor:
                                    • sigi234S sigi234
                                      @Negalein
                                      Ändere mal
                                      in
                                      Edit:
                                      @sigi234 sagte:
                                      Edit:
                                      Passt doch zur Excel-Tabelle von @Negalein.
                                        @sigi234 sagte:
                                        Edit:
                                        sigi234S Online
                                        sigi234S Online
                                        sigi234
                                        @sigi234 sagte:
                                        Edit:
                                        Ja sag ich eh...........👍
                                        • D dtp
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          Mir auch!
                                          Eventuell wird es ja noch was! :)
