  4. [Diskussion] js-controller 1.5.11 ab sofort im Stable Repository
    5.7k
js-controller
158 Beiträge 37 Kommentatoren 30.8k Aufrufe 20 Beobachtet
  • XsevX Xsev
    @apollon77 Mach ich! Merci!
    knopers1
    #141
    soeben auch den js-controller installiert.
    Kann jemand mit dem warn etwas anfangen?
    root@orangepiplus2e:/opt/iobroker# sudo iobroker upgrade self
    Update js-controller from @1.5.13 to @1.5.14
    NPM version: 6.4.1
    npm install iobroker.js-controller@1.5.14 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    ../src/diskusage_posix.cpp: In function ‘DiskUsage GetDiskUsage(const char*)’:
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bsize’ [-Wmissing-field-initializers]
         struct statvfs info = {};
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_frsize’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_blocks’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bfree’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bavail’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_files’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_ffree’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_favail’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_fsid’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_unused’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_flag’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_namemax’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_spare’ [-Wmissing-field-initializers]
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    Host "orangepiplus2e" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    • K knopers1
      NPM version: 6.4.1
      #142
      @knopers1 alles ok. Nur warnings.
        DocGame
        schrieb am zuletzt editiert von DocGame
        #143
        Hallo miteinander,
        nachdem mein NUC den Geist aufgegeben hat und die gesamte Hauselektrik nicht mehr steuerbar war, habe ich mir auf die schnelle einen neuen (wieder Win10, da Linux nicht so meins ist). Ich habe jetzt 3 Tage fast nonstopp wieder alles im IObroker installiert. An meine alten Blocklys komme ich leider nicht mehr ran und muss noch alles neu einrichten.
        Nun zu meinem Problem:
        Da sich einige Dinge sich komisch verhalten wollte ich den JS-Controller updaten.
        Geht leider gar nichts. Die Fehlermeldungen machen mich nachdenklich. Ich will nicht nochmal von vorne anfangen. Was können die Meldungen bedeuten?
        StabilostickS AlCalzoneA 2 Antworten Letzte Antwort
        • apollon77A Offline
          #144
          Du hast also den neuen Installer genutzt. Ist die gestartete Shell auch die aus dem Menü-Shortcut? wie in der Meldung gebeten?
          • D DocGame
            Hallo miteinander,
            StabilostickS Offline
            Stabilostick
            schrieb am zuletzt editiert von Stabilostick
            #145
            @DocGame
            Bitte verwende zum Installation unter Windows den Installer 1.5.14.a, den Du in der Kategorie „Tester“ findest (den bestehenden Versuch machst Du damit nicht kaputt).
            Wenn Du den Ordner ....../iobroker/iobroker-data vom Vorgängersystem auf Windows kopierst, kann diese Kopie vom Installer als Basis für eine Migration genutzt werden. Da sollten dann auch alle Blocklys usw nach der Migration mit dem neuen Installer mit übernommen werden. Lediglich per Hand (z.B. von GitHub) installierte Adapter musst Du noch mal per Hand nachinstallieren.
            • D DocGame
              Hallo miteinander,
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #146
              @DocGame sagte in [Diskussion] js-controller 1.5.11 ab sofort im Stable Repository:
              Die Windows-Installation bringt für jede ioBroker-Instanz eine eigene Konsole mit, die du auch nutzen musst, um Kommandos auszuführen. Ich glaube du hast einfach cmd geöffnet
              Außerdem hast du einen Tippfehler in "iobroker upgarde self"
                DocGame
                #147
                Danke für die Antworten....
                Wie komme ich denn Konsole der IOBroker-Instanz?
                Bei meiner zerschossenen Installation (war auf C:\Iobroker) haben die Updates über CMD immer geklappt.
                Diese Installation ist ja jetzt auf C:\IoBroker\SmartHome. Ich gehe zwar mir cd C:\IoBroker\SmartHome ins Verzeichnis, aber das ist ja scheinbar falsch.
                AlCalzoneA StabilostickS 2 Antworten Letzte Antwort
                • D DocGame
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  schrieb am zuletzt editiert von AlCalzone
                  #148
                  @DocGame Bei mir sieht das so aus im Startmenü:
                  Windows-Taste --> "iob" eingeben
                  Oder hast du nicht mit dem neuen Installer installiert?
                  • D DocGame
                    Stabilostick
                    #149
                    @DocGame
                    Im Startmenü,gibt es mit dem neuen Windows Installer ab Version 1.4.2 einen neuen Ordner „ioBroker“. Dort werden für jede ioBroker-Serverinstanz zwei Links abgelegt. Einer dient zum schnellen Aufruf des Admins der zu dieser Instanz gehört. Der andere öffnet eine administrative Kommandozeile, die speziell für diese Instanz eingerichtet ist.
                      DocGame
                      #150
                      Vielen Dank an euch für die Hilfe,
                      die Welt kann ja so einfach sein :-)
                      Update hat geklappt....
                      • Damian M.D Offline
                        Damian M.D Offline
                        Damian M.
                        #151
                        Warum kann ich kein neues Thema anlegen?
                        Gibt es dafür eine Anleitung?
                        • Damian M.D Damian M.
                          sigi234S Online
                          sigi234S Online
                          sigi234
                          #152
                          @Damian-M sagte in [Diskussion] js-controller 1.5.11 ab sofort im Stable Repository:
                          Willst du hier Antworten oder ein Neues Thema?
                          Immer Daten sichern!
                            Damian M.D Offline
                            Damian M.
                            #153
                            Eigentlich ein neues Thema.
                            Ich bekomme immer wieder eine Fehlermeldung.
                            Ich solle noch 1 Tag warten ?!?
                            Dabei warte ich schon 3 Tage nach der Anmeldung...
                              sigi234S Online
                              sigi234S Online
                              sigi234
                              #154
                              Hab es mal weitergeleitet.
                                Damian M.D Offline
                                Damian M.
                                #155
                                Das ist die Original Meldung:
                                ERROR
                                You should set a least 1 tag(s) !
                                apollon77A StabilostickS 2 Antworten Letzte Antwort
                                  ERROR
                                  #156
                                  @Damian-M Ein "tag" ist ein Wert was das Thema Deines Beitrags beschreibt. Unter dem EIngabefeld der Meldung ist dann ein Feld für "Tags" ... Du musst da was reinschreiben
                                    ERROR
                                    Stabilostick
                                    #157
                                    @Damian-M
                                    Da was bei einem neuen Forumthema eingeben.
                                    Bereits bestehende Schlagworte (tags) siehst Du hier:
                                    Viel Spaß noch!
                                      Damian M.D Offline
                                      Damian M.
                                      #158
                                      Danke, jetzt geht es.
