  4. [Diskussion] js-controller 1.5.11 ab sofort im Stable Repository
js-controller
158 Beiträge 37 Kommentatoren 31.9k Aufrufe 20 Beobachtet
  • K knopers1
    soeben auch den js-controller installiert.
    Kann jemand mit dem warn etwas anfangen?
    root@orangepiplus2e:/opt/iobroker# sudo iobroker upgrade self
    Update js-controller from @1.5.13 to @1.5.14
    NPM version: 6.4.1
    npm install iobroker.js-controller@1.5.14 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    ../src/diskusage_posix.cpp: In function ‘DiskUsage GetDiskUsage(const char*)’:
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bsize’ [-Wmissing-field-initializers]
         struct statvfs info = {};
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_frsize’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_blocks’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bfree’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_bavail’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_files’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_ffree’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_favail’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_fsid’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_unused’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_flag’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::f_namemax’ [-Wmissing-field-initializers]
    ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member ‘statvfs::__f_spare’ [-Wmissing-field-initializers]
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    Host "orangepiplus2e" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    #142
    @knopers1 alles ok. Nur warnings.
      DocGame
      schrieb am zuletzt editiert von DocGame
      #143
      Hallo miteinander,
      nachdem mein NUC den Geist aufgegeben hat und die gesamte Hauselektrik nicht mehr steuerbar war, habe ich mir auf die schnelle einen neuen (wieder Win10, da Linux nicht so meins ist). Ich habe jetzt 3 Tage fast nonstopp wieder alles im IObroker installiert. An meine alten Blocklys komme ich leider nicht mehr ran und muss noch alles neu einrichten.
      Nun zu meinem Problem:
      Da sich einige Dinge sich komisch verhalten wollte ich den JS-Controller updaten.
      Geht leider gar nichts. Die Fehlermeldungen machen mich nachdenklich. Ich will nicht nochmal von vorne anfangen. Was können die Meldungen bedeuten?
      StabilostickS AlCalzoneA 2 Antworten Letzte Antwort
      • apollon77A Offline
        #144
        Du hast also den neuen Installer genutzt. Ist die gestartete Shell auch die aus dem Menü-Shortcut? wie in der Meldung gebeten?
        • D DocGame
          Hallo miteinander,
          StabilostickS Offline
          Stabilostick
          schrieb am zuletzt editiert von Stabilostick
          #145
          @DocGame
          Bitte verwende zum Installation unter Windows den Installer 1.5.14.a, den Du in der Kategorie „Tester“ findest (den bestehenden Versuch machst Du damit nicht kaputt).
          Wenn Du den Ordner ....../iobroker/iobroker-data vom Vorgängersystem auf Windows kopierst, kann diese Kopie vom Installer als Basis für eine Migration genutzt werden. Da sollten dann auch alle Blocklys usw nach der Migration mit dem neuen Installer mit übernommen werden. Lediglich per Hand (z.B. von GitHub) installierte Adapter musst Du noch mal per Hand nachinstallieren.
          • D DocGame
            Hallo miteinander,
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #146
            @DocGame sagte in [Diskussion] js-controller 1.5.11 ab sofort im Stable Repository:
            Die Windows-Installation bringt für jede ioBroker-Instanz eine eigene Konsole mit, die du auch nutzen musst, um Kommandos auszuführen. Ich glaube du hast einfach cmd geöffnet
            Außerdem hast du einen Tippfehler in "iobroker upgarde self"
              DocGame
              #147
              Danke für die Antworten....
              Wie komme ich denn Konsole der IOBroker-Instanz?
              Bei meiner zerschossenen Installation (war auf C:\Iobroker) haben die Updates über CMD immer geklappt.
              Diese Installation ist ja jetzt auf C:\IoBroker\SmartHome. Ich gehe zwar mir cd C:\IoBroker\SmartHome ins Verzeichnis, aber das ist ja scheinbar falsch.
              AlCalzoneA StabilostickS 2 Antworten Letzte Antwort
              • D DocGame
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                #148
                @DocGame Bei mir sieht das so aus im Startmenü:
                Windows-Taste --> "iob" eingeben
                Oder hast du nicht mit dem neuen Installer installiert?
                • D DocGame
                  Stabilostick
                  #149
                  @DocGame
                  Im Startmenü,gibt es mit dem neuen Windows Installer ab Version 1.4.2 einen neuen Ordner „ioBroker“. Dort werden für jede ioBroker-Serverinstanz zwei Links abgelegt. Einer dient zum schnellen Aufruf des Admins der zu dieser Instanz gehört. Der andere öffnet eine administrative Kommandozeile, die speziell für diese Instanz eingerichtet ist.
                    DocGame
                    #150
                    Vielen Dank an euch für die Hilfe,
                    die Welt kann ja so einfach sein :-)
                    Update hat geklappt....
                    • Damian M.D Offline
                      Damian M.D Offline
                      Damian M.
                      #151
                      Warum kann ich kein neues Thema anlegen?
                      Gibt es dafür eine Anleitung?
                      • Damian M.D Damian M.
                        sigi234S Online
                        sigi234S Online
                        #152
                        @Damian-M sagte in [Diskussion] js-controller 1.5.11 ab sofort im Stable Repository:
                        Willst du hier Antworten oder ein Neues Thema?
                          Damian M.D Offline
                          Damian M.
                          #153
                          Eigentlich ein neues Thema.
                          Ich bekomme immer wieder eine Fehlermeldung.
                          Ich solle noch 1 Tag warten ?!?
                          Dabei warte ich schon 3 Tage nach der Anmeldung...
                            sigi234S Online
                            sigi234S Online
                            #154
                            Hab es mal weitergeleitet.
                              Damian M.D Offline
                              Damian M.
                              #155
                              Das ist die Original Meldung:
                              ERROR
                              You should set a least 1 tag(s) !
                              apollon77A StabilostickS 2 Antworten Letzte Antwort
                                ERROR
                                #156
                                @Damian-M Ein "tag" ist ein Wert was das Thema Deines Beitrags beschreibt. Unter dem EIngabefeld der Meldung ist dann ein Feld für "Tags" ... Du musst da was reinschreiben
                                  ERROR
                                  Stabilostick
                                  #157
                                  @Damian-M
                                  Da was bei einem neuen Forumthema eingeben.
                                  Bereits bestehende Schlagworte (tags) siehst Du hier:
                                  Viel Spaß noch!
                                    Damian M.D Offline
                                    Damian M.
                                    #158
                                    Danke, jetzt geht es.
