  4. Test Adapter lovelace v0.2.x
testcall for actionlovelacevisualisierung
1.1k Beiträge 131 Kommentatoren 453.0k Aufrufe 99 Beobachtet
  • chmilli1C chmilli1
    Hallo !
    Ich bekomme Ihn nicht einmal installiert.....
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'https://www.home-assistant.io/lovelace/',
    1 verbose cli   '--production',
    1 verbose cli   '--save',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker' ]
    2 info using npm@6.4.1
    3 info using node@v8.16.0
    4 verbose npm-session 675c4ef117ea92cb
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 200 https://www.home-assistant.io/lovelace/ 55ms (from cache)
    8 silly fetchPackageMetaData error for https://www.home-assistant.io/lovelace/ Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
    9 timing stage:rollbackFailedOptional Completed in 1ms
    10 timing stage:runTopLevelLifecycles Completed in 6676ms
    11 verbose stack Error: Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
    11 verbose stack     at BB.join (/usr/lib/node_modules/npm/node_modules/pacote/lib/finalize-manifest.js:162:23)
    11 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    11 verbose stack     at Holder$5._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:14:44)
    11 verbose stack     at Holder$5.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:29:30)
    11 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:14:16), <anonymous>:6:20)
    11 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
    11 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
    11 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
    11 verbose stack     at Async._drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:133:16)
    11 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:143:10)
    11 verbose stack     at Immediate.Async.drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    11 verbose stack     at runCallback (timers.js:810:20)
    11 verbose stack     at tryOnImmediate (timers.js:768:5)
    11 verbose stack     at processImmediate [as _immediateCallback] (timers.js:745:5)
    12 verbose cwd /
    13 verbose Linux 4.15.0-20-generic
    14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "https://www.home-assistant.io/lovelace/" "--production" "--save" "--prefix" "/opt/iobroker"
    15 verbose node v8.16.0
    16 verbose npm  v6.4.1
    17 error code ENOPACKAGEJSON
    18 error package.json Non-registry package missing package.json: https://www.home-assistant.io/lovelace/.
    19 error package.json npm can't find a package.json file in your current directory.
    20 verbose exit [ 1, true ]
    MOD Edit Jey Cee: Bitte Code und logs in code Tags packen
    thewhoboxT Offline
    thewhoboxT Offline
    thewhobox
    #81
    @chmilli1 Du benutzt den falschen Link.
    Das was du eingibst ist nicht der Github link sondern einfach nur die Infoseite von lovelance.
    https://github.com/ioBroker/ioBroker.lovelace
    Das ist der richtige.
    Meine Adapter: emby | discovery
      Hallo !
      12 verbose cwd /
      sigi234S Online
      sigi234S Online
      sigi234
      #82
      @chmilli1
      https://forum.iobroker.net/topic/23156/lovelace-in-iobroker-installieren/2
      Immer Daten sichern!
      • marcusklM Offline
        marcusklM Offline
        marcuskl
        #83
        Bei mir werden einige Aufzählungen, z.B. Lampen die definiert sind in Aufzählungen nicht angezeigt?
        Nutze Material Ui, da sind sie alle vorhanden.
        Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
        Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
        • marcusklM marcuskl
          sigi234S Online
          sigi234S Online
          sigi234
          #84
          @marcuskl
          Raum und Funktion zugeordnet?
          • marcusklM Offline
            marcusklM Offline
            marcuskl
            #85
            Jap, habs sogar nochmal geprüft aber passt alles.
            Sonst würde es ja im Material Ui Adapter auch net gehen.
              sigi234S Online
              sigi234S Online
              sigi234
              #86
              @marcuskl sagte in [Aufruf] Test lovelace Adapter:
              der Adapter ist noch sehr neu, habe ich auch. Da musst du experimentieren. Vielleicht ist manches noch nicht implementiert.
                Raducanu
                #87
                So, hab mich die letzten Tage mit dem LoveLace Adapter beschäftigt und bin echt begeistert:
                Die Übersicht welche Card was macht finde ich noch etwas schwirig, aber dort hilft die Home Assistant Seite gut weiter.
                Eine Frage habe ich noch zum Screenshot im Einleitungspost:
                https://forum.iobroker.net/assets/uploads/files/1559078898665-617ff2c4-59f2-4b49-8b2e-9cb7f030eafc-image.png
                Welche Card ist das Rechts/Mitte "Heizung Schlafzimmer"?
                H 1 Antwort Letzte Antwort
                  mandragora
                  #88
                  @ Bluefox.. vielen Dank :) hat jetzt super funktioniert.
                  ioBroker auf Synology DS218+ (Docker); VIS: 2x8" Tablets; Homematic CCU2 und Komponenten; Echo DOT; Unifi Ap-Ac Pro; Landroid S; Jovision IPCams
                  • R Raducanu
                    holgerwolf
                    #89
                    @Raducanu Das ist die Thermostat Karte (type: 'custom:simple-thermostat')
                    sigi234S X 2 Antworten Letzte Antwort
                    • H holgerwolf
                      sigi234S Online
                      sigi234S Online
                      sigi234
                      #90
                      @holgerwolf sagte in [Aufruf] Test lovelace Adapter:
                      Kannst du mal den Editor von der Karte zeigen, was hast du da drinnen?
                      • sigi234S sigi234
                        holgerwolf
                        schrieb am zuletzt editiert von holgerwolf
                        #91
                        @sigi234 Nicht viel:
                        entity: climate.Thermostat_Hobby_1
                        Hätte gerne auch noch andere Parameter auf der Karte, aber die Anleitung gibt auch nix her.
                        Edit: Gerade noch die Infos hier gefunden:
                        https://github.com/nervetattoo/simple-thermostat
                        A 1 Antwort Letzte Antwort
                        • G Gerni
                          Bin gespannt, auf die schnelle sieht es gut aus. Hoffe nur, dass es besser als Material UI wird. Da werden, trotz zugewiesen Räumen usw usw nicht alle Geräte angezeigt.
                          Mal sehen was dieser Adapter kann.
                          Update:
                          Soeben installiert und versucht zwei identisch eingerichtete Temp Sensoren von Xiaomi einzubinden. Einer geht. Einer nicht und wird in der Auswahl schon erst gar nicht angezeigt.
                          UpDate 2:
                          Schaltet man in iobroker wird der Status nicht übergeben.
                          Ist ja noch ein Test aber selbe Probleme wie bei Material bisher aber an sich schon cooler von der Bedienung!
                          apollon77A Online
                          apollon77A Online
                          #92
                          @Gerni auch wenn off topic: hast du bei Material auf GitHub alle Infos zu den fehlenden Geräten mal in issues gepackt? Material ist vom Ansatz her so das Geräte erkannt werden können um dann sinnvoll dargestellt zu werden. Alles was also nicht erkannt werden kann bleibt im Zweifel unsichtbar.
                          Also: issues are your friend!!
                          • LausiDL Offline
                            LausiDL Offline
                            LausiD
                            #93
                            Super Sache!
                            Gerade etwas gespielt...wird der angezeigte Name immer aus Funktion und Raum generiert?
                            Bei Material UI wurde immer Name des Objekts angezeigt...
                            Danke und Gruß
                            LausiD
                            Doku zum FHEM Adapter
                            Aktuelles zum FHEM Adapter
                            Test FHEM Adapter
                            • LausiDL LausiD
                              Super Sache!
                              Danke und Gruß
                              LausiD
                              holgerwolf
                              #94
                              @LausiD Den Namen kannst du an mehreren Stellen ändern:
                              • im Objekt im dem jeweiligen Setting für den Lovelace Adapter
                              • in den Cardsetting gibt es oft ein Setting für den Namen
                              • spätestens im Card Editor unter dem Eintrag für die Entity mit Name:“xyzzy“
                              Holger
                              LausiDL 1 Antwort Letzte Antwort
                              • H holgerwolf
                                Holger
                                LausiDL Offline
                                LausiDL Offline
                                LausiD
                                #95
                                @holgerwolf
                                Vielen Dank für die Info.
                                Wäre es nicht vielleicht sinnvoll den Namen aus dem Objekt als "Vorgabewert" zu übernehmen?
                                Möchte ungern alle Namen händisch ändern :-)
                                LausiD
                                Test FHEM Adapter
                                  Raducanu
                                  #96
                                  Hat jemand eine Idee, wie ich einen State aus dem IOBroker richtig anzeigen kann.
                                  In IOBroker Objekt steht "states": { "1": "Unknown 1", "2": "Sleep no Charge", "3": "Sleep", "5": "Cleaning", "6": "Returning home", "7": "Manuell mode", "8": "Charging", "10": "Paused", "11": "Spot cleaning", "12": "Error?!", "16": "Going to Spot", "17": "Zone cleaning" },
                                  Im Lovelace wird aber z.b. nur "8" oder "5" usw
                                  • dontobiD Offline
                                    dontobiD Offline
                                    dontobi
                                    #97
                                    Hallo zusammen
                                    Ich wollte an dieser Stelle Mal meine Konfiguration präsentieren. Nur das Wetter Widget macht noch Probleme, aber das scheint ein Bug zu sein. Vielleicht suche ich mir dafür auch eine Custom Card, die funktioniert.
                                    Die Screenshots sind auf meinem Handy entstanden, am PC bzw. Tablet sieht das ganze etwas anders aus.
                                    Euch noch einen schönen Sonntag.
                                    Smart Home Zentrale: Raspberry Pi 4 4GB
                                    Meine Homepage: https://www.myHome.zone
                                    coyoteC D 2 Antworten Letzte Antwort
                                    • dontobiD dontobi
                                      Hallo zusammen
                                      coyoteC Offline
                                      coyoteC Offline
                                      coyote
                                      #98
                                      @dontobi sieht sehr gut aus. Gibt es bei Lovelace eigentlich auch eine export Funktion wie in vis? Hab mich mit dem Adapter noch nicht wirklich beschäftigt, da wäre für den Anfang so ein Export ideal, um mal die Grundfunktionen anzuschauen
                                      • coyoteC coyote
                                        holgerwolf
                                        #99
                                        @coyote Man kann einfach den Code im Editor kopieren und dann nach Belieben einsetzten und editieren.
                                        Das komplette Setup gibt es auch in einem RAW Editor (oben rechts).
                                        • coyoteC Offline
                                          coyoteC Offline
                                          coyote
                                          #100
                                          Aha ok, sehr gut. Vllt möchte ja jemand mal ein Projekt zur Verfügung stellen
