  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
    6.3k
blockly
58 Beiträge 6 Kommentatoren 13.3k Aufrufe 7 Beobachtet
  • iomountainI iomountain
    @ap2017 sagte in ASTRO function:
    Not sure what you mean by Date and Time
    i use timedatectl on the command line of iobroker host to see all is set correct.
    ap2017
    #41
    @iomountain said in ASTRO function:
    timedatectl
    Here is my time and date, all good:
      If you config:
      you also will find Astro Settings for your location.
      ap2017
      #42
      @iomountain In adapter config I set location to Germany to make ASTRO work. So, why does it works for Germany but does not work for my location in US?
      • iomountainI Offline
        iomountainI Offline
        iomountain
        #43
        I set my location to:
        restartet the Host.
        Run this Blockly:
         <block type="create" id="v72H-N1#%w_zseA#CMc" x="-212" y="-38">
           <field name="NAME">01-Nachtende</field>
           <statement name="STATEMENT">
             <block type="create" id="@kYi)AXak/ydmJCF!oo]">
               <field name="NAME">02-Morgendämmerung</field>
                 <block type="create" id=";T8PP:ZCKeM4+U5?yi">
                   <field name="NAME">03-Sonnenaufgang</field>
                     <block type="create" id="gIfB:POQ4@(+!BTUapf">
                       <field name="NAME">04-Sonneneaufgang_Ende</field>
                         <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
                           <field name="NAME">05-Golden_Houer_Ende</field>
                             <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
                               <field name="NAME">06-Mittag</field>
                                 <block type="create" id="eYe;t8x=FwBT4B,.|k.">
                                   <field name="NAME">07-Golden_Houer</field>
                                     <block type="create" id="tVROR/kUT3MINh%SOcdY">
                                       <field name="NAME">08-Sonnenuntergang_Anfang</field>
                                         <block type="create" id="kCb|+j}(0FzG/abd,q1">
                                           <field name="NAME">09-Sonnenuntergang</field>
                                             <block type="create" id="4UBzNj{JG:saTpO/G">
                                               <field name="NAME">10-Abenddämmerung</field>
                                                 <block type="create" id="%kf8::E|Nt2icPYM.aB">
                                                   <field name="NAME">11-Nacht</field>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </statement>
           <next>
             <block type="on_ext" id="CJC}fNA0]pCZXm3|IQhw">
               <value name="OID0">
                 <shadow type="field_oid" id="~WnQKdX*p;3`gh]~Gv|}">
                 </shadow>
                 <block type="field_oid" id="sLj^7q(fyKCJ@uKYgne@">
                   <field name="oid">javascript.0.Datenpunkte_own.Alarm.Alarm_AUS</field>
                 </block>
               </value>
                 <block type="debug" id="^Q)xU7M#5MVip9{Y2$hP">
                   <value name="TEXT">
                     <shadow type="text" id="%kcngJ7d=5*$asYlS~T|">
                       <field name="TEXT">03_Astro test start</field>
                     </shadow>
                   </value>
                   <next>
                     <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
                       <field name="OID">javascript.0.01-Nachtende</field>
                       <value name="VALUE">
                         <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
                           <mutation format="false" language="false"></mutation>
                           <field name="OPTION">hh:mm:ss</field>
                             <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
                               <field name="TYPE">nightEnd</field>
                               <field name="OFFSET">0</field>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
                           <field name="OID">javascript.0.02-Morgendämmerung</field>
                             <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
                                 <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
                                   <field name="TYPE">dawn</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                             <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
                               <field name="OID">javascript.0.03-Sonnenaufgang</field>
                                 <block type="convert_from_date" id="AMyc:3Tp9XP+4kq(nv-">
                                     <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
                                       <field name="TYPE">sunrise</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="update" id="DwtR_scz+f42pEJ/sKn?">
                                   <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
                                     <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
                                         <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
                                           <field name="TYPE">sunriseEnd</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
                                       <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
                                         <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
                                             <block type="time_astro" id="]qS[Z+Pab*WUXun969T">
                                               <field name="TYPE">goldenHourEnd</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="update" id="FjU7x+vB-{|nz?Ntgi]B">
                                           <field name="OID">javascript.0.06-Mittag</field>
                                             <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
                                                 <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
                                                   <field name="TYPE">solarNoon</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
                                               <field name="OID">javascript.0.07-Golden_Houer</field>
                                                 <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^">
                                                     <block type="time_astro" id="~MgPI%%B44O6EzrHu._C">
                                                       <field name="TYPE">goldenHour</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="update" id="g|Q7g?g_fO6AjzFr(le">
                                                   <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
                                                     <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF">
                                                         <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
                                                           <field name="TYPE">sunsetStart</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
                                                       <field name="OID">javascript.0.09-Sonnenuntergang</field>
                                                         <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
                                                             <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
                                                               <field name="TYPE">sunset</field>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="update" id="okk0X1l~(0(nUW+Re46b">
                                                           <field name="OID">javascript.0.10-Abenddämmerung</field>
                                                             <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
        <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
        <field name="TYPE">dusk</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
                                                               <field name="OID">javascript.0.11-Nacht</field>
        <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
        <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
        <field name="TYPE">night</field>
        </block>
        </value>
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
        </xml>
        and got this
        seems OK for your location.
        What else could I check?
        A 1 Antwort Letzte Antwort
          restartet the Host.
          Run this Blockly:
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </statement>
             <next>
                 <value name="OID0">
                   </shadow>
                   </block>
                 </value>
                     <value name="TEXT">
                       </shadow>
                     </value>
                     <next>
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
          </xml>
          and got this
          ap2017
          #44
          @iomountain Please run with both system ASTRO and adapter ASTRO set to my location. Thank you.
            iomountainI Offline
            iomountain
            schrieb am zuletzt editiert von iomountain
            #45
            I set the location to:
            ssh on HOST sudo reboot -h now
            Run this Blockly:
                                                         <block type="create" id="m8=S(!$%YPfP56~qYN-V">
                                                           <field name="NAME">12-Nadir</field>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </statement>
               <next>
                   <value name="OID0">
                     </shadow>
                     </block>
                   </value>
                       <value name="TEXT">
                         </shadow>
                       </value>
                       <next>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="r4Pp!x8AYRH2ByxfJ-uj">
        <field name="OID">javascript.0.12-Nadir</field>
        <block type="convert_from_date" id="70t2I`G4:U{os`6!_.!i">
        <block type="time_astro" id="s:0TbVo8LNISj)?5m=fr">
        <field name="TYPE">nadir</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
            </xml>
            got this:
            javascript was set to:
            A 3 Antworten Letzte Antwort
              Run this Blockly:
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </statement>
                 <next>
                     <value name="OID0">
                       </shadow>
                       </block>
                     </value>
                         <value name="TEXT">
                           </shadow>
                         </value>
                         <next>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
              </xml>
              got this:
              ap2017
              #46
              @iomountain Thanks! I will try again on new X64 computer with freshly loaded software.
                Run this Blockly:
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </statement>
                   <next>
                       <value name="OID0">
                         </shadow>
                         </block>
                       </value>
                           <value name="TEXT">
                             </shadow>
                           </value>
                           <next>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
                </xml>
                got this:
                ap2017
                #47
                @iomountain This script works fine when started, it creates objects, but I want to use ASTRO to turn ON my lights repeatably, that what I have trouble with.
                  Run this Blockly:
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                     <next>
                         <value name="OID0">
                           </shadow>
                           </block>
                         </value>
                             <value name="TEXT">
                               </shadow>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                  </xml>
                  got this:
                  ap2017
                  #48
                  @iomountain After all latest updates ASTRO seems to work fine. Don't exactly know what happened, but it works. Thank you for your help
                    iomountainI Offline
                    iomountain
                    #49
                    schön das es jetzt läuft, hab noch viel Spass mit iobroker.
                    Vielleicht kannst du noch Deine Version posten und den Tread auf gelöst setzen.
                    Viele Grüße
                    Ralph
                      ap2017
                      schrieb am zuletzt editiert von ap2017
                      #50
                      Have this issue with ASTRO again after adding few different lights to control by ASTRO. Same problem as before, function ASTRO is ignored by the system - nothing in debug log.
                      Here is my script:
                      schedule({astro: "goldenHour", shift: 0}, function () {
                      console.log('astro_on_golden_hour');
                      // Florida Room
                      setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                      // Living
                      setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, true);
                      // TV Room
                      setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                      // Office
                      setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                      schedule({astro: "dusk", shift: 0}, function () {
                      console.log('astro_on_sunset');
                      // Outside
                      setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, true);
                      // Front Door
                      setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                      schedule("30 23 * * *", function () {
                      console.log('schedule_off');
                      // Florida Room
                      setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                      // Living
                      setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, false);
                      // Outside
                      setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, false);
                      // TV Room
                      setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                      // Office
                      setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                      // Front Door
                      setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                      // Basement Light
                      on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: true}, function (obj) {
                      var value = obj.state.val;
                      setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, true);
                      setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, true);
                      on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: false}, function (obj) {
                      setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, false);
                      setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, false);
                      • C Offline
                        cbr
                        schrieb am zuletzt editiert von cbr
                        #51
                        Hello everybody,
                        first of all I'm new to ioBroker (I installed it on a Raspberry Pi 4 just recently).
                        However I'm having a similar problem.
                        I have two scripts:
                        Switch by ping
                        var bool_NightTime;
                        function HS100_switch() {
                        if (bool_NightTime == true && getState("ping.0.raspberrypi.IP").val == true) {
                        setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, true);
                        } else {
                        setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, false);
                        bool_NightTime = compareTime(getAstroDate("sunrise", undefined, 0), getAstroDate("sunset", undefined, -20), "not between", null);
                        console.log(('NightTime: ' + String(('' + bool_NightTime))));
                        schedule({astro: "sunset", shift: -20}, function () {
                        console.log('Sonne untergegangen -20 Min');
                        bool_NightTime = true;
                        HS100_switch();
                        schedule({astro: "sunrise", shift: 0}, function () {
                        bool_NightTime = false;
                        HS100_switch();
                        on({id: "ping.0.raspberrypi.IP"/Rechnername/, change: "ne"}, function (obj) {
                        HS100_switch();
                        Switch by power
                        var _const_val_PowerLimit, bool_NightTime;
                        if (getState("hs100.0.IP.power").val < _const_val_PowerLimit && bool_NightTime == true && getState("fb-checkpresence.0.presence").val == true) {
                        setState("hs100.0.IP.state"/HS100/, true);
                        } else {
                        setState("hs100.0.IP.state"/HS100/, false);
                        _const_val_PowerLimit = 90;
                        bool_NightTime = compareTime(getAstroDate("sunset", undefined, -20), '23:00', "between", null) && compareTime('22:30', null, "<", getAstroDate("sunset", undefined, -20));
                        if (compareTime("22:30", "null", "<")) {
                        HS100_switch();
                        schedule("0 23 * * *", function () {
                        HS100_switch();
                        on({id: "hs100.0.IP.power"/HS110/, change: "ne"}, function (obj) {
                        HS100_switch();
                        on({id: "fb-checkpresence.0.presence"/presence/, change: "ne"}, function (obj) {
                        HS100_switch();
                        In both of them I use:
                          /* additional code */
                        However the astro function today only triggered for the "Switch by ping" script- see logfile:
                        2020-04-01 19:35:27.992  - ^[[32minfo^[[39m: javascript.0 (665) script.js.common.Switch_by_ping: Sonne untergegangen -20 Min
                        Yesterday it was working for both scripts. (Also the days before it was already inconsistent - however I only had the "Switch by power" script at that time.)
                        I'm restarting my raspberry every night and only added the console.log by today so I cannot tell about the recent days.
                        Any idea what could cause this issue?
                        • C cbr
                          Hello everybody,
                          I have two scripts:
                          Switch by ping
                          var bool_NightTime;
                          } else {
                          HS100_switch();
                          HS100_switch();
                          HS100_switch();
                          Switch by power
                          } else {
                          HS100_switch();
                          HS100_switch();
                          HS100_switch();
                          HS100_switch();
                          ap2017
                          #52
                          @cbr Any luck with astro? I was not using it for a while, got back to it - same issue, works intermittent. Some days it works, some does not. Where are you located? I was thinking this is related to iobroker incorrectly interpreting my astro location settings. I am in US, most other users in Europe and they are not complaning about it.
                          • A ap2017
                            #53
                            @ap2017 You have multiple triggers in you blockly. That is not possible.
                            A AlCalzoneA 2 Antworten Letzte Antwort
                              ap2017
                              #54
                              @Thomas-Braun What do you mean? Why?
                              • A ap2017
                                #55
                                @ap2017 Do you still have two purple blocks on the left side of your blockly? Please upload a screenshot of the current version.
                                  ap2017
                                  #56
                                  @Thomas-Braun here we go, in two parts. Script works stable except for astro triggers.
                                  • A ap2017
                                    #57
                                    @ap2017
                                    You should have only one trigger element per action.
                                    Separate it into independent blocks.
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #58
                                      @Thomas-Braun sagte in ASTRO function. Does not work again:
                                      That is not true. You can have as many as you like, but you should NEVER nest them.
