  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
blockly
58 Beiträge 6 Kommentatoren 13.3k Aufrufe 7 Beobachtet
  • iomountainI Offline
    iomountainI Offline
    iomountain
    I set my location to:
    restartet the Host.
    Run this Blockly:
     <block type="create" id="v72H-N1#%w_zseA#CMc" x="-212" y="-38">
       <field name="NAME">01-Nachtende</field>
       <statement name="STATEMENT">
         <block type="create" id="@kYi)AXak/ydmJCF!oo]">
           <field name="NAME">02-Morgendämmerung</field>
             <block type="create" id=";T8PP:ZCKeM4+U5?yi">
               <field name="NAME">03-Sonnenaufgang</field>
                 <block type="create" id="gIfB:POQ4@(+!BTUapf">
                   <field name="NAME">04-Sonneneaufgang_Ende</field>
                     <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
                       <field name="NAME">05-Golden_Houer_Ende</field>
                         <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
                           <field name="NAME">06-Mittag</field>
                             <block type="create" id="eYe;t8x=FwBT4B,.|k.">
                               <field name="NAME">07-Golden_Houer</field>
                                 <block type="create" id="tVROR/kUT3MINh%SOcdY">
                                   <field name="NAME">08-Sonnenuntergang_Anfang</field>
                                     <block type="create" id="kCb|+j}(0FzG/abd,q1">
                                       <field name="NAME">09-Sonnenuntergang</field>
                                         <block type="create" id="4UBzNj{JG:saTpO/G">
                                           <field name="NAME">10-Abenddämmerung</field>
                                             <block type="create" id="%kf8::E|Nt2icPYM.aB">
                                               <field name="NAME">11-Nacht</field>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </statement>
         </block>
       </statement>
       <next>
         <block type="on_ext" id="CJC}fNA0]pCZXm3|IQhw">
           <mutation items="1"></mutation>
           <value name="OID0">
             <shadow type="field_oid" id="~WnQKdX*p;3`gh]~Gv|}">
             </shadow>
             <block type="field_oid" id="sLj^7q(fyKCJ@uKYgne@">
               <field name="oid">javascript.0.Datenpunkte_own.Alarm.Alarm_AUS</field>
             </block>
           </value>
             <block type="debug" id="^Q)xU7M#5MVip9{Y2$hP">
               <value name="TEXT">
                 <shadow type="text" id="%kcngJ7d=5*$asYlS~T|">
                   <field name="TEXT">03_Astro test start</field>
                 </shadow>
               </value>
               <next>
                 <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
                   <mutation delay_input="false"></mutation>
                   <field name="OID">javascript.0.01-Nachtende</field>
                   <value name="VALUE">
                     <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
                       <mutation format="false" language="false"></mutation>
                       <field name="OPTION">hh:mm:ss</field>
                         <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
                           <field name="TYPE">nightEnd</field>
                           <field name="OFFSET">0</field>
                         </block>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
                       <field name="OID">javascript.0.02-Morgendämmerung</field>
                         <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
                             <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
                               <field name="TYPE">dawn</field>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
                           <field name="OID">javascript.0.03-Sonnenaufgang</field>
                             <block type="convert_from_date" id="AMyc:3Tp9XP+4kq(nv-">
                                 <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
                                   <field name="TYPE">sunrise</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                             <block type="update" id="DwtR_scz+f42pEJ/sKn?">
                               <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
                                 <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
                                     <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
                                       <field name="TYPE">sunriseEnd</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                 <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
                                   <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
                                     <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
                                         <block type="time_astro" id="]qS[Z+Pab*WUXun969T">
                                           <field name="TYPE">goldenHourEnd</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="update" id="FjU7x+vB-{|nz?Ntgi]B">
                                       <field name="OID">javascript.0.06-Mittag</field>
                                         <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
                                             <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
                                               <field name="TYPE">solarNoon</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
                                           <field name="OID">javascript.0.07-Golden_Houer</field>
                                             <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^">
                                                 <block type="time_astro" id="~MgPI%%B44O6EzrHu._C">
                                                   <field name="TYPE">goldenHour</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="update" id="g|Q7g?g_fO6AjzFr(le">
                                               <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
                                                 <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF">
                                                     <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
                                                       <field name="TYPE">sunsetStart</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
                                                   <field name="OID">javascript.0.09-Sonnenuntergang</field>
                                                     <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
                                                         <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
                                                           <field name="TYPE">sunset</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="update" id="okk0X1l~(0(nUW+Re46b">
                                                       <field name="OID">javascript.0.10-Abenddämmerung</field>
                                                         <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
                                                             <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
                                                               <field name="TYPE">dusk</field>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
                                                           <field name="OID">javascript.0.11-Nacht</field>
                                                             <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
        <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
        <field name="TYPE">night</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    and got this
    seems OK for your location.
    What else could I check?
    • iomountainI iomountain
      restartet the Host.
      Run this Blockly:
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </statement>
           </block>
         </statement>
         <next>
             <value name="OID0">
               </shadow>
               </block>
             </value>
                 <value name="TEXT">
                   </shadow>
                 </value>
                 <next>
                           </block>
                         </value>
                       </block>
                     </value>
                     <next>
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </next>
       </block>
      </xml>
      and got this
      ap2017
      @iomountain Please run with both system ASTRO and adapter ASTRO set to my location. Thank you.
        iomountainI Offline
        iomountain
        schrieb am zuletzt editiert von iomountain
        I set the location to:
        ssh on HOST sudo reboot -h now
        Run this Blockly:
                                                     <block type="create" id="m8=S(!$%YPfP56~qYN-V">
                                                       <field name="NAME">12-Nadir</field>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </statement>
           <next>
               <value name="OID0">
                 </shadow>
                 </block>
               </value>
                   <value name="TEXT">
                     </shadow>
                   </value>
                   <next>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <block type="update" id="r4Pp!x8AYRH2ByxfJ-uj">
        <field name="OID">javascript.0.12-Nadir</field>
        <block type="convert_from_date" id="70t2I`G4:U{os`6!_.!i">
        <block type="time_astro" id="s:0TbVo8LNISj)?5m=fr">
        <field name="TYPE">nadir</field>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
        </xml>
        got this:
        javascript was set to:
        A 3 Antworten Letzte Antwort
          Run this Blockly:
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </statement>
             <next>
                 <value name="OID0">
                   </shadow>
                   </block>
                 </value>
                     <value name="TEXT">
                       </shadow>
                     </value>
                     <next>
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
          </xml>
          got this:
          ap2017
          @iomountain Thanks! I will try again on new X64 computer with freshly loaded software.
            Run this Blockly:
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
               </statement>
               <next>
                   <value name="OID0">
                     </shadow>
                     </block>
                   </value>
                       <value name="TEXT">
                         </shadow>
                       </value>
                       <next>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <next>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
            </xml>
            got this:
            ap2017
            @iomountain This script works fine when started, it creates objects, but I want to use ASTRO to turn ON my lights repeatably, that what I have trouble with.
              Run this Blockly:
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </statement>
                 <next>
                     <value name="OID0">
                       </shadow>
                       </block>
                     </value>
                         <value name="TEXT">
                           </shadow>
                         </value>
                         <next>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
              </xml>
              got this:
              ap2017
              @iomountain After all latest updates ASTRO seems to work fine. Don't exactly know what happened, but it works. Thank you for your help
                iomountainI Offline
                iomountain
                schön das es jetzt läuft, hab noch viel Spass mit iobroker.
                Vielleicht kannst du noch Deine Version posten und den Tread auf gelöst setzen.
                Viele Grüße
                Ralph
                  ap2017
                  schrieb am zuletzt editiert von ap2017
                  Have this issue with ASTRO again after adding few different lights to control by ASTRO. Same problem as before, function ASTRO is ignored by the system - nothing in debug log.
                  Here is my script:
                  schedule({astro: "goldenHour", shift: 0}, function () {
                  console.log('astro_on_golden_hour');
                  // Florida Room
                  setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                  // Living
                  setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, true);
                  // TV Room
                  setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                  // Office
                  setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                  schedule({astro: "dusk", shift: 0}, function () {
                  console.log('astro_on_sunset');
                  // Outside
                  setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, true);
                  // Front Door
                  setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                  schedule("30 23 * * *", function () {
                  console.log('schedule_off');
                  // Florida Room
                  setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                  // Living
                  setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, false);
                  // Outside
                  setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, false);
                  // TV Room
                  setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                  // Office
                  setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                  // Front Door
                  setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                  // Basement Light
                  on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: true}, function (obj) {
                  var value = obj.state.val;
                  setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, true);
                  setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, true);
                  on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: false}, function (obj) {
                  setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, false);
                  setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, false);
                  • C Offline
                    cbr
                    schrieb am zuletzt editiert von cbr
                    Hello everybody,
                    first of all I'm new to ioBroker (I installed it on a Raspberry Pi 4 just recently).
                    However I'm having a similar problem.
                    I have two scripts:
                    Switch by ping
                    var bool_NightTime;
                    function HS100_switch() {
                    if (bool_NightTime == true && getState("ping.0.raspberrypi.IP").val == true) {
                    setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, true);
                    } else {
                    setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, false);
                    bool_NightTime = compareTime(getAstroDate("sunrise", undefined, 0), getAstroDate("sunset", undefined, -20), "not between", null);
                    console.log(('NightTime: ' + String(('' + bool_NightTime))));
                    schedule({astro: "sunset", shift: -20}, function () {
                    console.log('Sonne untergegangen -20 Min');
                    bool_NightTime = true;
                    HS100_switch();
                    schedule({astro: "sunrise", shift: 0}, function () {
                    bool_NightTime = false;
                    HS100_switch();
                    on({id: "ping.0.raspberrypi.IP"/Rechnername/, change: "ne"}, function (obj) {
                    HS100_switch();
                    Switch by power
                    var _const_val_PowerLimit, bool_NightTime;
                    if (getState("hs100.0.IP.power").val < _const_val_PowerLimit && bool_NightTime == true && getState("fb-checkpresence.0.presence").val == true) {
                    setState("hs100.0.IP.state"/HS100/, true);
                    } else {
                    setState("hs100.0.IP.state"/HS100/, false);
                    _const_val_PowerLimit = 90;
                    bool_NightTime = compareTime(getAstroDate("sunset", undefined, -20), '23:00', "between", null) && compareTime('22:30', null, "<", getAstroDate("sunset", undefined, -20));
                    if (compareTime("22:30", "null", "<")) {
                    HS100_switch();
                    schedule("0 23 * * *", function () {
                    HS100_switch();
                    on({id: "hs100.0.IP.power"/HS110/, change: "ne"}, function (obj) {
                    HS100_switch();
                    on({id: "fb-checkpresence.0.presence"/presence/, change: "ne"}, function (obj) {
                    HS100_switch();
                    In both of them I use:
                      /* additional code */
                    However the astro function today only triggered for the "Switch by ping" script- see logfile:
                    2020-04-01 19:35:27.992  - ^[[32minfo^[[39m: javascript.0 (665) script.js.common.Switch_by_ping: Sonne untergegangen -20 Min
                    Yesterday it was working for both scripts. (Also the days before it was already inconsistent - however I only had the "Switch by power" script at that time.)
                    I'm restarting my raspberry every night and only added the console.log by today so I cannot tell about the recent days.
                    Any idea what could cause this issue?
                    • C cbr
                      Hello everybody,
                      I have two scripts:
                      Switch by ping
                      var bool_NightTime;
                      } else {
                      HS100_switch();
                      HS100_switch();
                      HS100_switch();
                      Switch by power
                      } else {
                      HS100_switch();
                      HS100_switch();
                      HS100_switch();
                      HS100_switch();
                      ap2017
                      @cbr Any luck with astro? I was not using it for a while, got back to it - same issue, works intermittent. Some days it works, some does not. Where are you located? I was thinking this is related to iobroker incorrectly interpreting my astro location settings. I am in US, most other users in Europe and they are not complaning about it.
                      • A ap2017
                        @ap2017 You have multiple triggers in you blockly. That is not possible.
                        A AlCalzoneA 2 Antworten Letzte Antwort
                          ap2017
                          @Thomas-Braun What do you mean? Why?
                          • A ap2017
                            @ap2017 Do you still have two purple blocks on the left side of your blockly? Please upload a screenshot of the current version.
                              ap2017
                              @Thomas-Braun here we go, in two parts. Script works stable except for astro triggers.
                              • A ap2017
                                @ap2017
                                You should have only one trigger element per action.
                                Separate it into independent blocks.
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  @Thomas-Braun sagte in ASTRO function. Does not work again:
                                  That is not true. You can have as many as you like, but you should NEVER nest them.
