  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
blockly
58 Beiträge 6 Kommentatoren 13.3k Aufrufe 7 Beobachtet
  • iomountainI Offline
    iomountainI Offline
    iomountain
    schön das es jetzt läuft, hab noch viel Spass mit iobroker.
    Vielleicht kannst du noch Deine Version posten und den Tread auf gelöst setzen.
    Viele Grüße
    Ralph
      ap2017
      schrieb am zuletzt editiert von ap2017
      Have this issue with ASTRO again after adding few different lights to control by ASTRO. Same problem as before, function ASTRO is ignored by the system - nothing in debug log.
      Here is my script:
      schedule({astro: "goldenHour", shift: 0}, function () {
      console.log('astro_on_golden_hour');
      // Florida Room
      setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
      // Living
      setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, true);
      // TV Room
      setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
      // Office
      setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
      schedule({astro: "dusk", shift: 0}, function () {
      console.log('astro_on_sunset');
      // Outside
      setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, true);
      // Front Door
      setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
      schedule("30 23 * * *", function () {
      console.log('schedule_off');
      // Florida Room
      setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
      // Living
      setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, false);
      // Outside
      setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, false);
      // TV Room
      setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
      // Office
      setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
      // Front Door
      setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
      // Basement Light
      on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: true}, function (obj) {
      var value = obj.state.val;
      setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, true);
      setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, true);
      on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: false}, function (obj) {
      setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, false);
      setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, false);
      • C Offline
        cbr
        schrieb am zuletzt editiert von cbr
        Hello everybody,
        first of all I'm new to ioBroker (I installed it on a Raspberry Pi 4 just recently).
        However I'm having a similar problem.
        I have two scripts:
        Switch by ping
        var bool_NightTime;
        function HS100_switch() {
        if (bool_NightTime == true && getState("ping.0.raspberrypi.IP").val == true) {
        setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, true);
        } else {
        setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, false);
        bool_NightTime = compareTime(getAstroDate("sunrise", undefined, 0), getAstroDate("sunset", undefined, -20), "not between", null);
        console.log(('NightTime: ' + String(('' + bool_NightTime))));
        schedule({astro: "sunset", shift: -20}, function () {
        console.log('Sonne untergegangen -20 Min');
        bool_NightTime = true;
        HS100_switch();
        schedule({astro: "sunrise", shift: 0}, function () {
        bool_NightTime = false;
        HS100_switch();
        on({id: "ping.0.raspberrypi.IP"/Rechnername/, change: "ne"}, function (obj) {
        HS100_switch();
        Switch by power
        var _const_val_PowerLimit, bool_NightTime;
        if (getState("hs100.0.IP.power").val < _const_val_PowerLimit && bool_NightTime == true && getState("fb-checkpresence.0.presence").val == true) {
        setState("hs100.0.IP.state"/HS100/, true);
        } else {
        setState("hs100.0.IP.state"/HS100/, false);
        _const_val_PowerLimit = 90;
        bool_NightTime = compareTime(getAstroDate("sunset", undefined, -20), '23:00', "between", null) && compareTime('22:30', null, "<", getAstroDate("sunset", undefined, -20));
        if (compareTime("22:30", "null", "<")) {
        HS100_switch();
        schedule("0 23 * * *", function () {
        HS100_switch();
        on({id: "hs100.0.IP.power"/HS110/, change: "ne"}, function (obj) {
        HS100_switch();
        on({id: "fb-checkpresence.0.presence"/presence/, change: "ne"}, function (obj) {
        HS100_switch();
        In both of them I use:
          /* additional code */
        However the astro function today only triggered for the "Switch by ping" script- see logfile:
        2020-04-01 19:35:27.992  - ^[[32minfo^[[39m: javascript.0 (665) script.js.common.Switch_by_ping: Sonne untergegangen -20 Min
        Yesterday it was working for both scripts. (Also the days before it was already inconsistent - however I only had the "Switch by power" script at that time.)
        I'm restarting my raspberry every night and only added the console.log by today so I cannot tell about the recent days.
        Any idea what could cause this issue?
        • C cbr
          Hello everybody,
          I have two scripts:
          Switch by ping
          var bool_NightTime;
          } else {
          HS100_switch();
          HS100_switch();
          HS100_switch();
          Switch by power
          } else {
          HS100_switch();
          HS100_switch();
          HS100_switch();
          HS100_switch();
          ap2017
          @cbr Any luck with astro? I was not using it for a while, got back to it - same issue, works intermittent. Some days it works, some does not. Where are you located? I was thinking this is related to iobroker incorrectly interpreting my astro location settings. I am in US, most other users in Europe and they are not complaning about it.
          • A ap2017
            @ap2017 You have multiple triggers in you blockly. That is not possible.
            A AlCalzoneA 2 Antworten Letzte Antwort
              ap2017
              @Thomas-Braun What do you mean? Why?
              • A ap2017
                @ap2017 Do you still have two purple blocks on the left side of your blockly? Please upload a screenshot of the current version.
                  ap2017
                  @Thomas-Braun here we go, in two parts. Script works stable except for astro triggers.
                  • A ap2017
                    @ap2017
                    You should have only one trigger element per action.
                    Separate it into independent blocks.
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @Thomas-Braun sagte in ASTRO function. Does not work again:
                      That is not true. You can have as many as you like, but you should NEVER nest them.
