  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
blockly
58 Beiträge 6 Kommentatoren 13.3k Aufrufe 7 Beobachtet
  • iomountainI iomountain
    you can check the times at https://www.suncalc.org if you can get them.
    ap2017
    schrieb am zuletzt editiert von ap2017
    @iomountain I mean is there a way to check how ioBroker see my location? Maybe ASTRO gets screwed up because location is screwed up.
    • iomountainI Offline
      iomountainI Offline
      iomountain
      schrieb am zuletzt editiert von iomountain
      I am not sure, but i think what astro uses is only this:
      Is the Date and Time of your Operating System set right?
      A 2 Antworten Letzte Antwort
        ap2017
        @iomountain Here is the log with location in adapter ASTRO set to Germany. ASTRO seems to be working fine. As you can see, script reports ALL ASTRO events, while when my location was set to US it reported only few and then died.
        10-30-19 log.txt
          ap2017
          @iomountain In all my tests location in Overview Settings set to my address, see picture. Not sure what you mean by Date and Time
          iomountainI 1 Antwort Letzte Antwort
          • A ap2017
            iomountainI Offline
            iomountainI Offline
            iomountain
            @ap2017 sagte in ASTRO function:
            i use timedatectl on the command line of iobroker host to see all is set correct.
              iomountainI Offline
              iomountain
              If you config:
              you also will find Astro Settings for your location.
                ap2017
                @iomountain said in ASTRO function:
                timedatectl
                Here is my time and date, all good:
                  If you config:
                  ap2017
                  @iomountain In adapter config I set location to Germany to make ASTRO work. So, why does it works for Germany but does not work for my location in US?
                    iomountainI Offline
                    iomountain
                    I set my location to:
                    restartet the Host.
                    Run this Blockly:
                     <block type="create" id="v72H-N1#%w_zseA#CMc" x="-212" y="-38">
                       <field name="NAME">01-Nachtende</field>
                       <statement name="STATEMENT">
                         <block type="create" id="@kYi)AXak/ydmJCF!oo]">
                           <field name="NAME">02-Morgendämmerung</field>
                             <block type="create" id=";T8PP:ZCKeM4+U5?yi">
                               <field name="NAME">03-Sonnenaufgang</field>
                                 <block type="create" id="gIfB:POQ4@(+!BTUapf">
                                   <field name="NAME">04-Sonneneaufgang_Ende</field>
                                     <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
                                       <field name="NAME">05-Golden_Houer_Ende</field>
                                         <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
                                           <field name="NAME">06-Mittag</field>
                                             <block type="create" id="eYe;t8x=FwBT4B,.|k.">
                                               <field name="NAME">07-Golden_Houer</field>
                                                 <block type="create" id="tVROR/kUT3MINh%SOcdY">
                                                   <field name="NAME">08-Sonnenuntergang_Anfang</field>
                                                     <block type="create" id="kCb|+j}(0FzG/abd,q1">
                                                       <field name="NAME">09-Sonnenuntergang</field>
                                                         <block type="create" id="4UBzNj{JG:saTpO/G">
                                                           <field name="NAME">10-Abenddämmerung</field>
                                                             <block type="create" id="%kf8::E|Nt2icPYM.aB">
                                                               <field name="NAME">11-Nacht</field>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                         </block>
                       </statement>
                       <next>
                         <block type="on_ext" id="CJC}fNA0]pCZXm3|IQhw">
                           <mutation items="1"></mutation>
                           <value name="OID0">
                             <shadow type="field_oid" id="~WnQKdX*p;3`gh]~Gv|}">
                             </shadow>
                             <block type="field_oid" id="sLj^7q(fyKCJ@uKYgne@">
                               <field name="oid">javascript.0.Datenpunkte_own.Alarm.Alarm_AUS</field>
                             </block>
                           </value>
                             <block type="debug" id="^Q)xU7M#5MVip9{Y2$hP">
                               <value name="TEXT">
                                 <shadow type="text" id="%kcngJ7d=5*$asYlS~T|">
                                   <field name="TEXT">03_Astro test start</field>
                                 </shadow>
                               </value>
                               <next>
                                 <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
                                   <mutation delay_input="false"></mutation>
                                   <field name="OID">javascript.0.01-Nachtende</field>
                                   <value name="VALUE">
                                     <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
                                       <mutation format="false" language="false"></mutation>
                                       <field name="OPTION">hh:mm:ss</field>
                                         <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
                                           <field name="TYPE">nightEnd</field>
                                           <field name="OFFSET">0</field>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <next>
                                     <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
                                       <field name="OID">javascript.0.02-Morgendämmerung</field>
                                         <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
                                             <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
                                               <field name="TYPE">dawn</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
                                           <field name="OID">javascript.0.03-Sonnenaufgang</field>
                                             <block type="convert_from_date" id="AMyc:3Tp9XP+4kq(nv-">
                                                 <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
                                                   <field name="TYPE">sunrise</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                             <block type="update" id="DwtR_scz+f42pEJ/sKn?">
                                               <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
                                                 <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
                                                     <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
                                                       <field name="TYPE">sunriseEnd</field>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
                                                   <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
                                                     <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
                                                         <block type="time_astro" id="]qS[Z+Pab*WUXun969T">
                                                           <field name="TYPE">goldenHourEnd</field>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="update" id="FjU7x+vB-{|nz?Ntgi]B">
                                                       <field name="OID">javascript.0.06-Mittag</field>
                                                         <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
                                                             <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
                                                               <field name="TYPE">solarNoon</field>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
                                                           <field name="OID">javascript.0.07-Golden_Houer</field>
                                                             <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^">
        <block type="time_astro" id="~MgPI%%B44O6EzrHu._C">
        <field name="TYPE">goldenHour</field>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="update" id="g|Q7g?g_fO6AjzFr(le">
                                                               <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
        <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF">
        <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
        <field name="TYPE">sunsetStart</field>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
        <field name="OID">javascript.0.09-Sonnenuntergang</field>
        <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
        <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
        <field name="TYPE">sunset</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="okk0X1l~(0(nUW+Re46b">
        <field name="OID">javascript.0.10-Abenddämmerung</field>
        <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
        <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
        <field name="TYPE">dusk</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
        <field name="OID">javascript.0.11-Nacht</field>
        <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
        <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
        <field name="TYPE">night</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                    </xml>
                    and got this
                    seems OK for your location.
                    What else could I check?
                      restartet the Host.
                      Run this Blockly:
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                           </block>
                         </statement>
                         <next>
                             <value name="OID0">
                               </shadow>
                               </block>
                             </value>
                                 <value name="TEXT">
                                   </shadow>
                                 </value>
                                 <next>
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                      </xml>
                      and got this
                      ap2017
                      @iomountain Please run with both system ASTRO and adapter ASTRO set to my location. Thank you.
                        iomountainI Offline
                        iomountain
                        I set the location to:
                        ssh on HOST sudo reboot -h now
                        Run this Blockly:
        <block type="create" id="m8=S(!$%YPfP56~qYN-V">
        <field name="NAME">12-Nadir</field>
        </block>
        </statement>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                           <next>
                               <value name="OID0">
                                 </shadow>
                                 </block>
                               </value>
                                   <value name="TEXT">
                                     </shadow>
                                   </value>
                                   <next>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="r4Pp!x8AYRH2ByxfJ-uj">
        <field name="OID">javascript.0.12-Nadir</field>
        <block type="convert_from_date" id="70t2I`G4:U{os`6!_.!i">
        <block type="time_astro" id="s:0TbVo8LNISj)?5m=fr">
        <field name="TYPE">nadir</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                        </xml>
                        got this:
                        javascript was set to:
                        A 3 Antworten Letzte Antwort
                          Run this Blockly:
        </block>
        </statement>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                             <next>
                                 <value name="OID0">
                                   </shadow>
                                   </block>
                                 </value>
                                     <value name="TEXT">
                                       </shadow>
                                     </value>
                                     <next>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                          </xml>
                          got this:
                          ap2017
                          @iomountain Thanks! I will try again on new X64 computer with freshly loaded software.
                            Run this Blockly:
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                               <next>
                                   <value name="OID0">
                                     </shadow>
                                     </block>
                                   </value>
                                       <value name="TEXT">
                                         </shadow>
                                       </value>
                                       <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </next>
                             </block>
                            </xml>
                            got this:
                            ap2017
                            @iomountain This script works fine when started, it creates objects, but I want to use ASTRO to turn ON my lights repeatably, that what I have trouble with.
                              Run this Blockly:
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                                 <next>
                                     <value name="OID0">
                                       </shadow>
                                       </block>
                                     </value>
                                         <value name="TEXT">
                                           </shadow>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                   </block>
                                 </next>
                               </block>
                              </xml>
                              got this:
                              ap2017
                              @iomountain After all latest updates ASTRO seems to work fine. Don't exactly know what happened, but it works. Thank you for your help
                                iomountainI Offline
                                iomountain
                                schön das es jetzt läuft, hab noch viel Spass mit iobroker.
                                Vielleicht kannst du noch Deine Version posten und den Tread auf gelöst setzen.
                                Viele Grüße
                                Ralph
                                  ap2017
                                  Have this issue with ASTRO again after adding few different lights to control by ASTRO. Same problem as before, function ASTRO is ignored by the system - nothing in debug log.
                                  Here is my script:
                                  schedule({astro: "goldenHour", shift: 0}, function () {
                                  console.log('astro_on_golden_hour');
                                  // Florida Room
                                  setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                                  // Living
                                  setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, true);
                                  // TV Room
                                  setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                                  // Office
                                  setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                                  schedule({astro: "dusk", shift: 0}, function () {
                                  console.log('astro_on_sunset');
                                  // Outside
                                  setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, true);
                                  // Front Door
                                  setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                                  schedule("30 23 * * *", function () {
                                  console.log('schedule_off');
                                  // Florida Room
                                  setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                                  // Living
                                  setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, false);
                                  // Outside
                                  setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, false);
                                  // TV Room
                                  setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                                  // Office
                                  setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                                  // Front Door
                                  setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                                  // Basement Light
                                  on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: true}, function (obj) {
                                  var value = obj.state.val;
                                  setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, true);
                                  setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, true);
                                  on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: false}, function (obj) {
                                  setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, false);
                                  setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, false);
                                  • C Offline
                                    cbr
                                    schrieb am zuletzt editiert von cbr
                                    Hello everybody,
                                    first of all I'm new to ioBroker (I installed it on a Raspberry Pi 4 just recently).
                                    However I'm having a similar problem.
                                    I have two scripts:
                                    Switch by ping
                                    var bool_NightTime;
                                    function HS100_switch() {
                                    if (bool_NightTime == true && getState("ping.0.raspberrypi.IP").val == true) {
                                    setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, true);
                                    } else {
                                    setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, false);
                                    bool_NightTime = compareTime(getAstroDate("sunrise", undefined, 0), getAstroDate("sunset", undefined, -20), "not between", null);
                                    console.log(('NightTime: ' + String(('' + bool_NightTime))));
                                    schedule({astro: "sunset", shift: -20}, function () {
                                    console.log('Sonne untergegangen -20 Min');
                                    bool_NightTime = true;
                                    HS100_switch();
                                    schedule({astro: "sunrise", shift: 0}, function () {
                                    bool_NightTime = false;
                                    HS100_switch();
                                    on({id: "ping.0.raspberrypi.IP"/Rechnername/, change: "ne"}, function (obj) {
                                    HS100_switch();
                                    Switch by power
                                    var _const_val_PowerLimit, bool_NightTime;
                                    if (getState("hs100.0.IP.power").val < _const_val_PowerLimit && bool_NightTime == true && getState("fb-checkpresence.0.presence").val == true) {
                                    setState("hs100.0.IP.state"/HS100/, true);
                                    } else {
                                    setState("hs100.0.IP.state"/HS100/, false);
                                    _const_val_PowerLimit = 90;
                                    bool_NightTime = compareTime(getAstroDate("sunset", undefined, -20), '23:00', "between", null) && compareTime('22:30', null, "<", getAstroDate("sunset", undefined, -20));
                                    if (compareTime("22:30", "null", "<")) {
                                    HS100_switch();
                                    schedule("0 23 * * *", function () {
                                    HS100_switch();
                                    on({id: "hs100.0.IP.power"/HS110/, change: "ne"}, function (obj) {
                                    HS100_switch();
                                    on({id: "fb-checkpresence.0.presence"/presence/, change: "ne"}, function (obj) {
                                    HS100_switch();
                                    In both of them I use:
                                      /* additional code */
                                    However the astro function today only triggered for the "Switch by ping" script- see logfile:
                                    2020-04-01 19:35:27.992  - ^[[32minfo^[[39m: javascript.0 (665) script.js.common.Switch_by_ping: Sonne untergegangen -20 Min
                                    Yesterday it was working for both scripts. (Also the days before it was already inconsistent - however I only had the "Switch by power" script at that time.)
                                    I'm restarting my raspberry every night and only added the console.log by today so I cannot tell about the recent days.
                                    Any idea what could cause this issue?
                                    • C cbr
                                      Hello everybody,
                                      I have two scripts:
                                      Switch by ping
                                      var bool_NightTime;
                                      } else {
                                      HS100_switch();
                                      HS100_switch();
                                      HS100_switch();
                                      Switch by power
                                      } else {
                                      HS100_switch();
                                      HS100_switch();
                                      HS100_switch();
                                      HS100_switch();
                                      ap2017
                                      @cbr Any luck with astro? I was not using it for a while, got back to it - same issue, works intermittent. Some days it works, some does not. Where are you located? I was thinking this is related to iobroker incorrectly interpreting my astro location settings. I am in US, most other users in Europe and they are not complaning about it.
                                      • A ap2017
                                        @ap2017 You have multiple triggers in you blockly. That is not possible.
                                        A AlCalzoneA 2 Antworten Letzte Antwort
                                          ap2017
                                          @Thomas-Braun What do you mean? Why?
