  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
blockly
58 Beiträge 6 Kommentatoren 13.3k Aufrufe 7 Beobachtet
  • iomountainI iomountain
    Mine works:
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenmittag
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenuntergang Anfang
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Abenddämmerung
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Abenddämmerung
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nacht
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nadir
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nachtende
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Morgendämmerung
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Morgendämmerung
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang ende
    javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour Ende
    if you dont have all these "errors" in your log, we try next ideas, or compare Versions.
    ap2017
    @iomountain sorry, I am traveling now, will be able to try next week
    • iomountainI Offline
      iomountainI Offline
      iomountain
      mine works:
      my Versions of Software:
      Node.js v10.16.3
      NPM 6.9.0
        Could you please test this for 24 hours:
         <block type="comment" id="dZ/@oL!i0(@/:!$Ikw{J" x="13" y="13">
           <field name="COMMENT">Test Astro</field>
           <next>
             <block type="astro" id="sxZ*u!O2O8lf$a?qgNf%">
               <field name="TYPE">sunrise</field>
               <field name="OFFSET">0</field>
               <statement name="STATEMENT">
                 <block type="debug" id="f0h|hnMOj,t0a9F4R/*u">
                   <field name="Severity">error</field>
                   <value name="TEXT">
                     <shadow type="text" id="t~{SzkO:N+m/c:_aXvF_">
                       <field name="TEXT">Sonnenaufgang</field>
                     </shadow>
                   </value>
                   <next>
                     <block type="debug" id=";Kc+}!GR24eQ4F1zvsqz">
                       <value name="TEXT">
                         <shadow type="text" id="d7@Q.7Mu+wBczv=iaKT?">
                         </shadow>
                         <block type="time_get" id="0}ve}|zeLByf%Wn1)Z~N">
                           <mutation format="true" language="false"></mutation>
                           <field name="OPTION">custom</field>
                           <field name="FORMAT">JJJJ-MM-TT SS:mm:ss.sss</field>
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </statement>
               <next>
                 <block type="astro" id="e%0Te`wUBXm0Z(Tm~(uK">
                   <field name="TYPE">sunriseEnd</field>
                     <block type="debug" id="~yMY;Z`RDhY|PgL8aLYT">
                       <value name="TEXT">
                         <shadow type="text" id="{(iRk-Wgsniu)/OWNuec">
                           <field name="TEXT">Sonnenaufgang ende</field>
                         </shadow>
                       </value>
                       <next>
                         <block type="debug" id="q|N1he7_#J*z!t:Lxbq4">
                           <value name="TEXT">
                             </shadow>
                             <block type="time_get" id="tJ*UF;cM+aI^pYR^Qa;1">
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </statement>
                   <next>
                     <block type="astro" id="7-p8CPh^EAGz7TZ[HE=f">
                       <field name="TYPE">goldenHourEnd</field>
                         <block type="debug" id="#jT`iz!Nlmm:r|h0-a;{">
                           <value name="TEXT">
                             <shadow type="text" id="sF]?KilHL=/lQ@|f$!#B">
                               <field name="TEXT">Golden hour Ende</field>
                             </shadow>
                           </value>
                           <next>
                             <block type="debug" id="?jcK[-lRY6m67kH94cJ8">
                               <value name="TEXT">
                                 </shadow>
                                 <block type="time_get" id=":6c/3{e5w_Qr@--(F2,$">
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                       <next>
                         <block type="astro" id="tK}:wS(k,Xmf4I2Ms^,]">
                           <field name="TYPE">solarNoon</field>
                             <block type="debug" id="sYbNw@$;Db5D:)VF)*b}">
                               <value name="TEXT">
                                 <shadow type="text" id="h9Pt!n;uDsK%[C8H0T:-">
                                   <field name="TEXT">Sonnenmittag</field>
                                 </shadow>
                               </value>
                               <next>
                                 <block type="debug" id="0z@Vv^UhX8S(2Uk.L}AX">
                                   <value name="TEXT">
                                     </shadow>
                                     <block type="time_get" id="63mXGB7G3:L?++1KLilu">
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                             <block type="astro" id="2X-czA2y[$Ug?5[Q_aUV">
                               <field name="TYPE">goldenHour</field>
                                 <block type="debug" id="VvR2BxdbZn.+TuU)7yLe">
                                   <value name="TEXT">
                                     <shadow type="text" id="#r/L5Io)*?Qz!Co)U:Jc">
                                       <field name="TEXT">Golden hour</field>
                                     </shadow>
                                   </value>
                                   <next>
                                     <block type="debug" id="vO^xDs|z,PXJo=OKQ=bY">
                                       <value name="TEXT">
                                         </shadow>
                                         <block type="time_get" id="8b(z1|U:aT{s/-zQOG-O">
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                               <next>
                                 <block type="astro" id="dLczmmMSoFlkvb*/H*SF">
                                   <field name="TYPE">sunsetStart</field>
                                     <block type="debug" id="S%o3:;|MkGT:WNoq-5I/">
                                       <value name="TEXT">
                                         <shadow type="text" id="oZW7=ox`@zO:d)Qo`jM#">
                                           <field name="TEXT">Sonnenuntergang Anfang</field>
                                         </shadow>
                                       </value>
                                       <next>
                                         <block type="debug" id="88*2`mY-$F4-h46R$bsh">
                                           <value name="TEXT">
                                             </shadow>
                                             <block type="time_get" id="=yV74{gTTEshyETA[YT+">
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                   <next>
                                     <block type="astro" id="`E^X3.`tEYD#t?w3p[Y6">
                                       <field name="TYPE">sunset</field>
                                         <block type="debug" id="3y?c.oF8m3]qo`y^Sk2Y">
                                           <value name="TEXT">
                                             <shadow type="text" id="_^a1$PSDO%=0T$ouPs,z">
                                               <field name="TEXT">Sonnenuntergang</field>
                                             </shadow>
                                           </value>
                                           <next>
                                             <block type="debug" id="B{Xk(=sas9lxfcPeH~8l">
                                               <value name="TEXT">
                                                 </shadow>
                                                 <block type="time_get" id="?;boy8-PvsRtK^R`i(d!">
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                       <next>
                                         <block type="astro" id="yk2LFSH:M4]t,=g+r0Zr">
                                           <field name="TYPE">dusk</field>
                                             <block type="debug" id="JVc5|ie7ToL`o0+q*H6)">
                                               <value name="TEXT">
                                                 <shadow type="text" id=":3i#l]vFr9mFH`8A9d40">
                                                   <field name="TEXT">Abenddämmerung</field>
                                                 </shadow>
                                               </value>
                                               <next>
                                                 <block type="debug" id="}#5$Eg5HxUq%N?JiZUB|">
                                                   <value name="TEXT">
                                                     </shadow>
                                                     <block type="time_get" id="C8-_%?]~kLQbzj4$5M:w">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                           <next>
                                             <block type="astro" id="o1Y86d?aD}-85W@_Bc{X">
                                               <field name="TYPE">nauticalDusk</field>
                                                 <block type="debug" id="[y[=-3!xjqWbFILYTKrT">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="(Ka/nD(#:R%T5M;oQVo+">
                                                       <field name="TEXT">Nautische Abenddämmerung</field>
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                     <block type="debug" id="hQnK;WRQD=[=PuGnpeC^">
                                                       <value name="TEXT">
                                                         </shadow>
                                                         <block type="time_get" id="1*6{GuA}Ptl}@=:RYN8E">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <next>
                                                 <block type="astro" id="j8y_r:dEbMD7iY2.W7L,">
                                                   <field name="TYPE">night</field>
                                                     <block type="debug" id="76(?!SO)O1xP:}liKAC%">
                                                       <value name="TEXT">
                                                         <shadow type="text" id="hkdb,q:hVvOIp?ukBqRa">
                                                           <field name="TEXT">Nacht</field>
                                                         </shadow>
                                                       </value>
                                                       <next>
                                                         <block type="debug" id="K`Fpc2JYxRBNQEc[yo9_">
                                                           <value name="TEXT">
                                                             </shadow>
                                                             <block type="time_get" id="f.=BzucV$CL,2#_}W7wU">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                     <block type="astro" id=",EU+9{ySUaqT/?CfG5ap">
                                                       <field name="TYPE">nightEnd</field>
                                                         <block type="debug" id="nk=,IYJu$$)~c%9EMNZL">
                                                           <value name="TEXT">
                                                             <shadow type="text" id="?@=$%L4#!G}2|rgS]c=?">
                                                               <field name="TEXT">Nachtende</field>
                                                             </shadow>
                                                           </value>
                                                           <next>
                                                             <block type="debug" id="U_1^p,G9]J.];Zq9X~LM">
                                                               <value name="TEXT">
        </shadow>
        <block type="time_get" id="Wq.(8ZwGLimw6:lfSa!V">
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                       <next>
                                                         <block type="astro" id="Sz%RA[al07GBMdE@p1Gz">
                                                           <field name="TYPE">nauticalDawn</field>
                                                             <block type="debug" id="`y(OGo$-nPG8Ej5m[BHG">
                                                               <value name="TEXT">
        <shadow type="text" id="EOoN^Uh$_,d+JSl]lGUh">
        <field name="TEXT">Nautische Morgendämmerung</field>
        </shadow>
                                                               </value>
                                                               <next>
        <block type="debug" id="0S99AV1F|DJLUd,(d?qc">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="YOyQlgY?b(gtz4v^}j+H">
        </block>
        </value>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                           <next>
                                                             <block type="astro" id="Vw^5UMBH6vtWJyaq53.]">
                                                               <field name="TYPE">dawn</field>
        <block type="debug" id="19?SR^q{j;E8z!!;D7[)">
        <value name="TEXT">
        <shadow type="text" id="Ar4KDdxuaHRys!_~m2WV">
        <field name="TEXT">Morgendämmerung</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="=m0|q1#NNjFK3(dAk!Ad">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="78Wc.sXU9AC;tMV..MwN">
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </statement>
                                                               <next>
        <block type="astro" id="i`FUoNopylwQy:QgoJ}v">
        <field name="TYPE">nadir</field>
        <block type="debug" id="r(e93[h_`7D!QfmFL~Mf">
        <value name="TEXT">
        <shadow type="text" id="|P[TC/:yl.5FkD_HO*./">
        <field name="TEXT">Nadir</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="Dhca#mXRR2KV}e}.Opj$">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="f[j$/@]5]_7kP7mnP#ds">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
        </xml>
        ap2017
        @iomountain I am getting this error while saving your script:
        10/27/2019, 10:30:21 PM.531 [error]: javascript.0 (18920) script.js.ASTRO compile failed:
        at script.js.ASTRO:1
             <next>
                     <value name="TEXT">
                       </shadow>
                     </value>
                     <next>
                         <value name="TEXT">
                           </shadow>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
                 <next>
                         <value name="TEXT">
                           </shadow>
                         </value>
                         <next>
                             <value name="TEXT">
                               </shadow>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <next>
                             <value name="TEXT">
                               </shadow>
                             </value>
                             <next>
                                 <value name="TEXT">
                                   </shadow>
                                   </block>
                                 </value>
                               </block>
                             </next>
                           </block>
                         </statement>
                         <next>
                                 <value name="TEXT">
                                   </shadow>
                                 </value>
                                 <next>
                                     <value name="TEXT">
                                       </shadow>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                             <next>
                                     <value name="TEXT">
                                       </shadow>
                                     </value>
                                     <next>
                                         <value name="TEXT">
                                           </shadow>
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                                 <next>
                                         <value name="TEXT">
                                           </shadow>
                                         </value>
                                         <next>
                                             <value name="TEXT">
                                               </shadow>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                     <next>
                                             <value name="TEXT">
                                               </shadow>
                                             </value>
                                             <next>
                                                 <value name="TEXT">
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                         <next>
                                                 <value name="TEXT">
                                                   </shadow>
                                                 </value>
                                                 <next>
                                                     <value name="TEXT">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                                     <value name="TEXT">
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                         <value name="TEXT">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                         <value name="TEXT">
                                                           </shadow>
                                                         </value>
                                                         <next>
                                                             <value name="TEXT">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                             <value name="TEXT">
                                                               </shadow>
                                                             </value>
                                                             <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </statement>
                                                         <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                             <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
          </xml>
          ap2017
          @iomountain Actually, here is log after starting your script:
          2019-10-27 22:35:16.197 - info: javascript.0 (18920) Stop script script.js.ASTRO
          2019-10-27 22:35:20.358 - info: javascript.0 (18920) Start javascript script.js.ASTRO
          2019-10-27 22:35:20.358 - error: javascript.0 (18920) script.js.ASTRO compile failed:
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) ^
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) SyntaxError: Unexpected token <
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at new Script (vm.js:83:7)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at Object.createScript (vm.js:277:10)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
          2019-10-27 22:35:20.359 - error: javascript.0 (18920) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:433:21)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
          2019-10-27 22:35:20.360 - error: javascript.0 (18920) at process._tickCallback (internal/process/next_tick.js:68:7)
            mine works:
            Node.js v10.16.3
            NPM 6.9.0
            ap2017
            @iomountain My system:
            Script Engine 4.3.1
            Node.js 10.16.3
            NPM 6.9.0
              iomountainI Offline
              iomountain
              My script is a Blockly:
                ap2017
                @iomountain Thank you, will enter and start it tonight
                • A ap2017
                  ap2017
                  schrieb am zuletzt editiert von ap2017
                  @ap2017 Please see log attached, ASTRO does not work. Server was restarted after scrip creation yesterday evening. Currently my script adapter configured for System ASTRO Settings, shows my street on the screen. I am wondering if possible to debug how system sees my location.
                  Tonight I will change Script Adapter ASTRO location to Germany and run same script over night.
                  10-29-19.txt
                  My script:
                    iomountainI Offline
                    iomountain
                    you can check the times at https://www.suncalc.org if you can get them.
                      ap2017
                      @iomountain I mean is there a way to check how ioBroker see my location? Maybe ASTRO gets screwed up because location is screwed up.
                        iomountainI Offline
                        iomountain
                        schrieb am zuletzt editiert von iomountain
                        I am not sure, but i think what astro uses is only this:
                        Is the Date and Time of your Operating System set right?
                        A 2 Antworten Letzte Antwort
                          ap2017
                          @iomountain Here is the log with location in adapter ASTRO set to Germany. ASTRO seems to be working fine. As you can see, script reports ALL ASTRO events, while when my location was set to US it reported only few and then died.
                          10-30-19 log.txt
                            ap2017
                            @iomountain In all my tests location in Overview Settings set to my address, see picture. Not sure what you mean by Date and Time
                            iomountainI 1 Antwort Letzte Antwort
                            • A ap2017
                              iomountainI Offline
                              iomountainI Offline
                              iomountain
                              @ap2017 sagte in ASTRO function:
                              i use timedatectl on the command line of iobroker host to see all is set correct.
                                iomountainI Offline
                                iomountain
                                If you config:
                                you also will find Astro Settings for your location.
                                  ap2017
                                  @iomountain said in ASTRO function:
                                  timedatectl
                                  Here is my time and date, all good:
                                    If you config:
                                    ap2017
                                    @iomountain In adapter config I set location to Germany to make ASTRO work. So, why does it works for Germany but does not work for my location in US?
                                      iomountainI Offline
                                      iomountain
                                      I set my location to:
                                      restartet the Host.
                                      Run this Blockly:
                                       <block type="create" id="v72H-N1#%w_zseA#CMc" x="-212" y="-38">
                                         <field name="NAME">01-Nachtende</field>
                                           <block type="create" id="@kYi)AXak/ydmJCF!oo]">
                                             <field name="NAME">02-Morgendämmerung</field>
                                               <block type="create" id=";T8PP:ZCKeM4+U5?yi">
                                                 <field name="NAME">03-Sonnenaufgang</field>
                                                   <block type="create" id="gIfB:POQ4@(+!BTUapf">
                                                     <field name="NAME">04-Sonneneaufgang_Ende</field>
                                                       <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
                                                         <field name="NAME">05-Golden_Houer_Ende</field>
                                                           <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
                                                             <field name="NAME">06-Mittag</field>
                                                               <block type="create" id="eYe;t8x=FwBT4B,.|k.">
        <field name="NAME">07-Golden_Houer</field>
        <block type="create" id="tVROR/kUT3MINh%SOcdY">
        <field name="NAME">08-Sonnenuntergang_Anfang</field>
        <block type="create" id="kCb|+j}(0FzG/abd,q1">
        <field name="NAME">09-Sonnenuntergang</field>
        <block type="create" id="4UBzNj{JG:saTpO/G">
        <field name="NAME">10-Abenddämmerung</field>
        <block type="create" id="%kf8::E|Nt2icPYM.aB">
        <field name="NAME">11-Nacht</field>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                         <next>
                                           <block type="on_ext" id="CJC}fNA0]pCZXm3|IQhw">
                                             <mutation items="1"></mutation>
                                             <value name="OID0">
                                               <shadow type="field_oid" id="~WnQKdX*p;3`gh]~Gv|}">
                                               </shadow>
                                               <block type="field_oid" id="sLj^7q(fyKCJ@uKYgne@">
                                                 <field name="oid">javascript.0.Datenpunkte_own.Alarm.Alarm_AUS</field>
                                               </block>
                                             </value>
                                               <block type="debug" id="^Q)xU7M#5MVip9{Y2$hP">
                                                 <value name="TEXT">
                                                   <shadow type="text" id="%kcngJ7d=5*$asYlS~T|">
                                                     <field name="TEXT">03_Astro test start</field>
                                                   </shadow>
                                                 </value>
                                                 <next>
                                                   <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
                                                     <mutation delay_input="false"></mutation>
                                                     <field name="OID">javascript.0.01-Nachtende</field>
                                                     <value name="VALUE">
                                                       <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
                                                         <mutation format="false" language="false"></mutation>
                                                         <field name="OPTION">hh:mm:ss</field>
                                                           <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
                                                         <field name="OID">javascript.0.02-Morgendämmerung</field>
                                                           <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
                                                               <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
                                                             <field name="OID">javascript.0.03-Sonnenaufgang</field>
                                                               <block type="convert_from_date" id="AMyc:3Tp9XP+4kq(nv-">
        <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
                                                               <block type="update" id="DwtR_scz+f42pEJ/sKn?">
        <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
        <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
        <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
        <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
        <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
        <block type="time_astro" id="]qS[Z+Pab*WUXun969T">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="FjU7x+vB-{|nz?Ntgi]B">
        <field name="OID">javascript.0.06-Mittag</field>
        <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
        <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
        <field name="OID">javascript.0.07-Golden_Houer</field>
        <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^">
        <block type="time_astro" id="~MgPI%%B44O6EzrHu._C">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="g|Q7g?g_fO6AjzFr(le">
        <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
        <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF">
        <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
        <field name="OID">javascript.0.09-Sonnenuntergang</field>
        <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
        <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="okk0X1l~(0(nUW+Re46b">
        <field name="OID">javascript.0.10-Abenddämmerung</field>
        <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
        <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
        <field name="OID">javascript.0.11-Nacht</field>
        <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
        <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                           </block>
                                         </next>
                                       </block>
                                      </xml>
                                      and got this
                                      seems OK for your location.
                                      What else could I check?
                                        restartet the Host.
                                        Run this Blockly:
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                           <next>
                                               <value name="OID0">
                                                 </shadow>
                                                 </block>
                                               </value>
                                                   <value name="TEXT">
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                        </xml>
                                        and got this
                                        ap2017
                                        @iomountain Please run with both system ASTRO and adapter ASTRO set to my location. Thank you.
                                          iomountainI Offline
                                          iomountain
                                          I set the location to:
                                          ssh on HOST sudo reboot -h now
                                          Run this Blockly:
        <block type="create" id="m8=S(!$%YPfP56~qYN-V">
        <field name="NAME">12-Nadir</field>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                             <next>
                                                 <value name="OID0">
                                                   </shadow>
                                                   </block>
                                                 </value>
                                                     <value name="TEXT">
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="r4Pp!x8AYRH2ByxfJ-uj">
        <field name="OID">javascript.0.12-Nadir</field>
        <block type="convert_from_date" id="70t2I`G4:U{os`6!_.!i">
        <block type="time_astro" id="s:0TbVo8LNISj)?5m=fr">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                          </xml>
                                          got this:
                                          javascript was set to:
                                          A 3 Antworten Letzte Antwort
