  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
blockly
58 Beiträge 6 Kommentatoren 13.3k Aufrufe 7 Beobachtet
  • iomountainI iomountain
    My script is a Blockly:
    ap2017
    @iomountain Thank you, will enter and start it tonight
    • A ap2017
      ap2017
      schrieb am zuletzt editiert von ap2017
      @ap2017 Please see log attached, ASTRO does not work. Server was restarted after scrip creation yesterday evening. Currently my script adapter configured for System ASTRO Settings, shows my street on the screen. I am wondering if possible to debug how system sees my location.
      Tonight I will change Script Adapter ASTRO location to Germany and run same script over night.
      10-29-19.txt
      My script:
      • iomountainI Offline
        iomountainI Offline
        iomountain
        you can check the times at https://www.suncalc.org if you can get them.
          ap2017
          @iomountain I mean is there a way to check how ioBroker see my location? Maybe ASTRO gets screwed up because location is screwed up.
            iomountainI Offline
            iomountain
            schrieb am zuletzt editiert von iomountain
            I am not sure, but i think what astro uses is only this:
            Is the Date and Time of your Operating System set right?
            A 2 Antworten Letzte Antwort
              ap2017
              @iomountain Here is the log with location in adapter ASTRO set to Germany. ASTRO seems to be working fine. As you can see, script reports ALL ASTRO events, while when my location was set to US it reported only few and then died.
              10-30-19 log.txt
                ap2017
                @iomountain In all my tests location in Overview Settings set to my address, see picture. Not sure what you mean by Date and Time
                iomountainI 1 Antwort Letzte Antwort
                • A ap2017
                  iomountainI Offline
                  iomountainI Offline
                  iomountain
                  @ap2017 sagte in ASTRO function:
                  i use timedatectl on the command line of iobroker host to see all is set correct.
                    iomountainI Offline
                    iomountain
                    If you config:
                    you also will find Astro Settings for your location.
                      ap2017
                      @iomountain said in ASTRO function:
                      timedatectl
                      Here is my time and date, all good:
                        If you config:
                        ap2017
                        @iomountain In adapter config I set location to Germany to make ASTRO work. So, why does it works for Germany but does not work for my location in US?
                          iomountainI Offline
                          iomountain
                          I set my location to:
                          restartet the Host.
                          Run this Blockly:
                           <block type="create" id="v72H-N1#%w_zseA#CMc" x="-212" y="-38">
                             <field name="NAME">01-Nachtende</field>
                             <statement name="STATEMENT">
                               <block type="create" id="@kYi)AXak/ydmJCF!oo]">
                                 <field name="NAME">02-Morgendämmerung</field>
                                   <block type="create" id=";T8PP:ZCKeM4+U5?yi">
                                     <field name="NAME">03-Sonnenaufgang</field>
                                       <block type="create" id="gIfB:POQ4@(+!BTUapf">
                                         <field name="NAME">04-Sonneneaufgang_Ende</field>
                                           <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
                                             <field name="NAME">05-Golden_Houer_Ende</field>
                                               <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
                                                 <field name="NAME">06-Mittag</field>
                                                   <block type="create" id="eYe;t8x=FwBT4B,.|k.">
                                                     <field name="NAME">07-Golden_Houer</field>
                                                       <block type="create" id="tVROR/kUT3MINh%SOcdY">
                                                         <field name="NAME">08-Sonnenuntergang_Anfang</field>
                                                           <block type="create" id="kCb|+j}(0FzG/abd,q1">
                                                             <field name="NAME">09-Sonnenuntergang</field>
                                                               <block type="create" id="4UBzNj{JG:saTpO/G">
        <field name="NAME">10-Abenddämmerung</field>
        <block type="create" id="%kf8::E|Nt2icPYM.aB">
        <field name="NAME">11-Nacht</field>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                             <next>
                               <block type="on_ext" id="CJC}fNA0]pCZXm3|IQhw">
                                 <mutation items="1"></mutation>
                                 <value name="OID0">
                                   <shadow type="field_oid" id="~WnQKdX*p;3`gh]~Gv|}">
                                   </shadow>
                                   <block type="field_oid" id="sLj^7q(fyKCJ@uKYgne@">
                                     <field name="oid">javascript.0.Datenpunkte_own.Alarm.Alarm_AUS</field>
                                   </block>
                                 </value>
                                   <block type="debug" id="^Q)xU7M#5MVip9{Y2$hP">
                                     <value name="TEXT">
                                       <shadow type="text" id="%kcngJ7d=5*$asYlS~T|">
                                         <field name="TEXT">03_Astro test start</field>
                                       </shadow>
                                     </value>
                                     <next>
                                       <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
                                         <mutation delay_input="false"></mutation>
                                         <field name="OID">javascript.0.01-Nachtende</field>
                                         <value name="VALUE">
                                           <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
                                             <mutation format="false" language="false"></mutation>
                                             <field name="OPTION">hh:mm:ss</field>
                                               <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
                                                 <field name="TYPE">nightEnd</field>
                                                 <field name="OFFSET">0</field>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                           <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
                                             <field name="OID">javascript.0.02-Morgendämmerung</field>
                                               <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
                                                   <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
                                                     <field name="TYPE">dawn</field>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
                                                 <field name="OID">javascript.0.03-Sonnenaufgang</field>
                                                   <block type="convert_from_date" id="AMyc:3Tp9XP+4kq(nv-">
                                                       <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
                                                         <field name="TYPE">sunrise</field>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                   <block type="update" id="DwtR_scz+f42pEJ/sKn?">
                                                     <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
                                                       <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
                                                           <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
                                                             <field name="TYPE">sunriseEnd</field>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
                                                         <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
                                                           <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
                                                               <block type="time_astro" id="]qS[Z+Pab*WUXun969T">
        <field name="TYPE">goldenHourEnd</field>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="update" id="FjU7x+vB-{|nz?Ntgi]B">
                                                             <field name="OID">javascript.0.06-Mittag</field>
                                                               <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
        <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
        <field name="TYPE">solarNoon</field>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
                                                               <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
        <field name="OID">javascript.0.07-Golden_Houer</field>
        <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^">
        <block type="time_astro" id="~MgPI%%B44O6EzrHu._C">
        <field name="TYPE">goldenHour</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="g|Q7g?g_fO6AjzFr(le">
        <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
        <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF">
        <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
        <field name="TYPE">sunsetStart</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
        <field name="OID">javascript.0.09-Sonnenuntergang</field>
        <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
        <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
        <field name="TYPE">sunset</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="okk0X1l~(0(nUW+Re46b">
        <field name="OID">javascript.0.10-Abenddämmerung</field>
        <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
        <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
        <field name="TYPE">dusk</field>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
        <field name="OID">javascript.0.11-Nacht</field>
        <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
        <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
        <field name="TYPE">night</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                          </xml>
                          and got this
                          seems OK for your location.
                          What else could I check?
                            restartet the Host.
                            Run this Blockly:
        </block>
        </statement>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                               <next>
                                   <value name="OID0">
                                     </shadow>
                                     </block>
                                   </value>
                                       <value name="TEXT">
                                         </shadow>
                                       </value>
                                       <next>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </next>
                             </block>
                            </xml>
                            and got this
                            ap2017
                            @iomountain Please run with both system ASTRO and adapter ASTRO set to my location. Thank you.
                              iomountainI Offline
                              iomountain
                              I set the location to:
                              ssh on HOST sudo reboot -h now
                              Run this Blockly:
        <block type="create" id="m8=S(!$%YPfP56~qYN-V">
        <field name="NAME">12-Nadir</field>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                   </block>
                                 </statement>
                                 <next>
                                     <value name="OID0">
                                       </shadow>
                                       </block>
                                     </value>
                                         <value name="TEXT">
                                           </shadow>
                                         </value>
                                         <next>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="update" id="r4Pp!x8AYRH2ByxfJ-uj">
        <field name="OID">javascript.0.12-Nadir</field>
        <block type="convert_from_date" id="70t2I`G4:U{os`6!_.!i">
        <block type="time_astro" id="s:0TbVo8LNISj)?5m=fr">
        <field name="TYPE">nadir</field>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                   </block>
                                 </next>
                               </block>
                              </xml>
                              got this:
                              javascript was set to:
                              A 3 Antworten Letzte Antwort
                                Run this Blockly:
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                     </block>
                                   </statement>
                                   <next>
                                       <value name="OID0">
                                         </shadow>
                                         </block>
                                       </value>
                                           <value name="TEXT">
                                             </shadow>
                                           </value>
                                           <next>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                                </xml>
                                got this:
                                ap2017
                                @iomountain Thanks! I will try again on new X64 computer with freshly loaded software.
                                  Run this Blockly:
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
                                                               </block>
                                                             </statement>
                                                           </block>
                                                         </statement>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </statement>
                                       </block>
                                     </statement>
                                     <next>
                                         <value name="OID0">
                                           </shadow>
                                           </block>
                                         </value>
                                             <value name="TEXT">
                                               </shadow>
                                             </value>
                                             <next>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                  </xml>
                                  got this:
                                  ap2017
                                  @iomountain This script works fine when started, it creates objects, but I want to use ASTRO to turn ON my lights repeatably, that what I have trouble with.
                                    Run this Blockly:
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
        </statement>
        </block>
                                                               </statement>
                                                             </block>
                                                           </statement>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </statement>
                                       <next>
                                           <value name="OID0">
                                             </shadow>
                                             </block>
                                           </value>
                                               <value name="TEXT">
                                                 </shadow>
                                               </value>
                                               <next>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                   <next>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <next>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                    </xml>
                                    got this:
                                    ap2017
                                    @iomountain After all latest updates ASTRO seems to work fine. Don't exactly know what happened, but it works. Thank you for your help
                                      iomountainI Offline
                                      iomountain
                                      schön das es jetzt läuft, hab noch viel Spass mit iobroker.
                                      Vielleicht kannst du noch Deine Version posten und den Tread auf gelöst setzen.
                                      Viele Grüße
                                      Ralph
                                        ap2017
                                        Have this issue with ASTRO again after adding few different lights to control by ASTRO. Same problem as before, function ASTRO is ignored by the system - nothing in debug log.
                                        Here is my script:
                                        schedule({astro: "goldenHour", shift: 0}, function () {
                                        console.log('astro_on_golden_hour');
                                        // Florida Room
                                        setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                                        // Living
                                        setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, true);
                                        // TV Room
                                        setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                                        // Office
                                        setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                                        schedule({astro: "dusk", shift: 0}, function () {
                                        console.log('astro_on_sunset');
                                        // Outside
                                        setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, true);
                                        // Front Door
                                        setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, true);
                                        schedule("30 23 * * *", function () {
                                        console.log('schedule_off');
                                        // Florida Room
                                        setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                                        // Living
                                        setState("zwave.0.NODE2.SWITCH_BINARY.Switch_1"/Switch/, false);
                                        // Outside
                                        setState("zwave.0.NODE11.SWITCH_BINARY.Switch_1"/Switch/, false);
                                        // TV Room
                                        setState("zigbee.0.000b57fffebcfc39.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                                        // Office
                                        setState("zigbee.0.90fd9ffffe2bad6b.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                                        // Front Door
                                        setState("zigbee.0.d0cf5efffe7d475c.state"/TRADFRI bulb E26 W opal 1000lm Switch state/, false);
                                        // Basement Light
                                        on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: true}, function (obj) {
                                        var value = obj.state.val;
                                        setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, true);
                                        setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, true);
                                        on({id: "mysensors.0.9.3_DOOR.V_TRIPPED"/9.3_DOOR.V_TRIPPED/, val: false}, function (obj) {
                                        setState("zwave.0.NODE15.SWITCH_BINARY.Switch_1"/Switch/, false);
                                        setState("zwave.0.NODE16.SWITCH_BINARY.Switch_1"/Switch/, false);
                                        • C Offline
                                          cbr
                                          schrieb am zuletzt editiert von cbr
                                          Hello everybody,
                                          first of all I'm new to ioBroker (I installed it on a Raspberry Pi 4 just recently).
                                          However I'm having a similar problem.
                                          I have two scripts:
                                          Switch by ping
                                          var bool_NightTime;
                                          function HS100_switch() {
                                          if (bool_NightTime == true && getState("ping.0.raspberrypi.IP").val == true) {
                                          setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, true);
                                          } else {
                                          setState("hs100.0.IP.state"/HS100_Arbeitszimmer/, false);
                                          bool_NightTime = compareTime(getAstroDate("sunrise", undefined, 0), getAstroDate("sunset", undefined, -20), "not between", null);
                                          console.log(('NightTime: ' + String(('' + bool_NightTime))));
                                          schedule({astro: "sunset", shift: -20}, function () {
                                          console.log('Sonne untergegangen -20 Min');
                                          bool_NightTime = true;
                                          HS100_switch();
                                          schedule({astro: "sunrise", shift: 0}, function () {
                                          bool_NightTime = false;
                                          HS100_switch();
                                          on({id: "ping.0.raspberrypi.IP"/Rechnername/, change: "ne"}, function (obj) {
                                          HS100_switch();
                                          Switch by power
                                          var _const_val_PowerLimit, bool_NightTime;
                                          if (getState("hs100.0.IP.power").val < _const_val_PowerLimit && bool_NightTime == true && getState("fb-checkpresence.0.presence").val == true) {
                                          setState("hs100.0.IP.state"/HS100/, true);
                                          } else {
                                          setState("hs100.0.IP.state"/HS100/, false);
                                          _const_val_PowerLimit = 90;
                                          bool_NightTime = compareTime(getAstroDate("sunset", undefined, -20), '23:00', "between", null) && compareTime('22:30', null, "<", getAstroDate("sunset", undefined, -20));
                                          if (compareTime("22:30", "null", "<")) {
                                          HS100_switch();
                                          schedule("0 23 * * *", function () {
                                          HS100_switch();
                                          on({id: "hs100.0.IP.power"/HS110/, change: "ne"}, function (obj) {
                                          HS100_switch();
                                          on({id: "fb-checkpresence.0.presence"/presence/, change: "ne"}, function (obj) {
                                          HS100_switch();
                                          In both of them I use:
                                            /* additional code */
                                          However the astro function today only triggered for the "Switch by ping" script- see logfile:
                                          2020-04-01 19:35:27.992  - ^[[32minfo^[[39m: javascript.0 (665) script.js.common.Switch_by_ping: Sonne untergegangen -20 Min
                                          Yesterday it was working for both scripts. (Also the days before it was already inconsistent - however I only had the "Switch by power" script at that time.)
                                          I'm restarting my raspberry every night and only added the console.log by today so I cannot tell about the recent days.
                                          Any idea what could cause this issue?
