  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
  • Neuer Installer und neuer Fixer: übersichtliche Oberfläche und `iob docker`
  • Mitmachen: Sprich „ioBroker“ ein – für ein lokales Aktivierungswort
  • Neuer Blogbeitrag: KI in ioBroker, vom Helfer im Admin bis zum eigenen Smart Assistant
blockly
58 Beiträge 6 Kommentatoren 14.5k Aufrufe 7 Beobachtet
  • A ap2017
    @iomountain Here is the log from running your script Astro Time for Today, if it helps. So, script runs but shows error code at the end of each run.
    2019-10-19 18:48:42.414 - info: mysensors.0 (18452) STARTED
    2019-10-19 18:48:42.415 - info: mysensors.0 (18452) STARTED
    2019-10-19 18:48:55.725 - info: javascript.0 (18920) Stop script script.js.ASTRO
    2019-10-19 18:48:55.770 - info: javascript.0 (18920) Start javascript script.js.ASTRO
    2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: =====================
    2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: Astro time for today
    2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: (0) nightEnd (End of night)........................: 5:36:06 AM
    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (1) nauticalDawn (naut. Dämmerung Morgens)...........: 6:08:18 AM
    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (2) dawn (Dämmerung Morgens).........................: 6:40:39 AM
    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (3) sunrise (Sonnenaufgang)..........................: 7:08:50 AM
    2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (4) sunriseEnd (Ende des Sonnenaufgangs).............: 7:11:46 AM
    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (5) goldenHourEnd (Ende der Golden Hour VM)..........: 7:46:57 AM
    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (6) solarNoon (Mittag)...............................: 12:37:25 PM
    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (7) goldenHour (Start der Golden Hour NM)............: 5:27:52 PM
    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (8) sunsetStart (Start des Sonnenuntergangs).........: 6:03:04 PM
    2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (9) sunset (Sonnenuntergang).........................: 6:06:00 PM
    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (10) dusk (Dämmerung Abends)..........................: 6:34:11 PM
    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (11) nauticalDusk (naut. Dämmerung Abends)............: 7:06:31 PM
    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (12) night (Start of night)..........................: 7:38:44 PM
    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (13) nadir (midnight)..............................: 12:37:25 AM
    2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: =====================
    2019-10-19 18:48:55.777 - info: javascript.0 (18920) script.js.ASTRO: Night starts tomorrow at 7:37:17 PM
    2019-10-19 18:48:55.777 - error: javascript.0 (18920) script.js.ASTRO: script.js.ASTRO:41
    2019-10-19 18:48:55.777 - error: javascript.0 (18920) console.log(obj.id);
    2019-10-19 18:48:55.778 - error: javascript.0 (18920) ^
    2019-10-19 18:48:55.778 - error: javascript.0 (18920) ReferenceError: obj is not defined
    2019-10-19 18:48:55.778 - error: javascript.0 (18920) at script.js.ASTRO:41:13
    2019-10-19 18:48:55.778 - error: javascript.0 (18920) at Script.runInContext (vm.js:133:20)
    iomountainI
    iomountainI
    iomountain
    @ap2017 sagte in ASTRO function:
    shows that the AstroFunktion works
    What about the log of your script?
    A 1 Antwort Letzte Antwort
    • iomountainI iomountain
      A
      A
      ap2017
      @iomountain Here is my complete log from yesterday. Notice that in 18:58 I added your script with ASTRO Time for Day. Thank you for your help!
      10-20-19 Log.txt
      • iomountainI
        iomountainI
        iomountain
        something going wrong with ASTRO, still testing.
        • iomountainI
          iomountainI
          iomountain
          Could you please test this for 24 hours:
           <block type="comment" id="dZ/@oL!i0(@/:!$Ikw{J" x="13" y="13">
             <field name="COMMENT">Test Astro</field>
             <next>
               <block type="astro" id="sxZ*u!O2O8lf$a?qgNf%">
                 <field name="TYPE">sunrise</field>
                 <field name="OFFSET">0</field>
                 <statement name="STATEMENT">
                   <block type="debug" id="f0h|hnMOj,t0a9F4R/*u">
                     <field name="Severity">error</field>
                     <value name="TEXT">
                       <shadow type="text" id="t~{SzkO:N+m/c:_aXvF_">
                         <field name="TEXT">Sonnenaufgang</field>
                       </shadow>
                     </value>
                     <next>
                       <block type="debug" id=";Kc+}!GR24eQ4F1zvsqz">
                         <value name="TEXT">
                           <shadow type="text" id="d7@Q.7Mu+wBczv=iaKT?">
                           </shadow>
                           <block type="time_get" id="0}ve}|zeLByf%Wn1)Z~N">
                             <mutation format="true" language="false"></mutation>
                             <field name="OPTION">custom</field>
                             <field name="FORMAT">JJJJ-MM-TT SS:mm:ss.sss</field>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
                 <next>
                   <block type="astro" id="e%0Te`wUBXm0Z(Tm~(uK">
                     <field name="TYPE">sunriseEnd</field>
                       <block type="debug" id="~yMY;Z`RDhY|PgL8aLYT">
                         <value name="TEXT">
                           <shadow type="text" id="{(iRk-Wgsniu)/OWNuec">
                             <field name="TEXT">Sonnenaufgang ende</field>
                           </shadow>
                         </value>
                         <next>
                           <block type="debug" id="q|N1he7_#J*z!t:Lxbq4">
                             <value name="TEXT">
                               </shadow>
                               <block type="time_get" id="tJ*UF;cM+aI^pYR^Qa;1">
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                     <next>
                       <block type="astro" id="7-p8CPh^EAGz7TZ[HE=f">
                         <field name="TYPE">goldenHourEnd</field>
                           <block type="debug" id="#jT`iz!Nlmm:r|h0-a;{">
                             <value name="TEXT">
                               <shadow type="text" id="sF]?KilHL=/lQ@|f$!#B">
                                 <field name="TEXT">Golden hour Ende</field>
                               </shadow>
                             </value>
                             <next>
                               <block type="debug" id="?jcK[-lRY6m67kH94cJ8">
                                 <value name="TEXT">
                                   </shadow>
                                   <block type="time_get" id=":6c/3{e5w_Qr@--(F2,$">
                                   </block>
                                 </value>
                               </block>
                             </next>
                           </block>
                         </statement>
                         <next>
                           <block type="astro" id="tK}:wS(k,Xmf4I2Ms^,]">
                             <field name="TYPE">solarNoon</field>
                               <block type="debug" id="sYbNw@$;Db5D:)VF)*b}">
                                 <value name="TEXT">
                                   <shadow type="text" id="h9Pt!n;uDsK%[C8H0T:-">
                                     <field name="TEXT">Sonnenmittag</field>
                                   </shadow>
                                 </value>
                                 <next>
                                   <block type="debug" id="0z@Vv^UhX8S(2Uk.L}AX">
                                     <value name="TEXT">
                                       </shadow>
                                       <block type="time_get" id="63mXGB7G3:L?++1KLilu">
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                             <next>
                               <block type="astro" id="2X-czA2y[$Ug?5[Q_aUV">
                                 <field name="TYPE">goldenHour</field>
                                   <block type="debug" id="VvR2BxdbZn.+TuU)7yLe">
                                     <value name="TEXT">
                                       <shadow type="text" id="#r/L5Io)*?Qz!Co)U:Jc">
                                         <field name="TEXT">Golden hour</field>
                                       </shadow>
                                     </value>
                                     <next>
                                       <block type="debug" id="vO^xDs|z,PXJo=OKQ=bY">
                                         <value name="TEXT">
                                           </shadow>
                                           <block type="time_get" id="8b(z1|U:aT{s/-zQOG-O">
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                                 <next>
                                   <block type="astro" id="dLczmmMSoFlkvb*/H*SF">
                                     <field name="TYPE">sunsetStart</field>
                                       <block type="debug" id="S%o3:;|MkGT:WNoq-5I/">
                                         <value name="TEXT">
                                           <shadow type="text" id="oZW7=ox`@zO:d)Qo`jM#">
                                             <field name="TEXT">Sonnenuntergang Anfang</field>
                                           </shadow>
                                         </value>
                                         <next>
                                           <block type="debug" id="88*2`mY-$F4-h46R$bsh">
                                             <value name="TEXT">
                                               </shadow>
                                               <block type="time_get" id="=yV74{gTTEshyETA[YT+">
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                     <next>
                                       <block type="astro" id="`E^X3.`tEYD#t?w3p[Y6">
                                         <field name="TYPE">sunset</field>
                                           <block type="debug" id="3y?c.oF8m3]qo`y^Sk2Y">
                                             <value name="TEXT">
                                               <shadow type="text" id="_^a1$PSDO%=0T$ouPs,z">
                                                 <field name="TEXT">Sonnenuntergang</field>
                                               </shadow>
                                             </value>
                                             <next>
                                               <block type="debug" id="B{Xk(=sas9lxfcPeH~8l">
                                                 <value name="TEXT">
                                                   </shadow>
                                                   <block type="time_get" id="?;boy8-PvsRtK^R`i(d!">
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                         <next>
                                           <block type="astro" id="yk2LFSH:M4]t,=g+r0Zr">
                                             <field name="TYPE">dusk</field>
                                               <block type="debug" id="JVc5|ie7ToL`o0+q*H6)">
                                                 <value name="TEXT">
                                                   <shadow type="text" id=":3i#l]vFr9mFH`8A9d40">
                                                     <field name="TEXT">Abenddämmerung</field>
                                                   </shadow>
                                                 </value>
                                                 <next>
                                                   <block type="debug" id="}#5$Eg5HxUq%N?JiZUB|">
                                                     <value name="TEXT">
                                                       </shadow>
                                                       <block type="time_get" id="C8-_%?]~kLQbzj4$5M:w">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                               <block type="astro" id="o1Y86d?aD}-85W@_Bc{X">
                                                 <field name="TYPE">nauticalDusk</field>
                                                   <block type="debug" id="[y[=-3!xjqWbFILYTKrT">
                                                     <value name="TEXT">
                                                       <shadow type="text" id="(Ka/nD(#:R%T5M;oQVo+">
                                                         <field name="TEXT">Nautische Abenddämmerung</field>
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                       <block type="debug" id="hQnK;WRQD=[=PuGnpeC^">
                                                         <value name="TEXT">
                                                           </shadow>
                                                           <block type="time_get" id="1*6{GuA}Ptl}@=:RYN8E">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                   <block type="astro" id="j8y_r:dEbMD7iY2.W7L,">
                                                     <field name="TYPE">night</field>
                                                       <block type="debug" id="76(?!SO)O1xP:}liKAC%">
                                                         <value name="TEXT">
                                                           <shadow type="text" id="hkdb,q:hVvOIp?ukBqRa">
                                                             <field name="TEXT">Nacht</field>
                                                           </shadow>
                                                         </value>
                                                         <next>
                                                           <block type="debug" id="K`Fpc2JYxRBNQEc[yo9_">
                                                             <value name="TEXT">
                                                               </shadow>
                                                               <block type="time_get" id="f.=BzucV$CL,2#_}W7wU">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                       <block type="astro" id=",EU+9{ySUaqT/?CfG5ap">
                                                         <field name="TYPE">nightEnd</field>
                                                           <block type="debug" id="nk=,IYJu$$)~c%9EMNZL">
                                                             <value name="TEXT">
                                                               <shadow type="text" id="?@=$%L4#!G}2|rgS]c=?">
        <field name="TEXT">Nachtende</field>
                                                               </shadow>
                                                             </value>
                                                             <next>
                                                               <block type="debug" id="U_1^p,G9]J.];Zq9X~LM">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="Wq.(8ZwGLimw6:lfSa!V">
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </statement>
                                                         <next>
                                                           <block type="astro" id="Sz%RA[al07GBMdE@p1Gz">
                                                             <field name="TYPE">nauticalDawn</field>
                                                               <block type="debug" id="`y(OGo$-nPG8Ej5m[BHG">
        <value name="TEXT">
        <shadow type="text" id="EOoN^Uh$_,d+JSl]lGUh">
        <field name="TEXT">Nautische Morgendämmerung</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="0S99AV1F|DJLUd,(d?qc">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="YOyQlgY?b(gtz4v^}j+H">
        </block>
        </value>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                             <next>
                                                               <block type="astro" id="Vw^5UMBH6vtWJyaq53.]">
        <field name="TYPE">dawn</field>
        <block type="debug" id="19?SR^q{j;E8z!!;D7[)">
        <value name="TEXT">
        <shadow type="text" id="Ar4KDdxuaHRys!_~m2WV">
        <field name="TEXT">Morgendämmerung</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="=m0|q1#NNjFK3(dAk!Ad">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="78Wc.sXU9AC;tMV..MwN">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="astro" id="i`FUoNopylwQy:QgoJ}v">
        <field name="TYPE">nadir</field>
        <block type="debug" id="r(e93[h_`7D!QfmFL~Mf">
        <value name="TEXT">
        <shadow type="text" id="|P[TC/:yl.5FkD_HO*./">
        <field name="TEXT">Nadir</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="Dhca#mXRR2KV}e}.Opj$">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="f[j$/@]5]_7kP7mnP#ds">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
          </xml>
          A 2 Antworten Letzte Antwort
          • iomountainI
            iomountainI
            iomountain
            Mine works:
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenmittag
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenuntergang Anfang
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Abenddämmerung
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Abenddämmerung
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nacht
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nadir
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nachtende
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Morgendämmerung
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Morgendämmerung
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang ende
            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour Ende
            if you dont have all these "errors" in your log, we try next ideas, or compare Versions.
              Mine works:
              A
              A
              ap2017
              @iomountain sorry, I am traveling now, will be able to try next week
              • iomountainI
                iomountainI
                iomountain
                mine works:
                my Versions of Software:
                Node.js v10.16.3
                NPM 6.9.0
                     <next>
                             <value name="TEXT">
                               </shadow>
                             </value>
                             <next>
                                 <value name="TEXT">
                                   </shadow>
                                   </block>
                                 </value>
                               </block>
                             </next>
                           </block>
                         </statement>
                         <next>
                                 <value name="TEXT">
                                   </shadow>
                                 </value>
                                 <next>
                                     <value name="TEXT">
                                       </shadow>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                             <next>
                                     <value name="TEXT">
                                       </shadow>
                                     </value>
                                     <next>
                                         <value name="TEXT">
                                           </shadow>
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                                 <next>
                                         <value name="TEXT">
                                           </shadow>
                                         </value>
                                         <next>
                                             <value name="TEXT">
                                               </shadow>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                     <next>
                                             <value name="TEXT">
                                               </shadow>
                                             </value>
                                             <next>
                                                 <value name="TEXT">
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                         <next>
                                                 <value name="TEXT">
                                                   </shadow>
                                                 </value>
                                                 <next>
                                                     <value name="TEXT">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                                     <value name="TEXT">
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                         <value name="TEXT">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                         <value name="TEXT">
                                                           </shadow>
                                                         </value>
                                                         <next>
                                                             <value name="TEXT">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                             <value name="TEXT">
                                                               </shadow>
                                                             </value>
                                                             <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </statement>
                                                         <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                             <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                  </xml>
                  A
                  A
                  ap2017
                  @iomountain I am getting this error while saving your script:
                  10/27/2019, 10:30:21 PM.531 [error]: javascript.0 (18920) script.js.ASTRO compile failed:
                  at script.js.ASTRO:1
                       <next>
                               <value name="TEXT">
                                 </shadow>
                               </value>
                               <next>
                                   <value name="TEXT">
                                     </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                                   <value name="TEXT">
                                     </shadow>
                                   </value>
                                   <next>
                                       <value name="TEXT">
                                         </shadow>
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                               <next>
                                       <value name="TEXT">
                                         </shadow>
                                       </value>
                                       <next>
                                           <value name="TEXT">
                                             </shadow>
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                   <next>
                                           <value name="TEXT">
                                             </shadow>
                                           </value>
                                           <next>
                                               <value name="TEXT">
                                                 </shadow>
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                       <next>
                                               <value name="TEXT">
                                                 </shadow>
                                               </value>
                                               <next>
                                                   <value name="TEXT">
                                                     </shadow>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                           <next>
                                                   <value name="TEXT">
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                       <value name="TEXT">
                                                         </shadow>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <next>
                                                       <value name="TEXT">
                                                         </shadow>
                                                       </value>
                                                       <next>
                                                           <value name="TEXT">
                                                             </shadow>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                           <value name="TEXT">
                                                             </shadow>
                                                           </value>
                                                           <next>
                                                               <value name="TEXT">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                       <next>
                                                               <value name="TEXT">
        </shadow>
                                                               </value>
                                                               <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                           <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </statement>
                                                               <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                    </xml>
                    A
                    A
                    ap2017
                    @iomountain Actually, here is log after starting your script:
                    2019-10-27 22:35:16.197 - info: javascript.0 (18920) Stop script script.js.ASTRO
                    2019-10-27 22:35:20.358 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                    2019-10-27 22:35:20.358 - error: javascript.0 (18920) script.js.ASTRO compile failed:
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) ^
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) SyntaxError: Unexpected token <
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at new Script (vm.js:83:7)
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at Object.createScript (vm.js:277:10)
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:433:21)
                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at process._tickCallback (internal/process/next_tick.js:68:7)
                      mine works:
                      Node.js v10.16.3
                      NPM 6.9.0
                      A
                      A
                      ap2017
                      @iomountain My system:
                      Script Engine 4.3.1
                      Node.js 10.16.3
                      NPM 6.9.0
                      • iomountainI
                        iomountainI
                        iomountain
                        My script is a Blockly:
                          A
                          A
                          ap2017
                          @iomountain Thank you, will enter and start it tonight
                          • A ap2017
                            A
                            A
                            ap2017
                            schrieb am zuletzt editiert von ap2017
                            @ap2017 Please see log attached, ASTRO does not work. Server was restarted after scrip creation yesterday evening. Currently my script adapter configured for System ASTRO Settings, shows my street on the screen. I am wondering if possible to debug how system sees my location.
                            Tonight I will change Script Adapter ASTRO location to Germany and run same script over night.
                            10-29-19.txt
                            My script:
                            • iomountainI
                              iomountainI
                              iomountain
                              you can check the times at https://www.suncalc.org if you can get them.
                                A
                                A
                                ap2017
                                @iomountain I mean is there a way to check how ioBroker see my location? Maybe ASTRO gets screwed up because location is screwed up.
                                • iomountainI
                                  iomountainI
                                  iomountain
                                  schrieb am zuletzt editiert von iomountain
                                  I am not sure, but i think what astro uses is only this:
                                  Is the Date and Time of your Operating System set right?
                                    A
                                    A
                                    ap2017
                                    @iomountain Here is the log with location in adapter ASTRO set to Germany. ASTRO seems to be working fine. As you can see, script reports ALL ASTRO events, while when my location was set to US it reported only few and then died.
                                    10-30-19 log.txt
                                      A
                                      A
                                      ap2017
                                      @iomountain In all my tests location in Overview Settings set to my address, see picture. Not sure what you mean by Date and Time
                                      iomountainI 1 Antwort Letzte Antwort
                                      • A ap2017
                                        iomountainI
                                        iomountainI
                                        iomountain
                                        i use timedatectl on the command line of iobroker host to see all is set correct.
                                        • iomountainI
                                          iomountainI
                                          iomountain
                                          If you config:
                                          you also will find Astro Settings for your location.
                                          84.1k
                                          1.4m
