  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
blockly
58 Beiträge 6 Kommentatoren 14.6k Aufrufe 7 Beobachtet
  • iomountainI iomountain
    @ap2017 for debuging use debug, not telegram.
    substitute telegram whith debug to see what's going on.
    Look at the LOG.
    mine works:
    c8d8d908-8721-440c-b8e0-f1d21907f888-image.png ,
    Do you wanna Post an export of your Blockly?
    A
    A
    ap2017
    @iomountain Thank you for your response. I changed my script as you suggested, where do I find debugging log?
    • iomountainI
      iomountainI
      iomountain
      Try Log at main screen Admin
      There you will find your "debug output" Messages
        A
        A
        ap2017
        @iomountain I think that after long time of straggling I am getting close to resolving the issue with ASTRO function that I am experiencing. It looks like ASTRO algorithm does not like GEO coordinates in North America since it started to work fine after I set ASTRO for Berlin, Germany. Maybe negative value of Longitude confuses the algorithm?
        Could you do me a favor and try your script with GEO set to Hartford CT in USA? Thank you.
        • iomountainI
          iomountainI
          iomountain
          It works, United States Hartford 41.76 -72.68
          If you wanna see all astro times try the Script
          // Astrotime for today - V2.0
          console.log("=====================");
          console.log("Astro time for today");
          var nightEnd = getAstroDate("nightEnd");
          console.log(" (0) nightEnd (End of night)........................: " + nightEnd.toLocaleTimeString());
          var nauticalDawn = getAstroDate("nauticalDawn");
          console.log(" (1) nauticalDawn (naut. Dämmerung Morgens)...........: " + nauticalDawn.toLocaleTimeString());
          var dawn = getAstroDate("dawn");
          console.log(" (2) dawn (Dämmerung Morgens).........................: " + dawn.toLocaleTimeString());
          var sunrise = getAstroDate("sunrise");
          console.log(" (3) sunrise (Sonnenaufgang)..........................: " + sunrise.toLocaleTimeString());
          var sunriseEnd = getAstroDate("sunriseEnd");
          console.log(" (4) sunriseEnd (Ende des Sonnenaufgangs).............: " + sunriseEnd.toLocaleTimeString());
          var goldenHourEnd = getAstroDate("goldenHourEnd");
          console.log(" (5) goldenHourEnd (Ende der Golden Hour VM)..........: " + goldenHourEnd.toLocaleTimeString());
          var solarNoon = getAstroDate("solarNoon");
          console.log(" (6) solarNoon (Mittag)...............................: " + solarNoon.toLocaleTimeString());
          var goldenHour = getAstroDate("goldenHour");
          console.log(" (7) goldenHour (Start der Golden Hour NM)............: " + goldenHour.toLocaleTimeString());
          var sunsetStart = getAstroDate("sunsetStart");
          console.log(" (8) sunsetStart (Start des Sonnenuntergangs).........: " + sunsetStart.toLocaleTimeString());
          var sunset = getAstroDate("sunset");
          console.log(" (9) sunset (Sonnenuntergang).........................: " + sunset.toLocaleTimeString());
          var dusk = getAstroDate("dusk");
          console.log("(10) dusk (Dämmerung Abends)..........................: " + dusk.toLocaleTimeString());
          var nauticalDusk = getAstroDate("nauticalDusk");
          console.log("(11) nauticalDusk (naut. Dämmerung Abends)............: " + nauticalDusk.toLocaleTimeString());
          var night = getAstroDate("night");
          console.log("(12) night (Start of night)..........................: " + night.toLocaleTimeString());
          var nadir = getAstroDate("nadir");
          console.log("(13) nadir (midnight)..............................: " + nadir.toLocaleTimeString());
          var today = new Date();
          var tomorrow = today.setDate(today.getDate()+1);
          var tomorrowNight = getAstroDate("night", tomorrow);
          console.log("Night starts tomorrow at " + tomorrowNight.toLocaleTimeString());
          console.log(obj.id);
          @ap2017
            @ap2017
            A
            A
            ap2017
            @iomountain I will try to set ASTRO back to US, thanks
            • iomountainI
              iomountainI
              iomountain
              @ap2017 don't forget to restart iobroker. Like "iobroker stop" and "iobroker start"
              A 2 Antworten Letzte Antwort
                A
                A
                ap2017
                @iomountain Day I switched to US the ASTRO stopped working (no ASTRO string in LOG file). I restarted computer after I made a change. I will try your ASTRO script
                Here is my script:
                // Living Room Light
                schedule({astro: "goldenHour", shift: 0}, function () {
                console.log('astro_on');
                setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                schedule("0 18 * * *", function () {
                console.log('schedule_on');
                schedule("30 23 * * *", function () {
                console.log('schedule_off');
                setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                  A
                  A
                  ap2017
                  @iomountain Here is the log from running your script Astro Time for Today, if it helps. So, script runs but shows error code at the end of each run.
                  2019-10-19 18:48:42.414 - info: mysensors.0 (18452) STARTED
                  2019-10-19 18:48:42.415 - info: mysensors.0 (18452) STARTED
                  2019-10-19 18:48:55.725 - info: javascript.0 (18920) Stop script script.js.ASTRO
                  2019-10-19 18:48:55.770 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                  2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: =====================
                  2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: Astro time for today
                  2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: (0) nightEnd (End of night)........................: 5:36:06 AM
                  2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (1) nauticalDawn (naut. Dämmerung Morgens)...........: 6:08:18 AM
                  2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (2) dawn (Dämmerung Morgens).........................: 6:40:39 AM
                  2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (3) sunrise (Sonnenaufgang)..........................: 7:08:50 AM
                  2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (4) sunriseEnd (Ende des Sonnenaufgangs).............: 7:11:46 AM
                  2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (5) goldenHourEnd (Ende der Golden Hour VM)..........: 7:46:57 AM
                  2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (6) solarNoon (Mittag)...............................: 12:37:25 PM
                  2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (7) goldenHour (Start der Golden Hour NM)............: 5:27:52 PM
                  2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (8) sunsetStart (Start des Sonnenuntergangs).........: 6:03:04 PM
                  2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (9) sunset (Sonnenuntergang).........................: 6:06:00 PM
                  2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (10) dusk (Dämmerung Abends)..........................: 6:34:11 PM
                  2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (11) nauticalDusk (naut. Dämmerung Abends)............: 7:06:31 PM
                  2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (12) night (Start of night)..........................: 7:38:44 PM
                  2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (13) nadir (midnight)..............................: 12:37:25 AM
                  2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: =====================
                  2019-10-19 18:48:55.777 - info: javascript.0 (18920) script.js.ASTRO: Night starts tomorrow at 7:37:17 PM
                  2019-10-19 18:48:55.777 - error: javascript.0 (18920) script.js.ASTRO: script.js.ASTRO:41
                  2019-10-19 18:48:55.777 - error: javascript.0 (18920) console.log(obj.id);
                  2019-10-19 18:48:55.778 - error: javascript.0 (18920) ^
                  2019-10-19 18:48:55.778 - error: javascript.0 (18920) ReferenceError: obj is not defined
                  2019-10-19 18:48:55.778 - error: javascript.0 (18920) at script.js.ASTRO:41:13
                  2019-10-19 18:48:55.778 - error: javascript.0 (18920) at Script.runInContext (vm.js:133:20)
                  iomountainI 1 Antwort Letzte Antwort
                  • A ap2017
                    iomountainI
                    iomountainI
                    iomountain
                    @ap2017 sagte in ASTRO function:
                    shows that the AstroFunktion works
                    What about the log of your script?
                      A
                      A
                      ap2017
                      @iomountain Here is my complete log from yesterday. Notice that in 18:58 I added your script with ASTRO Time for Day. Thank you for your help!
                      10-20-19 Log.txt
                      • iomountainI
                        iomountainI
                        iomountain
                        something going wrong with ASTRO, still testing.
                        • iomountainI
                          iomountainI
                          iomountain
                          Could you please test this for 24 hours:
                           <block type="comment" id="dZ/@oL!i0(@/:!$Ikw{J" x="13" y="13">
                             <field name="COMMENT">Test Astro</field>
                             <next>
                               <block type="astro" id="sxZ*u!O2O8lf$a?qgNf%">
                                 <field name="TYPE">sunrise</field>
                                 <field name="OFFSET">0</field>
                                 <statement name="STATEMENT">
                                   <block type="debug" id="f0h|hnMOj,t0a9F4R/*u">
                                     <field name="Severity">error</field>
                                     <value name="TEXT">
                                       <shadow type="text" id="t~{SzkO:N+m/c:_aXvF_">
                                         <field name="TEXT">Sonnenaufgang</field>
                                       </shadow>
                                     </value>
                                     <next>
                                       <block type="debug" id=";Kc+}!GR24eQ4F1zvsqz">
                                         <value name="TEXT">
                                           <shadow type="text" id="d7@Q.7Mu+wBczv=iaKT?">
                                           </shadow>
                                           <block type="time_get" id="0}ve}|zeLByf%Wn1)Z~N">
                                             <mutation format="true" language="false"></mutation>
                                             <field name="OPTION">custom</field>
                                             <field name="FORMAT">JJJJ-MM-TT SS:mm:ss.sss</field>
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                                 <next>
                                   <block type="astro" id="e%0Te`wUBXm0Z(Tm~(uK">
                                     <field name="TYPE">sunriseEnd</field>
                                       <block type="debug" id="~yMY;Z`RDhY|PgL8aLYT">
                                         <value name="TEXT">
                                           <shadow type="text" id="{(iRk-Wgsniu)/OWNuec">
                                             <field name="TEXT">Sonnenaufgang ende</field>
                                           </shadow>
                                         </value>
                                         <next>
                                           <block type="debug" id="q|N1he7_#J*z!t:Lxbq4">
                                             <value name="TEXT">
                                               </shadow>
                                               <block type="time_get" id="tJ*UF;cM+aI^pYR^Qa;1">
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                     <next>
                                       <block type="astro" id="7-p8CPh^EAGz7TZ[HE=f">
                                         <field name="TYPE">goldenHourEnd</field>
                                           <block type="debug" id="#jT`iz!Nlmm:r|h0-a;{">
                                             <value name="TEXT">
                                               <shadow type="text" id="sF]?KilHL=/lQ@|f$!#B">
                                                 <field name="TEXT">Golden hour Ende</field>
                                               </shadow>
                                             </value>
                                             <next>
                                               <block type="debug" id="?jcK[-lRY6m67kH94cJ8">
                                                 <value name="TEXT">
                                                   </shadow>
                                                   <block type="time_get" id=":6c/3{e5w_Qr@--(F2,$">
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                         <next>
                                           <block type="astro" id="tK}:wS(k,Xmf4I2Ms^,]">
                                             <field name="TYPE">solarNoon</field>
                                               <block type="debug" id="sYbNw@$;Db5D:)VF)*b}">
                                                 <value name="TEXT">
                                                   <shadow type="text" id="h9Pt!n;uDsK%[C8H0T:-">
                                                     <field name="TEXT">Sonnenmittag</field>
                                                   </shadow>
                                                 </value>
                                                 <next>
                                                   <block type="debug" id="0z@Vv^UhX8S(2Uk.L}AX">
                                                     <value name="TEXT">
                                                       </shadow>
                                                       <block type="time_get" id="63mXGB7G3:L?++1KLilu">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                               <block type="astro" id="2X-czA2y[$Ug?5[Q_aUV">
                                                 <field name="TYPE">goldenHour</field>
                                                   <block type="debug" id="VvR2BxdbZn.+TuU)7yLe">
                                                     <value name="TEXT">
                                                       <shadow type="text" id="#r/L5Io)*?Qz!Co)U:Jc">
                                                         <field name="TEXT">Golden hour</field>
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                       <block type="debug" id="vO^xDs|z,PXJo=OKQ=bY">
                                                         <value name="TEXT">
                                                           </shadow>
                                                           <block type="time_get" id="8b(z1|U:aT{s/-zQOG-O">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                   <block type="astro" id="dLczmmMSoFlkvb*/H*SF">
                                                     <field name="TYPE">sunsetStart</field>
                                                       <block type="debug" id="S%o3:;|MkGT:WNoq-5I/">
                                                         <value name="TEXT">
                                                           <shadow type="text" id="oZW7=ox`@zO:d)Qo`jM#">
                                                             <field name="TEXT">Sonnenuntergang Anfang</field>
                                                           </shadow>
                                                         </value>
                                                         <next>
                                                           <block type="debug" id="88*2`mY-$F4-h46R$bsh">
                                                             <value name="TEXT">
                                                               </shadow>
                                                               <block type="time_get" id="=yV74{gTTEshyETA[YT+">
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                       <block type="astro" id="`E^X3.`tEYD#t?w3p[Y6">
                                                         <field name="TYPE">sunset</field>
                                                           <block type="debug" id="3y?c.oF8m3]qo`y^Sk2Y">
                                                             <value name="TEXT">
                                                               <shadow type="text" id="_^a1$PSDO%=0T$ouPs,z">
        <field name="TEXT">Sonnenuntergang</field>
                                                               </shadow>
                                                             </value>
                                                             <next>
                                                               <block type="debug" id="B{Xk(=sas9lxfcPeH~8l">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="?;boy8-PvsRtK^R`i(d!">
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </statement>
                                                         <next>
                                                           <block type="astro" id="yk2LFSH:M4]t,=g+r0Zr">
                                                             <field name="TYPE">dusk</field>
                                                               <block type="debug" id="JVc5|ie7ToL`o0+q*H6)">
        <value name="TEXT">
        <shadow type="text" id=":3i#l]vFr9mFH`8A9d40">
        <field name="TEXT">Abenddämmerung</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="}#5$Eg5HxUq%N?JiZUB|">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="C8-_%?]~kLQbzj4$5M:w">
        </block>
        </value>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                             <next>
                                                               <block type="astro" id="o1Y86d?aD}-85W@_Bc{X">
        <field name="TYPE">nauticalDusk</field>
        <block type="debug" id="[y[=-3!xjqWbFILYTKrT">
        <value name="TEXT">
        <shadow type="text" id="(Ka/nD(#:R%T5M;oQVo+">
        <field name="TEXT">Nautische Abenddämmerung</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="hQnK;WRQD=[=PuGnpeC^">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="1*6{GuA}Ptl}@=:RYN8E">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="astro" id="j8y_r:dEbMD7iY2.W7L,">
        <field name="TYPE">night</field>
        <block type="debug" id="76(?!SO)O1xP:}liKAC%">
        <value name="TEXT">
        <shadow type="text" id="hkdb,q:hVvOIp?ukBqRa">
        <field name="TEXT">Nacht</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="K`Fpc2JYxRBNQEc[yo9_">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="f.=BzucV$CL,2#_}W7wU">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="astro" id=",EU+9{ySUaqT/?CfG5ap">
        <field name="TYPE">nightEnd</field>
        <block type="debug" id="nk=,IYJu$$)~c%9EMNZL">
        <value name="TEXT">
        <shadow type="text" id="?@=$%L4#!G}2|rgS]c=?">
        <field name="TEXT">Nachtende</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="U_1^p,G9]J.];Zq9X~LM">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="Wq.(8ZwGLimw6:lfSa!V">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="astro" id="Sz%RA[al07GBMdE@p1Gz">
        <field name="TYPE">nauticalDawn</field>
        <block type="debug" id="`y(OGo$-nPG8Ej5m[BHG">
        <value name="TEXT">
        <shadow type="text" id="EOoN^Uh$_,d+JSl]lGUh">
        <field name="TEXT">Nautische Morgendämmerung</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="0S99AV1F|DJLUd,(d?qc">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="YOyQlgY?b(gtz4v^}j+H">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="astro" id="Vw^5UMBH6vtWJyaq53.]">
        <field name="TYPE">dawn</field>
        <block type="debug" id="19?SR^q{j;E8z!!;D7[)">
        <value name="TEXT">
        <shadow type="text" id="Ar4KDdxuaHRys!_~m2WV">
        <field name="TEXT">Morgendämmerung</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="=m0|q1#NNjFK3(dAk!Ad">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="78Wc.sXU9AC;tMV..MwN">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <block type="astro" id="i`FUoNopylwQy:QgoJ}v">
        <field name="TYPE">nadir</field>
        <block type="debug" id="r(e93[h_`7D!QfmFL~Mf">
        <value name="TEXT">
        <shadow type="text" id="|P[TC/:yl.5FkD_HO*./">
        <field name="TEXT">Nadir</field>
        </shadow>
        </value>
        <next>
        <block type="debug" id="Dhca#mXRR2KV}e}.Opj$">
        <value name="TEXT">
        </shadow>
        <block type="time_get" id="f[j$/@]5]_7kP7mnP#ds">
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                          </xml>
                          • iomountainI
                            iomountainI
                            iomountain
                            Mine works:
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenmittag
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenuntergang Anfang
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Abenddämmerung
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Abenddämmerung
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nacht
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nadir
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nachtende
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Nautische Morgendämmerung
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Morgendämmerung
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Sonnenaufgang ende
                            javascript.0 (18374) script.js.Scripte_zum_Testen.01_ASTRO_TEST_01: Golden hour Ende
                            if you dont have all these "errors" in your log, we try next ideas, or compare Versions.
                              Mine works:
                              A
                              A
                              ap2017
                              @iomountain sorry, I am traveling now, will be able to try next week
                              • iomountainI
                                iomountainI
                                iomountain
                                mine works:
                                my Versions of Software:
                                Node.js v10.16.3
                                NPM 6.9.0
                                     <next>
                                             <value name="TEXT">
                                               </shadow>
                                             </value>
                                             <next>
                                                 <value name="TEXT">
                                                   </shadow>
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                         <next>
                                                 <value name="TEXT">
                                                   </shadow>
                                                 </value>
                                                 <next>
                                                     <value name="TEXT">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                                     <value name="TEXT">
                                                       </shadow>
                                                     </value>
                                                     <next>
                                                         <value name="TEXT">
                                                           </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <next>
                                                         <value name="TEXT">
                                                           </shadow>
                                                         </value>
                                                         <next>
                                                             <value name="TEXT">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                     <next>
                                                             <value name="TEXT">
                                                               </shadow>
                                                             </value>
                                                             <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </statement>
                                                         <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
                                                               </block>
                                                             </statement>
                                                             <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                  </xml>
                                  A
                                  A
                                  ap2017
                                  @iomountain I am getting this error while saving your script:
                                  10/27/2019, 10:30:21 PM.531 [error]: javascript.0 (18920) script.js.ASTRO compile failed:
                                  at script.js.ASTRO:1
                                       <next>
                                               <value name="TEXT">
                                                 </shadow>
                                               </value>
                                               <next>
                                                   <value name="TEXT">
                                                     </shadow>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                           <next>
                                                   <value name="TEXT">
                                                     </shadow>
                                                   </value>
                                                   <next>
                                                       <value name="TEXT">
                                                         </shadow>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                               <next>
                                                       <value name="TEXT">
                                                         </shadow>
                                                       </value>
                                                       <next>
                                                           <value name="TEXT">
                                                             </shadow>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                   <next>
                                                           <value name="TEXT">
                                                             </shadow>
                                                           </value>
                                                           <next>
                                                               <value name="TEXT">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                       <next>
                                                               <value name="TEXT">
        </shadow>
                                                               </value>
                                                               <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
                                                               </next>
                                                             </block>
                                                           </statement>
                                                           <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                               </statement>
                                                               <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        <next>
        <value name="TEXT">
        </shadow>
        </value>
        <next>
        <value name="TEXT">
        </shadow>
        </block>
        </value>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                    </xml>
                                    A
                                    A
                                    ap2017
                                    @iomountain Actually, here is log after starting your script:
                                    2019-10-27 22:35:16.197 - info: javascript.0 (18920) Stop script script.js.ASTRO
                                    2019-10-27 22:35:20.358 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                                    2019-10-27 22:35:20.358 - error: javascript.0 (18920) script.js.ASTRO compile failed:
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) ^
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) SyntaxError: Unexpected token <
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at new Script (vm.js:83:7)
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at Object.createScript (vm.js:277:10)
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:961:28)
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1184:37)
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1237:17)
                                    2019-10-27 22:35:20.359 - error: javascript.0 (18920) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:828:17)
                                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:433:21)
                                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                    2019-10-27 22:35:20.360 - error: javascript.0 (18920) at process._tickCallback (internal/process/next_tick.js:68:7)
                                      mine works:
                                      Node.js v10.16.3
                                      NPM 6.9.0
                                      A
                                      A
                                      ap2017
                                      @iomountain My system:
                                      Script Engine 4.3.1
                                      Node.js 10.16.3
                                      NPM 6.9.0
                                      • iomountainI
                                        iomountainI
                                        iomountain
                                        My script is a Blockly:
                                          A
                                          A
                                          ap2017
                                          @iomountain Thank you, will enter and start it tonight
                                          84.2k
