    5.2k
7.5k Beiträge 335 Kommentatoren 11.4m Aufrufe 254 Beobachtet
  • R rotamint
    @simatec
    shuttercontrol.0
    	2022-06-01 16:36:01.722	debug	WZ Rolladenaktor Panoramafenster.LEVEL Old value = 100. New value = 100. automatic is active
    shuttercontrol.0
    	2022-06-01 16:36:01.578	debug	Shutter WZ Rolladenaktor Panoramafenster.LEVEL was moved manually to: 100% - prevent trigger from driving back
    shuttercontrol.0
    	2022-06-01 16:36:01.578	debug	save current height after State Check: 100% from WZ Rolladenaktor Panoramafenster.LEVEL
    shuttercontrol.0
    	2022-06-01 16:35:56.306	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 146
    shuttercontrol.0
    	2022-06-01 16:35:46.855	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 143
    shuttercontrol.0
    	2022-06-01 16:35:41.364	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 119
    shuttercontrol.0
    	2022-06-01 16:35:38.362	debug	Brightness State Down is: false
    shuttercontrol.0
    	2022-06-01 16:35:35.241	debug	WZ Rolladenaktor Panoramafenster.LEVEL Old value = 100. New value = 36. automatic is active
    shuttercontrol.0
    	2022-06-01 16:35:35.240	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
    shuttercontrol.0
    	2022-06-01 16:35:35.130	debug	Shutter WZ Rolladenaktor Panoramafenster.LEVEL was moved manually to: 36% - prevent trigger from driving back
    shuttercontrol.0
    	2022-06-01 16:35:35.129	debug	save current height after State Check: 36% from WZ Rolladenaktor Panoramafenster.LEVEL
    shuttercontrol.0
    	2022-06-01 16:35:35.082	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    	2022-06-01 16:35:35.081	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
    shuttercontrol.0
    	2022-06-01 16:35:35.071	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
    shuttercontrol.0
    	2022-06-01 16:35:28.574	debug	Sunprotect WZ Rolladenaktor Panoramafenster.LEVEL old height: 100% new height: 100%
    shuttercontrol.0
    	2022-06-01 16:35:28.573	debug	Sunprotect for WZ Rolladenaktor Panoramafenster.LEVEL is not active
    shuttercontrol.0
    	2022-06-01 16:35:28.572	debug	last automatic Action for WZ Rolladenaktor Panoramafenster.LEVEL: up_Sunprotect_end
    shuttercontrol.0
    	2022-06-01 16:35:28.485	info	Sunprotect #421 Set ID: WZ Rolladenaktor Panoramafenster.LEVEL value: 100%
    shuttercontrol.0
    	2022-06-01 16:35:28.361	debug	Brightness sensor value: 2771
    shuttercontrol.0
    	2022-06-01 16:35:26.475	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 80
    shuttercontrol.0
    	2022-06-01 16:35:11.571	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 93
    shuttercontrol.0
    	2022-06-01 16:35:02.078	debug	Sunprotect WZ Rolladenaktor Panoramafenster.LEVEL old height: 100% new height: 36%
    shuttercontrol.0
    	2022-06-01 16:35:02.077	debug	last automatic Action for WZ Rolladenaktor Panoramafenster.LEVEL: down_Sunprotect
    shuttercontrol.0
    	2022-06-01 16:35:02.076	debug	Sunprotect for WZ Rolladenaktor Panoramafenster.LEVEL is active
    shuttercontrol.0
    	2022-06-01 16:35:02.041	info	Sunprotect #420 Set ID: WZ Rolladenaktor Panoramafenster.LEVEL value: 36%
    Sicher dass der Aktor der Verursacher ist, und nicht die Tatsache, dass der Luxsensor die Beschattung aufheben will, bevor der korrekte State gesetzt wurde? Das ist doch meine Vermutung mit der das ganze Drama begonnen hat: Es wird eine Statusänderung angefordert, bevor der aktuell laufende Vorgang abschließend zu Ende gebracht wurde?
    zigbee.0.54ef4410000c18e4.illuminance stellt hier die Werte zur Besonnung (100 testweise) zur Verfügung. Verzögerung (hier 10 Minuten) funktioniert auch an diesem Rolladen (Ebenfalls Homematic, aber andere Firmware) nicht.
    LG S.
    simatecS Offline
    simatecS Offline
    simatec
    #4641
    @rotamint naja dein Lichtsensor sendet schon sehr wild ... Aber das sind auch keine realen Bedingungen in deiner Hosentasche.
    Ich hatte aber vorher schon geschrieben, dass du mit der Hysteresse arbeiten musst.
    Je nach Empfindlichkeit deines Lichtsensor halt angepasst.
    Wie ich auch schon geschrieben habe, kannst du den auch etwas glätten.
    Damit würde er nicht wie wild alle 5 Sekunden einen anderen Wert schicken.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • R rotamint
      @simatec
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      LG S.
      rotamint
      #4642
      @rotamint Auch diese These hat sich eben verworfen, wechselt auch ohne Änderung munter in den Manu_Mode...
      shuttercontrol.0
      	2022-06-01 16:45:38.028	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
      shuttercontrol.0
      	2022-06-01 16:45:38.028	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
      shuttercontrol.0
      	2022-06-01 16:45:38.019	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
      shuttercontrol.0
      	2022-06-01 16:45:22.889	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
      shuttercontrol.0
      	2022-06-01 16:45:22.888	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
      shuttercontrol.0
      	2022-06-01 16:45:22.874	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
      shuttercontrol.0
      	2022-06-01 16:45:22.714	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
      shuttercontrol.0
      	2022-06-01 16:45:22.713	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
      shuttercontrol.0
      	2022-06-01 16:45:22.702	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
      shuttercontrol.0
      	2022-06-01 16:45:01.286	debug	Lightsensor changed: zigbee.0.04cf8cdf3c7b5527.illuminance Value: 144
      shuttercontrol.0
      	2022-06-01 16:45:01.285	debug	insidetemperature changed: zigbee.0.04cf8cdf3c7b5527.illuminance Value: 144
      shuttercontrol.0
      	2022-06-01 16:45:00.026	debug	Sun Elevation: 41.4°
      shuttercontrol.0
      	2022-06-01 16:45:00.026	debug	Sun Azimut: 256.1°
      shuttercontrol.0
      	2022-06-01 16:45:00.025	debug	calculate astrodata ...
      shuttercontrol.0
      	2022-06-01 16:44:51.335	debug	save current height after State Check: 99.5% from WZ Rolladenaktor Panoramafenster.LEVEL
      shuttercontrol.0
      	2022-06-01 16:44:49.714	debug	Sunprotect WZ Rolladenaktor Panoramafenster.LEVEL old height: 100% new height: 36%
      shuttercontrol.0
      	2022-06-01 16:44:49.713	debug	last automatic Action for WZ Rolladenaktor Panoramafenster.LEVEL: down_Sunprotect
      shuttercontrol.0
      	2022-06-01 16:44:49.713	debug	Sunprotect for WZ Rolladenaktor Panoramafenster.LEVEL is active
      shuttercontrol.0
      	2022-06-01 16:44:49.693	info	Sunprotect #420 Set ID: WZ Rolladenaktor Panoramafenster.LEVEL value: 36%
      shuttercontrol.0
      	2022-06-01 16:44:47.689	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 1222
      shuttercontrol.0
      	2022-06-01 16:44:39.759	debug	insidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 2250
      shuttercontrol.0
      	2022-06-01 16:44:34.460	debug	Shuttercontrol save all shutter states
      • R rotamint
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        shuttercontrol.0
        simatecS Offline
        simatecS Offline
        simatec
        #4643
        @rotamint Logge die Statusänderungen des Aktors und die des Rollladenstates in shuttercontrol.
        Sonst suchen wir die Nadel im Heuhaufen.
        • simatecS simatec
          #4644
          @simatec mich irritiert die Meldung
          @homoran sagte in Test Adapter shuttercontrol v1.4.x:
          KZ Rolladenaktor Balkontüre:1.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
          Laut @rotamint ist das Fenster nicht offen gewesen
          R simatecS 2 Antworten Letzte Antwort
            rotamint
            #4645
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            shuttercontrol.0
            Auch dieses Fenster war nicht geöffnet, sitze mittlerweile daneben weil ich keine Lust mehr habe ständig nach Oben zu laufen. Das im EG hat auch das Manu_Mode Feature...
            • R rotamint
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              shuttercontrol.0
              simatecS Offline
              simatecS Offline
              simatec
              #4646
              @rotamint Zeige mal deine Config als json File
              R 1 Antwort Letzte Antwort
                simatecS Offline
                simatecS Offline
                simatec
                #4647
                @homoran ja da gebe ich dir recht ... Dieses Problem darf so nicht auftreten und tritt auch nicht auf.
                Ich hoffe, das wirklich keine Scripte irgendwo laufen und auch in der Config nix vertauscht ist
                • simatecS simatec
                  rotamint
                  #4648
                  @simatec sagte in Test Adapter shuttercontrol v1.4.x:
                  Wie geht das, wie komme ich da ran?
                  Hysterese ist bei den zu beschattenden Rolläden auf zwischen 20 und 25 % gestellt.
                  Habe keine Idee, wie ich den Sensor "glätten" könnte...
                  • R rotamint
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #4649
                    • simatecS simatec
                      rotamint
                      #4650
                      @simatec Merci, besten Dank!
                        "_id": "system.adapter.shuttercontrol.0",
                        "common": {
                          "name": "shuttercontrol",
                          "version": "1.4.13",
                          "title": "shuttercontrol",
                          "authors": [
                            "simatec <nais@gmx.net>"
                          "contributors": [
                            "Rene G. <info@rg-engineering.eu>"
                          "keywords": [
                            "ioBroker",
                            "Smart Home",
                            "home automation",
                            "Rollladen",
                            "Jalousie",
                            "Rollladensteuerung"
                          "license": "MIT",
                          "platform": "Javascript/Node.js",
                          "main": "main.js",
                          "icon": "shuttercontrol.png",
                          "enabled": true,
                          "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                          "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                          "loglevel": "silly",
                          "mode": "daemon",
                          "type": "climate-control",
                          "compact": true,
                          "materialize": true,
                          "stopBeforeUpdate": true,
                          "plugins": {
                            "sentry": {
                              "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                          "installedFrom": "iobroker.shuttercontrol@1.4.13",
                          "installedVersion": "1.4.13",
                          "host": "ioBroker",
                          "connectionType": "local",
                          "dataSource": "push",
                          "adminUI": {
                            "config": "materialize"
                        "native": {
                          "livingAutomatic": "livingSunriseSunset",
                          "W_shutterDownLiving": "",
                          "W_shutterUpLivingMin": "06:20",
                          "W_shutterUpLivingMax": "06:30",
                          "driveDelayUpLiving": "2",
                          "WE_shutterDownLiving": "",
                          "WE_shutterUpLivingMin": "07:00",
                          "WE_shutterUpLivingMax": "07:30",
                          "sleepAutomatic": "sleepSunriseSunset",
                          "W_shutterDownSleep": "",
                          "W_shutterUpSleepMin": "06:30",
                          "W_shutterUpSleepMax": "07:50",
                          "driveDelayUpSleep": "0",
                          "WE_shutterDownSleep": "",
                          "WE_shutterUpSleepMin": "09:30",
                          "WE_shutterUpSleepMax": "10:30",
                          "childrenAutomatic": "childrenSunriseSunset",
                          "W_shutterDownChildren": "21:15",
                          "W_shutterUpChildrenMin": "06:20",
                          "W_shutterUpChildrenMax": "06:35",
                          "driveDelayUpChildren": "2",
                          "WE_shutterDownChildren": "21:30",
                          "WE_shutterUpChildrenMin": "09:59",
                          "WE_shutterUpChildrenMax": "10:25",
                          "latitude": "48.40350",
                          "longitude": "10.03483",
                          "sunProtEndElevation": "-2",
                          "astroDelayUp": "0",
                          "astroDelayDown": "0",
                          "driveDelayUpAstro": "2",
                          "SummerStart": "01.03.",
                          "SummerEnd": "30.09.",
                          "XMasStart": "01.12.",
                          "XMasEnd": "06.01.",
                          "publicHolidays": true,
                          "publicHolInstance": "feiertage.0",
                          "HolidayDP": "",
                          "lightsensorDown": "8",
                          "lightsensorUp": "18",
                          "lightsensorUpDown": "zigbee.0.54ef4410000a2946.illuminance",
                          "schoolfree": true,
                          "schoolfreeInstance": "schoolfree.0",
                          "schoolfreeDP": "",
                          "schoolfreeChildrenArea": true,
                          "schoolfreeSleepArea": false,
                          "schoolfreeLivingArea": false,
                          "LateAllDown": false,
                          "LateAllDownTime": "22:00",
                          "betweenPositionTime": "",
                          "noGoTime": "",
                          "currentShutterState": true,
                          "currentShutterStateTime": "33",
                          "triggerAutoSleep": "",
                          "triggerAutoLiving": "",
                          "triggerAutoChildren": "",
                          "alarmWind1Level": "",
                          "alarmWind1": "",
                          "alarmWind2Level": "",
                          "alarmWind2": "",
                          "alarmRainLevel": "",
                          "alarmRain": "",
                          "alarmFrostLevel": "",
                          "alarmFrost": "",
                          "alarmFireLevel": "",
                          "alarmFire": "",
                          "events": [
                              "enabled": true,
                              "shutterName": "KÜ Rolladenaktor:1.LEVEL",
                              "name": "hm-rpc.0.OEQ1382087.1.LEVEL",
                              "triggerID": "hm-rpc.0.JEQ0152880.1.STATE",
                              "typeUp": "lightsensor",
                              "typeDown": "lightsensor",
                              "type": "off",
                              "heightDownSun": "100",
                              "direction": "120",
                              "directionRange": "50",
                              "tempInside": "",
                              "tempSensor": "",
                              "outsideTempSensor": "",
                              "tempOutside": "",
                              "lightSensor": "",
                              "valueLight": "",
                              "heightUp": "100",
                              "heightDown": "0",
                              "triggerState": "0",
                              "triggerStateTilted": "1",
                              "triggerDrive": "100",
                              "triggerDriveTildet": "10",
                              "triggerChange": "upDown",
                              "elevation": "8",
                              "autoDrive": "upDown",
                              "hysteresisOutside": "",
                              "hysteresisInside": "",
                              "hysteresisLight": "",
                              "currentAction": "",
                              "currentHeight": "",
                              "oldHeight": "",
                              "firstCompleteUp": "",
                              "triggerHeight": "",
                              "LateDown": true,
                              "inSummerNotDown": false,
                              "KeepSunProtect": false,
                              "triggerAction": "",
                              "driveAfterClose": true,
                              "useXmasLevel": false,
                              "XmasLevel": "0",
                              "betweenPosition": false,
                              "betweenPositionLevel": "50",
                              "trigDelyUp": "0",
                              "trigDelyDown": "0",
                              "sunProtectEndDely": "",
                              "sunProtectEndtimerid": "",
                              "enableAlarmWind1": false,
                              "enableAlarmWind2": false,
                              "enableAlarmRain": false,
                              "enableAlarmFrost": false,
                              "enableAlarmFire": false,
                              "alarmTriggerAction": "",
                              "alarmTriggerLevel": "",
                              "lastAutoAction": ""
                              "enabled": true,
                              "shutterName": "WZ Rolladenaktor Esstisch.LEVEL",
                              "name": "hm-rpc.0.LEQ1277083.1.LEVEL",
                              "triggerID": "hm-rpc.0.JEQ0261673.1.STATE",
                              "type": "off",
                              "direction": "165",
                              "directionRange": "60",
                              "tempInside": "",
                              "tempSensor": "",
                              "tempOutside": "",
                              "lightSensor": "",
                              "valueLight": "",
                              "heightUp": "100",
                              "heightDown": "0",
                              "triggerDriveTildet": "16",
                              "elevation": "8",
                              "oldHeight": "",
                              "LateDown": true,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "enabled": true,
                              "shutterName": "WZ Rolladenaktor Panoramafenster.LEVEL",
                              "name": "hm-rpc.0.MEQ0392022.1.LEVEL",
                              "triggerID": "hm-rpc.0.JEQ0262047.1.STATE",
                              "type": "only inside temperature",
                              "heightDownSun": "36",
                              "direction": "150",
                              "tempInside": "10000",
                              "tempSensor": "zigbee.0.54ef4410000c18e4.illuminance",
                              "tempOutside": "",
                              "lightSensor": "",
                              "valueLight": "",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "",
                              "hysteresisInside": "10",
                              "oldHeight": "",
                              "LateDown": true,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "sunProtectEndDely": "10",
                              "enabled": true,
                              "shutterName": "WZ Rolladenaktor Terrassentüre.LEVEL",
                              "name": "hm-rpc.0.LEQ0633917.1.LEVEL",
                              "triggerID": "hm-rpc.0.JEQ0152881.1.STATE",
                              "heightDownSun": "27",
                              "direction": "130",
                              "directionRange": "20",
                              "tempSensor": "zigbee.0.04cf8cdf3c7b5527.illuminance",
                              "outsideTempSensor": "hm-rpc.0.OEQ1962498.1.BRIGHTNESS",
                              "tempOutside": "1",
                              "lightSensor": "zigbee.0.04cf8cdf3c7b5527.illuminance",
                              "valueLight": "12000",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "",
                              "autoDrive": "onlyUp",
                              "hysteresisLight": "25",
                              "oldHeight": "",
                              "LateDown": false,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "enabled": true,
                              "shutterName": "BD Rolladenaktor:1.LEVEL",
                              "name": "hm-rpc.0.OEQ0548447.1.LEVEL",
                              "triggerID": "hm-rpc.0.LEQ1248857.1.STATE",
                              "type": "off",
                              "direction": "120",
                              "tempInside": "23",
                              "tempSensor": "",
                              "tempOutside": "23",
                              "lightSensor": "",
                              "valueLight": "15",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "8",
                              "hysteresisOutside": "5",
                              "hysteresisInside": "5",
                              "hysteresisLight": "5",
                              "oldHeight": "",
                              "LateDown": true,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "enabled": true,
                              "shutterName": "SZ Rolladenaktor:1.LEVEL",
                              "name": "hm-rpc.0.OEQ0259430.1.LEVEL",
                              "triggerID": "hm-rpc.0.NEQ1763576.1.STATE",
                              "typeUp": "sleep",
                              "type": "off",
                              "direction": "120",
                              "tempInside": "23",
                              "tempSensor": "",
                              "lightSensor": "",
                              "valueLight": "15",
                              "heightUp": "100",
                              "heightDown": "0",
                              "triggerDriveTildet": "6",
                              "elevation": "8",
                              "oldHeight": "",
                              "LateDown": false,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "enabled": true,
                              "shutterName": "KZ Rolladenaktor Balkontüre:1.LEVEL",
                              "name": "hm-rpc.0.OEQ0550585.1.LEVEL",
                              "triggerID": "hm-rpc.0.JEQ0152196.1.STATE",
                              "typeUp": "children",
                              "heightDownSun": "24",
                              "direction": "165",
                              "directionRange": "70",
                              "tempSensor": "zigbee.0.04cf8cdf3c78a785.illuminance",
                              "tempOutside": "",
                              "lightSensor": "",
                              "valueLight": "",
                              "heightUp": "100",
                              "heightDown": "0",
                              "triggerDriveTildet": "20",
                              "elevation": "",
                              "hysteresisInside": "20",
                              "oldHeight": "",
                              "LateDown": false,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "sunProtectEndDely": "3",
                              "enabled": true,
                              "shutterName": "KZ Rolladenaktor Fenster.LEVEL",
                              "name": "hm-rpc.0.MEQ0518060.1.LEVEL",
                              "triggerID": "hm-rpc.0.IEQ0044866.1.STATE",
                              "heightDownSun": "60",
                              "direction": "155",
                              "tempInside": "13000",
                              "tempSensor": "zigbee.0.54ef4410000a2de9.illuminance",
                              "tempOutside": "1",
                              "lightSensor": "zigbee.0.54ef4410000a2de9.illuminance",
                              "valueLight": "15000",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "8",
                              "oldHeight": "",
                              "LateDown": false,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "enabled": true,
                              "shutterName": "BZ Rolladenaktor.LEVEL",
                              "name": "hm-rpc.0.OEQ1382244.1.LEVEL",
                              "triggerID": "hm-rpc.0.MEQ0223230.1.STATE",
                              "heightDownSun": "78",
                              "direction": "150",
                              "tempInside": "20000",
                              "tempSensor": "zigbee.0.54ef4410000a2d4e.illuminance",
                              "tempOutside": "1",
                              "lightSensor": "zigbee.0.54ef4410000a2d4e.illuminance",
                              "valueLight": "20000",
                              "heightUp": "100",
                              "heightDown": "0",
                              "triggerChange": "off",
                              "elevation": "8",
                              "oldHeight": "",
                              "LateDown": true,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "enabled": true,
                              "shutterName": "DWZ Rolladenaktor.LEVEL",
                              "name": "hm-rpc.0.MEQ0392973.1.LEVEL",
                              "triggerID": "hm-rpc.0.NEQ1763354.1.STATE",
                              "type": "off",
                              "direction": "120",
                              "tempInside": "23",
                              "tempSensor": "",
                              "lightSensor": "",
                              "valueLight": "15",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "8",
                              "oldHeight": "",
                              "LateDown": true,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                      • R rotamint
                          "common": {
                            "authors": [
                            "contributors": [
                            "keywords": [
                              "ioBroker",
                              "Smart Home",
                              "home automation",
                              "Rollladen",
                              "Jalousie",
                            "license": "MIT",
                            "main": "main.js",
                            "enabled": true,
                            "mode": "daemon",
                            "compact": true,
                            "plugins": {
                              "sentry": {
                            "host": "ioBroker",
                            "adminUI": {
                          "native": {
                            "HolidayDP": "",
                            "schoolfree": true,
                            "schoolfreeDP": "",
                            "noGoTime": "",
                            "alarmWind1": "",
                            "alarmWind2": "",
                            "alarmRain": "",
                            "alarmFrost": "",
                            "alarmFire": "",
                            "events": [
                                "enabled": true,
                                "type": "off",
                                "direction": "120",
                                "tempInside": "",
                                "tempSensor": "",
                                "tempOutside": "",
                                "lightSensor": "",
                                "valueLight": "",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": true,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "type": "off",
                                "direction": "165",
                                "tempInside": "",
                                "tempSensor": "",
                                "tempOutside": "",
                                "lightSensor": "",
                                "valueLight": "",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": true,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "direction": "150",
                                "tempOutside": "",
                                "lightSensor": "",
                                "valueLight": "",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "",
                                "oldHeight": "",
                                "LateDown": true,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "direction": "130",
                                "tempOutside": "1",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "",
                                "oldHeight": "",
                                "LateDown": false,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "type": "off",
                                "direction": "120",
                                "tempInside": "23",
                                "tempSensor": "",
                                "lightSensor": "",
                                "valueLight": "15",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": true,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "typeUp": "sleep",
                                "type": "off",
                                "direction": "120",
                                "tempInside": "23",
                                "tempSensor": "",
                                "lightSensor": "",
                                "valueLight": "15",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": false,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "direction": "165",
                                "tempOutside": "",
                                "lightSensor": "",
                                "valueLight": "",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "",
                                "oldHeight": "",
                                "LateDown": false,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "direction": "155",
                                "tempOutside": "1",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": false,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "direction": "150",
                                "tempOutside": "1",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": true,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                                "enabled": true,
                                "type": "off",
                                "direction": "120",
                                "tempInside": "23",
                                "tempSensor": "",
                                "lightSensor": "",
                                "valueLight": "15",
                                "heightUp": "100",
                                "heightDown": "0",
                                "elevation": "8",
                                "oldHeight": "",
                                "LateDown": true,
                                "XmasLevel": "0",
                                "trigDelyUp": "0",
                        #4651
                        @rotamint sagte in Test Adapter shuttercontrol v1.4.x:
                        was ist das?
                        das passt irgendwie nicht
                        R 2 Antworten Letzte Antwort
                          was ist das?
                          rotamint
                          #4652
                          @homoran Ich schau nach ...
                            was ist das?
                            rotamint
                            schrieb am zuletzt editiert von rotamint
                            #4653
                            JEQ0152196
                            Fensterdrehgriffkontakt Kinderzimmer Balkontüre. (0 = geschlossen, 1 = gekippt /tilted 2 = offen /open)
                            Habe die Stati der Drehgriffe in Jarvis visualisiert und da gibt's keine Unregelmäßigkeiten...
                            • R rotamint
                              JEQ0152196
                              simatecS Offline
                              simatecS Offline
                              simatec
                              schrieb am zuletzt editiert von simatec
                              #4654
                              @rotamint Teste mal die Config laut Anhang
                              Kannst du oben rechts mit den Pfeiltasten wieder hochladen
                              bdc349ff-b58b-481a-88f4-610fffddeec2-system.adapter.shuttercontrol.0_rotamint.json
                              • simatecS simatec
                                rotamint
                                #4655
                                @simatec Danke für Deine Mühe. Eben hochgeladen... Sensor in die Hosentasche (=dunkel, Wert auf 100 für Änderung). Fazit: Wert > 100 wird erkannt, aber es fährt nichts...
                                Trigger steht auf Außentemperatur / Lichtsensor. Außentemperaturfeld ist leer.
                                Das Manual sagt an dieser Stelle:
                                Der Sonnenschutz löst erst aus wenn ALLE gewählten Auslöser aktiv sind (UND Verknüpfung).
                                Wird eine Steuerung mit mehreren Sensoren gewünscht, muss die entsprechende Kombination in der Sonnenschutzart gewählt werden. Der Lichtsensor ist in denjenigen Auswahlen, wo dieser mit aufgeführt ist, jeweils optional. Ist der Lichtsensor konfiguriert, wird er mit den anderen Parametern UND verknüpft.
                                Soll das trotzdem funktionieren, wenn nur der Lichtsensor, aber kein Temperatursensor hinterlegt ist? Ich hatte das anders verstanden...
                                • R rotamint
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #4656
                                  @rotamint sorry mein Fehler ...
                                  f5d28735-83c5-4c93-88ba-f82380633b07-system.adapter.shuttercontrol.0 (2).json
                                  • simatecS simatec
                                    rotamint
                                    #4657
                                    @simatec Danke. Ich werde testen und berichten!
                                    • simatecS simatec
                                      rotamint
                                      #4658
                                      @simatec Leider nein 😧
                                      shuttercontrol.0
                                      	2022-06-01 19:32:48.761	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
                                      shuttercontrol.0
                                      	2022-06-01 19:32:33.831	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
                                      shuttercontrol.0
                                      	2022-06-01 19:32:33.678	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 36% - prevent trigger from driving back
                                      shuttercontrol.0
                                      	2022-06-01 19:32:33.677	debug	save current height after State Check: 36% from WZ_Rolladenaktor_Panoramafenster
                                      shuttercontrol.0
                                      	2022-06-01 19:32:01.555	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 371
                                      shuttercontrol.0
                                      	2022-06-01 19:31:54.927	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 100. automatic is active
                                      shuttercontrol.0
                                      	2022-06-01 19:31:54.927	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
                                      shuttercontrol.0
                                      	2022-06-01 19:31:54.820	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 100% - prevent trigger from driving back
                                      shuttercontrol.0
                                      	2022-06-01 19:31:54.820	debug	save current height after State Check: 100% from WZ_Rolladenaktor_Panoramafenster
                                      shuttercontrol.0
                                      	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster Updated trigger action to Manu_Mode to prevent moving after window close
                                      shuttercontrol.0
                                      	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster drived manually to 100. Old value = 36. New value = 100
                                      shuttercontrol.0
                                      	2022-06-01 19:31:54.760	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
                                      shuttercontrol.0
                                      	2022-06-01 19:31:53.673	debug	Sunprotect WZ_Rolladenaktor_Panoramafenster old height: 36% new height: 36%
                                      shuttercontrol.0
                                      	2022-06-01 19:31:53.672	debug	Temperature outside: 347 > 100 AND Light: 0 > 15
                                      shuttercontrol.0
                                      	2022-06-01 19:31:53.672	debug	Sunprotect for WZ_Rolladenaktor_Panoramafenster is active
                                      shuttercontrol.0
                                      	2022-06-01 19:31:53.672	debug	last automatic Action for WZ_Rolladenaktor_Panoramafenster: down_Sunprotect
                                      shuttercontrol.0
                                      	2022-06-01 19:31:53.649	info	Sunprotect #418 Set ID: WZ_Rolladenaktor_Panoramafenster value: 36%
                                      shuttercontrol.0
                                      	2022-06-01 19:31:53.649	debug	WZ_Rolladenaktor_Panoramafenster: Check basis for sunprotect. Height:100 > HeightDownSun: 36 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                      shuttercontrol.0
                                      	2022-06-01 19:31:51.643	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 347
                                      shuttercontrol.0
                                      	2022-06-01 19:31:46.657	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 45
                                      • R rotamint
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        shuttercontrol.0
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #4659
                                        @rotamint Laut dem Log ist der Check erfolgreich
                                        Wie gesagt ... prüfe den Aktor ... der funkt dir dazwischen.
                                        Es gibt hier aber einige User, die diesen Aktor nutzen.
                                        Es geht also damit
                                        • simatecS simatec
                                          Es geht also damit
                                          rotamint
                                          #4660
                                          @simatec Danke an Deiner Stelle nochmals für Deinen Einsatz, der Ursache auf die Schliche zu kommen. Ich habe mich gestern und heute nochmals mit der Thematik auseinander gesetzt und komme erneut zu der Annahme, dass die Ursache nicht an meinem Aktor zu suchen ist, sondern auf einem Timingfehlverhalten im Code beruht (neuer Wert wird geliefert / von Shuttercontrol berücksichtigt bevor der aktuell laufende Prozess abgeschlossen wurde).
                                          Die Gründe dafür im Einzelnen:
                                          Die Beschattung hat in der vergangenen Zeit mit anderen "Wertelieferanten" bei gleichen Aktoren tadellos funktioniert. In fast zwei jähriger Einsatzzeit vom Shuttercontrol hatte ich noch nie einen "unbekannten" Manu_Mode vorgefunden. Damals habe ich über Innen-/Aussentemperatur und Sonnenstand gesteuert. Ohne jegliche Manu_Mode-Vorkomnisse, absolut störungsfrei!
                                          Das Problem ist somit ganz klar dem neuerlichen Einsatz der Lichtsensoren zuzuordnen.
                                          Den Github-Issues ist zu entnehmen, dass ich mit dem Problem "Manu_Mode / HM Aktor / Lichtsensor" nicht alleinig dastehe, es betrifft wohl weitere User. Teilweise wird berichtet, sie hätten keine Veränderungen am System vorgenommen, letzten Somme häbe alles hervorragend funktioniert.
                                          Das Fehlverhalten kann reproduziert werden:
                                          Der Lichtsensor hängt hierzu auf der Innenseite des Fensters und wird während der Abfahrt verdunkelt (Beschattungswert Unterschreitung) bevor die Sonnenschutzfahrt runter mit dem Abfragen der Position beendet wurde. Nachdem die Unten-Sonnenschutz-Endposition erreicht ist, wechselt der Rolladen sofort in die Gegenrichtung, Fahrt nach oben, speichert falsche Werte und wechselt in den Manu_Mode.
                                          shuttercontrol.0
                                          	2022-06-02 12:21:20.439	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                          shuttercontrol.0
                                          	2022-06-02 12:21:19.786	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                          shuttercontrol.0
                                          	2022-06-02 12:21:13.016	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                          shuttercontrol.0
                                          	2022-06-02 12:20:53.523	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 5497
                                          shuttercontrol.0
                                          	2022-06-02 12:20:48.523	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 3533
                                          shuttercontrol.0
                                          	2022-06-02 12:20:46.356	debug	KZ_Rolladenaktor_Balkontuere1 Updated trigger action to Manu_Mode to prevent moving after window close
                                          shuttercontrol.0
                                          	2022-06-02 12:20:46.354	debug	KZ_Rolladenaktor_Balkontuere1 drived manually to 5. Old value = 100. New value = 5
                                          shuttercontrol.0
                                          	2022-06-02 12:20:46.337	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 5
                                          shuttercontrol.0
                                          	2022-06-02 12:20:46.186	debug	KZ_Rolladenaktor_Balkontuere1 Updated trigger action to Manu_Mode to prevent moving after window close
                                          shuttercontrol.0
                                          	2022-06-02 12:20:46.184	debug	KZ_Rolladenaktor_Balkontuere1 drived manually to 5. Old value = 100. New value = 5
                                          shuttercontrol.0
                                          	2022-06-02 12:20:46.168	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 5
                                          shuttercontrol.0
                                          	2022-06-02 12:20:43.534	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 142
                                          shuttercontrol.0
                                          	2022-06-02 12:20:40.403	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 100%
                                          shuttercontrol.0
                                          	2022-06-02 12:20:40.403	debug	Temperature outside: 389 < 4750.00 OR Light: 0 < 14.25
                                          shuttercontrol.0
                                          	2022-06-02 12:20:40.403	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is not active
                                          shuttercontrol.0
                                          	2022-06-02 12:20:40.402	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: up_Sunprotect_end
                                          shuttercontrol.0
                                          	2022-06-02 12:20:39.764	info	Sunprotect #419 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 100%
                                          shuttercontrol.0
                                          	2022-06-02 12:20:38.532	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 389
                                          shuttercontrol.0
                                          	2022-06-02 12:20:33.554	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 2927
                                          shuttercontrol.0
                                          	2022-06-02 12:20:06.228	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 5%
                                          shuttercontrol.0
                                          	2022-06-02 12:20:06.227	debug	Temperature outside: 5545 > 5000 AND Light: 0 > 15
                                          shuttercontrol.0
                                          	2022-06-02 12:20:06.225	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is active
                                          shuttercontrol.0
                                          	2022-06-02 12:20:06.225	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: down_Sunprotect
                                          shuttercontrol.0
                                          	2022-06-02 12:20:06.146	info	Sunprotect #418 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 5%
                                          shuttercontrol.0
                                          	2022-06-02 12:20:06.145	debug	KZ_Rolladenaktor_Balkontuere1: Check basis for sunprotect. Height:100 > HeightDownSun: 5 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                          shuttercontrol.0
                                          	2022-06-02 12:20:03.092	debug	Lightsensor up DWZ_Rolladenaktor already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:20:01.074	debug	Lightsensor up BZ_Rolladenaktor already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:20:00.987	debug	Brightness State Down is: false
                                          shuttercontrol.0
                                          	2022-06-02 12:20:00.034	debug	Sun Elevation: 61.3°
                                          shuttercontrol.0
                                          	2022-06-02 12:20:00.031	debug	Sun Azimut: 151°
                                          shuttercontrol.0
                                          	2022-06-02 12:20:00.029	debug	calculate astrodata ...
                                          Wird ein veränderter Wert des Luxsensors erst dann verarbeitet wenn die Fahrtrichtung (egal ob auf oder ab) abgeschlossen und die korrekten Positionen gespeichert sind, funktioniert die Steuerung einwanfrei und wechselt auch nicht in den Manu_Mode:
                                          AB:
                                          shuttercontrol.0
                                          	2022-06-02 12:25:46.357	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 25. automatic is active
                                          shuttercontrol.0
                                          	2022-06-02 12:25:46.357	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 25
                                          shuttercontrol.0
                                          	2022-06-02 12:25:46.182	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 25. automatic is active
                                          shuttercontrol.0
                                          	2022-06-02 12:25:46.181	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 25
                                          shuttercontrol.0
                                          	2022-06-02 12:25:26.716	debug	Lightsensor up DWZ_Rolladenaktor already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:25:24.690	debug	Lightsensor up BZ_Rolladenaktor already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:25:24.578	debug	Brightness State Down is: false
                                          shuttercontrol.0
                                          	2022-06-02 12:25:22.670	debug	Lightsensor up BD_Rolladenaktor1 already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:25:20.654	debug	Lightsensor up WZ_Rolladenaktor_Terrassentuere already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:25:18.632	debug	Lightsensor up WZ_Rolladenaktor_Panoramafenster already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:25:16.617	debug	Lightsensor up WZ_Rolladenaktor_Esstisch already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:25:14.974	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 4883
                                          shuttercontrol.0
                                          	2022-06-02 12:25:14.603	debug	Lightsensor up Kue Rolladenaktor1 already up at: 100% - setting current action: up
                                          shuttercontrol.0
                                          	2022-06-02 12:25:14.576	debug	Brightness sensor value: 3340
                                          shuttercontrol.0
                                          	2022-06-02 12:25:06.237	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 25%
                                          shuttercontrol.0
                                          	2022-06-02 12:25:06.237	debug	Temperature outside: 5497 > 5000 AND Light: 0 > 15
                                          shuttercontrol.0
                                          	2022-06-02 12:25:06.236	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is active
                                          shuttercontrol.0
                                          	2022-06-02 12:25:06.235	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: down_Sunprotect
                                          shuttercontrol.0
                                          	2022-06-02 12:25:06.162	info	Sunprotect #418 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 25%
                                          shuttercontrol.0
                                          	2022-06-02 12:25:06.160	debug	KZ_Rolladenaktor_Balkontuere1: Check basis for sunprotect. Height:100 > HeightDownSun: 25 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                          shuttercontrol.0
                                          	2022-06-02 12:25:00.027	debug	Sun Elevation: 61.7°
                                          shuttercontrol.0
                                          	2022-06-02 12:25:00.026	debug	Sun Azimut: 153.3°
                                          shuttercontrol.0
                                          	2022-06-02 12:25:00.025	debug	calculate astrodata ...
                                          AUF:
                                          shuttercontrol.0
                                          	2022-06-02 12:27:36.523	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                          shuttercontrol.0
                                          	2022-06-02 12:27:35.890	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                          shuttercontrol.0
                                          	2022-06-02 12:27:14.718	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 16
                                          shuttercontrol.0
                                          	2022-06-02 12:26:56.529	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 100%
                                          shuttercontrol.0
                                          	2022-06-02 12:26:56.529	debug	Temperature outside: 9 < 4750.00 OR Light: 0 < 14.25
                                          shuttercontrol.0
                                          	2022-06-02 12:26:56.529	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is not active
                                          shuttercontrol.0
                                          	2022-06-02 12:26:56.528	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: up_Sunprotect_end
                                          shuttercontrol.0
                                          	2022-06-02 12:26:55.829	info	Sunprotect #419 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 100%
                                          shuttercontrol.0
                                          	2022-06-02 12:26:54.740	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 9
                                          shuttercontrol.0
                                          	2022-06-02 12:26:49.798	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 483
                                          Hierzu nochmals mein Vorschlag vom 27.05.22, unzählige Posts zuvor:
                                          "Ich vermute(!): Das "Problem" tritt meiner Meinung nach dann auf, wenn während eines "laufendes Prozesses" ein "neuer / anderer Prozess" angestossen wird.
                                          Fall A: Beispiel: Der Rolladen befindet sich in Sonnenschutzposition (und der "Prozess" wurde mit dem "Abfragen des Rolladenstatus nach X Sek" vollständig abgeschlossen.) Jetzt wird also beschattet und soweit ist alles schön.
                                          Jetzt meldet das Luxmeter z. B. dass die Sonne hinter einer Wolke ist (Wert < Sonnenschutzanforderung). Der "Verzögerung bis Beschattung beendet wird (Min)-Timer" läuft an und weil die Sonne beim Timerablauf immernoch verdeckt ist, wird der Rolladen jetzt nach oben gezogen.
                                          Während(!) dieser Fahrt nach oben, bzw. in jedem Fall aber bevor nach dieser Fahrt nach oben das "Abfragen des Rolladenstatus nach X Sek" erfolgt ist, erfolgt eine Werteänderung des Luxmeters (Wolke ist wieder weg, Wert vom Luxmeter > Auslöseschwelle).
                                          Der Rolladen fährt zuerst einmal hoch, dann wird sofort die Beschattung wieder eingeleitet, Richtungsumkehr und der Rolladen fährt wieder runter.
                                          Während dieser anschließenden Fahrt wieder nach unten wird das verzögert getimte "Abfragen des Rolladenstatus nach X Sek" (noch von der Fahrt nach oben) eingeleitet und liefert unsinnige Werte, da der Rolladen ja noch (wieder) fährt, bzw. der Aktor den Status noch nicht korrekt aktualisiert hat. Rolladen wechselt in den Manu_Mode."
                                          Ein ignorieren des / der (veränderten) Sensorwerte/s während der Fahrt des betreffenden Rolladens bis einschließlich der darauffolgenden Speicherung der korrekten Positionsdaten würde m. E. dieses Problem aus der Welt schaffen. Unabhängig vom Aktor.
                                          Klar ist auch, dass dies bei Temperaturänderungen in diesem Umfang niemals auftreten würde, kann aber hierüber genauso reproduziert werden.
                                          Daß die "Verzögerung nach der Beschattung" in der v.1.4.13 nicht mehr funktioniert hatte ich in einem vergangenen Threat bereits angesprochen. Ist das nur bei mir so? Ich bilde mir ein, in der v.1.4.12 entsprechend Logs noch gelesen zu haben und die Funktion war noch gegeben.
