    @simatec mich irritiert die Meldung
    @homoran sagte in Test Adapter shuttercontrol v1.4.x:
    KZ Rolladenaktor Balkontüre:1.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    Laut @rotamint ist das Fenster nicht offen gewesen
    rotamint
    #4645
    shuttercontrol.0
    	2022-06-01 16:45:38.028	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    	2022-06-01 16:45:38.028	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
    shuttercontrol.0
    	2022-06-01 16:45:38.019	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
    shuttercontrol.0
    	2022-06-01 16:45:22.889	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    	2022-06-01 16:45:22.888	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
    shuttercontrol.0
    	2022-06-01 16:45:22.874	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
    shuttercontrol.0
    	2022-06-01 16:45:22.714	debug	WZ Rolladenaktor Panoramafenster.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
    shuttercontrol.0
    	2022-06-01 16:45:22.713	debug	WZ Rolladenaktor Panoramafenster.LEVEL drived manually to 36. Old value = 100. New value = 36
    shuttercontrol.0
    	2022-06-01 16:45:22.702	debug	Shutter state changed: WZ Rolladenaktor Panoramafenster.LEVEL old value = 100 new value = 36
    shuttercontrol.0
    	2022-06-01 16:45:01.286	debug	Lightsensor changed: zigbee.0.04cf8cdf3c7b5527.illuminance Value: 144
    shuttercontrol.0
    	2022-06-01 16:45:01.285	debug	insidetemperature changed: zigbee.0.04cf8cdf3c7b5527.illuminance Value: 144
    shuttercontrol.0
    	2022-06-01 16:45:00.026	debug	Sun Elevation: 41.4°
    shuttercontrol.0
    	2022-06-01 16:45:00.026	debug	Sun Azimut: 256.1°
    shuttercontrol.0
    	2022-06-01 16:45:00.025	debug	calculate astrodata ...
    shuttercontrol.0
    	2022-06-01 16:44:51.335	debug	save current height after State Check: 99.5% from WZ Rolladenaktor Panoramafenster.LEVEL
    shuttercontrol.0
    	2022-06-01 16:44:49.714	debug	Sunprotect WZ Rolladenaktor Panoramafenster.LEVEL old height: 100% new height: 36%
    shuttercontrol.0
    	2022-06-01 16:44:49.713	debug	last automatic Action for WZ Rolladenaktor Panoramafenster.LEVEL: down_Sunprotect
    shuttercontrol.0
    	2022-06-01 16:44:49.713	debug	Sunprotect for WZ Rolladenaktor Panoramafenster.LEVEL is active
    shuttercontrol.0
    	2022-06-01 16:44:49.693	info	Sunprotect #420 Set ID: WZ Rolladenaktor Panoramafenster.LEVEL value: 36%
    shuttercontrol.0
    	2022-06-01 16:44:47.689	debug	insidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 1222
    shuttercontrol.0
    	2022-06-01 16:44:39.759	debug	insidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 2250
    shuttercontrol.0
    	2022-06-01 16:44:34.460	debug	Shuttercontrol save all shutter states
    Auch dieses Fenster war nicht geöffnet, sitze mittlerweile daneben weil ich keine Lust mehr habe ständig nach Oben zu laufen. Das im EG hat auch das Manu_Mode Feature...
    • R rotamint
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      shuttercontrol.0
      simatecS Online
      simatecS Online
      simatec
      #4646
      @rotamint Zeige mal deine Config als json File
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      R 1 Antwort Letzte Antwort
        simatecS Online
        simatecS Online
        simatec
        #4647
        @homoran ja da gebe ich dir recht ... Dieses Problem darf so nicht auftreten und tritt auch nicht auf.
        Ich hoffe, das wirklich keine Scripte irgendwo laufen und auch in der Config nix vertauscht ist
        • simatecS simatec
          rotamint
          #4648
          @simatec sagte in Test Adapter shuttercontrol v1.4.x:
          Wie geht das, wie komme ich da ran?
          Hysterese ist bei den zu beschattenden Rolläden auf zwischen 20 und 25 % gestellt.
          Habe keine Idee, wie ich den Sensor "glätten" könnte...
          • R rotamint
            simatecS Online
            simatecS Online
            simatec
            #4649
            • simatecS simatec
              rotamint
              #4650
              @simatec Merci, besten Dank!
                "_id": "system.adapter.shuttercontrol.0",
                "common": {
                  "name": "shuttercontrol",
                  "version": "1.4.13",
                  "title": "shuttercontrol",
                  "authors": [
                    "simatec <nais@gmx.net>"
                  "contributors": [
                    "Rene G. <info@rg-engineering.eu>"
                  "keywords": [
                    "ioBroker",
                    "Smart Home",
                    "home automation",
                    "Rollladen",
                    "Jalousie",
                    "Rollladensteuerung"
                  "license": "MIT",
                  "platform": "Javascript/Node.js",
                  "main": "main.js",
                  "icon": "shuttercontrol.png",
                  "enabled": true,
                  "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                  "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                  "loglevel": "silly",
                  "mode": "daemon",
                  "type": "climate-control",
                  "compact": true,
                  "materialize": true,
                  "stopBeforeUpdate": true,
                  "plugins": {
                    "sentry": {
                      "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                  "installedFrom": "iobroker.shuttercontrol@1.4.13",
                  "installedVersion": "1.4.13",
                  "host": "ioBroker",
                  "connectionType": "local",
                  "dataSource": "push",
                  "adminUI": {
                    "config": "materialize"
                "native": {
                  "livingAutomatic": "livingSunriseSunset",
                  "W_shutterDownLiving": "",
                  "W_shutterUpLivingMin": "06:20",
                  "W_shutterUpLivingMax": "06:30",
                  "driveDelayUpLiving": "2",
                  "WE_shutterDownLiving": "",
                  "WE_shutterUpLivingMin": "07:00",
                  "WE_shutterUpLivingMax": "07:30",
                  "sleepAutomatic": "sleepSunriseSunset",
                  "W_shutterDownSleep": "",
                  "W_shutterUpSleepMin": "06:30",
                  "W_shutterUpSleepMax": "07:50",
                  "driveDelayUpSleep": "0",
                  "WE_shutterDownSleep": "",
                  "WE_shutterUpSleepMin": "09:30",
                  "WE_shutterUpSleepMax": "10:30",
                  "childrenAutomatic": "childrenSunriseSunset",
                  "W_shutterDownChildren": "21:15",
                  "W_shutterUpChildrenMin": "06:20",
                  "W_shutterUpChildrenMax": "06:35",
                  "driveDelayUpChildren": "2",
                  "WE_shutterDownChildren": "21:30",
                  "WE_shutterUpChildrenMin": "09:59",
                  "WE_shutterUpChildrenMax": "10:25",
                  "latitude": "48.40350",
                  "longitude": "10.03483",
                  "sunProtEndElevation": "-2",
                  "astroDelayUp": "0",
                  "astroDelayDown": "0",
                  "driveDelayUpAstro": "2",
                  "SummerStart": "01.03.",
                  "SummerEnd": "30.09.",
                  "XMasStart": "01.12.",
                  "XMasEnd": "06.01.",
                  "publicHolidays": true,
                  "publicHolInstance": "feiertage.0",
                  "HolidayDP": "",
                  "lightsensorDown": "8",
                  "lightsensorUp": "18",
                  "lightsensorUpDown": "zigbee.0.54ef4410000a2946.illuminance",
                  "schoolfree": true,
                  "schoolfreeInstance": "schoolfree.0",
                  "schoolfreeDP": "",
                  "schoolfreeChildrenArea": true,
                  "schoolfreeSleepArea": false,
                  "schoolfreeLivingArea": false,
                  "LateAllDown": false,
                  "LateAllDownTime": "22:00",
                  "betweenPositionTime": "",
                  "noGoTime": "",
                  "currentShutterState": true,
                  "currentShutterStateTime": "33",
                  "triggerAutoSleep": "",
                  "triggerAutoLiving": "",
                  "triggerAutoChildren": "",
                  "alarmWind1Level": "",
                  "alarmWind1": "",
                  "alarmWind2Level": "",
                  "alarmWind2": "",
                  "alarmRainLevel": "",
                  "alarmRain": "",
                  "alarmFrostLevel": "",
                  "alarmFrost": "",
                  "alarmFireLevel": "",
                  "alarmFire": "",
                  "events": [
                      "enabled": true,
                      "shutterName": "KÜ Rolladenaktor:1.LEVEL",
                      "name": "hm-rpc.0.OEQ1382087.1.LEVEL",
                      "triggerID": "hm-rpc.0.JEQ0152880.1.STATE",
                      "typeUp": "lightsensor",
                      "typeDown": "lightsensor",
                      "type": "off",
                      "heightDownSun": "100",
                      "direction": "120",
                      "directionRange": "50",
                      "tempInside": "",
                      "tempSensor": "",
                      "outsideTempSensor": "",
                      "tempOutside": "",
                      "lightSensor": "",
                      "valueLight": "",
                      "heightUp": "100",
                      "heightDown": "0",
                      "triggerState": "0",
                      "triggerStateTilted": "1",
                      "triggerDrive": "100",
                      "triggerDriveTildet": "10",
                      "triggerChange": "upDown",
                      "elevation": "8",
                      "autoDrive": "upDown",
                      "hysteresisOutside": "",
                      "hysteresisInside": "",
                      "hysteresisLight": "",
                      "currentAction": "",
                      "currentHeight": "",
                      "oldHeight": "",
                      "firstCompleteUp": "",
                      "triggerHeight": "",
                      "LateDown": true,
                      "inSummerNotDown": false,
                      "KeepSunProtect": false,
                      "triggerAction": "",
                      "driveAfterClose": true,
                      "useXmasLevel": false,
                      "XmasLevel": "0",
                      "betweenPosition": false,
                      "betweenPositionLevel": "50",
                      "trigDelyUp": "0",
                      "trigDelyDown": "0",
                      "sunProtectEndDely": "",
                      "sunProtectEndtimerid": "",
                      "enableAlarmWind1": false,
                      "enableAlarmWind2": false,
                      "enableAlarmRain": false,
                      "enableAlarmFrost": false,
                      "enableAlarmFire": false,
                      "alarmTriggerAction": "",
                      "alarmTriggerLevel": "",
                      "lastAutoAction": ""
                      "enabled": true,
                      "shutterName": "WZ Rolladenaktor Esstisch.LEVEL",
                      "name": "hm-rpc.0.LEQ1277083.1.LEVEL",
                      "triggerID": "hm-rpc.0.JEQ0261673.1.STATE",
                      "type": "off",
                      "direction": "165",
                      "directionRange": "60",
                      "tempInside": "",
                      "tempSensor": "",
                      "tempOutside": "",
                      "lightSensor": "",
                      "valueLight": "",
                      "heightUp": "100",
                      "heightDown": "0",
                      "triggerDriveTildet": "16",
                      "elevation": "8",
                      "oldHeight": "",
                      "LateDown": true,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "enabled": true,
                      "shutterName": "WZ Rolladenaktor Panoramafenster.LEVEL",
                      "name": "hm-rpc.0.MEQ0392022.1.LEVEL",
                      "triggerID": "hm-rpc.0.JEQ0262047.1.STATE",
                      "type": "only inside temperature",
                      "heightDownSun": "36",
                      "direction": "150",
                      "tempInside": "10000",
                      "tempSensor": "zigbee.0.54ef4410000c18e4.illuminance",
                      "tempOutside": "",
                      "lightSensor": "",
                      "valueLight": "",
                      "heightUp": "100",
                      "heightDown": "0",
                      "elevation": "",
                      "hysteresisInside": "10",
                      "oldHeight": "",
                      "LateDown": true,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "sunProtectEndDely": "10",
                      "enabled": true,
                      "shutterName": "WZ Rolladenaktor Terrassentüre.LEVEL",
                      "name": "hm-rpc.0.LEQ0633917.1.LEVEL",
                      "triggerID": "hm-rpc.0.JEQ0152881.1.STATE",
                      "heightDownSun": "27",
                      "direction": "130",
                      "directionRange": "20",
                      "tempSensor": "zigbee.0.04cf8cdf3c7b5527.illuminance",
                      "outsideTempSensor": "hm-rpc.0.OEQ1962498.1.BRIGHTNESS",
                      "tempOutside": "1",
                      "lightSensor": "zigbee.0.04cf8cdf3c7b5527.illuminance",
                      "valueLight": "12000",
                      "heightUp": "100",
                      "heightDown": "0",
                      "elevation": "",
                      "autoDrive": "onlyUp",
                      "hysteresisLight": "25",
                      "oldHeight": "",
                      "LateDown": false,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "enabled": true,
                      "shutterName": "BD Rolladenaktor:1.LEVEL",
                      "name": "hm-rpc.0.OEQ0548447.1.LEVEL",
                      "triggerID": "hm-rpc.0.LEQ1248857.1.STATE",
                      "type": "off",
                      "direction": "120",
                      "tempInside": "23",
                      "tempSensor": "",
                      "tempOutside": "23",
                      "lightSensor": "",
                      "valueLight": "15",
                      "heightUp": "100",
                      "heightDown": "0",
                      "elevation": "8",
                      "hysteresisOutside": "5",
                      "hysteresisInside": "5",
                      "hysteresisLight": "5",
                      "oldHeight": "",
                      "LateDown": true,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "enabled": true,
                      "shutterName": "SZ Rolladenaktor:1.LEVEL",
                      "name": "hm-rpc.0.OEQ0259430.1.LEVEL",
                      "triggerID": "hm-rpc.0.NEQ1763576.1.STATE",
                      "typeUp": "sleep",
                      "type": "off",
                      "direction": "120",
                      "tempInside": "23",
                      "tempSensor": "",
                      "lightSensor": "",
                      "valueLight": "15",
                      "heightUp": "100",
                      "heightDown": "0",
                      "triggerDriveTildet": "6",
                      "elevation": "8",
                      "oldHeight": "",
                      "LateDown": false,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "enabled": true,
                      "shutterName": "KZ Rolladenaktor Balkontüre:1.LEVEL",
                      "name": "hm-rpc.0.OEQ0550585.1.LEVEL",
                      "triggerID": "hm-rpc.0.JEQ0152196.1.STATE",
                      "typeUp": "children",
                      "heightDownSun": "24",
                      "direction": "165",
                      "directionRange": "70",
                      "tempSensor": "zigbee.0.04cf8cdf3c78a785.illuminance",
                      "tempOutside": "",
                      "lightSensor": "",
                      "valueLight": "",
                      "heightUp": "100",
                      "heightDown": "0",
                      "triggerDriveTildet": "20",
                      "elevation": "",
                      "hysteresisInside": "20",
                      "oldHeight": "",
                      "LateDown": false,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "sunProtectEndDely": "3",
                      "enabled": true,
                      "shutterName": "KZ Rolladenaktor Fenster.LEVEL",
                      "name": "hm-rpc.0.MEQ0518060.1.LEVEL",
                      "triggerID": "hm-rpc.0.IEQ0044866.1.STATE",
                      "heightDownSun": "60",
                      "direction": "155",
                      "tempInside": "13000",
                      "tempSensor": "zigbee.0.54ef4410000a2de9.illuminance",
                      "tempOutside": "1",
                      "lightSensor": "zigbee.0.54ef4410000a2de9.illuminance",
                      "valueLight": "15000",
                      "heightUp": "100",
                      "heightDown": "0",
                      "elevation": "8",
                      "oldHeight": "",
                      "LateDown": false,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "enabled": true,
                      "shutterName": "BZ Rolladenaktor.LEVEL",
                      "name": "hm-rpc.0.OEQ1382244.1.LEVEL",
                      "triggerID": "hm-rpc.0.MEQ0223230.1.STATE",
                      "heightDownSun": "78",
                      "direction": "150",
                      "tempInside": "20000",
                      "tempSensor": "zigbee.0.54ef4410000a2d4e.illuminance",
                      "tempOutside": "1",
                      "lightSensor": "zigbee.0.54ef4410000a2d4e.illuminance",
                      "valueLight": "20000",
                      "heightUp": "100",
                      "heightDown": "0",
                      "triggerChange": "off",
                      "elevation": "8",
                      "oldHeight": "",
                      "LateDown": true,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
                      "enabled": true,
                      "shutterName": "DWZ Rolladenaktor.LEVEL",
                      "name": "hm-rpc.0.MEQ0392973.1.LEVEL",
                      "triggerID": "hm-rpc.0.NEQ1763354.1.STATE",
                      "type": "off",
                      "direction": "120",
                      "tempInside": "23",
                      "tempSensor": "",
                      "lightSensor": "",
                      "valueLight": "15",
                      "heightUp": "100",
                      "heightDown": "0",
                      "elevation": "8",
                      "oldHeight": "",
                      "LateDown": true,
                      "XmasLevel": "0",
                      "trigDelyUp": "0",
              • R rotamint
                  "common": {
                    "authors": [
                    "contributors": [
                    "keywords": [
                      "ioBroker",
                      "Smart Home",
                      "home automation",
                      "Rollladen",
                      "Jalousie",
                    "license": "MIT",
                    "main": "main.js",
                    "enabled": true,
                    "mode": "daemon",
                    "compact": true,
                    "plugins": {
                      "sentry": {
                    "host": "ioBroker",
                    "adminUI": {
                  "native": {
                    "HolidayDP": "",
                    "schoolfree": true,
                    "schoolfreeDP": "",
                    "noGoTime": "",
                    "alarmWind1": "",
                    "alarmWind2": "",
                    "alarmRain": "",
                    "alarmFrost": "",
                    "alarmFire": "",
                    "events": [
                        "enabled": true,
                        "type": "off",
                        "direction": "120",
                        "tempInside": "",
                        "tempSensor": "",
                        "tempOutside": "",
                        "lightSensor": "",
                        "valueLight": "",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "8",
                        "oldHeight": "",
                        "LateDown": true,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "type": "off",
                        "direction": "165",
                        "tempInside": "",
                        "tempSensor": "",
                        "tempOutside": "",
                        "lightSensor": "",
                        "valueLight": "",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "8",
                        "oldHeight": "",
                        "LateDown": true,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "direction": "150",
                        "tempOutside": "",
                        "lightSensor": "",
                        "valueLight": "",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "",
                        "oldHeight": "",
                        "LateDown": true,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "direction": "130",
                        "tempOutside": "1",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "",
                        "oldHeight": "",
                        "LateDown": false,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "type": "off",
                        "direction": "120",
                        "tempInside": "23",
                        "tempSensor": "",
                        "lightSensor": "",
                        "valueLight": "15",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "8",
                        "oldHeight": "",
                        "LateDown": true,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "typeUp": "sleep",
                        "type": "off",
                        "direction": "120",
                        "tempInside": "23",
                        "tempSensor": "",
                        "lightSensor": "",
                        "valueLight": "15",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "8",
                        "oldHeight": "",
                        "LateDown": false,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "direction": "165",
                        "tempOutside": "",
                        "lightSensor": "",
                        "valueLight": "",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "",
                        "oldHeight": "",
                        "LateDown": false,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "direction": "155",
                        "tempOutside": "1",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "8",
                        "oldHeight": "",
                        "LateDown": false,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "direction": "150",
                        "tempOutside": "1",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "8",
                        "oldHeight": "",
                        "LateDown": true,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                        "enabled": true,
                        "type": "off",
                        "direction": "120",
                        "tempInside": "23",
                        "tempSensor": "",
                        "lightSensor": "",
                        "valueLight": "15",
                        "heightUp": "100",
                        "heightDown": "0",
                        "elevation": "8",
                        "oldHeight": "",
                        "LateDown": true,
                        "XmasLevel": "0",
                        "trigDelyUp": "0",
                #4651
                @rotamint sagte in Test Adapter shuttercontrol v1.4.x:
                was ist das?
                das passt irgendwie nicht
                R 2 Antworten Letzte Antwort
                  was ist das?
                  rotamint
                  #4652
                  @homoran Ich schau nach ...
                    was ist das?
                    rotamint
                    schrieb am zuletzt editiert von rotamint
                    #4653
                    JEQ0152196
                    Fensterdrehgriffkontakt Kinderzimmer Balkontüre. (0 = geschlossen, 1 = gekippt /tilted 2 = offen /open)
                    Habe die Stati der Drehgriffe in Jarvis visualisiert und da gibt's keine Unregelmäßigkeiten...
                    • R rotamint
                      JEQ0152196
                      simatecS Online
                      simatecS Online
                      simatec
                      #4654
                      @rotamint Teste mal die Config laut Anhang
                      Kannst du oben rechts mit den Pfeiltasten wieder hochladen
                      bdc349ff-b58b-481a-88f4-610fffddeec2-system.adapter.shuttercontrol.0_rotamint.json
                      • simatecS simatec
                        rotamint
                        #4655
                        @simatec Danke für Deine Mühe. Eben hochgeladen... Sensor in die Hosentasche (=dunkel, Wert auf 100 für Änderung). Fazit: Wert > 100 wird erkannt, aber es fährt nichts...
                        Trigger steht auf Außentemperatur / Lichtsensor. Außentemperaturfeld ist leer.
                        Das Manual sagt an dieser Stelle:
                        Der Sonnenschutz löst erst aus wenn ALLE gewählten Auslöser aktiv sind (UND Verknüpfung).
                        Wird eine Steuerung mit mehreren Sensoren gewünscht, muss die entsprechende Kombination in der Sonnenschutzart gewählt werden. Der Lichtsensor ist in denjenigen Auswahlen, wo dieser mit aufgeführt ist, jeweils optional. Ist der Lichtsensor konfiguriert, wird er mit den anderen Parametern UND verknüpft.
                        Soll das trotzdem funktionieren, wenn nur der Lichtsensor, aber kein Temperatursensor hinterlegt ist? Ich hatte das anders verstanden...
                        • R rotamint
                          simatecS Online
                          simatecS Online
                          simatec
                          #4656
                          @rotamint sorry mein Fehler ...
                          f5d28735-83c5-4c93-88ba-f82380633b07-system.adapter.shuttercontrol.0 (2).json
                          • simatecS simatec
                            rotamint
                            #4657
                            @simatec Danke. Ich werde testen und berichten!
                            • simatecS simatec
                              rotamint
                              #4658
                              @simatec Leider nein 😧
                              shuttercontrol.0
                              	2022-06-01 19:32:48.761	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
                              shuttercontrol.0
                              	2022-06-01 19:32:33.831	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 36. automatic is active
                              shuttercontrol.0
                              	2022-06-01 19:32:33.678	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 36% - prevent trigger from driving back
                              shuttercontrol.0
                              	2022-06-01 19:32:33.677	debug	save current height after State Check: 36% from WZ_Rolladenaktor_Panoramafenster
                              shuttercontrol.0
                              	2022-06-01 19:32:01.555	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 371
                              shuttercontrol.0
                              	2022-06-01 19:31:54.927	debug	WZ_Rolladenaktor_Panoramafenster Old value = 36. New value = 100. automatic is active
                              shuttercontrol.0
                              	2022-06-01 19:31:54.927	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
                              shuttercontrol.0
                              	2022-06-01 19:31:54.820	debug	Shutter WZ_Rolladenaktor_Panoramafenster was moved manually to: 100% - prevent trigger from driving back
                              shuttercontrol.0
                              	2022-06-01 19:31:54.820	debug	save current height after State Check: 100% from WZ_Rolladenaktor_Panoramafenster
                              shuttercontrol.0
                              	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster Updated trigger action to Manu_Mode to prevent moving after window close
                              shuttercontrol.0
                              	2022-06-01 19:31:54.769	debug	WZ_Rolladenaktor_Panoramafenster drived manually to 100. Old value = 36. New value = 100
                              shuttercontrol.0
                              	2022-06-01 19:31:54.760	debug	Shutter state changed: WZ_Rolladenaktor_Panoramafenster old value = 36 new value = 100
                              shuttercontrol.0
                              	2022-06-01 19:31:53.673	debug	Sunprotect WZ_Rolladenaktor_Panoramafenster old height: 36% new height: 36%
                              shuttercontrol.0
                              	2022-06-01 19:31:53.672	debug	Temperature outside: 347 > 100 AND Light: 0 > 15
                              shuttercontrol.0
                              	2022-06-01 19:31:53.672	debug	Sunprotect for WZ_Rolladenaktor_Panoramafenster is active
                              shuttercontrol.0
                              	2022-06-01 19:31:53.672	debug	last automatic Action for WZ_Rolladenaktor_Panoramafenster: down_Sunprotect
                              shuttercontrol.0
                              	2022-06-01 19:31:53.649	info	Sunprotect #418 Set ID: WZ_Rolladenaktor_Panoramafenster value: 36%
                              shuttercontrol.0
                              	2022-06-01 19:31:53.649	debug	WZ_Rolladenaktor_Panoramafenster: Check basis for sunprotect. Height:100 > HeightDownSun: 36 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                              shuttercontrol.0
                              	2022-06-01 19:31:51.643	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 347
                              shuttercontrol.0
                              	2022-06-01 19:31:46.657	debug	outsidetemperature changed: zigbee.0.54ef4410000c18e4.illuminance Value: 45
                              • R rotamint
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                shuttercontrol.0
                                simatecS Online
                                simatecS Online
                                simatec
                                #4659
                                @rotamint Laut dem Log ist der Check erfolgreich
                                Wie gesagt ... prüfe den Aktor ... der funkt dir dazwischen.
                                Es gibt hier aber einige User, die diesen Aktor nutzen.
                                Es geht also damit
                                • simatecS simatec
                                  Es geht also damit
                                  rotamint
                                  #4660
                                  @simatec Danke an Deiner Stelle nochmals für Deinen Einsatz, der Ursache auf die Schliche zu kommen. Ich habe mich gestern und heute nochmals mit der Thematik auseinander gesetzt und komme erneut zu der Annahme, dass die Ursache nicht an meinem Aktor zu suchen ist, sondern auf einem Timingfehlverhalten im Code beruht (neuer Wert wird geliefert / von Shuttercontrol berücksichtigt bevor der aktuell laufende Prozess abgeschlossen wurde).
                                  Die Gründe dafür im Einzelnen:
                                  Die Beschattung hat in der vergangenen Zeit mit anderen "Wertelieferanten" bei gleichen Aktoren tadellos funktioniert. In fast zwei jähriger Einsatzzeit vom Shuttercontrol hatte ich noch nie einen "unbekannten" Manu_Mode vorgefunden. Damals habe ich über Innen-/Aussentemperatur und Sonnenstand gesteuert. Ohne jegliche Manu_Mode-Vorkomnisse, absolut störungsfrei!
                                  Das Problem ist somit ganz klar dem neuerlichen Einsatz der Lichtsensoren zuzuordnen.
                                  Den Github-Issues ist zu entnehmen, dass ich mit dem Problem "Manu_Mode / HM Aktor / Lichtsensor" nicht alleinig dastehe, es betrifft wohl weitere User. Teilweise wird berichtet, sie hätten keine Veränderungen am System vorgenommen, letzten Somme häbe alles hervorragend funktioniert.
                                  Das Fehlverhalten kann reproduziert werden:
                                  Der Lichtsensor hängt hierzu auf der Innenseite des Fensters und wird während der Abfahrt verdunkelt (Beschattungswert Unterschreitung) bevor die Sonnenschutzfahrt runter mit dem Abfragen der Position beendet wurde. Nachdem die Unten-Sonnenschutz-Endposition erreicht ist, wechselt der Rolladen sofort in die Gegenrichtung, Fahrt nach oben, speichert falsche Werte und wechselt in den Manu_Mode.
                                  shuttercontrol.0
                                  	2022-06-02 12:21:20.439	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                  shuttercontrol.0
                                  	2022-06-02 12:21:19.786	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                  shuttercontrol.0
                                  	2022-06-02 12:21:13.016	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                  shuttercontrol.0
                                  	2022-06-02 12:20:53.523	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 5497
                                  shuttercontrol.0
                                  	2022-06-02 12:20:48.523	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 3533
                                  shuttercontrol.0
                                  	2022-06-02 12:20:46.356	debug	KZ_Rolladenaktor_Balkontuere1 Updated trigger action to Manu_Mode to prevent moving after window close
                                  shuttercontrol.0
                                  	2022-06-02 12:20:46.354	debug	KZ_Rolladenaktor_Balkontuere1 drived manually to 5. Old value = 100. New value = 5
                                  shuttercontrol.0
                                  	2022-06-02 12:20:46.337	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 5
                                  shuttercontrol.0
                                  	2022-06-02 12:20:46.186	debug	KZ_Rolladenaktor_Balkontuere1 Updated trigger action to Manu_Mode to prevent moving after window close
                                  shuttercontrol.0
                                  	2022-06-02 12:20:46.184	debug	KZ_Rolladenaktor_Balkontuere1 drived manually to 5. Old value = 100. New value = 5
                                  shuttercontrol.0
                                  	2022-06-02 12:20:46.168	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 5
                                  shuttercontrol.0
                                  	2022-06-02 12:20:43.534	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 142
                                  shuttercontrol.0
                                  	2022-06-02 12:20:40.403	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 100%
                                  shuttercontrol.0
                                  	2022-06-02 12:20:40.403	debug	Temperature outside: 389 < 4750.00 OR Light: 0 < 14.25
                                  shuttercontrol.0
                                  	2022-06-02 12:20:40.403	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is not active
                                  shuttercontrol.0
                                  	2022-06-02 12:20:40.402	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: up_Sunprotect_end
                                  shuttercontrol.0
                                  	2022-06-02 12:20:39.764	info	Sunprotect #419 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 100%
                                  shuttercontrol.0
                                  	2022-06-02 12:20:38.532	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 389
                                  shuttercontrol.0
                                  	2022-06-02 12:20:33.554	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 2927
                                  shuttercontrol.0
                                  	2022-06-02 12:20:06.228	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 5%
                                  shuttercontrol.0
                                  	2022-06-02 12:20:06.227	debug	Temperature outside: 5545 > 5000 AND Light: 0 > 15
                                  shuttercontrol.0
                                  	2022-06-02 12:20:06.225	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is active
                                  shuttercontrol.0
                                  	2022-06-02 12:20:06.225	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: down_Sunprotect
                                  shuttercontrol.0
                                  	2022-06-02 12:20:06.146	info	Sunprotect #418 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 5%
                                  shuttercontrol.0
                                  	2022-06-02 12:20:06.145	debug	KZ_Rolladenaktor_Balkontuere1: Check basis for sunprotect. Height:100 > HeightDownSun: 5 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                  shuttercontrol.0
                                  	2022-06-02 12:20:03.092	debug	Lightsensor up DWZ_Rolladenaktor already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:20:01.074	debug	Lightsensor up BZ_Rolladenaktor already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:20:00.987	debug	Brightness State Down is: false
                                  shuttercontrol.0
                                  	2022-06-02 12:20:00.034	debug	Sun Elevation: 61.3°
                                  shuttercontrol.0
                                  	2022-06-02 12:20:00.031	debug	Sun Azimut: 151°
                                  shuttercontrol.0
                                  	2022-06-02 12:20:00.029	debug	calculate astrodata ...
                                  Wird ein veränderter Wert des Luxsensors erst dann verarbeitet wenn die Fahrtrichtung (egal ob auf oder ab) abgeschlossen und die korrekten Positionen gespeichert sind, funktioniert die Steuerung einwanfrei und wechselt auch nicht in den Manu_Mode:
                                  AB:
                                  shuttercontrol.0
                                  	2022-06-02 12:25:46.357	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 25. automatic is active
                                  shuttercontrol.0
                                  	2022-06-02 12:25:46.357	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 25
                                  shuttercontrol.0
                                  	2022-06-02 12:25:46.182	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 25. automatic is active
                                  shuttercontrol.0
                                  	2022-06-02 12:25:46.181	debug	Shutter state changed: KZ_Rolladenaktor_Balkontuere1 old value = 100 new value = 25
                                  shuttercontrol.0
                                  	2022-06-02 12:25:26.716	debug	Lightsensor up DWZ_Rolladenaktor already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:25:24.690	debug	Lightsensor up BZ_Rolladenaktor already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:25:24.578	debug	Brightness State Down is: false
                                  shuttercontrol.0
                                  	2022-06-02 12:25:22.670	debug	Lightsensor up BD_Rolladenaktor1 already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:25:20.654	debug	Lightsensor up WZ_Rolladenaktor_Terrassentuere already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:25:18.632	debug	Lightsensor up WZ_Rolladenaktor_Panoramafenster already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:25:16.617	debug	Lightsensor up WZ_Rolladenaktor_Esstisch already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:25:14.974	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 4883
                                  shuttercontrol.0
                                  	2022-06-02 12:25:14.603	debug	Lightsensor up Kue Rolladenaktor1 already up at: 100% - setting current action: up
                                  shuttercontrol.0
                                  	2022-06-02 12:25:14.576	debug	Brightness sensor value: 3340
                                  shuttercontrol.0
                                  	2022-06-02 12:25:06.237	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 25%
                                  shuttercontrol.0
                                  	2022-06-02 12:25:06.237	debug	Temperature outside: 5497 > 5000 AND Light: 0 > 15
                                  shuttercontrol.0
                                  	2022-06-02 12:25:06.236	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is active
                                  shuttercontrol.0
                                  	2022-06-02 12:25:06.235	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: down_Sunprotect
                                  shuttercontrol.0
                                  	2022-06-02 12:25:06.162	info	Sunprotect #418 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 25%
                                  shuttercontrol.0
                                  	2022-06-02 12:25:06.160	debug	KZ_Rolladenaktor_Balkontuere1: Check basis for sunprotect. Height:100 > HeightDownSun: 25 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                                  shuttercontrol.0
                                  	2022-06-02 12:25:00.027	debug	Sun Elevation: 61.7°
                                  shuttercontrol.0
                                  	2022-06-02 12:25:00.026	debug	Sun Azimut: 153.3°
                                  shuttercontrol.0
                                  	2022-06-02 12:25:00.025	debug	calculate astrodata ...
                                  AUF:
                                  shuttercontrol.0
                                  	2022-06-02 12:27:36.523	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                  shuttercontrol.0
                                  	2022-06-02 12:27:35.890	debug	KZ_Rolladenaktor_Balkontuere1 Old value = 100. New value = 100. automatic is active
                                  shuttercontrol.0
                                  	2022-06-02 12:27:14.718	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 16
                                  shuttercontrol.0
                                  	2022-06-02 12:26:56.529	debug	Sunprotect KZ_Rolladenaktor_Balkontuere1 old height: 100% new height: 100%
                                  shuttercontrol.0
                                  	2022-06-02 12:26:56.529	debug	Temperature outside: 9 < 4750.00 OR Light: 0 < 14.25
                                  shuttercontrol.0
                                  	2022-06-02 12:26:56.529	debug	Sunprotect for KZ_Rolladenaktor_Balkontuere1 is not active
                                  shuttercontrol.0
                                  	2022-06-02 12:26:56.528	debug	last automatic Action for KZ_Rolladenaktor_Balkontuere1: up_Sunprotect_end
                                  shuttercontrol.0
                                  	2022-06-02 12:26:55.829	info	Sunprotect #419 Set ID: KZ_Rolladenaktor_Balkontuere1 value: 100%
                                  shuttercontrol.0
                                  	2022-06-02 12:26:54.740	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 9
                                  shuttercontrol.0
                                  	2022-06-02 12:26:49.798	debug	outsidetemperature changed: zigbee.0.04cf8cdf3c78a785.illuminance Value: 483
                                  Hierzu nochmals mein Vorschlag vom 27.05.22, unzählige Posts zuvor:
                                  "Ich vermute(!): Das "Problem" tritt meiner Meinung nach dann auf, wenn während eines "laufendes Prozesses" ein "neuer / anderer Prozess" angestossen wird.
                                  Fall A: Beispiel: Der Rolladen befindet sich in Sonnenschutzposition (und der "Prozess" wurde mit dem "Abfragen des Rolladenstatus nach X Sek" vollständig abgeschlossen.) Jetzt wird also beschattet und soweit ist alles schön.
                                  Jetzt meldet das Luxmeter z. B. dass die Sonne hinter einer Wolke ist (Wert < Sonnenschutzanforderung). Der "Verzögerung bis Beschattung beendet wird (Min)-Timer" läuft an und weil die Sonne beim Timerablauf immernoch verdeckt ist, wird der Rolladen jetzt nach oben gezogen.
                                  Während(!) dieser Fahrt nach oben, bzw. in jedem Fall aber bevor nach dieser Fahrt nach oben das "Abfragen des Rolladenstatus nach X Sek" erfolgt ist, erfolgt eine Werteänderung des Luxmeters (Wolke ist wieder weg, Wert vom Luxmeter > Auslöseschwelle).
                                  Der Rolladen fährt zuerst einmal hoch, dann wird sofort die Beschattung wieder eingeleitet, Richtungsumkehr und der Rolladen fährt wieder runter.
                                  Während dieser anschließenden Fahrt wieder nach unten wird das verzögert getimte "Abfragen des Rolladenstatus nach X Sek" (noch von der Fahrt nach oben) eingeleitet und liefert unsinnige Werte, da der Rolladen ja noch (wieder) fährt, bzw. der Aktor den Status noch nicht korrekt aktualisiert hat. Rolladen wechselt in den Manu_Mode."
                                  Ein ignorieren des / der (veränderten) Sensorwerte/s während der Fahrt des betreffenden Rolladens bis einschließlich der darauffolgenden Speicherung der korrekten Positionsdaten würde m. E. dieses Problem aus der Welt schaffen. Unabhängig vom Aktor.
                                  Klar ist auch, dass dies bei Temperaturänderungen in diesem Umfang niemals auftreten würde, kann aber hierüber genauso reproduziert werden.
                                  Daß die "Verzögerung nach der Beschattung" in der v.1.4.13 nicht mehr funktioniert hatte ich in einem vergangenen Threat bereits angesprochen. Ist das nur bei mir so? Ich bilde mir ein, in der v.1.4.12 entsprechend Logs noch gelesen zu haben und die Funktion war noch gegeben.
                                  simatecS 2 Antworten Letzte Antwort
                                  • R rotamint
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    AB:
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    AUF:
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    shuttercontrol.0
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    #4661
                                    @rotamint Wie gesagt sehe ich deinen Lichtsensor als sehr wild von den Wertänderungen.
                                    Hier mal ein Script zum beruhigen der Sensorwerte.
                                    /********* Werte glätten und alle 5 Minuten ausgeben ***********/
                                    createState('0_userdata.0.shuttercontrol.illuminance', {
                                        role: "value",
                                        type: "number",
                                        read: true,
                                        write: true
                                    const time = 5; // Ausgabezeit des Sensorwertes in Minuten
                                    const sensor = 'zigbee.0.04cf8cdf3c78a785.illuminance'; // Zigbee Lichtsensor
                                    const illuminance = '0_userdata.0.shuttercontrol.illuminance'; // Wert für shuttercontrol Config
                                    on({ id: sensor, change: "ne" }, function (obj) {
                                        // @ts-ignore
                                        if (Math.round((new Date() - new Date(getState(illuminance).ts)) / 1000 / 60) > time) {
                                            setState(illuminance, obj.state.val, true);
                                    Einfach in Javascript einen Script erstellen und reinkopieren.
                                    In der Config von shuttercontrol ersetzt du alle ID's des Sensors "zigbee.0.04cf8cdf3c78a785.illuminance" durch "0_userdata.0.shuttercontrol.illuminance"
                                    • R rotamint
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      AB:
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      AUF:
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      shuttercontrol.0
                                      simatecS Online
                                      simatecS Online
                                      simatec
                                      #4662
                                      Ich glaube hier liegt auch das generelle Verständnisproblem.
                                      Du hebelst dich ja mit der Standortauswahl selber aus.
                                      Der Sensor kann doch nicht drin sitzen.
                                      Du verdunkelst und der Sensor meldet an shuttercontrol direkt wieder hochfahren ist zu dunkel
                                      Ein Lichtsensor sollte draußen vor dem Rollladen sitzen.
                                      So drehst du dich doch immer im Kreis
                                      R HomoranH 2 Antworten Letzte Antwort
                                      • simatecS simatec
                                        rotamint
                                        #4663
                                        @simatec Ich habe das einzig geschrieben, um dem Fehler reproduzierbar zu machen. Zur Vereinfachung der Anschaulichkeit! So kann das Fehlverhalten mit wenigen Handgriffen nachgestellt werden. Es verhält sich identisch wenn der Sensor aussen sitzt und die Sonnenintensität den Schwellenwert während des Rolladenlaufs im Shuttercontrol ändert.
                                        Alternativ auf Temperatur getriggert und den Temperaturwert während der Fahrt über den Schwellwert hinaus verändern. Führt auch zum Manu_Mode.
                                        Wüsste wirklich nicht wie ich den Fehler deutlicher beschreiben könnte...
                                        • simatecS simatec
                                              role: "value",
                                              type: "number",
                                              read: true,
                                              write: true
                                              // @ts-ignore
                                          rotamint
                                          #4664
                                          @simatec Besten Dank! Ich werde es heute abend probieren...
