  4. Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread)
    2.4k
    4.4k
appdark-modeiqontrolresponsivevisvisualisierungvisualizationwidget
7.6k Beiträge 296 Kommentatoren 7.6m Aufrufe 201 Beobachtet
  • V Offline
    V Offline
    Vocaris
    #5821
    @s-bormann
    Wie kann ich die Karte der Xiaomi Vacuum als Bild zur Anzeige bringen?
    1x einfach als großes Bild in einer Ansicht
    1x als Bild in einem Kachel Pop Up.
    Auf er Git Hub Seite steht folgendes:
    Es gibt also eine URL zu einem Bild aber auch ein HTML-Widget Code.
    [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{mihome-vacuum.0.map.map64}"},"style":{"left":"0","top":"0","width":"100%","height":"100%"},"widgetSet":"basic"}]
    Bekomme es aber nicht hin.
    s.bormannS 1 Antwort Letzte Antwort
    • dslraserD Offline
      dslraserD Offline
      dslraser
      #5822
      @s-bormann
      Die "Halbierungsmöglichkeit" gefällt mir gut👍.
      Sieht aufgeräumter aus.
      M V 2 Antworten Letzte Antwort
      • V Vocaris
        @meerkat Hei,
        wollte das jetzt auch mal machen.
        Also ich habe die Bereichsreinigung des Vaccums in ioB als Scene hinterlegt. Könnte aber auch via Add. Control die Koordianten den DP mihome-vacuum.0.control.zoneClean senden. Dafür muss ich aber die Koordinaten in den Namen schreiben und den kann man nicht ausblenden. Sieht also blöd aus.
        Ich sehe aber bei dir, dass du kein Add. Control genommen hast. Wie hast du die Buttons eine Ebene höher rein bekommen. Und das auch nebeneinander und mit Icons? Und wie sendest du die Koordinaten an den Vacuum?
        meerkat
        #5823
        Hi @vocaris,
        die zusätzlichen Zonen kann man im mihome-adapter unter Räume und dann addRooms anlegen. Wenn du da die Koordinaten einträgst, dann wird dir die Zone wie die Räume angelegt und hast dann auch einen entsprechenden Button.
        Im iQontrol habe ich die Buttons über Remote-Channels angelegt. Dort kannste auch Icons auswählen und auf den Datenpunkt CleanRoom des jeweiligen Raumes bzw. Zone zugreifen.
        V 1 Antwort Letzte Antwort
        • dslraserD dslraser
          @s-bormann
          muuulle
          #5824
          @dslraser said in Test Adapter iQontrol 1.9.x Vis:
          @s-bormann
          Auch die Einstellungen für das allgemeine Verhalten für Klick auf eine Kachel sehen jetzt super aus!
          • K kilasat
            @meerkat da wäre ich dir sehr dankbar für.
            meerkat
            #5825
            Hi @kilasat,
            hier die beiden Javascripte. Als erstes die Datenpunkte hinzufügen und das Script einmal ausführen (1. Script), danach das 2. Script aktivieren und laufen lassen. Achso, natürlich noch die Werte (in beiden Scripts) anpassen, ich habe 2 von den Dingern laufen und da kannste alles für den 2. rausschmeißen.
            In der Json ist meine Sicht mit dem Gerät, die kannste importieren und auch auf deine Datenpunkte anpassen.
            /* Setze neue Datenpunkte für
            *  - Wartungspunkt setzen pro Vacuum
            *  - Weitere Zonen einrichten, über script, da wenn der Adapter mal nicht mehr funktioniert die Werte nicht erneut ermittelt werden müssen
            *  - Warteschlange erzeugen, Standard reichte mir nicht
            //Settings
            //Anzahl der Vacuum
            var countVacuum = ['mihome-vacuum.0', 'mihome-vacuum.1'];
            var channelRooms = '.rooms';
            var servicePoints = ['22250,32300','27950,25450']
            var addRrooms = [
                'room' : ['Zone1','Zone2','Zone3'],
                'datenpunkt' : [[25235,29306,27535,30356],[23502,24895,25102,25995],[27763,30413,29163,33013]]
            //Channel für alle Vacuum unter userdata anlegen
            setObject("0_userdata.0.vacuums", {
                common: {
                    name: "Vacuums Zusatzpunkte"
                type: "channel"
            //Datenpunkte für ServicePoint und CleaningQueue pro Vacuum anlegen
            for (var v = 0; v < countVacuum.length; v++) {
                //Koordinaten des jeweiligen ServicPoints speichern
                if (servicePoints[v] != null){
                    createState("0_userdata.0." + countVacuum[v] + ".servicepoint", servicePoints[v], false, {
                        desc: "coordinates of servicepoint",
                        type: "number",
                        role: "value",
                        unit: "",
                        read: false,
                        write: false
                //Eine erweiterte CleaningQueue anlegen, in der dann Zone und Segment herausgefiltert wird und nur der Name steht
                createState("0_userdata.0." + countVacuum[v] + ".cleaningQueue", "", false, {
                    desc: "cleaning queue",
                    type: "object",
                    role: "info",
                    unit: "",
                    read: true,
                    write: true
                //Für die Ermittlung und anzeige des aktuellen Raumes, der gereinigt wird
                createState("0_userdata.0." + countVacuum[v] + ".currentRoom", "", false, {
                    name: "current cleaning",
                    desc: "current cleaning room or zone",
                    type: "object",
                    role: "info",
                    unit: "",
                    read: true,
                    write: true
                //Datenpunkt für den Button Servicepoint
                createState("0_userdata.0." + countVacuum[v] + ".goToService", false, false, {
                    desc: "going to ServicePointcleaning queue",
                    type: "boolean",
                    role: "button",
                    unit: "",
                    read: false,
                    write: true
                //Weitere Zonen anlegen
                if(addRrooms[v]!=null){
                    for (var i = 0; i < addRrooms[v]['room'].length; i++) {
                        setState(countVacuum[v] + channelRooms + ".addRoom", addRrooms[v]['datenpunkt'][i]);
                        var roomchannel = addRrooms[v]['datenpunkt'][i].toString();
                        roomchannel = roomchannel.replace("[", "");
                        roomchannel = roomchannel.replace("]", "");
                        roomchannel = roomchannel.split(",").join("_"); /*replaceAll(",", "_");*/
                        setState(countVacuum[v] + channelRooms + "." + roomchannel + ".roomFanPower", 103);
                        setState(countVacuum[v] + channelRooms +  "." + roomchannel + ".roomWaterBoxMode", 202);
            //////////////////// Vacuum 1 //////////////////////
            //Die beim nach Hause schicken die Queue leeren
            on({id: 'mihome-vacuum.0.control.home', val: true}, function() {
               setState('mihome-vacuum.0.control.clearQueue', true);
            //Die Queue der aktuellen Reinigung löschen wenn Vacuum in der Ladestation ist
            on({id: 'mihome-vacuum.0.info.state'/*Vacuum state*/, val: 8}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', '');
            //Den aktuell zu reinigenden Raum ermitteln
            on({id: 'mihome-vacuum.0.rooms.106001012191.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.106001012191').common.name);
            on({id: 'mihome-vacuum.0.rooms.106001012206.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.106001012206').common.name);
            on({id: 'mihome-vacuum.0.rooms.106001012207.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.106001012207').common.name);
            on({id: 'mihome-vacuum.0.rooms.106001012208.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.106001012208').common.name);
            on({id: 'mihome-vacuum.0.rooms.106001012209.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.106001012209').common.name);
            on({id: 'mihome-vacuum.0.rooms.106001012210.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.106001012210').common.name);
            on({id: 'mihome-vacuum.0.rooms.manual_23502_24895_25102_25995.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.manual_23502_24895_25102_25995').common.name);
            on({id: 'mihome-vacuum.0.rooms.manual_25235_29306_27535_30356.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.manual_25235_29306_27535_30356').common.name);
            on({id: 'mihome-vacuum.0.rooms.manual_27763_30413_29163_33013.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.0.currentRoom', getObject('mihome-vacuum.0.rooms.manual_27763_30413_29163_33013').common.name);
            //Die Standard CleaningQueue anpassen
            on({id: 'mihome-vacuum.0.info.queue', change: 'any'}, function (obj) {
                var queue = obj.state.val
                var tmpCleaningQueue = "Next: ";
                if (queue.length != 0) {
                    log(queue.length);
                    queue.reverse();
                    for (var i = 0; i < queue.length; i++){
                        tmpCleaningQueue += queue[i].replace("segment", "").replace("zone", "");
                        if(i+1<queue.length){
                            tmpCleaningQueue+= ",";
                else {
                    tmpCleaningQueue = "";
                setState('0_userdata.0.mihome-vacuum.0.cleaningQueue'/*cleaning queue*/, tmpCleaningQueue)
            //Auf den Button goToServicepoint reagieren
            on({id: '0_userdata.0.mihome-vacuum.0.goToService'/*goToService*/, val: true}, function (obj) {
                var servicepoint = getState('0_userdata.0.mihome-vacuum.0.servicepoint'/*map index*/).val;
                setState('mihome-vacuum.0.control.goTo'/*Go to point*/,servicepoint);
            //////////////////// Vacuum 2 //////////////////////
            on({id: 'mihome-vacuum.1.control.home', val: true}, function() {
               setState('mihome-vacuum.1.control.clearQueue', true);
            on({id: 'mihome-vacuum.1.info.state'/*Vacuum state*/, val: 8}, function() {
               setState('0_userdata.0.mihome-vacuum.1.currentRoom', '');
            on({id: 'mihome-vacuum.1.rooms.106001012200.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.1.currentRoom', getObject('mihome-vacuum.1.rooms.106001012200').common.name);
            on({id: 'mihome-vacuum.1.rooms.106001012201.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.1.currentRoom', getObject('mihome-vacuum.1.rooms.106001012201').common.name);
            on({id: 'mihome-vacuum.1.rooms.106001012202.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.1.currentRoom', getObject('mihome-vacuum.1.rooms.106001012202').common.name);
            on({id: 'mihome-vacuum.1.rooms.106001012203.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.1.currentRoom', getObject('mihome-vacuum.1.rooms.106001012203').common.name);
            on({id: 'mihome-vacuum.1.rooms.106001012205.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.1.currentRoom', getObject('mihome-vacuum.1.rooms.106001012205').common.name);
            on({id: 'mihome-vacuum.1.rooms.106001012607.state'/*info*/, val: "clean Room"}, function() {
               setState('0_userdata.0.mihome-vacuum.1.currentRoom', getObject('mihome-vacuum.1.rooms.106001012607').common.name);
            on({id: 'mihome-vacuum.1.info.queue', change: 'any'}, function (obj) {
                var tmpCleaningQueue = "Next ";
                else {
                setState('0_userdata.0.mihome-vacuum.1.cleaningQueue'/*cleaning queue*/, tmpCleaningQueue)
            on({id: '0_userdata.0.mihome-vacuum.1.goToService'/*goToService*/, val: true}, function (obj) {
                var servicepoint = getState('0_userdata.0.mihome-vacuum.1.servicepoint'/*map index*/).val;
                setState('mihome-vacuum.1.control.goTo'/*Go to point*/,servicepoint);
            2021-08-20_iqontrol_0_selected_views.json
            K 4 Antworten Letzte Antwort
            • dslraserD Offline
              dslraserD Offline
              dslraser
              #5826
              @s-bormann
              Ich habe mal meine Rasenmäher Datenpunkte in ein Widget gepackt. Kann man eigentlich die beiden oberen Linien weg bekommen ? Ich nutze keinen State, nur additionl Control und additional Info
              • s.bormannS s.bormann
                @s-bormann sagte in Test Adapter iQontrol 1.9.x Vis:
                @emd sagte in Test Adapter iQontrol 1.9.x Vis:
                @s-bormann
                Schriftart geht, danke!
                Kann ich bei meinen zeitprofilen weiter oben auch den Wert in klammern ausblenden wo steht wann der timer fällig wird? Ist ja bei mir eigentlich kein timer 😉
                Hmmm, da muss ich mir was überlegen, wie man das konfiguriert. Ich denk drüber nach, wie das geht.
                die Option das auszublenden wurde in den Customs des Datenpunktes (Schraubenschlüssel) eingefügt.
                VG
                eMd
                #5827
                @s-bormann
                Iwie Suche ich falsch, aber ich finde den Punkt in den customs nicht... Sorry, bin erst jetzt dazu gekommen...
                Such ich falsch?
                MfG
                eMd
                Master: Intel NUC 16GB/500GB
                Slave: Raspberry Pi 3 + Homematicmodul
                Shelly, Google Home, Zigbee Aqara, Sonoff
                Meine VIS: https://youtu.be/JMYr2KYlpME
                M s.bormannS 2 Antworten Letzte Antwort
                • E eMd
                  @s-bormann
                  Such ich falsch?
                  MfG
                  eMd
                  muuulle
                  schrieb am zuletzt editiert von muuulle
                  #5828
                  @s-bormann
                  Moin,
                  seit 1.9.4 habe ich ein Thema mit dem Dark Mode. Ich kann ihn über die Optionen nicht deaktivieren. Auch wenn ich den dark Mode von iOS ausschalte 🤔
                  Edit
                  Auch werden die Unter-Überschriften nicht angezeigt. Ich bin erstmal wieder bei 1.9.3 - hier bestehen beide Probleme noch nicht!
                  • M meerkat
                    @s-bormann
                    OK, das mit den Arrays wäre super.
                    Falls du doch mal Lust und Zeit hast 😉 einen Gerätetyp Vacuum zu machen, kann ich gerne behilflich sein. Zu mindestens für die Mi, Roborock Modelle.
                    s.bormannS Offline
                    s.bormannS Offline
                    s.bormann
                    #5829
                    @meerkat sagte in Test Adapter iQontrol 1.9.x Vis:
                    @s-bormann
                    Das mit den Arrays ist übrigens doch deutlich schwieriger, als angenommen. Es braucht dafür recht umfangreiche Änderungen an vielen Stellen. Ich weiß deshalb noch nicht, wann ich dazu komme. Nur als Info.
                    • M meerkat
                      @s-bormann
                      s.bormannS Offline
                      s.bormannS Offline
                      s.bormann
                      #5830
                      @s-bormann
                      Hilfe ist hier gerne Willkommen! Da ich wie gesagt Null Ahnung habe, was die Sauerg-Dinger alles brauchen (bin da wohl wirklich etwas altmodisch... :) ), bräuchte ich eine Liste, was die Kachel und der Dialog alles können muss, was muss angezeigt werden, was braucht man für Steuerelemente, was sind die üblichen Datenpunkte etc.. @meerkat, vielleicht kannst Du auch mal alles, was dazu von anderen Nutzern als Input kommt sammeln und mir dann noch mal zuschicken? Das wäre gut und würde mir schon mal viel Arbeit abnehmen.
                      • B BenGreenHigh
                        @s-bormann said in Test Adapter iQontrol 1.9.x Vis:
                        @bengreenhigh sagte in Test Adapter iQontrol 1.9.x Vis:
                        @s-bormann Danke Dir. Etwas hat sich geändert: Unter 1.8.0 habe ich jetzt ein Pulldown-Menü beim "normalen" Thermostat, schalten funktioniert. Da mir die Schaltflächen lieber sind, wieder auf Homematic-Thermostat eingestellt.
                        Nach dem Update auf 1.9.3 lässt sich der Mode beim Homematic-Thermostat wieder nicht mehr verändern. Hab's dann wieder auf Thermostat eingestellt und mit dem Pulldown-Menü funktioniert auch das schalten.
                        Kann man denn irgendwie noch einstellen, dass statt des Pulldown-Menüs die Buttons zum bedienen erscheinen?
                        LG
                        Hi, nein, leider nicht. Du kannst Dir aber das Verhalten des Homematic-Thermostates mit einem Alias, Value-List und Target-Value-List nachbauen. Muss man vermutlich etwas rumtüfteln - aber ich bin mir ziemlich sicher, dass es geht.
                        Okay, da stehe ich gerade ein bisschen auf'm Schlauch. Alias, Valuue-List und Target-Value-List setzte ich schon ein, aber wie komme ich damit vom Pulldown-Menü zu Buttons?
                        LG
                        s.bormannS Offline
                        s.bormannS Offline
                        s.bormann
                        #5831
                        LG
                        LG
                        Das hatte ich mir mal zu den HM-IP-Thermostaten aufgeschrieben (hab selbst keins, stammt hier aus dem Forum). Das müsstest Du also in irgendeiner Form nachbauen mit dem Alias:
                        - HM-IP Thermostat Datenpunkte ( https://forum.iobroker.net/post/636228 )
                        	CONTROL_MODE:
                        		0	Auto	--> setzt SET_POINT_MODE auf	0
                        		1	Manu	--> setzt SET_POINT_MODE auf	1
                        		2	Boost	--> setzt BOOST_MODE auf	true
                        	SET_POINT_MODE:
                        		0	Auto
                        		1	Manu
                        		2	Boost
                        • V Vocaris
                          @meerkat Hei,
                          s.bormannS Offline
                          s.bormannS Offline
                          s.bormann
                          #5832
                          @vocaris sagte in Test Adapter iQontrol 1.9.x Vis:
                          @meerkat Hei,
                          Hi @Vocaris , seit der 1.8.2 kann man die Namen auch ausblenden lassen:
                          VG
                          • V Vocaris
                            @s-bormann
                            s.bormannS Offline
                            s.bormannS Offline
                            s.bormann
                            #5833
                            Xiaomi Vacuum
                            Hi, der Code, den Du geschickt hast, kannst Du glaube ich in VIS importieren. Die erstellte VIS könntest Du dann als BACKGROUND_URL in iQontrol einbinden.
                              @s-bormann
                              s.bormannS Offline
                              s.bormannS Offline
                              s.bormann
                              #5834
                              @dslraser sagte in Test Adapter iQontrol 1.9.x Vis:
                              @s-bormann
                              Ich finde es echt cool, dass Euch solche Details auffallen! Hier sind echte Design-Liebhaber unterwegs!
                              Wird in der nächsten Version korrigiert! :)
                              • E eMd
                                @s-bormann
                                Such ich falsch?
                                MfG
                                eMd
                                s.bormannS Offline
                                s.bormannS Offline
                                s.bormann
                                schrieb am zuletzt editiert von s.bormann
                                #5835
                                @s-bormann
                                Such ich falsch?
                                MfG
                                eMd
                                Hi, hab ich erst mal nur für Admin 5 hinzugefügt. Habe es jetzt aber für die nächste Version auch bei Admin 4 eingefügt.
                                • M muuulle
                                  @s-bormann
                                  Moin,
                                  Edit
                                  s.bormannS Offline
                                  s.bormannS Offline
                                  s.bormann
                                  #5836
                                  @muuulle sagte in Test Adapter iQontrol 1.9.x Vis:
                                  @s-bormann
                                  Moin,
                                  Edit
                                  Das klingt nach einem Cache-Problem, so dass noch die alten CSS-Files aktiv waren. ioBroker muss neu gestartet und der Browser-Cache geleert werden. Oder man stellt im ioBroker den Cache aus: In der iobroker.json im iobroker-data Verzeichnis die Option "noFileCache" unter objects auf true setzen.
                                  • M meerkat
                                    Hi @vocaris,
                                    V Offline
                                    V Offline
                                    Vocaris
                                    #5837
                                    Hi @vocaris,
                                    Moin,
                                    danke für die Info. Du meinst wirklich den mi-home Adapter? Nicht den Vacuum Adapter?
                                    IMHO brauche ich für mi-home eine Verbindung zum Mi Gateway. Das habe ich aber nicht. Bzw. ich habe den schon. Aber in der EU Version 3 und da bekommt man keine Verbindung hin. Ist also gelb. Im Adapter finde ich auch keinen Reiter Räume.
                                      @s-bormann
                                      V Offline
                                      V Offline
                                      Vocaris
                                      #5838
                                      @dslraser Hei,
                                      wie hast du bei dem HM Thermostaten die drei Button für den Modus rein bekommen?
                                      Bei mir wird nix angezeigt:
                                      Habe es beim CONTROL_MODE mit dem DP hm-rpc.0.0006DAC8587AB2.1.SET_POINT_MODE versucht. Dann mit hm-rpc.0.0006DAC8587AB2.1.CONTROL_MODE. Aber nix wird angezeigt. Auch der Bost DP wir nicht angezeigt.
                                      • V Vocaris
                                        Hi @vocaris,
                                        Moin,
                                        meerkat
                                        #5839
                                        @vocaris sorry, natürlich der vacuum adapter
                                        • M meerkat
                                          V Offline
                                          V Offline
                                          Vocaris
                                          #5840
                                          @meerkat OK
                                          Aber da gibt es keine Möglichkeit einen Raum hinzuzufügen.
                                          Auch in den anderen Reitern nicht
