  4. TR-064.0 Adapter - Fehlermeldung
29 Beiträge 9 Kommentatoren 9.4k Aufrufe 4 Beobachtet
  • N Offline
    N Offline
    Nixbligger
    Guten Abend,
    ich bekomme bei der Verwendung des o.g. Adapters diese Fehlermeldung:
    ! host.debianiobroker 2019-01-06 01:41:10.337 info Restart adapter system.adapter.tr-064.0 because enabled
    ! host.debianiobroker 2019-01-06 01:41:10.337 error instance system.adapter.tr-064.0 terminated with code 1 ()
    ! host.debianiobroker 2019-01-06 01:41:10.336 error Caught by controller[0]: at startup (bootstrap_node.js:160:9)
    ! host.debianiobroker 2019-01-06 01:41:10.336 error Caught by controller[0]: at run (bootstrap_node.js:394:7)
    ! host.debianiobroker 2019-01-06 01:41:10.336 error Caught by controller[0]: at Module.runMain (module.js:611:10)
    ! host.debianiobroker 2019-01-06 01:41:10.336 error Caught by controller[0]: at Function.Module._load (module.js:445:3)
    ! host.debianiobroker 2019-01-06 01:41:10.335 error Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    ! host.debianiobroker 2019-01-06 01:41:10.335 error Caught by controller[0]: at Module.load (module.js:494:32)
    ! host.debianiobroker 2019-01-06 01:41:10.335 error Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
    ! host.debianiobroker 2019-01-06 01:41:10.335 error Caught by controller[0]: at Module._compile (module.js:577:32)
    ! host.debianiobroker 2019-01-06 01:41:10.334 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
    ! host.debianiobroker 2019-01-06 01:41:10.334 error Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    ! host.debianiobroker 2019-01-06 01:41:10.333 error Caught by controller[0]: TypeError: fns.adapter is not a function
    ! host.debianiobroker 2019-01-06 01:41:10.333 error Caught by controller[0]: ^
    ! host.debianiobroker 2019-01-06 01:41:10.332 error Caught by controller[0]: fns.adapter = fns.adapter(options);
    ! host.debianiobroker 2019-01-06 01:41:10.332 error Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383</anonymous>
    Vielleicht kann einer der Erfahrenen User mit einen Tipp geben, nach was ich suchen muss.
    Was ist ein fns.adapter ?
    LG
    Stephan
    • wendy2702W Online
      wendy2702W Online
      wendy2702
      Gab es Fehler bei der Installation des Adapters?
      Welche Node und NPM Version hast du auf deinem System?
      Welche Version des TR.064 Adapters installiert?
      • apollon77A Online
        apollon77A Online
        Welche Version wurde installiert? GitHub? oder npm? Bitte mal die Stable bzw latest installieren. NICHT GitHub
        • N Offline
          N Offline
          Nixbligger
          ich habe die Version jetzt erneut installiert. Das LOG, sieht so aus.
          ! $ ./iobroker url "https://github.com/soef/ioBroker.tr-064/tarball/master" tr-064
          ! install https://github.com/soef/ioBroker.tr-064/tarball/master
          ! npm install https://github.com/soef/ioBroker.tr-064/tarball/master –production --save --prefix "/opt/iobroker" (System call)
          ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"ia32"})
          ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.sonos/package.json'
          ! got /opt/iobroker/node_modules/iobroker.tr-064/admin
          ! upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
          ! upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
          ! upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index.html index.html text/html
          ! process exited with code 0
          Ich hoffe, das beantwortet eure Fragen. Ich bin erst ganz kurz mit dem IOB in Gange. Lerne täglich dazu.
          LG
          Stephan
            Alero
            Hi, habe auch das Problem mit TR64.
            Installiert habe ich die Version 04.18 und ich habe es über die Asapter installiert. hat auch wunderbar funktioniert bis heute.
            Beekomme auch die FM: error instance system.adapter.tr-064.0 terminated with code 1 ()
            Habe den Adatper schon deinstalliert und wieder neu. Gleiches Problem.
            TR-64 bleibt rot und sagt verbunden mit Host falsch und Lebbenszeichen falsch.
            Einstellungen sind : Fritz.box oder auch IP (beides Vversucht)
            User für TR ( extra angelgt)
            und das Passwort.
            Jemand eine Idee?
            Alero
            • SBorgS Offline
              SBorgS Offline
              SBorg
              Hast du ev. den js-controller oder ähnliches geupdated?
              Dann hilft:
              cd /opt/iobroker/
              iobroker stop tr-064
              cd /opt/iobroker/node_modules/iobroker.tr-064
              npm install soef
              LG SBorg ( SBorg auf GitHub)
              • E Offline
                erniecs
                Der Fehler kam bei mir nach dem ich den iobroker auf Version 1.5.8 und den admin auf Version 3.6.2 upgedatet hab.
                Danke SBorg
                cd /opt/iobroker/
                npm install soef
                hat geholfen
                A R 2 Antworten Letzte Antwort
                • E erniecs
                  Danke SBorg
                  cd /opt/iobroker/
                  npm install soef
                  hat geholfen
                  Alero
                  schrieb am zuletzt editiert von Alero
                  @erniecs
                  ja auf 3.62 habe ich auch ein Update gemacht.
                  Hat geklappt. danke
                  Alero
                    Alero
                    habe schon wieder einen Fehler mit TR-064.
                    FM:
                    etHostNumberOfEntries:Error: hosts.actions.GetHostNumberOfEntries is not a function - {}
                    Der Adapter hat auch keine Objekte angelegt. sollte er aber oder?
                    Habe Adapter neu installiert (04.18) über iobroker.
                    Im Adapter gibt es 2 Handys.
                    Kein Erfolg.
                    Alero
                      Alero
                      nach Neuanlegen der Hadnys ist die FM weg.
                      Jetzt kommt neue FM:
                      019-06-05 09:18:50.801 error ~
                      tr-064.0 2019-06-05 09:18:50.801 error ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
                      tr-064.0 2019-06-05 09:18:50.801 error ~~ Fatal error. Can not connect to your FritzBox.
                      tr-064.0 2019-06-05 09:18:50.800 error Error: read ECONNRESET - {"errno":"ECONNRESET","code":"ECONNRESET","syscall":"read"}
                      User und Passwort und Verbindung zur Box wurden überprüft. alles ok.
                      Weiterhin keine Objekte angelegt.
                      Ganz schön sensibel
                      Alero
                      • SBorgS Offline
                        SBorgS Offline
                        SBorg
                        Der Adapter ist obsolete und wird vom Entwickler auch nicht mehr gepflegt. Ich würde zur "Community"-Version switchen. Die läuft schon sehr gut :)
                        • A Alero
                          Ganz schön sensibel
                          Alero
                          sigi234S Online
                          sigi234S Online
                          sigi234
                          @Alero sagte in TR-064.0 Adapter - Fehlermeldung:
                          Ganz schön sensibel
                          Alero
                          https://forum.iobroker.net/topic/22782/aufruf-test-community-version-vom-tr-064-adapter
                          Immer Daten sichern!
                          A 1 Antwort Letzte Antwort
                            Alero
                            Hi, Danke werde ich mal versuchen
                            Alero
                            • sigi234S sigi234
                              Ganz schön sensibel
                              Alero
                              Alero
                              @sigi234
                              Hi,, bekomme bei jendem Upgrade von Software (also auch bei TR-064 Community) u.a. diese FM:
                              In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:
                              ../node_modules/nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handlev8::Integer) [with T = v8::Int32; v8::Handlev8::Integer = v8::Localv8::Integer]’:
                              ../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Localv8::Int32 v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                              Tov8::Int32(v8::Handlev8::Integer i) { return i->ToInt32(); }
                              Und nach Installation des neuen Tr-064 Treibers werden auch keine Objekte angelegt.
                              Alero
                              • A Alero
                                @sigi234
                                Alero
                                sigi234S Online
                                sigi234S Online
                                sigi234
                                Dauert ein wenig, und einfach mal sich selbst anrufen, Adapter Grün?
                                A 2 Antworten Letzte Antwort
                                • sigi234S sigi234
                                  Alero
                                  @sigi234
                                  Hi, jetzt wird noch nicht einmal als Instanz angezeigt.
                                  Sieht auch so aus als hätte ich nicht genug Rechte auf /opt/iobroker/node_modules.
                                  Ändere das gerade.
                                  Da ist was arg durcheinander.
                                  Alero
                                  • sigi234S sigi234
                                    Alero
                                    @sigi234
                                    Hi, jetzt habe ich die Berechtigungen nachgezogen. Adapter wird jetzt wieder angezeigt.
                                    Unter Objekten erscheint jetzt min. das
                                    Es sollten aber meine beiden eingetragenen Handy noch als Objekt unter TR-064-Community erscheiunen, oder?
                                    Und ich sehe wieder eine FM im Log:
                                    019-06-05 12:53:08.454 error ~
                                    tr-064-community.0 2019-06-05 12:53:08.454 error ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
                                    tr-064-community.0 2019-06-05 12:53:08.454 error ~~ Fatal error. Can not connect to your FritzBox.
                                    tr-064-community.0 2019-06-05 12:53:08.453 error ~
                                    tr-064-community.0 2019-06-05 12:53:08.453 error Error: read ECONNRESET - {"errno":"ECONNRESET","code":"ECONNRESET","syscall":"read"}
                                    PW und USer sind eingetragen und auch richtg. Box ist auch erreichbar.
                                    Ich bekomme gleich eine Kriese!!
                                    Alero
                                    • A Alero
                                      @sigi234
                                      Alero
                                      dslraserD Offline
                                      dslraserD Offline
                                      dslraser
                                      starte mal Deine FritzBox neu (steht da...)
                                      • dslraserD dslraser
                                        Alero
                                        @dslraser Hi,
                                        habe ich auch schon gemacht. HAbe auch schoin den User unddas Passwort neu gesetzt
                                        Alero
                                        • A Alero
                                          @dslraser Hi,
                                          Alero
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                          @Alero
                                          okay, aber im Log steht trotzdem das er Deine Fritte nicht erreichen kann. Wenn Netzwerk, Ip, User usw. okay, dann Fritte neu starten.
                                          Hast Du jetzt nach Deinen letzten Änderungen mal die FritzBox neu gestartet, oder irgendwann zwischendurch ?
                                          Objekte kommen erst, wenn der Adapter eine Verbindung herstellen kann...
