  4. [Aufruf] Test Shelly Adapter
shellyadapter
717 Beiträge 81 Kommentatoren 262.8k Aufrufe 30 Beobachtet
  • P pitybull
    @Stuebi
    Ok. hier nochmal der komplette log vom Aktuallisieren bis Fehlermeldungen. Gerade nochmal neu upgedatet auf 3.0.1
    host.raspberrypi	2019-05-22 14:51:30.145	info	Restart adapter system.adapter.shelly.0 because enabled
    host.raspberrypi	2019-05-22 14:51:30.145	error	instance system.adapter.shelly.0 terminated with code 1 ()
    host.raspberrypi	2019-05-22 14:51:30.144	error	Caught by controller[0]: at startup (bootstrap_node.js:149:9)
    host.raspberrypi	2019-05-22 14:51:30.144	error	Caught by controller[0]: at run (bootstrap_node.js:383:7)
    host.raspberrypi	2019-05-22 14:51:30.144	error	Caught by controller[0]: at Module.runMain (module.js:604:10)
    host.raspberrypi	2019-05-22 14:51:30.144	error	Caught by controller[0]: at Function.Module._load (module.js:438:3)
    host.raspberrypi	2019-05-22 14:51:30.144	error	Caught by controller[0]: at tryModuleLoad (module.js:446:12)
    host.raspberrypi	2019-05-22 14:51:30.143	error	Caught by controller[0]: at Module.load (module.js:487:32)
    host.raspberrypi	2019-05-22 14:51:30.143	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:579:10)
    host.raspberrypi	2019-05-22 14:51:30.143	error	Caught by controller[0]: at Module._compile (module.js:542:28)
    host.raspberrypi	2019-05-22 14:51:30.143	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
    host.raspberrypi	2019-05-22 14:51:30.143	error	Caught by controller[0]: at createScript (vm.js:56:10)
    host.raspberrypi	2019-05-22 14:51:30.142	error	Caught by controller[0]: SyntaxError: Unexpected token function
    host.raspberrypi	2019-05-22 14:51:30.142	error	Caught by controller[0]: ^^^^^^^^
    host.raspberrypi	2019-05-22 14:51:30.142	error	Caught by controller[0]: async function getAllDevices() {
    host.raspberrypi	2019-05-22 14:51:30.141	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.shelly/shelly.js:84
    host.raspberrypi	2019-05-22 14:51:29.824	info	instance system.adapter.shelly.0 started with pid 6113
    host.raspberrypi	2019-05-22 14:51:29.822	info	object change system.adapter.shelly.0
    host.raspberrypi	2019-05-22 14:51:22.499	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    iobroker	2019-05-22 14:51:17.908	info	2
    iobroker	2019-05-22 14:51:17.908	info	upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    iobroker	2019-05-22 14:51:17.732	info	upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
    iobroker	2019-05-22 14:51:17.675	info	upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    iobroker	2019-05-22 14:51:17.616	info	upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    iobroker	2019-05-22 14:51:17.554	info	upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    iobroker	2019-05-22 14:51:17.496	info	upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    iobroker	2019-05-22 14:51:17.430	info	upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    iobroker	2019-05-22 14:51:17.360	info	upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
    iobroker	2019-05-22 14:51:17.218	info	upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
    iobroker	2019-05-22 14:51:17.093	info	upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
    iobroker	2019-05-22 14:51:17.074	info	got /opt/iobroker/node_modules/iobroker.shelly/admin
    iobroker	2019-05-22 14:49:16.007	info	npm install https://github.com/schmupu/ioBroker.shelly/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    iobroker	2019-05-22 14:49:14.866	info	install https://github.com/schmupu/ioBroker.shelly/tarball/master
    iobroker	2019-05-22 14:49:13.954	info	url "https://github.com/schmupu/ioBroker.shelly/tarball/master" shelly
    host.raspberrypi	2019-05-22 14:49:01.171	info	instance system.adapter.shelly.0 terminated with code 0 (OK)
    shelly.0	2019-05-22 14:49:01.116	info	terminating
    StuebiS Offline
    StuebiS Offline
    Stuebi
    #441
    @pitybull , kannst du einmal auf den Info Reiter schauen ob ioBroker mit Node 10 läuft. Ich glaube du hast Node 6 und 10 installiert und ioBroker läuft mir 6 statt 10.
    ioBroker auf Synology DS216+II im Docker Container
      pitybull
      #442
      ja du hast recht... :)
      wie kann ich das ändern?
          Plattform: linux
          Die Architektur: arm
          CPUs: 4
          Geschwindigkeit: 1200 MHz
          Modell: ARMv7 Processor rev 4 (v7l)
          RAM: 927.3 MB
          System uptime: 02:28:13
          Node.js: v6.11.5
          NPM: 6.4.1
          Adapter zählen: 240
          Uptime: 02:27:59
      StuebiS 1 Antwort Letzte Antwort
      • P pitybull
            Plattform: linux
            CPUs: 4
            RAM: 927.3 MB
            Node.js: v6.11.5
            NPM: 6.4.1
            Adapter zählen: 240
            Uptime: 02:27:59
        StuebiS Offline
        StuebiS Offline
        Stuebi
        schrieb am zuletzt editiert von Stuebi
        #443
        @pitybull sagte in [Aufruf] Test Shelly Adapter:
            Plattform: linux
            CPUs: 4
            RAM: 927.3 MB
            Node.js: v6.11.5
            NPM: 6.4.1
            Adapter zählen: 240
            Uptime: 02:27:59
        ich bin da keine Experte, habe aber den Tipp bekommen einmal
        which node
        auf dem Raspi (Linux) aufzurufen und die Links auf 6 aufzulösen.
          pitybull
          #444
          Habe es wie folgt hinbekommen. Die Befhle nacheinander ausführen.
          sudo iobroker stop
          cd /opt/iobroker
          npm rebuild
          iobroker start
          Jetzt läuft der iobroker mit Node 10 und der shelly Adapter 3.0.1 läuft jetzt auch.
          • G Offline
            GiuseppeS
            #445
            habe meine Shellies alle über mqtt mit mosquitto verbunden. Aber der Adapter hätte hier definitiv Vorteile, allerdings bekomme ich Fehlermeldungen, sobald ich mehrere Shelly verbinde (Port von 1883 auf 1882 korrigieren).
            Mein Netzwerk:
            Da meine Fritzbox bei zu vielen Geräten überfordert ist, habe ich über meinen Server, wo auch ioBroker läuft, einen wifi AccessPoint über Docker laufen. Alle Shellies, bisher 10 Stück, sind mit diesem AccessPoint verbunden. Geräte vom Docker Netzwerk können auch mit dem Standard Fritzbox/Server Netzwerk kommunizieren.
            Kommunikation mit mqtt vom Server zu den Shellies funktioniert eigentlich einwandfrei.
            Wenn ich nun den neuen Shelly Adapter verwende, bekomme ich ab dem zweiten Shelly folgende Log's:
            2019-05-25 18:02:50.686 - info: shelly.0 Destroy 172.17.0.2 (shelly1 / shelly1-554FF7 / SHSW-1#554FF7#1)
            2019-05-25 18:02:50.692 - info: shelly.0 Shelly device 172.17.0.2 (shelly1 / shelly1-2C8A39 / SHSW-1#2C8A39#1) with MQTT connected!
            2019-05-25 18:02:52.601 - info: shelly.0 Destroy 172.17.0.2 (shelly1 / shelly1-2C8A39 / SHSW-1#2C8A39#1)
            2019-05-25 18:02:52.604 - info: shelly.0 Shelly device 172.17.0.2 (shelly1 / shelly1-554FF7 / SHSW-1#554FF7#1) with MQTT connected!
            2019-05-25 18:02:54.592 - info: shelly.0 Destroy 172.17.0.2 (shelly1 / shelly1-554FF7 / SHSW-1#554FF7#1)
            2019-05-25 18:02:54.597 - info: shelly.0 Shelly device 172.17.0.2 (shelly1 / shelly1-2C8A39 / SHSW-1#2C8A39#1) with MQTT connected!
            2019-05-25 18:02:56.619 - info: shelly.0 Destroy 172.17.0.2 (shelly1 / shelly1-2C8A39 / SHSW-1#2C8A39#1)
            2019-05-25 18:02:56.623 - info: shelly.0 Shelly device 172.17.0.2 (shelly1 / shelly1-554FF7 / SHSW-1#554FF7#1) with MQTT connected!
            Ich gehe davon aus, dass ein Device immer mit dem nachfolgendem Device ersetzt wird, weil hier die IP der Docker Bridge angezeigt wird (172.17.0.2). Unter den Objektinfos der beiden Shellies stehen allerdings die korrekten IPs.
            Kann ich hier was korrigieren? Oder ist diese Konstellation einfach nicht möglich?
            Der Software AccessPoint soll nur zum Übergang dienen, bis ich einen bezahlbaren Wifi6 AP in die Hände bekomme. Daher ist das hier kein sehr wichtiger Fall. Aber evtl liegt es nur an einer Kleinigkeit.
            Danke & Gruß,
            Giuseppe
            StuebiS 2 Antworten Letzte Antwort
            • G GiuseppeS
              Mein Netzwerk:
              Danke & Gruß,
              Giuseppe
              StuebiS Offline
              StuebiS Offline
              Stuebi
              #446
              @GiuseppeS sagte in [Aufruf] Test Shelly Adapter:
              interessante Konstellation. Ich schaue einmal Morgen in Ruhe. Funktioniert es denn wenn Du Dich mit dem MQTT Adapter verbindest?
              • G GiuseppeS
                Mein Netzwerk:
                Danke & Gruß,
                Giuseppe
                StuebiS Offline
                StuebiS Offline
                Stuebi
                #447
                @GiuseppeS , ich habe eine kleine Sache geändert. Damit sollte es gehen. Kannst Du über Adapter -> GitHub Katze und dann Shelly auswählen laden. Danach die Instanz neu starten. Version 3.0.2
                • G Offline
                  GiuseppeS
                  #448
                  Ok, danke für die Rückmeldung. Werde ich heute testen. Direkt über den mqtt Adapter funktioniert übrigens alles. Das nutze ich aktuell.
                  • G GiuseppeS
                    StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #449
                    ja, ich habe es umgebaut, jetzt sollte es funktionieren. Bin auf Deine Testergebnisse gespannt.
                    • G Offline
                      GiuseppeS
                      #450
                      Was soll ich sagen:
                      Perfekt!
                      Geräte werden nun fehlerfrei hinzugefügt. Danke für die schnelle Anpassung und noch einen schönen Sonntag.
                        Andi888
                        #451
                        Hallo, setzte mich grade als Einsteiger mit iobroker auseinander und habe ein Problem mit dem shutter mode . Ich habe meherer Shelly 2.5 mit denen ich meine Rolladen steuere. Wie kann ich diese jetzt im iobroker ansteuern. Mir kommt es vor, als ob einige Punkte bei meinen Objekten fehlen. Über den switch von Relay0 oder 1 passiert auch nichts.
                        • A Andi888
                          StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          #452
                          @Andi888 , der Ordner shutter sollte nicht leer sein. Hier findest du die States open, Close, Pause und Position zum Schalten der Rollläden.
                          Wenn der Ordner nicht gefüllt ist starte die Shelly Instanz nochmals neu. Dann sollten alle Objekte angelegt werden
                            dos1973
                            #453
                            ich habe auch den Adapter upgedatet... jetzt geht irgendwie nichts mehr.
                            das Log sagt nichts ?
                            keines der Geräte ist via iobroker erreichbar, also reagiert auf das Relay switch... Der Adapter ist grün.
                            shelly.0	2019-05-28 18:06:46.981	debug	system.adapter.admin.0: logging true
                            shelly.0	2019-05-28 18:05:57.879	debug	stateChange shelly.0.SHSW-PM#608D93#1.Relay0.Switch {"val":true,"ack":false,"ts":1559059557875,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1559059557875}
                            shelly.0	2019-05-28 18:05:53.000	debug	system.adapter.admin.0: logging false
                            shelly.0	2019-05-28 18:05:31.809	info	Listening for Shelly packets in the network
                            shelly.0	2019-05-28 18:05:31.731	info	Stating Shelly adapter in CoAP modus.
                            shelly.0	2019-05-28 18:05:31.536	info	starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                            shelly.0	2019-05-28 18:05:31.502	debug	statesDB connected
                            shelly.0	2019-05-28 18:05:31.480	debug	objectDB connected
                            shelly.0	2019-05-28 18:05:28.107	info	Closing Adapter
                            shelly.0	2019-05-28 18:05:28.089	info	Closing Adapter
                            shelly.0	2019-05-28 18:05:27.204	debug	system.adapter.admin.0: logging false
                            shelly.0	2019-05-28 18:04:49.911	info	Listening for Shelly packets in the network
                            shelly.0	2019-05-28 18:04:49.808	info	Stating Shelly adapter in CoAP modus.
                            shelly.0	2019-05-28 18:04:49.641	info	starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                            shelly.0	2019-05-28 18:04:49.597	debug	statesDB connected
                            shelly.0	2019-05-28 18:04:49.573	debug	objectDB connected
                            shelly.0	2019-05-28 18:04:46.185	info	Closing Adapter
                            shelly.0	2019-05-28 18:06:46.982	debug	system.adapter.admin.0: logging true
                            Info:
                            ich habe heute ein alle Shelly's in ein neuen wlan umgezogen. Die Ip Adresse und alles ist gleich geblieben. Ich kann alle Shellys vis WebIF normal erreichen und schalten. (zurück ins alte wlan hilft auch nicht)
                            einen Shelly 2.5PM habe ich aus dem ObjektBaum gelöscht... der wird durch den Adapter auch nicht gefunden und wieder angelegt.
                            Muss ich die Shelly mit dem Adapter, jetzt zusätzlich konfigurieren?
                            In den Adapter Setting, habe ich all-IP und die iobroker spezifische versucht. Ohne Erfolg.
                            Idee, was ich machen kann??
                            • D dos1973
                              Info:
                              StuebiS Offline
                              StuebiS Offline
                              Stuebi
                              #454
                              @dos1973 , was passiert wenn Du in der Shelly App den Status änderst, siehst Du das in den ioBroker Shelly Objekten?
                              Hast Du bei Shellys ein Passwort unter "Restrict Login" gesetzt?
                              Befinden sich ioBroker und die Shellys im gleichen Subnetz?
                              Was mich wundert ist, dass online auf true steht!
                              VG
                              Stübi
                                dos1973
                                #455
                                ändern des status im webvif hat keine Reaktion in iobroker
                                nein, kein Passwort. habe auch in iobroker den admin rausgelöst
                                ja, alles im 192.168.10.xx
                                • D dos1973
                                  StuebiS Offline
                                  StuebiS Offline
                                  Stuebi
                                  #456
                                  @dos1973 , kannst Du einmal einen Shelly vom Stromnetz nehmen und dann neu starten. Hier ein ähnlicher Fall: https://github.com/schmupu/ioBroker.shelly/issues/54
                                    dos1973
                                    #457
                                    Was neu starten... den Adapter.
                                      dos1973
                                      schrieb am zuletzt editiert von dos1973
                                      #458
                                      Shelly vom strom, nix
                                      Adapter neustart nix
                                      Reagiert alles nicht...
                                      Macht es sinn den Adapter gesamthaft zu deinstallieren und nochmals neu zu installieren?
                                        dos1973
                                        #459
                                        es hilft eigentlich nix.
                                        ich habe eben einen auf Werkseinstellung gesetzt und diesen wieder ins wlan gepackt. keine Statusänderung.
                                        • D dos1973
                                          StuebiS Offline
                                          StuebiS Offline
                                          Stuebi
                                          #460
                                          @dos1973 , kannst du einmal den Debug Modus für den Shelly Adapter aktivieren.
                                          Interessant sind die CoAP Nachrichten in den Debug Messages (sind mit CoAP gekennzeichnet)
