  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • Marc BergM Marc Berg
    @simatec sagte in Test Adapter ioBroker.backitup v2.6.x:
    @marc-berg Sollte nun mit der v2.6.23 funktionieren
    Jup, funktioniert jetzt. Danke!
    Laser
    #2405
    @simatec backitup soll ja influx Daten sichern und wiederherstellen können. Beim Sichern kommt schon diese Fehlermeldung:
    Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.57/backup /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 2956 states saved
    [DEBUG] [iobroker] - host.raspberrypi 3663 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_01-18_22_41_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_06_01-18_22_52_backupiobroker"
    [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_06_01-18_22_52_backupiobroker" successfully deleted
    [ERROR] [influxDB] - Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2023_06_01-18_22_52_backupiobroker"
    Error: unknown shorthand flag: 'p' in -portable
    See 'influxd -h' for help
    • Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      #2406
      @laser sagte in Test Adapter ioBroker.backitup v2.6.x:
      Du hast den Backitup Adapter falsch konfiguriert. Du hast ne 2.x Datenbank und versuchst, mit 1.x Befehlen zu sichern.
      L 1 Antwort Letzte Antwort
        Laser
        schrieb am zuletzt editiert von Laser
        #2407
        @marc-berg OK, jetzt habe ich schon mal einen Ansatz. Was will ich genau machen? Ich möchte meinen "alten" PI mit Influx sichern und die Datenbank auf dem "Neuen" wieder herstellen. Ich hoffe, das geht. Das Sichern lief schon mal ohne Fehler durch. Eigentlich möchte ich nur die Influx- Daten erhalten/ übertragen. Der Rest soll bleiben. Wenn ich IO Broker abwähle, nur Influx lasse, kann ich kein Backup machen.
        Marc BergM 2 Antworten Letzte Antwort
        • L Laser
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          #2408
          Die Sicherungsdatei rüberkopieren und am Zielsystem auf "Get Backups" gehen (keine Ahnung, wie das im Deutschen übersetzt wurde). Vorher natürlich den Backitup Adapter konfigurieren. Wenn dort die DB frisch installiert wurde, musst du den NEUEN Token benutzen.
          • L Laser
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            #2409
            ja, isso. Aber nicht schlimm, du muss den ioBroker ja nicht wiederherstellen.
              Laser
              #2410
              @marc-berg Da habe ich aber immer meine fehlerhafte IOBroker Konfig wiederhergestellt. Das wollte ich eigentlich nicht.
              • L Laser
                Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                #2411
                Das InfluxDB Backup lässt sich doch beim Wiederherstellen separat auswählen. Es sind auch zwei separate Dateien, die beim Backup erstellt werden.
                  Laser
                  #2412
                  @marc-berg OK, hat sich jetzt etwas überschnitten. Werde ich versuchen.
                  • L Laser
                    Laser
                    #2413
                    @Marc-Berg Werde mal etwas rumprobieren. Die Sicherung wird nicht auf dem NAS abgelegt, wo ich mein "normales" Backup hinsichere, sondern auf dem "neuen" PI?
                    Marc BergM DJMarc75D 2 Antworten Letzte Antwort
                    • L Laser
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      #2414
                      Keine Ahnung. Da, wo du das "backups" Verzeichnis auf dem neuen System gemountet hast.
                        Laser
                        #2415
                        @marc-berg OK, muß mal etwas probieren...
                        • L Laser
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #2416
                          Ist das eine Frage oder eine Feststellung ? Anfang 2023 hatten "wir" also DU glaub ich schonmal ein ähnliches Anliegen ...
                          Lehrling seit 1975 !!!
                          • DJMarc75D DJMarc75
                            Laser
                            #2417
                            @djmarc75 Das sollte eine Frage sein. Am liebsten hätte ich als Zwischenspeicher für das Backup jetzt mein NAS. Im den Einstellungen von Backitup verwirrt mich die Angabe "Remote" etwas...Heißt ja sonst "NAS".
                            EDIT: OK, da steht auch "Quelle" also "local" lassen. Beim Sichern.
                            Der Fragesteller von damals war ich nicht. Lese mir aber diesen Beitrag (allerdings von 2021) gerade durch!
                            • L Laser
                              simatecS Online
                              simatecS Online
                              simatec
                              #2418
                              Nein Remote oder lokal ist auf deinen Datenbank bezogen.
                              • Besuche meine Github Seite
                              • HowTo Restore ioBroker
                              • simatecS simatec
                                Laser
                                #2419
                                @simatec Es wird immer klarer. Jetzt habe ich noch diese Meldungen:
                                Backitup V.2.6.23
                                [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.2.57:/backup2 /opt/iobroker/backups"
                                [ERROR] [iobroker] - host.raspberrypi Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EROFS: read-only file system, open '/opt/iobroker/backups/iobroker_2023_06_02-08_29_54_backupiobroker.tar.gz'
                                [DEBUG] [influxDB] - InfluxDB Backup tmp directory cannot created
                                [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t 566R9jsPKOvKvzrIwJUU-eWDZI3GrKDlnko_AqkK99tzr0xEWjU_7pbplhFFnVcF6OPI7LTV1dD3UD4upLQuUA== "/opt/iobroker/backups/influxDB_2023_06_02-08_30_02_backupiobroker"
                                Error: mkdir /opt/iobroker/backups/influxDB_2023_06_02-08_30_02_backupiobroker: read-only file system
                                in diesem Ordner ist doch mein NAS gemountet? Ich versuche mich jetzt mit NFS statt CIFS (ist das besser geeignet?). Eigentlich ist dieses Filesystem "backup2" für Benutzer IOBroker Read/Write erlaubt.
                                Mein NAS ist OMV. Wenn man den OMV Einstellungen trauen kann...
                                EDIT: auch manuell kann ich da nicht schreiben. Es liegt am NAS! Im Jahr 2022 habe ich dort aber schon mal gesichert. Eigenartig.
                                Mit CIFS kann ich ein influx-Backup erstellen.
                                • B biker1602
                                  @simatec
                                  Super es hat funktioniert.
                                  Eine Frage habe ich noch. Bevor ich es auf Google Drive gesichert habe, hatte ich es mal auf meinem NAS Server gesichert. Das mache ich aber schon lange nicht mehr. Wenn ich jetzt aber wie eben die Sicherung manuell angestoßen habe, kommt immer noch die IP vom NAS Server mit im Test, obwohl Sicherung auf NAS gar nicht mehr angehakt ist.
                                  mountType":"CIFS","type":"storage","source":"googledrive","mount":"192.168.XX.XX","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","s
                                  Muss ich das irgendwie manuell rauslöschen?
                                  tobitobsta
                                  #2420
                                  @biker1602 said in Test Adapter ioBroker.backitup v2.6.x:
                                  @simatec
                                  War bei mir genau dieselbe Ausgangslage (früher mal mit NAS und Mount) und der Fixer hat auch geholfen. Ich meine, dass es dann aber irgendwann wieder aufgetreten ist, nach meinem letzten "fixer" (nicht gesichert). Hast Du das jetzt irgendwie rausgelöscht @biker1602?
                                  VG und Danke
                                  • simatecS simatec
                                    Aktuelle Test Version 3.1.0
                                    Veröffentlichungsdatum 02.03.2025
                                    Github Link https://github.com/simatec/ioBroker.backitup
                                    Wiki Link https://github.com/simatec/ioBroker.backitup/wiki
                                    Hier geht es um die aktuelle Version von ioBroker.backitup, nachdem der alte Thread langsam zu unübersichtlich wurde.
                                    Bitte gebt euer Feedback und eure Anregungen hier ab.
                                    3.1.0 (2025-03-02)
                                    • (Bluefox) Dependencies updated
                                    • (Bluefox) Vite added
                                    • (simatec) jsonConfig updated
                                    • (simatec) Fix month for history
                                    3.0.37 (2025-02-28)
                                    • (simatec) Fix CronJob
                                    3.0.36 (2025-02-26)
                                    • (simatec) Fix src-admin
                                    3.0.35 (2025-02-26)
                                    3.0.34 (2025-02-26)
                                    3.0.33 (2025-02-25)
                                    • (simatec) Fix cronjob
                                    • (simatec) Fix Backup Console
                                    3.0.32 (2025-02-24)
                                    • (simatec) Error handling for GoogleDrive fix
                                    • (simatec) globalDependencies updated
                                    • (simatec) Dependencies updated
                                    • (simatec) Design Fix
                                    3.0.31 (2024-11-30)
                                    • (simatec) Fix Tab Menu
                                    3.0.30 (2024-11-29)
                                    3.0.29 (2024-11-29)
                                    3.0.28 (2024-11-27)
                                    • (simatec) eslint-config added
                                    • (bluefox) Allow to store files for up to ca 3 years
                                    • (Marc-Berg) Grafana Docu updated
                                    3.0.27 (2024-11-12)
                                    • (simatec) dependencies updated
                                    3.0.26 (2024-10-16)
                                    • (simatec) Fix FTP Connections
                                    • (simatec) Issue Workflow added
                                    3.0.25 (2024-09-26)
                                    • (bluefox) Improvement of Google Drive authentication workflow
                                    • (bluefox) Removed gulp from a build process
                                    • (simatec) small Design Fix
                                    • (simatec) Fix for Admin 7.1.5
                                    • (simatec) Fix Test & Release
                                    • (simatec) Fix ESlint errors
                                    3.0.22 (2024-09-03)
                                    • (simatec) Fix Notification Instance
                                    • (simatec) Fix Notification Design
                                    • (simatec) Fix Default Settings
                                    3.0.21 (2024-09-01)
                                    • (simatec) Fix Onedrive Notification
                                    • (simatec) Fix Zigbee2MQTT Backup
                                    3.0.20 (2024-08-22)
                                    • (simatec) Responsive Design for Tab added
                                    • (simatec) Responsive Design for jsonConfig added
                                    3.0.19 (2024-08-15)
                                    • (simatec) Fix CCU Backup
                                    • (simatec) Fix InfluxDB Backup Config
                                    • (simatec) Fix Backup-Log for Slave Instanz
                                    3.0.18 (2024-08-14)
                                    • (simatec) Package optimisation
                                    • (simatec) Fix the warning when opening the configuration
                                    3.0.17 (2024-08-12)
                                    • (simatec) Fix io-package for Release
                                    • (simatec) manual-review added
                                    • (simatec) Fix Slave Backup
                                    3.0.16 (2024-08-05)
                                    • (bluefox) dependencies updated
                                    • (simatec) Rename json5 Files
                                    3.0.15 (2024-08-03)
                                    • (simatec) fix dependencies
                                    3.0.14 (2024-08-02)
                                    • (simatec) Improved log outputs
                                    3.0.12 (2024-08-01)
                                    • (simatec) Backup Log for History added
                                    • (simatec) Added separate selection for deleting FTP backups
                                    • (simatec) Added separate selection for deleting Onedrive backups
                                    • (simatec) Added separate selection for deleting Webdav backups
                                    • (simatec) Added separate selection for deleting Dropbox backups
                                    • (simatec) Added separate selection for deleting Googledrive backups
                                    • (simatec) Source code cleaned up
                                    3.0.11 (2024-07-28)
                                    3.0.10 (2024-07-22)
                                    • (simatec) Design Fix for Dark Mode
                                    3.0.9 (2024-07-11)
                                    • (simatec) Tab Icons added
                                    • (simatec) small fix
                                    • (simatec) Docu updated
                                    3.0.8 (2024-07-01)
                                    • (Grothesk242/simatec) forceuid and forcegid added
                                    3.0.7 (2024-06-26)
                                    • (simatec) Restore Information added
                                    • (simatec) Fix Formaterrors
                                    • (bluefox) Fixing the problems with styles
                                    • (simatec) Fix iobroker Backup Error
                                    3.0.6 (2024-06-26)
                                    3.0.5 (2024-06-18)
                                    • (simatec) Fix Build
                                    3.0.4 (2024-06-18)
                                    • (simatec) History Gui Fix
                                    • (simatec) Tab GUI modified
                                    • (bluefox) Added support for Admin 7
                                    • (simatec) Onedrive ready for School/Business Accounts
                                    3.0.3 (2024-06-10)
                                    • (simatec) Fixed WebDav
                                    • (simatec) Admin Notification for Backup errors added
                                    • (simatec) Remove Sentry Config
                                    • (simatec) Translations updated
                                    • (simatec) Error handling optimized
                                    3.0.2 (2024-06-06)
                                    • (simatec) Fixed Google Drive
                                    • (simatec) Fixed Translations
                                    • (simatec) Fixed Onedrive
                                    • (simatec) Fixed MySql Backup
                                    • (simatec) Fixed Translation added
                                    • (simatec) new notifications content added
                                    3.0.1 (2024-05-29)
                                    • (simatec) Fixed umount callback
                                    • (simatec) Fixed Backup Message
                                    • (simatec) Fixed InfluxDB Multi Backup
                                    • (simatec) Fixed Restore Console
                                    • (simatec) Fixed Backup Console
                                    3.0.0 (2024-05-28)
                                    • (simatec) jsonConfig added
                                    • (bluefox) Conversion to React
                                    • (bluefox) Added react components
                                    • (bluefox/simatec) Working on React GUI
                                    • (simatec) Fix Yahka Backup
                                    • (simatec) Fix Nodered Backup
                                    • (simatec) some bugs fixed
                                    • (bluefox/simatec) New Restore-Interface
                                    • (simatec) Translation updated
                                    qqolliQ Offline
                                    qqolliQ Offline
                                    qqolli
                                    #2421
                                    @simatec
                                    Mal eine ganz ketzerische Frage. Ich nutze ioB auf einer Proxmoxinstallation deren Container täglich gesichert werden.
                                    Zusätzlich führe ich (bis jetzt) ebenfalls täglich die ioB-BackitUp durch.
                                    Eigentlich bräuchte ich den Adapter in meinem Fall eigentlich nicht, oder bringt es einen Vorteil beides zu sichern?
                                    F 1 Antwort Letzte Antwort
                                    • qqolliQ qqolli
                                      @simatec
                                      firebowl
                                      #2422
                                      @qqolli bin zwar nicht @simatec aber ich antworte trotzdem mal.
                                      Hab genau das gleiche Szenario wie Du und ich werde weiterhin dabei bleiben. Stell dir vor Du änderst an verschiedenen Adaptern oder Scripts etwas und dabei geht was kaputt.
                                      Hast Du nur die Proxmox Sicherung, kannst nur alles oder nichts restoren. Mit dem backitup Adapter restore ich halt im Zweifel nur Scripts oder etwas anderes.
                                      qqolliQ 1 Antwort Letzte Antwort
                                      • F firebowl
                                        qqolliQ Offline
                                        qqolliQ Offline
                                        qqolli
                                        #2423
                                        @firebowl
                                        Ja, das hatte ich mir schon gedacht und deshalb ebenfalls die Sicherung beibehalten Werde das dann auch in Zukunft so halten. Danke für den Tipp, an die Skripte hatte ich gar nicht gedacht :-)
                                        • simatecS Online
                                          simatecS Online
                                          simatec
                                          #2424
                                          Ab sofort steht die Version 2.7.0 auf Github und im latest zur Verfügung.
                                          Changelog
                                          2.7.0 (2023-08-14)
                                          • (simatec) Fix error Messages
                                          • (simatec) edit automatic name addition added
                                          • (simatec) Docu & Wiki updated
                                          • (simatec) small bug fixes
                                          • (crycode-de) Add support for sending notifications via discord (requires ioBroker.discord >= 2.1)
