  4. Alpha Test js-controller 5.0
    6.6k
140 Beiträge 25 Kommentatoren 31.9k Aufrufe 31 Beobachtet
  • T todde
    Alle adapter laufen nach dem Update auf v5 bis auf Doorbird. Der crashed mit einer uncaught exception:
    2023-05-16 07:24:37.299 - debug: doorbird.0 (177011) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2023-05-16 07:24:37.369 - debug: doorbird.0 (177011) Objects client ready ... initialize now
    2023-05-16 07:24:37.372 - debug: doorbird.0 (177011) Objects create System PubSub Client
    2023-05-16 07:24:37.373 - debug: doorbird.0 (177011) Objects create User PubSub Client
    2023-05-16 07:24:37.529 - debug: doorbird.0 (177011) Objects client initialize lua scripts
    2023-05-16 07:24:37.561 - debug: doorbird.0 (177011) Objects connected to redis: 0.0.0.0:9001
    2023-05-16 07:24:37.564 - silly: doorbird.0 (177011) redis psubscribe cfg.o.system.user.*
    2023-05-16 07:24:37.616 - silly: doorbird.0 (177011) redis psubscribe cfg.o.enum.*
    2023-05-16 07:24:37.619 - silly: doorbird.0 (177011) objectDB connected
    2023-05-16 07:24:37.622 - debug: doorbird.0 (177011) Redis States: Use Redis connection: 0.0.0.0:9000
    2023-05-16 07:24:37.738 - debug: doorbird.0 (177011) States create System PubSub Client
    2023-05-16 07:24:37.739 - debug: doorbird.0 (177011) States create User PubSub Client
    2023-05-16 07:24:37.877 - debug: doorbird.0 (177011) States connected to redis: 0.0.0.0:9000
    2023-05-16 07:24:37.878 - silly: doorbird.0 (177011) statesDB connected
    2023-05-16 07:24:38.406 - info: doorbird.0 (177011) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.doorbird, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
    2023-05-16 07:24:38.458 - silly: doorbird.0 (177011) States system redis pmessage system.adapter.doorbird.0.logLevel/system.adapter.doorbird.0.logLevel:{"val":"silly","ack":true,"ts":1684214678440,"q":0,"from":"system.adapter.doorbird.0","lc":1684214678440}
    2023-05-16 07:24:38.508 - silly: doorbird.0 (177011) States user redis pmessage doorbird.0.*/doorbird.0.info.connection:{"val":false,"ack":true,"ts":1684214678501,"q":0,"from":"system.adapter.doorbird.0","user":"system.user.admin","lc":1684214678501}
    2023-05-16 07:24:38.532 - debug: doorbird.0 (177011) Authorization with User gheicj0001 successfull!
    2023-05-16 07:24:38.559 - debug: doorbird.0 (177011) Checking favorites on DoorBird Device..
    2023-05-16 07:24:38.569 - silly: doorbird.0 (177011) States user redis pmessage doorbird.0.*/doorbird.0.info.connection:{"val":true,"ack":true,"ts":1684214678565,"q":0,"from":"system.adapter.doorbird.0","user":"system.user.admin","lc":1684214678565}
    2023-05-16 07:24:38.587 - debug: doorbird.0 (177011) Found a Favorite that belongs to me..
    2023-05-16 07:24:38.588 - debug: doorbird.0 (177011) (ID: 0) (ioBroker doorbird.0 1 Ring: http://192.168.6.54:8100/ring?1)
    2023-05-16 07:24:38.588 - debug: doorbird.0 (177011) Found a Favorite that belongs to me..
    2023-05-16 07:24:38.589 - debug: doorbird.0 (177011) (ID: 1) (ioBroker doorbird.0 Motion: http://192.168.6.54:8100/motion)
    2023-05-16 07:24:38.589 - debug: doorbird.0 (177011) Result of Favorites: {"1":{"ID":"0","URL":"http://192.168.6.54:8100/ring?1"},"Motion":{"ID":"1","URL":"http://192.168.6.54:8100/motion"}}
    2023-05-16 07:24:38.600 - silly: doorbird.0 (177011) States user redis pmessage doorbird.0.*/doorbird.0.info.firmware:{"val":"000139","ack":true,"ts":1684214678595,"q":0,"from":"system.adapter.doorbird.0","user":"system.user.admin","lc":1683609657823}
    2023-05-16 07:24:38.618 - silly: doorbird.0 (177011) States user redis pmessage doorbird.0.*/doorbird.0.info.build:{"val":"16824274","ack":true,"ts":1684214678615,"q":0,"from":"system.adapter.doorbird.0","user":"system.user.admin","lc":1683609657823}
    2023-05-16 07:24:38.620 - silly: doorbird.0 (177011) States user redis pmessage doorbird.0.*/doorbird.0.info.type:{"val":"DoorBird D2101V","ack":true,"ts":1684214678615,"q":0,"from":"system.adapter.doorbird.0","user":"system.user.admin","lc":1558199246009}
    2023-05-16 07:24:38.625 - debug: doorbird.0 (177011) Looping trough the Schedules..
    2023-05-16 07:24:38.626 - debug: doorbird.0 (177011) Detected a Doorbell Schedule!
    2023-05-16 07:24:38.626 - debug: doorbird.0 (177011) The Param of the actual Schedule is: 1
    2023-05-16 07:24:38.627 - debug: doorbird.0 (177011) The Output contains 3 entries!
    2023-05-16 07:24:38.627 - debug: doorbird.0 (177011) Entry "0" is: {"event":"notify","param":"","schedule":{"weekdays":[{"to":"75599","from":"75600"}]}}
    2023-05-16 07:24:38.627 - debug: doorbird.0 (177011) Entry "1" is: {"event":"sip","param":"1","schedule":{"weekdays":[{"to":"75599","from":"75600"}]}}
    2023-05-16 07:24:38.628 - debug: doorbird.0 (177011) Entry "2" is: {"event":"http","param":"0","enabled":"1","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}
    2023-05-16 07:24:38.628 - debug: doorbird.0 (177011) Counted 1 Doorbells.
    2023-05-16 07:24:38.628 - debug: doorbird.0 (177011) Detected Motion Schedule!
    2023-05-16 07:24:38.629 - debug: doorbird.0 (177011) The Output contains 2 entries!
    2023-05-16 07:24:38.629 - debug: doorbird.0 (177011) Entry "0" is: {"event":"notify","param":"","schedule":{"weekdays":[{"to":"75599","from":"75600"}]}}
    2023-05-16 07:24:38.630 - debug: doorbird.0 (177011) Entry "1" is: {"event":"http","param":"1","enabled":"1","schedule":{"weekdays":[{"from":"75600","to":"75599"}]}}
    2023-05-16 07:24:38.630 - debug: doorbird.0 (177011) Checking if we need to create any favorites..
    2023-05-16 07:24:38.631 - debug: doorbird.0 (177011) Cheking if Favorite for Doorbell ID 1 exists.
    2023-05-16 07:24:38.631 - debug: doorbird.0 (177011) Favorite for Doorbell ID 1 exists!
    2023-05-16 07:24:38.632 - debug: doorbird.0 (177011) Checking if we need to create any favorites..
    2023-05-16 07:24:38.632 - debug: doorbird.0 (177011) Favorites checked successfully. No actions needed!
    2023-05-16 07:24:38.633 - debug: doorbird.0 (177011) Checking if we need to create Schedules on DoorBird Device..
    2023-05-16 07:24:38.633 - debug: doorbird.0 (177011) Okay we dont need to create any Doorbell-Schedules..
    2023-05-16 07:25:09.094 - debug: doorbird.0 (177011) Received Motion-alert from Doorbird!
    2023-05-16 07:25:09.138 - silly: doorbird.0 (177011) States user redis pmessage doorbird.0.*/doorbird.0.Motion.trigger:{"val":true,"ack":true,"ts":1684214709133,"q":0,"from":"system.adapter.doorbird.0","user":"system.user.admin","lc":1683122919533}
    2023-05-16 07:25:09.174 - error: doorbird.0 (177011) uncaught exception: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker-data/doorbird.0.snap.jpg'
    2023-05-16 07:25:09.175 - error: doorbird.0 (177011) Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker-data/doorbird.0.snap.jpg'
    2023-05-16 07:25:09.175 - error: doorbird.0 (177011) Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker-data/doorbird.0.snap.jpg'
    2023-05-16 07:25:09.180 - info: doorbird.0 (177011) terminating
    2023-05-16 07:25:09.181 - warn: doorbird.0 (177011) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-05-16 07:25:09.683 - info: doorbird.0 (177011) terminating
    2023-05-16 07:25:09.842 - error: host.iobroker instance system.adapter.doorbird.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-05-16 07:25:09.842 - info: host.iobroker Restart adapter system.adapter.doorbird.0 because enabled
    Hier das iob diag:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
    07:39:41 up 12 days, 17:10,  1 user,  load average: 1.21, 1.04, 1.00
    CPU threads: 4
    *** Time and Time Zones ***
                  Local time: Tue 2023-05-16 07:39:41 CEST
              Universal time: Tue 2023-05-16 05:39:41 UTC
                    RTC time: Tue 2023-05-16 05:39:41
                 NTP service: n/a
             RTC in local TZ: no
    *** User and Groups ***
    thrieger
    /home/thrieger
    thrieger cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.8G        4.9G        2.3G        0.0K        589M        2.5G
    Swap:           976M        469M        507M
    Total:          8.8G        5.4G        2.8G
            7794 M total memory
            4931 M used memory
             661 M active memory
            4535 M inactive memory
            2273 M free memory
             203 M buffer memory
             385 M swap cache
             976 M total swap
             469 M used swap
             507 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     780M  808K  779M   1% /run
    /dev/sda2      ext4      109G   18G   86G  17% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1      vfat      511M  6.1M  505M   2% /boot/efi
    tmpfs          tmpfs     780M     0  780M   0% /run/user/1000
    [Wed May  3 14:28:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed May  3 14:28:56 2023] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
    [Wed May 10 19:27:39 2023]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Thu May 11 06:37:28 2023]  ext4_filemap_fault+0x2d/0x50 [ext4]
    [Thu May 11 07:05:50 2023]  ext4_filemap_fault+0x2d/0x50 [ext4]
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    3.7G    /var/
    3.1G    /var/log/journal/10061850f7cc416f9745face05a6bc4e
    3.1G    /var/log
    300M    /var/cache
    Archived and active journals take up 128.0M in the file system.
    /opt/iobroker/backups:
    348M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.0G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/history
    1.3G    /opt/iobroker/iobroker-data/files
    615M    /opt/iobroker/iobroker-data/files/vis-2-beta
    545M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
    32M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/esphometest/.pioenvs/esphometest/libFrameworkArduino.a
    23M     /opt/iobroker/iobroker-data/states.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.e7d9968b.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
     Installed: 18.16.0-deb-1nodesource1
     Candidate: 18.16.0-deb-1nodesource1
     Version table:
    *** 18.16.0-deb-1nodesource1 500
           500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
        12.22.12~dfsg-1~deb11u4 500
           500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
        12.22.12~dfsg-1~deb11u3 500
           500 http://deb.debian.org/debian bullseye/main amd64 Packages
        10.24.0~dfsg-1~deb10u3 500
           500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
        10.24.0~dfsg-1~deb10u1 500
           500 http://deb.debian.org/debian buster/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    admin:          6.4.4
    javascript:     7.0.3
    Adapters from github:   6
    Adapter State
     system.adapter.acme.0                   : acme                  : iobroker                                 -  enabled, port: 8090, bind: 192.168.6.54
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
     system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
     system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
     system.adapter.doorbird.0               : doorbird              : iobroker                                 - disabled
     system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
     system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
     system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
     system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
     system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
     system.adapter.javascript.1             : javascript            : iobroker                                 - disabled
     system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.luxtronik1.0             : luxtronik1            : iobroker                                 -  enabled, port: 8899
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
     system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
     system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled
     system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
     system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 - disabled, port: 8002
    + system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.simple-api.1             : simple-api            : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.simple-api.2             : simple-api            : iobroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
     system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
     system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
     system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
     system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
     system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
     system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
     system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
     system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
     system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
     system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
     system.adapter.yahka.0                  : yahka                 : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "acme"         : 0.0.2    , installed 0.0.2
    Adapter    "admin"        : 6.4.4    , installed 6.4.4
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.20   , installed 2.6.20
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "doorbird"     : 0.1.5    , installed 0.1.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.4.15   , installed 1.4.15
    Adapter    "esphome"      : 0.2.4    , installed 0.2.4
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "jarvis"       : 3.1.3    , installed 3.1.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 5.0.1
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "luxtronik1"   : 0.3.5    , installed 0.3.5
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "openweathermap": 0.3.8   , installed 0.3.8
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "senec"        : 1.3.9    , installed 1.3.9
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "snmp"         : 2.4.7    , installed 2.4.7
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-2-widgets-energy": 0.1.12, installed 0.1.12
    Adapter    "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
    Adapter    "vis-2-widgets-material": 0.2.13, installed 0.2.13
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        21303
    States:         21197
    Hit:1 http://security.debian.org/debian-security buster/updates InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian buster InRelease
    Hit:4 http://deb.debian.org/debian buster-updates InRelease
    Hit:5 http://deb.debian.org/debian bullseye InRelease
    Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12982      1/init
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          61397439   220138/nc
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       37046815   2776150/io.jarvis.0
    tcp        0      0 192.168.6.54:2001       0.0.0.0:*               LISTEN      1001       37039146   2772811/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11842      533/sshd: /usr/sbin
    tcp        0      0 192.168.6.54:2010       0.0.0.0:*               LISTEN      1001       37039382   2773270/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       37036786   2773037/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       37037714   2772978/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       37037715   2772978/io.mqtt.0
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       37043830   2775659/python3
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       37035584   2771578/iobroker.js
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       37035577   2771578/iobroker.js
    tcp6       0      0 :::111                  :::*                    LISTEN      0          11562      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       37037425   2772295/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       37042022   2774602/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11844      533/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       37043779   2775528/io.simple-a
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       37045947   2776355/io.simple-a
    tcp6       0      0 :::8089                 :::*                    LISTEN      1001       37047767   2777702/io.simple-a
    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       37045169   2776815/io.rest-api
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16579      468/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1416       1/init
    udp        0      0 192.168.6.54:123        0.0.0.0:*                           0          12086      661/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          12084      661/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          12080      661/ntpd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37047312   2776808/io.wled.0
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       37043839   2775659/python3
    udp        0      0 192.168.6.54:5353       0.0.0.0:*                           1001       37043838   2775659/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37043833   2775659/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37046340   2775329/io.esphome.
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       37043538   2774506/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          858        1/init
    udp6       0      0 2003:cc:8f2e:9700:9:123 :::*                                108        44031850   661/ntpd
    udp6       0      0 fe80::96c6:91ff:fea:123 :::*                                0          12092      661/ntpd
    udp6       0      0 ::1:123                 :::*                                0          12088      661/ntpd
    udp6       0      0 :::123                  :::*                                0          12077      661/ntpd
    2023-05-16 07:25:54.986  - info: host.iobroker instance system.adapter.doorbird.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-16 07:30:00.252  - info: host.iobroker instance system.adapter.dwd.0 started with pid 190996
    2023-05-16 07:30:03.208  - info: dwd.0 (190996) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
    2023-05-16 07:30:04.341  - info: host.iobroker instance system.adapter.ical.0 started with pid 191069
    2023-05-16 07:30:05.863  - warn: dwd.0 (190996) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-05-16 07:30:06.636  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-16 07:30:07.366  - info: ical.0 (191069) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
    2023-05-16 07:30:13.661  - info: ical.0 (191069) Terminated (NO_ERROR): Without reason
    2023-05-16 07:30:14.210  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-05-16 07:31:48.020  - info: javascript.0 (2772368) script.js.ThR.TabletEingang: Tablet battery new level: 37
    2023-05-16 07:35:00.273  - info: host.iobroker instance system.adapter.dwd.0 started with pid 203821
    2023-05-16 07:35:03.014  - info: dwd.0 (203821) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
    2023-05-16 07:35:04.977  - warn: dwd.0 (203821) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-05-16 07:35:05.658  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-05-16 07:40:00.256  - info: host.iobroker instance system.adapter.dwd.0 started with pid 216923
    2023-05-16 07:40:03.014  - info: dwd.0 (216923) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 5.0.1-alpha.0-20230418-efa3e809
    2023-05-16 07:40:05.303  - warn: dwd.0 (216923) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-05-16 07:40:05.836  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-22-amd64
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     3
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                           /usr/bin/npm            9.5.1
                           /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        4.9G        1.9G        0.0K        966M        2.5G
    Total:          8.8G        5.4G        2.4G
    Active iob-Instances:   43
    ioBroker Core:          js-controller           5.0.1-alpha.0-20230418-efa3e809
                           admin                   6.4.4
    Objects type: jsonl
    States  type: jsonl
    Objects:                21303
    States:                 21197
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/objects.json.migrated
    15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    25M     /opt/iobroker/iobroker-data/states.jsonl
    3.8M    /opt/iobroker/iobroker-data/states.json.migrated
    3.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    Issue ist beim Adapter auf GitHub offen: https://github.com/BuZZy1337/ioBroker.doorbird/issues/27
    #105
    @todde
    Deine Quellen sind falsch. Entweder 'buster' oder 'bullseye', aber nicht beides. Lösch die doppelten Einträge mit Buster.
    Und das Dateisystem schaut mir auch verdächtig aus.
      @todde
      todde
      #106
      @thomas-braun vielen Dank für deine schnelle Antwort. Buster ist entfernt und ein sudo apt update && sudo apt upgrade lief durch.
      OK:1 http://security.debian.org/debian-security bullseye-security InRelease
      OK:2 http://deb.debian.org/debian bullseye InRelease
      OK:3 http://deb.debian.org/debian bullseye-updates InRelease
      OK:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Was genau meinst du mit dem Dateisystem?
      • T todde
        #107
        @todde
        Damit meine ich diese Einträge mit ext4_filemap_fault:
        Das ist nicht normal.
        • T todde
          Hier das iob diag:
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
                       NTP service: n/a
                   RTC in local TZ: no
          thrieger
          /home/thrieger
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                  7794 M total memory
                  4931 M used memory
                   661 M active memory
                  2273 M free memory
                   203 M buffer memory
                   385 M swap cache
                   976 M total swap
                   469 M used swap
                   507 M free swap
          *** FILESYSTEM ***
          /var:
          3.7G    /var/
          3.1G    /var/log
          300M    /var/cache
          /usr/bin/npm            9.5.1
          /usr/bin/npx            9.5.1
          nodejs:
           Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.4.4
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        21303
          States:         21197
          Pending Updates: 3
                              v.2023-04-16
          User-ID:                1000
          X-Server:               false
                                 /usr/bin/npm            9.5.1
                                 /usr/bin/npx            9.5.1
          MEMORY:
                                 admin                   6.4.4
          Objects type: jsonl
          States  type: jsonl
          Objects:                21303
          States:                 21197
          #108
          @todde Ok itte die "Diag diskussion" in einen anderen Thread verlagern. Am Ende Doorbord: Der mact etwas was er nie tun darf und das rächt sich jetzt. Da muss der Adapter-Dev ran.
          T SchmakusS 2 Antworten Letzte Antwort
          • apollon77A apollon77
            todde
            #109
            @apollon77 , vielen Dank fürs Nachschauen. Leider ist der Adapter-Entwickler seit 5 Jahren inaktiv ...
            • T todde
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              #110
              @todde Ist jetzt in der Community und somit für viele Entwickler zugängig: https://github.com/iobroker-community-adapters/ioBroker.doorbird
              Videotutorials & mehr
              • apollon77A Offline
                #111
                So, nach einer kleinen "Pause", in der vor allem @foxriver76 aber nicht untätig war.
                Das wichtigste ist das ab sofort auch Node.js 14 nicht mehr unterstützt wird!!
                Danke für Eure nächste Testrunde. Ich denke es geht dann auch bald in Latest damit
                Changelog 5.0.1-alpha.0-20230525-c580eb7e
                • drop support for nodejs 14 with controller 5 as it is EOL
                • (foxriver76) Enable upgrade of js-controller via Admin UI (Linux only) - will be testable when we start with Beta
                • (foxriver76) fix wrong hostname after backup restore
                  (foxriver76) new io-package flag common.supportedMessages to replace messagebox and other messagebox-related properties
                • (foxriver76) adapter.sendTo now accepts an optional timeout argument
                ? E 2 Antworten Letzte Antwort
                  #112
                  @apollon77
                  Fettes Dankeschön an alle Entwickler!
                  Update durchgeführt, startet bis jetzt ohne weitere Auffälligkeiten.. 75 Adapter .. Node 18, Synology VM mit Debian Bullseye.
                  Auch Adapter, die mal gemeckert haben, laufen / liefen bisher, Fitbit, LGTV (hab den Fork von @basti4557 LGTV Adapter Fork) und auch Yeelight ohne Probleme.
                  ilovegym@iobrokerS2:/opt/iobroker$ iob stop
                  ilovegym@iobrokerS2:/opt/iobroker$ iob backup
                  host.iobrokerS2 87547 states saved
                  host.iobrokerS2 105622 objects saved
                  Backup created: /opt/iobroker/backups/2023_05_26-11_38_17_backupiobroker.tar.gz
                  This backup can only be restored with js-controller version up from 4.1
                  ilovegym@iobrokerS2:/opt/iobroker$ npm i iobroker.js-controller@next
                  changed 12 packages in 1m
                  145 packages are looking for funding
                   run `npm fund` for details
                  ilovegym@iobrokerS2:/opt/iobroker$ iob start
                  ilovegym@iobrokerS2:/opt/iobroker$ iob status
                  At least one iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  ilovegym@iobrokerS2:/opt/iobroker$ iob list instances
                  + system.adapter.admin.0                  : admin                 : iobrokerS2                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                   system.adapter.alarm.0                  : alarm                 : iobrokerS2                               -  enabled
                   system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : iobrokerS2                               -  enabled
                   system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobrokerS2                               -  enabled
                   system.adapter.alexa2.0                 : alexa2                : iobrokerS2                               -  enabled
                   system.adapter.backitup.0               : backitup              : iobrokerS2                               -  enabled
                   system.adapter.bluelink.0               : bluelink              : iobrokerS2                               -  enabled
                   system.adapter.cloud.0                  : cloud                 : iobrokerS2                               -  enabled
                   system.adapter.countdown.0              : countdown             : iobrokerS2                               -  enabled
                   system.adapter.device-watcher.0         : device-watcher        : iobrokerS2                               -  enabled
                   system.adapter.devices.0                : devices               : iobrokerS2                               - disabled
                   system.adapter.deyeidc.0                : deyeidc               : iobrokerS2                               -  enabled, port: 8899
                   system.adapter.deyeidc.1                : deyeidc               : iobrokerS2                               -  enabled, port: 8899
                   system.adapter.discovery.0              : discovery             : iobrokerS2                               -  enabled
                   system.adapter.drops-weather.0          : drops-weather         : iobrokerS2                               -  enabled
                   system.adapter.dwd.0                    : dwd                   : iobrokerS2                               -  enabled
                  + system.adapter.email.0                  : email                 : iobrokerS2                               -  enabled
                   system.adapter.energiefluss.0           : energiefluss          : iobrokerS2                               -  enabled
                   system.adapter.energiefluss.1           : energiefluss          : iobrokerS2                               -  enabled
                   system.adapter.feiertage.0              : feiertage             : iobrokerS2                               -  enabled
                   system.adapter.fitbit-fitness.0         : fitbit-fitness        : iobrokerS2                               -  enabled
                   system.adapter.flot.0                   : flot                  : iobrokerS2                               - disabled
                   system.adapter.fritzdect.0              : fritzdect             : iobrokerS2                               -  enabled
                   system.adapter.fully-mqtt.0             : fully-mqtt            : iobrokerS2                               -  enabled
                   system.adapter.go-e.0                   : go-e                  : iobrokerS2                               -  enabled
                   system.adapter.govee-app.0              : govee-app             : iobrokerS2                               -  enabled
                   system.adapter.heizoel.0                : heizoel               : iobrokerS2                               -  enabled
                   system.adapter.hp-ilo.0                 : hp-ilo                : iobrokerS2                               -  enabled
                   system.adapter.ical.0                   : ical                  : iobrokerS2                               -  enabled
                   system.adapter.iceroad.0                : iceroad               : iobrokerS2                               -  enabled
                  + system.adapter.influxdb.0               : influxdb              : iobrokerS2                               -  enabled, port: 8086
                  + system.adapter.influxdb.1               : influxdb              : iobrokerS2                               -  enabled, port: 8086
                  + system.adapter.influxdb.2               : influxdb              : iobrokerS2                               -  enabled, port: 8086
                   system.adapter.iot.0                    : iot                   : iobrokerS2                               -  enabled
                  + system.adapter.javascript.0             : javascript            : iobrokerS2                               -  enabled
                   system.adapter.lgtv.0                   : lgtv                  : iobrokerS2                               -  enabled
                   system.adapter.lgtv.1                   : lgtv                  : iobrokerS2                               -  enabled
                   system.adapter.lightcontrol.0           : lightcontrol          : iobrokerS2                               -  enabled
                   system.adapter.lightcontrol.1           : lightcontrol          : iobrokerS2                               -  enabled
                   system.adapter.linux-control.0          : linux-control         : iobrokerS2                               -  enabled
                   system.adapter.lovelace.0               : lovelace              : iobrokerS2                               -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                   system.adapter.meteoalarm.0             : meteoalarm            : iobrokerS2                               -  enabled
                   system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerS2                               -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobrokerS2                               -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.2          : mihome-vacuum         : iobrokerS2                               -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.3          : mihome-vacuum         : iobrokerS2                               -  enabled, port: 54321
                   system.adapter.minuaru.0                : minuaru               : iobrokerS2                               -  enabled
                   system.adapter.minuvis.0                : minuvis               : iobrokerS2                               - disabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobrokerS2                               -  enabled, port: 1886, bind: 0.0.0.0
                  + system.adapter.mqtt.1                   : mqtt                  : iobrokerS2                               -  enabled, port: 1884, bind: 0.0.0.0
                  + system.adapter.nut.0                    : nut                   : iobrokerS2                               -  enabled
                   system.adapter.octoprint.0              : octoprint             : iobrokerS2                               -  enabled
                   system.adapter.odl.0                    : odl                   : iobrokerS2                               -  enabled
                   system.adapter.oilfox.0                 : oilfox                : iobrokerS2                               -  enabled
                   system.adapter.openligadb.0             : openligadb            : iobrokerS2                               -  enabled
                   system.adapter.openweathermap.0         : openweathermap        : iobrokerS2                               -  enabled
                   system.adapter.operating-hours.0        : operating-hours       : iobrokerS2                               -  enabled
                  + system.adapter.ping.0                   : ping                  : iobrokerS2                               -  enabled
                   system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobrokerS2                               -  enabled, port: 8102
                   system.adapter.pollenflug.0             : pollenflug            : iobrokerS2                               -  enabled
                   system.adapter.puppeteer.0              : puppeteer             : iobrokerS2                               -  enabled
                   system.adapter.rest-api.0               : rest-api              : iobrokerS2                               -  enabled, port: 8880, bind: 0.0.0.0, run as: restapi
                   system.adapter.simple-api.0             : simple-api            : iobrokerS2                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                   system.adapter.snmp.0                   : snmp                  : iobrokerS2                               -  enabled
                   system.adapter.solarmanpv.0             : solarmanpv            : iobrokerS2                               -  enabled
                   system.adapter.sonoff.0                 : sonoff                : iobrokerS2                               -  enabled, port: 1883, bind: 0.0.0.0
                   system.adapter.synochat.0               : synochat              : iobrokerS2                               -  enabled
                  + system.adapter.synology.0               : synology              : iobrokerS2                               -  enabled, port: 5001
                   system.adapter.synology.1               : synology              : iobrokerS2                               -  enabled, port: 5000
                   system.adapter.text2command.0           : text2command          : iobrokerS2                               -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : iobrokerS2                               -  enabled
                  + system.adapter.tr-064.1                 : tr-064                : iobrokerS2                               -  enabled
                   system.adapter.trashschedule.0          : trashschedule         : iobrokerS2                               -  enabled
                   system.adapter.tuya.0                   : tuya                  : iobrokerS2                               -  enabled
                   system.adapter.unifi.0                  : unifi                 : iobrokerS2                               -  enabled
                   system.adapter.viessmannapi.0           : viessmannapi          : iobrokerS2                               -  enabled
                   system.adapter.vis.0                    : vis                   : iobrokerS2                               -  enabled
                   system.adapter.weatherunderground.0     : weatherunderground    : iobrokerS2                               -  enabled
                   system.adapter.web.0                    : web                   : iobrokerS2                               -  enabled, port: 81, bind: 0.0.0.0, run as: admin
                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokerS2                               -  enabled
                  + system.adapter.wifilight.0              : wifilight             : iobrokerS2                               -  enabled
                   system.adapter.windows-control.0        : windows-control       : iobrokerS2                               -  enabled
                  + system.adapter.wireguard.0              : wireguard             : iobrokerS2                               -  enabled
                   system.adapter.wled.0                   : wled                  : iobrokerS2                               -  enabled
                   system.adapter.worx.0                   : worx                  : iobrokerS2                               -  enabled
                   system.adapter.yahka.0                  : yahka                 : iobrokerS2                               -  enabled
                   system.adapter.yeelight-2.0             : yeelight-2            : iobrokerS2                               -  enabled
                   system.adapter.zigbee.0                 : zigbee                : iobrokerS2                               -  enabled, port: tcp://10.1.1.98:20108
                  + instance is alive
                  ilovegym@iobrokerS2:/opt/iobroker$ date
                  Fri 26 May 2023 11:44:03 AM CEST
                  ilovegym@iobrokerS2:/opt/iobroker$ iob logs --watch
                  ilovegym@iobrokerS2:/opt/iobroker$ iob update
                  Adapter    "admin"        : 6.5.3    , installed 6.5.3
                  Adapter    "alarm"        : 3.3.11   , installed 3.3.11
                  Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
                  Adapter    "alexa-timer-vis": 0.1.14 , installed 0.1.14
                  Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                  Adapter    "bluelink"     : 2.3.2    , installed 2.3.2
                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                  Adapter    "countdown"    : 2.0.1    , installed 2.0.1
                  Adapter    "device-watcher": 2.9.2   , installed 2.9.2
                  Adapter    "devices"      : 1.1.3    , installed 1.1.3
                  Adapter    "email"        : 1.1.4    , installed 1.1.4
                  Adapter    "fitbit-fitness": 0.4.10  , installed 0.4.10
                  Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                  Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                  Adapter    "hp-ilo"       : 1.0.6    , installed 1.0.6
                  Adapter    "iceroad"      : 1.2.0    , installed 1.2.0
                  Adapter    "lgtv"         : 1.1.10   , installed 1.1.11
                  Adapter    "lightcontrol" : 0.2.17   , installed 0.2.17
                  Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                  Adapter    "meteoalarm"   : 2.3.5    , installed 2.3.5
                  Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
                  Adapter    "minuaru"      : 1.1.0    , installed 1.1.0
                  Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
                  Adapter    "nut"          : 1.6.0    , installed 1.6.0
                  Adapter    "octoprint"    : 5.0.0    , installed 5.0.0
                  Adapter    "odl"          : 2.0.5    , installed 2.0.5
                  Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
                  Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
                  Adapter    "operating-hours": 1.0.1  , installed 1.0.1
                  Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
                  Adapter    "solarmanpv"   : 0.4.0    , installed 0.4.0
                  Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                  Adapter    "synochat"     : 1.2.1    , installed 1.2.1
                  Adapter    "synology"     : 2.1.13   , installed 2.1.13
                  Adapter    "text2command" : 3.0.2    , installed 3.0.2
                  Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                  Adapter    "unifi"        : 0.6.4    , installed 0.6.4
                  Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                  Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                  Adapter    "windows-control": 0.1.5  , installed 0.1.5
                  Adapter    "wireguard"    : 1.4.1    , installed 1.4.1
                  Adapter    "worx"         : 2.1.3    , installed 2.1.3
                  Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                  Adapter    "zigbee"       : 1.8.10   , installed 1.8.9  [Updatable]
                    SchmakusS Offline
                    SchmakusS Offline
                    Schmakus
                    #113
                    @apollon77 Was genau darf der Adapter nicht machen?
                    Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
                    foxriver76F apollon77A 2 Antworten Letzte Antwort
                    • SchmakusS Schmakus
                      foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      #114
                      @schmakus Außerhalb seines Directories schreiben. Ist allerdings schon behoben, soweit ich das sehe (zumindest auf GitHub): https://github.com/iobroker-community-adapters/ioBroker.doorbird/commit/57d05c5689d8fb1fb152b62bc90746ac97f297b1
                        #115
                        @schmakus bzw in dem Fall ging es auch darum wie der Adapter das Verzeichnis zusammengebaut hat. Dieser Weg geht seit js-Controller 5 nicht mehr und die seid “Ewigkeiten” verfügbaren Methoden von Adapter-core sollten genutzt werden.
                          e-i-k-e
                          #116
                          @apollon77
                          Bei mir läuft auch alles fehlerfrei. Besten Dank!
                          • FeuersturmF Offline
                            FeuersturmF Offline
                            Feuersturm
                            #117
                            @apollon77 Ich habe gerade mein Testsystem auf die aktuelle Version vom js-controller 5.0.1-alpha.0-20230525-c580eb7e aktualisiert.
                            Jetzt wollte ich gerade meine Adapter aktualisieren und erhalte diese Meldung:
                            node -v && npm -v
                            v18.16.0
                            9.5.1
                            Hat dies etwas mit dem js-controller zu tun?
                            Edit: Das Problem hat sich erledigt. Ich hatte den Master aktualisiert, der Slave war aber aus. Hab den Slave wieder aktiviert und auch auf die aktuelle js-controller Version gebracht und die Fehlermeldung ist weg.
                            • MalleRalleM Offline
                              MalleRalleM Offline
                              MalleRalle
                              #118
                              @foxriver76 @apollon77 @hieblmedia
                              @foxriver76
                              Ich habe gesehen das Du den Enigma2 Adapter für den neuen js-controller 5 angepasst hast.
                              Könntest Du das auch für den alten Broadlink Adapter machen:
                              https://github.com/hieblmedia/ioBroker.broadlink
                              Ich habe den neuen js-controller 5 getestet und dieser alte Broadlink Adapter macht Probleme damit.
                              Ja, ich weiß das es den Broadlink2 Adapter gibt.
                              Der ist bei mir auch in Gebrauch.
                              Aber viele meiner Befehle arbeiten noch mit dem alten Adapter.
                              Und da ich eine Umfangreiche VIS habe, möchte ich da ungern alle Datenpunkte anpassen.
                              Es wäre schön wenn Ihr Euch das mal anschauen würdet.
                              Grüße Achim
                              foxriver76F apollon77A 3 Antworten Letzte Antwort
                              • MalleRalleM MalleRalle
                                @foxriver76
                                Grüße Achim
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #119
                                @malleralle ich habe leider keine Rechte für diesen Adapter und PRs werden seit langer Zeit nicht mehr gemerged vom einzigen maintainer.
                                H 1 Antwort Letzte Antwort
                                  @foxriver76
                                  Grüße Achim
                                  #120
                                  @malleralle du kann ja mal schauen ob du email Adressen findest ggf GitHub Oder in der package.json und den dev mal Anschreiben ob er den Adapter nicht in die Community geben möchte. Vllt kommen wir ja so einfacher ran.
                                  • foxriver76F foxriver76
                                    hieblmedia
                                    #121
                                    Habe gerade eine Email von Achim erhalten. Habe euch zwei als Collaborator in GitHub eingeladen. Dann solltet ihr normal alles notwendige machen können.
                                    Reinhard
                                    • H hieblmedia
                                      Reinhard
                                      #122
                                      @hieblmedia danke!!
                                      • H hieblmedia
                                        Reinhard
                                        #123
                                        @hieblmedia hey, sorry das ich nochmal störe. Kannst du uns bitte auch bei npm hinzufügen? Danke
                                        haselchenH H 2 Antworten Letzte Antwort
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #124
                                          @apollon77
                                          Moin @apollon77
                                          mir wird bei den Hosts die 5.0.2 angeboten.
                                          Als Changelog Hinweis kommt nur: see changelog.md
                                          Für den geneigten Anfänger könnte das ein Fragezeichen aufwerfen.
                                          Eventuell könntet ihr ja nen Link zu Github dort anführen, dass würde nachfragen verhindern.
                                          Edit:
                                          Kommt für die Version noch nen Comment hier von Dir?
