  4. Adapter LightControl 0.4.x Stable
lightlight controllightcontrolmotionmotion detection
117 Beiträge 18 Kommentatoren 25.8k Aufrufe 25 Beobachtet
  • SchmakusS Schmakus
    @fredf sagte in Adapter LightControl 0.2.x Latest:
    @m-a-hueb sagte in Adapter LightControl 0.2.x Latest:
    Wert für Standardfarbe
    Wo ist denn diese Eingabe?
    Direkt in den Einstellungen des Datenpunkts „Color“
    FredFF Online
    FredFF Online
    FredF
    Most Active Forum Testing
    @schmakus Ja schon, ich suchte diese Angabe
    Trag ich dann einfach bei "Wert für Standardfarbe
    • FredFF FredF
      @schmakus Beim update von 0.1.3 auf 0.2.12 gab es einige Fehlermeldungen:
      2023-05-05 15:48:44.992 - warn: lightcontrol.0 (12105) Object 0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch is invalid: Default value has to be type "boolean" but received type "string"
      2023-05-05 15:48:44.993 - warn: lightcontrol.0 (12105) This object will not be created in future versions. Please report this to the developer.
      2023-05-05 15:48:45.115 - warn: lightcontrol.0 (12105) Object 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch is invalid: Default value has to be type "boolean" but received type "string"
      2023-05-05 15:48:45.115 - warn: lightcontrol.0 (12105) This object will not be created in future versions. Please report this to the developer.
      2023-05-05 15:48:45.208 - warn: lightcontrol.0 (12105) Object 0_userdata.0.lightcontrol_DEV.Lamps.Lamp3.colorModeSwitch is invalid: Default value has to be type "boolean" but received type "string"
      2023-05-05 15:48:45.208 - warn: lightcontrol.0 (12105) This object will not be created in future versions. Please report this to the developer.
      2023-05-05 15:48:45.415 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.dimmUp (type=state) property native missing!
      2023-05-05 15:48:45.461 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.dimmDown (type=state) property native missing!
      2023-05-05 15:48:45.514 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.adaptiveCtMode (type=state) property native missing!
      2023-05-05 15:48:45.625 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.autoOnMotion.color (type=state) property native missing!
      2023-05-05 15:48:45.686 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.autoOnLux.color (type=state) property native missing!
      2023-05-05 15:48:45.736 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.autoOnLux.operator (type=state) property native missing!
      2023-05-05 15:48:45.790 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.autoOnPresenceIncrease.color (type=state) property native missing!
      2023-05-05 15:48:45.856 - warn: lightcontrol.0 (12105) setObject KuecheSockelbeleuchtung.blink.frequency (type=state) property native missing!
      2023-05-05 15:48:45.910 - warn: lightcontrol.0 (12105) setObject Eingangslicht.dimmUp (type=state) property native missing!
      2023-05-05 15:48:45.956 - warn: lightcontrol.0 (12105) setObject Eingangslicht.dimmDown (type=state) property native missing!
      2023-05-05 15:48:46.008 - warn: lightcontrol.0 (12105) setObject Eingangslicht.adaptiveCtMode (type=state) property native missing!
      2023-05-05 15:48:46.081 - warn: lightcontrol.0 (12105) setObject Eingangslicht.autoOnMotion.color (type=state) property native missing!
      2023-05-05 15:48:46.137 - warn: lightcontrol.0 (12105) setObject Eingangslicht.autoOnLux.color (type=state) property native missing!
      2023-05-05 15:48:46.186 - warn: lightcontrol.0 (12105) setObject Eingangslicht.autoOnLux.operator (type=state) property native missing!
      2023-05-05 15:48:46.239 - warn: lightcontrol.0 (12105) setObject Eingangslicht.autoOnPresenceIncrease.color (type=state) property native missing!
      2023-05-05 15:48:46.325 - warn: lightcontrol.0 (12105) setObject Eingangslicht.blink.frequency (type=state) property native missing!
      2023-05-05 15:48:46.566 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri)
      2023-05-05 15:48:46.613 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat)
      2023-05-05 15:48:46.657 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct)
      2023-05-05 15:48:46.704 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX)
      2023-05-05 15:48:46.753 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch)
      2023-05-05 15:48:46.754 - warn: lightcontrol.0 (12105) Object 0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch is invalid: Default value has to be type "boolean" but received type "string"
      2023-05-05 15:48:46.754 - warn: lightcontrol.0 (12105) This object will not be created in future versions. Please report this to the developer.
      2023-05-05 15:48:46.800 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power)
      2023-05-05 15:48:46.845 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri)
      2023-05-05 15:48:46.891 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat)
      2023-05-05 15:48:46.939 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct)
      2023-05-05 15:48:46.985 - warn: lightcontrol.0 (12105) [ buildStateDetailsArray ] Light group "Wohnzimmer" was deleted by the user in the instance settings! LightControl settings will be deactivated for this StateID: 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch)
      2023-05-05 15:48:46.985 - warn: lightcontrol.0 (12105) Object 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch is invalid: Default value has to be type "boolean" but received type "string"
      2023-05-05 15:48:46.986 - warn: lightcontrol.0 (12105) This object will not be created in future versions. Please report this to the developer.
      Kann ich wahrscheinlich ignorieren, oder?
      SchmakusS Offline
      SchmakusS Offline
      Schmakus
      Mit der Version v0.2.13 gefixt.
      Dev of LightControl Adapter, Contributor of HUE and DoorBird Adapter
        kukoratsch
        @schmakus Bekomme Fehlermeldung bei ein und ausschalten Gruppe Wohnzimmer
        lightcontrol.0
        	2023-05-16 10:05:35.546	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "Decke vorn" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}}
        lightcontrol.0
        	2023-05-16 10:05:35.545	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "hinten" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
        lightcontrol.0
        	2023-05-16 10:05:35.545	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "vorne" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
        SchmakusS 1 Antwort Letzte Antwort
        • K kukoratsch
          lightcontrol.0
          lightcontrol.0
          lightcontrol.0
          SchmakusS Offline
          SchmakusS Offline
          Schmakus
          @kukoratsch sagte in Adapter LightControl 0.2.x Latest:
          lightcontrol.0
          lightcontrol.0
          lightcontrol.0
          Ja es ist auch power oder brightness state definiert. so kann kein Licht geschaltet werden. ;-)
            lightcontrol.0
            lightcontrol.0
            lightcontrol.0
            kukoratsch
            schrieb am zuletzt editiert von kukoratsch
            #66
            @schmakus Ja
            • K kukoratsch
              @schmakus Ja
              SchmakusS Offline
              SchmakusS Offline
              Schmakus
              schrieb am zuletzt editiert von Schmakus
              #67
              @kukoratsch Und gehts nun? Ansonsten stell das Loglevel des Adapters auf "Debug" und poste das logging.
              Was ich noch sehe: einmal heißt es "Decke vorne" und einmal "Decke vorn"....
                kukoratsch
                #68
                lightcontrol.0
                	2023-05-16 11:11:59.707	debug	[ AdaptiveCt ] adaptiveCtLinear="5429" adaptiveCtSolar="5895"
                lightcontrol.0
                	2023-05-16 11:11:59.707	debug	[ AdaptiveCt ] minCT="2700", maxCt="6500", sunset="1684264539905", sunrise="1684208029297", solarNoon="1684236284601"
                lightcontrol.0
                	2023-05-16 11:11:59.707	debug	[ AdaptiveCt // getAstroDate] sunsetDate="Tue May 16 2023 21:15:39 GMT+0200 (Mitteleuropäische Sommerzeit)", sunriseDate="Tue May 16 2023 05:33:49 GMT+0200 (Mitteleuropäische Sommerzeit)", solarNoonDate="Tue May 16 2023 13:24:44 GMT+0200 (Mitteleuropäische Sommerzeit)"
                lightcontrol.0
                	2023-05-16 11:11:59.707	debug	[ getAstroDate ] getAstroDate(pattern=solarNoon, date=Tue May 16 2023 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Tue May 16 2023 13:24:44 GMT+0200 (Mitteleuropäische Sommerzeit)
                lightcontrol.0
                	2023-05-16 11:11:59.706	debug	[ getAstroDate ] getAstroDate(pattern=sunrise, date=Tue May 16 2023 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Tue May 16 2023 05:33:49 GMT+0200 (Mitteleuropäische Sommerzeit)
                lightcontrol.0
                	2023-05-16 11:11:59.706	debug	[ getAstroDate ] getAstroDate(pattern=sunset, date=Tue May 16 2023 12:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)) => Tue May 16 2023 21:15:39 GMT+0200 (Mitteleuropäische Sommerzeit)
                lightcontrol.0
                	2023-05-16 11:11:59.706	debug	[ AdaptiveCt ] minCT="2700", maxCt="6500", CtRange="3800"
                lightcontrol.0
                	2023-05-16 11:11:30.905	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.ct changed: 3300 (ack = true)
                lightcontrol.0
                	2023-05-16 11:11:30.812	debug	Reaching SetCt, Group="Wohnzimmer" Ct="3300"
                lightcontrol.0
                	2023-05-16 11:11:30.812	info	[ SetColorMode ] Device="0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch" Val="false
                lightcontrol.0
                	2023-05-16 11:11:30.809	info	[ SetColorMode ] Device="0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch" Val="false
                lightcontrol.0
                	2023-05-16 11:11:30.802	info	[ SetColorMode ] Device="milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode" Val="false
                lightcontrol.0
                	2023-05-16 11:11:30.796	info	[ SetColorMode ] Device="milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode" Val="false
                lightcontrol.0
                	2023-05-16 11:11:30.747	info	[ SetColorMode ] Reaching for Group="Wohnzimmer"
                lightcontrol.0
                	2023-05-16 11:11:30.747	info	[ WhiteSubstituteColor ] Reaching for Group="Wohnzimmer" = "Wohnzimmer" LightGroups[Group].power="true" LightGroups[Group].color="#FFFFFF
                lightcontrol.0
                	2023-05-16 11:11:30.747	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.color changed: #FFFFFF (ack = true)
                lightcontrol.0
                	2023-05-16 11:11:30.717	info	[ SetColor ] Reaching for Group="Wohnzimmer" power="true" Color="#FFFFFF"
                lightcontrol.0
                	2023-05-16 11:11:30.717	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.bri changed: 0 (ack = true)
                lightcontrol.0
                	2023-05-16 11:11:30.622	debug	[ setDeviceBri ] Switching with Power State is activated. Min. Brightness is defined with 2%. Actual Brightness = "0"
                lightcontrol.0
                	2023-05-16 11:11:30.621	debug	[ setDeviceBri ] Switching with Brightness is activated. No min. Brightness needed. Actual Brightness = "0"
                lightcontrol.0
                	2023-05-16 11:11:30.621	debug	[ setDeviceBri ] Switching with Power State is activated. Min. Brightness is defined with 2%. Actual Brightness = "0"
                lightcontrol.0
                lightcontrol.0
                	2023-05-16 11:11:30.621	debug	[ SetBrightness ] Reaching for Group="Wohnzimmer", Brightness="0, PowerState="true"
                lightcontrol.0
                	2023-05-16 11:11:30.620	info	[ PowerOnAfterCare ] Now setting bri to 0% for Group="Wohnzimmer"
                lightcontrol.0
                	2023-05-16 11:11:30.620	info	[ PowerOnAfterCare ] Reaching for Group="Wohnzimmer" bri="0" ct="3300" color="#FFFFFF"
                lightcontrol.0
                	2023-05-16 11:11:30.620	debug	[ SetLightState ] Set State "All.anyOn" to true from function="GroupPowerOnOff"
                lightcontrol.0
                	2023-05-16 11:11:30.619	debug	[ onStateChange ] state lightcontrol.0.All.power changed: true (ack = true)
                lightcontrol.0
                	2023-05-16 11:11:30.615	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: true (ack = true)
                lightcontrol.0
                	2023-05-16 11:11:30.605	info	[ SimpleGroupPowerOnOff ] Simple power on without ramping for Group="Wohnzimmer"
                lightcontrol.0
                	2023-05-16 11:11:30.502	debug	[ SimpleGroupPowerOnOff ] Switching on Decke (0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power) with power state
                lightcontrol.0
                	2023-05-16 11:11:30.502	debug	[ SimpleGroupPowerOnOff ] Switching on Spot (0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri) with brightness state
                lightcontrol.0
                	2023-05-16 11:11:30.501	debug	[ setDeviceBri ] Switching with Brightness is activated. No min. Brightness needed. Actual Brightness = "0"
                lightcontrol.0
                	2023-05-16 11:11:30.501	warn	[ SimpleGroupPowerOnOff ] Can't switching on for Light = "Decke vorn" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}}
                lightcontrol.0
                	2023-05-16 11:11:30.501	debug	[ SimpleGroupPowerOnOff ] Switching on Decke vorne (alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne) with power state
                lightcontrol.0
                	2023-05-16 11:11:30.501	debug	[ SimpleGroupPowerOnOff ] Switching on Decke hinten (alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten) with power state
                lightcontrol.0
                	2023-05-16 11:11:30.501	warn	[ SimpleGroupPowerOnOff ] Can't switching on for Light = "hinten" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
                lightcontrol.0
                	2023-05-16 11:11:30.501	warn	[ SimpleGroupPowerOnOff ] Can't switching on for Light = "vorne" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
                lightcontrol.0
                	2023-05-16 11:11:30.500	debug	[ GroupPowerOnOff ] Reaching for Group="Wohnzimmer", OnOff="true" rampOn="false" - {"enabled":false,"time":10,"switchOutletsLast":true} rampOff="false" - {"enabled":false,"time":10,"switchOutletsLast":false}
                lightcontrol.0
                	2023-05-16 11:11:30.500	info	[ Controller ] Reaching, Group="Wohnzimmer" Property="power" NewVal="true", OldVal=false"
                lightcontrol.0
                	2023-05-16 11:11:30.500	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: true (ack = false)
                lightcontrol.0
                	2023-05-16 11:11:26.485	debug	[ SetLightState ] Set State "All.anyOn" to false from function="GroupPowerOnOff"
                lightcontrol.0
                	2023-05-16 11:11:26.441	debug	[ onStateChange ] state lightcontrol.0.All.power changed: false (ack = true)
                lightcontrol.0
                	2023-05-16 11:11:26.439	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: false (ack = true)
                lightcontrol.0
                	2023-05-16 11:11:26.432	info	[ SimpleGroupPowerOnOff ] Simple power off without ramping for Group="Wohnzimmer"
                lightcontrol.0
                	2023-05-16 11:11:26.325	debug	[ SimpleGroupPowerOnOff ] Switching off Decke (0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power) with power state
                lightcontrol.0
                	2023-05-16 11:11:26.324	debug	[ SimpleGroupPowerOnOff ] Switching off Spot (0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri) with brightness state
                lightcontrol.0
                	2023-05-16 11:11:26.324	debug	[ setDeviceBri ] Switching with Brightness is activated. No min. Brightness needed. Actual Brightness = "0"
                lightcontrol.0
                	2023-05-16 11:11:26.324	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "Decke vorn" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}}
                lightcontrol.0
                	2023-05-16 11:11:26.324	debug	[ SimpleGroupPowerOnOff ] Switching off Decke vorne (alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne) with power state
                lightcontrol.0
                	2023-05-16 11:11:26.324	debug	[ SimpleGroupPowerOnOff ] Switching off Decke hinten (alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten) with power state
                lightcontrol.0
                	2023-05-16 11:11:26.323	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "hinten" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
                lightcontrol.0
                	2023-05-16 11:11:26.323	warn	[ SimpleGroupPowerOnOff ] Can't switching off for Light = "vorne" in Group = "Wohnzimmer". No power or brightness state defined. Light: {"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}
                lightcontrol.0
                	2023-05-16 11:11:26.323	debug	[ GroupPowerOnOff ] Reaching for Group="Wohnzimmer", OnOff="false" rampOn="false" - {"enabled":false,"time":10,"switchOutletsLast":true} rampOff="false" - {"enabled":false,"time":10,"switchOutletsLast":false}
                lightcontrol.0
                	2023-05-16 11:11:26.322	info	[ Controller ] Reaching, Group="Wohnzimmer" Property="power" NewVal="false", OldVal=true"
                lightcontrol.0
                	2023-05-16 11:11:26.322	debug	[ onStateChange ] state lightcontrol.0.Wohnzimmer.power changed: false (ack = false)
                lightcontrol.0
                	2023-05-16 11:10:59.917	debug	[ SetLightState ] Set State "All.anyOn" to true from function="noFunction"
                lightcontrol.0
                	2023-05-16 11:10:59.874	debug	[ onStateChange ] state lightcontrol.0.All.power changed: true (ack = true)
                lightcontrol.0
                	2023-05-16 11:10:59.825	info	Successfully activated LightControl for 22 of 22 states, will do my Job until you stop me!
                lightcontrol.0
                	2023-05-16 11:10:59.825	debug	[ InitCustomStates ] subscribed all foreign objects to detect (de)activation of LightControl enabled states
                lightcontrol.0
                	2023-05-16 11:10:59.823	info	Initialization of 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch successfully
                lightcontrol.0
                	2023-05-16 11:10:59.823	debug	[ buildStateDetailsArray ] completed for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch.
                lightcontrol.0
                	2023-05-16 11:10:59.822	debug	[ buildStateDetailsArray ] Type: Light, in Group: Wohnzimmer with Lights: [{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}] and Light: {"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}} with Index: 6
                lightcontrol.0
                	2023-05-16 11:10:59.823	debug	[ buildStateDetailsArray ] Updated LightGroups: {"Wohnzimmer":{"description":"Wohnzimmer","LuxSensor":"","lights":[{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}}],"sensors":[],"actualLux":0,"powerNewVal":true,"power":true,"dimmUp":false,"dimmDown":false,"dimmAmount":10,"bri":0,"ct":3300,"color":"#FFFFFF","adaptiveBri":false,"adaptiveCt":false,"adaptiveCtMode":"solar","adaptiveCtTime":"06:00","powerCleaningLight":false,"isMotion":false,"autoOffTimed":{"enabled":false,"autoOffTime":120,"noAutoOffWhenMotion":true,"noticeEnabled":false,"noticeBri":10,"noticeTime":10},"autoOffLux":{"enabled":false,"minLux":500,"dailyLock":false,"operator":">","dailyLockCounter":0},"autoOnMotion":{"enabled":false,"minLux":300,"bri":0,"color":"#FFFFFF"},"autoOnLux":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF","switchOnlyWhenPresence":true,"switchOnlyWhenNoPresence":false,"dailyLock":false,"operator":"<","dailyLockCounter":0},"autoOnPresenceIncrease":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF"},"rampOn":{"enabled":false,"time":10,"switchOutletsLast":true},"rampOff":{"enabled":false,"time":10,"switchOutletsLast":false},"blink":{"enabled":false,"start":false,"frequency":1,"blinks":3,"bri":100,"color":"#FF0000"}},"All":{"powerNewVal":true,"power":true,"anyOn":true}}
                lightcontrol.0
                	2023-05-16 11:10:59.822	debug	[ buildLightGroupParameter ] customData {"enabled":true,"CtReverse":false,"defaultBri":"100","whiteModeVal":"false","colorModeVal":"true","colorType":"hex","defaultColor":"#FFFFFF","sendCt":true,"sendSat":true,"sendColor":true,"sendModeswitch":true,"useBri":true,"type":"light","func":"modeswitch","onVal":1,"offVal":0,"minVal":0,"maxVal":100,"motionVal":"On","noMotionVal":"Off","group":"Wohnzimmer","description":"Decke"}
                lightcontrol.0
                	2023-05-16 11:10:59.820	debug	[ buildStateDetailsArray ] started for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch
                lightcontrol.0
                	2023-05-16 11:10:59.820	info	Initialization of 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct successfully
                lightcontrol.0
                	2023-05-16 11:10:59.820	debug	[ buildStateDetailsArray ] Updated LightGroups: {"Wohnzimmer":{"description":"Wohnzimmer","LuxSensor":"","lights":[{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true}}],"sensors":[],"actualLux":0,"powerNewVal":true,"power":true,"dimmUp":false,"dimmDown":false,"dimmAmount":10,"bri":0,"ct":3300,"color":"#FFFFFF","adaptiveBri":false,"adaptiveCt":false,"adaptiveCtMode":"solar","adaptiveCtTime":"06:00","powerCleaningLight":false,"isMotion":false,"autoOffTimed":{"enabled":false,"autoOffTime":120,"noAutoOffWhenMotion":true,"noticeEnabled":false,"noticeBri":10,"noticeTime":10},"autoOffLux":{"enabled":false,"minLux":500,"dailyLock":false,"operator":">","dailyLockCounter":0},"autoOnMotion":{"enabled":false,"minLux":300,"bri":0,"color":"#FFFFFF"},"autoOnLux":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF","switchOnlyWhenPresence":true,"switchOnlyWhenNoPresence":false,"dailyLock":false,"operator":"<","dailyLockCounter":0},"autoOnPresenceIncrease":{"enabled":false,"minLux":50,"bri":0,"color":"#FFFFFF"},"rampOn":{"enabled":false,"time":10,"switchOutletsLast":true},"rampOff":{"enabled":false,"time":10,"switchOutletsLast":false},"blink":{"enabled":false,"start":false,"frequency":1,"blinks":3,"bri":100,"color":"#FF0000"}},"All":{"powerNewVal":true,"power":true,"anyOn":true}}
                lightcontrol.0
                	2023-05-16 11:10:59.819	debug	[ buildStateDetailsArray ] Type: Light, in Group: Wohnzimmer with Lights: [{"description":"vorne","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"hinten","modeswitch":{"oid":"milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke hinten","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_brightness_hinten","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_hinten","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorne","bri":{"oid":"alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne","minVal":0,"maxVal":100,"defaultBri":100,"useBri":false},"sat":{"oid":"alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne","minVal":0,"maxVal":100,"sendCt":true},"power":{"oid":"alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne","onVal":true,"offVal":false},"ct":{"oid":"alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne","minVal":0,"maxVal":100,"sendCt":true}},{"description":"Decke vorn","color":{"oid":"alias.0.Wohnzimmer.Licht.Decke_RGB_vorne","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true}},{"description":"Spot","bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri","minVal":0,"maxVal":100,"defaultBri":100,"useBri":true},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct","minVal":0,"maxVal":100,"sendCt":true},"color":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX","colorType":"hex","defaultColor":"#FFFFFF","sendColor":true},"modeswitch":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch","whiteModeVal":false,"colorModeVal":true,"sendModeswitch":true}},{"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true}}] and Light: {"description":"Decke","power":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power","onVal":true,"offVal":false},"bri":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri","minVal":0,"maxVal":254,"defaultBri":254,"useBri":false},"sat":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat","minVal":0,"maxVal":100,"sendCt":true},"ct":{"oid":"0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct","minVal":2700,"maxVal":6500,"sendCt":true}} with Index: 6
                lightcontrol.0
                	2023-05-16 11:10:59.820	debug	[ InitCustomStates ] Initialising (22 of 22) "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch"
                lightcontrol.0
                	2023-05-16 11:10:59.819	debug	[ buildLightGroupParameter ] customData {"enabled":true,"CtReverse":false,"defaultBri":"100","whiteModeVal":"false","colorModeVal":"true","colorType":"hex","defaultColor":"#FFFFFF","sendCt":true,"sendSat":true,"sendColor":true,"sendModeswitch":true,"useBri":true,"type":"light","func":"ct","onVal":1,"offVal":0,"minVal":2700,"maxVal":6500,"motionVal":"On","noMotionVal":"Off","group":"Wohnzimmer","description":"Decke"}
                lightcontrol.0
                	2023-05-16 11:10:59.819	debug	[ buildStateDetailsArray ] completed for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct.
                lightcontrol.0
                	2023-05-16 11:10:59.817	debug	[ buildStateDetailsArray ] started for 0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct
                lightcontrol.0
                	2023-05-16 11:10:59.817	debug	[ InitCustomStates ] Initialising (21 of 22) "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct"
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                lightcontrol.0
                • K kukoratsch
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  lightcontrol.0
                  SchmakusS Offline
                  SchmakusS Offline
                  Schmakus
                  #69
                  @kukoratsch Das ist nicht das gesamte logging. bitte Adapter einmal neustarten. Welche Version ist installiert? bitte Namen der Lichter prüfen.
                  K 2 Antworten Letzte Antwort
                    kukoratsch
                    #70
                    @schmakus Verision 1.2.16 Log ist zu gross
                    neu 2.txt
                      kukoratsch
                      #71
                      @schmakus sagte in Adapter LightControl 0.2.x Latest:
                      @kukoratsch bitte Namen der Lichter prüfen.
                      Das wahr mein Fehler. Danke
                      • K kukoratsch
                        neu 2.txt
                        SchmakusS Offline
                        SchmakusS Offline
                        Schmakus
                        #72
                        neu 2.txt
                        Also:
                        Lampe "vorne" hat keinen power oder state Datenpunkt
                        Lampe "hinten" hat keinen power oder state Datenpunkt
                        Lampe "Decke vorne" hat keinen power oder state Datenpunkt
                        Und bitte lösche den ganzen Baum 0_userdata.0.lightcontrol_DEV.Lamps. Aufgrund eines Fehlers meinerseits hat es Datenpunkte bei dir angelegt, wo keine sein dürften. ;-)
                        Und zu guter Letzt: Bitte künftig bei den Logs auf LightControl filtern. Sonst suche ich mir einen Hirsch, wenn noch Logs von SourceAnalytix usw. dabei sind.
                        	"Wohnzimmer": {
                        		"description": "Wohnzimmer",
                        		"LuxSensor": "",
                        		"lights": [{
                        			"description": "vorne",
                        			"modeswitch": {
                        				"oid": "milight-smart-light.0.Wohnzimmer_vorne.fullColor8Zone-1.whiteMode",
                        				"whiteModeVal": false,
                        				"colorModeVal": true,
                        				"sendModeswitch": true
                        			"description": "hinten",
                        			"modeswitch": {
                        				"oid": "milight-smart-light.0.Wohnzimmer_hinten.fullColor8Zone-2.whiteMode",
                        			"description": "Decke hinten",
                        			"bri": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Decke_brightness_hinten",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"defaultBri": 100,
                        				"useBri": false
                        			"color": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Decke_RGB_hinten",
                        				"colorType": "hex",
                        				"defaultColor": "#FFFFFF",
                        				"sendColor": true
                        			"sat": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Decke_Saturation_hinten",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"sendCt": true
                        			"power": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Deckenschalter_onoff_hinten",
                        				"onVal": true,
                        				"offVal": false
                        			"ct": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_hinten",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"sendCt": true
                        			"description": "Decke vorne",
                        			"bri": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Decke_Brightness_vorne",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"defaultBri": 100,
                        				"useBri": false
                        			"sat": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Deche_Saturation_vorne",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"sendCt": true
                        			"power": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Deckeschalter_onoff_vorne",
                        				"onVal": true,
                        				"offVal": false
                        			"ct": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Decke_whiteTemperature_vorne",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"sendCt": true
                        			"description": "Decke vorn",
                        			"color": {
                        				"oid": "alias.0.Wohnzimmer.Licht.Decke_RGB_vorne",
                        				"colorType": "hex",
                        				"sendColor": true
                        			"description": "Spot",
                        			"bri": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.bri",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"defaultBri": 100,
                        				"useBri": true
                        			"sat": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.sat",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"sendCt": true
                        			"ct": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.ct",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"sendCt": true
                        			"color": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorHEX",
                        				"colorType": "hex",
                        				"sendColor": true
                        			"modeswitch": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp1.colorModeSwitch",
                        			"description": "Decke",
                        			"power": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.power",
                        				"onVal": true,
                        				"offVal": false
                        			"bri": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.bri",
                        				"minVal": 0,
                        				"maxVal": 254,
                        				"defaultBri": 254,
                        				"useBri": false
                        			"sat": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.sat",
                        				"minVal": 0,
                        				"maxVal": 100,
                        				"sendCt": true
                        			"ct": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.ct",
                        				"minVal": 2700,
                        				"maxVal": 6500,
                        				"sendCt": true
                        			"modeswitch": {
                        				"oid": "0_userdata.0.lightcontrol_DEV.Lamps.Lamp2.colorModeSwitch",
                        		"sensors": [],
                        		"actualLux": 0,
                        		"powerNewVal": false,
                        		"power": false,
                        		"dimmUp": false,
                        		"dimmDown": false,
                        		"dimmAmount": 10,
                        		"bri": 100,
                        		"ct": 3300,
                        		"color": "#FFFFFF",
                        		"adaptiveBri": false,
                        		"adaptiveCt": false,
                        		"adaptiveCtMode": "solar",
                        		"adaptiveCtTime": "06:00",
                        		"powerCleaningLight": false,
                        		"isMotion": false,
                        		"autoOffTimed": {
                        			"enabled": false,
                        			"autoOffTime": 120,
                        			"noAutoOffWhenMotion": true,
                        			"noticeEnabled": false,
                        			"noticeBri": 10,
                        			"noticeTime": 10
                        		"autoOffLux": {
                        			"enabled": false,
                        			"minLux": 500,
                        			"dailyLock": false,
                        			"operator": ">",
                        			"dailyLockCounter": 0
                        		"autoOnMotion": {
                        			"enabled": false,
                        			"minLux": 300,
                        			"bri": 0,
                        			"color": "#FFFFFF"
                        		"autoOnLux": {
                        			"enabled": false,
                        			"minLux": 50,
                        			"bri": 0,
                        			"color": "#FFFFFF",
                        			"switchOnlyWhenPresence": true,
                        			"switchOnlyWhenNoPresence": false,
                        			"dailyLock": false,
                        			"operator": "<",
                        		"autoOnPresenceIncrease": {
                        			"enabled": false,
                        			"minLux": 50,
                        			"bri": 0,
                        			"color": "#FFFFFF"
                        		"rampOn": {
                        			"enabled": false,
                        			"time": 10,
                        			"switchOutletsLast": true
                        		"rampOff": {
                        			"enabled": false,
                        			"time": 10,
                        			"switchOutletsLast": false
                        		"blink": {
                        			"enabled": false,
                        			"start": false,
                        			"frequency": 1,
                        			"blinks": 3,
                        			"bri": 100,
                        			"color": "#FF0000"
                        	"All": {
                        		"powerNewVal": true,
                        		"power": true,
                        		"anyOn": true
                          neu 2.txt
                          Also:
                          	"Wohnzimmer": {
                          		"LuxSensor": "",
                          		"lights": [{
                          			"modeswitch": {
                          			"modeswitch": {
                          			"bri": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"defaultBri": 100,
                          				"useBri": false
                          			"color": {
                          				"colorType": "hex",
                          				"sendColor": true
                          			"sat": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"sendCt": true
                          			"power": {
                          				"onVal": true,
                          				"offVal": false
                          			"ct": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"sendCt": true
                          			"bri": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"defaultBri": 100,
                          				"useBri": false
                          			"sat": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"sendCt": true
                          			"power": {
                          				"onVal": true,
                          				"offVal": false
                          			"ct": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"sendCt": true
                          			"color": {
                          				"colorType": "hex",
                          				"sendColor": true
                          			"bri": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"defaultBri": 100,
                          				"useBri": true
                          			"sat": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"sendCt": true
                          			"ct": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"sendCt": true
                          			"color": {
                          				"colorType": "hex",
                          				"sendColor": true
                          			"modeswitch": {
                          			"power": {
                          				"onVal": true,
                          				"offVal": false
                          			"bri": {
                          				"minVal": 0,
                          				"maxVal": 254,
                          				"defaultBri": 254,
                          				"useBri": false
                          			"sat": {
                          				"minVal": 0,
                          				"maxVal": 100,
                          				"sendCt": true
                          			"ct": {
                          				"minVal": 2700,
                          				"maxVal": 6500,
                          				"sendCt": true
                          			"modeswitch": {
                          		"sensors": [],
                          		"actualLux": 0,
                          		"power": false,
                          		"dimmUp": false,
                          		"dimmDown": false,
                          		"dimmAmount": 10,
                          		"bri": 100,
                          		"ct": 3300,
                          		"color": "#FFFFFF",
                          		"isMotion": false,
                          		"autoOffTimed": {
                          			"enabled": false,
                          			"autoOffTime": 120,
                          			"noticeBri": 10,
                          			"noticeTime": 10
                          		"autoOffLux": {
                          			"enabled": false,
                          			"minLux": 500,
                          			"dailyLock": false,
                          			"operator": ">",
                          		"autoOnMotion": {
                          			"enabled": false,
                          			"minLux": 300,
                          			"bri": 0,
                          			"color": "#FFFFFF"
                          		"autoOnLux": {
                          			"enabled": false,
                          			"minLux": 50,
                          			"bri": 0,
                          			"color": "#FFFFFF",
                          			"dailyLock": false,
                          			"operator": "<",
                          			"enabled": false,
                          			"minLux": 50,
                          			"bri": 0,
                          			"color": "#FFFFFF"
                          		"rampOn": {
                          			"enabled": false,
                          			"time": 10,
                          		"rampOff": {
                          			"enabled": false,
                          			"time": 10,
                          		"blink": {
                          			"enabled": false,
                          			"start": false,
                          			"frequency": 1,
                          			"blinks": 3,
                          			"bri": 100,
                          			"color": "#FF0000"
                          	"All": {
                          		"power": true,
                          		"anyOn": true
                          kukoratsch
                          #73
                          @schmakus Dankeschön jetzt läuft alles.
                          • K kukoratsch
                            SchmakusS Offline
                            SchmakusS Offline
                            Schmakus
                            #74
                            👍 Perfekt. Wenn noch was sein sollte, einfach hier melden oder auf Github ein Issue aufmachen.
                            Aktuell bin ich dran, die erste Stable zu veröffentlichen.
                            • M-A HuebM Offline
                              M-A HuebM Offline
                              M-A Hueb
                              #75
                              Hat jemand diesen Adapter schon erfolgreich mit dem Shelly RGBW2 im Einsatz? Ich verwende den mit einem RGBWW-LED Streifen und würde gerne das im Tagesverlauf anpassende Licht verwenden.
                              iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                              ? SchmakusS 2 Antworten Letzte Antwort
                              • M-A HuebM M-A Hueb
                                #76
                                @m-a-hueb
                                ich hab 2 Instanzen, eine testet die Beleuchtung im Buero-Bad, das funktioniert von Anfang an sehr gut.
                                Leuchte ist ne Zigbee, die Helligkeitsregelung klappt.
                                Die andere Instanz ist fuer die Muellanzeige, steuert diverse Yeelight's mit verschiedenen Farben und blinkt, wenn die Tonne noch nicht draussen steht.
                                Ist die Tonne draussen, schalte ich in der Vis das Blinken aus. Spart mir hier einige Scripte und funktioniert seit langen auch sehr gut!
                                  @m-a-hueb
                                  SchmakusS Offline
                                  SchmakusS Offline
                                  Schmakus
                                  #77
                                  @ilovegym sagte in Adapter LightControl 0.2.x Latest:
                                  @m-a-hueb
                                  Danke fürs Feedback, jedoch wieso 2 Instanzen? Weil du keine Lampe in mehreren Gruppen zuweisen kannst? Wenn ja, das ist eigentlich vorgesehen, jedoch gibt es seitens jsonCustom noch einen Bug, den ich aber selbst nicht beheben kann.
                                    SchmakusS Offline
                                    SchmakusS Offline
                                    Schmakus
                                    #78
                                    Shelly RGBW ist noch so ein Thema und ne offene Baustelle.... weil hier müsste auf den 8-stelligen HEX Code umgerechnet werden.
                                    • M-A HuebM Offline
                                      M-A HuebM Offline
                                      M-A Hueb
                                      #79
                                      @schmakus wäre es nicht leichter Hue einzubinden?
                                      das kann der RGBW2 ja auch
                                        SchmakusS Offline
                                        SchmakusS Offline
                                        Schmakus
                                        #80
                                        @m-a-hueb sagte in Adapter LightControl 0.2.x Stable:
                                        Prinzipiell würde es keine Rolle spielen. Aktuell arbeitet AdaptiveCt ausschließlich mit der Farbtemperatur einer Lampe. Hier müsste man eventuell die Möglichkeit hinzufügen, die über die Farbe zu regeln. Kannst du hierzu ein Issue auf Github einstellen? Danke
                                          @m-a-hueb
                                          #81
                                          @schmakus
                                          Hi, genau, ich möchte meine yeelights einmal in der Müllgruppe steuern und einmal mit dem Adapter in der Gruppe Wohnzimmer.. von daher hab ich nicht lange rumprobiert und einfach ne zweite Instanz angelegt.
