  4. ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert
esphomepythonwemos d1 miniplatformio
29 Beiträge 3 Kommentatoren 3.9k Aufrufe 2 Beobachtet
    mayokleckz
    flo@raspberrypi:~ $ ls -la /opt/iobroker/node_modules/nopy/src/
    ls: cannot access '/opt/iobroker/node_modules/nopy/src/': No such file or directory
    flo@raspberrypi:~ $
    • M mayokleckz
      flo@raspberrypi:~ $
      @mayokleckz
      cd /opt/iobroker
      npm i nopy
      sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
      Danach sollte es mit der Installation funktionieren.
        @mayokleckz
        cd /opt/iobroker
        npm i nopy
        mayokleckz
        @thomas-braun said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
        sudo -u iobroker chmod a+x /opt/iobroker/node_modules/nopy/src/n*
        Mit den Rechten kommt man ein Stück weiter. Jedoch rennt das System in den nächsten Fehler.
        Ist da bei meiner Installation gestern was schief gegangen? Mit so viel Problemen installiert sich ja sonst niemand einen Adapter.
        Würd mich freuen wenn du auch hier nochmal drüber schaust.
        Hier das Logfile /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@9.5.1
        2 info using node@v18.16.0
        3 timing npm:load:whichnode Completed in 24ms
        4 timing config:load:defaults Completed in 17ms
        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 24ms
        6 timing config:load:builtin Completed in 24ms
        7 timing config:load:cli Completed in 11ms
        8 timing config:load:env Completed in 1ms
        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 8ms
        10 timing config:load:project Completed in 12ms
        11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
        12 timing config:load:user Completed in 1ms
        13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
        14 timing config:load:global Completed in 1ms
        15 timing config:load:setEnvs Completed in 6ms
        16 timing config:load Completed in 77ms
        17 timing npm:load:configload Completed in 77ms
        18 timing npm:load:mkdirpcache Completed in 1ms
        19 timing npm:load:mkdirplogs Completed in 1ms
        20 verbose title npm install iobroker.esphome@0.2.4
        21 verbose argv "install" "--save-exact" "iobroker.esphome@0.2.4"
        22 timing npm:load:setTitle Completed in 5ms
        23 timing config:load:flatten Completed in 13ms
        24 timing npm:load:display Completed in 17ms
        25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-
        26 verbose logfile /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
        27 timing npm:load:logFile Completed in 20ms
        28 timing npm:load:timers Completed in 0ms
        29 timing npm:load:configScope Completed in 0ms
        30 timing npm:load Completed in 151ms
        31 timing arborist:ctor Completed in 3ms
        32 silly logfile start cleaning logs, removing 2 files
        33 silly logfile done cleaning log files
        34 timing idealTree:init Completed in 4111ms
        35 timing idealTree:userRequests Completed in 30ms
        36 silly idealTree buildDeps
        37 silly fetch manifest iobroker.esphome@0.2.4
        38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
        39 http fetch GET 200 https://registry.npmjs.org/iobroker.esphome 181ms (cache hit)
        40 silly placeDep ROOT iobroker.esphome@0.2.4 OK for: iobroker.inst@3.0.0 want: 0.2.4
        41 silly fetch manifest @sentry/node@^5.30.0
        42 silly fetch manifest esphome-native-api@^1.0.9
        43 silly fetch manifest tree-kill@^1.2.2
        44 http fetch GET 200 https://registry.npmjs.org/esphome-native-api 3381ms (cache hit)
        45 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 3396ms (cache hit)
        46 http fetch GET 200 https://registry.npmjs.org/tree-kill 3453ms (cache hit)
        47 timing idealTree:#root Completed in 3683ms
        48 silly placeDep node_modules/iobroker.esphome @sentry/node@5.30.0 OK for: iobroker.esphome@0.2.4 want: ^5.30.0
        49 silly placeDep ROOT esphome-native-api@1.0.9 OK for: iobroker.esphome@0.2.4 want: ^1.0.9
        50 silly placeDep ROOT tree-kill@1.2.2 OK for: iobroker.esphome@0.2.4 want: ^1.2.2
        51 silly fetch manifest @sentry/core@5.30.0
        52 silly fetch manifest @sentry/hub@5.30.0
        53 silly fetch manifest @sentry/types@5.30.0
        54 silly fetch manifest @sentry/utils@5.30.0
        55 silly fetch manifest eslint@^7.13.0
        56 silly fetch manifest events@^3.2.0
        57 silly fetch manifest google-protobuf@^3.14.0
        58 silly fetch manifest multicast-dns@^7.2.2
        59 silly fetch manifest net@^1.0.2
        60 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 963ms (cache hit)
        61 http fetch GET 200 https://registry.npmjs.org/events 976ms (cache hit)
        62 http fetch GET 200 https://registry.npmjs.org/multicast-dns 986ms (cache hit)
        63 http fetch GET 200 https://registry.npmjs.org/@sentry%2fhub 1010ms (cache hit)
        64 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 1037ms (cache hit)
        65 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 1067ms (cache hit)
        66 http fetch GET 200 https://registry.npmjs.org/google-protobuf 1072ms (cache hit)
        67 http fetch GET 200 https://registry.npmjs.org/net 1075ms (cache hit)
        68 http fetch GET 200 https://registry.npmjs.org/eslint 1093ms (cache hit)
        69 timing idealTree:node_modules/iobroker.esphome Completed in 1226ms
        70 silly placeDep ROOT eslint@7.32.0 OK for: esphome-native-api@1.0.9 want: ^7.13.0
        71 silly placeDep ROOT events@3.3.0 OK for: esphome-native-api@1.0.9 want: ^3.2.0
        72 silly placeDep ROOT google-protobuf@3.21.2 OK for: esphome-native-api@1.0.9 want: ^3.14.0
        73 silly placeDep ROOT multicast-dns@7.2.5 OK for: esphome-native-api@1.0.9 want: ^7.2.2
        74 silly placeDep ROOT net@1.0.2 OK for: esphome-native-api@1.0.9 want: ^1.0.2
        75 silly fetch manifest @babel/code-frame@7.12.11
        76 silly fetch manifest @eslint/eslintrc@^0.4.3
        77 silly fetch manifest @humanwhocodes/config-array@^0.5.0
        78 silly fetch manifest debug@^4.0.1
        79 silly fetch manifest doctrine@^3.0.0
        80 silly fetch manifest enquirer@^2.3.5
        81 silly fetch manifest eslint-scope@^5.1.1
        82 silly fetch manifest eslint-utils@^2.1.0
        83 silly fetch manifest eslint-visitor-keys@^2.0.0
        84 silly fetch manifest espree@^7.3.1
        85 silly fetch manifest esquery@^1.4.0
        86 silly fetch manifest esutils@^2.0.2
        87 silly fetch manifest file-entry-cache@^6.0.1
        88 silly fetch manifest functional-red-black-tree@^1.0.1
        89 silly fetch manifest globals@^13.6.0
        90 silly fetch manifest ignore@^4.0.6
        91 silly fetch manifest js-yaml@^3.13.1
        92 silly fetch manifest json-stable-stringify-without-jsonify@^1.0.1
        93 silly fetch manifest levn@^0.4.1
        94 silly fetch manifest lodash.merge@^4.6.2
        95 silly fetch manifest minimatch@^3.0.4
        96 silly fetch manifest natural-compare@^1.4.0
        97 silly fetch manifest optionator@^0.9.1
        98 silly fetch manifest progress@^2.0.0
        99 silly fetch manifest regexpp@^3.1.0
        100 silly fetch manifest strip-json-comments@^3.1.0
        101 silly fetch manifest table@^6.0.9
        102 silly fetch manifest text-table@^0.2.0
        103 silly fetch manifest v8-compile-cache@^2.0.3
        104 silly fetch manifest dns-packet@^5.2.2
        105 silly fetch manifest thunky@^1.0.2
        106 http fetch GET 200 https://registry.npmjs.org/@babel%2fcode-frame 325ms (cache hit)
        107 http fetch GET 200 https://registry.npmjs.org/@eslint%2feslintrc 328ms (cache hit)
        108 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fconfig-array 332ms (cache hit)
        109 http fetch GET 200 https://registry.npmjs.org/debug 337ms (cache hit)
        110 http fetch GET 200 https://registry.npmjs.org/enquirer 357ms (cache hit)
        111 http fetch GET 200 https://registry.npmjs.org/eslint-scope 362ms (cache hit)
        112 http fetch GET 200 https://registry.npmjs.org/doctrine 368ms (cache hit)
        113 http fetch GET 200 https://registry.npmjs.org/eslint-utils 368ms (cache hit)
        114 http fetch GET 200 https://registry.npmjs.org/eslint-visitor-keys 371ms (cache hit)
        115 http fetch GET 200 https://registry.npmjs.org/espree 374ms (cache hit)
        116 http fetch GET 200 https://registry.npmjs.org/esquery 382ms (cache hit)
        117 http fetch GET 200 https://registry.npmjs.org/esutils 381ms (cache hit)
        118 http fetch GET 200 https://registry.npmjs.org/file-entry-cache 381ms (cache hit)
        119 http fetch GET 200 https://registry.npmjs.org/functional-red-black-tree 382ms (cache hit)
        120 http fetch GET 200 https://registry.npmjs.org/globals 382ms (cache hit)
        121 http fetch GET 200 https://registry.npmjs.org/ignore 386ms (cache hit)
        122 http fetch GET 200 https://registry.npmjs.org/js-yaml 391ms (cache hit)
        123 http fetch GET 200 https://registry.npmjs.org/json-stable-stringify-without-jsonify 395ms (cache hit)
        124 http fetch GET 200 https://registry.npmjs.org/lodash.merge 393ms (cache hit)
        125 http fetch GET 200 https://registry.npmjs.org/levn 399ms (cache hit)
        126 http fetch GET 200 https://registry.npmjs.org/natural-compare 395ms (cache hit)
        127 http fetch GET 200 https://registry.npmjs.org/minimatch 402ms (cache hit)
        128 http fetch GET 200 https://registry.npmjs.org/progress 409ms (cache hit)
        129 http fetch GET 200 https://registry.npmjs.org/optionator 417ms (cache hit)
        130 http fetch GET 200 https://registry.npmjs.org/regexpp 417ms (cache hit)
        131 http fetch GET 200 https://registry.npmjs.org/strip-json-comments 417ms (cache hit)
        132 http fetch GET 200 https://registry.npmjs.org/text-table 415ms (cache hit)
        133 http fetch GET 200 https://registry.npmjs.org/table 421ms (cache hit)
        134 http fetch GET 200 https://registry.npmjs.org/thunky 417ms (cache hit)
        135 http fetch GET 200 https://registry.npmjs.org/v8-compile-cache 425ms (cache hit)
        136 http fetch GET 200 https://registry.npmjs.org/dns-packet 425ms (cache hit)
        137 timing idealTree:node_modules/esphome-native-api Completed in 534ms
        138 silly placeDep node_modules/eslint @babel/code-frame@7.12.11 OK for: eslint@7.32.0 want: 7.12.11
        139 silly placeDep ROOT @eslint/eslintrc@0.4.3 OK for: eslint@7.32.0 want: ^0.4.3
        140 silly placeDep ROOT @humanwhocodes/config-array@0.5.0 OK for: eslint@7.32.0 want: ^0.5.0
        141 silly placeDep node_modules/eslint debug@4.3.4 OK for: eslint@7.32.0 want: ^4.0.1
        142 silly placeDep ROOT doctrine@3.0.0 OK for: eslint@7.32.0 want: ^3.0.0
        143 silly placeDep ROOT enquirer@2.3.6 OK for: eslint@7.32.0 want: ^2.3.5
        144 silly placeDep ROOT eslint-scope@5.1.1 OK for: eslint@7.32.0 want: ^5.1.1
        145 silly placeDep ROOT eslint-utils@2.1.0 OK for: eslint@7.32.0 want: ^2.1.0
        146 silly placeDep ROOT eslint-visitor-keys@2.1.0 OK for: eslint@7.32.0 want: ^2.0.0
        147 silly placeDep ROOT espree@7.3.1 OK for: eslint@7.32.0 want: ^7.3.1
        148 silly placeDep ROOT esquery@1.5.0 OK for: eslint@7.32.0 want: ^1.4.0
        149 silly placeDep ROOT esutils@2.0.3 OK for: eslint@7.32.0 want: ^2.0.2
        150 silly placeDep ROOT file-entry-cache@6.0.1 OK for: eslint@7.32.0 want: ^6.0.1
        151 silly placeDep ROOT functional-red-black-tree@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
        152 silly placeDep ROOT globals@13.20.0 OK for: eslint@7.32.0 want: ^13.6.0
        153 silly placeDep node_modules/eslint ignore@4.0.6 OK for: eslint@7.32.0 want: ^4.0.6
        154 silly placeDep ROOT js-yaml@3.14.1 OK for: eslint@7.32.0 want: ^3.13.1
        155 silly placeDep ROOT json-stable-stringify-without-jsonify@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
        156 silly placeDep ROOT levn@0.4.1 OK for: eslint@7.32.0 want: ^0.4.1
        157 silly placeDep ROOT lodash.merge@4.6.2 OK for: eslint@7.32.0 want: ^4.6.2
        158 silly placeDep node_modules/eslint minimatch@3.1.2 OK for: eslint@7.32.0 want: ^3.0.4
        159 silly placeDep ROOT natural-compare@1.4.0 OK for: eslint@7.32.0 want: ^1.4.0
        160 silly placeDep ROOT optionator@0.9.1 OK for: eslint@7.32.0 want: ^0.9.1
        161 silly placeDep ROOT progress@2.0.3 OK for: eslint@7.32.0 want: ^2.0.0
        162 silly placeDep ROOT regexpp@3.2.0 OK for: eslint@7.32.0 want: ^3.1.0
        163 silly placeDep node_modules/eslint strip-json-comments@3.1.1 OK for: eslint@7.32.0 want: ^3.1.0
        164 silly placeDep ROOT table@6.8.1 OK for: eslint@7.32.0 want: ^6.0.9
        165 silly placeDep ROOT text-table@0.2.0 OK for: eslint@7.32.0 want: ^0.2.0
        166 silly placeDep ROOT v8-compile-cache@2.3.0 OK for: eslint@7.32.0 want: ^2.0.3
        167 silly fetch manifest debug@^4.1.1
        168 silly fetch manifest strip-json-comments@^3.1.1
        169 silly fetch manifest @humanwhocodes/object-schema@^1.2.0
        170 silly fetch manifest ms@2.1.2
        171 silly fetch manifest ansi-colors@^4.1.1
        172 silly fetch manifest esrecurse@^4.3.0
        173 silly fetch manifest estraverse@^4.1.1
        174 silly fetch manifest eslint-visitor-keys@^1.1.0
        175 silly fetch manifest acorn@^7.4.0
        176 silly fetch manifest acorn-jsx@^5.3.1
        177 silly fetch manifest eslint-visitor-keys@^1.3.0
        178 silly fetch manifest estraverse@^5.1.0
        179 silly fetch manifest flat-cache@^3.0.4
        180 silly fetch manifest type-fest@^0.20.2
        181 silly fetch manifest argparse@^1.0.7
        182 silly fetch manifest esprima@^4.0.0
        183 silly fetch manifest prelude-ls@^1.2.1
        184 silly fetch manifest type-check@~0.4.0
        185 silly fetch manifest brace-expansion@^1.1.7
        186 silly fetch manifest deep-is@^0.1.3
        187 silly fetch manifest word-wrap@^1.2.3
        188 silly fetch manifest type-check@^0.4.0
        189 silly fetch manifest fast-levenshtein@^2.0.6
        190 silly fetch manifest ajv@^8.0.1
        191 silly fetch manifest lodash.truncate@^4.4.2
        192 silly fetch manifest slice-ansi@^4.0.0
        193 http fetch GET 200 https://registry.npmjs.org/esrecurse 315ms (cache hit)
        194 http fetch GET 200 https://registry.npmjs.org/estraverse 315ms (cache hit)
        195 http fetch GET 200 https://registry.npmjs.org/estraverse 308ms (cache hit)
        196 http fetch GET 200 https://registry.npmjs.org/flat-cache 308ms (cache hit)
        197 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fobject-schema 337ms (cache hit)
        198 http fetch GET 200 https://registry.npmjs.org/ms 336ms (cache hit)
        199 http fetch GET 200 https://registry.npmjs.org/acorn 327ms (cache hit)
        200 http fetch GET 200 https://registry.npmjs.org/type-fest 327ms (cache hit)
        201 http fetch GET 200 https://registry.npmjs.org/ansi-colors 358ms (cache hit)
        202 http fetch GET 200 https://registry.npmjs.org/prelude-ls 330ms (cache hit)
        203 http fetch GET 200 https://registry.npmjs.org/acorn-jsx 350ms (cache hit)
        204 http fetch GET 200 https://registry.npmjs.org/esprima 338ms (cache hit)
        205 http fetch GET 200 https://registry.npmjs.org/type-check 336ms (cache hit)
        206 http fetch GET 200 https://registry.npmjs.org/brace-expansion 334ms (cache hit)
        207 http fetch GET 200 https://registry.npmjs.org/word-wrap 332ms (cache hit)
        208 http fetch GET 200 https://registry.npmjs.org/type-check 331ms (cache hit)
        209 http fetch GET 200 https://registry.npmjs.org/argparse 355ms (cache hit)
        210 http fetch GET 200 https://registry.npmjs.org/lodash.truncate 305ms (cache hit)
        211 http fetch GET 200 https://registry.npmjs.org/slice-ansi 307ms (cache hit)
        212 http fetch GET 200 https://registry.npmjs.org/deep-is 351ms (cache hit)
        213 http fetch GET 200 https://registry.npmjs.org/fast-levenshtein 343ms (cache hit)
        214 http fetch GET 200 https://registry.npmjs.org/ajv 351ms (cache hit)
        215 timing idealTree:node_modules/eslint Completed in 668ms
        216 silly placeDep node_modules/@eslint/eslintrc debug@4.3.4 OK for: @eslint/eslintrc@0.4.3 want: ^4.1.1
        217 silly placeDep node_modules/@eslint/eslintrc ignore@4.0.6 OK for: @eslint/eslintrc@0.4.3 want: ^4.0.6
        218 silly placeDep node_modules/@eslint/eslintrc minimatch@3.1.2 OK for: @eslint/eslintrc@0.4.3 want: ^3.0.4
        219 silly placeDep node_modules/@eslint/eslintrc strip-json-comments@3.1.1 OK for: @eslint/eslintrc@0.4.3 want: ^3.1.1
        220 timing idealTree:node_modules/@eslint/eslintrc Completed in 24ms
        221 silly placeDep ROOT @humanwhocodes/object-schema@1.2.1 OK for: @humanwhocodes/config-array@0.5.0 want: ^1.2.0
        222 silly placeDep node_modules/@humanwhocodes/config-array debug@4.3.4 OK for: @humanwhocodes/config-array@0.5.0 want: ^4.1.1
        223 silly placeDep node_modules/@humanwhocodes/config-array minimatch@3.1.2 OK for: @humanwhocodes/config-array@0.5.0 want: ^3.0.4
        224 timing idealTree:node_modules/@humanwhocodes/config-array Completed in 18ms
        225 timing idealTree:node_modules/@humanwhocodes/object-schema Completed in 0ms
        226 timing idealTree:node_modules/doctrine Completed in 0ms
        227 silly placeDep ROOT ansi-colors@4.1.3 OK for: enquirer@2.3.6 want: ^4.1.1
        228 timing idealTree:node_modules/enquirer Completed in 6ms
        229 timing idealTree:node_modules/ansi-colors Completed in 0ms
        230 silly placeDep ROOT esrecurse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.3.0
        231 silly placeDep ROOT estraverse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.1.1
        232 silly fetch manifest estraverse@^5.2.0
        233 timing idealTree:node_modules/eslint-scope Completed in 15ms
        234 silly placeDep node_modules/eslint-utils eslint-visitor-keys@1.3.0 OK for: eslint-utils@2.1.0 want: ^1.1.0
        235 timing idealTree:node_modules/eslint-utils Completed in 4ms
        236 timing idealTree:node_modules/eslint-visitor-keys Completed in 0ms
        237 silly placeDep ROOT acorn@7.4.1 OK for: espree@7.3.1 want: ^7.4.0
        238 silly placeDep ROOT acorn-jsx@5.3.2 OK for: espree@7.3.1 want: ^5.3.1
        239 silly placeDep node_modules/espree eslint-visitor-keys@1.3.0 OK for: espree@7.3.1 want: ^1.3.0
        240 timing idealTree:node_modules/espree Completed in 26ms
        241 timing idealTree:node_modules/acorn Completed in 0ms
        242 timing idealTree:node_modules/acorn-jsx Completed in 0ms
        243 silly placeDep node_modules/esquery estraverse@5.3.0 OK for: esquery@1.5.0 want: ^5.1.0
        244 timing idealTree:node_modules/esquery Completed in 6ms
        245 silly placeDep node_modules/esrecurse estraverse@5.3.0 OK for: esrecurse@4.3.0 want: ^5.2.0
        246 timing idealTree:node_modules/esrecurse Completed in 4ms
        247 timing idealTree:node_modules/estraverse Completed in 0ms
        248 timing idealTree:node_modules/esutils Completed in 1ms
        249 timing idealTree:node_modules/events Completed in 0ms
        250 silly placeDep ROOT flat-cache@3.0.4 OK for: file-entry-cache@6.0.1 want: ^3.0.4
        251 silly fetch manifest flatted@^3.1.0
        252 http fetch GET 200 https://registry.npmjs.org/flatted 18ms (cache hit)
        253 timing idealTree:node_modules/file-entry-cache Completed in 31ms
        254 silly placeDep ROOT flatted@3.2.7 OK for: flat-cache@3.0.4 want: ^3.1.0
        255 timing idealTree:node_modules/flat-cache Completed in 7ms
        256 timing idealTree:node_modules/flatted Completed in 0ms
        257 timing idealTree:node_modules/functional-red-black-tree Completed in 0ms
        258 silly placeDep node_modules/globals type-fest@0.20.2 OK for: globals@13.20.0 want: ^0.20.2
        259 timing idealTree:node_modules/globals Completed in 5ms
        260 timing idealTree:node_modules/google-protobuf Completed in 0ms
        261 silly placeDep ROOT argparse@1.0.10 OK for: js-yaml@3.14.1 want: ^1.0.7
        262 silly placeDep ROOT esprima@4.0.1 OK for: js-yaml@3.14.1 want: ^4.0.0
        263 silly fetch manifest sprintf-js@~1.0.2
        264 http fetch GET 200 https://registry.npmjs.org/sprintf-js 20ms (cache hit)
        265 timing idealTree:node_modules/js-yaml Completed in 38ms
        266 silly placeDep node_modules/argparse sprintf-js@1.0.3 OK for: argparse@1.0.10 want: ~1.0.2
        267 timing idealTree:node_modules/argparse Completed in 4ms
        268 timing idealTree:node_modules/esprima Completed in 0ms
        269 timing idealTree:node_modules/json-stable-stringify-without-jsonify Completed in 0ms
        270 silly placeDep ROOT prelude-ls@1.2.1 OK for: levn@0.4.1 want: ^1.2.1
        271 silly placeDep ROOT type-check@0.4.0 OK for: levn@0.4.1 want: ~0.4.0
        272 timing idealTree:node_modules/levn Completed in 13ms
        273 timing idealTree:node_modules/lodash.merge Completed in 0ms
        274 silly placeDep node_modules/multicast-dns dns-packet@5.6.0 OK for: multicast-dns@7.2.5 want: ^5.2.2
        275 silly placeDep ROOT thunky@1.1.0 OK for: multicast-dns@7.2.5 want: ^1.0.2
        276 silly fetch manifest @leichtgewicht/ip-codec@^2.0.1
        277 http fetch GET 200 https://registry.npmjs.org/@leichtgewicht%2fip-codec 18ms (cache hit)
        278 timing idealTree:node_modules/multicast-dns Completed in 34ms
        279 timing idealTree:node_modules/natural-compare Completed in 0ms
        280 timing idealTree:node_modules/net Completed in 0ms
        281 silly placeDep ROOT deep-is@0.1.4 OK for: optionator@0.9.1 want: ^0.1.3
        282 silly placeDep ROOT fast-levenshtein@2.0.6 OK for: optionator@0.9.1 want: ^2.0.6
        283 silly placeDep ROOT word-wrap@1.2.3 OK for: optionator@0.9.1 want: ^1.2.3
        284 timing idealTree:node_modules/optionator Completed in 19ms
        285 timing idealTree:node_modules/deep-is Completed in 0ms
        286 timing idealTree:node_modules/fast-levenshtein Completed in 1ms
        287 timing idealTree:node_modules/prelude-ls Completed in 0ms
        288 timing idealTree:node_modules/progress Completed in 0ms
        289 timing idealTree:node_modules/regexpp Completed in 0ms
        290 silly placeDep node_modules/table ajv@8.12.0 OK for: table@6.8.1 want: ^8.0.1
        291 silly placeDep ROOT lodash.truncate@4.4.2 OK for: table@6.8.1 want: ^4.4.2
        292 silly placeDep node_modules/table slice-ansi@4.0.0 OK for: table@6.8.1 want: ^4.0.0
        293 silly fetch manifest json-schema-traverse@^1.0.0
        294 silly fetch manifest require-from-string@^2.0.2
        295 silly fetch manifest astral-regex@^2.0.0
        296 http fetch GET 200 https://registry.npmjs.org/require-from-string 48ms (cache hit)
        297 http fetch GET 200 https://registry.npmjs.org/astral-regex 47ms (cache hit)
        298 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 54ms (cache hit)
        299 timing idealTree:node_modules/table Completed in 78ms
        300 timing idealTree:node_modules/lodash.truncate Completed in 0ms
        301 timing idealTree:node_modules/text-table Completed in 0ms
        302 timing idealTree:node_modules/thunky Completed in 0ms
        303 timing idealTree:node_modules/tree-kill Completed in 1ms
        304 timing idealTree:node_modules/type-check Completed in 0ms
        305 timing idealTree:node_modules/v8-compile-cache Completed in 0ms
        306 timing idealTree:node_modules/word-wrap Completed in 0ms
        307 silly placeDep node_modules/@eslint/eslintrc ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
        308 timing idealTree:node_modules/@eslint/eslintrc/node_modules/debug Completed in 6ms
        309 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 0ms
        310 silly placeDep node_modules/@eslint/eslintrc brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
        311 timing idealTree:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 5ms
        312 timing idealTree:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 0ms
        313 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ms Completed in 0ms
        314 timing idealTree:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 0ms
        315 silly placeDep node_modules/@humanwhocodes/config-array ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
        316 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 4ms
        317 silly placeDep node_modules/@humanwhocodes/config-array brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
        318 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 6ms
        319 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1ms
        320 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 0ms
        321 timing idealTree:node_modules/argparse/node_modules/sprintf-js Completed in 0ms
        322 timing idealTree:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 0ms
        323 timing idealTree:node_modules/eslint/node_modules/@babel/code-frame Completed in 0ms
        324 silly placeDep node_modules/eslint ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
        325 timing idealTree:node_modules/eslint/node_modules/debug Completed in 5ms
        326 timing idealTree:node_modules/eslint/node_modules/ignore Completed in 0ms
        327 silly placeDep node_modules/eslint brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
        328 timing idealTree:node_modules/eslint/node_modules/minimatch Completed in 6ms
        329 timing idealTree:node_modules/eslint/node_modules/brace-expansion Completed in 0ms
        330 timing idealTree:node_modules/eslint/node_modules/ms Completed in 0ms
        331 timing idealTree:node_modules/eslint/node_modules/strip-json-comments Completed in 0ms
        332 timing idealTree:node_modules/espree/node_modules/eslint-visitor-keys Completed in 0ms
        333 timing idealTree:node_modules/esquery/node_modules/estraverse Completed in 0ms
        334 timing idealTree:node_modules/esrecurse/node_modules/estraverse Completed in 0ms
        335 timing idealTree:node_modules/globals/node_modules/type-fest Completed in 1ms
        336 silly placeDep node_modules/iobroker.esphome @sentry/core@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
        337 silly placeDep node_modules/iobroker.esphome @sentry/hub@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
        338 silly placeDep node_modules/iobroker.esphome @sentry/types@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
        339 silly placeDep node_modules/iobroker.esphome @sentry/utils@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
        340 silly fetch manifest @sentry/minimal@5.30.0
        341 http fetch GET 200 https://registry.npmjs.org/@sentry%2fminimal 32ms (cache hit)
        342 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 79ms
        343 silly placeDep node_modules/iobroker.esphome @sentry/minimal@5.30.0 OK for: @sentry/core@5.30.0 want: 5.30.0
        344 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 6ms
        345 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 0ms
        346 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 0ms
        347 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 0ms
        348 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 0ms
        349 silly placeDep ROOT @leichtgewicht/ip-codec@2.0.4 OK for: dns-packet@5.6.0 want: ^2.0.1
        350 timing idealTree:node_modules/multicast-dns/node_modules/dns-packet Completed in 8ms
        351 timing idealTree:node_modules/@leichtgewicht/ip-codec Completed in 0ms
        352 silly placeDep node_modules/table json-schema-traverse@1.0.0 OK for: ajv@8.12.0 want: ^1.0.0
        353 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.12.0 want: ^2.0.2
        354 timing idealTree:node_modules/table/node_modules/ajv Completed in 12ms
        355 timing idealTree:node_modules/require-from-string Completed in 0ms
        356 timing idealTree:node_modules/table/node_modules/json-schema-traverse Completed in 0ms
        357 silly placeDep ROOT astral-regex@2.0.0 OK for: slice-ansi@4.0.0 want: ^2.0.0
        358 timing idealTree:node_modules/table/node_modules/slice-ansi Completed in 7ms
        359 timing idealTree:node_modules/astral-regex Completed in 0ms
        360 timing idealTree:buildDeps Completed in 6642ms
        361 timing idealTree:fixDepFlags Completed in 30ms
        362 timing idealTree Completed in 10857ms
        363 timing reify:loadTrees Completed in 10861ms
        364 timing reify:diffTrees Completed in 104ms
        365 silly reify mark retired [ '/opt/iobroker/node_modules/fsevents' ]
        366 silly reify mark retired [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
        367 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.vis' ]
        368 silly reify moves {
        368 silly reify   '/opt/iobroker/node_modules/fsevents': '/opt/iobroker/node_modules/.fsevents-yNYMVUiI',
        368 silly reify   '/opt/iobroker/node_modules/osx-temperature-sensor': '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv',
        368 silly reify   '/opt/iobroker/node_modules/iobroker.vis': '/opt/iobroker/node_modules/.iobroker.vis-A3mwBQZP'
        368 silly reify }
        369 timing reify:retireShallow Completed in 16ms
        370 timing reify:createSparse Completed in 41ms
        371 timing reify:loadBundles Completed in 0ms
        372 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
        373 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
        374 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
        375 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
        376 timing reifyNode:node_modules/osx-temperature-sensor Completed in 56ms
        377 timing reifyNode:node_modules/fsevents Completed in 57ms
        378 timing reifyNode:node_modules/natural-compare Completed in 1469ms
        379 timing reifyNode:node_modules/require-from-string Completed in 1511ms
        380 timing reifyNode:node_modules/fast-levenshtein Completed in 1513ms
        381 timing reifyNode:node_modules/table/node_modules/slice-ansi Completed in 1538ms
        382 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1540ms
        383 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 1540ms
        384 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ms Completed in 1541ms
        385 timing reifyNode:node_modules/eslint/node_modules/brace-expansion Completed in 1540ms
        386 timing reifyNode:node_modules/eslint/node_modules/ms Completed in 1541ms
        387 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 1545ms
        388 timing reifyNode:node_modules/astral-regex Completed in 1562ms
        389 timing reifyNode:node_modules/word-wrap Completed in 1561ms
        390 timing reifyNode:node_modules/lodash.truncate Completed in 1562ms
        391 timing reifyNode:node_modules/net Completed in 1576ms
        392 timing reifyNode:node_modules/eslint/node_modules/strip-json-comments Completed in 1589ms
        393 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 1592ms
        394 timing reifyNode:node_modules/eslint/node_modules/@babel/code-frame Completed in 1592ms
        395 timing reifyNode:node_modules/esrecurse Completed in 1628ms
        396 timing reifyNode:node_modules/tree-kill Completed in 1644ms
        397 timing reifyNode:node_modules/thunky Completed in 1674ms
        398 timing reifyNode:node_modules/v8-compile-cache Completed in 1687ms
        399 timing reifyNode:node_modules/file-entry-cache Completed in 1688ms
        400 timing reifyNode:node_modules/@humanwhocodes/config-array Completed in 1698ms
        401 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 1716ms
        402 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 1716ms
        403 timing reifyNode:node_modules/eslint/node_modules/minimatch Completed in 1715ms
        404 timing reifyNode:node_modules/type-check Completed in 1738ms
        405 timing reifyNode:node_modules/acorn-jsx Completed in 1742ms
        406 timing reifyNode:node_modules/lodash.merge Completed in 1746ms
        407 timing reifyNode:node_modules/@leichtgewicht/ip-codec Completed in 1778ms
        408 timing reifyNode:node_modules/ansi-colors Completed in 1779ms
        409 timing reifyNode:node_modules/progress Completed in 1781ms
        410 timing reifyNode:node_modules/levn Completed in 1782ms
        411 timing reifyNode:node_modules/eslint-visitor-keys Completed in 1784ms
        412 timing reifyNode:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1795ms
        413 timing reifyNode:node_modules/espree/node_modules/eslint-visitor-keys Completed in 1796ms
        414 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/debug Completed in 1793ms
        415 timing reifyNode:node_modules/eslint/node_modules/debug Completed in 1793ms
        416 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 1796ms
        417 timing reifyNode:node_modules/estraverse Completed in 1810ms
        418 timing reifyNode:node_modules/globals Completed in 1810ms
        419 timing reifyNode:node_modules/esrecurse/node_modules/estraverse Completed in 1821ms
        420 timing reifyNode:node_modules/esquery/node_modules/estraverse Completed in 1818ms
        421 timing reifyNode:node_modules/deep-is Completed in 1827ms
        422 timing reifyNode:node_modules/flat-cache Completed in 1828ms
        423 timing reifyNode:node_modules/optionator Completed in 1829ms
        424 timing reifyNode:node_modules/functional-red-black-tree Completed in 1830ms
        425 timing reifyNode:node_modules/multicast-dns Completed in 1832ms
        426 timing reifyNode:node_modules/eslint/node_modules/ignore Completed in 1835ms
        427 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 1838ms
        428 timing reifyNode:node_modules/esutils Completed in 1879ms
        429 timing reifyNode:node_modules/multicast-dns/node_modules/dns-packet Completed in 1885ms
        430 timing reifyNode:node_modules/prelude-ls Completed in 1896ms
        431 timing reifyNode:node_modules/text-table Completed in 1939ms
        432 timing reifyNode:node_modules/espree Completed in 1938ms
        433 timing reifyNode:node_modules/doctrine Completed in 1939ms
        434 timing reifyNode:node_modules/flatted Completed in 1950ms
        435 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 1953ms
        436 timing reifyNode:node_modules/json-stable-stringify-without-jsonify Completed in 1967ms
        437 timing reifyNode:node_modules/table/node_modules/json-schema-traverse Completed in 1977ms
        438 timing reifyNode:node_modules/@humanwhocodes/object-schema Completed in 2000ms
        439 timing reifyNode:node_modules/eslint-scope Completed in 2019ms
        440 timing reifyNode:node_modules/argparse/node_modules/sprintf-js Completed in 2039ms
        441 timing reifyNode:node_modules/regexpp Completed in 2053ms
        442 timing reifyNode:node_modules/esprima Completed in 2076ms
        443 timing reifyNode:node_modules/eslint-utils Completed in 2084ms
        444 timing reifyNode:node_modules/events Completed in 2277ms
        445 timing reifyNode:node_modules/argparse Completed in 2319ms
        446 timing reifyNode:node_modules/@eslint/eslintrc Completed in 2330ms
        447 timing reifyNode:node_modules/iobroker.esphome Completed in 2359ms
        448 timing reifyNode:node_modules/globals/node_modules/type-fest Completed in 2398ms
        449 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 2525ms
        450 timing reifyNode:node_modules/esphome-native-api Completed in 2527ms
        451 timing reifyNode:node_modules/enquirer Completed in 2544ms
        452 timing reifyNode:node_modules/google-protobuf Completed in 2602ms
        453 timing reifyNode:node_modules/js-yaml Completed in 2616ms
        454 timing reifyNode:node_modules/esquery Completed in 2617ms
        455 timing reifyNode:node_modules/acorn Completed in 2683ms
        456 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 2893ms
        457 timing reifyNode:node_modules/table Completed in 3019ms
        458 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 3240ms
        459 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 3279ms
        460 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 3411ms
        461 timing reifyNode:node_modules/table/node_modules/ajv Completed in 4089ms
        462 timing reifyNode:node_modules/eslint Completed in 4128ms
        463 timing reify:unpack Completed in 4140ms
        464 timing reify:unretire Completed in 1ms
        465 timing build:queue Completed in 18ms
        466 timing build:link:node_modules/eslint Completed in 5ms
        467 timing build:link:node_modules/acorn Completed in 9ms
        468 timing build:link:node_modules/esprima Completed in 5ms
        469 timing build:link:node_modules/js-yaml Completed in 5ms
        470 timing build:link:node_modules/multicast-dns Completed in 5ms
        471 timing build:link:node_modules/tree-kill Completed in 4ms
        472 timing build:link Completed in 10ms
        473 info run iobroker.esphome@0.2.4 install node_modules/iobroker.esphome npip install
        474 info run iobroker.esphome@0.2.4 install { code: 1, signal: null }
        475 timing reify:rollback:createSparse Completed in 487ms
        476 timing reify:rollback:retireShallow Completed in 2ms
        477 timing command:install Completed in 107556ms
        478 verbose stack Error: command failed
        478 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
        478 verbose stack     at ChildProcess.emit (node:events:513:28)
        478 verbose stack     at maybeClose (node:internal/child_process:1091:16)
        478 verbose stack     at Socket.<anonymous> (node:internal/child_process:449:11)
        478 verbose stack     at Socket.emit (node:events:513:28)
        478 verbose stack     at Pipe.<anonymous> (node:net:322:12)
        479 verbose pkgid iobroker.esphome@0.2.4
        480 verbose cwd /opt/iobroker
        481 verbose Linux 6.1.21-v8+
        482 verbose node v18.16.0
        483 verbose npm  v9.5.1
        484 error code 1
        485 error path /opt/iobroker/node_modules/iobroker.esphome
        486 error command failed
        487 error command sh -c npip install
        488 error No python_modules directory; installing pip locally if needed.
        488 error Successfully completed pip check.
        488 error Collecting esphome>=2021.8
        488 error   Using cached esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
        488 error Collecting tornado>=3.2
        488 error   Using cached tornado-6.3.1.tar.gz (508 kB)
        488 error   Installing build dependencies: started
        488 error   Installing build dependencies: finished with status 'done'
        488 error   Getting requirements to build wheel: started
        488 error   Getting requirements to build wheel: finished with status 'done'
        488 error   Preparing metadata (pyproject.toml): started
        488 error   Preparing metadata (pyproject.toml): finished with status 'done'
        488 error Collecting voluptuous==0.13.1 (from esphome>=2021.8)
        488 error   Using cached voluptuous-0.13.1-py3-none-any.whl (29 kB)
        488 error Collecting PyYAML==6.0 (from esphome>=2021.8)
        488 error   Using cached PyYAML-6.0.tar.gz (124 kB)
        488 error Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
        488 error   Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
        488 error   Preparing metadata (setup.py): started
        488 error   Preparing metadata (setup.py): finished with status 'done'
        488 error Collecting colorama==0.4.6 (from esphome>=2021.8)
        488 error   Using cached colorama-0.4.6-py2.py3-none-any.whl (25 kB)
        488 error   Using cached tornado-6.2.tar.gz (504 kB)
        488 error Collecting tzlocal==4.2 (from esphome>=2021.8)
        488 error   Using cached tzlocal-4.2-py3-none-any.whl (19 kB)
        488 error Collecting tzdata>=2021.1 (from esphome>=2021.8)
        488 error   Using cached tzdata-2023.3-py2.py3-none-any.whl (341 kB)
        488 error Collecting pyserial==3.5 (from esphome>=2021.8)
        488 error   Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
        488 error Collecting platformio==6.1.6 (from esphome>=2021.8)
        488 error   Using cached platformio-6.1.6.tar.gz (236 kB)
        488 error Collecting esptool==4.5.1 (from esphome>=2021.8)
        488 error   Using cached esptool-4.5.1.tar.gz (252 kB)
        488 error Collecting click==8.1.3 (from esphome>=2021.8)
        488 error   Using cached click-8.1.3-py3-none-any.whl (96 kB)
        488 error Collecting esphome-dashboard==20230214.0 (from esphome>=2021.8)
        488 error   Using cached esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
        488 error Collecting aioesphomeapi==13.5.1 (from esphome>=2021.8)
        488 error   Using cached aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
        488 error Collecting zeroconf==0.56.0 (from esphome>=2021.8)
        488 error   Using cached zeroconf-0.56.0.tar.gz (140 kB)
        488 error Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
        488 error   Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
        488 error Collecting protobuf>=3.19.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
        488 error   Using cached protobuf-4.22.3-py3-none-any.whl (172 kB)
        488 error Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==13.5.1->esphome>=2021.8)
        488 error   Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
        488 error Collecting async-timeout>=4.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
        488 error   Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
        488 error Collecting bitstring>=3.1.6 (from esptool==4.5.1->esphome>=2021.8)
        488 error   Using cached bitstring-4.0.2-py3-none-any.whl (46 kB)
        488 error Collecting cryptography>=2.1.4 (from esptool==4.5.1->esphome>=2021.8)
        488 error   Using cached cryptography-40.0.2.tar.gz (625 kB)
        488 error   Installing build dependencies: finished with status 'error'
        489 error /usr/bin/python3: No module named pip
        489 error /usr/bin/python3: No module named ensurepip
        489 error ERROR: Could not install packages due to an OSError: [Errno 2] No such file or directory: '/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/wheel-0.40.0.dist-info/INSTALLER4efqrkmn.tmp'
        489 error
        489 error   error: subprocess-exited-with-error
        489 error
        489 error   × pip subprocess to install build dependencies did not run successfully.
        489 error   │ exit code: 1
        489 error   ╰─> [81 lines of output]
        489 error       Collecting setuptools!=60.9.0,>=40.6.0
        489 error         Using cached setuptools-67.7.2-py3-none-any.whl (1.1 MB)
        489 error       Collecting wheel
        489 error         Using cached wheel-0.40.0-py3-none-any.whl (64 kB)
        489 error       Collecting cffi>=1.12
        489 error         Using cached cffi-1.15.1.tar.gz (508 kB)
        489 error         Preparing metadata (setup.py): started
        489 error         Preparing metadata (setup.py): finished with status 'done'
        489 error       Collecting setuptools-rust>=0.11.4
        489 error         Using cached setuptools_rust-1.5.2-py3-none-any.whl (23 kB)
        489 error       Collecting pycparser (from cffi>=1.12)
        489 error         Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
        489 error       Collecting semantic-version<3,>=2.8.2 (from setuptools-rust>=0.11.4)
        489 error         Using cached semantic_version-2.10.0-py2.py3-none-any.whl (15 kB)
        489 error       Collecting typing-extensions>=3.7.4.3 (from setuptools-rust>=0.11.4)
        489 error         Using cached typing_extensions-4.5.0-py3-none-any.whl (27 kB)
        489 error       Building wheels for collected packages: cffi
        489 error         Building wheel for cffi (setup.py): started
        489 error         Building wheel for cffi (setup.py): finished with status 'error'
        489 error
        489 error         × python setup.py bdist_wheel did not run successfully.
        489 error         ╰─> [50 lines of output]
        489 error             /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/config/setupcfg.py:293: _DeprecatedConfig: Deprecated config in `setup.cfg`
        489 error             !!
        489 error
        489 error                     ********************************************************************************
        489 error                     The license_file parameter is deprecated, use license_files instead.
        489 error
        489 error                     By 2023-Oct-30, you need to update your project and remove deprecated calls
        489 error                     or your builds will no longer be supported.
        489 error
        489 error                     See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
        489 error
        489 error             !!
        489 error               parsed = self.parsers.get(option_name, lambda x: x)(value)
        489 error             running bdist_wheel
        489 error             running build
        489 error             running build_py
        489 error             creating build
        489 error             creating build/lib.linux-aarch64-cpython-39
        489 error             creating build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/lock.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/cparser.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/verifier.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/vengine_gen.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/backend_ctypes.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/vengine_cpy.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/setuptools_ext.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/error.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/cffi_opcode.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/__init__.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/model.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/pkgconfig.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/recompiler.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/api.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/ffiplatform.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/commontypes.py -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/_cffi_include.h -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/parse_c_type.h -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/_embedding.h -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             copying cffi/_cffi_errors.h -> build/lib.linux-aarch64-cpython-39/cffi
        489 error             running build_ext
        489 error             building '_cffi_backend' extension
        489 error             creating build/temp.linux-aarch64-cpython-39
        489 error             creating build/temp.linux-aarch64-cpython-39/c
        489 error             arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DFFI_BUILDING=1 -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-aarch64-cpython-39/c/_cffi_backend.o
        489 error             c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
        489 error                 2 | #include <Python.h>
        489 error                   |          ^~~~~~~~~~
        489 error             compilation terminated.
        489 error             error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
        489 error             [end of output]
        489 error
        489 error         note: This error originates from a subprocess, and is likely not a problem with pip.
        489 error         ERROR: Failed building wheel for cffi
        489 error         Running setup.py clean for cffi
        489 error       Failed to build cffi
        489 error       ERROR: Could not build wheels for cffi, which is required to install pyproject.toml-based projects
        489 error
        489 error
        489 error ╰─> See above for output.
        489 error
        490 verbose exit 1
        491 timing npm Completed in 107807ms
        492 verbose unfinished npm timer reify 1682367601160
        493 verbose unfinished npm timer reify:build 1682367616344
        494 verbose unfinished npm timer build 1682367616349
        495 verbose unfinished npm timer build:deps 1682367616350
        496 verbose unfinished npm timer build:run:install 1682367616381
        497 verbose unfinished npm timer build:run:install:node_modules/iobroker.esphome 1682367616382
        498 verbose code 1
        499 error A complete log of this run can be found in:
        499 error     /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
        • M mayokleckz
          368 silly reify }
          484 error code 1
          489 error
          489 error
          489 error
          489 error             !!
          489 error
          489 error
          489 error
          489 error
          489 error             !!
          489 error
          489 error
          489 error
          489 error
          490 verbose exit 1
          498 verbose code 1
          @mayokleckz
          apt policy python3-full python3-pip
            @mayokleckz
            mayokleckz
            flo@raspberrypi:~ $ apt policy python3-full python3-pip
            python3-full:
              Installed: (none)
              Candidate: 3.9.2-3
              Version table:
                 3.9.2-3 500
            python3-pip:
              Installed: 20.3.4-4+rpt1+deb11u1
              Candidate: 20.3.4-4+rpt1+deb11u1
              Version table:
             *** 20.3.4-4+rpt1+deb11u1 500
                    500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                 20.3.4-4+deb11u1 500
            flo@raspberrypi:~ $
            • M mayokleckz
              python3-full:
                Installed: (none)
                Candidate: 3.9.2-3
                Version table:
                   3.9.2-3 500
              python3-pip:
                Version table:
              flo@raspberrypi:~ $
              @mayokleckz sagte in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
              python3-full
              Installier das mal nach.
              sudo apt install python3-full python3.9-dev libpython3.9-dev
                python3-full
                mayokleckz
                Die Installation funktioniert nun.
                Es war also
                cd /opt/iobroker
                npm i nopy
                und
                notwendig.
                Danke.
                Beim Kompilieren komme ich in einen neuen Fehler. Nach erstem suchen ein 32-bit<>64-bit os Problem?!
                INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-7a8069.yaml...
                INFO Generating C++ source...
                INFO Compiling app...
                Processing esphome--brunnen-web-7a8069 (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
                HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
                Dependency Graph
                |-- ESPAsyncTCP-esphome @ 1.2.3
                |-- ESPAsyncWebServer-esphome @ 2.1.0
                |   |-- Hash @ 1.0
                |   |-- ESP8266WiFi @ 1.0
                |-- DNSServer @ 1.1.1
                |-- ESP8266mDNS @ 1.2
                |-- noise-c @ 0.1.4
                |   |-- libsodium @ 1.10018.1
                Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o
                sh: 1: xtensa-lx106-elf-g++: not found
                Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o
                Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o
                *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o] Error 127
                Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o
                *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o] Error 127
                *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o] Error 127
                *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o] Error 127
                ========================== [FAILED] Took 2.55 seconds ==========================
                Der erste Lösungsversuch schlug schonmal fehl.
                flo@raspberrypi:~ $ sudo apt-get install xtensa-lx106-elf
                Reading package lists... Done
                E: Unable to locate package xtensa-lx106-elf
                flo@raspberrypi:~ $
                • M mayokleckz
                  Es war also
                  cd /opt/iobroker
                  npm i nopy
                  und
                  notwendig.
                  Danke.
                  Dependency Graph
                  |   |-- Hash @ 1.0
                  |-- noise-c @ 0.1.4
                  flo@raspberrypi:~ $
                  Versuch es mit
                  sudo apt install gcc-xtensa-lx106
                    Versuch es mit
                    mayokleckz
                    Das ging durch.
                    Ich stolper trotzdem nur ahnungslos von Fehler zu Fehler.
                    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esp-home-brunnen.yaml...
                    Processing esphome-brunnen (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
                    HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
                    Dependency Graph
                    |   |-- Hash @ 1.0
                    Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o
                    Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o
                    xtensa-lx106-elf-g++: fatal error: cannot execute 'cc1plus': execvp: No such file or directory
                    Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o
                    *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o] Error 1
                    *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
                    *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o] Error 1
                    Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o
                    *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
                    ========================== [FAILED] Took 2.38 seconds ==========================
                    • M mayokleckz
                      Das ging durch.
                      Dependency Graph
                      |   |-- Hash @ 1.0
                      @mayokleckz
                      Da fehlt dir der Cross Compiler
                      https://packages.debian.org/search?searchon=contents&keywords=cc1plus&mode=exactfilename&suite=stable&arch=any
                      Musst Mal schauen welcher gcc und welche Architektur da bei dir am Start ist. Danach richtet sich das zu installierende Paket.
                      uname -m
                      gcc --version
                      sagt dir Näheres.
                      Edit:
                      Ich sehe gerade, das sollte eigentlich auch im Paket gcc-xtensa-lx106 drin sein. Dann weiß ich nicht was dem System noch fehlt.
                        @mayokleckz
                        uname -m
                        gcc --version
                        sagt dir Näheres.
                        Edit:
                        mayokleckz
                        ok schade. trotzdem danke.
                        Evtl. ließt hier noch jemand drüber und weiß weiter Rat.
                        Ich hab mal nachgeschaut, also vorhanden scheint es zu sein.
                        flo@raspberrypi:~ $ find /usr/ -name "*cc1*"
                        /usr/share/terminfo/x/xterm+pcc1
                        /usr/share/doc/libcc1-0
                        /usr/lib/debug/.build-id/97/fca3e5a4e23a7a9dc3429293fe5f810dcc1cd6.debug
                        /usr/lib/debug/.build-id/ac/24d09573ac4b8d5987190d274d9128cc1aeb38.debug
                        find: ‘/usr/lib/mysql/plugin/auth_pam_tool_dir’: Permission denied
                        /usr/lib/arm-linux-gnueabihf/libcc1.so.0.0.0
                        /usr/lib/gcc/arm-linux-gnueabihf/10/cc1
                        /usr/lib/gcc/arm-linux-gnueabihf/10/cc1plus
                        /usr/lib/gcc/arm-linux-gnueabihf/10/libcc1.so
                        /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so
                        /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so.0.0.0
                        /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1
                        /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus
                        /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so
                        /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so.0.0.0
                        /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.la
                        flo@raspberrypi:~ $ find /usr/ -name "*execvp*"
                        /usr/share/man/man3/execvpe.3.gz
                        /usr/share/man/man3/execvp.3.gz
                        flo@raspberrypi:~ $ ^C
                        da eine Rechtevergabe schon mal geklappt hat, hab ich mal verzweifelt chmod versucht.
                        flo@raspberrypi:~ $ sudo -u iobroker chmod a+x /usr/lib/gcc/xtensa-lx106-elf/10.2.1/c*
                        chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1': Operation not permitted
                        chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus': Operation not permitted
                        chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/collect2': Operation not permitted
                        chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtbegin.o': Operation not permitted
                        chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtend.o': Operation not permitted
                        chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crti.o': Operation not permitted
                        chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtn.o': Operation not permitted
                        flo@raspberrypi:~ $
                        Dann noch in die Umgebungsvariable
                        flo@raspberrypi:~ $ export PATH=$PATH:/usr/lib/gcc/xtensa-lx106-elf/10.2.1
                        flo@raspberrypi:~ $ $PATH
                        -bash: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/bin/g++::/usr/lib/gcc/xtensa-lx106-elf/10.2.1:
                        flo@raspberrypi:~ $
                        Den Adapter auch noch mal neu installiert. Kompiliert einfach nicht.
                        Hänge also weiter bei
                        @mayokleckz said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
                        Das ging durch.
                        Dependency Graph
                        |   |-- Hash @ 1.0
                        • M mayokleckz
                          flo@raspberrypi:~ $
                          flo@raspberrypi:~ $
                          Das ging durch.
                          Dependency Graph
                          |   |-- Hash @ 1.0
                          Schlachte dich da nicht so durch das Rechtegefüge. Das die Rechte bei per Paketmanager installierten Softwarepaketen nicht stimmen kommt nur extrem selten vor, ich würde behaupten nie. Eher fehlen da Gruppenzugehörigkeiten für die User.
                          Gibt es da wo der Code herkommt keine Hinweise was für eine build chain benötigt wird?
                          Edith: Gerade noch was herumgeschaut. Hab ähnliche Probleme gefunden, wenn ältere Versionen von esphome verwendet wurden.
                          echad@chet:~ $ esphome version
                          Version: 2023.4.1
                          echad@chet:~ $
                          Was spuckt das bei dir aus?
                            Version: 2023.4.1
                            echad@chet:~ $
                            mayokleckz
                            schrieb am zuletzt editiert von mayokleckz
                            flo@raspberrypi:~ $ esphome version
                            -bash: esphome: command not found
                            flo@raspberrypi:~ $
                            Welchen Code meinst du? Falls der YAML Code zum kompilieren gemeint ist, das ist die initiale yaml Datei, die vom ESPHome Adapter beim hinzufügen eines Geräts automatisch erzeugt wird.
                            esphome:
                            esp8266:
                              board: d1_mini
                            # Enable logging
                            logger:
                            # Enable Home Assistant API
                            api:
                                password: 'MyPassword'
                            ota:
                              password: "d960f666ab261cb6fbcd4e21b4cd9a59"
                            wifi:
                              ssid: !secret wifi_ssid
                              password: !secret wifi_password
                              # Enable fallback hotspot (captive portal) in case wifi connection fails
                              ap:
                                ssid: "Esphome-Brunnen Fallback Hotspot"
                                password: "15dOCTm1PxgU"
                            captive_portal:
                            • M mayokleckz
                              flo@raspberrypi:~ $
                              esphome:
                              esp8266:
                                board: d1_mini
                              # Enable logging
                              logger:
                              api:
                              ota:
                              wifi:
                                ap:
                              captive_portal:
                              @mayokleckz
                              Keine Ahnung, hab mit esphome eigentlich nix am Hut.
                                @mayokleckz
                                mayokleckz
                                Das esphome version keine Antwort gab, hab ich folgendes versucht. Brachte aber auch keine Änderung am Ergebnis. Und im falschen Verzeichnis hab ichs wohl auch noch installiert.
                                flo@raspberrypi:~ $ pip3 install esphome
                                Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                Collecting esphome
                                  Downloading https://www.piwheels.org/simple/esphome/esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
                                     |████████████████████████████████| 2.6 MB 1.2 MB/s
                                  Downloading https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                                     |████████████████████████████████| 341 kB 7.1 MB/s
                                  Downloading https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
                                  Downloading https://www.piwheels.org/simple/tzlocal/tzlocal-4.2-py3-none-any.whl (19 kB)
                                  Downloading https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp39-cp39-linux_armv7l.whl (45 kB)
                                     |████████████████████████████████| 45 kB 1.5 MB/s
                                  Downloading https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                                     |████████████████████████████████| 145 kB 1.2 MB/s
                                  Downloading https://www.piwheels.org/simple/platformio/platformio-6.1.6-py3-none-any.whl (416 kB)
                                     |████████████████████████████████| 416 kB 6.9 MB/s
                                  Downloading https://www.piwheels.org/simple/esptool/esptool-4.5.1-py3-none-any.whl (320 kB)
                                     |████████████████████████████████| 320 kB 3.8 MB/s
                                Collecting tornado==6.2
                                  Downloading https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                                     |████████████████████████████████| 422 kB 2.9 MB/s
                                  Downloading https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                                     |████████████████████████████████| 90 kB 2.9 MB/s
                                  Downloading https://www.piwheels.org/simple/zeroconf/zeroconf-0.56.0-cp39-cp39-manylinux_2_31_armv7l.whl (2.1 MB)
                                     |████████████████████████████████| 2.1 MB 1.2 MB/s
                                  Downloading https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
                                  Downloading https://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
                                     |████████████████████████████████| 96 kB 1.6 MB/s
                                  Downloading https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
                                     |████████████████████████████████| 1.6 MB 6.8 MB/s
                                  Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                                     |████████████████████████████████| 75 kB 1.6 MB/s
                                  Downloading https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
                                     |████████████████████████████████| 54 kB 802 kB/s
                                  Downloading https://www.piwheels.org/simple/protobuf/protobuf-4.22.3-cp39-cp39-linux_armv7l.whl (924 kB)
                                     |████████████████████████████████| 924 kB 1.2 MB/s
                                  Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
                                  Downloading https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                                  Downloading https://www.piwheels.org/simple/cryptography/cryptography-40.0.2-cp39-cp39-linux_armv7l.whl (1.5 MB)
                                     |████████████████████████████████| 1.5 MB 1.2 MB/s
                                Collecting reedsolo<=1.6.0,>=1.5.3
                                  Downloading https://www.piwheels.org/simple/reedsolo/reedsolo-1.6.0-cp39-cp39-linux_armv7l.whl (897 kB)
                                     |████████████████████████████████| 897 kB 6.9 MB/s
                                Collecting ecdsa>=0.16.0
                                  Downloading https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                                     |████████████████████████████████| 142 kB 7.0 MB/s
                                  Downloading https://www.piwheels.org/simple/bitstring/bitstring-4.0.2-py3-none-any.whl (46 kB)
                                     |████████████████████████████████| 46 kB 1.6 MB/s
                                Collecting semantic-version==2.10.*
                                  Downloading https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-any.whl (19 kB)
                                Collecting tabulate==0.9.*
                                  Downloading https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
                                Collecting starlette==0.23.*
                                  Downloading https://www.piwheels.org/simple/starlette/starlette-0.23.1-py3-none-any.whl (64 kB)
                                     |████████████████████████████████| 64 kB 1.4 MB/s
                                Collecting pyelftools<1,>=0.27
                                  Downloading https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                                     |████████████████████████████████| 174 kB 6.9 MB/s
                                Collecting ajsonrpc==1.*
                                  Downloading https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                                Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.6->esphome) (2.25.1)
                                Collecting aiofiles==22.1.*
                                  Downloading https://www.piwheels.org/simple/aiofiles/aiofiles-22.1.0-py3-none-any.whl (14 kB)
                                Collecting wsproto==1.2.*
                                  Downloading https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
                                Collecting bottle==0.12.*
                                  Downloading https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                                     |████████████████████████████████| 90 kB 2.8 MB/s
                                Collecting marshmallow==3.*
                                  Downloading marshmallow-3.19.0-py3-none-any.whl (49 kB)
                                     |████████████████████████████████| 49 kB 1.6 MB/s
                                Collecting uvicorn==0.20.*
                                  Downloading https://www.piwheels.org/simple/uvicorn/uvicorn-0.20.0-py3-none-any.whl (56 kB)
                                     |████████████████████████████████| 56 kB 787 kB/s
                                Collecting packaging>=17.0
                                  Downloading https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                                     |████████████████████████████████| 48 kB 992 kB/s
                                Collecting typing-extensions>=3.10.0
                                  Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.5.0-py3-none-any.whl (27 kB)
                                Collecting anyio<5,>=3.4.0
                                  Downloading https://www.piwheels.org/simple/anyio/anyio-3.6.2-py3-none-any.whl (80 kB)
                                     |████████████████████████████████| 80 kB 937 kB/s
                                Collecting pytz-deprecation-shim
                                  Downloading https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                                Collecting h11>=0.8
                                  Downloading https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                                     |████████████████████████████████| 58 kB 2.0 MB/s
                                Collecting ifaddr>=0.1.7
                                  Downloading https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                                Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome) (2.10)
                                Collecting sniffio>=1.1
                                  Downloading https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                                  Downloading https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
                                     |████████████████████████████████| 364 kB 1.2 MB/s
                                  Downloading https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                                     |████████████████████████████████| 119 kB 6.9 MB/s
                                Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.5.1->esphome) (1.16.0)
                                Installing collected packages: pycparser, sniffio, cffi, tzdata, typing-extensions, packaging, ifaddr, h11, cryptography, click, async-timeout, anyio, zeroconf, wsproto, uvicorn, tabulate, starlette, semantic-version, reedsolo, pytz-deprecation-shim, pyserial, pyelftools, protobuf, noiseprotocol, marshmallow, ecdsa, colorama, bottle, bitstring, ajsonrpc, aiofiles, voluptuous, tzlocal, tornado, PyYAML, platformio, paho-mqtt, kconfiglib, esptool, esphome-dashboard, aioesphomeapi, esphome
                                  WARNING: The script uvicorn is installed in '/home/flo/.local/bin' which is not on PATH.
                                  Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
                                  WARNING: The script tabulate is installed in '/home/flo/.local/bin' which is not on PATH.
                                  WARNING: The scripts pyserial-miniterm and pyserial-ports are installed in '/home/flo/.local/bin' which is not on PATH.
                                  WARNING: The script async-json-rpc-server is installed in '/home/flo/.local/bin' which is not on PATH.
                                  WARNING: The scripts pio, piodebuggdb and platformio are installed in '/home/flo/.local/bin' which is not on PATH.
                                  WARNING: The scripts alldefconfig, allmodconfig, allnoconfig, allyesconfig, defconfig, genconfig, guiconfig, listnewconfig, menuconfig, oldconfig, olddefconfig, savedefconfig and setconfig are installed in '/home/flo/.local/bin' which is not on PATH.
                                  WARNING: The script esphome is installed in '/home/flo/.local/bin' which is not on PATH.
                                Successfully installed PyYAML-6.0 aioesphomeapi-13.5.1 aiofiles-22.1.0 ajsonrpc-1.2.0 anyio-3.6.2 async-timeout-4.0.2 bitstring-4.0.2 bottle-0.12.25 cffi-1.15.1 click-8.1.3 colorama-0.4.6 cryptography-40.0.2 ecdsa-0.18.0 esphome-2023.4.1 esphome-dashboard-20230214.0 esptool-4.5.1 h11-0.14.0 ifaddr-0.2.0 kconfiglib-13.7.1 marshmallow-3.19.0 noiseprotocol-0.3.1 packaging-23.1 paho-mqtt-1.6.1 platformio-6.1.6 protobuf-4.22.3 pycparser-2.21 pyelftools-0.29 pyserial-3.5 pytz-deprecation-shim-0.1.0.post0 reedsolo-1.6.0 semantic-version-2.10.0 sniffio-1.3.0 starlette-0.23.1 tabulate-0.9.0 tornado-6.2 typing-extensions-4.5.0 tzdata-2023.3 tzlocal-4.2 uvicorn-0.20.0 voluptuous-0.13.1 wsproto-1.2.0 zeroconf-0.56.0
                                flo@raspberrypi:~ $ export PATH=$PATH:/home/flo/.local/bin
                                Version: 2023.4.1
                                flo@raspberrypi:~ $
                                Ich glaub den ESPHome Adapter lass ich dann mal bleiben, oder versuchs mal bei HA.
                                • M mayokleckz
                                  Collecting esphome
                                  Collecting h11>=0.8
                                  Version: 2023.4.1
                                  flo@raspberrypi:~ $
                                  @mayokleckz
                                  pipx install esphome
                                  ist aber möglich das des Adapter das anders braucht/selber mitbringt.
                                    @mayokleckz
                                    mayokleckz
                                    Ich weiß ja, dass es kein iobroker Thema mehr ist, würde es aber trotzdem hier Dokumentieren, falls ich zu einer Lösung komme. Kann ja nicht sein, dass es nicht geht. . .
                                    Im Abhängigkeitsbaum zu Beginn der Kompilierung, habe ich festgestellt, dass im Vergleich zu anderen noise-c und libsodium fehlen. Kann es daran liegen?
                                    Falls ja, wie kann ich das installieren? Wenn ich google, bekomm ich nur noise canceling und audio Ergebnisse.
                                    Mein "Error"Log auf dem Raspi
                                    Dependency Graph
                                    |   |-- Hash @ 1.0
                                    Hier aus dem log einer funktionierenden Kompilierung
                                    Dependency Graph
                                    |   |-- Hash @ 1.0
                                    |-- noise-c @ 0.1.4
                                    Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_connection.cpp.o
                                    Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_frame_helper.cpp.o
                                    Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_pb2.cpp.o
                                    • M mayokleckz
                                      Dependency Graph
                                      |   |-- Hash @ 1.0
                                      Dependency Graph
                                      |   |-- Hash @ 1.0
                                      |-- noise-c @ 0.1.4
                                      mayokleckz
                                      @mayokleckz
                                      SD Karte formatieren und RaspOS 64 bit drauf. Alles installieren und es läuft.
                                      Ich brech zam.
                                      Danke @Thomas-Braun für den support und sorry, war offensichtlich unnötig.
