  4. ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert
esphomepythonwemos d1 miniplatformio
29 Beiträge 3 Kommentatoren 3.9k Aufrufe 2 Beobachtet
    @mayokleckz sagte in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
    python3-full
    Installier das mal nach.
    sudo apt install python3-full python3.9-dev libpython3.9-dev
    mayokleckz
    Die Installation funktioniert nun.
    Es war also
    cd /opt/iobroker
    npm i nopy
    sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
    und
    notwendig.
    Danke.
    Beim Kompilieren komme ich in einen neuen Fehler. Nach erstem suchen ein 32-bit<>64-bit os Problem?!
    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-7a8069.yaml...
    INFO Generating C++ source...
    INFO Compiling app...
    Processing esphome--brunnen-web-7a8069 (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
    HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
    Dependency Graph
    |-- ESPAsyncTCP-esphome @ 1.2.3
    |-- ESPAsyncWebServer-esphome @ 2.1.0
    |   |-- Hash @ 1.0
    |   |-- ESP8266WiFi @ 1.0
    |-- DNSServer @ 1.1.1
    |-- ESP8266mDNS @ 1.2
    |-- noise-c @ 0.1.4
    |   |-- libsodium @ 1.10018.1
    Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o
    sh: 1: xtensa-lx106-elf-g++: not found
    Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o
    Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o
    *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o] Error 127
    Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o
    *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o] Error 127
    *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o] Error 127
    *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o] Error 127
    ========================== [FAILED] Took 2.55 seconds ==========================
    Der erste Lösungsversuch schlug schonmal fehl.
    flo@raspberrypi:~ $ sudo apt-get install xtensa-lx106-elf
    Reading package lists... Done
    E: Unable to locate package xtensa-lx106-elf
    flo@raspberrypi:~ $
    • M mayokleckz
      Es war also
      cd /opt/iobroker
      npm i nopy
      und
      notwendig.
      Danke.
      Dependency Graph
      |   |-- Hash @ 1.0
      |-- noise-c @ 0.1.4
      flo@raspberrypi:~ $
      Versuch es mit
      sudo apt install gcc-xtensa-lx106
        Versuch es mit
        mayokleckz
        Das ging durch.
        Ich stolper trotzdem nur ahnungslos von Fehler zu Fehler.
        INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esp-home-brunnen.yaml...
        Processing esphome-brunnen (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
        HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
        Dependency Graph
        |   |-- Hash @ 1.0
        Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o
        Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o
        xtensa-lx106-elf-g++: fatal error: cannot execute 'cc1plus': execvp: No such file or directory
        compilation terminated.
        Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o
        *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o] Error 1
        *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
        *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o] Error 1
        Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o
        *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
        ========================== [FAILED] Took 2.38 seconds ==========================
        • M mayokleckz
          Das ging durch.
          Dependency Graph
          |   |-- Hash @ 1.0
          @mayokleckz
          Da fehlt dir der Cross Compiler
          https://packages.debian.org/search?searchon=contents&keywords=cc1plus&mode=exactfilename&suite=stable&arch=any
          Musst Mal schauen welcher gcc und welche Architektur da bei dir am Start ist. Danach richtet sich das zu installierende Paket.
          uname -m
          gcc --version
          sagt dir Näheres.
          Edit:
          Ich sehe gerade, das sollte eigentlich auch im Paket gcc-xtensa-lx106 drin sein. Dann weiß ich nicht was dem System noch fehlt.
            @mayokleckz
            uname -m
            gcc --version
            sagt dir Näheres.
            Edit:
            mayokleckz
            ok schade. trotzdem danke.
            Evtl. ließt hier noch jemand drüber und weiß weiter Rat.
            Ich hab mal nachgeschaut, also vorhanden scheint es zu sein.
            flo@raspberrypi:~ $ find /usr/ -name "*cc1*"
            /usr/share/terminfo/x/xterm+pcc1
            /usr/share/doc/libcc1-0
            /usr/lib/debug/.build-id/97/fca3e5a4e23a7a9dc3429293fe5f810dcc1cd6.debug
            /usr/lib/debug/.build-id/ac/24d09573ac4b8d5987190d274d9128cc1aeb38.debug
            find: ‘/usr/lib/mysql/plugin/auth_pam_tool_dir’: Permission denied
            /usr/lib/arm-linux-gnueabihf/libcc1.so.0.0.0
            /usr/lib/gcc/arm-linux-gnueabihf/10/cc1
            /usr/lib/gcc/arm-linux-gnueabihf/10/cc1plus
            /usr/lib/gcc/arm-linux-gnueabihf/10/libcc1.so
            /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so
            /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so.0.0.0
            /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1
            /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus
            /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so
            /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so.0.0.0
            /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.la
            flo@raspberrypi:~ $ find /usr/ -name "*execvp*"
            /usr/share/man/man3/execvpe.3.gz
            /usr/share/man/man3/execvp.3.gz
            flo@raspberrypi:~ $ ^C
            da eine Rechtevergabe schon mal geklappt hat, hab ich mal verzweifelt chmod versucht.
            flo@raspberrypi:~ $ sudo -u iobroker chmod a+x /usr/lib/gcc/xtensa-lx106-elf/10.2.1/c*
            chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1': Operation not permitted
            chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus': Operation not permitted
            chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/collect2': Operation not permitted
            chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtbegin.o': Operation not permitted
            chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtend.o': Operation not permitted
            chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crti.o': Operation not permitted
            chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtn.o': Operation not permitted
            flo@raspberrypi:~ $
            Dann noch in die Umgebungsvariable
            flo@raspberrypi:~ $ export PATH=$PATH:/usr/lib/gcc/xtensa-lx106-elf/10.2.1
            flo@raspberrypi:~ $ $PATH
            -bash: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/bin/g++::/usr/lib/gcc/xtensa-lx106-elf/10.2.1:
            flo@raspberrypi:~ $
            Den Adapter auch noch mal neu installiert. Kompiliert einfach nicht.
            Hänge also weiter bei
            @mayokleckz said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
            Das ging durch.
            Dependency Graph
            |   |-- Hash @ 1.0
            • M mayokleckz
              flo@raspberrypi:~ $
              flo@raspberrypi:~ $
              Das ging durch.
              Dependency Graph
              |   |-- Hash @ 1.0
              Schlachte dich da nicht so durch das Rechtegefüge. Das die Rechte bei per Paketmanager installierten Softwarepaketen nicht stimmen kommt nur extrem selten vor, ich würde behaupten nie. Eher fehlen da Gruppenzugehörigkeiten für die User.
              Gibt es da wo der Code herkommt keine Hinweise was für eine build chain benötigt wird?
              Edith: Gerade noch was herumgeschaut. Hab ähnliche Probleme gefunden, wenn ältere Versionen von esphome verwendet wurden.
              echad@chet:~ $ esphome version
              Version: 2023.4.1
              echad@chet:~ $
              Was spuckt das bei dir aus?
                Version: 2023.4.1
                echad@chet:~ $
                mayokleckz
                schrieb am zuletzt editiert von mayokleckz
                flo@raspberrypi:~ $ esphome version
                -bash: esphome: command not found
                flo@raspberrypi:~ $
                Welchen Code meinst du? Falls der YAML Code zum kompilieren gemeint ist, das ist die initiale yaml Datei, die vom ESPHome Adapter beim hinzufügen eines Geräts automatisch erzeugt wird.
                esphome:
                esp8266:
                  board: d1_mini
                # Enable logging
                logger:
                # Enable Home Assistant API
                api:
                    password: 'MyPassword'
                ota:
                  password: "d960f666ab261cb6fbcd4e21b4cd9a59"
                wifi:
                  ssid: !secret wifi_ssid
                  password: !secret wifi_password
                  # Enable fallback hotspot (captive portal) in case wifi connection fails
                  ap:
                    ssid: "Esphome-Brunnen Fallback Hotspot"
                    password: "15dOCTm1PxgU"
                captive_portal:
                • M mayokleckz
                  flo@raspberrypi:~ $
                  esphome:
                  esp8266:
                    board: d1_mini
                  # Enable logging
                  logger:
                  api:
                  ota:
                  wifi:
                    ap:
                  captive_portal:
                  @mayokleckz
                  Keine Ahnung, hab mit esphome eigentlich nix am Hut.
                    @mayokleckz
                    mayokleckz
                    Das esphome version keine Antwort gab, hab ich folgendes versucht. Brachte aber auch keine Änderung am Ergebnis. Und im falschen Verzeichnis hab ichs wohl auch noch installiert.
                    flo@raspberrypi:~ $ pip3 install esphome
                    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                    Collecting esphome
                      Downloading https://www.piwheels.org/simple/esphome/esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
                         |████████████████████████████████| 2.6 MB 1.2 MB/s
                    Collecting tzdata>=2021.1
                      Downloading https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                         |████████████████████████████████| 341 kB 7.1 MB/s
                    Collecting colorama==0.4.6
                      Downloading https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
                    Collecting tzlocal==4.2
                      Downloading https://www.piwheels.org/simple/tzlocal/tzlocal-4.2-py3-none-any.whl (19 kB)
                    Collecting PyYAML==6.0
                      Downloading https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp39-cp39-linux_armv7l.whl (45 kB)
                         |████████████████████████████████| 45 kB 1.5 MB/s
                    Collecting kconfiglib==13.7.1
                      Downloading https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                         |████████████████████████████████| 145 kB 1.2 MB/s
                    Collecting platformio==6.1.6
                      Downloading https://www.piwheels.org/simple/platformio/platformio-6.1.6-py3-none-any.whl (416 kB)
                         |████████████████████████████████| 416 kB 6.9 MB/s
                    Collecting esptool==4.5.1
                      Downloading https://www.piwheels.org/simple/esptool/esptool-4.5.1-py3-none-any.whl (320 kB)
                         |████████████████████████████████| 320 kB 3.8 MB/s
                    Collecting tornado==6.2
                      Downloading https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                         |████████████████████████████████| 422 kB 2.9 MB/s
                    Collecting pyserial==3.5
                      Downloading https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                         |████████████████████████████████| 90 kB 2.9 MB/s
                    Collecting zeroconf==0.56.0
                      Downloading https://www.piwheels.org/simple/zeroconf/zeroconf-0.56.0-cp39-cp39-manylinux_2_31_armv7l.whl (2.1 MB)
                         |████████████████████████████████| 2.1 MB 1.2 MB/s
                    Collecting voluptuous==0.13.1
                      Downloading https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
                    Collecting click==8.1.3
                      Downloading https://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
                         |████████████████████████████████| 96 kB 1.6 MB/s
                    Collecting esphome-dashboard==20230214.0
                      Downloading https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
                         |████████████████████████████████| 1.6 MB 6.8 MB/s
                    Collecting paho-mqtt==1.6.1
                      Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                         |████████████████████████████████| 75 kB 1.6 MB/s
                    Collecting aioesphomeapi==13.5.1
                      Downloading https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
                         |████████████████████████████████| 54 kB 802 kB/s
                    Collecting protobuf>=3.19.0
                      Downloading https://www.piwheels.org/simple/protobuf/protobuf-4.22.3-cp39-cp39-linux_armv7l.whl (924 kB)
                         |████████████████████████████████| 924 kB 1.2 MB/s
                    Collecting async-timeout>=4.0
                      Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
                    Collecting noiseprotocol<1.0,>=0.3.1
                      Downloading https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                    Collecting cryptography>=2.1.4
                      Downloading https://www.piwheels.org/simple/cryptography/cryptography-40.0.2-cp39-cp39-linux_armv7l.whl (1.5 MB)
                         |████████████████████████████████| 1.5 MB 1.2 MB/s
                    Collecting reedsolo<=1.6.0,>=1.5.3
                      Downloading https://www.piwheels.org/simple/reedsolo/reedsolo-1.6.0-cp39-cp39-linux_armv7l.whl (897 kB)
                         |████████████████████████████████| 897 kB 6.9 MB/s
                    Collecting ecdsa>=0.16.0
                      Downloading https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                         |████████████████████████████████| 142 kB 7.0 MB/s
                    Collecting bitstring>=3.1.6
                      Downloading https://www.piwheels.org/simple/bitstring/bitstring-4.0.2-py3-none-any.whl (46 kB)
                         |████████████████████████████████| 46 kB 1.6 MB/s
                    Collecting semantic-version==2.10.*
                      Downloading https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-any.whl (19 kB)
                    Collecting tabulate==0.9.*
                      Downloading https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
                    Collecting starlette==0.23.*
                      Downloading https://www.piwheels.org/simple/starlette/starlette-0.23.1-py3-none-any.whl (64 kB)
                         |████████████████████████████████| 64 kB 1.4 MB/s
                    Collecting pyelftools<1,>=0.27
                      Downloading https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                         |████████████████████████████████| 174 kB 6.9 MB/s
                    Collecting ajsonrpc==1.*
                      Downloading https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                    Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.6->esphome) (2.25.1)
                    Collecting aiofiles==22.1.*
                      Downloading https://www.piwheels.org/simple/aiofiles/aiofiles-22.1.0-py3-none-any.whl (14 kB)
                    Collecting wsproto==1.2.*
                      Downloading https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
                    Collecting bottle==0.12.*
                      Downloading https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                         |████████████████████████████████| 90 kB 2.8 MB/s
                    Collecting marshmallow==3.*
                      Downloading marshmallow-3.19.0-py3-none-any.whl (49 kB)
                         |████████████████████████████████| 49 kB 1.6 MB/s
                    Collecting uvicorn==0.20.*
                      Downloading https://www.piwheels.org/simple/uvicorn/uvicorn-0.20.0-py3-none-any.whl (56 kB)
                         |████████████████████████████████| 56 kB 787 kB/s
                    Collecting packaging>=17.0
                      Downloading https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                         |████████████████████████████████| 48 kB 992 kB/s
                    Collecting typing-extensions>=3.10.0
                      Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.5.0-py3-none-any.whl (27 kB)
                    Collecting anyio<5,>=3.4.0
                      Downloading https://www.piwheels.org/simple/anyio/anyio-3.6.2-py3-none-any.whl (80 kB)
                         |████████████████████████████████| 80 kB 937 kB/s
                    Collecting pytz-deprecation-shim
                      Downloading https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                    Collecting h11>=0.8
                      Downloading https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                         |████████████████████████████████| 58 kB 2.0 MB/s
                    Collecting ifaddr>=0.1.7
                      Downloading https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                    Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome) (2.10)
                    Collecting sniffio>=1.1
                      Downloading https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                    Collecting cffi>=1.12
                      Downloading https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
                         |████████████████████████████████| 364 kB 1.2 MB/s
                    Collecting pycparser
                      Downloading https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                         |████████████████████████████████| 119 kB 6.9 MB/s
                    Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.5.1->esphome) (1.16.0)
                    Installing collected packages: pycparser, sniffio, cffi, tzdata, typing-extensions, packaging, ifaddr, h11, cryptography, click, async-timeout, anyio, zeroconf, wsproto, uvicorn, tabulate, starlette, semantic-version, reedsolo, pytz-deprecation-shim, pyserial, pyelftools, protobuf, noiseprotocol, marshmallow, ecdsa, colorama, bottle, bitstring, ajsonrpc, aiofiles, voluptuous, tzlocal, tornado, PyYAML, platformio, paho-mqtt, kconfiglib, esptool, esphome-dashboard, aioesphomeapi, esphome
                      WARNING: The script uvicorn is installed in '/home/flo/.local/bin' which is not on PATH.
                      Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
                      WARNING: The script tabulate is installed in '/home/flo/.local/bin' which is not on PATH.
                      WARNING: The scripts pyserial-miniterm and pyserial-ports are installed in '/home/flo/.local/bin' which is not on PATH.
                      WARNING: The script async-json-rpc-server is installed in '/home/flo/.local/bin' which is not on PATH.
                      WARNING: The scripts pio, piodebuggdb and platformio are installed in '/home/flo/.local/bin' which is not on PATH.
                      WARNING: The scripts alldefconfig, allmodconfig, allnoconfig, allyesconfig, defconfig, genconfig, guiconfig, listnewconfig, menuconfig, oldconfig, olddefconfig, savedefconfig and setconfig are installed in '/home/flo/.local/bin' which is not on PATH.
                      WARNING: The script esphome is installed in '/home/flo/.local/bin' which is not on PATH.
                    Successfully installed PyYAML-6.0 aioesphomeapi-13.5.1 aiofiles-22.1.0 ajsonrpc-1.2.0 anyio-3.6.2 async-timeout-4.0.2 bitstring-4.0.2 bottle-0.12.25 cffi-1.15.1 click-8.1.3 colorama-0.4.6 cryptography-40.0.2 ecdsa-0.18.0 esphome-2023.4.1 esphome-dashboard-20230214.0 esptool-4.5.1 h11-0.14.0 ifaddr-0.2.0 kconfiglib-13.7.1 marshmallow-3.19.0 noiseprotocol-0.3.1 packaging-23.1 paho-mqtt-1.6.1 platformio-6.1.6 protobuf-4.22.3 pycparser-2.21 pyelftools-0.29 pyserial-3.5 pytz-deprecation-shim-0.1.0.post0 reedsolo-1.6.0 semantic-version-2.10.0 sniffio-1.3.0 starlette-0.23.1 tabulate-0.9.0 tornado-6.2 typing-extensions-4.5.0 tzdata-2023.3 tzlocal-4.2 uvicorn-0.20.0 voluptuous-0.13.1 wsproto-1.2.0 zeroconf-0.56.0
                    flo@raspberrypi:~ $ export PATH=$PATH:/home/flo/.local/bin
                    Version: 2023.4.1
                    flo@raspberrypi:~ $
                    Ich glaub den ESPHome Adapter lass ich dann mal bleiben, oder versuchs mal bei HA.
                    • M mayokleckz
                      Collecting esphome
                      Collecting h11>=0.8
                      Version: 2023.4.1
                      flo@raspberrypi:~ $
                      @mayokleckz
                      pipx install esphome
                      ist aber möglich das des Adapter das anders braucht/selber mitbringt.
                        @mayokleckz
                        mayokleckz
                        Ich weiß ja, dass es kein iobroker Thema mehr ist, würde es aber trotzdem hier Dokumentieren, falls ich zu einer Lösung komme. Kann ja nicht sein, dass es nicht geht. . .
                        Im Abhängigkeitsbaum zu Beginn der Kompilierung, habe ich festgestellt, dass im Vergleich zu anderen noise-c und libsodium fehlen. Kann es daran liegen?
                        Falls ja, wie kann ich das installieren? Wenn ich google, bekomm ich nur noise canceling und audio Ergebnisse.
                        Mein "Error"Log auf dem Raspi
                        Dependency Graph
                        |   |-- Hash @ 1.0
                        Hier aus dem log einer funktionierenden Kompilierung
                        Dependency Graph
                        |   |-- Hash @ 1.0
                        |-- noise-c @ 0.1.4
                        Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_connection.cpp.o
                        Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_frame_helper.cpp.o
                        Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_pb2.cpp.o
                        • M mayokleckz
                          Dependency Graph
                          |   |-- Hash @ 1.0
                          Dependency Graph
                          |   |-- Hash @ 1.0
                          |-- noise-c @ 0.1.4
                          mayokleckz
                          @mayokleckz
                          SD Karte formatieren und RaspOS 64 bit drauf. Alles installieren und es läuft.
                          Ich brech zam.
                          Danke @Thomas-Braun für den support und sorry, war offensichtlich unnötig.
