  4. ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert
esphomepythonwemos d1 miniplatformio
29 Beiträge 3 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • M mayokleckz
    @thomas-braun said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
    apt policy python3-full python3-pip
    flo@raspberrypi:~ $ apt policy python3-full python3-pip
    python3-full:
      Installed: (none)
      Candidate: 3.9.2-3
      Version table:
         3.9.2-3 500
    python3-pip:
      Installed: 20.3.4-4+rpt1+deb11u1
      Candidate: 20.3.4-4+rpt1+deb11u1
      Version table:
     *** 20.3.4-4+rpt1+deb11u1 500
            500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
         20.3.4-4+deb11u1 500
    flo@raspberrypi:~ $
    @mayokleckz sagte in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
    python3-full
    Installier das mal nach.
    sudo apt install python3-full python3.9-dev libpython3.9-dev
      python3-full
      mayokleckz
      Die Installation funktioniert nun.
      Es war also
      cd /opt/iobroker
      npm i nopy
      sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
      und
      notwendig.
      Danke.
      Beim Kompilieren komme ich in einen neuen Fehler. Nach erstem suchen ein 32-bit<>64-bit os Problem?!
      INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-7a8069.yaml...
      INFO Generating C++ source...
      INFO Compiling app...
      Processing esphome--brunnen-web-7a8069 (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
      HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
      Dependency Graph
      |-- ESPAsyncTCP-esphome @ 1.2.3
      |-- ESPAsyncWebServer-esphome @ 2.1.0
      |   |-- Hash @ 1.0
      |   |-- ESP8266WiFi @ 1.0
      |-- DNSServer @ 1.1.1
      |-- ESP8266mDNS @ 1.2
      |-- noise-c @ 0.1.4
      |   |-- libsodium @ 1.10018.1
      Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o
      sh: 1: xtensa-lx106-elf-g++: not found
      Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o
      Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o
      *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o] Error 127
      Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o
      *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o] Error 127
      *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o] Error 127
      *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o] Error 127
      ========================== [FAILED] Took 2.55 seconds ==========================
      Der erste Lösungsversuch schlug schonmal fehl.
      flo@raspberrypi:~ $ sudo apt-get install xtensa-lx106-elf
      Reading package lists... Done
      E: Unable to locate package xtensa-lx106-elf
      flo@raspberrypi:~ $
      • M mayokleckz
        Es war also
        cd /opt/iobroker
        npm i nopy
        und
        notwendig.
        Danke.
        Dependency Graph
        |   |-- Hash @ 1.0
        |-- noise-c @ 0.1.4
        flo@raspberrypi:~ $
        Versuch es mit
        sudo apt install gcc-xtensa-lx106
          Versuch es mit
          mayokleckz
          Das ging durch.
          Ich stolper trotzdem nur ahnungslos von Fehler zu Fehler.
          INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esp-home-brunnen.yaml...
          Processing esphome-brunnen (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
          HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
          Dependency Graph
          |   |-- Hash @ 1.0
          Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o
          Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o
          xtensa-lx106-elf-g++: fatal error: cannot execute 'cc1plus': execvp: No such file or directory
          compilation terminated.
          Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o
          *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o] Error 1
          *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
          *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o] Error 1
          Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o
          *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
          ========================== [FAILED] Took 2.38 seconds ==========================
          • M mayokleckz
            Das ging durch.
            Dependency Graph
            |   |-- Hash @ 1.0
            @mayokleckz
            Da fehlt dir der Cross Compiler
            https://packages.debian.org/search?searchon=contents&keywords=cc1plus&mode=exactfilename&suite=stable&arch=any
            Musst Mal schauen welcher gcc und welche Architektur da bei dir am Start ist. Danach richtet sich das zu installierende Paket.
            uname -m
            gcc --version
            sagt dir Näheres.
            Edit:
            Ich sehe gerade, das sollte eigentlich auch im Paket gcc-xtensa-lx106 drin sein. Dann weiß ich nicht was dem System noch fehlt.
              @mayokleckz
              uname -m
              gcc --version
              sagt dir Näheres.
              Edit:
              mayokleckz
              ok schade. trotzdem danke.
              Evtl. ließt hier noch jemand drüber und weiß weiter Rat.
              Ich hab mal nachgeschaut, also vorhanden scheint es zu sein.
              flo@raspberrypi:~ $ find /usr/ -name "*cc1*"
              /usr/share/terminfo/x/xterm+pcc1
              /usr/share/doc/libcc1-0
              /usr/lib/debug/.build-id/97/fca3e5a4e23a7a9dc3429293fe5f810dcc1cd6.debug
              /usr/lib/debug/.build-id/ac/24d09573ac4b8d5987190d274d9128cc1aeb38.debug
              find: ‘/usr/lib/mysql/plugin/auth_pam_tool_dir’: Permission denied
              /usr/lib/arm-linux-gnueabihf/libcc1.so.0.0.0
              /usr/lib/gcc/arm-linux-gnueabihf/10/cc1
              /usr/lib/gcc/arm-linux-gnueabihf/10/cc1plus
              /usr/lib/gcc/arm-linux-gnueabihf/10/libcc1.so
              /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so
              /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so.0.0.0
              /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1
              /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus
              /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so
              /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so.0.0.0
              /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.la
              flo@raspberrypi:~ $ find /usr/ -name "*execvp*"
              /usr/share/man/man3/execvpe.3.gz
              /usr/share/man/man3/execvp.3.gz
              flo@raspberrypi:~ $ ^C
              da eine Rechtevergabe schon mal geklappt hat, hab ich mal verzweifelt chmod versucht.
              flo@raspberrypi:~ $ sudo -u iobroker chmod a+x /usr/lib/gcc/xtensa-lx106-elf/10.2.1/c*
              chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1': Operation not permitted
              chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus': Operation not permitted
              chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/collect2': Operation not permitted
              chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtbegin.o': Operation not permitted
              chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtend.o': Operation not permitted
              chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crti.o': Operation not permitted
              chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtn.o': Operation not permitted
              flo@raspberrypi:~ $
              Dann noch in die Umgebungsvariable
              flo@raspberrypi:~ $ export PATH=$PATH:/usr/lib/gcc/xtensa-lx106-elf/10.2.1
              flo@raspberrypi:~ $ $PATH
              -bash: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/bin/g++::/usr/lib/gcc/xtensa-lx106-elf/10.2.1:
              flo@raspberrypi:~ $
              Den Adapter auch noch mal neu installiert. Kompiliert einfach nicht.
              Hänge also weiter bei
              @mayokleckz said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
              Das ging durch.
              Dependency Graph
              |   |-- Hash @ 1.0
              • M mayokleckz
                flo@raspberrypi:~ $
                flo@raspberrypi:~ $
                Das ging durch.
                Dependency Graph
                |   |-- Hash @ 1.0
                Schlachte dich da nicht so durch das Rechtegefüge. Das die Rechte bei per Paketmanager installierten Softwarepaketen nicht stimmen kommt nur extrem selten vor, ich würde behaupten nie. Eher fehlen da Gruppenzugehörigkeiten für die User.
                Gibt es da wo der Code herkommt keine Hinweise was für eine build chain benötigt wird?
                Edith: Gerade noch was herumgeschaut. Hab ähnliche Probleme gefunden, wenn ältere Versionen von esphome verwendet wurden.
                echad@chet:~ $ esphome version
                Version: 2023.4.1
                echad@chet:~ $
                Was spuckt das bei dir aus?
                  Version: 2023.4.1
                  echad@chet:~ $
                  mayokleckz
                  schrieb am zuletzt editiert von mayokleckz
                  flo@raspberrypi:~ $ esphome version
                  -bash: esphome: command not found
                  flo@raspberrypi:~ $
                  Welchen Code meinst du? Falls der YAML Code zum kompilieren gemeint ist, das ist die initiale yaml Datei, die vom ESPHome Adapter beim hinzufügen eines Geräts automatisch erzeugt wird.
                  esphome:
                  esp8266:
                    board: d1_mini
                  # Enable logging
                  logger:
                  # Enable Home Assistant API
                  api:
                      password: 'MyPassword'
                  ota:
                    password: "d960f666ab261cb6fbcd4e21b4cd9a59"
                  wifi:
                    ssid: !secret wifi_ssid
                    password: !secret wifi_password
                    # Enable fallback hotspot (captive portal) in case wifi connection fails
                    ap:
                      ssid: "Esphome-Brunnen Fallback Hotspot"
                      password: "15dOCTm1PxgU"
                  captive_portal:
                  • M mayokleckz
                    flo@raspberrypi:~ $
                    esphome:
                    esp8266:
                      board: d1_mini
                    # Enable logging
                    logger:
                    api:
                    ota:
                    wifi:
                      ap:
                    captive_portal:
                    @mayokleckz
                    Keine Ahnung, hab mit esphome eigentlich nix am Hut.
                      @mayokleckz
                      mayokleckz
                      Das esphome version keine Antwort gab, hab ich folgendes versucht. Brachte aber auch keine Änderung am Ergebnis. Und im falschen Verzeichnis hab ichs wohl auch noch installiert.
                      flo@raspberrypi:~ $ pip3 install esphome
                      Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                      Collecting esphome
                        Downloading https://www.piwheels.org/simple/esphome/esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
                           |████████████████████████████████| 2.6 MB 1.2 MB/s
                      Collecting tzdata>=2021.1
                        Downloading https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                           |████████████████████████████████| 341 kB 7.1 MB/s
                      Collecting colorama==0.4.6
                        Downloading https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
                      Collecting tzlocal==4.2
                        Downloading https://www.piwheels.org/simple/tzlocal/tzlocal-4.2-py3-none-any.whl (19 kB)
                      Collecting PyYAML==6.0
                        Downloading https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp39-cp39-linux_armv7l.whl (45 kB)
                           |████████████████████████████████| 45 kB 1.5 MB/s
                      Collecting kconfiglib==13.7.1
                        Downloading https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                           |████████████████████████████████| 145 kB 1.2 MB/s
                      Collecting platformio==6.1.6
                        Downloading https://www.piwheels.org/simple/platformio/platformio-6.1.6-py3-none-any.whl (416 kB)
                           |████████████████████████████████| 416 kB 6.9 MB/s
                      Collecting esptool==4.5.1
                        Downloading https://www.piwheels.org/simple/esptool/esptool-4.5.1-py3-none-any.whl (320 kB)
                           |████████████████████████████████| 320 kB 3.8 MB/s
                      Collecting tornado==6.2
                        Downloading https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                           |████████████████████████████████| 422 kB 2.9 MB/s
                      Collecting pyserial==3.5
                        Downloading https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                           |████████████████████████████████| 90 kB 2.9 MB/s
                      Collecting zeroconf==0.56.0
                        Downloading https://www.piwheels.org/simple/zeroconf/zeroconf-0.56.0-cp39-cp39-manylinux_2_31_armv7l.whl (2.1 MB)
                           |████████████████████████████████| 2.1 MB 1.2 MB/s
                      Collecting voluptuous==0.13.1
                        Downloading https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
                      Collecting click==8.1.3
                        Downloading https://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
                           |████████████████████████████████| 96 kB 1.6 MB/s
                      Collecting esphome-dashboard==20230214.0
                        Downloading https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
                           |████████████████████████████████| 1.6 MB 6.8 MB/s
                      Collecting paho-mqtt==1.6.1
                        Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                           |████████████████████████████████| 75 kB 1.6 MB/s
                      Collecting aioesphomeapi==13.5.1
                        Downloading https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
                           |████████████████████████████████| 54 kB 802 kB/s
                      Collecting protobuf>=3.19.0
                        Downloading https://www.piwheels.org/simple/protobuf/protobuf-4.22.3-cp39-cp39-linux_armv7l.whl (924 kB)
                           |████████████████████████████████| 924 kB 1.2 MB/s
                      Collecting async-timeout>=4.0
                        Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
                      Collecting noiseprotocol<1.0,>=0.3.1
                        Downloading https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                      Collecting cryptography>=2.1.4
                        Downloading https://www.piwheels.org/simple/cryptography/cryptography-40.0.2-cp39-cp39-linux_armv7l.whl (1.5 MB)
                           |████████████████████████████████| 1.5 MB 1.2 MB/s
                      Collecting reedsolo<=1.6.0,>=1.5.3
                        Downloading https://www.piwheels.org/simple/reedsolo/reedsolo-1.6.0-cp39-cp39-linux_armv7l.whl (897 kB)
                           |████████████████████████████████| 897 kB 6.9 MB/s
                      Collecting ecdsa>=0.16.0
                        Downloading https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                           |████████████████████████████████| 142 kB 7.0 MB/s
                      Collecting bitstring>=3.1.6
                        Downloading https://www.piwheels.org/simple/bitstring/bitstring-4.0.2-py3-none-any.whl (46 kB)
                           |████████████████████████████████| 46 kB 1.6 MB/s
                      Collecting semantic-version==2.10.*
                        Downloading https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-any.whl (19 kB)
                      Collecting tabulate==0.9.*
                        Downloading https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
                      Collecting starlette==0.23.*
                        Downloading https://www.piwheels.org/simple/starlette/starlette-0.23.1-py3-none-any.whl (64 kB)
                           |████████████████████████████████| 64 kB 1.4 MB/s
                      Collecting pyelftools<1,>=0.27
                        Downloading https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                           |████████████████████████████████| 174 kB 6.9 MB/s
                      Collecting ajsonrpc==1.*
                        Downloading https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                      Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.6->esphome) (2.25.1)
                      Collecting aiofiles==22.1.*
                        Downloading https://www.piwheels.org/simple/aiofiles/aiofiles-22.1.0-py3-none-any.whl (14 kB)
                      Collecting wsproto==1.2.*
                        Downloading https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
                      Collecting bottle==0.12.*
                        Downloading https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                           |████████████████████████████████| 90 kB 2.8 MB/s
                      Collecting marshmallow==3.*
                        Downloading marshmallow-3.19.0-py3-none-any.whl (49 kB)
                           |████████████████████████████████| 49 kB 1.6 MB/s
                      Collecting uvicorn==0.20.*
                        Downloading https://www.piwheels.org/simple/uvicorn/uvicorn-0.20.0-py3-none-any.whl (56 kB)
                           |████████████████████████████████| 56 kB 787 kB/s
                      Collecting packaging>=17.0
                        Downloading https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                           |████████████████████████████████| 48 kB 992 kB/s
                      Collecting typing-extensions>=3.10.0
                        Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.5.0-py3-none-any.whl (27 kB)
                      Collecting anyio<5,>=3.4.0
                        Downloading https://www.piwheels.org/simple/anyio/anyio-3.6.2-py3-none-any.whl (80 kB)
                           |████████████████████████████████| 80 kB 937 kB/s
                      Collecting pytz-deprecation-shim
                        Downloading https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                      Collecting h11>=0.8
                        Downloading https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                           |████████████████████████████████| 58 kB 2.0 MB/s
                      Collecting ifaddr>=0.1.7
                        Downloading https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                      Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome) (2.10)
                      Collecting sniffio>=1.1
                        Downloading https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                      Collecting cffi>=1.12
                        Downloading https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
                           |████████████████████████████████| 364 kB 1.2 MB/s
                      Collecting pycparser
                        Downloading https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                           |████████████████████████████████| 119 kB 6.9 MB/s
                      Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.5.1->esphome) (1.16.0)
                      Installing collected packages: pycparser, sniffio, cffi, tzdata, typing-extensions, packaging, ifaddr, h11, cryptography, click, async-timeout, anyio, zeroconf, wsproto, uvicorn, tabulate, starlette, semantic-version, reedsolo, pytz-deprecation-shim, pyserial, pyelftools, protobuf, noiseprotocol, marshmallow, ecdsa, colorama, bottle, bitstring, ajsonrpc, aiofiles, voluptuous, tzlocal, tornado, PyYAML, platformio, paho-mqtt, kconfiglib, esptool, esphome-dashboard, aioesphomeapi, esphome
                        WARNING: The script uvicorn is installed in '/home/flo/.local/bin' which is not on PATH.
                        Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
                        WARNING: The script tabulate is installed in '/home/flo/.local/bin' which is not on PATH.
                        WARNING: The scripts pyserial-miniterm and pyserial-ports are installed in '/home/flo/.local/bin' which is not on PATH.
                        WARNING: The script async-json-rpc-server is installed in '/home/flo/.local/bin' which is not on PATH.
                        WARNING: The scripts pio, piodebuggdb and platformio are installed in '/home/flo/.local/bin' which is not on PATH.
                        WARNING: The scripts alldefconfig, allmodconfig, allnoconfig, allyesconfig, defconfig, genconfig, guiconfig, listnewconfig, menuconfig, oldconfig, olddefconfig, savedefconfig and setconfig are installed in '/home/flo/.local/bin' which is not on PATH.
                        WARNING: The script esphome is installed in '/home/flo/.local/bin' which is not on PATH.
                      Successfully installed PyYAML-6.0 aioesphomeapi-13.5.1 aiofiles-22.1.0 ajsonrpc-1.2.0 anyio-3.6.2 async-timeout-4.0.2 bitstring-4.0.2 bottle-0.12.25 cffi-1.15.1 click-8.1.3 colorama-0.4.6 cryptography-40.0.2 ecdsa-0.18.0 esphome-2023.4.1 esphome-dashboard-20230214.0 esptool-4.5.1 h11-0.14.0 ifaddr-0.2.0 kconfiglib-13.7.1 marshmallow-3.19.0 noiseprotocol-0.3.1 packaging-23.1 paho-mqtt-1.6.1 platformio-6.1.6 protobuf-4.22.3 pycparser-2.21 pyelftools-0.29 pyserial-3.5 pytz-deprecation-shim-0.1.0.post0 reedsolo-1.6.0 semantic-version-2.10.0 sniffio-1.3.0 starlette-0.23.1 tabulate-0.9.0 tornado-6.2 typing-extensions-4.5.0 tzdata-2023.3 tzlocal-4.2 uvicorn-0.20.0 voluptuous-0.13.1 wsproto-1.2.0 zeroconf-0.56.0
                      flo@raspberrypi:~ $ export PATH=$PATH:/home/flo/.local/bin
                      Version: 2023.4.1
                      flo@raspberrypi:~ $
                      Ich glaub den ESPHome Adapter lass ich dann mal bleiben, oder versuchs mal bei HA.
                      • M mayokleckz
                        Collecting esphome
                        Collecting h11>=0.8
                        Version: 2023.4.1
                        flo@raspberrypi:~ $
                        @mayokleckz
                        pipx install esphome
                        ist aber möglich das des Adapter das anders braucht/selber mitbringt.
                          @mayokleckz
                          mayokleckz
                          Ich weiß ja, dass es kein iobroker Thema mehr ist, würde es aber trotzdem hier Dokumentieren, falls ich zu einer Lösung komme. Kann ja nicht sein, dass es nicht geht. . .
                          Im Abhängigkeitsbaum zu Beginn der Kompilierung, habe ich festgestellt, dass im Vergleich zu anderen noise-c und libsodium fehlen. Kann es daran liegen?
                          Falls ja, wie kann ich das installieren? Wenn ich google, bekomm ich nur noise canceling und audio Ergebnisse.
                          Mein "Error"Log auf dem Raspi
                          Dependency Graph
                          |   |-- Hash @ 1.0
                          Hier aus dem log einer funktionierenden Kompilierung
                          Dependency Graph
                          |   |-- Hash @ 1.0
                          |-- noise-c @ 0.1.4
                          Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_connection.cpp.o
                          Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_frame_helper.cpp.o
                          Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_pb2.cpp.o
                          • M mayokleckz
                            Dependency Graph
                            |   |-- Hash @ 1.0
                            Dependency Graph
                            |   |-- Hash @ 1.0
                            |-- noise-c @ 0.1.4
                            mayokleckz
                            @mayokleckz
                            SD Karte formatieren und RaspOS 64 bit drauf. Alles installieren und es läuft.
                            Ich brech zam.
                            Danke @Thomas-Braun für den support und sorry, war offensichtlich unnötig.
